The Linux kernel has long RCU-bh read-side critical sections that
intolerably increase scheduling latency under mainline's RCU-bh rules,
which include RCU-bh read-side critical sections being non-preemptible.
This patch therefore arranges for RCU-bh to be implemented in terms of
RCU-preempt for CONFIG_PREEMPT_RT_FULL=y.
This has the downside of defeating the purpose of RCU-bh, namely,
handling the case where the system is subjected to a network-based
denial-of-service attack that keeps at least one CPU doing full-time
softirq processing. This issue will be fixed by a later commit.
The current commit will need some work to make it appropriate for
mainline use, for example, it needs to be extended to cover Tiny RCU.
[ paulmck: Added a useful changelog ]
Link: http://lkml.kernel.org/r/20111005185938.GA20403@linux.vnet.ibm.com
Although it is legal to use RCU during early boot, it is anything
but legal to use RCU at runtime from an offlined CPU. After all, RCU
explicitly ignores offlined CPUs. This commit therefore adds checks
for runtime use of RCU from offlined CPUs.
These checks are not perfect, in particular, they can be subverted
through use of things like rcu_dereference_raw(). Note that it is not
possible to put checks in rcu_read_lock() and friends due to the fact
that these primitives are used in code that might be used under either
RCU or lock-based protection, which means that checking rcu_read_lock()
gets you fat piles of false positives.
Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org>
Report that none of the rcu read lock maps are held while in an RCU
extended quiescent state (the section between rcu_idle_enter()
and rcu_idle_exit()). This helps detect any use of rcu_dereference()
and friends from within the section in idle where RCU is not allowed.
This way we can guarantee an extended quiescent window where the CPU
can be put in dyntick idle mode or can simply aoid to be part of any
global grace period completion while in the idle loop.
Uses of RCU from such mode are totally ignored by RCU, hence the
importance of these checks.
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
Trace the rcutorture RCU accesses and dump the trace buffer when the
first failure is detected.
The changed files were only including linux/module.h for the
EXPORT_SYMBOL infrastructure, and nothing else. Revector them
onto the isolated export header for faster compile times.
Nothing to see here but a whole lot of instances of:
-#include <linux/module.h>
+#include <linux/export.h>
This commit is only changing the kernel dir; next targets
will probably be mm, fs, the arch dirs, etc.
There was recently some controversy about the overhead of invoking RCU
callbacks. Add TRACE_EVENT()s to obtain fine-grained timings for the
start and stop of a batch of callbacks and also for each callback invoked.
Pull the code that waits for an RCU grace period into a single function,
which is then called by synchronize_rcu() and friends in the case of
TREE_RCU and TREE_PREEMPT_RCU, and from rcu_barrier() and friends in
the case of TINY_RCU and TINY_PREEMPT_RCU.
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Avoid additional multiple-warning confusion in memory-corruption scenarios.
The prohibition of DEBUG_OBJECTS_RCU_HEAD from !PREEMPT was due to the
fixup actions. So just produce a warning from !PREEMPT.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
The build will break if you change the Kconfig to allow
DEBUG_OBJECTS_RCU_HEAD and !PREEMPT, so document the reasoning
near where the breakage would occur.
DEBUG_OBJECTS_RCU_HEAD depends on PREEMPT, so #ifndef CONFIG_PREEMPT
is totally useless in kernel/rcupdate.c.
Signed-off-by: WANG Cong <amwang@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/rcu
As suggested by Linus, push the irqs_disabled() down to the
rcu_read_lock_bh_held() level so that all callers get the benefit
of the correct check.
This commit provides definitions for the __rcu annotation defined earlier.
This annotation permits sparse to check for correct use of RCU-protected
pointers. If a pointer that is annotated with __rcu is accessed
directly (as opposed to via rcu_dereference(), rcu_assign_pointer(),
or one of their variants), sparse can be made to complain. To enable
such complaints, use the new default-disabled CONFIG_SPARSE_RCU_POINTER
kernel configuration option. Please note that these sparse complaints are
intended to be a debugging aid, -not- a code-style-enforcement mechanism.
There are special rcu_dereference_protected() and rcu_access_pointer()
accessors for use when RCU read-side protection is not required, for
example, when no other CPU has access to the data structure in question
or while the current CPU hold the update-side lock.
This patch also updates a number of docbook comments that were showing
their age.
Cc: Christopher Li <sparse@chrisli.org>
Helps finding racy users of call_rcu(), which results in hangs because list
entries are overwritten and/or skipped.
Changelog since v4:
- Bissectability is now OK
- Now generate a WARN_ON_ONCE() for non-initialized rcu_head passed to
call_rcu(). Statically initialized objects are detected with
object_is_static().
- Rename rcu_head_init_on_stack to init_rcu_head_on_stack.
- Remove init_rcu_head() completely.
Changelog since v3:
- Include comments from Lai Jiangshan
This new patch version is based on the debugobjects with the newly introduced
"active state" tracker.
Non-initialized entries are all considered as "statically initialized". An
activation fixup (triggered by call_rcu()) takes care of performing the debug
object initialization without issuing any warning. Since we cannot increase the
size of struct rcu_head, I don't see much room to put an identifier for
statically initialized rcu_head structures. So for now, we have to live without
"activation without explicit init" detection. But the main purpose of this debug
option is to detect double-activations (double call_rcu() use of a rcu_head
before the callback is executed), which is correctly addressed here.
This also detects potential internal RCU callback corruption, which would cause
the callbacks to be executed twice.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
CC: David S. Miller <davem@davemloft.net>
CC: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
CC: akpm@linux-foundation.org
CC: mingo@elte.hu
CC: laijs@cn.fujitsu.com
CC: dipankar@in.ibm.com
CC: josh@joshtriplett.org
CC: dvhltc@us.ibm.com
CC: niv@us.ibm.com
CC: tglx@linutronix.de
CC: peterz@infradead.org
CC: rostedt@goodmis.org
CC: Valdis.Kletnieks@vt.edu
CC: dhowells@redhat.com
CC: eric.dumazet@gmail.com
CC: Alexey Dobriyan <adobriyan@gmail.com>
Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
TINY_RCU does not need rcu_scheduler_active unless CONFIG_DEBUG_LOCK_ALLOC.
So conditionally compile rcu_scheduler_active in order to slim down
rcutiny a bit more. Also gets rid of an EXPORT_SYMBOL_GPL, which is
responsible for most of the slimming.
Some RCU-lockdep splat repairs need to know whether they are running
in a single-threaded process. Unfortunately, the thread_group_empty()
primitive is defined in sched.h, and can induce #include hell. This
commit therefore introduces a rcu_my_thread_group_empty() wrapper that
is defined in rcupdate.c, thus avoiding the need to include sched.h
everywhere.
Signed-off-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
The lockdep facility temporarily disables lockdep checking by
incrementing the current->lockdep_recursion variable. Such
disabling happens in NMIs and in other situations where lockdep
might expect to recurse on itself.
This patch therefore checks current->lockdep_recursion, disabling RCU
lockdep splats when this variable is non-zero. In addition, this patch
removes the "likely()", as suggested by Lai Jiangshan.
Reported-by: Frederic Weisbecker <fweisbec@gmail.com>
Reported-by: David Miller <davem@davemloft.net>
Tested-by: Frederic Weisbecker <fweisbec@gmail.com>
Cc: laijs@cn.fujitsu.com
Cc: dipankar@in.ibm.com
Cc: mathieu.desnoyers@polymtl.ca
Cc: josh@joshtriplett.org
Cc: dvhltc@us.ibm.com
Cc: niv@us.ibm.com
Cc: peterz@infradead.org
Cc: rostedt@goodmis.org
Cc: Valdis.Kletnieks@vt.edu
Cc: dhowells@redhat.com
Cc: eric.dumazet@gmail.com
LKML-Reference: <20100415195039.GA22623@linux.vnet.ibm.com>
Disabling BH can stand in for rcu_read_lock_bh(), and this patch
updates rcu_read_lock_bh_held() to allow for this. In order to
avoid include-file hell, this function is moved out of line to
kernel/rcupdate.c.
This fixes a false positive RCU warning.
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Acked-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: niv@us.ibm.com
LKML-Reference: <20100316000343.GA25857@linux.vnet.ibm.com>
Kernel modules using rcu_read_lock_sched_held() must now have
access to rcu_scheduler_active, so it must be exported.
This should fix the fix for the boot-time RCU-lockdep splat.
Cc: niv@us.ibm.com
LKML-Reference: <20100226030230.GA7743@linux.vnet.ibm.com>
Before the scheduler starts, all tasks are non-preemptible by
definition. So, during that time, rcu_read_lock_sched_held()
needs to always return "true". This patch makes that be so.
Cc: niv@us.ibm.com
LKML-Reference: <1267135607-7056-2-git-send-email-paulmck@linux.vnet.ibm.com>
Inspection is proving insufficient to catch all RCU misuses,
which is understandable given that rcu_dereference() might be
protected by any of four different flavors of RCU (RCU, RCU-bh,
RCU-sched, and SRCU), and might also/instead be protected by any
of a number of locking primitives. It is therefore time to
enlist the aid of lockdep.
This set of patches is inspired by earlier work by Peter
Zijlstra and Thomas Gleixner, and takes the following approach:
o Set up separate lockdep classes for RCU, RCU-bh, and RCU-sched.
o Set up separate lockdep classes for each instance of SRCU.
o Create primitives that check for being in an RCU read-side
critical section. These return exact answers if lockdep is
fully enabled, but if unsure, report being in an RCU read-side
critical section. (We want to avoid false positives!)
The primitives are:
For RCU: rcu_read_lock_held(void)
For RCU-bh: rcu_read_lock_bh_held(void)
For RCU-sched: rcu_read_lock_sched_held(void)
For SRCU: srcu_read_lock_held(struct srcu_struct *sp)
o Add rcu_dereference_check(), which takes a second argument
in which one places a boolean expression based on the above
primitives and/or lockdep_is_held().
o A new kernel configuration parameter, CONFIG_PROVE_RCU, enables
rcu_dereference_check(). This depends on CONFIG_PROVE_LOCKING,
and should be quite helpful during the transition period while
CONFIG_PROVE_RCU-unaware patches are in flight.
The existing rcu_dereference() primitive does no checking, but
upcoming patches will change that.
Cc: niv@us.ibm.com
LKML-Reference: <1266887105-1528-1-git-send-email-paulmck@linux.vnet.ibm.com>
Remove #ifdefs from kernel/rcupdate.c and
include/linux/rcupdate.h by moving code to
include/linux/rcutiny.h, include/linux/rcutree.h, and
kernel/rcutree.c.
Also remove some definitions that are no longer used.
Cc: niv@us.ibm.com
LKML-Reference: <1258908830885-git-send-email->
The functions rcu_init() is a wrapper for __rcu_init(), and also
sets up the CPU-hotplug notifier for rcu_barrier_cpu_hotplug().
But TINY_RCU doesn't need CPU-hotplug notification, and the
rcu_barrier_cpu_hotplug() is a simple wrapper for
rcu_cpu_notify().
So push rcu_init() out to kernel/rcutree.c and kernel/rcutiny.c
and get rid of the wrapper function rcu_barrier_cpu_hotplug().
Cc: niv@us.ibm.com
LKML-Reference: <12589088302320-git-send-email->
This patch is a version of RCU designed for !SMP provided for a
small-footprint RCU implementation. In particular, the
implementation of synchronize_rcu() is extremely lightweight and
high performance. It passes rcutorture testing in each of the
four relevant configurations (combinations of NO_HZ and PREEMPT)
on x86. This saves about 1K bytes compared to old Classic RCU
(which is no longer in mainline), and more than three kilobytes
compared to Hierarchical RCU (updated to 2.6.30):
CONFIG_TREE_RCU:
text data bss dec filename
183 4 0 187 kernel/rcupdate.o
2783 520 36 3339 kernel/rcutree.o
3526 Total (vs 4565 for v7)
CONFIG_TREE_PREEMPT_RCU:
263 4 0 267 kernel/rcupdate.o
4594 776 52 5422 kernel/rcutree.o
5689 Total (6155 for v7)
CONFIG_TINY_RCU:
96 4 0 100 kernel/rcupdate.o
734 24 0 758 kernel/rcutiny.o
858 Total (vs 848 for v7)
The above is for x86. Your mileage may vary on other platforms.
Further compression is possible, but is being procrastinated.
Changes from v7 (http://lkml.org/lkml/2009/10/9/388)
o Apply Lai Jiangshan's review comments (aside from
might_sleep() in synchronize_sched(), which is covered by SMP builds).
o Fix up expedited primitives.
Changes from v6 (http://lkml.org/lkml/2009/9/23/293).
o Forward ported to put it into the 2.6.33 stream.
o Added lockdep support.
o Make lightweight rcu_barrier.
Changes from v5 (http://lkml.org/lkml/2009/6/23/12).
o Ported to latest pre-2.6.32 merge window kernel.
- Renamed rcu_qsctr_inc() to rcu_sched_qs().
- Renamed rcu_bh_qsctr_inc() to rcu_bh_qs().
- Provided trivial rcu_cpu_notify().
- Provided trivial exit_rcu().
- Provided trivial rcu_needs_cpu().
- Fixed up the rcu_*_enter/exit() functions in linux/hardirq.h.
o Removed the dependence on EMBEDDED, with a view to making
TINY_RCU default for !SMP at some time in the future.
o Added (trivial) support for expedited grace periods.
Changes from v4 (http://lkml.org/lkml/2009/5/2/91) include:
o Squeeze the size down a bit further by removing the
->completed field from struct rcu_ctrlblk.
o This permits synchronize_rcu() to become the empty function.
Previous concerns about rcutorture were unfounded, as
rcutorture correctly handles a constant value from
rcu_batches_completed() and rcu_batches_completed_bh().
Changes from v3 (http://lkml.org/lkml/2009/3/29/221) include:
o Changed rcu_batches_completed(), rcu_batches_completed_bh()
rcu_enter_nohz(), rcu_exit_nohz(), rcu_nmi_enter(), and
rcu_nmi_exit(), to be static inlines, as suggested by David
Howells. Doing this saves about 100 bytes from rcutiny.o.
(The numbers between v3 and this v4 of the patch are not directly
comparable, since they are against different versions of Linux.)
Changes from v2 (http://lkml.org/lkml/2009/2/3/333) include:
o Fix whitespace issues.
o Change short-circuit "||" operator to instead be "+" in order
to fix performance bug noted by "kraai" on LWN.
(http://lwn.net/Articles/324348/)
Changes from v1 (http://lkml.org/lkml/2009/1/13/440) include:
o This version depends on EMBEDDED as well as !SMP, as suggested
by Ingo.
o Updated rcu_needs_cpu() to unconditionally return zero,
permitting the CPU to enter dynticks-idle mode at any time.
This works because callbacks can be invoked upon entry to
dynticks-idle mode.
o Paul is now OK with this being included, based on a poll at
the Kernel Miniconf at linux.conf.au, where about ten people said
that they cared about saving 900 bytes on single-CPU systems.
o Applies to both mainline and tip/core/rcu.
Acked-by: Josh Triplett <josh@joshtriplett.org>
Cc: niv@us.ibm.com
Cc: avi@redhat.com
Cc: mtosatti@redhat.com
LKML-Reference: <12565226351355-git-send-email->
Move the existing rcu_barrier() implementation to rcutree.c,
consistent with the fact that the rcu_barrier() implementation is
tied quite tightly to the RCU implementation.
This opens the way to simplify and fix rcutree.c's rcu_barrier()
implementation in a later patch.
Cc: akpm@linux-foundation.org
Cc: niv@us.ibm.com
LKML-Reference: <12548908982563-git-send-email->
The rcu_barrier enum causes several problems:
(1) you have to define the enum somewhere, and there is no
convenient place,
(2) the difference between TREE_RCU and TREE_PREEMPT_RCU causes
problems when you need to map from rcu_barrier enum to struct
rcu_state,
(3) the switch statement are large, and
(4) TINY_RCU really needs a different rcu_barrier() than do the
treercu implementations.
So replace it with a functionally equivalent but cleaner function
pointer abstraction.
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
Cc: niv@us.ibm.com
LKML-Reference: <12541998232366-git-send-email->
Move the rcu_lock_map definition from rcutree.c to rcupdate.c so that
TINY_RCU can use lockdep.
Reported-by: Ingo Molnar <mingo@elte.hu>
Move declarations and update storage classes to make checkpatch happy.
Cc: niv@us.ibm.com
LKML-Reference: <12537246441701-git-send-email->
Fix a number of whitespace ^Ierrors in the include/linux/rcu*
and the kernel/rcu* files.
Cc: niv@us.ibm.com
LKML-Reference: <20090918172819.GA24405@linux.vnet.ibm.com>
[ did more checkpatch fixlets ]
The redirection of synchronize_sched() to synchronize_rcu() was
appropriate for TREE_RCU, but not for TREE_PREEMPT_RCU.
Fix this by creating an underlying synchronize_sched(). TREE_RCU
then redirects synchronize_rcu() to synchronize_sched(), while
TREE_PREEMPT_RCU has its own version of synchronize_rcu().
Cc: niv@us.ibm.com
LKML-Reference: <12528585111916-git-send-email->
Ingo Molnar reported this lockup:
[ 200.380003] Hangcheck: hangcheck value past margin!
[ 248.192003] INFO: task S99local:2974 blocked for more than 120 seconds.
[ 248.194532] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 248.202330] S99local D 0000000c 6256 2974 2687 0x00000000
[ 248.208929] 9c7ebe90 00000086 6b67ef8b 0000000c 9f25a610 81a69869 00000001 820b6990
[ 248.216123] 820b6990 820b6990 9c6e4c20 9c6e4eb4 82c78990 00000000 6b993559 0000000c
[ 248.220616] 9c7ebe90 8105f22a 9c6e4eb4 9c6e4c20 00000001 9c7ebe98 9c7ebeb4 81a65cb3
[ 248.229990] Call Trace:
[ 248.234049] [<81a69869>] ? _spin_unlock_irqrestore+0x22/0x37
[ 248.239769] [<8105f22a>] ? prepare_to_wait+0x48/0x4e
[ 248.244796] [<81a65cb3>] rcu_barrier_cpu_hotplug+0xaa/0xc9
[ 248.250343] [<8105f029>] ? autoremove_wake_function+0x0/0x38
[ 248.256063] [<81062cf2>] notifier_call_chain+0x49/0x71
[ 248.261263] [<81062da0>] raw_notifier_call_chain+0x11/0x13
[ 248.266809] [<81a0b475>] _cpu_down+0x272/0x288
[ 248.271316] [<81a0b4d5>] cpu_down+0x4a/0xa2
[ 248.275563] [<81a0c48a>] store_online+0x2a/0x5e
[ 248.280156] [<81a0c460>] ? store_online+0x0/0x5e
[ 248.284836] [<814ddc35>] sysdev_store+0x20/0x28
[ 248.289429] [<8112e403>] sysfs_write_file+0xb8/0xe3
[ 248.294369] [<8112e34b>] ? sysfs_write_file+0x0/0xe3
[ 248.299396] [<810e4c8f>] vfs_write+0x91/0x120
[ 248.303817] [<810e4dc1>] sys_write+0x40/0x65
[ 248.308150] [<81002d73>] sysenter_do_call+0x12/0x28
This change moves an RCU grace period delay off of the
critical path for CPU-hotunplug operations.
Since RCU callback migration is only performed on
CPU-hotunplug operations, and since the rcu_barrier() race is
provoked only by consecutive CPU-hotunplug operations, it is
not necessary to delay the end of a given CPU-hotunplug
operation.
We can instead choose to delay the beginning of the next
CPU-hotunplug operation.
Cc: Josh Triplett <josht@linux.vnet.ibm.com>
Cc: niv@us.ibm.com
Cc: hugh.dickins@tiscali.co.uk
Cc: benh@kernel.crashing.org
LKML-Reference: <20090819060614.GA14383@linux.vnet.ibm.com>
Use the new cpu_notifier() API to simplify RCU's CPU-hotplug
notifiers, collapsing down to a single such notifier.
This makes it trivial to provide the notifier-ordering
guarantee that rcu_barrier() depends on.
Also remove redundant open_softirq() calls from Hierarchical
RCU notifier.
Cc: josht@linux.vnet.ibm.com
Cc: niv@us.ibm.com
LKML-Reference: <12503552312510-git-send-email->
This adds the synchronize_sched_expedited() primitive that
implements the "big hammer" expedited RCU grace periods.
This primitive is placed in kernel/sched.c rather than
kernel/rcupdate.c due to its need to interact closely with the
migration_thread() kthread.
The idea is to wake up this kthread with req->task set to NULL,
in response to which the kthread reports the quiescent state
resulting from the kthread having been scheduled.
Because this patch needs to fallback to the slow versions of
the primitives in response to some races with CPU onlining and
offlining, a new synchronize_rcu_bh() primitive is added as
well.
Cc: torvalds@linux-foundation.org
Cc: davem@davemloft.net
Cc: dada1@cosmosbay.com
Cc: zbr@ioremap.net
Cc: jeff.chua.linux@gmail.com
Cc: paulus@samba.org
Cc: jengelh@medozas.de
Cc: r000n@r000n.net
LKML-Reference: <12459460982947-git-send-email->
Don't try and predeclare inline funcs like this:
static inline void wait_migrated_callbacks(void)
static void _rcu_barrier(enum rcu_barrier type)
wait_migrated_callbacks();
wait_event(rcu_migrate_wq, !atomic_read(&rcu_migrate_type_count));
as it upsets some versions of gcc under some circumstances:
kernel/rcupdate.c: In function `_rcu_barrier':
kernel/rcupdate.c:125: sorry, unimplemented: inlining failed in call to 'wait_migrated_callbacks': function body not available
kernel/rcupdate.c:152: sorry, unimplemented: called from here
This can be dealt with by simply putting the static variables (rcu_migrate_*)
at the top, and moving the implementation of the function up so that it
replaces its forward declaration.
Cc: Dipankar Sarma <dipankar@in.ibm.com>
to online cpu
cpu hotplug may happen asynchronously, some rcu callbacks are maybe
still on dead cpu, rcu_barrier() also needs to wait for these rcu
callbacks to complete, so we must ensure callbacks in dead cpu are
migrated to online cpu.
Paul E. McKenney's review:
Good stuff, Lai!!! Simpler than any of the approaches that I was
considering, and, better yet, independent of the underlying RCU
implementation!!!
I was initially worried that wake_up() might wake only one of two
possible wait_event()s, namely rcu_barrier() and the CPU_POST_DEAD code,
but the fact that wait_event() clears WQ_FLAG_EXCLUSIVE avoids that issue.
I was also worried about the fact that different RCU implementations have
different mappings of call_rcu(), call_rcu_bh(), and call_rcu_sched(), but
this is OK as well because we just get an extra (harmless) callback in the
case that they map together (for example, Classic RCU has call_rcu_sched()
mapping to call_rcu()).
Overlap of CPU-hotplug operations is prevented by cpu_add_remove_lock,
and any stray callbacks that arrive (for example, from irq handlers
running on the dying CPU) either are ahead of the CPU_DYING callbacks on
the one hand (and thus accounted for), or happened after the rcu_barrier()
started on the other (and thus don't need to be accounted for).
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
LKML-Reference: <49C36476.1010400@cn.fujitsu.com>
This patch fixes a bug located by Vegard Nossum with the aid of
kmemcheck, updated based on review comments from Nick Piggin,
Ingo Molnar, and Andrew Morton. And cleans up the variable-name
and function-name language. ;-)
The boot CPU runs in the context of its idle thread during boot-up.
During this time, idle_cpu(0) will always return nonzero, which will
fool Classic and Hierarchical RCU into deciding that a large chunk of
the boot-up sequence is a big long quiescent state. This in turn causes
RCU to prematurely end grace periods during this time.
This patch changes the rcutree.c and rcuclassic.c rcu_check_callbacks()
function to ignore the idle task as a quiescent state until the
system has started up the scheduler in rest_init(), introducing a
new non-API function rcu_idle_now_means_idle() to inform RCU of this
transition. RCU maintains an internal rcu_idle_cpu_truthful variable
to track this state, which is then used by rcu_check_callback() to
determine if it should believe idle_cpu().
Because this patch has the effect of disallowing RCU grace periods
during long stretches of the boot-up sequence, this patch also introduces
Josh Triplett's UP-only optimization that makes synchronize_rcu() be a
no-op if num_online_cpus() returns 1. This allows boot-time code that
calls synchronize_rcu() to proceed normally. Note, however, that RCU
callbacks registered by call_rcu() will likely queue up until later in
the boot sequence. Although rcuclassic and rcutree can also use this
same optimization after boot completes, rcupreempt must restrict its
use of this optimization to the portion of the boot sequence before the
scheduler starts up, given that an rcupreempt RCU read-side critical
section may be preeempted.
In addition, this patch takes Nick Piggin's suggestion to make the
system_state global variable be __read_mostly.
Changes since v4:
o Changes the name of the introduced function and variable to
be less emotional. ;-)
Changes since v3:
o WARN_ON(nr_context_switches() > 0) to verify that RCU
switches out of boot-time mode before the first context
switch, as suggested by Nick Piggin.
Changes since v2:
o Created rcu_blocking_is_gp() internal-to-RCU API that
determines whether a call to synchronize_rcu() is itself
a grace period.
o The definition of rcu_blocking_is_gp() for rcuclassic and
rcutree checks to see if but a single CPU is online.
o The definition of rcu_blocking_is_gp() for rcupreempt
checks to see both if but a single CPU is online and if
the system is still in early boot.
This allows rcupreempt to again work correctly if running
on a single CPU after booting is complete.
o Added check to rcupreempt's synchronize_sched() for there
being but one online CPU.
Tested all three variants both SMP and !SMP, booted fine, passed a short
rcutorture test on both x86 and Power.
Located-by: Vegard Nossum <vegard.nossum@gmail.com>
Tested-by: Vegard Nossum <vegard.nossum@gmail.com>
Tested-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Impact: cleanup
Expand macro into two files.
The synchronize_rcu_xxx macro is quite ugly and it's only used by two
callers, so expand it instead. This makes this code easier to change.
current rcu_barrier_bh() is like this:
void rcu_barrier_bh(void)
BUG_ON(in_interrupt());
/* Take cpucontrol mutex to protect against CPU hotplug */
mutex_lock(&rcu_barrier_mutex);
init_completion(&rcu_barrier_completion);
atomic_set(&rcu_barrier_cpu_count, 0);
* The queueing of callbacks in all CPUs must be atomic with
* respect to RCU, otherwise one CPU may queue a callback,
* wait for a grace period, decrement barrier count and call
* complete(), while other CPUs have not yet queued anything.
* So, we need to make sure that grace periods cannot complete
* until all the callbacks are queued.
rcu_read_lock();
on_each_cpu(rcu_barrier_func, (void *)RCU_BARRIER_BH, 1);
rcu_read_unlock();
wait_for_completion(&rcu_barrier_completion);
mutex_unlock(&rcu_barrier_mutex);
The inconsistency of the code and the comments show a bug here.
rcu_read_lock() cannot make sure that "grace periods for RCU_BH
cannot complete until all the callbacks are queued".
it only make sure that race periods for RCU cannot complete
so we must use rcu_read_lock_bh() for rcu_barrier_bh().
like this:
rcu_read_lock_bh();
rcu_read_unlock_bh();
and also rcu_barrier() rcu_barrier_sched() are implemented like this.
it will bring a lot of duplicate code. My patch uses another way to
fix this bug, please see the comment of my patch.
Thank Paul E. McKenney for he rewrote the comment.
Fix RCU's synchronize_rcu() so that it looks like a C function, enabling
it to be recognized as a function with kernel-doc annotation.
Warning(linux-2.6.26-git11//kernel/rcupdate.c:81): No description found for parameter 'synchronize_rcu'
Warning(linux-2.6.26-git11//kernel/rcupdate.c:81): No description found for parameter 'call_rcu'
[akpm@linux-foundation.org: fix comment]
* 'generic-ipi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (22 commits)
generic-ipi: more merge fallout
generic-ipi: merge fix
x86, visws: use mach-default/entry_arch.h
x86, visws: fix generic-ipi build
generic-ipi: fixlet
generic-ipi: fix s390 build bug
generic-ipi: fix linux-next tree build failure
fix: "smp_call_function: get rid of the unused nonatomic/retry argument"
fix "smp_call_function: get rid of the unused nonatomic/retry argument"
on_each_cpu(): kill unused 'retry' parameter
sh: convert to generic helpers for IPI function calls
parisc: convert to generic helpers for IPI function calls
mips: convert to generic helpers for IPI function calls
m32r: convert to generic helpers for IPI function calls
arm: convert to generic helpers for IPI function calls
alpha: convert to generic helpers for IPI function calls
ia64: convert to generic helpers for IPI function calls
powerpc: convert to generic helpers for IPI function calls
Fix trivial conflicts due to rcu updates in kernel/rcupdate.c manually
It's not even passed on to smp_call_function() anymore, since that
was removed. So kill it.
Acked-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
Add rcu_barrier_sched() and rcu_barrier_bh(). With these in place,
rcutorture no longer gives the occasional oops when repeatedly starting
and stopping torturing rcu_bh. Also adds the API needed to flush out
pre-existing call_rcu_sched() callbacks.
Fourth cut of patch to provide the call_rcu_sched(). This is again to
synchronize_sched() as call_rcu() is to synchronize_rcu().
Should be fine for experimental and -rt use, but not ready for inclusion.
With some luck, I will be able to tell Andrew to come out of hiding on
the next round.
Passes multi-day rcutorture sessions with concurrent CPU hotplugging.
Fixes since the first version include a bug that could result in
indefinite blocking (spotted by Gautham Shenoy), better resiliency
against CPU-hotplug operations, and other minor fixes.
Fixes since the second version include reworking grace-period detection
to avoid deadlocks that could happen when running concurrently with
CPU hotplug, adding Mathieu's fix to avoid the softlockup messages,
as well as Mathieu's fix to allow use earlier in boot.
Fixes since the third version include a wrong-CPU bug spotted by
Andrew, getting rid of the obsolete synchronize_kernel API that somehow
snuck back in, merging spin_unlock() and local_irq_restore() in a
few places, commenting the code that checks for quiescent states based
on interrupting from user-mode execution or the idle loop, removing
some inline attributes, and some code-style changes.
Known/suspected shortcomings:
o I still do not entirely trust the sleep/wakeup logic. Next step
will be to use a private snapshot of the CPU online mask in
rcu_sched_grace_period() -- if the CPU wasn't there at the start
of the grace period, we don't need to hear from it. And the
bit about accounting for changes in online CPUs inside of
rcu_sched_grace_period() is ugly anyway.
o It might be good for rcu_sched_grace_period() to invoke
resched_cpu() when a given CPU wasn't responding quickly,
but resched_cpu() is declared static...
This patch also fixes a long-standing bug in the earlier preemptable-RCU
implementation of synchronize_rcu() that could result in loss of
concurrent external changes to a task's CPU affinity mask. I still cannot
remember who reported this...
This comment caused some consternation during fastcall removal. Make it
truthful.
Cc: Harvey Harrison <harvey.harrison@gmail.com>
Fix rcu_barrier() to work properly in preemptive kernel environment.
Also, the ordering of callback must be preserved while moving
callbacks to another CPU during CPU hotplug.
Signed-off-by: Gautham R Shenoy <ego@in.ibm.com>
Signed-off-by: Dipankar Sarma <dipankar@in.ibm.com>
Reviewed-by: Steven Rostedt <srostedt@redhat.com>
This patch re-organizes the RCU code to enable multiple implementations
of RCU. Users of RCU continues to include rcupdate.h and the
RCU interfaces remain the same. This is in preparation for
subsequently merging the preemptible RCU implementation.
This patch makes RCU use softirq instead of tasklets.
It also adds a memory barrier after raising the softirq
inorder to ensure that the cpu sees the most recently updated
value of rcu->cur while processing callbacks.
The discussion of the related theoretical race pointed out
by James Huang can be found here --> http://lkml.org/lkml/2007/11/20/603
rcu_online_cpu() should be __cpuinit instead of __devinit.
WARNING: vmlinux.o(.text+0x4b6d5): Section mismatch: reference to .init.text: (between 'rcu_cpu_notify' and 'wakeme_after_rcu')
