path: root/kernel/rcutiny.c
2011-10-31kernel: fix up module header handling in rcutiny filesPaul Gortmaker
The file rcutiny.c does not need moduleparam.h header, as there are no modparams in this file. However rcutiny_plugin.h does define a module_init() and a module_exit() and it uses the various MODULE_ macros, so it really does need module.h included. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31kernel: Map most files to use export.h instead of module.hPaul Gortmaker
The changed files were only including linux/module.h for the EXPORT_SYMBOL infrastructure, and nothing else. Revector them onto the isolated export header for faster compile times. Nothing to see here but a whole lot of instances of: -#include <linux/module.h> +#include <linux/export.h> This commit is only changing the kernel dir; next targets will probably be mm, fs, the arch dirs, etc. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-28rcu: Add grace-period, quiescent-state, and call_rcu trace eventsPaul E. McKenney
Add trace events to record grace-period start and end, quiescent states, CPUs noticing grace-period start and end, grace-period initialization, call_rcu() invocation, tasks blocking in RCU read-side critical sections, tasks exiting those same critical sections, force_quiescent_state() detection of dyntick-idle and offline CPUs, CPUs entering and leaving dyntick-idle mode (except from NMIs), CPUs coming online and going offline, and CPUs being kicked for staying in dyntick-idle mode for too long (as in many weeks, even on 32-bit systems). Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> rcu: Add the rcu flavor to callback trace events The earlier trace events for registering RCU callbacks and for invoking them did not include the RCU flavor (rcu_bh, rcu_preempt, or rcu_sched). This commit adds the RCU flavor to those trace events. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-09-28rcu: Make TINY_RCU also use softirq for RCU_BOOST=nPaul E. McKenney
This patch #ifdefs TINY_RCU kthreads out of the kernel unless RCU_BOOST=y, thus eliminating context-switch overhead if RCU priority boosting has not been configured. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-09-28rcu: Add RCU type to callback-invocation tracingPaul E. McKenney
Add a string to the rcu_batch_start() and rcu_batch_end() trace messages that indicates the RCU type ("rcu_sched", "rcu_bh", or "rcu_preempt"). The trace messages for the actual invocations themselves are not marked, as it should be clear from the rcu_batch_start() and rcu_batch_end() events before and after. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-09-28rcu: Put names into TINY_RCU structures under RCU_TRACEPaul E. McKenney
In order to allow event tracing to distinguish between flavors of RCU, we need those names in the relevant RCU data structures. TINY_RCU has avoided them for memory-footprint reasons, so add them only if CONFIG_RCU_TRACE=y. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-09-28rcu: Add event-tracing for RCU callback invocationPaul E. McKenney
There was recently some controversy about the overhead of invoking RCU callbacks. Add TRACE_EVENT()s to obtain fine-grained timings for the start and stop of a batch of callbacks and also for each callback invoked. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-09-28rcu: Abstract common code for RCU grace-period-wait primitivesPaul E. McKenney
Pull the code that waits for an RCU grace period into a single function, which is then called by synchronize_rcu() and friends in the case of TREE_RCU and TREE_PREEMPT_RCU, and from rcu_barrier() and friends in the case of TINY_RCU and TINY_PREEMPT_RCU. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-05-20sanitize <linux/prefetch.h> usageLinus Torvalds
Commit e66eed651fd1 ("list: remove prefetching from regular list iterators") removed the include of prefetch.h from list.h, which uncovered several cases that had apparently relied on that rather obscure header file dependency. So this fixes things up a bit, using grep -L linux/prefetch.h $(git grep -l '[^a-z_]prefetchw*(' -- '*.[ch]') grep -L 'prefetchw*(' $(git grep -l 'linux/prefetch.h' -- '*.[ch]') to guide us in finding files that either need <linux/prefetch.h> inclusion, or have it despite not needing it. There are more of them around (mostly network drivers), but this gets many core ones. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-05rcu: optimize rcutinyEric Dumazet
rcu_sched_qs() currently calls local_irq_save()/local_irq_restore() up to three times. Remove irq masking from rcu_qsctr_help() / invoke_rcu_kthread() and do it once in rcu_sched_qs() / rcu_bh_qs() This generates smaller code as well. text data bss dec hex filename 2314 156 24 2494 9be kernel/rcutiny.old.o 2250 156 24 2430 97e kernel/rcutiny.new.o Fix an outdated comment for rcu_qsctr_help() Move invoke_rcu_kthread() definition before its use. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-05rcu: introduce kfree_rcu()Lai Jiangshan
Many rcu callbacks functions just call kfree() on the base structure. These functions are trivial, but their size adds up, and furthermore when they are used in a kernel module, that module must invoke the high-latency rcu_barrier() function at module-unload time. The kfree_rcu() function introduced by this commit addresses this issue. Rather than encoding a function address in the embedded rcu_head structure, kfree_rcu() instead encodes the offset of the rcu_head structure within the base structure. Because the functions are not allowed in the low-order 4096 bytes of kernel virtual memory, offsets up to 4095 bytes can be accommodated. If the offset is larger than 4095 bytes, a compile-time error will be generated in __kfree_rcu(). If this error is triggered, you can either fall back to use of call_rcu() or rearrange the structure to position the rcu_head structure into the first 4096 bytes. Note that the allowable offset might decrease in the future, for example, to allow something like kmem_cache_free_rcu(). The new kfree_rcu() function can replace code as follows: call_rcu(&p->rcu, simple_kfree_callback); where "simple_kfree_callback()" might be defined as follows: void simple_kfree_callback(struct rcu_head *p) { struct foo *q = container_of(p, struct foo, rcu); kfree(q); } with the following: kfree_rcu(&p->rcu, rcu); Note that the "rcu" is the name of a field in the structure being freed. The reason for using this rather than passing in a pointer to the base structure is that the above approach allows better type checking. This commit is based on earlier work by Lai Jiangshan and Manfred Spraul: Lai's V1 patch: http://lkml.org/lkml/2008/9/18/1 Manfred's patch: http://lkml.org/lkml/2009/1/2/115 Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: David Howells <dhowells@redhat.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-01-14rcu: avoid pointless blocked-task warningsPaul E. McKenney
If the RCU callback-processing kthread has nothing to do, it parks in a wait_event(). If RCU remains idle for more than two minutes, the kernel complains about this. This commit changes from wait_event() to wait_event_interruptible() to prevent the kernel from complaining just because RCU is idle. Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Tested-by: Thomas Weber <weber@corscience.de> Tested-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-29rcu: add tracing for TINY_RCU and TINY_PREEMPT_RCUPaul E. McKenney
Add tracing for the tiny RCU implementations, including statistics on boosting in the case of TINY_PREEMPT_RCU and RCU_BOOST. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-11-29rcu: priority boosting for TINY_PREEMPT_RCUPaul E. McKenney
Add priority boosting, but only for TINY_PREEMPT_RCU. This is enabled by the default-off RCU_BOOST kernel parameter. The priority to which to boost preempted RCU readers is controlled by the RCU_BOOST_PRIO kernel parameter (defaulting to real-time priority 1) and the time to wait before boosting the readers blocking a given grace period is controlled by the RCU_BOOST_DELAY kernel parameter (defaulting to 500 milliseconds). Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-11-17rcu: move TINY_RCU from softirq to kthreadPaul E. McKenney
If RCU priority boosting is to be meaningful, callback invocation must be boosted in addition to preempted RCU readers. Otherwise, in presence of CPU real-time threads, the grace period ends, but the callbacks don't get invoked. If the callbacks don't get invoked, the associated memory doesn't get freed, so the system is still subject to OOM. But it is not reasonable to priority-boost RCU_SOFTIRQ, so this commit moves the callback invocations to a kthread, which can be boosted easily. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-08-20rcu: Add a TINY_PREEMPT_RCUPaul E. McKenney
Implement a small-memory-footprint uniprocessor-only implementation of preemptible RCU. This implementation uses but a single blocked-tasks list rather than the combinatorial number used per leaf rcu_node by TREE_PREEMPT_RCU, which reduces memory consumption and greatly simplifies processing. This version also takes advantage of uniprocessor execution to accelerate grace periods in the case where there are no readers. The general design is otherwise broadly similar to that of TREE_PREEMPT_RCU. This implementation is a step towards having RCU implementation driven off of the SMP and PREEMPT kernel configuration variables, which can happen once this implementation has accumulated sufficient experience. Removed ACCESS_ONCE() from __rcu_read_unlock() and added barrier() as suggested by Steve Rostedt in order to avoid the compiler-reordering issue noted by Mathieu Desnoyers (http://lkml.org/lkml/2010/8/16/183). As can be seen below, CONFIG_TINY_PREEMPT_RCU represents almost 5Kbyte savings compared to CONFIG_TREE_PREEMPT_RCU. Of course, for non-real-time workloads, CONFIG_TINY_RCU is even better. CONFIG_TREE_PREEMPT_RCU text data bss dec filename 13 0 0 13 kernel/rcupdate.o 6170 825 28 7023 kernel/rcutree.o ---- 7026 Total CONFIG_TINY_PREEMPT_RCU text data bss dec filename 13 0 0 13 kernel/rcupdate.o 2081 81 8 2170 kernel/rcutiny.o ---- 2183 Total CONFIG_TINY_RCU (non-preemptible) text data bss dec filename 13 0 0 13 kernel/rcupdate.o 719 25 0 744 kernel/rcutiny.o --- 757 Total Requested-by: Loïc Minier <loic.minier@canonical.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-06-14tree/tiny rcu: Add debug RCU head objectsMathieu Desnoyers
Helps finding racy users of call_rcu(), which results in hangs because list entries are overwritten and/or skipped. Changelog since v4: - Bissectability is now OK - Now generate a WARN_ON_ONCE() for non-initialized rcu_head passed to call_rcu(). Statically initialized objects are detected with object_is_static(). - Rename rcu_head_init_on_stack to init_rcu_head_on_stack. - Remove init_rcu_head() completely. Changelog since v3: - Include comments from Lai Jiangshan This new patch version is based on the debugobjects with the newly introduced "active state" tracker. Non-initialized entries are all considered as "statically initialized". An activation fixup (triggered by call_rcu()) takes care of performing the debug object initialization without issuing any warning. Since we cannot increase the size of struct rcu_head, I don't see much room to put an identifier for statically initialized rcu_head structures. So for now, we have to live without "activation without explicit init" detection. But the main purpose of this debug option is to detect double-activations (double call_rcu() use of a rcu_head before the callback is executed), which is correctly addressed here. This also detects potential internal RCU callback corruption, which would cause the callbacks to be executed twice. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> CC: David S. Miller <davem@davemloft.net> CC: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> CC: akpm@linux-foundation.org CC: mingo@elte.hu CC: laijs@cn.fujitsu.com CC: dipankar@in.ibm.com CC: josh@joshtriplett.org CC: dvhltc@us.ibm.com CC: niv@us.ibm.com CC: tglx@linutronix.de CC: peterz@infradead.org CC: rostedt@goodmis.org CC: Valdis.Kletnieks@vt.edu CC: dhowells@redhat.com CC: eric.dumazet@gmail.com CC: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2010-05-11rcu: remove all rcu head initializations, except on_stack initializationsPaul E. McKenney
Remove all rcu head inits. We don't care about the RCU head state before passing it to call_rcu() anyway. Only leave the "on_stack" variants so debugobjects can keep track of objects on stack. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-05-10rcu: slim down rcutiny by removing rcu_scheduler_active and friendsPaul E. McKenney
TINY_RCU does not need rcu_scheduler_active unless CONFIG_DEBUG_LOCK_ALLOC. So conditionally compile rcu_scheduler_active in order to slim down rcutiny a bit more. Also gets rid of an EXPORT_SYMBOL_GPL, which is responsible for most of the slimming. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-05-10rcu: rename rcutiny rcu_ctrlblk to rcu_sched_ctrlblkPaul E. McKenney
Make naming line up in preparation for CONFIG_TINY_PREEMPT_RCU. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-05-10rcu: shrink rcutiny by making synchronize_rcu_bh() be inlinePaul E. McKenney
Because synchronize_rcu_bh() is identical to synchronize_sched(), make the former a static inline invoking the latter, saving the overhead of an EXPORT_SYMBOL_GPL() and the duplicate code. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2009-11-22rcu: Eliminate unneeded function wrappingPaul E. McKenney
The functions rcu_init() is a wrapper for __rcu_init(), and also sets up the CPU-hotplug notifier for rcu_barrier_cpu_hotplug(). But TINY_RCU doesn't need CPU-hotplug notification, and the rcu_barrier_cpu_hotplug() is a simple wrapper for rcu_cpu_notify(). So push rcu_init() out to kernel/rcutree.c and kernel/rcutiny.c and get rid of the wrapper function rcu_barrier_cpu_hotplug(). Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12589088302320-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-26rcu: Do tiny cleanups in rcutinyIngo Molnar
No change in functionality - just straighten out a few small stylistic details. Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: David Howells <dhowells@redhat.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: avi@redhat.com Cc: mtosatti@redhat.com LKML-Reference: <12565226351355-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-26rcu: "Tiny RCU", The Bloatwatch EditionPaul E. McKenney
This patch is a version of RCU designed for !SMP provided for a small-footprint RCU implementation. In particular, the implementation of synchronize_rcu() is extremely lightweight and high performance. It passes rcutorture testing in each of the four relevant configurations (combinations of NO_HZ and PREEMPT) on x86. This saves about 1K bytes compared to old Classic RCU (which is no longer in mainline), and more than three kilobytes compared to Hierarchical RCU (updated to 2.6.30): CONFIG_TREE_RCU: text data bss dec filename 183 4 0 187 kernel/rcupdate.o 2783 520 36 3339 kernel/rcutree.o 3526 Total (vs 4565 for v7) CONFIG_TREE_PREEMPT_RCU: text data bss dec filename 263 4 0 267 kernel/rcupdate.o 4594 776 52 5422 kernel/rcutree.o 5689 Total (6155 for v7) CONFIG_TINY_RCU: text data bss dec filename 96 4 0 100 kernel/rcupdate.o 734 24 0 758 kernel/rcutiny.o 858 Total (vs 848 for v7) The above is for x86. Your mileage may vary on other platforms. Further compression is possible, but is being procrastinated. Changes from v7 (http://lkml.org/lkml/2009/10/9/388) o Apply Lai Jiangshan's review comments (aside from might_sleep() in synchronize_sched(), which is covered by SMP builds). o Fix up expedited primitives. Changes from v6 (http://lkml.org/lkml/2009/9/23/293). o Forward ported to put it into the 2.6.33 stream. o Added lockdep support. o Make lightweight rcu_barrier. Changes from v5 (http://lkml.org/lkml/2009/6/23/12). o Ported to latest pre-2.6.32 merge window kernel. - Renamed rcu_qsctr_inc() to rcu_sched_qs(). - Renamed rcu_bh_qsctr_inc() to rcu_bh_qs(). - Provided trivial rcu_cpu_notify(). - Provided trivial exit_rcu(). - Provided trivial rcu_needs_cpu(). - Fixed up the rcu_*_enter/exit() functions in linux/hardirq.h. o Removed the dependence on EMBEDDED, with a view to making TINY_RCU default for !SMP at some time in the future. o Added (trivial) support for expedited grace periods. Changes from v4 (http://lkml.org/lkml/2009/5/2/91) include: o Squeeze the size down a bit further by removing the ->completed field from struct rcu_ctrlblk. o This permits synchronize_rcu() to become the empty function. Previous concerns about rcutorture were unfounded, as rcutorture correctly handles a constant value from rcu_batches_completed() and rcu_batches_completed_bh(). Changes from v3 (http://lkml.org/lkml/2009/3/29/221) include: o Changed rcu_batches_completed(), rcu_batches_completed_bh() rcu_enter_nohz(), rcu_exit_nohz(), rcu_nmi_enter(), and rcu_nmi_exit(), to be static inlines, as suggested by David Howells. Doing this saves about 100 bytes from rcutiny.o. (The numbers between v3 and this v4 of the patch are not directly comparable, since they are against different versions of Linux.) Changes from v2 (http://lkml.org/lkml/2009/2/3/333) include: o Fix whitespace issues. o Change short-circuit "||" operator to instead be "+" in order to fix performance bug noted by "kraai" on LWN. (http://lwn.net/Articles/324348/) Changes from v1 (http://lkml.org/lkml/2009/1/13/440) include: o This version depends on EMBEDDED as well as !SMP, as suggested by Ingo. o Updated rcu_needs_cpu() to unconditionally return zero, permitting the CPU to enter dynticks-idle mode at any time. This works because callbacks can be invoked upon entry to dynticks-idle mode. o Paul is now OK with this being included, based on a poll at the Kernel Miniconf at linux.conf.au, where about ten people said that they cared about saving 900 bytes on single-CPU systems. o Applies to both mainline and tip/core/rcu. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Josh Triplett <josh@joshtriplett.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: avi@redhat.com Cc: mtosatti@redhat.com LKML-Reference: <12565226351355-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
