path: root/kernel/rcutiny.c
2013-01-28Merge branches 'doctorture.2013.01.29a', 'fixes.2013.01.26a', ↵Paul E. McKenney
'tagcb.2013.01.24a' and 'tiny.2013.01.29b' into HEAD doctorture.2013.01.11a: Changes to rcutorture and to RCU documentation. fixes.2013.01.26a: Miscellaneous fixes. tagcb.2013.01.24a: Tag RCU callbacks with grace-period number to simplify callback advancement. tiny.2013.01.29b: Enhancements to uniprocessor handling in tiny RCU.
2013-01-28rcu: Provide RCU CPU stall warnings for tiny RCUPaul E. McKenney
Tiny RCU has historically omitted RCU CPU stall warnings in order to reduce memory requirements, however, lack of these warnings caused Thomas Gleixner some debugging pain recently. Therefore, this commit adds RCU CPU stall warnings to tiny RCU if RCU_TRACE=y. This keeps the memory footprint small, while still enabling CPU stall warnings in kernels built to enable them. Updated to include Josh Triplett's suggested use of RCU_STALL_COMMON config variable to simplify #if expressions. Reported-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2013-01-08rcu: Make rcu_is_cpu_rrupt_from_idle helper functions staticJosh Triplett
Both rcutiny and rcutree define a helper function named rcu_is_cpu_rrupt_from_idle(), each used exactly once, later in the same file. This commit therefore declares these helper functions static. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2012-11-13rcu: Fix TINY_RCU rcu_is_cpu_rrupt_from_idle checkPaul E. McKenney
The rcu_is_cpu_rrupt_from_idle() needs to allow for one interrupt level from the idle loop, but TINY_RCU checks for a call from the idle loop itself. This commit fixes this issue. Reported-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2012-09-23rcu: Move TINY_RCU quiescent state out of extended quiescent stateLi Zhong
TINY_RCU's rcu_idle_enter_common() invokes rcu_sched_qs() in order to inform the RCU core of the quiescent state implied by idle entry. Of course, idle is also an extended quiescent state, so that the call to rcu_sched_qs() speeds up RCU's invoking of any callbacks that might be queued. This speed-up is important when entering into dyntick-idle mode -- if there are no further scheduling-clock interrupts, the callbacks might never be invoked, which could result in a system hang. However, processing callbacks does event tracing, which in turn implies RCU read-side critical sections, which are illegal in extended quiescent states. This patch therefore moves the call to rcu_sched_qs() so that it precedes the point at which we inform lockdep that RCU has entered an extended quiescent state. Signed-off-by: Li Zhong <zhong@linux.vnet.ibm.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2012-09-23rcu: Permit RCU_NONIDLE() to be used from interrupt contextPaul E. McKenney
There is a need to use RCU from interrupt context, but either before rcu_irq_enter() is called or after rcu_irq_exit() is called. If the interrupt occurs from idle, then lockdep-RCU will complain about such uses, as they appear to be illegal uses of RCU from the idle loop. In other environments, RCU_NONIDLE() could be used to properly protect the use of RCU, but RCU_NONIDLE() currently cannot be invoked except from process context. This commit therefore modifies RCU_NONIDLE() to permit its use more globally. Reported-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2012-09-23rcu: Pull TINY_RCU dyntick-idle tracing into non-idle regionPaul E. McKenney
Because TINY_RCU's idle detection keys directly off of the nesting level, rather than from a separate variable as in TREE_RCU, the TINY_RCU dyntick-idle tracing on transition to idle must happen before the change to the nesting level. This commit therefore makes this change by passing the desired new value (rather than the old value) of the nesting level in to rcu_idle_enter_common(). [ paulmck: Add fix for wrong-variable bug spotted by Michael Wang <wangyun@linux.vnet.ibm.com>. ] Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2012-07-02rcu: Fix rcu_is_cpu_idle() #ifdef in TINY_RCUPaul E. McKenney
The rcu_is_cpu_idle() function is used if CONFIG_DEBUG_LOCK_ALLOC, but TINY_RCU defines it only when CONFIG_PROVE_RCU. This causes build failures when CONFIG_DEBUG_LOCK_ALLOC=y but CONFIG_PROVE_RCU=n. This commit therefore adjusts the #ifdefs for rcu_is_cpu_idle() so that it is defined when CONFIG_DEBUG_LOCK_ALLOC=y. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2012-02-21rcu: Add RCU_NONIDLE() for idle-loop RCU read-side critical sectionsPaul E. McKenney
RCU, RCU-bh, and RCU-sched read-side critical sections are forbidden in the inner idle loop, that is, between the rcu_idle_enter() and the rcu_idle_exit() -- RCU will happily ignore any such read-side critical sections. However, things like powertop need tracepoints in the inner idle loop. This commit therefore provides an RCU_NONIDLE() macro that can be used to wrap code in the idle loop that requires RCU read-side critical sections. Suggested-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
2012-02-21rcu: Allow nesting of rcu_idle_enter() and rcu_idle_exit()Paul E. McKenney
Use of RCU in the idle loop is incorrect, quite a few instances of just that have made their way into mainline, primarily event tracing. The problem with RCU read-side critical sections on CPUs that RCU believes to be idle is that RCU is completely ignoring the CPU, along with any attempts and RCU read-side critical sections. The approaches of eliminating the offending uses and of pushing the definition of idle down beyond the offending uses have both proved impractical. The new approach is to encapsulate offending uses of RCU with rcu_idle_exit() and rcu_idle_enter(), but this requires nesting for code that is invoked both during idle and and during normal execution. Therefore, this commit modifies rcu_idle_enter() and rcu_idle_exit() to permit nesting. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Deepthi Dharwar <deepthi@linux.vnet.ibm.com>
2012-02-21rcu: Avoid waking up CPUs having only kfree_rcu() callbacksPaul E. McKenney
When CONFIG_RCU_FAST_NO_HZ is enabled, RCU will allow a given CPU to enter dyntick-idle mode even if it still has RCU callbacks queued. RCU avoids system hangs in this case by scheduling a timer for several jiffies in the future. However, if all of the callbacks on that CPU are from kfree_rcu(), there is no reason to wake the CPU up, as it is not a problem to defer freeing of memory. This commit therefore tracks the number of callbacks on a given CPU that are from kfree_rcu(), and avoids scheduling the timer if all of a given CPU's callbacks are from kfree_rcu(). Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2012-02-21rcu: Add lockdep-RCU checks for simple self-deadlockPaul E. McKenney
It is illegal to have a grace period within a same-flavor RCU read-side critical section, so this commit adds lockdep-RCU checks to splat when such abuse is encountered. This commit does not detect more elaborate RCU deadlock situations. These situations might be a job for lockdep enhancements. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-12-11rcu: Augment rcu_batch_end tracing for idle and callback statePaul E. McKenney
The current rcu_batch_end event trace records only the name of the RCU flavor and the total number of callbacks that remain queued on the current CPU. This is insufficient for testing and tuning the new dyntick-idle RCU_FAST_NO_HZ code, so this commit adds idle state along with whether or not any of the callbacks that were ready to invoke at the beginning of rcu_do_batch() are still queued. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-12-11rcu: Make RCU use the new is_idle_task() APIPaul E. McKenney
Change from direct comparison of ->pid with zero to is_idle_task(). Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-12-11rcu: Fix idle-task checksPaul E. McKenney
RCU has traditionally relied on idle_cpu() to determine whether a given CPU is running in the context of an idle task, but commit 908a3283 (Fix idle_cpu()) has invalidated this approach. After commit 908a3283, idle_cpu() will return true if the current CPU is currently running the idle task, and will be doing so for the foreseeable future. RCU instead needs to know whether or not the current CPU is currently running the idle task, regardless of what the near future might bring. This commit therefore switches from idle_cpu() to "current->pid != 0". Reported-by: Wu Fengguang <fengguang.wu@intel.com> Suggested-by: Carsten Emde <C.Emde@osadl.org> Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Tested-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-12-11rcu: Add more information to the wrong-idle-task complaintPaul E. McKenney
The current code just complains if the current task is not the idle task. This commit therefore adds printing of the identity of the idle task. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-12-11rcu: Deconfuse dynticks entry-exit tracingPaul E. McKenney
The trace_rcu_dyntick() trace event did not print both the old and the new value of the nesting level, and furthermore printed only the low-order 32 bits of it. This could result in some confusion when interpreting trace-event dumps, so this commit prints both the old and the new value, prints the full 64 bits, and also selects the process-entry/exit increment to print nicely in hexadecimal. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-12-11rcu: Detect illegal rcu dereference in extended quiescent stateFrederic Weisbecker
Report that none of the rcu read lock maps are held while in an RCU extended quiescent state (the section between rcu_idle_enter() and rcu_idle_exit()). This helps detect any use of rcu_dereference() and friends from within the section in idle where RCU is not allowed. This way we can guarantee an extended quiescent window where the CPU can be put in dyntick idle mode or can simply aoid to be part of any global grace period completion while in the idle loop. Uses of RCU from such mode are totally ignored by RCU, hence the importance of these checks. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-12-11rcu: Track idleness independent of idle tasksPaul E. McKenney
Earlier versions of RCU used the scheduling-clock tick to detect idleness by checking for the idle task, but handled idleness differently for CONFIG_NO_HZ=y. But there are now a number of uses of RCU read-side critical sections in the idle task, for example, for tracing. A more fine-grained detection of idleness is therefore required. This commit presses the old dyntick-idle code into full-time service, so that rcu_idle_enter(), previously known as rcu_enter_nohz(), is always invoked at the beginning of an idle loop iteration. Similarly, rcu_idle_exit(), previously known as rcu_exit_nohz(), is always invoked at the end of an idle-loop iteration. This allows the idle task to use RCU everywhere except between consecutive rcu_idle_enter() and rcu_idle_exit() calls, in turn allowing architecture maintainers to specify exactly where in the idle loop that RCU may be used. Because some of the userspace upcall uses can result in what looks to RCU like half of an interrupt, it is not possible to expect that the irq_enter() and irq_exit() hooks will give exact counts. This patch therefore expands the ->dynticks_nesting counter to 64 bits and uses two separate bitfields to count process/idle transitions and interrupt entry/exit transitions. It is presumed that userspace upcalls do not happen in the idle loop or from usermode execution (though usermode might do a system call that results in an upcall). The counter is hard-reset on each process/idle transition, which avoids the interrupt entry/exit error from accumulating. Overflow is avoided by the 64-bitness of the ->dyntick_nesting counter. This commit also adds warnings if a non-idle task asks RCU to enter idle state (and these checks will need some adjustment before applying Frederic's OS-jitter patches (http://lkml.org/lkml/2011/10/7/246). In addition, validation of ->dynticks and ->dynticks_nesting is added. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-10-31kernel: fix up module header handling in rcutiny filesPaul Gortmaker
The file rcutiny.c does not need moduleparam.h header, as there are no modparams in this file. However rcutiny_plugin.h does define a module_init() and a module_exit() and it uses the various MODULE_ macros, so it really does need module.h included. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31kernel: Map most files to use export.h instead of module.hPaul Gortmaker
The changed files were only including linux/module.h for the EXPORT_SYMBOL infrastructure, and nothing else. Revector them onto the isolated export header for faster compile times. Nothing to see here but a whole lot of instances of: -#include <linux/module.h> +#include <linux/export.h> This commit is only changing the kernel dir; next targets will probably be mm, fs, the arch dirs, etc. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-28rcu: Add grace-period, quiescent-state, and call_rcu trace eventsPaul E. McKenney
Add trace events to record grace-period start and end, quiescent states, CPUs noticing grace-period start and end, grace-period initialization, call_rcu() invocation, tasks blocking in RCU read-side critical sections, tasks exiting those same critical sections, force_quiescent_state() detection of dyntick-idle and offline CPUs, CPUs entering and leaving dyntick-idle mode (except from NMIs), CPUs coming online and going offline, and CPUs being kicked for staying in dyntick-idle mode for too long (as in many weeks, even on 32-bit systems). Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> rcu: Add the rcu flavor to callback trace events The earlier trace events for registering RCU callbacks and for invoking them did not include the RCU flavor (rcu_bh, rcu_preempt, or rcu_sched). This commit adds the RCU flavor to those trace events. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-09-28rcu: Make TINY_RCU also use softirq for RCU_BOOST=nPaul E. McKenney
This patch #ifdefs TINY_RCU kthreads out of the kernel unless RCU_BOOST=y, thus eliminating context-switch overhead if RCU priority boosting has not been configured. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-09-28rcu: Add RCU type to callback-invocation tracingPaul E. McKenney
Add a string to the rcu_batch_start() and rcu_batch_end() trace messages that indicates the RCU type ("rcu_sched", "rcu_bh", or "rcu_preempt"). The trace messages for the actual invocations themselves are not marked, as it should be clear from the rcu_batch_start() and rcu_batch_end() events before and after. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-09-28rcu: Put names into TINY_RCU structures under RCU_TRACEPaul E. McKenney
In order to allow event tracing to distinguish between flavors of RCU, we need those names in the relevant RCU data structures. TINY_RCU has avoided them for memory-footprint reasons, so add them only if CONFIG_RCU_TRACE=y. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-09-28rcu: Add event-tracing for RCU callback invocationPaul E. McKenney
There was recently some controversy about the overhead of invoking RCU callbacks. Add TRACE_EVENT()s to obtain fine-grained timings for the start and stop of a batch of callbacks and also for each callback invoked. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-09-28rcu: Abstract common code for RCU grace-period-wait primitivesPaul E. McKenney
Pull the code that waits for an RCU grace period into a single function, which is then called by synchronize_rcu() and friends in the case of TREE_RCU and TREE_PREEMPT_RCU, and from rcu_barrier() and friends in the case of TINY_RCU and TINY_PREEMPT_RCU. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-05-20sanitize <linux/prefetch.h> usageLinus Torvalds
Commit e66eed651fd1 ("list: remove prefetching from regular list iterators") removed the include of prefetch.h from list.h, which uncovered several cases that had apparently relied on that rather obscure header file dependency. So this fixes things up a bit, using grep -L linux/prefetch.h $(git grep -l '[^a-z_]prefetchw*(' -- '*.[ch]') grep -L 'prefetchw*(' $(git grep -l 'linux/prefetch.h' -- '*.[ch]') to guide us in finding files that either need <linux/prefetch.h> inclusion, or have it despite not needing it. There are more of them around (mostly network drivers), but this gets many core ones. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-05rcu: optimize rcutinyEric Dumazet
rcu_sched_qs() currently calls local_irq_save()/local_irq_restore() up to three times. Remove irq masking from rcu_qsctr_help() / invoke_rcu_kthread() and do it once in rcu_sched_qs() / rcu_bh_qs() This generates smaller code as well. text data bss dec hex filename 2314 156 24 2494 9be kernel/rcutiny.old.o 2250 156 24 2430 97e kernel/rcutiny.new.o Fix an outdated comment for rcu_qsctr_help() Move invoke_rcu_kthread() definition before its use. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-05rcu: introduce kfree_rcu()Lai Jiangshan
Many rcu callbacks functions just call kfree() on the base structure. These functions are trivial, but their size adds up, and furthermore when they are used in a kernel module, that module must invoke the high-latency rcu_barrier() function at module-unload time. The kfree_rcu() function introduced by this commit addresses this issue. Rather than encoding a function address in the embedded rcu_head structure, kfree_rcu() instead encodes the offset of the rcu_head structure within the base structure. Because the functions are not allowed in the low-order 4096 bytes of kernel virtual memory, offsets up to 4095 bytes can be accommodated. If the offset is larger than 4095 bytes, a compile-time error will be generated in __kfree_rcu(). If this error is triggered, you can either fall back to use of call_rcu() or rearrange the structure to position the rcu_head structure into the first 4096 bytes. Note that the allowable offset might decrease in the future, for example, to allow something like kmem_cache_free_rcu(). The new kfree_rcu() function can replace code as follows: call_rcu(&p->rcu, simple_kfree_callback); where "simple_kfree_callback()" might be defined as follows: void simple_kfree_callback(struct rcu_head *p) { struct foo *q = container_of(p, struct foo, rcu); kfree(q); } with the following: kfree_rcu(&p->rcu, rcu); Note that the "rcu" is the name of a field in the structure being freed. The reason for using this rather than passing in a pointer to the base structure is that the above approach allows better type checking. This commit is based on earlier work by Lai Jiangshan and Manfred Spraul: Lai's V1 patch: http://lkml.org/lkml/2008/9/18/1 Manfred's patch: http://lkml.org/lkml/2009/1/2/115 Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: David Howells <dhowells@redhat.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-01-14rcu: avoid pointless blocked-task warningsPaul E. McKenney
If the RCU callback-processing kthread has nothing to do, it parks in a wait_event(). If RCU remains idle for more than two minutes, the kernel complains about this. This commit changes from wait_event() to wait_event_interruptible() to prevent the kernel from complaining just because RCU is idle. Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Tested-by: Thomas Weber <weber@corscience.de> Tested-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-11-29rcu: add tracing for TINY_RCU and TINY_PREEMPT_RCUPaul E. McKenney
Add tracing for the tiny RCU implementations, including statistics on boosting in the case of TINY_PREEMPT_RCU and RCU_BOOST. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-11-29rcu: priority boosting for TINY_PREEMPT_RCUPaul E. McKenney
Add priority boosting, but only for TINY_PREEMPT_RCU. This is enabled by the default-off RCU_BOOST kernel parameter. The priority to which to boost preempted RCU readers is controlled by the RCU_BOOST_PRIO kernel parameter (defaulting to real-time priority 1) and the time to wait before boosting the readers blocking a given grace period is controlled by the RCU_BOOST_DELAY kernel parameter (defaulting to 500 milliseconds). Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-11-17rcu: move TINY_RCU from softirq to kthreadPaul E. McKenney
If RCU priority boosting is to be meaningful, callback invocation must be boosted in addition to preempted RCU readers. Otherwise, in presence of CPU real-time threads, the grace period ends, but the callbacks don't get invoked. If the callbacks don't get invoked, the associated memory doesn't get freed, so the system is still subject to OOM. But it is not reasonable to priority-boost RCU_SOFTIRQ, so this commit moves the callback invocations to a kthread, which can be boosted easily. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-08-20rcu: Add a TINY_PREEMPT_RCUPaul E. McKenney
Implement a small-memory-footprint uniprocessor-only implementation of preemptible RCU. This implementation uses but a single blocked-tasks list rather than the combinatorial number used per leaf rcu_node by TREE_PREEMPT_RCU, which reduces memory consumption and greatly simplifies processing. This version also takes advantage of uniprocessor execution to accelerate grace periods in the case where there are no readers. The general design is otherwise broadly similar to that of TREE_PREEMPT_RCU. This implementation is a step towards having RCU implementation driven off of the SMP and PREEMPT kernel configuration variables, which can happen once this implementation has accumulated sufficient experience. Removed ACCESS_ONCE() from __rcu_read_unlock() and added barrier() as suggested by Steve Rostedt in order to avoid the compiler-reordering issue noted by Mathieu Desnoyers (http://lkml.org/lkml/2010/8/16/183). As can be seen below, CONFIG_TINY_PREEMPT_RCU represents almost 5Kbyte savings compared to CONFIG_TREE_PREEMPT_RCU. Of course, for non-real-time workloads, CONFIG_TINY_RCU is even better. CONFIG_TREE_PREEMPT_RCU text data bss dec filename 13 0 0 13 kernel/rcupdate.o 6170 825 28 7023 kernel/rcutree.o ---- 7026 Total CONFIG_TINY_PREEMPT_RCU text data bss dec filename 13 0 0 13 kernel/rcupdate.o 2081 81 8 2170 kernel/rcutiny.o ---- 2183 Total CONFIG_TINY_RCU (non-preemptible) text data bss dec filename 13 0 0 13 kernel/rcupdate.o 719 25 0 744 kernel/rcutiny.o --- 757 Total Requested-by: Loïc Minier <loic.minier@canonical.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-06-14tree/tiny rcu: Add debug RCU head objectsMathieu Desnoyers
Helps finding racy users of call_rcu(), which results in hangs because list entries are overwritten and/or skipped. Changelog since v4: - Bissectability is now OK - Now generate a WARN_ON_ONCE() for non-initialized rcu_head passed to call_rcu(). Statically initialized objects are detected with object_is_static(). - Rename rcu_head_init_on_stack to init_rcu_head_on_stack. - Remove init_rcu_head() completely. Changelog since v3: - Include comments from Lai Jiangshan This new patch version is based on the debugobjects with the newly introduced "active state" tracker. Non-initialized entries are all considered as "statically initialized". An activation fixup (triggered by call_rcu()) takes care of performing the debug object initialization without issuing any warning. Since we cannot increase the size of struct rcu_head, I don't see much room to put an identifier for statically initialized rcu_head structures. So for now, we have to live without "activation without explicit init" detection. But the main purpose of this debug option is to detect double-activations (double call_rcu() use of a rcu_head before the callback is executed), which is correctly addressed here. This also detects potential internal RCU callback corruption, which would cause the callbacks to be executed twice. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> CC: David S. Miller <davem@davemloft.net> CC: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> CC: akpm@linux-foundation.org CC: mingo@elte.hu CC: laijs@cn.fujitsu.com CC: dipankar@in.ibm.com CC: josh@joshtriplett.org CC: dvhltc@us.ibm.com CC: niv@us.ibm.com CC: tglx@linutronix.de CC: peterz@infradead.org CC: rostedt@goodmis.org CC: Valdis.Kletnieks@vt.edu CC: dhowells@redhat.com CC: eric.dumazet@gmail.com CC: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
2010-05-11rcu: remove all rcu head initializations, except on_stack initializationsPaul E. McKenney
Remove all rcu head inits. We don't care about the RCU head state before passing it to call_rcu() anyway. Only leave the "on_stack" variants so debugobjects can keep track of objects on stack. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-05-10rcu: slim down rcutiny by removing rcu_scheduler_active and friendsPaul E. McKenney
TINY_RCU does not need rcu_scheduler_active unless CONFIG_DEBUG_LOCK_ALLOC. So conditionally compile rcu_scheduler_active in order to slim down rcutiny a bit more. Also gets rid of an EXPORT_SYMBOL_GPL, which is responsible for most of the slimming. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-05-10rcu: rename rcutiny rcu_ctrlblk to rcu_sched_ctrlblkPaul E. McKenney
Make naming line up in preparation for CONFIG_TINY_PREEMPT_RCU. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-05-10rcu: shrink rcutiny by making synchronize_rcu_bh() be inlinePaul E. McKenney
Because synchronize_rcu_bh() is identical to synchronize_sched(), make the former a static inline invoking the latter, saving the overhead of an EXPORT_SYMBOL_GPL() and the duplicate code. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2009-11-22rcu: Eliminate unneeded function wrappingPaul E. McKenney
The functions rcu_init() is a wrapper for __rcu_init(), and also sets up the CPU-hotplug notifier for rcu_barrier_cpu_hotplug(). But TINY_RCU doesn't need CPU-hotplug notification, and the rcu_barrier_cpu_hotplug() is a simple wrapper for rcu_cpu_notify(). So push rcu_init() out to kernel/rcutree.c and kernel/rcutiny.c and get rid of the wrapper function rcu_barrier_cpu_hotplug(). Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12589088302320-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-26rcu: Do tiny cleanups in rcutinyIngo Molnar
No change in functionality - just straighten out a few small stylistic details. Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: David Howells <dhowells@redhat.com> Cc: Josh Triplett <josh@joshtriplett.org> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: avi@redhat.com Cc: mtosatti@redhat.com LKML-Reference: <12565226351355-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-26rcu: "Tiny RCU", The Bloatwatch EditionPaul E. McKenney
This patch is a version of RCU designed for !SMP provided for a small-footprint RCU implementation. In particular, the implementation of synchronize_rcu() is extremely lightweight and high performance. It passes rcutorture testing in each of the four relevant configurations (combinations of NO_HZ and PREEMPT) on x86. This saves about 1K bytes compared to old Classic RCU (which is no longer in mainline), and more than three kilobytes compared to Hierarchical RCU (updated to 2.6.30): CONFIG_TREE_RCU: text data bss dec filename 183 4 0 187 kernel/rcupdate.o 2783 520 36 3339 kernel/rcutree.o 3526 Total (vs 4565 for v7) CONFIG_TREE_PREEMPT_RCU: text data bss dec filename 263 4 0 267 kernel/rcupdate.o 4594 776 52 5422 kernel/rcutree.o 5689 Total (6155 for v7) CONFIG_TINY_RCU: text data bss dec filename 96 4 0 100 kernel/rcupdate.o 734 24 0 758 kernel/rcutiny.o 858 Total (vs 848 for v7) The above is for x86. Your mileage may vary on other platforms. Further compression is possible, but is being procrastinated. Changes from v7 (http://lkml.org/lkml/2009/10/9/388) o Apply Lai Jiangshan's review comments (aside from might_sleep() in synchronize_sched(), which is covered by SMP builds). o Fix up expedited primitives. Changes from v6 (http://lkml.org/lkml/2009/9/23/293). o Forward ported to put it into the 2.6.33 stream. o Added lockdep support. o Make lightweight rcu_barrier. Changes from v5 (http://lkml.org/lkml/2009/6/23/12). o Ported to latest pre-2.6.32 merge window kernel. - Renamed rcu_qsctr_inc() to rcu_sched_qs(). - Renamed rcu_bh_qsctr_inc() to rcu_bh_qs(). - Provided trivial rcu_cpu_notify(). - Provided trivial exit_rcu(). - Provided trivial rcu_needs_cpu(). - Fixed up the rcu_*_enter/exit() functions in linux/hardirq.h. o Removed the dependence on EMBEDDED, with a view to making TINY_RCU default for !SMP at some time in the future. o Added (trivial) support for expedited grace periods. Changes from v4 (http://lkml.org/lkml/2009/5/2/91) include: o Squeeze the size down a bit further by removing the ->completed field from struct rcu_ctrlblk. o This permits synchronize_rcu() to become the empty function. Previous concerns about rcutorture were unfounded, as rcutorture correctly handles a constant value from rcu_batches_completed() and rcu_batches_completed_bh(). Changes from v3 (http://lkml.org/lkml/2009/3/29/221) include: o Changed rcu_batches_completed(), rcu_batches_completed_bh() rcu_enter_nohz(), rcu_exit_nohz(), rcu_nmi_enter(), and rcu_nmi_exit(), to be static inlines, as suggested by David Howells. Doing this saves about 100 bytes from rcutiny.o. (The numbers between v3 and this v4 of the patch are not directly comparable, since they are against different versions of Linux.) Changes from v2 (http://lkml.org/lkml/2009/2/3/333) include: o Fix whitespace issues. o Change short-circuit "||" operator to instead be "+" in order to fix performance bug noted by "kraai" on LWN. (http://lwn.net/Articles/324348/) Changes from v1 (http://lkml.org/lkml/2009/1/13/440) include: o This version depends on EMBEDDED as well as !SMP, as suggested by Ingo. o Updated rcu_needs_cpu() to unconditionally return zero, permitting the CPU to enter dynticks-idle mode at any time. This works because callbacks can be invoked upon entry to dynticks-idle mode. o Paul is now OK with this being included, based on a poll at the Kernel Miniconf at linux.conf.au, where about ten people said that they cared about saving 900 bytes on single-CPU systems. o Applies to both mainline and tip/core/rcu. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Josh Triplett <josh@joshtriplett.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: avi@redhat.com Cc: mtosatti@redhat.com LKML-Reference: <12565226351355-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
