path: root/kernel/rcutorture.c
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-08rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_checkMichal Hocko
Since ca5ecddf (rcu: define __rcu address space modifier for sparse) rcu_dereference_check use rcu_read_lock_held as a part of condition automatically so callers do not have to do that as well. Signed-off-by: Michal Hocko <mhocko@suse.cz> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-05rcu: mark rcutorture boosting callback as being on-stackPaul E. McKenney
The CONFIG_DEBUG_OBJECTS_RCU_HEAD facility requires that on-stack RCU callbacks be flagged explicitly to debug-objects using the init_rcu_head_on_stack() and destroy_rcu_head_on_stack() functions. This commit applies those functions to the rcutorture code that tests RCU priority boosting. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-05rcu: make rcutorture version numbers available through debugfsPaul E. McKenney
It is not possible to accurately correlate rcutorture output with that of debugfs. This patch therefore adds a debugfs file that prints out the rcutorture version number, permitting easy correlation. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-05rcu: eliminate unused boosting statisticsPaul E. McKenney
The n_rcu_torture_boost_allocerror and n_rcu_torture_boost_afferror statistics are not actually incremented anymore, so eliminate them. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-05-05rcu: avoid hammering sched with yet another bound RT kthreadPaul E. McKenney
The scheduler does not appear to take kindly to having multiple real-time threads bound to a CPU that is going offline. So this commit is a temporary hack-around to avoid that happening. Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2011-03-04rcutorture: Get rid of duplicate sched.h includeJesper Juhl
linux/sched.h is included twice in kernel/rcutorture.c - once is enough. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-10-07rcu: add priority-inversion testing to rcutorturePaul E. McKenney
Add an optional test to force long-term preemption of RCU read-side critical sections, controlled by new test_boost, test_boost_interval, and test_boost_duration module parameters. This is to be used to test RCU priority boosting. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-09-23rcu: fix sparse errors in rcutorture.cPaul E. McKenney
Add the sparse __rcu address-space identifier and make a couple of variables static. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-08-19rcutorture: add random preemptionLai Jiangshan
Add random preemption to help we to torture the preemptable rcu. srcu_read_delay() also calls rcu_read_delay() for shorter delays. Added comment to preempt_schedule() call indicating that no quiescent states happen if preemption is disabled. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2010-06-09sched_clock: Add local_clock() API and improve documentationPeter Zijlstra
For people who otherwise get to write: cpu_clock(smp_processor_id()), there is now: local_clock(). Also, as per suggestion from Andrew, provide some documentation on the various clock interfaces, and minimize the unsigned long long vs u64 mess. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Jens Axboe <jaxboe@fusionio.com> LKML-Reference: <1275052414.1645.52.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-05-18Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (49 commits) stop_machine: Move local variable closer to the usage site in cpu_stop_cpu_callback() sched, wait: Use wrapper functions sched: Remove a stale comment ondemand: Make the iowait-is-busy time a sysfs tunable ondemand: Solve a big performance issue by counting IOWAIT time as busy sched: Intoduce get_cpu_iowait_time_us() sched: Eliminate the ts->idle_lastupdate field sched: Fold updating of the last_update_time_info into update_ts_time_stats() sched: Update the idle statistics in get_cpu_idle_time_us() sched: Introduce a function to update the idle statistics sched: Add a comment to get_cpu_idle_time_us() cpu_stop: add dummy implementation for UP sched: Remove rq argument to the tracepoints rcu: need barrier() in UP synchronize_sched_expedited() sched: correctly place paranioa memory barriers in synchronize_sched_expedited() sched: kill paranoia check in synchronize_sched_expedited() sched: replace migration_thread with cpu_stop stop_machine: reimplement using cpu_stop cpu_stop: implement stop_cpu[s]() sched: Fix select_idle_sibling() logic in select_task_rq_fair() ...
2010-05-11rcu: remove all rcu head initializations, except on_stack initializationsPaul E. McKenney
Remove all rcu head inits. We don't care about the RCU head state before passing it to call_rcu() anyway. Only leave the "on_stack" variants so debugobjects can keep track of objects on stack. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-05-06sched: replace migration_thread with cpu_stopTejun Heo
Currently migration_thread is serving three purposes - migration pusher, context to execute active_load_balance() and forced context switcher for expedited RCU synchronize_sched. All three roles are hardcoded into migration_thread() and determining which job is scheduled is slightly messy. This patch kills migration_thread and replaces all three uses with cpu_stop. The three different roles of migration_thread() are splitted into three separate cpu_stop callbacks - migration_cpu_stop(), active_load_balance_cpu_stop() and synchronize_sched_expedited_cpu_stop() - and each use case now simply asks cpu_stop to execute the callback as necessary. synchronize_sched_expedited() was implemented with private preallocated resources and custom multi-cpu queueing and waiting logic, both of which are provided by cpu_stop. synchronize_sched_expedited_count is made atomic and all other shared resources along with the mutex are dropped. synchronize_sched_expedited() also implemented a check to detect cases where not all the callback got executed on their assigned cpus and fall back to synchronize_sched(). If called with cpu hotplug blocked, cpu_stop already guarantees that and the condition cannot happen; otherwise, stop_machine() would break. However, this patch preserves the paranoid check using a cpumask to record on which cpus the stopper ran so that it can serve as a bisection point if something actually goes wrong theree. Because the internal execution state is no longer visible, rcu_expedited_torture_stats() is removed. This patch also renames cpu_stop threads to from "stopper/%d" to "migration/%d". The names of these threads ultimately don't matter and there's no reason to make unnecessary userland visible changes. With this patch applied, stop_machine() and sched now share the same resources. stop_machine() is faster without wasting any resources and sched migration users are much cleaner. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Dipankar Sarma <dipankar@in.ibm.com> Cc: Josh Triplett <josh@freedesktop.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Dimitri Sivanich <sivanich@sgi.com>
2010-03-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: add __percpu sparse annotations to what's left percpu: add __percpu sparse annotations to fs percpu: add __percpu sparse annotations to core kernel subsystems local_t: Remove leftover local.h this_cpu: Remove pageset_notifier this_cpu: Page allocator conversion percpu, x86: Generic inc / dec percpu instructions local_t: Move local.h include to ringbuffer.c and ring_buffer_benchmark.c module: Use this_cpu_xx to dynamically allocate counters local_t: Remove cpu_local_xx macros percpu: refactor the code in pcpu_[de]populate_chunk() percpu: remove compile warnings caused by __verify_pcpu_ptr() percpu: make accessors check for percpu pointer in sparse percpu: add __percpu for sparse. percpu: make access macros universal percpu: remove per_cpu__ prefix.
2010-02-25rcu: Fix rcutorture mod_timer argument to delay one jiffyPaul E. McKenney
The current "mod_timer(&t, 1)" potentially makes the timer fire immediately, change this to wait one jiffy. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1266887105-1528-20-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25rcu: Introduce lockdep-based checking to RCU read-side primitivesPaul E. McKenney
Inspection is proving insufficient to catch all RCU misuses, which is understandable given that rcu_dereference() might be protected by any of four different flavors of RCU (RCU, RCU-bh, RCU-sched, and SRCU), and might also/instead be protected by any of a number of locking primitives. It is therefore time to enlist the aid of lockdep. This set of patches is inspired by earlier work by Peter Zijlstra and Thomas Gleixner, and takes the following approach: o Set up separate lockdep classes for RCU, RCU-bh, and RCU-sched. o Set up separate lockdep classes for each instance of SRCU. o Create primitives that check for being in an RCU read-side critical section. These return exact answers if lockdep is fully enabled, but if unsure, report being in an RCU read-side critical section. (We want to avoid false positives!) The primitives are: For RCU: rcu_read_lock_held(void) For RCU-bh: rcu_read_lock_bh_held(void) For RCU-sched: rcu_read_lock_sched_held(void) For SRCU: srcu_read_lock_held(struct srcu_struct *sp) o Add rcu_dereference_check(), which takes a second argument in which one places a boolean expression based on the above primitives and/or lockdep_is_held(). o A new kernel configuration parameter, CONFIG_PROVE_RCU, enables rcu_dereference_check(). This depends on CONFIG_PROVE_LOCKING, and should be quite helpful during the transition period while CONFIG_PROVE_RCU-unaware patches are in flight. The existing rcu_dereference() primitive does no checking, but upcoming patches will change that. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1266887105-1528-1-git-send-email-paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-13rcu: Add force_quiescent_state() testing to rcutorturePaul E. McKenney
Add force_quiescent_state() testing to rcutorture, with a separate thread that repeatedly invokes force_quiescent_state() in bursts. This can greatly increase the probability of encountering certain types of race conditions. Suggested-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1262646551116-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-01-05Merge branch 'master' into percpuTejun Heo
Conflicts: arch/powerpc/platforms/pseries/hvCall.S include/linux/percpu.h
2009-12-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (34 commits) m68k: rename global variable vmalloc_end to m68k_vmalloc_end percpu: add missing per_cpu_ptr_to_phys() definition for UP percpu: Fix kdump failure if booted with percpu_alloc=page percpu: make misc percpu symbols unique percpu: make percpu symbols in ia64 unique percpu: make percpu symbols in powerpc unique percpu: make percpu symbols in x86 unique percpu: make percpu symbols in xen unique percpu: make percpu symbols in cpufreq unique percpu: make percpu symbols in oprofile unique percpu: make percpu symbols in tracer unique percpu: make percpu symbols under kernel/ and mm/ unique percpu: remove some sparse warnings percpu: make alloc_percpu() handle array types vmalloc: fix use of non-existent percpu variable in put_cpu_var() this_cpu: Use this_cpu_xx in trace_functions_graph.c this_cpu: Use this_cpu_xx for ftrace this_cpu: Use this_cpu_xx in nmi handling this_cpu: Use this_cpu operations in RCU this_cpu: Use this_cpu ops for VM statistics ... Fix up trivial (famous last words) global per-cpu naming conflicts in arch/x86/kvm/svm.c mm/slab.c
2009-12-03rcu: Add expedited grace-period support for preemptible RCUPaul E. McKenney
Implement an synchronize_rcu_expedited() for preemptible RCU that actually is expedited. This uses synchronize_sched_expedited() to force all threads currently running in a preemptible-RCU read-side critical section onto the appropriate ->blocked_tasks[] list, then takes a snapshot of all of these lists and waits for them to drain. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <1259784616158-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-29percpu: remove per_cpu__ prefix.Rusty Russell
Now that the return from alloc_percpu is compatible with the address of per-cpu vars, it makes sense to hand around the address of per-cpu variables. To make this sane, we remove the per_cpu__ prefix we used created to stop people accidentally using these vars directly. Now we have sparse, we can use that (next patch). tj: * Updated to convert stuff which were missed by or added after the original patch. * Kill per_cpu_var() macro. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
2009-10-26rcu: Improve rcutorture diagnostics when bad torture_type specifiedPaul E. McKenney
Make rcutorture list the available torture_type values when it doesn't like the one specified. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Josh Triplett <josh@joshtriplett.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com Cc: avi@redhat.com Cc: mtosatti@redhat.com LKML-Reference: <12565226351868-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-26rcu: Add synchronize_srcu_expedited() to the rcutorture test suitePaul E. McKenney
Adds the "srcu_expedited" torture type, and also renames sched_ops_sync to sched_sync_ops for consistency while we are in this file. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Josh Triplett <josh@joshtriplett.org> Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: dipankar@in.ibm.com Cc: mathieu.desnoyers@polymtl.ca Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com Cc: avi@redhat.com Cc: mtosatti@redhat.com LKML-Reference: <12565226353636-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-03this_cpu: Use this_cpu operations in RCUChristoph Lameter
RCU does not do dynamic allocations but it increments per cpu variables a lot. These instructions results in a move to a register and then back to memory. This patch will make it use the inc/dec instructions on x86 that do not need a register. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2009-09-23rcu: Clean up code to address Ingo's checkpatch feedbackPaul E. McKenney
Move declarations and update storage classes to make checkpatch happy. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu Cc: dhowells@redhat.com LKML-Reference: <12537246441701-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-19rcu: Fix whitespace inconsistenciesPaul E. McKenney
Fix a number of whitespace ^Ierrors in the include/linux/rcu* and the kernel/rcu* files. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josh@joshtriplett.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org Cc: rostedt@goodmis.org Cc: Valdis.Kletnieks@vt.edu LKML-Reference: <20090918172819.GA24405@linux.vnet.ibm.com> [ did more checkpatch fixlets ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-18rcutorture: Occasionally delay readers enough to make RCU force_quiescent_stateJosh Triplett
rcutorture already delays readers, but never for long enough to make RCU force a quiescent state. Add an occasional delay of 50ms. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: laijs@cn.fujitsu.com Cc: dipankar@in.ibm.com Cc: akpm@linux-foundation.org Cc: mathieu.desnoyers@polymtl.ca Cc: josht@linux.vnet.ibm.com Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: peterz@infradead.org LKML-Reference: <12524504772607-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-03rcu: Add synchronize_sched_expedited() torture testsPaul E. McKenney
This patch adds rcutorture tests for the new synchronize_sched_expedited() primitive, and also does some whitespace cleanups in kernel/rcutorture.c as well. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: akpm@linux-foundation.org Cc: torvalds@linux-foundation.org Cc: davem@davemloft.net Cc: dada1@cosmosbay.com Cc: zbr@ioremap.net Cc: jeff.chua.linux@gmail.com Cc: paulus@samba.org Cc: laijs@cn.fujitsu.com Cc: jengelh@medozas.de Cc: r000n@r000n.net Cc: benh@kernel.crashing.org Cc: mathieu.desnoyers@polymtl.ca LKML-Reference: <12459460981342-git-send-email-> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-30cpumask: convert rcutorture.cRusty Russell
We're getting rid of cpumasks on the stack. Simply change tmp_mask to a global, and allocate it in rcu_torture_init(). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Josh Triplett <josh@freedesktop.org>
2009-01-07rcu: fix bug in rcutorture system-shutdown codePaul E. McKenney
This patch fixes an rcutorture bug found by Eric Sesterhenn that resulted in oopses in response to "rmmod rcutorture". The problem was in some new code that attempted to handle the case where a system is shut down while rcutorture is still running, for example, when rcutorture is built into the kernel so that it cannot be removed. The fix causes the rcutorture threads to "park" in an schedule_timeout_uninterruptible(MAX_SCHEDULE_TIMEOUT) rather than trying to get them to terminate cleanly. Concurrent shutdown and rmmod is illegal. I believe that this is 2.6.29 material, as it is used in some testing setups. For reference, here are the rcutorture operating modes: CONFIG_RCU_TORTURE_TEST=m This is the normal rcutorture build. Use "modprobe rcutorture" (with optional arguments) to start, and "rmmod rcutorture" to stop. If you shut the system down without doing the rmmod, you should see console output like: rcutorture thread rcu_torture_writer parking due to system shutdown One for each rcutorture kthread. CONFIG_RCU_TORTURE_TEST=y CONFIG_RCU_TORTURE_TEST_RUNNABLE=n Use this if you want rcutorture built in, but don't want the test to start running during early boot. To start the torturing: echo 1 > /proc/sys/kernel/rcutorture_runnable To stop the torturing, s/1/0/ You will get "parking" console messages as noted above when you shut the system down. CONFIG_RCU_TORTURE_TEST=y CONFIG_RCU_TORTURE_TEST_RUNNABLE=y Same as above, except that the torturing starts during early boot. Only for the stout of heart and strong of stomach. The same /proc entry noted above may be used to control the test. Located-by: Eric Sesterhenn <snakebyte@gmx.de> Tested-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-05rcu: fix rcutorture bugPaul E. McKenney
Fix an rcutorture bug that prevents the shutdown notifier from ever actually having any effect, due to the fact that kthreads ignore all signals. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-01cpumask: convert RCU implementationsRusty Russell
Impact: use new cpumask API. rcu_ctrlblk contains a cpumask, and it's highly optimized so I don't want a cpumask_var_t (ie. a pointer) for the CONFIG_CPUMASK_OFFSTACK case. It could use a dangling bitmap, and be allocated in __rcu_init to save memory, but for the moment we use a bitmap. (Eventually 'struct cpumask' will be undefined for CONFIG_CPUMASK_OFFSTACK, so we use a bitmap here to show we really mean it). We remove on-stack cpumasks, using cpumask_var_t for rcu_torture_shuffle_tasks() and for_each_cpu_and in force_quiescent_state(). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-12-17rcu: fix rcutorture behavior during rebootPaul E. McKenney
Impact: fix very rare reboot hang Because rcutorture ignored all signals, it does not terminate in response to the signals sent at shutdown time. This can cause strange failures due to its continuing to make use of kernel function too late in the shutdown sequence. This patch therefore adds a shutdown notifier to rcutorture, causing it to shut down in response to a reboot or an orderly shutdown. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-20byteorder: remove direct includes of linux/byteorder/swab[b].hHarvey Harrison
A consolidated implementation will provide this generically through asm/byteorder, remove direct includes to avoid breakage when the changeover to the new implementation occurs. This hunk was lost from commit 1d8cca44b6a244b7e378546d719041819049a0f9 ("byteorder: provide swabb.h generically in asm/byteorder.h") Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-26rcu: make rcutorture even more vicious: invoke RCU readers from irq handlers ↵Paul E. McKenney
(timers) This patch allows torturing RCU from irq handlers (timers, in this case). A new module parameter irqreader enables such additional torturing, and is enabled by default. Variants of RCU that do not tolerate readers being called from irq handlers (e.g., SRCU) ignore irqreader. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: josh@freedesktop.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: dino@in.ibm.com Cc: akpm@linux-foundation.org Cc: torvalds@linux-foundation.org Cc: vegard.nossum@gmail.com Cc: adobriyan@gmail.com Cc: oleg@tv-sign.ru Cc: bunk@kernel.org Cc: rjw@sisk.pl Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-24rcu: make quiescent rcutorture less power-hungryPaul E. McKenney
This patch aligns the rcutorture wakeup times to align with all other multiple-of-a-second wakeups to further decrease power consumption. Suggested-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: josh@freedesktop.org Cc: dvhltc@us.ibm.com Cc: niv@us.ibm.com Cc: dino@in.ibm.com Cc: akpm@linux-foundation.org Cc: torvalds@linux-foundation.org Cc: vegard.nossum@gmail.com Cc: adobriyan@gmail.com Cc: oleg@tv-sign.ru Cc: bunk@kernel.org Cc: rjw@sisk.pl Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-24rcu, rcutorture: make quiescent rcutorture less power-hungryPaul E. McKenney
2008-06-19rcu: make rcutorture more vicious: reinstate boot-time testingPaul E. McKenney
This patch re-institutes the ability to build rcutorture directly into the Linux kernel. The reason that this capability was removed was that this could result in your kernel being pretty much useless, as rcutorture would be running starting from early boot. This problem has been avoided by (1) making rcutorture run only three seconds of every six by default, (2) adding a CONFIG_RCU_TORTURE_TEST_RUNNABLE that permits rcutorture to be quiesced at boot time, and (3) adding a sysctl in /proc named /proc/sys/kernel/rcutorture_runnable that permits rcutorture to be quiesced and unquiesced when built into the kernel. Please note that this /proc file is -not- available when rcutorture is built as a module. Please also note that to get the earlier take-no-prisoners behavior, you must use the boot command line to set rcutorture's "stutter" parameter to zero. The rcutorture quiescing mechanism is currently quite crude: loops in each rcutorture process that poll a global variable once per tick. Suggestions for improvement are welcome. The default action will be to reduce the polling rate to a few times per second. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Suggested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-18rcu: make rcutorture more vicious: add stutter featurePaul E. McKenney
This patch takes a step towards making rcutorture more brutal by allowing the test to be automatically periodically paused, with the default being to run the test for five seconds then pause for five seconds and repeat. This behavior can be controlled using a new "stutter" module parameter, so that "stutter=0" gives the old default behavior of running continuously. Starting and stopping rcutorture more heavily stresses RCU's interaction with the scheduler, as well as exercising more paths through the grace-period detection code. Note that the default to "shuffle_interval" has also been adjusted from 5 seconds to 3 seconds to provide varying overlap with the "stutter" interval. I am still unable to provoke the failures that Alexey has been seeing, even with this patch, but will be doing a few additional things to beef up rcutorture. Suggested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-18rcutorture: WARN_ON_ONCE(1) when detecting an errorIngo Molnar
this makes it easier for automated tests to pick up such failures.
2008-05-19rcu: add call_rcu_sched() and friends to rcutorturePaul E. McKenney
Add entry to rcu_torture_ops allowing the correct barrier function to be used upon exit from rcutorture. Also add torture options for the new call_rcu_sched() API. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-29kernel: explicitly include required header files under kernel/Robert P. J. Day
Following an experimental deletion of the unnecessary directive #include <linux/slab.h> from the header file <linux/percpu.h>, these files under kernel/ were exposed as needing to include one of <linux/slab.h> or <linux/gfp.h>, so explicit includes were added where necessary. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19generic: use new set_cpus_allowed_ptr functionMike Travis
* Use new set_cpus_allowed_ptr() function added by previous patch, which instead of passing the "newly allowed cpus" cpumask_t arg by value, pass it by pointer: -int set_cpus_allowed(struct task_struct *p, cpumask_t new_mask) +int set_cpus_allowed_ptr(struct task_struct *p, const cpumask_t *new_mask) * Modify CPU_MASK_ALL Depends on: [sched-devel]: sched: add new set_cpus_allowed_ptr function Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-01-25cpu-hotplug: replace lock_cpu_hotplug() with get_online_cpus()Gautham R Shenoy
Replace all lock_cpu_hotplug/unlock_cpu_hotplug from the kernel and use get_online_cpus and put_online_cpus instead as it highlights the refcount semantics in these operations. The new API guarantees protection against the cpu-hotplug operation, but it doesn't guarantee serialized access to any of the local data structures. Hence the changes needs to be reviewed. In case of pseries_add_processor/pseries_remove_processor, use cpu_maps_update_begin()/cpu_maps_update_done() as we're modifying the cpu_present_map there. Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-17Make rcutorture RNG use temporal entropyPaul E. McKenney
Repost of http://lkml.org/lkml/2007/8/10/472 made available by request. The locking used by get_random_bytes() can conflict with the preempt_disable() and synchronize_sched() form of RCU. This patch changes rcutorture's RNG to gather entropy from the new cpu_clock() interface (relying on interrupts, preemption, daemons, and rcutorture's reader thread's rock-bottom scheduling priority to provide useful entropy), and also adds and EXPORT_SYMBOL_GPL() to make that interface available to GPLed kernel modules such as rcutorture. Passes several hours of rcutorture. [ego@in.ibm.com: Use raw_smp_processor_id() in rcu_random()] Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Clean up duplicate includes in kernel/Jesper Juhl
This patch cleans up duplicate includes in kernel/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Freezer: make kernel threads nonfreezable by defaultRafael J. Wysocki
Currently, the freezer treats all tasks as freezable, except for the kernel threads that explicitly set the PF_NOFREEZE flag for themselves. This approach is problematic, since it requires every kernel thread to either set PF_NOFREEZE explicitly, or call try_to_freeze(), even if it doesn't care for the freezing of tasks at all. It seems better to only require the kernel threads that want to or need to be frozen to use some freezer-related code and to remove any freezer-related code from the other (nonfreezable) kernel threads, which is done in this patch. The patch causes all kernel threads to be nonfreezable by default (ie. to have PF_NOFREEZE set by default) and introduces the set_freezable() function that should be called by the freezable kernel threads in order to unset PF_NOFREEZE. It also makes all of the currently freezable kernel threads call set_freezable(), so it shouldn't cause any (intentional) change of behaviour to appear. Additionally, it updates documentation to describe the freezing of tasks more accurately. [akpm@linux-foundation.org: build fixes] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Pavel Machek <pavel@ucw.cz> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rcutorture: Remove redundant assignment to cur_ops in for loopJosh Triplett
The for loop in rcutorture_init uses the condition cur_ops = torture_ops[i], cur_ops but then makes the same assignment to cur_ops inside the loop. Remove the redundant assignment inside the loop, and remove now-unnecessary braces. Signed-off-by: Josh Triplett <josh@kernel.org> Cc: "Paul E. McKenney" <paulmck@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rcutorture: style cleanup: avoid != NULL in boolean testsJosh Triplett
