commit a10d206ef1a83121ab7430cb196e0376a7145b22 upstream.
Each grace period is supposed to have at least one callback waiting
for that grace period to complete. However, if CONFIG_NO_HZ=n, an
extra callback-free grace period is no big problem -- it will chew up
a tiny bit of CPU time, but it will complete normally. In contrast,
CONFIG_NO_HZ=y kernels have the potential for all the CPUs to go to
sleep indefinitely, in turn indefinitely delaying completion of the
callback-free grace period. Given that nothing is waiting on this grace
period, this is also not a problem.
That is, unless RCU CPU stall warnings are also enabled, as they are
in recent kernels. In this case, if a CPU wakes up after at least one
minute of inactivity, an RCU CPU stall warning will result. The reason
that no one noticed until quite recently is that most systems have enough
OS noise that they will never remain absolutely idle for a full minute.
But there are some embedded systems with cut-down userspace configurations
that consistently get into this situation.
All this begs the question of exactly how a callback-free grace period
gets started in the first place. This can happen due to the fact that
CPUs do not necessarily agree on which grace period is in progress.
If a CPU still believes that the grace period that just completed is
still ongoing, it will believe that it has callbacks that need to wait for
another grace period, never mind the fact that the grace period that they
were waiting for just completed. This CPU can therefore erroneously
decide to start a new grace period. Note that this can happen in
TREE_RCU and TREE_PREEMPT_RCU even on a single-CPU system: Deadlock
considerations mean that the CPU that detected the end of the grace
period is not necessarily officially informed of this fact for some time.
Once this CPU notices that the earlier grace period completed, it will
invoke its callbacks. It then won't have any callbacks left. If no
other CPU has any callbacks, we now have a callback-free grace period.
This commit therefore makes CPUs check more carefully before starting a
new grace period. This new check relies on an array of tail pointers
into each CPU's list of callbacks. If the CPU is up to date on which
grace periods have completed, it checks to see if any callbacks follow
the RCU_DONE_TAIL segment, otherwise it checks to see if any callbacks
follow the RCU_WAIT_TAIL segment. The reason that this works is that
the RCU_WAIT_TAIL segment will be promoted to the RCU_DONE_TAIL segment
as soon as the CPU is officially notified that the old grace period
has ended.
This change is to cpu_needs_another_gp(), which is called in a number
of places. The only one that really matters is in rcu_start_gp(), where
the root rcu_node structure's ->lock is held, which prevents any
other CPU from starting or completing a grace period, so that the
comparison that determines whether the CPU is missing the completion
of a grace period is stable.
Reported-by: Becky Bruce <bgillbruce@gmail.com>
Reported-by: Subodh Nijsure <snijsure@grid-net.com>
Reported-by: Paul Walmsley <paul@pwsan.com>
Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org>
Tested-by: Paul Walmsley <paul@pwsan.com>
Under some rare but real combinations of configuration parameters, RCU
callbacks are posted during early boot that use kernel facilities that
are not yet initialized. Therefore, when these callbacks are invoked,
hard hangs and crashes ensue. This commit therefore prevents RCU
callbacks from being invoked until after the scheduler is fully up and
running, as in after multiple tasks have been spawned.
It might well turn out that a better approach is to identify the specific
RCU callbacks that are causing this problem, but that discussion will
wait until such time as someone really needs an RCU callback to be invoked
(as opposed to merely registered) during early boot.
Reported-by: julie Sullivan <kernelmail.jms@gmail.com>
Reported-by: RKK <kulkarni.ravi4@gmail.com>
Tested-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Tested-by: julie Sullivan <kernelmail.jms@gmail.com>
Tested-by: RKK <kulkarni.ravi4@gmail.com>
The commit "use softirq instead of kthreads except when RCU_BOOST=y"
just applied #ifdef in place. This commit is a cleanup that moves
the newly #ifdef'ed code to the header file kernel/rcutree_plugin.h.
This patch #ifdefs RCU kthreads out of the kernel unless RCU_BOOST=y,
thus eliminating context-switch overhead if RCU priority boosting has
not been configured.
Commit a26ac2455ffcf3(rcu: move TREE_RCU from softirq to kthread)
introduced performance regression. In an AIM7 test, this commit degraded
performance by about 40%.
The commit runs rcu callbacks in a kthread instead of softirq. We observed
high rate of context switch which is caused by this. Out test system has
64 CPUs and HZ is 1000, so we saw more than 64k context switch per second
which is caused by RCU's per-CPU kthread. A trace showed that most of
the time the RCU per-CPU kthread doesn't actually handle any callbacks,
but instead just does a very small amount of work handling grace periods.
This means that RCU's per-CPU kthreads are making the scheduler do quite
a bit of work in order to allow a very small amount of RCU-related
processing to be done.
Alex Shi's analysis determined that this slowdown is due to lock
contention within the scheduler. Unfortunately, as Peter Zijlstra points
out, the scheduler's real-time semantics require global action, which
means that this contention is inherent in real-time scheduling. (Yes,
perhaps someone will come up with a workaround -- otherwise, -rt is not
going to do well on large SMP systems -- but this patch will work around
this issue in the meantime. And "the meantime" might well be forever.)
This patch therefore re-introduces softirq processing to RCU, but only
for core RCU work. RCU callbacks are still executed in kthread context,
so that only a small amount of RCU work runs in softirq context in the
common case. This should minimize ksoftirqd execution, allowing us to
skip boosting of ksoftirqd for CONFIG_RCU_BOOST=y kernels.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Tested-by: "Alex,Shi" <alex.shi@intel.com>
Make the functions creating the kthreads wake them up. Leverage the
fact that the per-node and boost kthreads can run anywhere, thus
dispensing with the need to wake them up once the incoming CPU has
gone fully online.
Tested-by: Daniel J Blueman <daniel.blueman@gmail.com>
Commit cc3ce5176d83 (rcu: Start RCU kthreads in TASK_INTERRUPTIBLE
state) fudges a sleeping task' state, resulting in the scheduler seeing
a TASK_UNINTERRUPTIBLE task going to sleep, but a TASK_INTERRUPTIBLE
task waking up. The result is unbalanced load calculation.
The problem that patch tried to address is that the RCU threads could
stay in UNINTERRUPTIBLE state for quite a while and triggering the hung
task detector due to on-demand wake-ups.
Cure the problem differently by always giving the tasks at least one
wake-up once the CPU is fully up and running, this will kick them out of
the initial UNINTERRUPTIBLE state and into the regular INTERRUPTIBLE
wait state.
[ The alternative would be teaching kthread_create() to start threads as
INTERRUPTIBLE but that needs a tad more thought. ]
Reported-by: Damien Wyart <damien.wyart@free.fr>
Acked-by: Paul E. McKenney <paul.mckenney@linaro.org>
Link: http://lkml.kernel.org/r/1306755291.1200.2872.camel@twins
Upon creation, kthreads are in TASK_UNINTERRUPTIBLE state, which can
result in softlockup warnings. Because some of RCU's kthreads can
legitimately be idle indefinitely, start them in TASK_INTERRUPTIBLE
state in order to avoid those warnings.
Suggested-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Tested-by: Yinghai Lu <yinghai@kernel.org>
It is not necessary to use waitqueues for the RCU kthreads because
we always know exactly which thread is to be awakened. In addition,
wake_up() only issues an actual wakeup when there is a thread waiting on
the queue, which was why there was an extra explicit wake_up_process()
to get the RCU kthreads started.
Eliminating the waitqueues (and wake_up()) in favor of wake_up_process()
eliminates the need for the initial wake_up_process() and also shrinks
the data structure size a bit. The wakeup logic is placed in a new
rcu_wait() macro.
This commit switches manipulations of the rcu_node ->wakemask field
to atomic operations, which allows rcu_cpu_kthread_timer() to avoid
acquiring the rcu_node lock. This should avoid the following lockdep
splat reported by Valdis Kletnieks:
[ 12.872150] usb 1-4: new high speed USB device number 3 using ehci_hcd
[ 12.986667] usb 1-4: New USB device found, idVendor=413c, idProduct=2513
[ 12.986679] usb 1-4: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 12.987691] hub 1-4:1.0: USB hub found
[ 12.987877] hub 1-4:1.0: 3 ports detected
[ 12.996372] input: PS/2 Generic Mouse as /devices/platform/i8042/serio1/input/input10
[ 13.071471] udevadm used greatest stack depth: 3984 bytes left
[ 13.172129]
[ 13.172130] =======================================================
[ 13.172425] [ INFO: possible circular locking dependency detected ]
[ 13.172650] 2.6.39-rc6-mmotm0506 #1
[ 13.172773] -------------------------------------------------------
[ 13.172997] blkid/267 is trying to acquire lock:
[ 13.173009] (&p->pi_lock){-.-.-.}, at: [<ffffffff81032d8f>] try_to_wake_up+0x29/0x1aa
[ 13.173009]
[ 13.173009] but task is already holding lock:
[ 13.173009] (rcu_node_level_0){..-...}, at: [<ffffffff810901cc>] rcu_cpu_kthread_timer+0x27/0x58
[ 13.173009]
[ 13.173009] which lock already depends on the new lock.
[ 13.173009]
[ 13.173009]
[ 13.173009] the existing dependency chain (in reverse order) is:
[ 13.173009]
[ 13.173009] -> #2 (rcu_node_level_0){..-...}:
[ 13.173009] [<ffffffff810679b9>] check_prevs_add+0x8b/0x104
[ 13.173009] [<ffffffff81067da1>] validate_chain+0x36f/0x3ab
[ 13.173009] [<ffffffff8106846b>] __lock_acquire+0x369/0x3e2
[ 13.173009] [<ffffffff81068a0f>] lock_acquire+0xfc/0x14c
[ 13.173009] [<ffffffff815697f1>] _raw_spin_lock+0x36/0x45
[ 13.173009] [<ffffffff81090794>] rcu_read_unlock_special+0x8c/0x1d5
[ 13.173009] [<ffffffff8109092c>] __rcu_read_unlock+0x4f/0xd7
[ 13.173009] [<ffffffff81027bd3>] rcu_read_unlock+0x21/0x23
[ 13.173009] [<ffffffff8102cc34>] cpuacct_charge+0x6c/0x75
[ 13.173009] [<ffffffff81030cc6>] update_curr+0x101/0x12e
[ 13.173009] [<ffffffff810311d0>] check_preempt_wakeup+0xf7/0x23b
[ 13.173009] [<ffffffff8102acb3>] check_preempt_curr+0x2b/0x68
[ 13.173009] [<ffffffff81031d40>] ttwu_do_wakeup+0x76/0x128
[ 13.173009] [<ffffffff81031e49>] ttwu_do_activate.constprop.63+0x57/0x5c
[ 13.173009] [<ffffffff81031e96>] scheduler_ipi+0x48/0x5d
[ 13.173009] [<ffffffff810177d5>] smp_reschedule_interrupt+0x16/0x18
[ 13.173009] [<ffffffff815710f3>] reschedule_interrupt+0x13/0x20
[ 13.173009] [<ffffffff810b66d1>] rcu_read_unlock+0x21/0x23
[ 13.173009] [<ffffffff810b739c>] find_get_page+0xa9/0xb9
[ 13.173009] [<ffffffff810b8b48>] filemap_fault+0x6a/0x34d
[ 13.173009] [<ffffffff810d1a25>] __do_fault+0x54/0x3e6
[ 13.173009] [<ffffffff810d447a>] handle_pte_fault+0x12c/0x1ed
[ 13.173009] [<ffffffff810d48f7>] handle_mm_fault+0x1cd/0x1e0
[ 13.173009] [<ffffffff8156cfee>] do_page_fault+0x42d/0x5de
[ 13.173009] [<ffffffff8156a75f>] page_fault+0x1f/0x30
[ 13.173009]
[ 13.173009] -> #1 (&rq->lock){-.-.-.}:
[ 13.173009] [<ffffffff81027e19>] __task_rq_lock+0x8b/0xd3
[ 13.173009] [<ffffffff81032f7f>] wake_up_new_task+0x41/0x108
[ 13.173009] [<ffffffff810376c3>] do_fork+0x265/0x33f
[ 13.173009] [<ffffffff81007d02>] kernel_thread+0x6b/0x6d
[ 13.173009] [<ffffffff8153a9dd>] rest_init+0x21/0xd2
[ 13.173009] [<ffffffff81b1db4f>] start_kernel+0x3bb/0x3c6
[ 13.173009] [<ffffffff81b1d29f>] x86_64_start_reservations+0xaf/0xb3
[ 13.173009] [<ffffffff81b1d393>] x86_64_start_kernel+0xf0/0xf7
[ 13.173009]
[ 13.173009] -> #0 (&p->pi_lock){-.-.-.}:
[ 13.173009] [<ffffffff81067788>] check_prev_add+0x68/0x20e
[ 13.173009] [<ffffffff815698ea>] _raw_spin_lock_irqsave+0x44/0x57
[ 13.173009] [<ffffffff81032d8f>] try_to_wake_up+0x29/0x1aa
[ 13.173009] [<ffffffff81032f3c>] wake_up_process+0x10/0x12
[ 13.173009] [<ffffffff810901e9>] rcu_cpu_kthread_timer+0x44/0x58
[ 13.173009] [<ffffffff81045286>] call_timer_fn+0xac/0x1e9
[ 13.173009] [<ffffffff8104556d>] run_timer_softirq+0x1aa/0x1f2
[ 13.173009] [<ffffffff8103e487>] __do_softirq+0x109/0x26a
[ 13.173009] [<ffffffff8157144c>] call_softirq+0x1c/0x30
[ 13.173009] [<ffffffff81003207>] do_softirq+0x44/0xf1
[ 13.173009] [<ffffffff8103e8b9>] irq_exit+0x58/0xc8
[ 13.173009] [<ffffffff81017f5a>] smp_apic_timer_interrupt+0x79/0x87
[ 13.173009] [<ffffffff81570fd3>] apic_timer_interrupt+0x13/0x20
[ 13.173009] [<ffffffff810bd51a>] get_page_from_freelist+0x2aa/0x310
[ 13.173009] [<ffffffff810bdf03>] __alloc_pages_nodemask+0x178/0x243
[ 13.173009] [<ffffffff8101fe2f>] pte_alloc_one+0x1e/0x3a
[ 13.173009] [<ffffffff810d27fe>] __pte_alloc+0x22/0x14b
[ 13.173009] [<ffffffff810d48a8>] handle_mm_fault+0x17e/0x1e0
[ 13.173009]
[ 13.173009] other info that might help us debug this:
[ 13.173009]
[ 13.173009] Chain exists of:
[ 13.173009] &p->pi_lock --> &rq->lock --> rcu_node_level_0
[ 13.173009]
[ 13.173009] Possible unsafe locking scenario:
[ 13.173009]
[ 13.173009] CPU0 CPU1
[ 13.173009] ---- ----
[ 13.173009] lock(rcu_node_level_0);
[ 13.173009] lock(&rq->lock);
[ 13.173009] lock(&p->pi_lock);
[ 13.173009]
[ 13.173009] *** DEADLOCK ***
[ 13.173009]
[ 13.173009] 3 locks held by blkid/267:
[ 13.173009] #0: (&mm->mmap_sem){++++++}, at: [<ffffffff8156cdb4>] do_page_fault+0x1f3/0x5de
[ 13.173009] #1: (&yield_timer){+.-...}, at: [<ffffffff810451da>] call_timer_fn+0x0/0x1e9
[ 13.173009] #2: (rcu_node_level_0){..-...}, at: [<ffffffff810901cc>] rcu_cpu_kthread_timer+0x27/0x58
[ 13.173009]
[ 13.173009] stack backtrace:
[ 13.173009] Pid: 267, comm: blkid Not tainted 2.6.39-rc6-mmotm0506 #1
[ 13.173009] Call Trace:
[ 13.173009] <IRQ> [<ffffffff8154a529>] print_circular_bug+0xc8/0xd9
[ 13.173009] [<ffffffff8100c861>] ? save_stack_trace+0x28/0x46
[ 13.173009] [<ffffffff81032d8f>] ? try_to_wake_up+0x29/0x1aa
[ 13.173009] [<ffffffff810901a5>] ? rcu_check_quiescent_state+0x82/0x82
[ 13.173009] [<ffffffff810451da>] ? del_timer+0x75/0x75
[ 13.173009] [<ffffffff8106365f>] ? tick_dev_program_event+0x37/0xf6
[ 13.173009] [<ffffffff810a0e4a>] ? time_hardirqs_off+0x1b/0x2f
[ 13.173009] <EOI> [<ffffffff810bd384>] ? get_page_from_freelist+0x114/0x310
[ 13.173009] [<ffffffff810bd51a>] ? get_page_from_freelist+0x2aa/0x310
[ 13.173009] [<ffffffff812220e7>] ? clear_page_c+0x7/0x10
[ 13.173009] [<ffffffff810bd1ef>] ? prep_new_page+0x14c/0x1cd
[ 13.173009] [<ffffffff810d46b9>] ? __pmd_alloc+0x87/0x99
[ 13.173009] [<ffffffff810d915f>] ? sys_brk+0x32/0x10c
[ 13.173009] [<ffffffff81065c4f>] ? trace_hardirqs_off_caller+0x3f/0x9c
[ 13.173009] [<ffffffff812235dd>] ? trace_hardirqs_off_thunk+0x3a/0x3c
[ 14.010075] usb 5-1: new full speed USB device number 2 using uhci_hcd
Reported-by: Valdis Kletnieks <Valdis.Kletnieks@vt.edu>
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/urgent
(Note: this was reverted, and is now being re-applied in pieces, with
this being the fifth and final piece. See below for the reason that
it is now felt to be safe to re-apply this.)
Commit d09b62d fixed grace-period synchronization, but left some smp_mb()
invocations in rcu_process_callbacks() that are no longer needed, but
sheer paranoia prevented them from being removed. This commit removes
them and provides a proof of correctness in their absence. It also adds
a memory barrier to rcu_report_qs_rsp() immediately before the update to
rsp->completed in order to handle the theoretical possibility that the
compiler or CPU might move massive quantities of code into a lock-based
critical section. This also proves that the sheer paranoia was not
entirely unjustified, at least from a theoretical point of view.
In addition, the old dyntick-idle synchronization depended on the fact
that grace periods were many milliseconds in duration, so that it could
be assumed that no dyntick-idle CPU could reorder a memory reference
across an entire grace period. Unfortunately for this design, the
addition of expedited grace periods breaks this assumption, which has
the unfortunate side-effect of requiring atomic operations in the
functions that track dyntick-idle state for RCU. (There is some hope
that the algorithms used in user-level RCU might be applied here, but
some work is required to handle the NMIs that user-space applications
can happily ignore. For the short term, better safe than sorry.)
This proof assumes that neither compiler nor CPU will allow a lock
acquisition and release to be reordered, as doing so can result in
deadlock. The proof is as follows:
1. A given CPU declares a quiescent state under the protection of
its leaf rcu_node's lock.
2. If there is more than one level of rcu_node hierarchy, the
last CPU to declare a quiescent state will also acquire the
->lock of the next rcu_node up in the hierarchy, but only
after releasing the lower level's lock. The acquisition of this
lock clearly cannot occur prior to the acquisition of the leaf
node's lock.
3. Step 2 repeats until we reach the root rcu_node structure.
Please note again that only one lock is held at a time through
this process. The acquisition of the root rcu_node's ->lock
must occur after the release of that of the leaf rcu_node.
4. At this point, we set the ->completed field in the rcu_state
structure in rcu_report_qs_rsp(). However, if the rcu_node
hierarchy contains only one rcu_node, then in theory the code
preceding the quiescent state could leak into the critical
section. We therefore precede the update of ->completed with a
memory barrier. All CPUs will therefore agree that any updates
preceding any report of a quiescent state will have happened
before the update of ->completed.
5. Regardless of whether a new grace period is needed, rcu_start_gp()
will propagate the new value of ->completed to all of the leaf
rcu_node structures, under the protection of each rcu_node's ->lock.
If a new grace period is needed immediately, this propagation
will occur in the same critical section that ->completed was
set in, but courtesy of the memory barrier in #4 above, is still
seen to follow any pre-quiescent-state activity.
6. When a given CPU invokes __rcu_process_gp_end(), it becomes
aware of the end of the old grace period and therefore makes
any RCU callbacks that were waiting on that grace period eligible
for invocation.
If this CPU is the same one that detected the end of the grace
period, and if there is but a single rcu_node in the hierarchy,
we will still be in the single critical section. In this case,
the memory barrier in step #4 guarantees that all callbacks will
be seen to execute after each CPU's quiescent state.
On the other hand, if this is a different CPU, it will acquire
the leaf rcu_node's ->lock, and will again be serialized after
each CPU's quiescent state for the old grace period.
On the strength of this proof, this commit therefore removes the memory
barriers from rcu_process_callbacks() and adds one to rcu_report_qs_rsp().
The effect is to reduce the number of memory barriers by one and to
reduce the frequency of execution from about once per scheduling tick
per CPU to once per grace period.
This was reverted do to hangs found during testing by Yinghai Lu and
Ingo Molnar. Frederic Weisbecker supplied Yinghai with tracing that
located the underlying problem, and Frederic also provided the fix.
The underlying problem was that the HARDIRQ_ENTER() macro from
lib/locking-selftest.c invoked irq_enter(), which in turn invokes
rcu_irq_enter(), but HARDIRQ_EXIT() invoked __irq_exit(), which
does not invoke rcu_irq_exit(). This situation resulted in calls
to rcu_irq_enter() that were not balanced by the required calls to
rcu_irq_exit(). Therefore, after these locking selftests completed,
RCU's dyntick-idle nesting count was a large number (for example,
72), which caused RCU to to conclude that the affected CPU was not in
dyntick-idle mode when in fact it was.
RCU would therefore incorrectly wait for this dyntick-idle CPU, resulting
in hangs.
In contrast, with Frederic's patch, which replaces the irq_enter()
in HARDIRQ_ENTER() with an __irq_enter(), these tests don't ever call
either rcu_irq_enter() or rcu_irq_exit(), which works because the CPU
running the test is already marked as not being in dyntick-idle mode.
This means that the rcu_irq_enter() and rcu_irq_exit() calls and RCU
then has no problem working out which CPUs are in dyntick-idle mode and
which are not.
The reason that the imbalance was not noticed before the barrier patch
was applied is that the old implementation of rcu_enter_nohz() ignored
the nesting depth. This could still result in delays, but much shorter
ones. Whenever there was a delay, RCU would IPI the CPU with the
unbalanced nesting level, which would eventually result in rcu_enter_nohz()
being called, which in turn would force RCU to see that the CPU was in
dyntick-idle mode.
The reason that very few people noticed the problem is that the mismatched
irq_enter() vs. __irq_exit() occured only when the kernel was built with
CONFIG_DEBUG_LOCKING_API_SELFTESTS.
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
The old version of rcu_enter_nohz() forced RCU into nohz mode even if
the nesting count was non-zero. This change causes rcu_enter_nohz()
to hold off for non-zero nesting counts.
Condition the set_need_resched() in rcu_irq_exit() on in_irq(). This
should be a no-op, because rcu_irq_exit() should only be called from irq.
Second step of partitioning of commit e59fb3120b.
Add the memory barriers added by e59fb3120b.
Commit e66eed651fd1 ("list: remove prefetching from regular list
iterators") removed the include of prefetch.h from list.h, which
uncovered several cases that had apparently relied on that rather
obscure header file dependency.
So this fixes things up a bit, using
grep -L linux/prefetch.h $(git grep -l '[^a-z_]prefetchw*(' -- '*.[ch]')
grep -L 'prefetchw*(' $(git grep -l 'linux/prefetch.h' -- '*.[ch]')
to guide us in finding files that either need <linux/prefetch.h>
inclusion, or have it despite not needing it.
There are more of them around (mostly network drivers), but this gets
many core ones.
This reverts commit e59fb3120becfb36b22ddb8bd27d065d3cdca499.
This reversion was due to (extreme) boot-time slowdowns on SPARC seen by
Yinghai Lu and on x86 by Ingo
This is a non-trivial reversion due to intervening commits.
Documentation/RCU/trace.txt
kernel/rcutree.c
Avoid calling into the scheduler while holding core RCU locks. This
allows rcu_read_unlock() to be called while holding the runqueue locks,
but only as long as there was no chance of the RCU read-side critical
section having been preempted. (Otherwise, if RCU priority boosting
is enabled, rcu_read_unlock() might call into the scheduler in order to
unboost itself, which might allows self-deadlock on the runqueue locks
within the scheduler.)
Provide rcu_virt_note_context_switch() for vitalization use to note
quiescent state during guest entry.
Signed-off-by: Gleb Natapov <gleb@redhat.com>
Signed integer overflow is undefined by the C standard, so move
calculations to unsigned.
This commit marks a first step towards making call_rcu() have
real-time behavior. If irqs are disabled, don't dive into the
RCU core. Later on, this new early exit will wake up the
per-CPU kthread, which first must be modified to handle the
cases involving callback storms.
Although rcu_yield() dropped from real-time to normal priority, there
is always the possibility that the competing tasks have been niced.
So nice to 19 in rcu_yield() to help ensure that other tasks have a
better chance of running.
Many rcu callbacks functions just call kfree() on the base structure.
These functions are trivial, but their size adds up, and furthermore
when they are used in a kernel module, that module must invoke the
high-latency rcu_barrier() function at module-unload time.
The kfree_rcu() function introduced by this commit addresses this issue.
Rather than encoding a function address in the embedded rcu_head
structure, kfree_rcu() instead encodes the offset of the rcu_head
structure within the base structure. Because the functions are not
allowed in the low-order 4096 bytes of kernel virtual memory, offsets
up to 4095 bytes can be accommodated. If the offset is larger than
4095 bytes, a compile-time error will be generated in __kfree_rcu().
If this error is triggered, you can either fall back to use of call_rcu()
or rearrange the structure to position the rcu_head structure into the
first 4096 bytes.
Note that the allowable offset might decrease in the future, for example,
to allow something like kmem_cache_free_rcu().
The new kfree_rcu() function can replace code as follows:
call_rcu(&p->rcu, simple_kfree_callback);
where "simple_kfree_callback()" might be defined as follows:
void simple_kfree_callback(struct rcu_head *p)
struct foo *q = container_of(p, struct foo, rcu);
kfree(q);
with the following:
kfree_rcu(&p->rcu, rcu);
Note that the "rcu" is the name of a field in the structure being
freed. The reason for using this rather than passing in a pointer
to the base structure is that the above approach allows better type
checking.
This commit is based on earlier work by Lai Jiangshan and Manfred Spraul:
Lai's V1 patch: http://lkml.org/lkml/2008/9/18/1
Manfred's patch: http://lkml.org/lkml/2009/1/2/115
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Signed-off-by: Manfred Spraul <manfred@colorfullife.com>
Reviewed-by: David Howells <dhowells@redhat.com>
The "preemptible" spelling is preferable. May as well fix it.
This removes a couple of lines from invoke_rcu_cpu_kthread(), improving
readability.
Reported-by: Christoph Lameter <cl@linux.com>
Increment a per-CPU counter on each pass through rcu_cpu_kthread()'s
service loop, and add it to the rcudata trace output.
This commit adds the age in jiffies of the current grace period along
with the duration in jiffies of the longest grace period since boot
to the rcu/rcugp debugfs file. It also adds an additional "O" state
to kthread tracing to differentiate between the kthread waiting due to
having nothing to do on the one hand and waiting due to being on the
wrong CPU on the other hand.
It is not possible to accurately correlate rcutorture output with that
of debugfs. This patch therefore adds a debugfs file that prints out
the rcutorture version number, permitting easy correlation.
Add tracing to help debugging situations when RCU's kthreads are not
running but are supposed to be.
If you are doing CPU hotplug operations, it is best not to have
CPU-bound realtime tasks running CPU-bound on the outgoing CPU.
So this commit makes per-CPU kthreads run at non-realtime priority
during that time.
The scheduler has had some heartburn in the past when too many real-time
kthreads were affinitied to the outgoing CPU. So, this commit lightens
the load by forcing the per-rcu_node and the boost kthreads off of the
outgoing CPU. Note that RCU's per-CPU kthread remains on the outgoing
CPU until the bitter end, as it must in order to preserve correctness.
Also avoid disabling hardirqs across calls to set_cpus_allowed_ptr(),
given that this function can block.
Add priority boosting for TREE_PREEMPT_RCU, similar to that for
TINY_PREEMPT_RCU. This is enabled by the default-off RCU_BOOST
kernel parameter. The priority to which to boost preempted
RCU readers is controlled by the RCU_BOOST_PRIO kernel parameter
(defaulting to real-time priority 1) and the time to wait before
boosting the readers who are blocking a given grace period is
controlled by the RCU_BOOST_DELAY kernel parameter (defaulting to
500 milliseconds).
If RCU priority boosting is to be meaningful, callback invocation must
be boosted in addition to preempted RCU readers. Otherwise, in presence
of CPU real-time threads, the grace period ends, but the callbacks don't
get invoked. If the callbacks don't get invoked, the associated memory
doesn't get freed, so the system is still subject to OOM.
But it is not reasonable to priority-boost RCU_SOFTIRQ, so this commit
moves the callback invocations to a kthread, which can be boosted easily.
Also add comments and properly synchronized all accesses to
rcu_cpu_kthread_task, as suggested by Lai Jiangshan.
Combine the current TREE_PREEMPT_RCU ->blocked_tasks[] lists in the
rcu_node structure into a single ->blkd_tasks list with ->gp_tasks
and ->exp_tasks tail pointers. This is in preparation for RCU priority
boosting, which will add a third dimension to the combinatorial explosion
in the ->blocked_tasks[] case, but simply a third pointer in the new
->blkd_tasks case.
Also update documentation to reflect blocked_tasks[] merge
node's lock.
for invocation.
The RCU CPU stall warnings can now be controlled using the
rcu_cpu_stall_suppress boot-time parameter or via the same parameter
from sysfs. There is therefore no longer any reason to have
kernel config parameters for this feature. This commit therefore
removes the RCU_CPU_STALL_DETECTOR and RCU_CPU_STALL_DETECTOR_RUNNABLE
kernel config parameters. The RCU_CPU_STALL_TIMEOUT parameter remains
to allow the timeout to be tuned and the RCU_CPU_STALL_VERBOSE parameter
remains to allow task-stall information to be suppressed if desired.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-2.6.38' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (30 commits)
gameport: use this_cpu_read instead of lookup
x86: udelay: Use this_cpu_read to avoid address calculation
x86: Use this_cpu_inc_return for nmi counter
x86: Replace uses of current_cpu_data with this_cpu ops
x86: Use this_cpu_ops to optimize code
vmstat: User per cpu atomics to avoid interrupt disable / enable
irq_work: Use per cpu atomics instead of regular atomics
cpuops: Use cmpxchg for xchg to avoid lock semantics
x86: this_cpu_cmpxchg and this_cpu_xchg operations
percpu: Generic this_cpu_cmpxchg() and this_cpu_xchg support
percpu,x86: relocate this_cpu_add_return() and friends
connector: Use this_cpu operations
xen: Use this_cpu_inc_return
taskstats: Use this_cpu_ops
random: Use this_cpu_inc_return
fs: Use this_cpu_inc_return in buffer.c
highmem: Use this_cpu_xx_return() operations
vmstat: Use this_cpu_inc_return for vm statistics
x86: Support for this_cpu_add, sub, dec, inc_return
percpu: Generic support for this_cpu_add, sub, dec, inc_return
Fixed up conflicts: in arch/x86/kernel/{apic/nmi.c, apic/x2apic_uv_x.c, process.c}
as per Tejun.
When the current __call_rcu() function was written, the expedited
APIs did not exist. The __call_rcu() implementation therefore went
to great lengths to detect the end of old grace periods and to start
new ones, all in the name of reducing grace-period latency. Now the
expedited APIs do exist, and the usage of __call_rcu() has increased
considerably. This commit therefore causes __call_rcu() to avoid
worrying about grace periods unless there are a large number of
RCU callbacks stacked up on the current CPU.
Some recent benchmarks have indicated possible lock contention on the
leaf-level rcu_node locks. This commit therefore limits the number of
CPUs per leaf-level rcu_node structure to 16, in other words, there
can be at most 16 rcu_data structures fanning into a given rcu_node
structure. Prior to this, the limit was 32 on 32-bit systems and 64 on
64-bit systems.
Note that the fanout of non-leaf rcu_node structures is unchanged. The
organization of accesses to the rcu_node tree is such that references
to non-leaf rcu_node structures are much less frequent than to the
leaf structures.
Use the CPU's bit in rnp->qsmask to determine whether or not the CPU
should try to report a quiescent state. Handle overflow in the check
for rdp->gpnum having fallen behind.
When a CPU that was in an extended quiescent state wakes
up and catches up with grace periods that remote CPUs
completed on its behalf, we update the completed field
but not the gpnum that keeps a stale value of a backward
grace period ID.
Later, note_new_gpnum() will interpret the shift between
the local CPU and the node grace period ID as some new grace
period to handle and will then start to hunt quiescent state.
But if every grace periods have already been completed, this
interpretation becomes broken. And we'll be stuck in clusters
of spurious softirqs because rcu_report_qs_rdp() will make
this broken state run into infinite loop.
The solution, as suggested by Lai Jiangshan, is to ensure that
the gpnum and completed fields are well synchronized when we catch
up with completed grace periods on their behalf by other cpus.
This way we won't start noting spurious new grace periods.
Suggested-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Steven Rostedt <rostedt@goodmis.org
When a CPU is idle and others CPUs handled its extended
quiescent state to complete grace periods on its behalf,
it will catch up with completed grace periods numbers
when it wakes up.
But at this point there might be no more grace period to
complete, but still the woken CPU always keeps its stale
qs_pending value and will then continue to chase quiescent
states even if its not needed anymore.
This results in clusters of spurious softirqs until a new
real grace period is started. Because if we continue to
chase quiescent states but we have completed every grace
periods, rcu_report_qs_rdp() is puzzled and makes that
state run into infinite loops.
As suggested by Lai Jiangshan, just reset qs_pending if
someone completed every grace periods on our behalf.
__get_cpu_var() can be replaced with this_cpu_read and will then use a
single read instruction with implied address calculation to access the
correct per cpu instance.
However, the address of a per cpu variable passed to __this_cpu_read()
cannot be determined (since it's an implied address conversion through
segment prefixes). Therefore apply this only to uses of __get_cpu_var
where the address of the variable is not used.
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Acked-by: H. Peter Anvin <hpa@zytor.com>
Signed-off-by: Christoph Lameter <cl@linux.com>
Lai's RCU-callback immediate-adoption patch changes the RCU tracing
output, so update tracing.txt. Also update a few comments to clarify
the synchronization design.
When we handle the CPU_DYING notifier, the whole system is stopped except
for the current CPU. We therefore need no synchronization with the other
CPUs. This allows us to move any orphaned RCU callbacks directly to the
list of any online CPU without needing to run them through the global
orphan lists. These global orphan lists can therefore be dispensed with.
This commit makes thes changes, though currently victimizes CPU 0 @@@.
Using ACCESS_ONCE() to observe the jiffies_stall/rnp->qsmask value
due to the caller didn't hold the root_rcu/rnp node's lock. Although
use without ACCESS_ONCE() is safe due to the value loaded being used
but once, the ACCESS_ONCE() is a good documentation aid -- the variables
are being loaded without the services of a lock.
Signed-off-by: Dongdong Deng <dongdong.deng@windriver.com>
CC: Dipankar Sarma <dipankar@in.ibm.com>
CC: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
The current tracing data is not sufficient to deduce the average time
that a callback spends waiting for a grace period to end. Add three
per-CPU counters recording the number of callbacks invoked (ci), the
number of callbacks orphaned (co), and the number of callbacks adopted
(ca). Given the existing callback queue length (ql), the average wait
time in absence of CPU hotplug operations is ql/ci. The units of wait
time will be in terms of the duration over which ci was measured.
In the presence of CPU hotplug operations, there is room for argument,
but ql/(ci-co+ca) won't steer you too far wrong.
Also fixes a typo called out by Lucas De Marchi <lucas.de.marchi@gmail.com>.
When using a kernel debugger, a long sojourn in the debugger can get
you lots of RCU CPU stall warnings once you resume. This might not be
helpful, especially if you are using the system console. This patch
therefore allows RCU CPU stall warnings to be suppressed, but only for
the duration of the current set of grace periods.
This differs from Jason's original patch in that it adds support for
tiny RCU and preemptible RCU, and uses a slightly different method for
suppressing the RCU CPU stall warning messages.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
Tested-by: Jason Wessel <jason.wessel@windriver.com>
There is some documentation on RCU CPU stall warnings contained in
Documentation/RCU/stallwarn.txt, but it will not be apparent to someone
who runs into such a warning while under time pressure. This commit
therefore adds comments preceding the printk()s pointing out the
location of this documentation.
