path: root/kernel/relay.c
2009-04-05Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (413 commits) tracing, net: fix net tree and tracing tree merge interaction tracing, powerpc: fix powerpc tree and tracing tree interaction ring-buffer: do not remove reader page from list on ring buffer free function-graph: allow unregistering twice trace: make argument 'mem' of trace_seq_putmem() const tracing: add missing 'extern' keywords to trace_output.h tracing: provide trace_seq_reserve() blktrace: print out BLK_TN_MESSAGE properly blktrace: extract duplidate code blktrace: fix memory leak when freeing struct blk_io_trace blktrace: fix blk_probes_ref chaos blktrace: make classic output more classic blktrace: fix off-by-one bug blktrace: fix the original blktrace blktrace: fix a race when creating blk_tree_root in debugfs blktrace: fix timestamp in binary output tracing, Text Edit Lock: cleanup tracing: filter fix for TRACE_EVENT_FORMAT events ftrace: Using FTRACE_WARN_ON() to check "freed record" in ftrace_release() x86: kretprobe-booster interrupt emulation code fix ... Fix up trivial conflicts in arch/parisc/include/asm/ftrace.h include/linux/memory.h kernel/extable.c kernel/module.c
2009-04-02relay: fix for possible loss/corruption of produced subbufsAravind Srinivasan
Fix possible loss/corruption of produced subbufs in relay_subbufs_consumed(). When buf->subbufs_produced wraps around after UINT_MAX and buf->subbufs_consumed is still < UINT_MAX, the condition if (buf->subbufs_consumed > buf->subbufs_produced) will be true even for certain valid values of subbufs_consumed. This may lead to loss or corruption of produced subbufs. Signed-off-by: Aravind Srinivasan <raa.aars@gmail.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02Merge branch 'tracing/core-v2' into tracing-for-linusIngo Molnar
Conflicts: include/linux/slub_def.h lib/Kconfig.debug mm/slob.c mm/slub.c
2009-02-18timers: add mod_timer_pending()Ingo Molnar
Impact: new timer API Based on an idea from Martin Josefsson with the help of Patrick McHardy and Stephen Hemminger: introduce the mod_timer_pending() API which is a mod_timer() offspring that is an invariant on already removed timers. (regular mod_timer() re-activates non-pending timers.) This is useful for the networking code in that it can allow unserialized mod_timer_pending() timer-forwarding calls, but a single del_timer*() will stop the timer from being reactivated again. Also while at it: - optimize the regular mod_timer() path some more, the timer-stat and a debug check was needlessly duplicated in __mod_timer(). - make the exports come straight after the function, as most other exports in timer.c already did. - eliminate __mod_timer() as an external API, change the users to mod_timer(). The regular mod_timer() code path is not impacted significantly, due to inlining optimizations and due to the simplifications. Based-on-patch-from: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Cc: netdev@vger.kernel.org Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-03Merge branches 'tracing/ftrace', 'tracing/kmemtrace' and 'linus' into ↵Ingo Molnar
tracing/core
2009-01-18relay: fix lock imbalance in relay_late_setup_filesJiri Slaby
One fail path in relay_late_setup_files() omits mutex_unlock(&relay_channels_mutex); Add it. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-30relayfs: replace BUG() with WARN_ON() in relay_late_setup_files()Ingo Molnar
Impact: turn boot crash into boot warning This BUG() can trigger: [ 16.684131] initcall fail_page_alloc_debugfs+0x0/0xc1 returned 0 after 0 usecs [ 16.692035] calling kmemtrace_setup_late+0x0/0xd5 @ 1 [ 16.700087] relay_late_setup_files: CPU 1 has no buffer, it must have! [ 16.704044] ------------[ cut here ]------------ [ 16.708030] kernel BUG at kernel/relay.c:680! [ 16.708030] invalid opcode: 0000 [#1] SMP DEBUG_PAGEALLOC [ 16.708030] last sysfs file: [ 16.708030] [ 16.708030] Pid: 1, comm: swapper Not tainted (2.6.28-tip-03903-g9a39f58-dirty #13207) System Product Name [ 16.708030] EIP: 0060:[<c01604ae>] EFLAGS: 00010246 CPU: 1 [ 16.708030] EIP is at relay_late_setup_files+0x8c/0x176 Reduce it to a more reportable WARN_ONCE(). Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-10relayfs: fix infinite loop with splice()Tom Zanussi
Running kmemtraced, which uses splice() on relayfs, causes a hard lock on x86-64 SMP. As described by Tom Zanussi: It looks like you hit the same problem as described here: commit 8191ecd1d14c6914c660dfa007154860a7908857 splice: fix infinite loop in generic_file_splice_read() relay uses the same loop but it never got noticed or fixed. Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Tested-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-18relay: fix cpu offline problemLai Jiangshan
relay_open() will close allocated buffers when failed. but if cpu offlined, some buffer will not be closed. this patch fixed it. and did cleanup for relay_reset() too. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-05relay: fix "full buffer with exactly full last subbuffer" accounting problemTom Zanussi
In relay's current read implementation, if the buffer is completely full but hasn't triggered the buffer-full condition (i.e. the last write didn't cross the subbuffer boundary) and the last subbuffer is exactly full, the subbuffer accounting code erroneously finds nothing available. This patch fixes the problem. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Mathieu Desnoyers <compudj@krystal.dyndns.org> Cc: Andrea Righi <righi.andrea@gmail.com> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26relay: add buffer-only channels; useful for early loggingEduard - Gabriel Munteanu
Allows one to create and use a channel with no associated files. Files can be initialized later. This is useful in scenarios such as logging in early code, before VFS is up. Therefore, such channels can be created and used as soon as kmem_cache_init() completed. This is needed by kmemtrace to do tracing in early kernel code. [kosaki.motohiro@jp.fujitsu.com: build fix] Signed-off-by: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-28splice: fix sendfile() issue with relayTom Zanussi
Splice isn't always incrementing the ppos correctly, which broke relay splice. Signed-off-by: Tom Zanussi <zanussi@comcast.net> Tested-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-05-08Revert "relay: fix splice problem"Jens Axboe
This reverts commit c3270e577c18b3d0e984c3371493205a4807db9d.
2008-04-29Merge branch 'for-linus' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/linux-2.6-block: block: Skip I/O merges when disabled block: add large command support block: replace sizeof(rq->cmd) with BLK_MAX_CDB ide: use blk_rq_init() to initialize the request block: use blk_rq_init() to initialize the request block: rename and export rq_init() block: no need to initialize rq->cmd with blk_get_request block: no need to initialize rq->cmd in prepare_flush_fn hook block/blk-barrier.c:blk_ordered_cur_seq() mustn't be inline block/elevator.c:elv_rq_merge_ok() mustn't be inline block: make queue flags non-atomic block: add dma alignment and padding support to blk_rq_map_kern unexport blk_max_pfn ps3disk: Remove superfluous cast block: make rq_init() do a full memset() relay: fix splice problem
2008-04-29relayfs: support larger relay bufferMasami Hiramatsu
Use vmalloc() and memset() instead of kcalloc() to allocate a page* array when the array size is bigger than one page. This enables relayfs to support bigger relay buffers than 64MB on 4k-page system, 512MB on 16k-page system. [akpm@linux-foundation.org: cleanup] Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: David Wilder <dwilder@us.ibm.com> Reviewed-by: Tom Zanussi <zanussi@comcast.net> Reviewed-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29relay: fix splice problemTom Zanussi
Splice isn't always incrementing the ppos correctly, which broke relay splice. Signed-off-by: Tom Zanussi <zanussi@comcast.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-26relay: set an spd_release() hook for spliceJens Axboe
relay doesn't reference the pages it adds, however we need a non-NULL hook or splice_to_pipe() can oops. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-26set relay file can not be read by pread(2)Lai Jiangshan
I found that relay files can be read by pread(2). I fix it, for relay files are not capable of seeking. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-03-17relay: fix subbuf_splice_actor() adding too many pagesJens Axboe
If subbuf_pages was larger than the max number of pages the pipe buffer will hold, subbuf_splice_actor() would happily go beyond the array size. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-02-06relay: nopageNick Piggin
Convert relay from nopage to fault. Remove redundant vma range checks. Switch from OOM to SIGBUS if the resource is not available. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-04vm audit: add VM_DONTEXPAND to mmap for drivers that need itNick Piggin
Drivers that register a ->fault handler, but do not range-check the offset argument, must set VM_DONTEXPAND in the vm_flags in order to prevent an expanding mremap from overflowing the resource. I've audited the tree and attempted to fix these problems (usually by adding VM_DONTEXPAND where it is not obvious). Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18whitespace fixes: relayfsDaniel Walker
Signed-off-by: Daniel Walker <dwalker@mvista.com> Cc: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31Fix a use after free bug in kernel->userspace relay file supportJesper Juhl
Coverity spotted what looks like a real possible case of using a variable after it has been freed. The problem is in kernel/relay.c::relay_open_buf() If the code hits "goto free_buf;" it ends up in this code : free_buf: relay_destroy_buf(buf); <--- calls kfree() on 'buf'. free_name: kfree(tmpname); end: return buf; <-- use after free of 'buf'. I read through the callers and they all handle a NULL return from this function as an error (and hitting the 'free_buf' label only happens on failure to chan->cb->create_buf_file(), so that looks like a clear error to me). The patch simply sets 'buf' to NULL after the call to relay_destroy_buf(buf); - as far as I can see that should take care of the problem. The patch also corrects a reference to a documentation file while I was at it. Note from Mathieu: the documentation reference change should have been done in a separate patch, but I guess no one will really care. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: "David J. Wilder" <wilder@us.ibm.com> Tested-by: "David J. Wilder" <wilder@us.ibm.com> Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Tom Zanussi <zanussi@us.ibm.com> Cc: Karim Yaghmour <karim@opersys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19kernel/relay.c: make functions staticAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-13relay: fixup kerneldoc commentTom Zanussi
Change comment from kerneldoc to normal. Signed-off-by: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-13relay: fix bogus cast in subbuf_splice_actor()Tom Zanussi
The current code that sets the read position in subbuf_splice_actor may give erroneous results if the buffer size isn't a power of 2. This patch fixes the problem. Signed-off-by: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10pipe: change the ->pin() operation to ->confirm()Jens Axboe
The name 'pin' was badly chosen, it doesn't pin a pipe buffer in the most commonly used sense in the kernel. So change the name to 'confirm', after debating this issue with Hugh Dickins a bit. A good return from ->confirm() means that the buffer is really there, and that the contents are good. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10relay: use splice_to_pipe() instead of open-coding the pipe loopJens Axboe
It cleans up the relay splice implementation a lot, and gets rid of a lot of internal pipe knowledge that should not be in there. Plus fixes for padding and partial first page (and lots more) from Tom Zanussi. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10splice: divorce the splice structure/function definitions from the pipe headerJens Axboe
We need to move even more stuff into the header so that folks can use the splice_to_pipe() implementation instead of open-coding a lot of pipe knowledge (see relay implementation), so move to our own header file finally. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10splice: relay supportTom Zanussi
2007-06-28relayfs: fix overwritesMasami Hiramatsu
When I use relayfs with "overwrite" mode, read() still sets incorrect number of consumed bytes. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Acked-by: Tom Zanussi <zanussi@us.ibm.com> Acked-by: David Wilder <dwilder@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-28relay file read: start-pos fixDavid Wilder
Fix a bug in the relay read interface causing the number of consumed bytes to be set incorrectly. Signed-off-by: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: David Wilder <dwilder@us.ibm.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (25 commits) sound: convert "sound" subdirectory to UTF-8 MAINTAINERS: Add cxacru website/mailing list include files: convert "include" subdirectory to UTF-8 general: convert "kernel" subdirectory to UTF-8 documentation: convert the Documentation directory to UTF-8 Convert the toplevel files CREDITS and MAINTAINERS to UTF-8. remove broken URLs from net drivers' output Magic number prefix consistency change to Documentation/magic-number.txt trivial: s/i_sem /i_mutex/ fix file specification in comments drivers/base/platform.c: fix small typo in doc misc doc and kconfig typos Remove obsolete fat_cvf help text Fix occurrences of "the the " Fix minor typoes in kernel/module.c Kconfig: Remove reference to external mqueue library Kconfig: A couple of grammatical fixes in arch/i386/Kconfig Correct comments in genrtc.c to refer to correct /proc file. Fix more "deprecated" spellos. Fix "deprecated" typoes. ... Fix trivial comment conflict in kernel/relay.c.
2007-05-09Add suspend-related notifications for CPU hotplugRafael J. Wysocki
Since nonboot CPUs are now disabled after tasks and devices have been frozen and the CPU hotplug infrastructure is used for this purpose, we need special CPU hotplug notifications that will help the CPU-hotplug-aware subsystems distinguish normal CPU hotplug events from CPU hotplug events related to a system-wide suspend or resume operation in progress. This patch introduces such notifications and causes them to be used during suspend and resume transitions. It also changes all of the CPU-hotplug-aware subsystems to take these notifications into consideration (for now they are handled in the same way as the corresponding "normal" ones). [oleg@tv-sign.ru: cleanups] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Cc: Gautham R Shenoy <ego@in.ibm.com> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09relay: use plain timer instead of delayed workTom Zanussi
relay doesn't need to use schedule_delayed_work() for waking readers when a simple timer will do. Signed-off-by: Tom Zanussi <zanussi@comcast.net> Cc: Satyam Sharma <satyam.sharma@gmail.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Fix occurrences of "the the "Michael Opdenacker
Signed-off-by: Michael Opdenacker <michael@free-electrons.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-03-01[PATCH] kernel-doc fixes for 2.6.20-git15 (non-drivers)Randy Dunlap
Fix kernel-doc warnings in 2.6.20-git15 (lib/, mm/, kernel/, include/). Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Numerous fixes to kernel-doc info in source files.Robert P. J. Day
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in source files, including: * make multi-line initial descriptions single line * denote some function names, constants and structs as such * change erroneous opening '/*' to '/**' in a few places * reword some text for clarity Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Relay: add CPU hotplug supportMathieu Desnoyers
Mathieu originally needed to add this for tracing Xen, but it's something that's needed for any application that can be tracing while cpus are added. unplug isn't supported by this patch. The thought was that at minumum a new buffer needs to be added when a cpu comes up, but it wasn't worth the effort to remove buffers on cpu down since they'd be freed soon anyway when the channel was closed. [zanussi@us.ibm.com: avoid lock_cpu_hotplug deadlock] Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-22[PATCH] relay: remove inliningAndrew Morton
text data bss dec hex filename before: 4036 44 0 4080 ff0 kernel/relay.o after: 3727 44 0 3771 ebb kernel/relay.o Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-22[PATCH] fix kernel-doc warnings in 2.6.20-rc1Randy Dunlap
Fix kernel-doc warnings in 2.6.20-rc1. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] Fix numerous kcalloc() calls, convert to kzalloc()Robert P. J. Day
All kcalloc() calls of the form "kcalloc(1,...)" are converted to the equivalent kzalloc() calls, and a few kcalloc() calls with the incorrect ordering of the first two arguments are fixed. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Jeff Garzik <jeff@garzik.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] kernel: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in linux/kernel/. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] struct seq_operations and struct file_operations constificationHelge Deller
- move some file_operations structs into the .rodata section - move static strings from policy_types[] array into the .rodata section - fix generic seq_operations usages, so that those structs may be defined as "const" as well [akpm@osdl.org: couple of fixes] Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-10[PATCH] make kernel/relay.c __user-cleanAl Viro
2006-09-29[PATCH] kernel-doc for relay interfaceRandy Dunlap
Add relay interface support to DocBook/kernel-api.tmpl. Fix typos etc. in relay.c and relayfs.txt. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] inode_diet: Replace inode.u.generic_ip with inode.i_privateTheodore Ts'o
The following patches reduce the size of the VFS inode structure by 28 bytes on a UP x86. (It would be more on an x86_64 system). This is a 10% reduction in the inode size on a UP kernel that is configured in a production mode (i.e., with no spinlock or other debugging functions enabled; if you want to save memory taken up by in-core inodes, the first thing you should do is disable the debugging options; they are responsible for a huge amount of bloat in the VFS inode structure). This patch: The filesystem or device-specific pointer in the inode is inside a union, which is pretty pointless given that all 30+ users of this field have been using the void pointer. Get rid of the union and rename it to i_private, with a comment to explain who is allowed to use the void pointer. This is just a cleanup, but it allows us to reuse the union 'u' for something something where the union will actually be used. [judith@osdl.org: powerpc build fix] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Judith Lebzelter <judith@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] relay: consolidate sendfile() and read() codeTom Zanussi
Signed-off-by: Jens Axboe <axboe@suse.de>
2006-03-23[PATCH] relay: add sendfile() supportJens Axboe
