path: root/kernel/res_counter.c
2009-01-08memcg: memory cgroup resource counters for hierarchyBalbir Singh
Add support for building hierarchies in resource counters. Cgroups allows us to build a deep hierarchy, but we currently don't link the resource counters belonging to the memory controller control groups, in the same fashion as the corresponding cgroup entries in the cgroup hierarchy. This patch provides the infrastructure for resource counters that have the same hiearchy as their cgroup counter parts. These set of patches are based on the resource counter hiearchy patches posted by Pavel Emelianov. NOTE: Building hiearchies is expensive, deeper hierarchies imply charging the all the way up to the root. It is known that hiearchies are expensive, so the user needs to be careful and aware of the trade-offs before creating very deep ones. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: YAMAMOTO Takashi <yamamoto@valinux.co.jp> Cc: Paul Menage <menage@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: David Rientjes <rientjes@google.com> Cc: Pavel Emelianov <xemul@openvz.org> Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25cgroup files: convert res_counter_write() to be a cgroups write_string() handlerPaul Menage
Currently res_counter_write() is a raw file handler even though it's ultimately taking a number, since in some cases it wants to pre-process the string when converting it to a number. This patch converts res_counter_write() from a raw file handler to a write_string() handler; this allows some of the boilerplate copying/locking/checking to be removed, and simplies the cleanup path, since these functions are now performed by the cgroups framework. [lizf@cn.fujitsu.com: build fix] Signed-off-by: Paul Menage <menage@google.com> Cc: Paul Jackson <pj@sgi.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29memcgroup: add the max_usage member on the res_counterPavel Emelyanov
This field is the maximal value of the usage one since the counter creation (or since the latest reset). To reset this to the usage value simply write anything to the appropriate cgroup file. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29CGroup API files: add res_counter_read_u64()Paul Menage
Adds a function for returning the value of a resource counter member, in a form suitable for use in a cgroup read_u64 control file method. Signed-off-by: Paul Menage <menage@google.com> Cc: "Li Zefan" <lizf@cn.fujitsu.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Paul Jackson <pj@sgi.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: "YAMAMOTO Takashi" <yamamoto@valinux.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29kernel: explicitly include required header files under kernel/Robert P. J. Day
Following an experimental deletion of the unnecessary directive #include <linux/slab.h> from the header file <linux/percpu.h>, these files under kernel/ were exposed as needing to include one of <linux/slab.h> or <linux/gfp.h>, so explicit includes were added where necessary. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04Memory Resource Controller use strstrip while parsing argumentsBalbir Singh
The memory controller has a requirement that while writing values, we need to use echo -n. This patch fixes the problem and makes the UI more consistent. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Memory controller improve user interfaceBalbir Singh
Change the interface to use bytes instead of pages. Page sizes can vary across platforms and configurations. A new strategy routine has been added to the resource counters infrastructure to format the data as desired. Suggested by David Rientjes, Andrew Morton and Herbert Poetzl Tested on a UML setup with the config for memory control enabled. [kamezawa.hiroyu@jp.fujitsu.com: possible race fix in res_counter] Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Pavel Emelianov <xemul@openvz.org> Cc: Paul Menage <menage@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Kirill Korotaev <dev@sw.ru> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: David Rientjes <rientjes@google.com> Cc: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Memory controller: resource countersPavel Emelianov
With fixes from David Rientjes <rientjes@google.com> Introduce generic structures and routines for resource accounting. Each resource accounting cgroup is supposed to aggregate it, cgroup_subsystem_state and its resource-specific members within. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Paul Menage <menage@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Kirill Korotaev <dev@sw.ru> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Vaidyanathan Srinivasan <svaidy@linux.vnet.ibm.com> Signed-off-by: David Rientjes <rientjes@google.com> Cc: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
