path: root/kernel/resource.c
2006-12-07[PATCH] struct seq_operations and struct file_operations constificationHelge Deller
- move some file_operations structs into the .rodata section - move static strings from policy_types[] array into the .rodata section - fix generic seq_operations usages, so that those structs may be defined as "const" as well [akpm@osdl.org: couple of fixes] Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] kernel-doc for kernel/resource.cRandy Dunlap
Add kernel-doc function headers in kernel/resource.c and use them in DocBook. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26Resources: insert identical resources above existing resourcesMatthew Wilcox
If you have two resources which aree exactly the same size, insert_resource() currently inserts the new one below the existing one. This is wrong because there's no way to insert a resource of the same size above an existing one. I took this opportunity to rewrite the initial loop to be a for-loop instead of a goto-loop and fix the documentation. Signed-off-by: Matthew Wilcox <matthew@wil.cx> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-06[PATCH] memory hotadd fixes: find_next_system_ram catch range fixKAMEZAWA Hiroyuki
find_next_system_ram() is used to find available memory resource at onlining newly added memory. This patch fixes following problem. find_next_system_ram() cannot catch this case. Resource: (start)-------------(end) Section : (start)-------------(end) Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Keith Mannthey <kmannth@gmail.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] memory hotadd fixes: change find_next_system_ram's return value mannerKAMEZAWA Hiroyuki
find_next_system_ram() returns valid memory range which meets requested area, only used by memory-hot-add. This function always rewrite requested resource even if returned area is not fully fit in requested one. And sometimes the returnd resource is larger than requested area. This annoyes the caller. This patch changes the returned value to fit in requested area. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Keith Mannthey <kmannth@gmail.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-12[PATCH] The scheduled unexport of insert_resourceAdrian Bunk
Implement the scheduled unexport of insert_resource. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-29Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: [PATCH] i386: export memory more than 4G through /proc/iomem [PATCH] 64bit Resource: finally enable 64bit resource sizes [PATCH] 64bit Resource: convert a few remaining drivers to use resource_size_t where needed [PATCH] 64bit resource: change pnp core to use resource_size_t [PATCH] 64bit resource: change pci core and arch code to use resource_size_t [PATCH] 64bit resource: change resource core to use resource_size_t [PATCH] 64bit resource: introduce resource_size_t for the start and end of struct resource [PATCH] 64bit resource: fix up printks for resources in misc drivers [PATCH] 64bit resource: fix up printks for resources in arch and core code [PATCH] 64bit resource: fix up printks for resources in pcmcia drivers [PATCH] 64bit resource: fix up printks for resources in video drivers [PATCH] 64bit resource: fix up printks for resources in ide drivers [PATCH] 64bit resource: fix up printks for resources in mtd drivers [PATCH] 64bit resource: fix up printks for resources in pci core and hotplug drivers [PATCH] 64bit resource: fix up printks for resources in networks drivers [PATCH] 64bit resource: fix up printks for resources in sound drivers [PATCH] 64bit resource: C99 changes for struct resource declarations Fixed up trivial conflict in drivers/ide/pci/cmd64x.c (the printk that was changed by the 64-bit resources had been deleted in the meantime ;)
2006-06-27[PATCH] catch valid mem range at onlining memoryKAMEZAWA Hiroyuki
This patch allows hot-add memory which is not aligned to section. Now, hot-added memory has to be aligned to section size. Considering big section sized archs, this is not useful. When hot-added memory is registerd as iomem resoruce by iomem resource patch, we can make use of that information to detect valid memory range. Note: With this, not-aligned memory can be registerd. To allow hot-add memory with holes, we have to do more work around add_memory(). (It doesn't allows add memory to already existing mem section.) Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] 64bit Resource: finally enable 64bit resource sizesGreg Kroah-Hartman
Introduce the Kconfig entry and actually switch to a 64bit value, if wanted, for resource_size_t. Based on a patch series originally from Vivek Goyal <vgoyal@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-27[PATCH] 64bit resource: change resource core to use resource_size_tGreg Kroah-Hartman
2006-06-27[PATCH] 64bit resource: fix up printks for resources in arch and core codeGreg Kroah-Hartman
This is needed if we wish to change the size of the resource structures. Based on an original patch from Vivek Goyal <vgoyal@in.ibm.com> and Andrew Morton. (tweaked by Andy Isaacson <adi@hexapodia.org>) Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Andy Isaacson <adi@hexapodia.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-10[PATCH] kernel/resource.c: __check_region(): remove pointless __deprecatedAdrian Bunk
If a __deprecated is desired it should go to the prototype in the header (where it currently isn't). But at this place it's pointless. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] introduce and use kzallocPekka J Enberg
This patch introduces a kzalloc wrapper and converts kernel/ to use it. It saves a little program text. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] Use ALIGN to remove duplicate codeNick Wilson
This patch makes use of ALIGN() to remove duplicate round-up code. Signed-off-by: Nick Wilson <njw@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] pci enumeration on ixp2000: overflow in kernel/resource.cLennert Buytenhek
IXP2000 (ARM-based) platforms use a separate 'struct resource' for PCI MEM space. Resource allocation for PCI BARs always fails because the 'root' resource (the IXP2000 PCI MEM resource) always has the entire address space (00000000-ffffffff) free, and find_resource() calculates the size of that range as ffffffff-00000000+1=0, so all allocations fail because it thinks there is no space. (akpm: pls. double-check) Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
