path: root/kernel/rtmutex-tester.c
2008-07-21sysdev: Pass the attribute to the low level sysdev show/store functionAndi Kleen
This allow to dynamically generate attributes and share show/store functions between attributes. Right now most attributes are generated by special macros and lots of duplicated code. With the attribute passed it's instead possible to attach some data to the attribute and then use that in shared low level functions to do different things. I need this for the dynamically generated bank attributes in the x86 machine check code, but it'll allow some further cleanups. I converted all users in tree to the new show/store prototype. It's a single huge patch to avoid unbisectable sections. Runtime tested: x86-32, x86-64 Compiled only: ia64, powerpc Not compile tested/only grep converted: sh, arm, avr32 Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Driver core: change sysdev classes to use dynamic kobject namesKay Sievers
All kobjects require a dynamically allocated name now. We no longer need to keep track if the name is statically assigned, we can just unconditionally free() all kobject names on cleanup. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-17Freezer: make kernel threads nonfreezable by defaultRafael J. Wysocki
Currently, the freezer treats all tasks as freezable, except for the kernel threads that explicitly set the PF_NOFREEZE flag for themselves. This approach is problematic, since it requires every kernel thread to either set PF_NOFREEZE explicitly, or call try_to_freeze(), even if it doesn't care for the freezing of tasks at all. It seems better to only require the kernel threads that want to or need to be frozen to use some freezer-related code and to remove any freezer-related code from the other (nonfreezable) kernel threads, which is done in this patch. The patch causes all kernel threads to be nonfreezable by default (ie. to have PF_NOFREEZE set by default) and introduces the set_freezable() function that should be called by the freezable kernel threads in order to unset PF_NOFREEZE. It also makes all of the currently freezable kernel threads call set_freezable(), so it shouldn't cause any (intentional) change of behaviour to appear. Additionally, it updates documentation to describe the freezing of tasks more accurately. [akpm@linux-foundation.org: build fixes] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Pavel Machek <pavel@ucw.cz> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] Add include/linux/freezer.h and move definitions from sched.hNigel Cunningham
Move process freezing functions from include/linux/sched.h to freezer.h, so that modifications to the freezer or the kernel configuration don't require recompiling just about everything. [akpm@osdl.org: fix ueagle driver] Signed-off-by: Nigel Cunningham <nigel@suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04Remove all inclusions of <linux/config.h>Dave Jones
kbuild explicitly includes this at build time. Signed-off-by: Dave Jones <davej@redhat.com>
2006-07-14[PATCH] Add try_to_freeze() to rt-test kthreadsLuca Tettamanti
When CONFIG_RT_MUTEX_TESTER is enabled kernel refuses to suspend the machine because it's unable to freeze the rt-test-* threads. Add try_to_freeze() after schedule() so that the threads will be freezed correctly; I've tested the patch and it lets the notebook suspends and resumes nicely. Signed-off-by: Luca Tettamanti <kronos.it@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] sched: cleanup, remove task_t, convert to struct task_structIngo Molnar
cleanup: remove task_t and convert all the uses to struct task_struct. I introduced it for the scheduler anno and it was a mistake. Conversion was mostly scripted, the result was reviewed and all secondary whitespace and style impact (if any) was fixed up by hand. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] rtmutex: Modify rtmutex-tester to test the setscheduler propagationThomas Gleixner
Make test suite setscheduler calls asynchronously. Remove the waits in the test cases and add a new testcase to verify the correctness of the setscheduler priority propagation. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] pi-futex: rt mutex testerThomas Gleixner
RT-mutex tester: scriptable tester for rt mutexes, which allows userspace scripting of mutex unit-tests (and dynamic tests as well), using the actual rt-mutex implementation of the kernel. [akpm@osdl.org: fixlet] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
