path: root/kernel/rtmutex.h
2014-07-16rtmutex: Handle deadlock detection smarterThomas Gleixner
commit 3d5c9340d1949733eb37616abd15db36aef9a57c upstream. Even in the case when deadlock detection is not requested by the caller, we can detect deadlocks. Right now the code stops the lock chain walk and keeps the waiter enqueued, even on itself. Silly not to yell when such a scenario is detected and to keep the waiter enqueued. Return -EDEADLK unconditionally and handle it at the call sites. The futex calls return -EDEADLK. The non futex ones dequeue the waiter, throw a warning and put the task into a schedule loop. Tagged for stable as it makes the code more robust. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Brad Mouring <bmouring@ni.com> Link: http://lkml.kernel.org/r/20140605152801.836501969@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Mike Galbraith <umgwanakikbuti@gmail.com> Signed-off-by: Jiri Slaby <jslaby@suse.cz>
2006-07-03[PATCH] lockdep: better lock debuggingIngo Molnar
Generic lock debugging: - generalized lock debugging framework. For example, a bug in one lock subsystem turns off debugging in all lock subsystems. - got rid of the caller address passing (__IP__/__IP_DECL__/etc.) from the mutex/rtmutex debugging code: it caused way too much prototype hackery, and lockdep will give the same information anyway. - ability to do silent tests - check lock freeing in vfree too. - more finegrained debugging options, to allow distributions to turn off more expensive debugging features. There's no separate 'held mutexes' list anymore - but there's a 'held locks' stack within lockdep, which unifies deadlock detection across all lock classes. (this is independent of the lockdep validation stuff - lockdep first checks whether we are holding a lock already) Here are the current debugging options: CONFIG_DEBUG_MUTEXES=y CONFIG_DEBUG_LOCK_ALLOC=y which do: config DEBUG_MUTEXES bool "Mutex debugging, basic checks" config DEBUG_LOCK_ALLOC bool "Detect incorrect freeing of live mutexes" Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-27[PATCH] pi-futex: rt mutex coreIngo Molnar
Core functions for the rt-mutex subsystem. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
