wake_up_process() should be never used to wakeup a TASK_STOPPED/TRACED task
CVE-2013-0871
BugLink: http://bugs.launchpad.net/bugs/1129192
wake_up_process() should never wakeup a TASK_STOPPED/TRACED task.
Change it to use TASK_NORMAL and add the WARN_ON().
TASK_ALL has no other users, probably can be killed.
(backported from commit 9067ac85d533651b98c2ff903182a20cbb361fcb)
kernel/sched/core.c
Signed-off-by: Luis Henriques <luis.henriques@canonical.com>
Acked-by: Colin King <colin.king@canonical.com>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Signed-off-by: Willy Tarreau <w@1wt.eu>
commit 868baf07b1a259f5f3803c1dc2777b6c358f83cf upstream.
When the fuction graph tracer starts, it needs to make a special
stack for each task to save the real return values of the tasks.
All running tasks have this stack created, as well as any new
tasks.
On CPU hot plug, the new idle task will allocate a stack as well
when init_idle() is called. The problem is that cpu hotplug does
not create a new idle_task. Instead it uses the idle task that
existed when the cpu went down.
ftrace_graph_init_task() will add a new ret_stack to the task
that is given to it. Because a clone will make the task
have a stack of its parent it does not check if the task's
ret_stack is already NULL or not. When the CPU hotplug code
starts a CPU up again, it will allocate a new stack even
though one already existed for it.
The solution is to treat the idle_task specially. In fact, the
function_graph code already does, just not at init_idle().
Instead of using the ftrace_graph_init_task() for the idle task,
which that function expects the task to be a clone, have a
separate ftrace_graph_init_idle_task(). Also, we will create a
per_cpu ret_stack that is used by the idle task. When we call
ftrace_graph_init_idle_task() it will check if the idle task's
ret_stack is NULL, if it is, then it will assign it the per_cpu
ret_stack.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Suggested-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Commit: e51fd5e22e12b39f49b1bb60b37b300b17378a43 upstream
Mike reports that since e9e9250b (sched: Scale down cpu_power due to RT
tasks), wake_affine() goes funny on RT tasks due to them still having a
!0 weight and wake_affine() still subtracts that from the rq weight.
Since nobody should be using se->weight for RT tasks, set the value to
zero. Also, since we now use ->cpu_power to normalize rq weights to
account for RT cpu usage, add that factor into the imbalance computation.
Reported-by: Mike Galbraith <efault@gmx.de>
Tested-by: Mike Galbraith <efault@gmx.de>
LKML-Reference: <1275316109.27810.22969.camel@twins>
Signed-off-by: Mike Galbraith <efault@gmx.de>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Commit: d5ad140bc1505a98c0f040937125bfcbb508078f upstream
An earlier commit reverts idle balancing throttling reset to fix a 30%
regression in volanomark throughput. We still need to reset idle_stamp
when we pull a task in newidle balance.
Reported-by: Alex Shi <alex.shi@intel.com>
Signed-off-by: Nikhil Rao <ncrao@google.com>
LKML-Reference: <1290022924-3548-1-git-send-email-ncrao@google.com>
Commit: b5482cfa1c95a188b3054fa33274806add91bbe5 upstream
Commit fab4762 triggers excessive idle balancing, causing a ~30% loss in
volanomark throughput. Remove idle balancing throttle reset.
Originally-by: Alex Shi <alex.shi@intel.com>
Acked-by: Nikhil Rao <ncrao@google.com>
LKML-Reference: <1289928732.5169.211.camel@maggy.simson.net>
Commit: 1e5a74059f9059d330744eac84873b1b99657008 upstream
Instead of dealing with sched classes inside each check_preempt_curr()
implementation, pull out this logic into the generic wakeup preemption
path.
This fixes a hang in KVM (and others) where we are waiting for the
stop machine thread to run ...
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Tested-by: Marcelo Tosatti <mtosatti@redhat.com>
Tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
LKML-Reference: <1288891946.2039.31.camel@laptop>
Commit: aae6d3ddd8b90f5b2c8d79a2b914d1706d124193 upstream
Currently we consider a sched domain to be well balanced when the imbalance
is less than the domain's imablance_pct. As the number of cores and threads
are increasing, current values of imbalance_pct (for example 25% for a
NUMA domain) are not enough to detect imbalances like:
a) On a WSM-EP system (two sockets, each having 6 cores and 12 logical threads),
24 cpu-hogging tasks get scheduled as 13 on one socket and 11 on another
socket. Leading to an idle HT cpu.
b) On a hypothetial 2 socket NHM-EX system (each socket having 8 cores and
16 logical threads), 16 cpu-hogging tasks can get scheduled as 9 on one
socket and 7 on another socket. Leaving one core in a socket idle
whereas in another socket we have a core having both its HT siblings busy.
While this issue can be fixed by decreasing the domain's imbalance_pct
(by making it a function of number of logical cpus in the domain), it
can potentially cause more task migrations across sched groups in an
overloaded case.
Fix this by using imbalance_pct only during newly_idle and busy
load balancing. And during idle load balancing, check if there
is an imbalance in number of idle cpu's across the busiest and this
sched_group or if the busiest group has more tasks than its weight that
the idle cpu in this_group can pull.
Reported-by: Nikhil Rao <ncrao@google.com>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <1284760952.2676.11.camel@sbsiddha-MOBL3.sc.intel.com>
Commit: b2b5ce022acf5e9f52f7b78c5579994fdde191d4 upstream
Dima noticed that we fail to correct the ->vruntime of sleeping tasks
when we move them between cgroups.
Reported-by: Dima Zavin <dima@android.com>
LKML-Reference: <1287150604.29097.1513.camel@twins>
Commit: b7dadc38797584f6203386da1947ed5edf516646 upstream
KVM uses it for example:
ERROR: "account_system_vtime" [arch/x86/kvm/kvm.ko] undefined!
Cc: Venkatesh Pallipadi <venki@google.com>
LKML-Reference: <1286237003-12406-3-git-send-email-venki@google.com>
Commit: d267f87fb8179c6dba03d08b91952e81bc3723c7 upstream
When CPU is idle and on first interrupt, irq_enter calls tick_check_idle()
to notify interruption from idle. But, there is a problem if this call
is done after __irq_enter, as all routines in __irq_enter may find
stale time due to yet to be done tick_check_idle.
Specifically, trace calls in __irq_enter when they use global clock and also
account_system_vtime change in this patch as it wants to use sched_clock_cpu()
to do proper irq timing.
But, tick_check_idle was moved after __irq_enter intentionally to
prevent problem of unneeded ksoftirqd wakeups by the commit ee5f80a:
irq: call __irq_enter() before calling the tick_idle_check
Impact: avoid spurious ksoftirqd wakeups
Moving tick_check_idle() before __irq_enter and wrapping it with
local_bh_enable/disable would solve both the problems.
Fixed-by: Yong Zhang <yong.zhang0@gmail.com>
Signed-off-by: Venkatesh Pallipadi <venki@google.com>
LKML-Reference: <1286237003-12406-9-git-send-email-venki@google.com>
Commit: aa483808516ca5cacfa0e5849691f64fec25828e upstream
The idea was suggested by Peter Zijlstra here:
http://marc.info/?l=linux-kernel&m=127476934517534&w=2
irq time is technically not available to the tasks running on the CPU.
This patch removes irq time from CPU power piggybacking on
sched_rt_avg_update().
Tested this by keeping CPU X busy with a network intensive task having 75%
oa a single CPU irq processing (hard+soft) on a 4-way system. And start seven
cycle soakers on the system. Without this change, there will be two tasks on
each CPU. With this change, there is a single task on irq busy CPU X and
remaining 7 tasks are spread around among other 3 CPUs.
LKML-Reference: <1286237003-12406-8-git-send-email-venki@google.com>
Commit: 305e6835e05513406fa12820e40e4a8ecb63743c upstream
Scheduler accounts both softirq and interrupt processing times to the
currently running task. This means, if the interrupt processing was
for some other task in the system, then the current task ends up being
penalized as it gets shorter runtime than otherwise.
Change sched task accounting to acoount only actual task time from
currently running task. Now update_curr(), modifies the delta_exec to
depend on rq->clock_task.
Note that this change only handles CONFIG_IRQ_TIME_ACCOUNTING case. We can
extend this to CONFIG_VIRT_CPU_ACCOUNTING with minimal effort. But, thats
for later.
This change will impact scheduling behavior in interrupt heavy conditions.
Tested on a 4-way system with eth0 handled by CPU 2 and a network heavy
task (nc) running on CPU 3 (and no RSS/RFS). With that I have CPU 2
spending 75%+ of its time in irq processing. CPU 3 spending around 35%
time running nc task.
Now, if I run another CPU intensive task on CPU 2, without this change
/proc/<pid>/schedstat shows 100% of time accounted to this task. With this
change, it rightly shows less than 25% accounted to this task as remaining
time is actually spent on irq processing.
LKML-Reference: <1286237003-12406-7-git-send-email-venki@google.com>
Commit: b52bfee445d315549d41eacf2fa7c156e7d153d5 upstream
s390/powerpc/ia64 have support for CONFIG_VIRT_CPU_ACCOUNTING which does
the fine granularity accounting of user, system, hardirq, softirq times.
Adding that option on archs like x86 will be challenging however, given the
state of TSC reliability on various platforms and also the overhead it will
add in syscall entry exit.
Instead, add a lighter variant that only does finer accounting of
hardirq and softirq times, providing precise irq times (instead of timer tick
based samples). This accounting is added with a new config option
CONFIG_IRQ_TIME_ACCOUNTING so that there won't be any overhead for users not
interested in paying the perf penalty.
This accounting is based on sched_clock, with the code being generic.
So, other archs may find it useful as well.
This patch just adds the core logic and does not enable this logic yet.
LKML-Reference: <1286237003-12406-5-git-send-email-venki@google.com>
Commit: 75e1056f5c57050415b64cb761a3acc35d91f013 upstream
Peter Zijlstra found a bug in the way softirq time is accounted in
VIRT_CPU_ACCOUNTING on this thread:
http://lkml.indiana.edu/hypermail//linux/kernel/1009.2/01366.html
The problem is, softirq processing uses local_bh_disable internally. There
is no way, later in the flow, to differentiate between whether softirq is
being processed or is it just that bh has been disabled. So, a hardirq when bh
is disabled results in time being wrongly accounted as softirq.
Looking at the code a bit more, the problem exists in !VIRT_CPU_ACCOUNTING
as well. As account_system_time() in normal tick based accouting also uses
softirq_count, which will be set even when not in softirq with bh disabled.
Peter also suggested solution of using 2*SOFTIRQ_OFFSET as irq count
for local_bh_{disable,enable} and using just SOFTIRQ_OFFSET while softirq
processing. The patch below does that and adds API in_serving_softirq() which
returns whether we are currently processing softirq or not.
Also changes one of the usages of softirq_count in net/sched/cls_cgroup.c
to in_serving_softirq.
Looks like many usages of in_softirq really want in_serving_softirq. Those
changes can be made individually on a case by case basis.
LKML-Reference: <1286237003-12406-2-git-send-email-venki@google.com>
Commit: 75dd321d79d495a0ee579e6249ebc38ddbb2667f upstream
When SD_PREFER_SIBLING is set on a sched domain, drop group_capacity to 1
only if the local group has extra capacity. The extra check prevents the case
where you always pull from the heaviest group when it is already under-utilized
(possible with a large weight task outweighs the tasks on the system).
For example, consider a 16-cpu quad-core quad-socket machine with MC and NUMA
scheduling domains. Let's say we spawn 15 nice0 tasks and one nice-15 task,
and each task is running on one core. In this case, we observe the following
events when balancing at the NUMA domain:
- find_busiest_group() will always pick the sched group containing the niced
task to be the busiest group.
- find_busiest_queue() will then always pick one of the cpus running the
nice0 task (never picks the cpu with the nice -15 task since
weighted_cpuload > imbalance).
- The load balancer fails to migrate the task since it is the running task
and increments sd->nr_balance_failed.
- It repeats the above steps a few more times until sd->nr_balance_failed > 5,
at which point it kicks off the active load balancer, wakes up the migration
thread and kicks the nice 0 task off the cpu.
The load balancer doesn't stop until we kick out all nice 0 tasks from
the sched group, leaving you with 3 idle cpus and one cpu running the
nice -15 task.
When balancing at the NUMA domain, we drop sgs.group_capacity to 1 if the child
domain (in this case MC) has SD_PREFER_SIBLING set. Subsequent load checks are
not relevant because the niced task has a very large weight.
In this patch, we add an extra condition to the "if(prefer_sibling)" check in
update_sd_lb_stats(). We drop the capacity of a group only if the local group
has extra capacity, ie. nr_running < group_capacity. This patch preserves the
original intent of the prefer_siblings check (to spread tasks across the system
in low utilization scenarios) and fixes the case above.
It helps in the following ways:
- In low utilization cases (where nr_tasks << nr_cpus), we still drop
group_capacity down to 1 if we prefer siblings.
- On very busy systems (where nr_tasks >> nr_cpus), sgs.nr_running will most
likely be > sgs.group_capacity.
- When balancing large weight tasks, if the local group does not have extra
capacity, we do not pick the group with the niced task as the busiest group.
This prevents failed balances, active migration and the under-utilization
described above.
LKML-Reference: <1287173550-30365-5-git-send-email-ncrao@google.com>
Commit: fab476228ba37907ad75216d0fd9732ada9c119e upstream
This patch forces a load balance on a newly idle cpu when the local group has
extra capacity and the busiest group does not have any. It improves system
utilization when balancing tasks with a large weight differential.
Under certain situations, such as a niced down task (i.e. nice = -15) in the
presence of nr_cpus NICE0 tasks, the niced task lands on a sched group and
kicks away other tasks because of its large weight. This leads to sub-optimal
utilization of the machine. Even though the sched group has capacity, it does
not pull tasks because sds.this_load >> sds.max_load, and f_b_g() returns NULL.
With this patch, if the local group has extra capacity, we shortcut the checks
in f_b_g() and try to pull a task over. A sched group has extra capacity if the
group capacity is greater than the number of running tasks in that group.
Thanks to Mike Galbraith for discussions leading to this patch and for the
insight to reuse SD_NEWIDLE_BALANCE.
LKML-Reference: <1287173550-30365-4-git-send-email-ncrao@google.com>
Commit: 2582f0eba54066b5e98ff2b27ef0cfa833b59f54 upstream
When cycling through sched groups to determine the busiest group, set
group_imb only if the busiest cpu has more than 1 runnable task. This patch
fixes the case where two cpus in a group have one runnable task each, but there
is a large weight differential between these two tasks. The load balancer is
unable to migrate any task from this group, and hence do not consider this
group to be imbalanced.
LKML-Reference: <1286996978-7007-3-git-send-email-ncrao@google.com>
[ small code readability edits ]
Commit: ef8002f6848236de5adc613063ebeabddea8a6fb upstream
This patch adds a check in task_hot to return if the task has SCHED_IDLE
policy. SCHED_IDLE tasks have very low weight, and when run with regular
workloads, are typically scheduled many milliseconds apart. There is no
need to consider these tasks hot for load balancing.
LKML-Reference: <1287173550-30365-2-git-send-email-ncrao@google.com>
Commit: 6506cf6ce68d78a5470a8360c965dafe8e4b78e3 upstream
This addresses the following RCU lockdep splat:
[0.051203] CPU0: AMD QEMU Virtual CPU version 0.12.4 stepping 03
[0.052999] lockdep: fixing up alternatives.
[0.054105]
[0.054106] ===================================================
[0.054999] [ INFO: suspicious rcu_dereference_check() usage. ]
[0.054999] ---------------------------------------------------
[0.054999] kernel/sched.c:616 invoked rcu_dereference_check() without protection!
[0.054999]
[0.054999] other info that might help us debug this:
[0.054999]
[0.054999]
[0.054999] rcu_scheduler_active = 1, debug_locks = 1
[0.054999] 3 locks held by swapper/1:
[0.054999] #0: (cpu_add_remove_lock){+.+.+.}, at: [<ffffffff814be933>] cpu_up+0x42/0x6a
[0.054999] #1: (cpu_hotplug.lock){+.+.+.}, at: [<ffffffff810400d8>] cpu_hotplug_begin+0x2a/0x51
[0.054999] #2: (&rq->lock){-.-...}, at: [<ffffffff814be2f7>] init_idle+0x2f/0x113
[0.054999]
[0.054999] stack backtrace:
[0.054999] Pid: 1, comm: swapper Not tainted 2.6.35 #1
[0.054999] Call Trace:
[0.054999] [<ffffffff81068054>] lockdep_rcu_dereference+0x9b/0xa3
[0.054999] [<ffffffff810325c3>] task_group+0x7b/0x8a
[0.054999] [<ffffffff810325e5>] set_task_rq+0x13/0x40
[0.054999] [<ffffffff814be39a>] init_idle+0xd2/0x113
[0.054999] [<ffffffff814be78a>] fork_idle+0xb8/0xc7
[0.054999] [<ffffffff81068717>] ? mark_held_locks+0x4d/0x6b
[0.054999] [<ffffffff814bcebd>] do_fork_idle+0x17/0x2b
[0.054999] [<ffffffff814bc89b>] native_cpu_up+0x1c1/0x724
[0.054999] [<ffffffff814bcea6>] ? do_fork_idle+0x0/0x2b
[0.054999] [<ffffffff814be876>] _cpu_up+0xac/0x127
[0.054999] [<ffffffff814be946>] cpu_up+0x55/0x6a
[0.054999] [<ffffffff81ab562a>] kernel_init+0xe1/0x1ff
[0.054999] [<ffffffff81003854>] kernel_thread_helper+0x4/0x10
[0.054999] [<ffffffff814c353c>] ? restore_args+0x0/0x30
[0.054999] [<ffffffff81ab5549>] ? kernel_init+0x0/0x1ff
[0.054999] [<ffffffff81003850>] ? kernel_thread_helper+0x0/0x10
[0.056074] Booting Node 0, Processors #1lockdep: fixing up alternatives.
[0.130045] #2lockdep: fixing up alternatives.
[0.203089] #3 Ok.
[0.275286] Brought up 4 CPUs
[0.276005] Total of 4 processors activated (16017.17 BogoMIPS).
The cgroup_subsys_state structures referenced by idle tasks are never
freed, because the idle tasks should be part of the root cgroup,
which is not removable.
The problem is that while we do in-fact hold rq->lock, the newly spawned
idle thread's cpu is not yet set to the correct cpu so the lockdep check
in task_group():
lockdep_is_held(&task_rq(p)->lock)
will fail.
But this is a chicken and egg problem. Setting the CPU's runqueue requires
that the CPU's runqueue already be set. ;-)
So insert an RCU read-side critical section to avoid the complaint.
Commit: 58b26c4c025778c09c7a1438ff185080e11b7d0a upstream
scheduler uses cache_nice_tries as an indicator to do cache_hot and
active load balance, when normal load balance fails. Currently,
this value is changed on any failed load balance attempt. That ends
up being not so nice to workloads that enter/exit idle often, as
they do more frequent new_idle balance and that pretty soon results
in cache hot tasks being pulled in.
Making the cache_nice_tries ignore failed new_idle balance seems to
make better sense. With that only the failed load balance in
periodic load balance gets accounted and the rate of accumulation
of cache_nice_tries will not depend on idle entry/exit (short
running sleep-wakeup kind of tasks). This reduces movement of
cache_hot tasks.
schedstat diff (after-before) excerpt from a workload that has
frequent and short wakeup-idle pattern (:2 in cpu col below refers
to NEWIDLE idx) This snapshot was across ~400 seconds.
Without this change:
domainstats: domain0
cpu cnt bln fld imb gain hgain nobusyq nobusyg
0:2 306487 219575 73167 110069413 44583 19070 1172 218403
1:2 292139 194853 81421 120893383 50745 21902 1259 193594
2:2 283166 174607 91359 129699642 54931 23688 1287 173320
3:2 273998 161788 93991 132757146 57122 24351 1366 160422
4:2 289851 215692 62190 83398383 36377 13680 851 214841
5:2 316312 222146 77605 117582154 49948 20281 988 221158
6:2 297172 195596 83623 122133390 52801 21301 929 194667
7:2 283391 178078 86378 126622761 55122 22239 928 177150
8:2 297655 210359 72995 110246694 45798 19777 1125 209234
9:2 297357 202011 79363 119753474 50953 22088 1089 200922
10:2 278797 178703 83180 122514385 52969 22726 1128 177575
11:2 272661 167669 86978 127342327 55857 24342 1195 166474
12:2 293039 204031 73211 110282059 47285 19651 948 203083
13:2 289502 196762 76803 114712942 49339 20547 1016 195746
14:2 264446 169609 78292 115715605 50459 21017 982 168627
15:2 260968 163660 80142 116811793 51483 21281 1064 162596
With this change:
0:2 272347 187380 77455 105420270 24975 1 953 186427
1:2 267276 172360 86234 116242264 28087 6 1028 171332
2:2 259769 156777 93281 123243134 30555 1 1043 155734
3:2 250870 143129 97627 127370868 32026 6 1188 141941
4:2 248422 177116 64096 78261112 22202 2 757 176359
5:2 275595 180683 84950 116075022 29400 6 778 179905
6:2 262418 162609 88944 119256898 31056 4 817 161792
7:2 252204 147946 92646 122388300 32879 4 824 147122
8:2 262335 172239 81631 110477214 26599 4 864 171375
9:2 261563 164775 88016 117203621 28331 3 849 163926
10:2 243389 140949 93379 121353071 29585 2 909 140040
11:2 242795 134651 98310 124768957 30895 2 1016 133635
12:2 255234 166622 79843 104696912 26483 4 746 165876
13:2 244944 151595 83855 109808099 27787 3 801 150794
14:2 241301 140982 89935 116954383 30403 6 845 140137
15:2 232271 128564 92821 119185207 31207 4 1416 127148
LKML-Reference: <1284167957-3675-1-git-send-email-venki@google.com>
Commit: da2b71edd8a7db44fe1746261410a981f3e03632 upstream
Currently sched_avg_update() (which updates rt_avg stats in the rq)
is getting called from scale_rt_power() (in the load balance context)
which doesn't take rq->lock.
Fix it by moving the sched_avg_update() to more appropriate
update_cpu_load() where the CFS load gets updated as well.
LKML-Reference: <1282596171.2694.3.camel@sbsiddha-MOBL3>
Commit: 7c9414385ebfdd87cc542d4e7e3bb0dbb2d3ce25 upstream
Remove the USER_SCHED feature. It has been scheduled to be removed in
2.6.34 as per http://marc.info/?l=linux-kernel&m=125728479022976&w=2
[trace from referenced thread]
[1046577.884289] general protection fault: 0000 [#1] SMP
[1046577.911332] last sysfs file: /sys/devices/platform/coretemp.7/temp1_input
[1046577.938715] CPU 3
[1046577.965814] Modules linked in: ipt_REJECT xt_tcpudp iptable_filter ip_tables x_tables coretemp k8temp
[1046577.994456] Pid: 38, comm: events/3 Not tainted 2.6.32.27intel #1 X8DT3
[1046578.023166] RIP: 0010:[] [] sched_destroy_group+0x3c/0x10d
[1046578.052639] RSP: 0000:ffff88043e5abe10 EFLAGS: 00010097
[1046578.081360] RAX: ffff880139fa5540 RBX: ffff8803d18419c0 RCX: ffff8801d2f8fb78
[1046578.109903] RDX: dead000000200200 RSI: 0000000000000000 RDI: 0000000000000000
[1046578.109905] RBP: 0000000000000246 R08: 0000000000000020 R09: ffffffff816339b8
[1046578.109907] R10: 0000000004e6e5f0 R11: 0000000000000006 R12: ffffffff816339b8
[1046578.109909] R13: ffff8803d63ac4e0 R14: ffff88043e582340 R15: ffffffff8104a216
[1046578.109911] FS: 0000000000000000(0000) GS:ffff880028260000(0000) knlGS:0000000000000000
[1046578.109914] CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
[1046578.109915] CR2: 00007f55ab220000 CR3: 00000001e5797000 CR4: 00000000000006e0
[1046578.109917] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[1046578.109919] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[1046578.109922] Process events/3 (pid: 38, threadinfo ffff88043e5aa000, task ffff88043e582340)
[1046578.109923] Stack:
[1046578.109924] ffff8803d63ac498 ffff8803d63ac4d8 ffff8803d63ac440 ffffffff8104a2c3
[1046578.109927] <0> ffff88043e5abef8 ffff880028276040 ffff8803d63ac4d8 ffffffff81050395
[1046578.109929] <0> ffff88043e582340 ffff88043e5826c8 ffff88043e582340 ffff88043e5abfd8
[1046578.109932] Call Trace:
[1046578.109938] [] ? cleanup_user_struct+0xad/0xcc
[1046578.109942] [] ? worker_thread+0x148/0x1d4
[1046578.109946] [] ? autoremove_wake_function+0x0/0x2e
[1046578.109948] [] ? worker_thread+0x0/0x1d4
[1046578.109951] [] ? kthread+0x79/0x81
[1046578.109955] [] ? child_rip+0xa/0x20
[1046578.109957] [] ? kthread+0x0/0x81
[1046578.109959] [] ? child_rip+0x0/0x20
[1046578.109961] Code: 3c 00 4c 8b 25 02 98 3d 00 48 89 c5 83 cf ff eb 5c 48 8b 43 10 48 63 f7 48 8b 04 f0 48 8b 90 80 00 00 00 48 8b 48 78 48 89 51 08 <48> 89 0a 48 b9 00 02 20 00 00 00 ad de 48 89 88 80 00 00 00 48
[1046578.109975] RIP [] sched_destroy_group+0x3c/0x10d
[1046578.109979] RSP
[1046578.109981] ---[ end trace 5ebc2944b7872d4a ]---
Signed-off-by: Dhaval Giani <dhaval.giani@gmail.com>
LKML-Reference: <1263990378.24844.3.camel@localhost>
LKML-Reference: http://marc.info/?l=linux-kernel&m=129466345327931
commit 7740191cd909b75d75685fb08a5d1f54b8a9d28b upstream.
Fix incorrect handling of the following case:
INTERACTIVE
INTERACTIVE_SOMETHING_ELSE
The comparison only checks up to each element's length.
Changelog since v1:
- Embellish using some Rostedtisms.
[ mingo: ^^ == smaller and cleaner ]
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Tony Lindgren <tony@atomide.com>
LKML-Reference: <20100913214700.GB16118@Krystal>
[Not upstream in the same way, as it was fixed differently there]
6f6198a sched: kill migration thread in CPU_POST_DEAD instead of CPU_DEAD
leaves migration threads lying about. Mask out CPU_TASKS_FROZEN.
commit e75e863dd5c7d96b91ebbd241da5328fc38a78cc upstream.
We have 32-bit variable overflow possibility when multiply in
task_times() and thread_group_times() functions. When the
overflow happens then the scaled utime value becomes erroneously
small and the scaled stime becomes i erroneously big.
Reported here:
https://bugzilla.redhat.com/show_bug.cgi?id=633037
https://bugzilla.kernel.org/show_bug.cgi?id=16559
Reported-by: Michael Chapman <redhat-bugzilla@very.puzzling.org>
Reported-by: Ciriaco Garcia de Celis <sysman@etherpilot.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
LKML-Reference: <20100914143513.GB8415@redhat.com>
commit fa535a77bd3fa32b9215ba375d6a202fe73e1dd6 upstream
When CONFIG_VIRT_CPU_ACCOUNTING and CONFIG_CGROUP_CPUACCT are
enabled we can call cpuacct_update_stats with values much larger
than percpu_counter_batch. This means the call to
percpu_counter_add will always add to the global count which is
protected by a spinlock and we end up with a global spinlock in
the scheduler.
Based on an idea by KOSAKI Motohiro, this patch scales the batch
value by cputime_one_jiffy such that we have the same batch
limit as we would if CONFIG_VIRT_CPU_ACCOUNTING was disabled.
His patch did this once at boot but that initialisation happened
too early on PowerPC (before time_init) and it was never updated
at runtime as a result of a hotplug cpu add/remove.
This patch instead scales percpu_counter_batch by
cputime_one_jiffy at runtime, which keeps the batch correct even
after cpu hotplug operations. We cap it at INT_MAX in case of
overflow.
For architectures that do not support
CONFIG_VIRT_CPU_ACCOUNTING, cputime_one_jiffy is the constant 1
and gcc is smart enough to optimise min(s32
percpu_counter_batch, INT_MAX) to just percpu_counter_batch at
least on x86 and PowerPC. So there is no need to add an #ifdef.
On a 64 thread PowerPC box with CONFIG_VIRT_CPU_ACCOUNTING and
CONFIG_CGROUP_CPUACCT enabled, a context switch microbenchmark
is 234x faster and almost matches a CONFIG_CGROUP_CPUACCT
disabled kernel:
CONFIG_CGROUP_CPUACCT disabled: 16906698 ctx switches/sec
CONFIG_CGROUP_CPUACCT enabled: 61720 ctx switches/sec
CONFIG_CGROUP_CPUACCT + patch: 16663217 ctx switches/sec
Tested with:
wget http://ozlabs.org/~anton/junkcode/context_switch.c
make context_switch
for i in `seq 0 63`; do taskset -c $i ./context_switch & done
vmstat 1
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com>
Tested-by: Balbir Singh <balbir@linux.vnet.ibm.com>
commit 669c55e9f99b90e46eaa0f98a67ec53d46dc969a upstream
Dave reported that his large SPARC machines spend lots of time in
hweight64(), try and optimize some of those needless cpumask_weight()
invocations (esp. with the large offstack cpumasks these are very
expensive indeed).
Reported-by: David Miller <davem@davemloft.net>
LKML-Reference: <new-submission>
commit cc87f76a601d2d256118f7bab15e35254356ae21 upstream
The cpuload calculation in calc_load_account_active() assumes
rq->nr_uninterruptible will not change on an offline cpu after
migrate_nr_uninterruptible(). However the recent migrate on wakeup
changes broke that and would result in decrementing the offline cpu's
rq->nr_uninterruptible.
Fix this by accounting the nr_uninterruptible on the waking cpu.
commit 65cc8e4859ff29a9ddc989c88557d6059834c2a2 upstream
Now that we hold the rq->lock over set_task_cpu() again, we can do
away with most of the TASK_WAKING checks and reduce them again to
set_cpus_allowed_ptr().
Removes some conditionals from scheduling hot-paths.
commit 0017d735092844118bef006696a750a0e4ef6ebd upstream
Oleg noticed a few races with the TASK_WAKING usage on fork.
- since TASK_WAKING is basically a spinlock, it should be IRQ safe
- since we set TASK_WAKING (*) without holding rq->lock it could
be there still is a rq->lock holder, thereby not actually
providing full serialization.
(*) in fact we clear PF_STARTING, which in effect enables TASK_WAKING.
Cure the second issue by not setting TASK_WAKING in sched_fork(), but
only temporarily in wake_up_new_task() while calling select_task_rq().
Cure the first by holding rq->lock around the select_task_rq() call,
this will disable IRQs, this however requires that we push down the
rq->lock release into select_task_rq_fair()'s cgroup stuff.
Because select_task_rq_fair() still needs to drop the rq->lock we
cannot fully get rid of TASK_WAKING.
Reported-by: Oleg Nesterov <oleg@redhat.com>
commit 9084bb8246ea935b98320554229e2f371f7f52fa upstream
Introduce cpuset_cpus_allowed_fallback() helper to fix the cpuset problems
with select_fallback_rq(). It can be called from any context and can't use
any cpuset locks including task_lock(). It is called when the task doesn't
have online cpus in ->cpus_allowed but ttwu/etc must be able to find a
suitable cpu.
I am not proud of this patch. Everything which needs such a fat comment
can't be good even if correct. But I'd prefer to not change the locking
rules in the code I hardly understand, and in any case I believe this
simple change make the code much more correct compared to deadlocks we
currently have.
LKML-Reference: <20100315091027.GA9155@redhat.com>
commit 6a1bdc1b577ebcb65f6603c57f8347309bc4ab13 upstream
_cpu_down() changes the current task's affinity and then recovers it at
the end. The problems are well known: we can't restore old_allowed if it
was bound to the now-dead-cpu, and we can race with the userspace which
can change cpu-affinity during unplug.
_cpu_down() should not play with current->cpus_allowed at all. Instead,
take_cpu_down() can migrate the caller of _cpu_down() after __cpu_disable()
removes the dying cpu from cpu_online_mask.
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
LKML-Reference: <20100315091023.GA9148@redhat.com>
commit 30da688ef6b76e01969b00608202fff1eed2accc upstream.
sched_exec()->select_task_rq() reads/updates ->cpus_allowed lockless.
This can race with other CPUs updating our ->cpus_allowed, and this
looks meaningless to me.
The task is current and running, it must have online cpus in ->cpus_allowed,
the fallback mode is bogus. And, if ->sched_class returns the "wrong" cpu,
this likely means we raced with set_cpus_allowed() which was called
for reason, why should sched_exec() retry and call ->select_task_rq()
again?
Change the code to call sched_class->select_task_rq() directly and do
nothing if the returned cpu is wrong after re-checking under rq->lock.
From now task_struct->cpus_allowed is always stable under TASK_WAKING,
select_fallback_rq() is always called under rq-lock or the caller or
the caller owns TASK_WAKING (select_task_rq).
LKML-Reference: <20100315091019.GA9141@redhat.com>
commit c1804d547dc098363443667609c272d1e4d15ee8 upstream
The previous patch preserved the retry logic, but it looks unneeded.
__migrate_task() can only fail if we raced with migration after we dropped
the lock, but in this case the caller of set_cpus_allowed/etc must initiate
migration itself if ->on_rq == T.
We already fixed p->cpus_allowed, the changes in active/online masks must
be visible to racer, it should migrate the task to online cpu correctly.
LKML-Reference: <20100315091014.GA9138@redhat.com>
commit 1445c08d06c5594895b4fae952ef8a457e89c390 upstream
move_task_off_dead_cpu()->select_fallback_rq() reads/updates ->cpus_allowed
lockless. We can race with set_cpus_allowed() running in parallel.
Change it to take rq->lock around select_fallback_rq(). Note that it is not
trivial to move this spin_lock() into select_fallback_rq(), we must recheck
the task was not migrated after we take the lock and other callers do not
need this lock.
To avoid the races with other callers of select_fallback_rq() which rely on
TASK_WAKING, we also check p->state != TASK_WAKING and do nothing otherwise.
The owner of TASK_WAKING must update ->cpus_allowed and choose the correct
CPU anyway, and the subsequent __migrate_task() is just meaningless because
p->se.on_rq must be false.
Alternatively, we could change select_task_rq() to take rq->lock right
after it calls sched_class->select_task_rq(), but this looks a bit ugly.
Also, change it to not assume irqs are disabled and absorb __migrate_task_irq().
LKML-Reference: <20100315091010.GA9131@redhat.com>
cpuset_lock/cpuset_cpus_allowed_locked code
commit 897f0b3c3ff40b443c84e271bef19bd6ae885195 upstream
This patch just states the fact the cpusets/cpuhotplug interaction is
broken and removes the deadlockable code which only pretends to work.
- cpuset_lock() doesn't really work. It is needed for
cpuset_cpus_allowed_locked() but we can't take this lock in
try_to_wake_up()->select_fallback_rq() path.
- cpuset_lock() is deadlockable. Suppose that a task T bound to CPU takes
callback_mutex. If cpu_down(CPU) happens before T drops callback_mutex
stop_machine() preempts T, then migration_call(CPU_DEAD) tries to take
cpuset_lock() and hangs forever because CPU is already dead and thus
T can't be scheduled.
- cpuset_cpus_allowed_locked() is deadlockable too. It takes task_lock()
which is not irq-safe, but try_to_wake_up() can be called from irq.
Kill them, and change select_fallback_rq() to use cpu_possible_mask, like
we currently do without CONFIG_CPUSETS.
Also, with or without this patch, with or without CONFIG_CPUSETS, the
callers of select_fallback_rq() can race with each other or with
set_cpus_allowed() pathes.
The subsequent patches try to to fix these problems.
LKML-Reference: <20100315091003.GA9123@redhat.com>
commit 47a70985e5c093ae03d8ccf633c70a93761d86f2 upstream
Trivial typo fix. rq->migration_thread can be NULL after
task_rq_unlock(), this is why we have "mt" which should be
used instead.
LKML-Reference: <20100330165829.GA18284@redhat.com>
commit 60db48cacb9b253d5607a5ff206112a59cd09e34 upstream
rtmutex_set_prio() is used to implement priority inheritance for
futexes. When a task is deboosted it gets enqueued at the tail of its
RT priority list. This is violating the POSIX scheduling semantics:
rt priority list X contains two runnable tasks A and B
task A runs with priority X and holds mutex M
task C preempts A and is blocked on mutex M
-> task A is boosted to priority of task C (Y)
task A unlocks the mutex M and deboosts itself
-> A is dequeued from rt priority list Y
-> A is enqueued to the tail of rt priority list X
task C schedules away
task B runs
This is wrong as task A did not schedule away and therefor violates
the POSIX scheduling semantics.
Enqueue the task to the head of the priority list instead.
Reported-by: Mathias Weber <mathias.weber.mw1@roche.com>
Reported-by: Carsten Emde <cbe@osadl.org>
Acked-by: Peter Zijlstra <peterz@infradead.org>
Tested-by: Carsten Emde <cbe@osadl.org>
Tested-by: Mathias Weber <mathias.weber.mw1@roche.com>
LKML-Reference: <20100120171629.809074113@linutronix.de>
commit ea87bb7853168434f4a82426dd1ea8421f9e604d upstream
The ability of enqueueing a task to the head of a SCHED_FIFO priority
list is required to fix some violations of POSIX scheduling policy.
Extend the related functions with a "head" argument.
LKML-Reference: <20100120171629.734886007@linutronix.de>
commit 0970d2992dfd7d5ec2c787417cf464f01eeaf42a upstream
Thomas found that due to ttwu() changing a task's cpu without holding
the rq->lock, task_rq_lock() might end up locking the wrong rq.
Avoid this by serializing against TASK_WAKING.
Reported-by: Thomas Gleixner <tglx@linutronix.de>
LKML-Reference: <1266241712.15770.420.camel@laptop>
commit fabf318e5e4bda0aca2b0d617b191884fda62703 upstream
There are a number of issues:
1) TASK_WAKING vs cgroup_clone (cpusets)
copy_process():
sched_fork()
child->state = TASK_WAKING; /* waiting for wake_up_new_task() */
if (current->nsproxy != p->nsproxy)
ns_cgroup_clone()
cgroup_clone()
mutex_lock(inode->i_mutex)
mutex_lock(cgroup_mutex)
cgroup_attach_task()
ss->can_attach()
ss->attach() [ -> cpuset_attach() ]
cpuset_attach_task()
set_cpus_allowed_ptr();
while (child->state == TASK_WAKING)
cpu_relax();
will deadlock the system.
2) cgroup_clone (cpusets) vs copy_process
So even if the above would work we still have:
copy_process():
ns_cgroup_clone()
cgroup_clone()
ss->can_attach()
p->cpus_allowed = current->cpus_allowed
over-writing the modified cpus_allowed.
3) fork() vs hotplug
if we unplug the child's cpu after the sanity check when the child
gets attached to the task_list but before wake_up_new_task() shit
will meet with fan.
Solve all these issues by moving fork cpu selection into
wake_up_new_task().
Reported-by: Serge E. Hallyn <serue@us.ibm.com>
Tested-by: Serge E. Hallyn <serue@us.ibm.com>
LKML-Reference: <1264106190.4283.1314.camel@laptop>
commit 70f1120527797adb31c68bdc6f1b45e182c342c7 upstream
The hot-unplug kstopmachine usage does a wakeup after
deactivating the cpu, hence we cannot use cpu_active()
here but must rely on the good olde online.
Reported-by: Sachin Sant <sachinp@in.ibm.com>
Reported-by: Jens Axboe <jens.axboe@oracle.com>
Tested-by: Jens Axboe <jens.axboe@oracle.com>
LKML-Reference: <1261326987.4314.24.camel@laptop>
commit 88ec22d3edb72b261f8628226cd543589a6d5e1b upstream
In order to remove the cfs_rq dependency from set_task_cpu() we
need to ensure the task is cfs_rq invariant for all callsites.
The simple approach is to substract cfs_rq->min_vruntime from
se->vruntime on dequeue, and add cfs_rq->min_vruntime on
enqueue.
However, this has the downside of breaking FAIR_SLEEPERS since
we loose the old vruntime as we only maintain the relative
position.
To solve this, we observe that we only migrate runnable tasks,
we do this using deactivate_task(.sleep=0) and
activate_task(.wakeup=0), therefore we can restrain the
min_vruntime invariance to that state.
The only other case is wakeup balancing, since we want to
maintain the old vruntime we cannot make it relative on dequeue,
but since we don't migrate inactive tasks, we can do so right
before we activate it again.
This is where we need the new pre-wakeup hook, we need to call
this while still holding the old rq->lock. We could fold it into
->select_task_rq(), but since that has multiple callsites and
would obfuscate the locking requirements, that seems like a
fudge.
This leaves the fork() case, simply make sure that ->task_fork()
leaves the ->vruntime in a relative state.
This covers all cases where set_task_cpu() gets called, and
ensures it sees a relative vruntime.
LKML-Reference: <20091216170518.191697025@chello.nl>
commit efbbd05a595343a413964ad85a2ad359b7b7efbd upstream
As will be apparent in the next patch, we need a pre wakeup hook
for sched_fair task migration, hence rename the post wakeup hook
and one pre wakeup.
LKML-Reference: <20091216170518.114746117@chello.nl>
commit 5da9a0fb673a0ea0a093862f95f6b89b3390c31e upstream
Since select_task_rq() is now responsible for guaranteeing
->cpus_allowed and cpu_active_mask, we need to verify this.
select_task_rq_rt() can blindly return
smp_processor_id()/task_cpu() without checking the valid masks,
select_task_rq_fair() can do the same in the rare case that all
SD_flags are disabled.
LKML-Reference: <20091216170517.961475466@chello.nl>
commit 3802290628348674985d14914f9bfee7b9084548 upstream
sched: Fix sched_exec() balancing
Since we access ->cpus_allowed without holding rq->lock we need
a retry loop to validate the result, this comes for near free
when we merge sched_migrate_task() into sched_exec() since that
already does the needed check.
LKML-Reference: <20091216170517.884743662@chello.nl>
commit 077614ee1e93245a3b9a4e1213659405dbeb0ba6 upstream
There's a preemption race in the set_task_cpu() debug check in
that when we get preempted after setting task->state we'd still
be on the rq proper, but fail the test.
Check for preempted tasks, since those are always on the RQ.
LKML-Reference: <20091217121830.137155561@chello.nl>
commit 416eb39556a03d1c7e52b0791e9052ccd71db241 upstream
LKML-Reference: <20091216170517.807938893@chello.nl>
commit e2912009fb7b715728311b0d8fe327a1432b3f79 upstream
In order to clean up the set_task_cpu() rq dependencies we need
to ensure it is never called on blocked tasks because such usage
does not pair with consistent rq->lock usage.
This puts the migration burden on ttwu().
Furthermore we need to close a race against changing
->cpus_allowed, since select_task_rq() runs with only preemption
disabled.
For sched_fork() this is safe because the child isn't in the
tasklist yet, for wakeup we fix this by synchronizing
set_cpus_allowed_ptr() against TASK_WAKING, which leaves
sched_exec to be a problem
This also closes a hole in (6ad4c1888 sched: Fix balance vs
hotplug race) where ->select_task_rq() doesn't validate the
result against the sched_domain/root_domain.
commit 06b83b5fbea273672822b6ee93e16781046553ec upstream
For later convenience use TASK_WAKING for fresh tasks.
LKML-Reference: <20091216170517.732561278@chello.nl>
