commit e75e863dd5c7d96b91ebbd241da5328fc38a78cc upstream.
We have 32-bit variable overflow possibility when multiply in
task_times() and thread_group_times() functions. When the
overflow happens then the scaled utime value becomes erroneously
small and the scaled stime becomes i erroneously big.
Reported here:
https://bugzilla.redhat.com/show_bug.cgi?id=633037
https://bugzilla.kernel.org/show_bug.cgi?id=16559
Reported-by: Michael Chapman <redhat-bugzilla@very.puzzling.org>
Reported-by: Ciriaco Garcia de Celis <sysman@etherpilot.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
LKML-Reference: <20100914143513.GB8415@redhat.com>
commit 868baf07b1a259f5f3803c1dc2777b6c358f83cf upstream.
When the fuction graph tracer starts, it needs to make a special
stack for each task to save the real return values of the tasks.
All running tasks have this stack created, as well as any new
tasks.
On CPU hot plug, the new idle task will allocate a stack as well
when init_idle() is called. The problem is that cpu hotplug does
not create a new idle_task. Instead it uses the idle task that
existed when the cpu went down.
ftrace_graph_init_task() will add a new ret_stack to the task
that is given to it. Because a clone will make the task
have a stack of its parent it does not check if the task's
ret_stack is already NULL or not. When the CPU hotplug code
starts a CPU up again, it will allocate a new stack even
though one already existed for it.
The solution is to treat the idle_task specially. In fact, the
function_graph code already does, just not at init_idle().
Instead of using the ftrace_graph_init_task() for the idle task,
which that function expects the task to be a clone, have a
separate ftrace_graph_init_idle_task(). Also, we will create a
per_cpu ret_stack that is used by the idle task. When we call
ftrace_graph_init_idle_task() it will check if the idle task's
ret_stack is NULL, if it is, then it will assign it the per_cpu
ret_stack.
Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
Suggested-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
commit 7740191cd909b75d75685fb08a5d1f54b8a9d28b upstream.
Fix incorrect handling of the following case:
INTERACTIVE
INTERACTIVE_SOMETHING_ELSE
The comparison only checks up to each element's length.
Changelog since v1:
- Embellish using some Rostedtisms.
[ mingo: ^^ == smaller and cleaner ]
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Tony Lindgren <tony@atomide.com>
LKML-Reference: <20100913214700.GB16118@Krystal>
commit 3c93717cfa51316e4dbb471e7c0f9d243359d5f8 upstream.
Commit e70971591 ("sched: Optimize unused cgroup configuration") introduced
an imbalanced scheduling bug.
If we do not use CGROUP, function update_h_load won't update h_load. When the
system has a large number of tasks far more than logical CPU number, the
incorrect cfs_rq[cpu]->h_load value will cause load_balance() to pull too
many tasks to the local CPU from the busiest CPU. So the busiest CPU keeps
going in a round robin. That will hurt performance.
The issue was found originally by a scientific calculation workload that
developed by Yanmin. With that commit, the workload performance drops
about 40%.
CPU before after
00 : 2 : 7
01 : 1 : 7
02 : 11 : 6
03 : 12 : 7
04 : 6 : 6
05 : 11 : 7
06 : 10 : 6
07 : 12 : 7
08 : 11 : 6
09 : 12 : 6
10 : 1 : 6
11 : 1 : 6
12 : 6 : 6
13 : 2 : 6
14 : 2 : 6
15 : 1 : 6
Reviewed-by: Yanmin zhang <yanmin.zhang@intel.com>
Signed-off-by: Alex Shi <alex.shi@intel.com>
LKML-Reference: <1276754893.9452.5442.camel@debian>
commit 0d98bb2656e9bd2dfda2d089db1fe1dbdab41504 upstream.
GCC 4.4.1 on ARM has been observed to replace the while loop in
sched_avg_update with a call to uldivmod, resulting in the
following build failure at link-time:
kernel/built-in.o: In function `sched_avg_update':
kernel/sched.c:1261: undefined reference to `__aeabi_uldivmod'
make: *** [.tmp_vmlinux1] Error 1
This patch introduces a fake data hazard to the loop body to
prevent the compiler optimising the loop away.
Acked-by: Peter Zijlstra <peterz@infradead.org>
commit 8bc037fb89bb3104b9ae290d18c877624cd7d9cc upstream.
Using the proper type fixes the following compiler warning:
kernel/sched.c:4850: warning: comparison of distinct pointer types lacks a cast
Cc: torvalds@linux-foundation.org
Cc: travis@sgi.com
Cc: peterz@infradead.org
Cc: drepper@redhat.com
Cc: rja@sgi.com
Cc: sharyath@in.ibm.com
Cc: steiner@sgi.com
LKML-Reference: <20100317090046.4C79.A69D9226@jp.fujitsu.com>
commit 84fba5ec91f11c0efb27d0ed6098f7447491f0df upstream.
taskset on 2.6.34-rc3 fails on one of my ppc64 test boxes with
the following error:
sched_getaffinity(0, 16, 0x10029650030) = -1 EINVAL (Invalid argument)
This box has 128 threads and 16 bytes is enough to cover it.
Commit cd3d8031eb4311e516329aee03c79a08333141f1 (sched:
sched_getaffinity(): Allow less than NR_CPUS length) is
comparing this 16 bytes agains nr_cpu_ids.
Fix it by comparing nr_cpu_ids to the number of bits in the
cpumask we pass in.
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Sharyathi Nagesh <sharyath@in.ibm.com>
Cc: Ulrich Drepper <drepper@redhat.com>
Cc: Jack Steiner <steiner@sgi.com>
Cc: Russ Anderson <rja@sgi.com>
Cc: Mike Travis <travis@sgi.com>
LKML-Reference: <20100406070218.GM5594@kryten>
commit cd3d8031eb4311e516329aee03c79a08333141f1 upstream.
[ Note, this commit changes the syscall ABI for > 1024 CPUs systems. ]
Recently, some distro decided to use NR_CPUS=4096 for mysterious reasons.
Unfortunately, glibc sched interface has the following definition:
# define __CPU_SETSIZE 1024
# define __NCPUBITS (8 * sizeof (__cpu_mask))
typedef unsigned long int __cpu_mask;
typedef struct
__cpu_mask __bits[__CPU_SETSIZE / __NCPUBITS];
} cpu_set_t;
It mean, if NR_CPUS is bigger than 1024, cpu_set_t makes an
ABI issue ...
More recently, Sharyathi Nagesh reported following test program makes
misterious syscall failure:
#define _GNU_SOURCE
#include<stdio.h>
#include<errno.h>
#include<sched.h>
int main()
cpu_set_t set;
if (sched_getaffinity(0, sizeof(cpu_set_t), &set) < 0)
printf("\n Call is failing with:%d", errno);
Because the kernel assumes len argument of sched_getaffinity() is bigger
than NR_CPUS. But now it is not correct.
Now we are faced with the following annoying dilemma, due to
the limitations of the glibc interface built in years ago:
(1) if we change glibc's __CPU_SETSIZE definition, we lost
binary compatibility of _all_ application.
(2) if we don't change it, we also lost binary compatibility of
Sharyathi's use case.
Then, I would propse to change the rule of the len argument of
sched_getaffinity().
Old:
len should be bigger than NR_CPUS
New:
len should be bigger than maximum possible cpu id
This creates the following behavior:
(A) In the real 4096 cpus machine, the above test program still
return -EINVAL.
(B) NR_CPUS=4096 but the machine have less than 1024 cpus (almost
all machines in the world), the above can run successfully.
Fortunatelly, BIG SGI machine is mainly used for HPC use case. It means
they can rebuild their programs.
IOW we hope they are not annoyed by this issue ...
Reported-by: Sharyathi Nagesh <sharyath@in.ibm.com>
Acked-by: Ulrich Drepper <drepper@redhat.com>
LKML-Reference: <20100312161316.9520.A69D9226@jp.fujitsu.com>
commit dd5feea14a7de4edbd9f36db1a2db785de91b88d upstream
On platforms like dual socket quad-core platform, the scheduler load
balancer is not detecting the load imbalances in certain scenarios. This
is leading to scenarios like where one socket is completely busy (with
all the 4 cores running with 4 tasks) and leaving another socket
completely idle. This causes performance issues as those 4 tasks share
the memory controller, last-level cache bandwidth etc. Also we won't be
taking advantage of turbo-mode as much as we would like, etc.
Some of the comparisons in the scheduler load balancing code are
comparing the "weighted cpu load that is scaled wrt sched_group's
cpu_power" with the "weighted average load per task that is not scaled
wrt sched_group's cpu_power". While this has probably been broken for a
longer time (for multi socket numa nodes etc), the problem got aggrevated
via this recent change:
| commit f93e65c186ab3c05ce2068733ca10e34fd00125e
| Author: Peter Zijlstra <a.p.zijlstra@chello.nl>
| Date: Tue Sep 1 10:34:32 2009 +0200
| sched: Restore __cpu_power to a straight sum of power
Also with this change, the sched group cpu power alone no longer reflects
the group capacity that is needed to implement MC, MT performance
(default) and power-savings (user-selectable) policies.
We need to use the computed group capacity (sgs.group_capacity, that is
computed using the SD_PREFER_SIBLING logic in update_sd_lb_stats()) to
find out if the group with the max load is above its capacity and how
much load to move etc.
Reported-by: Ma Ling <ling.ma@intel.com>
Initial-Analysis-by: Zhang, Yanmin <yanmin_zhang@linux.intel.com>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
[ -v2: build fix ]
LKML-Reference: <1266970432.11588.22.camel@sbs-t61.sc.intel.com>
commit 83ab0aa0d5623d823444db82c3b3c34d7ec364ae upstream.
setscheduler() saves task->sched_class outside of the rq->lock held
region for a check after the setscheduler changes have become
effective. That might result in checking a stale value.
rtmutex_setprio() has the same problem, though it is protected by
p->pi_lock against setscheduler(), but for correctness sake (and to
avoid bad examples) it needs to be fixed as well.
Retrieve task->sched_class inside of the rq->lock held region.
commit 9000f05c6d1607f79c0deacf42b09693be673f4c upstream.
Fix a SMT scheduler performance regression that is leading to a scenario
where SMT threads in one core are completely idle while both the SMT threads
in another core (on the same socket) are busy.
This is caused by this commit (with the problematic code highlighted)
commit bdb94aa5dbd8b55e75f5a50b61312fe589e2c2d1
Date: Tue Sep 1 10:34:38 2009 +0200
sched: Try to deal with low capacity
@@ -4203,15 +4223,18 @@ find_busiest_queue()
for_each_cpu(i, sched_group_cpus(group)) {
+ unsigned long power = power_of(i);
- wl = weighted_cpuload(i);
+ wl = weighted_cpuload(i) * SCHED_LOAD_SCALE;
+ wl /= power;
- if (rq->nr_running == 1 && wl > imbalance)
+ if (capacity && rq->nr_running == 1 && wl > imbalance)
continue;
On a SMT system, power of the HT logical cpu will be 589 and
the scheduler load imbalance (for scenarios like the one mentioned above)
can be approximately 1024 (SCHED_LOAD_SCALE). The above change of scaling
the weighted load with the power will result in "wl > imbalance" and
ultimately resulting in find_busiest_queue() return NULL, causing
load_balance() to think that the load is well balanced. But infact
one of the tasks can be moved to the idle core for optimal performance.
We don't need to use the weighted load (wl) scaled by the cpu power to
compare with imabalance. In that condition, we already know there is only a
single task "rq->nr_running == 1" and the comparison between imbalance,
wl is to make sure that we select the correct priority thread which matches
imbalance. So we really need to compare the imabalnce with the original
weighted load of the cpu and not the scaled load.
But in other conditions where we want the most hammered(busiest) cpu, we can
use scaled load to ensure that we consider the cpu power in addition to the
actual load on that cpu, so that we can move the load away from the
guy that is getting most hammered with respect to the actual capacity,
as compared with the rest of the cpu's in that busiest group.
Fix it.
LKML-Reference: <1266023662.2808.118.camel@sbs-t61.sc.intel.com>
There are a number of issues:
1) TASK_WAKING vs cgroup_clone (cpusets)
copy_process():
sched_fork()
child->state = TASK_WAKING; /* waiting for wake_up_new_task() */
if (current->nsproxy != p->nsproxy)
ns_cgroup_clone()
cgroup_clone()
mutex_lock(inode->i_mutex)
mutex_lock(cgroup_mutex)
cgroup_attach_task()
ss->can_attach()
ss->attach() [ -> cpuset_attach() ]
cpuset_attach_task()
set_cpus_allowed_ptr();
while (child->state == TASK_WAKING)
cpu_relax();
will deadlock the system.
2) cgroup_clone (cpusets) vs copy_process
So even if the above would work we still have:
copy_process():
ns_cgroup_clone()
cgroup_clone()
ss->can_attach()
p->cpus_allowed = current->cpus_allowed
over-writing the modified cpus_allowed.
3) fork() vs hotplug
if we unplug the child's cpu after the sanity check when the child
gets attached to the task_list but before wake_up_new_task() shit
will meet with fan.
Solve all these issues by moving fork cpu selection into
wake_up_new_task().
Reported-by: Serge E. Hallyn <serue@us.ibm.com>
Tested-by: Serge E. Hallyn <serue@us.ibm.com>
LKML-Reference: <1264106190.4283.1314.camel@laptop>
Assume A->B schedule is processing, if B have acquired BKL before and it
need reschedule this time. Then on B's context, it will go to
need_resched_nonpreemptible for reschedule. But at this time, prev and
switch_count are related to A. It's wrong and will lead to incorrect
scheduler statistics.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
LKML-Reference: <2674af741001102238w7b0ddcadref00d345e2181d11@mail.gmail.com>
Effectively reverts 738d2be4301007f054541c5c4bf7fb6a361c9b3a.
As demonstrated by Eric, we really need to call __set_task_cpu()
early in the fork() path to properly initialize the various task
state -- specifically the cgroup state through set_task_rq().
[ we could probably fix this by explicitly calling
__set_task_cpu() from sched_fork(), but lets try that for the
next cycle and simply revert to the old behaviour for now. ]
Reported-by: Eric Paris <eparis@redhat.com>
Tested-by: Eric Paris <eparis@redhat.com>,
Cc: efault@gmx.de
LKML-Reference: <1261492999.4937.36.camel@laptop>
The hot-unplug kstopmachine usage does a wakeup after
deactivating the cpu, hence we cannot use cpu_active()
here but must rely on the good olde online.
Reported-by: Sachin Sant <sachinp@in.ibm.com>
Reported-by: Jens Axboe <jens.axboe@oracle.com>
Tested-by: Jens Axboe <jens.axboe@oracle.com>
LKML-Reference: <1261326987.4314.24.camel@laptop>
Revert the braindead pr_* crap. (Commit 663997d "sched: Use
pr_fmt() and pr_<level>()")
It's dumb and causes stupid "sched: " strings all over the place.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Mike Galbraith <efault@gmx.de>
Cc: Joe Perches <joe@perches.com>
LKML-Reference: <1261315437.4314.6.camel@laptop>
[ i dont mind the pr_*() patterns that much - but Peter dislikes them with a vengence. ]
[ - v2: remove spurious diffstat from changelog :-/ ]
There's a preemption race in the set_task_cpu() debug check in
that when we get preempted after setting task->state we'd still
be on the rq proper, but fail the test.
Check for preempted tasks, since those are always on the RQ.
LKML-Reference: <20091217121830.137155561@chello.nl>
In practice, it is harmless to voluntarily sleep in a
rcu_read_lock() section if we are running under preempt rcu, but
it is illegal if we build a kernel running non-preemptable rcu.
Currently, might_sleep() doesn't notice sleepable operations
under rcu_read_lock() sections if we are running under
preemptable rcu because preempt_count() is left untouched after
rcu_read_lock() in this case. But we want developers who test
their changes under such config to notice the "sleeping while
atomic" issues.
So we add rcu_read_lock_nesting to prempt_count() in
might_sleep() checks.
[ v2: Handle rcu-tiny ]
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
LKML-Reference: <1260991265-8451-1-git-send-regression-fweisbec@gmail.com>
LKML-Reference: <20091216170517.807938893@chello.nl>
Rearrange code a bit now that its a simpler function.
LKML-Reference: <20091216170518.269101883@chello.nl>
In order to remove the cfs_rq dependency from set_task_cpu() we
need to ensure the task is cfs_rq invariant for all callsites.
The simple approach is to substract cfs_rq->min_vruntime from
se->vruntime on dequeue, and add cfs_rq->min_vruntime on
enqueue.
However, this has the downside of breaking FAIR_SLEEPERS since
we loose the old vruntime as we only maintain the relative
position.
To solve this, we observe that we only migrate runnable tasks,
we do this using deactivate_task(.sleep=0) and
activate_task(.wakeup=0), therefore we can restrain the
min_vruntime invariance to that state.
The only other case is wakeup balancing, since we want to
maintain the old vruntime we cannot make it relative on dequeue,
but since we don't migrate inactive tasks, we can do so right
before we activate it again.
This is where we need the new pre-wakeup hook, we need to call
this while still holding the old rq->lock. We could fold it into
->select_task_rq(), but since that has multiple callsites and
would obfuscate the locking requirements, that seems like a
fudge.
This leaves the fork() case, simply make sure that ->task_fork()
leaves the ->vruntime in a relative state.
This covers all cases where set_task_cpu() gets called, and
ensures it sees a relative vruntime.
LKML-Reference: <20091216170518.191697025@chello.nl>
As will be apparent in the next patch, we need a pre wakeup hook
for sched_fair task migration, hence rename the post wakeup hook
and one pre wakeup.
LKML-Reference: <20091216170518.114746117@chello.nl>
Since kthread_bind() lost its dependencies on sched.c, move it
back where it came from.
LKML-Reference: <20091216170518.039524041@chello.nl>
Since select_task_rq() is now responsible for guaranteeing
->cpus_allowed and cpu_active_mask, we need to verify this.
select_task_rq_rt() can blindly return
smp_processor_id()/task_cpu() without checking the valid masks,
select_task_rq_fair() can do the same in the rare case that all
SD_flags are disabled.
LKML-Reference: <20091216170517.961475466@chello.nl>
Since we access ->cpus_allowed without holding rq->lock we need
a retry loop to validate the result, this comes for near free
when we merge sched_migrate_task() into sched_exec() since that
already does the needed check.
LKML-Reference: <20091216170517.884743662@chello.nl>
In order to clean up the set_task_cpu() rq dependencies we need
to ensure it is never called on blocked tasks because such usage
does not pair with consistent rq->lock usage.
This puts the migration burden on ttwu().
Furthermore we need to close a race against changing
->cpus_allowed, since select_task_rq() runs with only preemption
disabled.
For sched_fork() this is safe because the child isn't in the
tasklist yet, for wakeup we fix this by synchronizing
set_cpus_allowed_ptr() against TASK_WAKING, which leaves
sched_exec to be a problem
This also closes a hole in (6ad4c1888 sched: Fix balance vs
hotplug race) where ->select_task_rq() doesn't validate the
result against the sched_domain/root_domain.
For later convenience use TASK_WAKING for fresh tasks.
LKML-Reference: <20091216170517.732561278@chello.nl>
Make sure not to access sched_fair fields before verifying it is
indeed a sched_fair task.
CC: stable@kernel.org
LKML-Reference: <20091216170517.577998058@chello.nl>
kernel/sched_idletask.c
Merge reason: resolve the conflicts, pick up latest changes.
Convert locks which cannot be sleeping locks in preempt-rt to
raw_spinlocks.
raw_spinlocks.
raw_spinlocks.
The name space hierarchy for the internal lock functions is now a bit
backwards. raw_spin* functions map to _spin* which use __spin*, while
we would like to have _raw_spin* and __raw_spin*.
_raw_spin* is already used by lock debugging, so rename those funtions
to do_raw_spin* to free up the _raw_spin* name space.
No functional change.
Now that the raw_spin name space is freed up, we can implement
raw_spinlock and the related functions which are used to annotate the
locks which are not converted to sleeping spinlocks in preempt-rt.
A side effect is that only such locks can be used with the low level
lock fsunctions which circumvent lockdep.
For !rt spin_* functions are mapped to the raw_spin* implementations.
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (34 commits)
m68k: rename global variable vmalloc_end to m68k_vmalloc_end
percpu: add missing per_cpu_ptr_to_phys() definition for UP
percpu: Fix kdump failure if booted with percpu_alloc=page
percpu: make misc percpu symbols unique
percpu: make percpu symbols in ia64 unique
percpu: make percpu symbols in powerpc unique
percpu: make percpu symbols in x86 unique
percpu: make percpu symbols in xen unique
percpu: make percpu symbols in cpufreq unique
percpu: make percpu symbols in oprofile unique
percpu: make percpu symbols in tracer unique
percpu: make percpu symbols under kernel/ and mm/ unique
percpu: remove some sparse warnings
percpu: make alloc_percpu() handle array types
vmalloc: fix use of non-existent percpu variable in put_cpu_var()
this_cpu: Use this_cpu_xx in trace_functions_graph.c
this_cpu: Use this_cpu_xx for ftrace
this_cpu: Use this_cpu_xx in nmi handling
this_cpu: Use this_cpu operations in RCU
this_cpu: Use this_cpu ops for VM statistics
Fix up trivial (famous last words) global per-cpu naming conflicts in
arch/x86/kvm/svm.c
mm/slab.c
read_lock(&tasklist_lock) does not protect
sys_sched_get_rr_param() against a concurrent update of the
policy or scheduler parameters as do_sched_scheduler() does not
take the tasklist_lock.
The access to task->sched_class->get_rr_interval is protected by
task_rq_lock(task).
Use rcu_read_lock() to protect find_task_by_vpid() and prevent
the task struct from going away.
LKML-Reference: <20091209100706.862897167@linutronix.de>
tasklist_lock is held read locked to protect the
find_task_by_vpid() call and to prevent the task going away.
sched_setaffinity acquires a task struct ref and drops tasklist
lock right away. The access to the cpus_allowed mask is
protected by rq->lock.
rcu_read_lock() provides the same protection here.
LKML-Reference: <20091209100706.789059966@linutronix.de>
sys_sched_getscheduler and sys_sched_getparam() against a
concurrent update of the policy or scheduler parameters as
do_sched_setscheduler() does not take the tasklist_lock. The
accessed integers can be retrieved w/o locking and are snapshots
anyway.
Using rcu_read_lock() to protect find_task_by_vpid() and prevent
the task struct from going away is not changing the above
situation.
LKML-Reference: <20091209100706.753790977@linutronix.de>
- Convert printk(KERN_<level> to pr_<level> (not KERN_DEBUG)
- Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
- Coalesce long format strings
- Add missing \n to "ERROR: !SD_LOAD_BALANCE domain has parent"
LKML-Reference: <1260655047.2637.7.camel@Joe-Laptop.home>
Alan Stern noticed that all the wakeup side (and atomic) variants of the
completion APIs should be irq safe, but the newly introduced
completion_done() and try_wait_for_completion() aren't. The use of the
irq unsafe variants in IRQ contexts can cause crashes/hangs.
Fix the problem by making them use spin_lock_irqsave() and
spin_lock_irqrestore().
Reported-by: Alan Stern <stern@rowland.harvard.edu>
Cc: Zhang Rui <rui.zhang@intel.com>
Cc: pm list <linux-pm@lists.linux-foundation.org>
Cc: David Chinner <david@fromorbit.com>
Cc: Lachlan McIlroy <lachlan@sgi.com>
LKML-Reference: <200912130007.30541.rjw@sisk.pl>
* 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (21 commits)
sched: Remove forced2_migrations stats
sched: Fix memory leak in two error corner cases
sched: Fix build warning in get_update_sysctl_factor()
sched: Update normalized values on user updates via proc
sched: Make tunable scaling style configurable
sched: Fix missing sched tunable recalculation on cpu add/remove
sched: Fix task priority bug
sched: cgroup: Implement different treatment for idle shares
sched: Remove unnecessary RCU exclusion
sched: Discard some old bits
sched: Clean up check_preempt_wakeup()
sched: Move update_curr() in check_preempt_wakeup() to avoid redundant call
sched: Sanitize fork() handling
sched: Clean up ttwu() rq locking
sched: Remove rq->clock coupling from set_task_cpu()
sched: Consolidate select_task_rq() callers
sched: Remove sysctl.sched_features
sched: Protect sched_rr_get_param() access to task->sched_class
sched: Protect task->cpus_allowed access in sched_getaffinity()
sched: Fix balance vs hotplug race
Fixed up conflicts in kernel/sysctl.c (due to sysctl cleanup)
This build warning:
kernel/sched.c: In function 'set_task_cpu':
kernel/sched.c:2070: warning: unused variable 'old_rq'
Made me realize that the forced2_migrations stat looks pretty
pointless (and a misnomer) - remove it.
LKML-Reference: <new-submission>
If the second in each of these pairs of allocations fails, then the
first one will not be freed in the error route out.
Found by a static code analysis tool.
Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
LKML-Reference: <1260448177-28448-1-git-send-email-ext-phil.2.carmody@nokia.com>
Signed-off-by: Mike Galbraith <efault@gmx.de>
The normalized values are also recalculated in case the scaling factor
changes.
This patch updates the internally used scheduler tuning values that are
normalized to one cpu in case a user sets new values via sysfs.
Together with patch 2 of this series this allows to let user configured
values scale (or not) to cpu add/remove events taking place later.
Signed-off-by: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com>
LKML-Reference: <1259579808-11357-4-git-send-email-ehrhardt@linux.vnet.ibm.com>
[ v2: fix warning ]
As scaling now takes place on all kind of cpu add/remove events a user
that configures values via proc should be able to configure if his set
values are still rescaled or kept whatever happens.
As the comments state that log2 was just a second guess that worked the
interface is not just designed for on/off, but to choose a scaling type.
Currently this allows none, log and linear, but more important it allwos
us to keep the interface even if someone has an even better idea how to
scale the values.
LKML-Reference: <1259579808-11357-3-git-send-email-ehrhardt@linux.vnet.ibm.com>
Based on Peter Zijlstras patch suggestion this enables recalculation of
the scheduler tunables in response of a change in the number of cpus. It
also adds a max of eight cpus that are considered in that scaling.
LKML-Reference: <1259579808-11357-2-git-send-email-ehrhardt@linux.vnet.ibm.com>
83f9ac removed a call to effective_prio() in wake_up_new_task(), which
leads to tasks running at MAX_PRIO.
This is caused by the idle thread being set to MAX_PRIO before forking
off init. O(1) used that to make sure idle was always preempted, CFS
uses check_preempt_curr_idle() for that so we can savely remove this bit
of legacy code.
Reported-by: Mike Galbraith <efault@gmx.de>
Tested-by: Mike Galbraith <efault@gmx.de>
LKML-Reference: <1259754383.4003.610.camel@laptop>
When setting the weight for a per-cpu task-group, we have to put in a
phantom weight when there is no work on that cpu, otherwise we'll not
service that cpu when new work gets placed there until we again update
the per-cpu weights.
We used to add these phantom weights to the total, so that the idle
per-cpu shares don't get inflated, this however causes the non-idle
parts to get deflated, causing unexpected weight distibutions.
Reverse this, so that the non-idle shares are correct but the idle
shares are inflated.
Reported-by: Yasunori Goto <y-goto@jp.fujitsu.com>
Tested-by: Yasunori Goto <y-goto@jp.fujitsu.com>
LKML-Reference: <1257934048.23203.76.camel@twins>
WAKEUP_RUNNING was an experiment, not sure why that ever ended up being
merged...
