path: root/kernel/sched
2013-09-20sched/balancing: Fix cfs_rq->task_h_load calculationVladimir Davydov
Patch a003a2 (sched: Consider runnable load average in move_tasks()) sets all top-level cfs_rqs' h_load to rq->avg.load_avg_contrib, which is always 0. This mistype leads to all tasks having weight 0 when load balancing in a cpu-cgroup enabled setup. There obviously should be sum of weights of all runnable tasks there instead. Fix it. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Reviewed-by: Paul Turner <pjt@google.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1379173186-11944-1-git-send-email-vdavydov@parallels.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-20sched/balancing: Fix 'local->avg_load > busiest->avg_load' case in ↵Vladimir Davydov
fix_small_imbalance() In busiest->group_imb case we can come to fix_small_imbalance() with local->avg_load > busiest->avg_load. This can result in wrong imbalance fix-up, because there is the following check there where all the members are unsigned: if (busiest->avg_load - local->avg_load + scaled_busy_load_per_task >= (scaled_busy_load_per_task * imbn)) { env->imbalance = busiest->load_per_task; return; } As a result we can end up constantly bouncing tasks from one cpu to another if there are pinned tasks. Fix it by substituting the subtraction with an equivalent addition in the check. [ The bug can be caught by running 2*N cpuhogs pinned to two logical cpus belonging to different cores on an HT-enabled machine with N logical cpus: just look at se.nr_migrations growth. ] Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/ef167822e5c5b2d96cf5b0e3e4f4bdff3f0414a2.1379252740.git.vdavydov@parallels.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-20sched/balancing: Fix 'local->avg_load > sds->avg_load' case in ↵Vladimir Davydov
calculate_imbalance() In busiest->group_imb case we can come to calculate_imbalance() with local->avg_load >= busiest->avg_load >= sds->avg_load. This can result in imbalance overflow, because it is calculated as follows env->imbalance = min( max_pull * busiest->group_power, (sds->avg_load - local->avg_load) * local->group_power) / SCHED_POWER_SCALE; As a result we can end up constantly bouncing tasks from one cpu to another if there are pinned tasks. Fix this by skipping the assignment and assuming imbalance=0 in case local->avg_load > sds->avg_load. [ The bug can be caught by running 2*N cpuhogs pinned to two logical cpus belonging to different cores on an HT-enabled machine with N logical cpus: just look at se.nr_migrations growth. ] Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/8f596cc6bc0e5e655119dc892c9bfcad26e971f4.1379252740.git.vdavydov@parallels.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-18Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Misc fixes" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched: Fix comment for sched_info_depart sched/Documentation: Update sched-design-CFS.txt documentation sched/debug: Take PID namespace into account sched/fair: Fix small race where child->se.parent,cfs_rq might point to invalid ones
2013-09-16sched: Fix comment for sched_info_departMichael S. Tsirkin
sched_info_depart seems to be only called from sched_info_switch(), so only on involuntary task switch. Fix the comment to match. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Link: http://lkml.kernel.org/r/20130916083036.GA1113@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-12Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fix from Ingo Molnar: "Performance regression fix" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched: Fix load balancing performance regression in should_we_balance()
2013-09-12sched/debug: Take PID namespace into accountPeter Zijlstra
Emmanuel reported that /proc/sched_debug didn't report the right PIDs when using namespaces, cure this. Reported-by: Emmanuel Deloget <emmanuel.deloget@efixo.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20130909110141.GM31370@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-12sched/fair: Fix small race where child->se.parent,cfs_rq might point to ↵Daisuke Nishimura
invalid ones There is a small race between copy_process() and cgroup_attach_task() where child->se.parent,cfs_rq points to invalid (old) ones. parent doing fork() | someone moving the parent to another cgroup -------------------------------+--------------------------------------------- copy_process() + dup_task_struct() -> parent->se is copied to child->se. se.parent,cfs_rq of them point to old ones. cgroup_attach_task() + cgroup_task_migrate() -> parent->cgroup is updated. + cpu_cgroup_attach() + sched_move_task() + task_move_group_fair() +- set_task_rq() -> se.parent,cfs_rq of parent are updated. + cgroup_fork() -> parent->cgroup is copied to child->cgroup. (*1) + sched_fork() + task_fork_fair() -> se.parent,cfs_rq of child are accessed while they point to old ones. (*2) In the worst case, this bug can lead to "use-after-free" and cause a panic, because it's new cgroup's refcount that is incremented at (*1), so the old cgroup(and related data) can be freed before (*2). In fact, a panic caused by this bug was originally caught in RHEL6.4. BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff81051e3e>] sched_slice+0x6e/0xa0 [...] Call Trace: [<ffffffff81051f25>] place_entity+0x75/0xa0 [<ffffffff81056a3a>] task_fork_fair+0xaa/0x160 [<ffffffff81063c0b>] sched_fork+0x6b/0x140 [<ffffffff8106c3c2>] copy_process+0x5b2/0x1450 [<ffffffff81063b49>] ? wake_up_new_task+0xd9/0x130 [<ffffffff8106d2f4>] do_fork+0x94/0x460 [<ffffffff81072a9e>] ? sys_wait4+0xae/0x100 [<ffffffff81009598>] sys_clone+0x28/0x30 [<ffffffff8100b393>] stub_clone+0x13/0x20 [<ffffffff8100b072>] ? system_call_fastpath+0x16/0x1b Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/039601ceae06$733d3130$59b79390$@mxp.nes.nec.co.jp Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-10sched: Fix load balancing performance regression in should_we_balance()Joonsoo Kim
Commit 23f0d20 ("sched: Factor out code to should_we_balance()") introduces the should_we_balance() function. This function should return 1 if this cpu is appropriate for balancing. But the newly introduced code doesn't do so, it returns 0 instead of 1. This introduces performance regression, reported by Dave Chinner: v4 filesystem v5 filesystem 3.11+xfsdev: 220k files/s 225k files/s 3.12-git 180k files/s 185k files/s 3.12-git-revert 245k files/s 247k files/s You can find more detailed information at: https://lkml.org/lkml/2013/9/10/1 This patch corrects the return value of should_we_balance() function as orignally intended. With this patch, Dave Chinner reports that the regression is gone: v4 filesystem v5 filesystem 3.11+xfsdev: 220k files/s 225k files/s 3.12-git 180k files/s 185k files/s 3.12-git-revert 245k files/s 247k files/s 3.12-git-fix 249k files/s 248k files/s Reported-by: Dave Chinner <dchinner@redhat.com> Tested-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Paul Turner <pjt@google.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Dave Chinner <david@fromorbit.com> Link: http://lkml.kernel.org/r/20130910065448.GA20368@lge.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-05Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull cputime fix from Ingo Molnar: "This fixes a longer-standing cputime accounting bug that Stanislaw Gruszka finally managed to track down" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/cputime: Do not scale when utime == 0
2013-09-04Merge branch 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Gleb Natapov: "The highlights of the release are nested EPT and pv-ticketlocks support (hypervisor part, guest part, which is most of the code, goes through tip tree). Apart of that there are many fixes for all arches" Fix up semantic conflicts as discussed in the pull request thread.. * 'next' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (88 commits) ARM: KVM: Add newlines to panic strings ARM: KVM: Work around older compiler bug ARM: KVM: Simplify tracepoint text ARM: KVM: Fix kvm_set_pte assignment ARM: KVM: vgic: Bump VGIC_NR_IRQS to 256 ARM: KVM: Bugfix: vgic_bytemap_get_reg per cpu regs ARM: KVM: vgic: fix GICD_ICFGRn access ARM: KVM: vgic: simplify vgic_get_target_reg KVM: MMU: remove unused parameter KVM: PPC: Book3S PR: Rework kvmppc_mmu_book3s_64_xlate() KVM: PPC: Book3S PR: Make instruction fetch fallback work for system calls KVM: PPC: Book3S PR: Don't corrupt guest state when kernel uses VMX KVM: x86: update masterclock when kvmclock_offset is calculated (v2) KVM: PPC: Book3S: Fix compile error in XICS emulation KVM: PPC: Book3S PR: return appropriate error when allocation fails arch: powerpc: kvm: add signed type cast for comparation KVM: x86: add comments where MMIO does not return to the emulator KVM: vmx: count exits to userspace during invalid guest emulation KVM: rename __kvm_io_bus_sort_cmp to kvm_io_bus_cmp kvm: optimize away THP checks in kvm_is_mmio_pfn() ...
2013-09-04Merge branch 'timers-nohz-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timers/nohz changes from Ingo Molnar: "It mostly contains fixes and full dynticks off-case optimizations, by Frederic Weisbecker" * 'timers-nohz-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (24 commits) nohz: Include local CPU in full dynticks global kick nohz: Optimize full dynticks's sched hooks with static keys nohz: Optimize full dynticks state checks with static keys nohz: Rename a few state variables vtime: Always debug check snapshot source _before_ updating it vtime: Always scale generic vtime accounting results vtime: Optimize full dynticks accounting off case with static keys vtime: Describe overriden functions in dedicated arch headers m68k: hardirq_count() only need preempt_mask.h hardirq: Split preempt count mask definitions context_tracking: Split low level state headers vtime: Fix racy cputime delta update vtime: Remove a few unneeded generic vtime state checks context_tracking: User/kernel broundary cross trace events context_tracking: Optimize context switch off case with static keys context_tracking: Optimize guest APIs off case with static key context_tracking: Optimize main APIs off case with static key context_tracking: Ground setup for static key use context_tracking: Remove full dynticks' hacky dependency on wide context tracking nohz: Only enable context tracking on full dynticks CPUs ...
2013-09-04Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: "Various optimizations, cleanups and smaller fixes - no major changes in scheduler behavior" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/fair: Fix the sd_parent_degenerate() code sched/fair: Rework and comment the group_imb code sched/fair: Optimize find_busiest_queue() sched/fair: Make group power more consistent sched/fair: Remove duplicate load_per_task computations sched/fair: Shrink sg_lb_stats and play memset games sched: Clean-up struct sd_lb_stat sched: Factor out code to should_we_balance() sched: Remove one division operation in find_busiest_queue() sched/cputime: Use this_cpu_add() in task_group_account_field() cpumask: Fix cpumask leak in partition_sched_domains() sched/x86: Optimize switch_mm() for multi-threaded workloads generic-ipi: Kill unnecessary variable - csd_flags numa: Mark __node_set() as __always_inline sched/fair: Cleanup: remove duplicate variable declaration sched/__wake_up_sync_key(): Fix nr_exclusive tasks which lead to WF_SYNC clearing
2013-09-04Merge branches 'perf-urgent-for-linus' and 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf changes from Ingo Molnar: "As a first remark I'd like to point out that the obsolete '-f' (--force) option, which has not done anything for several releases, has been removed from 'perf record' and related utilities. Everyone please update muscle memory accordingly! :-) Main changes on the perf kernel side: - Performance optimizations: . for trace events, by Steve Rostedt. . for time values, by Peter Zijlstra - New hardware support: . for Intel Silvermont (22nm Atom) CPUs, by Zheng Yan . for Intel SNB-EP uncore PMUs, by Zheng Yan - Enhanced hardware support: . for Intel uncore PMUs: add filter support for QPI boxes, by Zheng Yan - Core perf events code enhancements and fixes: . for full-nohz feature handling, by Frederic Weisbecker . for group events, by Jiri Olsa . for call chains, by Frederic Weisbecker . for event stream parsing, by Adrian Hunter - New ABI details: . Add attr->mmap2 attribute, by Stephane Eranian . Add PERF_EVENT_IOC_ID ioctl to return event ID, by Jiri Olsa . Export u64 time_zero on the mmap header page to allow TSC calculation, by Adrian Hunter . Add dummy software event, by Adrian Hunter. . Add a new PERF_SAMPLE_IDENTIFIER to make samples always parseable, by Adrian Hunter. . Make Power7 events available via sysfs, by Runzhen Wang. - Code cleanups and refactorings: . for nohz-full, by Frederic Weisbecker . for group events, by Jiri Olsa - Documentation updates: . for perf_event_type, by Peter Zijlstra Main changes on the perf tooling side (some of these tooling changes utilize the above kernel side changes): - Lots of 'perf trace' enhancements: . Make 'perf trace' command line arguments consistent with 'perf record', by David Ahern. . Allow specifying syscalls a la strace, by Arnaldo Carvalho de Melo. . Add --verbose and -o/--output options, by Arnaldo Carvalho de Melo. . Support ! in -e expressions, to filter a list of syscalls, by Arnaldo Carvalho de Melo. . Arg formatting improvements to allow masking arguments in syscalls such as futex and open, where the some arguments are ignored and thus should not be printed depending on other args, by Arnaldo Carvalho de Melo. . Beautify futex open, openat, open_by_handle_at, lseek and futex syscalls, by Arnaldo Carvalho de Melo. . Add option to analyze events in a file versus live, so that one can do: [root@zoo ~]# perf record -a -e raw_syscalls:* sleep 1 [ perf record: Woken up 0 times to write data ] [ perf record: Captured and wrote 25.150 MB perf.data (~1098836 samples) ] [root@zoo ~]# perf trace -i perf.data -e futex --duration 1 17.799 ( 1.020 ms): 7127 futex(uaddr: 0x7fff3f6c6674, op: 393, val: 1, utime: 0x7fff3f6c6470, ua 113.344 (95.429 ms): 7127 futex(uaddr: 0x7fff3f6c6674, op: 393, val: 1, utime: 0x7fff3f6c6470, uaddr2: 0x7fff3f6c6648, val3: 4294967 133.778 ( 1.042 ms): 18004 futex(uaddr: 0x7fff3f6c6674, op: 393, val: 1, utime: 0x7fff3f6c6470, uaddr2: 0x7fff3f6c6648, val3: 429496 [root@zoo ~]# By David Ahern. . Honor target pid / tid options when analyzing a file, by David Ahern. . Introduce better formatting of syscall arguments, including so far beautifiers for mmap, madvise, syscall return values, by Arnaldo Carvalho de Melo. . Handle HUGEPAGE defines in the mmap beautifier, by David Ahern. - 'perf report/top' enhancements: . Do annotation using /proc/kcore and /proc/kallsyms when available, removing the forced need for a vmlinux file kernel assembly annotation. This also improves this use case because vmlinux has just the initial kernel image, not what is actually in use after various code patchings by things like alternatives. By Adrian Hunter. . Add --ignore-callees=<regex> option to collapse undesired parts of call graphs, by Greg Price. . Simplify symbol filtering by doing it at machine class level, by Adrian Hunter. . Add support for callchains in the gtk UI, by Namhyung Kim. . Add --objdump option to 'perf top', by Sukadev Bhattiprolu. - 'perf kvm' enhancements: . Add option to print only events that exceed a specified time duration, by David Ahern. . Improve stack trace printing, by David Ahern. . Update documentation of the live command, by David Ahern . Add perf kvm stat live mode that combines aspects of 'perf kvm stat' record and report, by David Ahern. . Add option to analyze specific VM in perf kvm stat report, by David Ahern. . Do not require /lib/modules/* on a guest, by Jason Wessel. - 'perf script' enhancements: . Fix symbol offset computation for some dsos, by David Ahern. . Fix named threads support, by David Ahern. . Don't install scripting files files when perl/python support is disabled, by Arnaldo Carvalho de Melo. - 'perf test' enhancements: . Add various improvements and fixes to the "vmlinux matches kallsyms" 'perf test' entry, related to the /proc/kcore annotation feature. By Adrian Hunter. . Add sample parsing test, by Adrian Hunter. . Add test for reading object code, by Adrian Hunter. . Add attr record group sampling test, by Jiri Olsa. . Misc testing infrastructure improvements and other details, by Jiri Olsa. - 'perf list' enhancements: . Skip unsupported hardware events, by Namhyung Kim. . List pmu events, by Andi Kleen. - 'perf diff' enhancements: . Add support for more than two files comparison, by Jiri Olsa. - 'perf sched' enhancements: . Various improvements, including removing reliance on some scheduler tracepoints that provide the same information as the PERF_RECORD_{FORK,EXIT} events. By David Ahern. . Remove odd build stall by moving a large struct initialization from a local variable to a global one, by Namhyung Kim. - 'perf stat' enhancements: . Add --initial-delay option to skip measuring for a defined startup phase, by Andi Kleen. - Generic perf tooling infrastructure/plumbing changes: . Tidy up sample parsing validation, by Adrian Hunter. . Fix up jobserver setup in libtraceevent Makefile. by Arnaldo Carvalho de Melo. . Debug improvements, by Adrian Hunter. . Fix correlation of samples coming after PERF_RECORD_EXIT event, by David Ahern. . Improve robustness of the topology parsing code, by Stephane Eranian. . Add group leader sampling, that allows just one event in a group to sample while the other events have just its values read, by Jiri Olsa. . Add support for a new modifier "D", which requests that the event, or group of events, be pinned to the PMU. By Michael Ellerman. . Support callchain sorting based on addresses, by Andi Kleen . Prep work for multi perf data file storage, by Jiri Olsa. . libtraceevent cleanups, by Namhyung Kim. And lots and lots of other fixes and code reorganizations that did not make it into the list, see the shortlog, diffstat and the Git log for details!" [ Also merge a leftover from the 3.11 cycle ] * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf: Prevent race in unthrottling code * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (237 commits) perf trace: Tell arg formatters the arg index perf trace: Add beautifier for open's flags arg perf trace: Add beautifier for lseek's whence arg perf tools: Fix symbol offset computation for some dsos perf list: Skip unsupported events perf tests: Add 'keep tracking' test perf tools: Add support for PERF_COUNT_SW_DUMMY perf: Add a dummy software event to keep tracking perf trace: Add beautifier for futex 'operation' parm perf trace: Allow syscall arg formatters to mask args perf: Convert kmalloc_node(...GFP_ZERO...) to kzalloc_node() perf: Export struct perf_branch_entry to userspace perf: Add attr->mmap2 attribute to an event perf/x86: Add Silvermont (22nm Atom) support perf/x86: use INTEL_UEVENT_EXTRA_REG to define MSR_OFFCORE_RSP_X perf trace: Handle missing HUGEPAGE defines perf trace: Honor target pid / tid options when analyzing a file perf trace: Add option to analyze events in a file versus live perf evlist: Add tracepoint lookup by name perf tests: Add a sample parsing test ...
2013-09-04sched/cputime: Do not scale when utime == 0Stanislaw Gruszka
scale_stime() silently assumes that stime < rtime, otherwise when stime == rtime and both values are big enough (operations on them do not fit in 32 bits), the resulting scaling stime can be bigger than rtime. In consequence utime = rtime - stime results in negative value. User space visible symptoms of the bug are overflowed TIME values on ps/top, for example: $ ps aux | grep rcu root 8 0.0 0.0 0 0 ? S 12:42 0:00 [rcuc/0] root 9 0.0 0.0 0 0 ? S 12:42 0:00 [rcub/0] root 10 62422329 0.0 0 0 ? R 12:42 21114581:37 [rcu_preempt] root 11 0.1 0.0 0 0 ? S 12:42 0:02 [rcuop/0] root 12 62422329 0.0 0 0 ? S 12:42 21114581:35 [rcuop/1] root 10 62422329 0.0 0 0 ? R 12:42 21114581:37 [rcu_preempt] or overflowed utime values read directly from /proc/$PID/stat Reference: https://lkml.org/lkml/2013/8/20/259 Reported-and-tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Cc: stable@vger.kernel.org Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Borislav Petkov <bp@alien8.de> Link: http://lkml.kernel.org/r/20130904131602.GC2564@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-03Merge branch 'for-3.12' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup updates from Tejun Heo: "A lot of activities on the cgroup front. Most changes aren't visible to userland at all at this point and are laying foundation for the planned unified hierarchy. - The biggest change is decoupling the lifetime management of css (cgroup_subsys_state) from that of cgroup's. Because controllers (cpu, memory, block and so on) will need to be dynamically enabled and disabled, css which is the association point between a cgroup and a controller may come and go dynamically across the lifetime of a cgroup. Till now, css's were created when the associated cgroup was created and stayed till the cgroup got destroyed. Assumptions around this tight coupling permeated through cgroup core and controllers. These assumptions are gradually removed, which consists bulk of patches, and css destruction path is completely decoupled from cgroup destruction path. Note that decoupling of creation path is relatively easy on top of these changes and the patchset is pending for the next window. - cgroup has its own event mechanism cgroup.event_control, which is only used by memcg. It is overly complex trying to achieve high flexibility whose benefits seem dubious at best. Going forward, new events will simply generate file modified event and the existing mechanism is being made specific to memcg. This pull request contains prepatory patches for such change. - Various fixes and cleanups" Fixed up conflict in kernel/cgroup.c as per Tejun. * 'for-3.12' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (69 commits) cgroup: fix cgroup_css() invocation in css_from_id() cgroup: make cgroup_write_event_control() use css_from_dir() instead of __d_cgrp() cgroup: make cgroup_event hold onto cgroup_subsys_state instead of cgroup cgroup: implement CFTYPE_NO_PREFIX cgroup: make cgroup_css() take cgroup_subsys * instead and allow NULL subsys cgroup: rename cgroup_css_from_dir() to css_from_dir() and update its syntax cgroup: fix cgroup_write_event_control() cgroup: fix subsystem file accesses on the root cgroup cgroup: change cgroup_from_id() to css_from_id() cgroup: use css_get() in cgroup_create() to check CSS_ROOT cpuset: remove an unncessary forward declaration cgroup: RCU protect each cgroup_subsys_state release cgroup: move subsys file removal to kill_css() cgroup: factor out kill_css() cgroup: decouple cgroup_subsys_state destruction from cgroup destruction cgroup: replace cgroup->css_kill_cnt with ->nr_css cgroup: bounce cgroup_subsys_state ref kill confirmation to a work item cgroup: move cgroup->subsys[] assignment to online_css() cgroup: reorganize css init / exit paths cgroup: add __rcu modifier to cgroup->subsys[] ...
2013-09-02sched/fair: Fix the sd_parent_degenerate() codePeter Zijlstra
I found that on my WSM box I had a redundant domain: [ 0.949769] CPU0 attaching sched-domain: [ 0.953765] domain 0: span 0,12 level SIBLING [ 0.958335] groups: 0 (cpu_power = 587) 12 (cpu_power = 588) [ 0.964548] domain 1: span 0-5,12-17 level MC [ 0.969206] groups: 0,12 (cpu_power = 1175) 1,13 (cpu_power = 1176) 2,14 (cpu_power = 1176) 3,15 (cpu_power = 1176) 4,16 (cpu_power = 1176) 5,17 (cpu_power = 1176) [ 0.984993] domain 2: span 0-5,12-17 level CPU [ 0.989822] groups: 0-5,12-17 (cpu_power = 7055) [ 0.995049] domain 3: span 0-23 level NUMA [ 0.999620] groups: 0-5,12-17 (cpu_power = 7055) 6-11,18-23 (cpu_power = 7056) Note how domain 2 has only a single group and spans the same CPUs as domain 1. We should not keep such domains and do in fact have code to prune these. It turns out that the 'new' SD_PREFER_SIBLING flag causes this, it makes sd_parent_degenerate() fail on the CPU domain. We can easily fix this by 'ignoring' the SD_PREFER_SIBLING bit and transfering it to whatever domain ends up covering the span. With this patch the domains now look like this: [ 0.950419] CPU0 attaching sched-domain: [ 0.954454] domain 0: span 0,12 level SIBLING [ 0.959039] groups: 0 (cpu_power = 587) 12 (cpu_power = 588) [ 0.965271] domain 1: span 0-5,12-17 level MC [ 0.969936] groups: 0,12 (cpu_power = 1175) 1,13 (cpu_power = 1176) 2,14 (cpu_power = 1176) 3,15 (cpu_power = 1176) 4,16 (cpu_power = 1176) 5,17 (cpu_power = 1176) [ 0.985737] domain 2: span 0-23 level NUMA [ 0.990231] groups: 0-5,12-17 (cpu_power = 7055) 6-11,18-23 (cpu_power = 7056) Reviewed-by: Paul Turner <pjt@google.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-ys201g4jwukj0h8xcamakxq1@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-02sched/fair: Rework and comment the group_imb codePeter Zijlstra
Rik reported some weirdness due to the group_imb code. As a start to looking at it, clean it up a little and add a few explanatory comments. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-caeeqttnla4wrrmhp5uf89gp@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-02sched/fair: Optimize find_busiest_queue()Peter Zijlstra
Use for_each_cpu_and() and thereby avoid computing the capacity for CPUs we know we're not interested in. Reviewed-by: Paul Turner <pjt@google.com> Reviewed-by: Preeti U Murthy <preeti@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-lppceyv6kb3a19g8spmrn20b@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-02sched/fair: Make group power more consistentPeter Zijlstra
For easier access, less dereferences and more consistent value, store the group power in update_sg_lb_stats() and use it thereafter. The actual value in sched_group::sched_group_power::power can change throughout the load-balance pass if we're unlucky. Reviewed-by: Preeti U Murthy <preeti@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-739xxqkyvftrhnh9ncudutc7@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-02sched/fair: Remove duplicate load_per_task computationsPeter Zijlstra
Since we already compute (but don't store) the sgs load_per_task value in update_sg_lb_stats() we might as well store it and not re-compute it later on. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-ym1vmljiwbzgdnnrwp9azftq@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-02sched/fair: Shrink sg_lb_stats and play memset gamesPeter Zijlstra
We can shrink sg_lb_stats because rq::nr_running is an unsigned int and cpu numbers are 'int' Before: sgs: /* size: 72, cachelines: 2, members: 10 */ sds: /* size: 184, cachelines: 3, members: 7 */ After: sgs: /* size: 56, cachelines: 1, members: 10 */ sds: /* size: 152, cachelines: 3, members: 7 */ Further we can avoid clearing all of sds since we do a total clear/assignment of sg_stats in update_sg_lb_stats() with exception of busiest_stat.avg_load which is referenced in update_sd_pick_busiest(). Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-0klzmz9okll8wc0nsudguc9p@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-02sched: Clean-up struct sd_lb_statJoonsoo Kim
There is no reason to maintain separate variables for this_group and busiest_group in sd_lb_stat, except saving some space. But this structure is always allocated in stack, so this saving isn't really benificial [peterz: reducing stack space is good; in this case readability increases enough that I think its still beneficial] This patch unify these variables, so IMO, readability may be improved. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> [ Rename this to local -- avoids confusion between this_cpu and the C++ this pointer. ] Reviewed-by: Paul Turner <pjt@google.com> [ Lots of style edits, a few fixes and a rename. ] Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1375778203-31343-4-git-send-email-iamjoonsoo.kim@lge.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-02sched: Factor out code to should_we_balance()Joonsoo Kim
Now checking whether this cpu is appropriate to balance or not is embedded into update_sg_lb_stats() and this checking has no direct relationship to this function. There is not enough reason to place this checking at update_sg_lb_stats(), except saving one iteration for sched_group_cpus. In this patch, I factor out this checking to should_we_balance() function. And before doing actual work for load_balancing, check whether this cpu is appropriate to balance via should_we_balance(). If this cpu is not a candidate for balancing, it quit the work immediately. With this change, we can save two memset cost and can expect better compiler optimization. Below is result of this patch. * Vanilla * text data bss dec hex filename 34499 1136 116 35751 8ba7 kernel/sched/fair.o * Patched * text data bss dec hex filename 34243 1136 116 35495 8aa7 kernel/sched/fair.o In addition, rename @balance to @continue_balancing in order to represent its purpose more clearly. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> [ s/should_balance/continue_balancing/g ] Reviewed-by: Paul Turner <pjt@google.com> [ Made style changes and a fix in should_we_balance(). ] Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1375778203-31343-3-git-send-email-iamjoonsoo.kim@lge.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-02sched: Remove one division operation in find_busiest_queue()Joonsoo Kim
Remove one division operation in find_busiest_queue() by using crosswise multiplication: wl_i / power_i > wl_j / power_j := wl_i * power_j > wl_j * power_i Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> [ Expanded the changelog. ] Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1375778203-31343-2-git-send-email-iamjoonsoo.kim@lge.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-08-29Merge branch 'linus' into perf/coreIngo Molnar
Pick up the latest upstream fixes. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-08-16sched/cputime: Use this_cpu_add() in task_group_account_field()Christoph Lameter
Use of a this_cpu() operation reduces the number of instructions used for accounting (account_user_time()) and frees up some registers. This is in the scheduler tick hotpath. Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/00000140596dd165-338ff7f5-893b-4fec-b251-aaac5557239e-000000@email.amazonses.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-08-16cpumask: Fix cpumask leak in partition_sched_domains()Xiaotian Feng
If doms_new is NULL, partition_sched_domains() will reset ndoms_cur to 0, and free old sched domains with free_sched_domains(doms_cur, ndoms_cur). As ndoms_cur is 0, the cpumask will not be freed. Signed-off-by: Xiaotian Feng <xtfeng@gmail.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: linux-kernel@vger.kernel.org Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1375790802-11857-1-git-send-email-xtfeng@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-08-16Merge tag 'v3.11-rc5' into sched/coreIngo Molnar
Merge Linux 3.11-rc5, to pick up the latest fixes. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-08-15Merge tag 'v3.11-rc5' into perf/coreIngo Molnar
Merge Linux 3.11-rc5, to sync up with the latest upstream fixes since -rc1. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-08-14Merge branch 'timers/nohz-v3' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/linux-dynticks into timers/nohz Pull nohz improvements from Frederic Weisbecker: " It mostly contains fixes and full dynticks off-case optimizations. I believe that distros want to enable this feature so it seems important to optimize the case where the "nohz_full=" parameter is empty. ie: I'm trying to remove any performance regression that comes with NO_HZ_FULL=y when the feature is not used. This patchset improves the current situation a lot (off-case appears to be around 11% faster with hackbench, although I guess it may vary depending on the configuration but it should be significantly faster in any case) now there is still some work to do: I can still observe a remaining loss of 1.6% throughput seen with hackbench compared to CONFIG_NO_HZ_FULL=n. " Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-08-14vtime: Always debug check snapshot source _before_ updating itFrederic Weisbecker
The vtime delta update performed by get_vtime_delta() always check that the source of the snapshot is valid. Meanhile the snapshot updaters that rely on get_vtime_delta() also set the new snapshot origin. But some of them do this right before the call to get_vtime_delta(), making its debug check useless. This is easily fixable by moving the snapshot origin update after the call to get_vtime_delta(). The order doesn't matter there. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Kevin Hilman <khilman@linaro.org>
2013-08-14vtime: Always scale generic vtime accounting resultsFrederic Weisbecker
The cputime accounting in full dynticks can be a subtle mixup of CPUs using tick based accounting and others using generic vtime. As long as the tick can have a share on producing these stats, we want to scale the result against CFS precise accounting as the tick can miss some task hiding between the periodic interrupt. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Kevin Hilman <khilman@linaro.org>
2013-08-14vtime: Optimize full dynticks accounting off case with static keysFrederic Weisbecker
If no CPU is in the full dynticks range, we can avoid the full dynticks cputime accounting through generic vtime along with its overhead and use the traditional tick based accounting instead. Let's do this and nope the off case with static keys. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Kevin Hilman <khilman@linaro.org>
2013-08-14vtime: Fix racy cputime delta updateFrederic Weisbecker
get_vtime_delta() must be called under the task vtime_seqlock with the code that does the cputime accounting flush. Otherwise the cputime reader can be fooled and run into a race where it sees the snapshot update but misses the cputime flush. As a result it can report a cputime that is way too short. Fix vtime_account_user() that wasn't complying to that rule. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Kevin Hilman <khilman@linaro.org>
2013-08-14vtime: Remove a few unneeded generic vtime state checksFrederic Weisbecker
Some generic vtime APIs check if the vtime accounting is enabled on the local CPU before doing their work. Some of these are not needed because all their callers already take care of that. Let's remove the checks on these. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Kevin Hilman <khilman@linaro.org>
2013-08-14context_tracking: Optimize guest APIs off case with static keyFrederic Weisbecker
Optimize guest entry/exit APIs with static keys. This minimize the overhead for those who enable CONFIG_NO_HZ_FULL without always using it. Having no range passed to nohz_full= should result in the probes overhead to be minimized. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Kevin Hilman <khilman@linaro.org>
2013-08-13Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar: "Docbook fixes that make 99% of the diffstat, plus a oneliner fix" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched: Ensure update_cfs_shares() is called for parents of continuously-running tasks sched: Fix some kernel-doc warnings
2013-08-13sched: fix the theoretical signal_wake_up() vs schedule() raceOleg Nesterov
This is only theoretical, but after try_to_wake_up(p) was changed to check p->state under p->pi_lock the code like __set_current_state(TASK_INTERRUPTIBLE); schedule(); can miss a signal. This is the special case of wait-for-condition, it relies on try_to_wake_up/schedule interaction and thus it does not need mb() between __set_current_state() and if(signal_pending). However, this __set_current_state() can move into the critical section protected by rq->lock, now that try_to_wake_up() takes another lock we need to ensure that it can't be reordered with "if (signal_pending(current))" check inside that section. The patch is actually one-liner, it simply adds smp_wmb() before spin_lock_irq(rq->lock). This is what try_to_wake_up() already does by the same reason. We turn this wmb() into the new helper, smp_mb__before_spinlock(), for better documentation and to allow the architectures to change the default implementation. While at it, kill smp_mb__after_lock(), it has no callers. Perhaps we can also add smp_mb__before/after_spinunlock() for prepare_to_wait(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-08-13vtime: Update a few commentsFrederic Weisbecker
Update a stale comment from the old vtime era and document some locking that might be non obvious. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Kevin Hilman <khilman@linaro.org>
2013-08-13sched: Consolidate open coded preemptible() checksFrederic Weisbecker
preempt_schedule() and preempt_schedule_context() open code their preemptability checks. Use the standard API instead for consolidation. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Li Zhong <zhong@linux.vnet.ibm.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Borislav Petkov <bp@alien8.de> Cc: Alex Shi <alex.shi@intel.com> Cc: Paul Turner <pjt@google.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Vincent Guittot <vincent.guittot@linaro.org>
2013-08-08cgroup: make cgroup_taskset deal with cgroup_subsys_state instead of cgroupTejun Heo
cgroup is in the process of converting to css (cgroup_subsys_state) from cgroup as the principal subsystem interface handle. This is mostly to prepare for the unified hierarchy support where css's will be created and destroyed dynamically but also helps cleaning up subsystem implementations as css is usually what they are interested in anyway. cgroup_taskset which is used by the subsystem attach methods is the last cgroup subsystem API which isn't using css as the handle. Update cgroup_taskset_cur_cgroup() to cgroup_taskset_cur_css() and cgroup_taskset_for_each() to take @skip_css instead of @skip_cgrp. The conversions are pretty mechanical. One exception is cpuset::cgroup_cs(), which lost its last user and got removed. This patch shouldn't introduce any functional changes. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org>
2013-08-08cgroup: pass around cgroup_subsys_state instead of cgroup in file methodsTejun Heo
cgroup is currently in the process of transitioning to using struct cgroup_subsys_state * as the primary handle instead of struct cgroup. Please see the previous commit which converts the subsystem methods for rationale. This patch converts all cftype file operations to take @css instead of @cgroup. cftypes for the cgroup core files don't have their subsytem pointer set. These will automatically use the dummy_css added by the previous patch and can be converted the same way. Most subsystem conversions are straight forwards but there are some interesting ones. * freezer: update_if_frozen() is also converted to take @css instead of @cgroup for consistency. This will make the code look simpler too once iterators are converted to use css. * memory/vmpressure: mem_cgroup_from_css() needs to be exported to vmpressure while mem_cgroup_from_cont() can be made static. Updated accordingly. * cpu: cgroup_tg() doesn't have any user left. Removed. * cpuacct: cgroup_ca() doesn't have any user left. Removed. * hugetlb: hugetlb_cgroup_form_cgroup() doesn't have any user left. Removed. * net_cls: cgrp_cls_state() doesn't have any user left. Removed. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Aristeu Rozanski <aris@redhat.com> Acked-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Steven Rostedt <rostedt@goodmis.org>
2013-08-08cgroup: pass around cgroup_subsys_state instead of cgroup in subsystem methodsTejun Heo
cgroup is currently in the process of transitioning to using struct cgroup_subsys_state * as the primary handle instead of struct cgroup * in subsystem implementations for the following reasons. * With unified hierarchy, subsystems will be dynamically bound and unbound from cgroups and thus css's (cgroup_subsys_state) may be created and destroyed dynamically over the lifetime of a cgroup, which is different from the current state where all css's are allocated and destroyed together with the associated cgroup. This in turn means that cgroup_css() should be synchronized and may return NULL, making it more cumbersome to use. * Differing levels of per-subsystem granularity in the unified hierarchy means that the task and descendant iterators should behave differently depending on the specific subsystem the iteration is being performed for. * In majority of the cases, subsystems only care about its part in the cgroup hierarchy - ie. the hierarchy of css's. Subsystem methods often obtain the matching css pointer from the cgroup and don't bother with the cgroup pointer itself. Passing around css fits much better. This patch converts all cgroup_subsys methods to take @css instead of @cgroup. The conversions are mostly straight-forward. A few noteworthy changes are * ->css_alloc() now takes css of the parent cgroup rather than the pointer to the new cgroup as the css for the new cgroup doesn't exist yet. Knowing the parent css is enough for all the existing subsystems. * In kernel/cgroup.c::offline_css(), unnecessary open coded css dereference is replaced with local variable access. This patch shouldn't cause any behavior differences. v2: Unnecessary explicit cgrp->subsys[] deref in css_online() replaced with local variable @css as suggested by Li Zefan. Rebased on top of new for-3.12 which includes for-3.11-fixes so that ->css_free() invocation added by da0a12caff ("cgroup: fix a leak when percpu_ref_init() fails") is converted too. Suggested by Li Zefan. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com> Acked-by: Michal Hocko <mhocko@suse.cz> Acked-by: Vivek Goyal <vgoyal@redhat.com> Acked-by: Aristeu Rozanski <aris@redhat.com> Acked-by: Daniel Wagner <daniel.wagner@bmw-carit.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Balbir Singh <bsingharora@gmail.com> Cc: Matt Helsley <matthltc@us.ibm.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Steven Rostedt <rostedt@goodmis.org>
2013-08-08cgroup: add css_parent()Tejun Heo
Currently, controllers have to explicitly follow the cgroup hierarchy to find the parent of a given css. cgroup is moving towards using cgroup_subsys_state as the main controller interface construct, so let's provide a way to climb the hierarchy using just csses. This patch implements css_parent() which, given a css, returns its parent. The function is guarnateed to valid non-NULL parent css as long as the target css is not at the top of the hierarchy. freezer, cpuset, cpu, cpuacct, hugetlb, memory, net_cls and devices are converted to use css_parent() instead of accessing cgroup->parent directly. * __parent_ca() is dropped from cpuacct and its usage is replaced with parent_ca(). The only difference between the two was NULL test on cgroup->parent which is now embedded in css_parent() making the distinction moot. Note that eventually a css->parent field will be added to css and the NULL check in css_parent() will go away. This patch shouldn't cause any behavior differences. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-08-08cgroup: add/update accessors which obtain subsys specific data from cssTejun Heo
css (cgroup_subsys_state) is usually embedded in a subsys specific data structure. Subsystems either use container_of() directly to cast from css to such data structure or has an accessor function wrapping such cast. As cgroup as whole is moving towards using css as the main interface handle, add and update such accessors to ease dealing with css's. All accessors explicitly handle NULL input and return NULL in those cases. While this looks like an extra branch in the code, as all controllers specific data structures have css as the first field, the casting doesn't involve any offsetting and the compiler can trivially optimize out the branch. * blkio, freezer, cpuset, cpu, cpuacct and net_cls didn't have such accessor. Added. * memory, hugetlb and devices already had one but didn't explicitly handle NULL input. Updated. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-08-08cgroup: s/cgroup_subsys_state/cgroup_css/ s/task_subsys_state/task_css/Tejun Heo
The names of the two struct cgroup_subsys_state accessors - cgroup_subsys_state() and task_subsys_state() - are somewhat awkward. The former clashes with the type name and the latter doesn't even indicate it's somehow related to cgroup. We're about to revamp large portion of cgroup API, so, let's rename them so that they're less awkward. Most per-controller usages of the accessors are localized in accessor wrappers and given the amount of scheduled changes, this isn't gonna add any noticeable headache. Rename cgroup_subsys_state() to cgroup_css() and task_subsys_state() to task_css(). This patch is pure rename. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Li Zefan <lizefan@huawei.com>
2013-07-31mm: sched: numa: fix NUMA balancing when !SCHED_DEBUGDave Kleikamp
Commit 3105b86a9fee ("mm: sched: numa: Control enabling and disabling of NUMA balancing if !SCHED_DEBUG") defined numabalancing_enabled to control the enabling and disabling of automatic NUMA balancing, but it is never used. I believe the intention was to use this in place of sched_feat_numa(NUMA). Currently, if SCHED_DEBUG is not defined, sched_feat_numa(NUMA) will never be changed from the initial "false". Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-30sched: Ensure update_cfs_shares() is called for parents of ↵Peter Zijlstra
continuously-running tasks We typically update a task_group's shares within the dequeue/enqueue path. However, continuously running tasks sharing a CPU are not subject to these updates as they are only put/picked. Unfortunately, when we reverted f269ae046 (in 17bc14b7), we lost the augmenting periodic update that was supposed to account for this; resulting in a potential loss of fairness. To fix this, re-introduce the explicit update in update_cfs_rq_blocked_load() [called via entity_tick()]. Reported-by: Max Hailperin <max@gustavus.edu> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Reviewed-by: Paul Turner <pjt@google.com> Link: http://lkml.kernel.org/n/tip-9545m3apw5d93ubyrotrj31y@git.kernel.org Cc: <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-07-23sched: Micro-optimize the smart wake-affine logicPeter Zijlstra
Smart wake-affine is using node-size as the factor currently, but the overhead of the mask operation is high. Thus, this patch introduce the 'sd_llc_size' percpu variable, which will record the highest cache-share domain size, and make it to be the new factor, in order to reduce the overhead and make it more reasonable. Tested-by: Davidlohr Bueso <davidlohr.bueso@hp.com> Tested-by: Michael Wang <wangyun@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Michael Wang <wangyun@linux.vnet.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Link: http://lkml.kernel.org/r/51D5008E.6030102@linux.vnet.ibm.com [ Tidied up the changelog. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
