invalid ones
commit 6c9a27f5da9609fca46cb2b183724531b48f71ad upstream.
There is a small race between copy_process() and cgroup_attach_task()
where child->se.parent,cfs_rq points to invalid (old) ones.
parent doing fork() | someone moving the parent to another cgroup
copy_process()
+ dup_task_struct()
-> parent->se is copied to child->se.
se.parent,cfs_rq of them point to old ones.
+ cgroup_task_migrate()
-> parent->cgroup is updated.
+ cpu_cgroup_attach()
+ sched_move_task()
+ task_move_group_fair()
+- set_task_rq()
-> se.parent,cfs_rq of parent
are updated.
+ cgroup_fork()
-> parent->cgroup is copied to child->cgroup. (*1)
+ sched_fork()
+ task_fork_fair()
-> se.parent,cfs_rq of child are accessed
while they point to old ones. (*2)
In the worst case, this bug can lead to "use-after-free" and cause a panic,
because it's new cgroup's refcount that is incremented at (*1),
so the old cgroup(and related data) can be freed before (*2).
In fact, a panic caused by this bug was originally caught in RHEL6.4.
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff81051e3e>] sched_slice+0x6e/0xa0
Call Trace:
[<ffffffff81051f25>] place_entity+0x75/0xa0
[<ffffffff81056a3a>] task_fork_fair+0xaa/0x160
[<ffffffff81063c0b>] sched_fork+0x6b/0x140
[<ffffffff8106c3c2>] copy_process+0x5b2/0x1450
[<ffffffff81063b49>] ? wake_up_new_task+0xd9/0x130
[<ffffffff8106d2f4>] do_fork+0x94/0x460
[<ffffffff81072a9e>] ? sys_wait4+0xae/0x100
[<ffffffff81009598>] sys_clone+0x28/0x30
[<ffffffff8100b393>] stub_clone+0x13/0x20
[<ffffffff8100b072>] ? system_call_fastpath+0x16/0x1b
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/039601ceae06$733d3130$59b79390$@mxp.nes.nec.co.jp
commit 5a8e01f8fa51f5cbce8f37acc050eb2319d12956 upstream.
scale_stime() silently assumes that stime < rtime, otherwise
when stime == rtime and both values are big enough (operations
on them do not fit in 32 bits), the resulting scaling stime can
be bigger than rtime. In consequence utime = rtime - stime
results in negative value.
User space visible symptoms of the bug are overflowed TIME
values on ps/top, for example:
$ ps aux | grep rcu
root 8 0.0 0.0 0 0 ? S 12:42 0:00 [rcuc/0]
root 9 0.0 0.0 0 0 ? S 12:42 0:00 [rcub/0]
root 10 62422329 0.0 0 0 ? R 12:42 21114581:37 [rcu_preempt]
root 11 0.1 0.0 0 0 ? S 12:42 0:02 [rcuop/0]
root 12 62422329 0.0 0 0 ? S 12:42 21114581:35 [rcuop/1]
or overflowed utime values read directly from /proc/$PID/stat
Reference:
https://lkml.org/lkml/2013/8/20/259
Reported-and-tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Cc: stable@vger.kernel.org
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20130904131602.GC2564@redhat.com
Pull scheduler fixes from Ingo Molnar:
"Docbook fixes that make 99% of the diffstat, plus a oneliner fix"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
sched: Ensure update_cfs_shares() is called for parents of continuously-running tasks
sched: Fix some kernel-doc warnings
This is only theoretical, but after try_to_wake_up(p) was changed
to check p->state under p->pi_lock the code like
__set_current_state(TASK_INTERRUPTIBLE);
schedule();
can miss a signal. This is the special case of wait-for-condition,
it relies on try_to_wake_up/schedule interaction and thus it does
not need mb() between __set_current_state() and if(signal_pending).
However, this __set_current_state() can move into the critical
section protected by rq->lock, now that try_to_wake_up() takes
another lock we need to ensure that it can't be reordered with
"if (signal_pending(current))" check inside that section.
The patch is actually one-liner, it simply adds smp_wmb() before
spin_lock_irq(rq->lock). This is what try_to_wake_up() already
does by the same reason.
We turn this wmb() into the new helper, smp_mb__before_spinlock(),
for better documentation and to allow the architectures to change
the default implementation.
While at it, kill smp_mb__after_lock(), it has no callers.
Perhaps we can also add smp_mb__before/after_spinunlock() for
prepare_to_wait().
Acked-by: Peter Zijlstra <peterz@infradead.org>
Commit 3105b86a9fee ("mm: sched: numa: Control enabling and disabling of
NUMA balancing if !SCHED_DEBUG") defined numabalancing_enabled to
control the enabling and disabling of automatic NUMA balancing, but it
is never used.
I believe the intention was to use this in place of sched_feat_numa(NUMA).
Currently, if SCHED_DEBUG is not defined, sched_feat_numa(NUMA) will
never be changed from the initial "false".
Signed-off-by: Dave Kleikamp <dave.kleikamp@oracle.com>
We typically update a task_group's shares within the dequeue/enqueue
path. However, continuously running tasks sharing a CPU are not
subject to these updates as they are only put/picked. Unfortunately,
when we reverted f269ae046 (in 17bc14b7), we lost the augmenting
periodic update that was supposed to account for this; resulting in a
potential loss of fairness.
To fix this, re-introduce the explicit update in
update_cfs_rq_blocked_load() [called via entity_tick()].
Reported-by: Max Hailperin <max@gustavus.edu>
Reviewed-by: Paul Turner <pjt@google.com>
Link: http://lkml.kernel.org/n/tip-9545m3apw5d93ubyrotrj31y@git.kernel.org
Cc: <stable@kernel.org>
When building the htmldocs (in verbose mode), scripts/kernel-doc
reports the follwing type of warnings:
Warning(kernel/sched/core.c:936): No description found for return value of 'task_curr'
Fix those by:
- adding the missing descriptions
- using "Return" sections for the descriptions
Signed-off-by: Yacine Belkadi <yacine.belkadi.1@gmail.com>
Link: http://lkml.kernel.org/r/1373654747-2389-1-git-send-email-yacine.belkadi.1@gmail.com
[ While at it, fix the cpupri_set() explanation. ]
The __cpuinit type of throwaway sections might have made sense
some time ago when RAM was more constrained, but now the savings
do not offset the cost and complications. For example, the fix in
commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time")
is a good example of the nasty type of bugs that can be created
with improper use of the various __init prefixes.
After a discussion on LKML[1] it was decided that cpuinit should go
the way of devinit and be phased out. Once all the users are gone,
we can then finally remove the macros themselves from linux/init.h.
This removes all the uses of the __cpuinit macros from C files in
the core kernel directories (kernel, init, lib, mm, and include)
that don't really have a specific maintainer.
[1] https://lkml.org/lkml/2013/5/20/589
David reported that the HRTICK sched feature was borken; which was enough
motivation for me to finally fix it ;-)
We should not allow hrtimer code to do softirq wakeups while holding scheduler
locks. The hrtimer code only needs this when we accidentally try to program an
expired time. We don't much care about those anyway since we have the regular
tick to fall back to.
Reported-by: David Ahern <dsahern@gmail.com>
Tested-by: David Ahern <dsahern@gmail.com>
Link: http://lkml.kernel.org/r/20130628091853.GE29209@dyad.programming.kicks-ass.net
Pull timer core updates from Thomas Gleixner:
"The timer changes contain:
- posix timer code consolidation and fixes for odd corner cases
- sched_clock implementation moved from ARM to core code to avoid
duplication by other architectures
- alarm timer updates
- clocksource and clockevents unregistration facilities
- clocksource/events support for new hardware
- precise nanoseconds RTC readout (Xen feature)
- generic support for Xen suspend/resume oddities
- the usual lot of fixes and cleanups all over the place
The parts which touch other areas (ARM/XEN) have been coordinated with
the relevant maintainers. Though this results in an handful of
trivial to solve merge conflicts, which we preferred over nasty cross
tree merge dependencies.
The patches which have been committed in the last few days are bug
fixes plus the posix timer lot. The latter was in akpms queue and
next for quite some time; they just got forgotten and Frederic
collected them last minute."
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (59 commits)
hrtimer: Remove unused variable
hrtimers: Move SMP function call to thread context
clocksource: Reselect clocksource when watchdog validated high-res capability
posix-cpu-timers: don't account cpu timer after stopped thread runtime accounting
posix_timers: fix racy timer delta caching on task exit
posix-timers: correctly get dying task time sample in posix_cpu_timer_schedule()
selftests: add basic posix timers selftests
posix_cpu_timers: consolidate expired timers check
posix_cpu_timers: consolidate timer list cleanups
posix_cpu_timer: consolidate expiry time type
tick: Sanitize broadcast control logic
tick: Prevent uncontrolled switch to oneshot mode
tick: Make oneshot broadcast robust vs. CPU offlining
x86: xen: Sync the CMOS RTC as well as the Xen wallclock
x86: xen: Sync the wallclock when the system time is set
timekeeping: Indicate that clock was set in the pvclock gtod notifier
timekeeping: Pass flags instead of multiple bools to timekeeping_update()
xen: Remove clock_was_set() call in the resume path
hrtimers: Support resuming with two or more CPUs online (but stopped)
timer: Fix jiffies wrap behavior of round_jiffies_common()
accounting
When tsk->signal->cputimer->running is 1, signal->cputimer (i.e. per process
timer account) and tsk->sum_sched_runtime (i.e. per thread timer account)
increase at the same pace because update_curr() increases both accounting.
However, there is one exception. When thread exiting, __exit_signal() turns
over task's sum_shced_runtime to sig->sum_sched_runtime, but it doesn't stop
signal->cputimer accounting.
This inconsistency makes POSIX timer wake up too early. This patch fixes it.
Original-patch-by: Olivier Langlois <olivier@trillion01.com>
Signed-off-by: Olivier Langlois <olivier@trillion01.com>
Merge in a recent upstream commit:
c2853c8df57f include/linux/math64.h: add div64_ul()
because:
72a4cf20cb71 sched: Change cfs_rq load avg to unsigned long
relies on it.
[ We don't rebase sched/core for this, because the handful of
followup commits after the broken commit are not behavioral
changes so are unlikely to be needed during bisection. ]
Now that we are using runnable load avg in sched balance, we don't
need to keep it under CONFIG_FAIR_GROUP_SCHED.
Also align the code style to #ifdef instead of #if defined() and
reorder the tg output info.
Signed-off-by: Alex Shi <alex.shi@intel.com>
Cc: pjt@google.com
Cc: kamalesh@linux.vnet.ibm.com
Cc: peterz@infradead.org
Link: http://lkml.kernel.org/r/1372417835-4698-1-git-send-email-alex.shi@intel.com
This patch alters format string's width, to align all statistics
at par with the longest struct sched_statistic member name under
/proc/<PID>/sched.
Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20130627165005.GA15583@linux.vnet.ibm.com
Fix spelling of 'calling' in description of se flags in
enqueue_entity().
Link: http://lkml.kernel.org/r/20130627055418.GA18582@linux.vnet.ibm.com
At present we print per-entity load-tracking statistics for
cfs_rq of cgroups/runqueues. Given that per task statistics
is maintained, it can be used to know the contribution made
by the task to its parenting cfs_rq level.
This patch adds per-task load-tracking statistics to /proc/<PID>/sched.
Link: http://lkml.kernel.org/r/20130625080336.GA20175@linux.vnet.ibm.com
Based-on-patch-by: Fengguang Wu <fengguang.wu@intel.com>
Tested-by: Vincent Guittot <vincent.guittot@linaro.org>
Link: http://lkml.kernel.org/r/1371694737-29336-14-git-send-email-alex.shi@intel.com
Since no one use it.
Link: http://lkml.kernel.org/r/1371694737-29336-13-git-send-email-alex.shi@intel.com
Similar to runnable_load_avg, blocked_load_avg variable, long type is
enough for removed_load in 64 bit or 32 bit machine.
Then we avoid the expensive atomic64 operations on 32 bit machine.
Link: http://lkml.kernel.org/r/1371694737-29336-12-git-send-email-alex.shi@intel.com
Since tg->load_avg is smaller than tg->load_weight, we don't need a
atomic64_t variable for load_avg in 32 bit machine.
The same reason for cfs_rq->tg_load_contrib.
The atomic_long_t/unsigned long variable type are more efficient and
convenience for them.
Link: http://lkml.kernel.org/r/1371694737-29336-11-git-send-email-alex.shi@intel.com
Since the 'u64 runnable_load_avg, blocked_load_avg' in cfs_rq struct are
smaller than 'unsigned long' cfs_rq->load.weight. We don't need u64
vaiables to describe them. unsigned long is more efficient and convenience.
Link: http://lkml.kernel.org/r/1371694737-29336-10-git-send-email-alex.shi@intel.com
Aside from using runnable load average in background, move_tasks is
also the key function in load balance. We need consider the runnable
load average in it in order to make it an apple to apple load
comparison.
Morten had caught a div u64 bug on ARM, thanks!
Thanks-to: Morten Rasmussen <morten.rasmussen@arm.com>
Link: http://lkml.kernel.org/r/1371694737-29336-8-git-send-email-alex.shi@intel.com
They are the base values in load balance, update them with rq runnable
load average, then the load balance will consider runnable load avg
naturally.
We also try to include the blocked_load_avg as cpu load in balancing,
but that cause kbuild performance drop 6% on every Intel machine, and
aim7/oltp drop on some of 4 CPU sockets machines.
Or only add blocked_load_avg into get_rq_runable_load, hackbench still
drop a little on NHM EX.
Reviewed-by: Gu Zheng <guz.fnst@cn.fujitsu.com>
Link: http://lkml.kernel.org/r/1371694737-29336-7-git-send-email-alex.shi@intel.com
To get the latest runnable info, we need do this cpuload update after
task_tick.
Link: http://lkml.kernel.org/r/1371694737-29336-6-git-send-email-alex.shi@intel.com
The woken migrated task will __synchronize_entity_decay(se); in
migrate_task_rq_fair, then it needs to set
`se->avg.last_runnable_update -= (-se->avg.decay_count) << 20' before
update_entity_load_avg, in order to avoid sleep time is updated twice
for se.avg.load_avg_contrib in both __syncchronize and
update_entity_load_avg.
However if the sleeping task is woken up from the same cpu, it miss
the last_runnable_update before update_entity_load_avg(se, 0, 1), then
the sleep time was used twice in both functions. So we need to remove
the double sleep time accounting.
Paul also contributed some code comments in this commit.
Link: http://lkml.kernel.org/r/1371694737-29336-5-git-send-email-alex.shi@intel.com
We need to initialize the se.avg.{decay_count, load_avg_contrib} for a
new forked task. Otherwise random values of above variables cause a
mess when a new task is enqueued:
enqueue_task_fair
enqueue_entity
enqueue_entity_load_avg
and make fork balancing imbalance due to incorrect load_avg_contrib.
Further more, Morten Rasmussen notice some tasks were not launched at
once after created. So Paul and Peter suggest giving a start value for
new task runnable avg time same as sched_slice().
PeterZ said:
> So the 'problem' is that our running avg is a 'floating' average; ie. it
> decays with time. Now we have to guess about the future of our newly
> spawned task -- something that is nigh impossible seeing these CPU
> vendors keep refusing to implement the crystal ball instruction.
> So there's two asymptotic cases we want to deal well with; 1) the case
> where the newly spawned program will be 'nearly' idle for its lifetime;
> and 2) the case where its cpu-bound.
> Since we have to guess, we'll go for worst case and assume its
> cpu-bound; now we don't want to make the avg so heavy adjusting to the
> near-idle case takes forever. We want to be able to quickly adjust and
> lower our running avg.
> Now we also don't want to make our avg too light, such that it gets
> decremented just for the new task not having had a chance to run yet --
> even if when it would run, it would be more cpu-bound than not.
> So what we do is we make the initial avg of the same duration as that we
> guess it takes to run each task on the system at least once -- aka
> sched_slice().
> Of course we can defeat this with wakeup/fork bombs, but in the 'normal'
> case it should be good enough.
Paul also contributed most of the code comments in this commit.
[peterz; added explanation of sched_slice() usage]
Link: http://lkml.kernel.org/r/1371694737-29336-4-git-send-email-alex.shi@intel.com
The following 2 variables are only used under CONFIG_SMP, so its
better to move their definiation into CONFIG_SMP too.
atomic64_t load_avg;
atomic_t runnable_avg;
Link: http://lkml.kernel.org/r/1371694737-29336-3-git-send-email-alex.shi@intel.com
load-tracking"
Remove CONFIG_FAIR_GROUP_SCHED that covers the runnable info, then
we can use runnable load variables.
Also remove 2 CONFIG_FAIR_GROUP_SCHED setting which is not in reverted
patch(introduced in 9ee474f), but also need to revert.
Link: http://lkml.kernel.org/r/51CA76A3.3050207@intel.com
"Two smaller fixes - plus a context tracking tracing fix that is a bit
bigger"
tracing/context-tracking: Add preempt_schedule_context() for tracing
sched: Fix clear NOHZ_BALANCE_KICK
sched/x86: Construct all sibling maps if smt
Just use struct ctl_table.
Link: http://lkml.kernel.org/r/1371063336.2069.22.camel@joe-AO722
sd can't be NULL in init_sched_groups_power() and so checking it for NULL isn't
useful. In case it is required, then also we need to rearrange the code a bit as
we already accessed invalid pointer sd to get sg: sg = sd->groups.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Link: http://lkml.kernel.org/r/2bbe633cd74b431c05253a8ce61fdfd5066a531b.1370948150.git.viresh.kumar@linaro.org
In build_sched_groups() we don't need to call get_group() for cpus
which are already covered in previous iterations. Calling get_group()
would mark the group used and eventually leak it since we wouldn't
connect it and not find it again to free it.
This will happen only in cases where sg->cpumask contained more than
one cpu (For any topology level). This patch would free sg's memory
for all cpus leaving the group leader as the group isn't marked used
now.
Link: http://lkml.kernel.org/r/7a61e955abdcbb1dfa9fe493f11a5ec53a11ddd3.1370948150.git.viresh.kumar@linaro.org
In the beginning of build_sched_groups() we called sched_domain_span() and
cached its return value in span. Few statements later we are calling it again to
get the same pointer.
Lets use the cached value instead as it hasn't changed in between.
Link: http://lkml.kernel.org/r/834ecd507071ad88aff039352dbc7e063dd996a7.1370948150.git.viresh.kumar@linaro.org
For loop for traversing sched_domain_topology was used at multiple placed in
core.c. This patch removes code redundancy by creating for_each_sd_topology().
Link: http://lkml.kernel.org/r/e0e04542f54e9464bd9da54f5ccfe62ec6c4c0bc.1370861520.git.viresh.kumar@linaro.org
Memory for sd is allocated with kzalloc_node() which will initialize its fields
with zero. In build_sched_domain() we are setting sd->child to child even if
child is NULL, which isn't required.
Lets do it only if child isn't NULL.
Link: http://lkml.kernel.org/r/f4753a1730051341003ad2ad29a3229c7356678e.1370861520.git.viresh.kumar@linaro.org
alloc_state will be overwritten by __visit_domain_allocation_hell() and so we
don't actually need to initialize alloc_state.
Link: http://lkml.kernel.org/r/df57734a075cc5ad130e1ae498702e24f2529ab8.1370861520.git.viresh.kumar@linaro.org
We are saving first scheduling domain for a cpu in build_sched_domains() by
iterating over the nested sd->child list. We don't actually need to do it this
way.
tl will be equal to sched_domain_topology for the first iteration and so we can
set *per_cpu_ptr(d.sd, i) based on that. So, save pointer to first SD while
running the iteration loop over tl's.
Link: http://lkml.kernel.org/r/fc473527cbc4dfa0b8eeef2a59db74684eb59a83.1370436120.git.viresh.kumar@linaro.org
build_sched_domain() never uses parameter struct s_data *d and so passing it is
useless.
Remove it.
Link: http://lkml.kernel.org/r/545e0b4536166a15b4475abcafe5ed0db4ad4a2c.1370436120.git.viresh.kumar@linaro.org
default_cfs_period(), do_sched_cfs_period_timer(), do_sched_cfs_slack_timer()
already defined previously, no need to declare again.
Signed-off-by: Michael Wang <wangyun@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/51AD8808.7020608@linux.vnet.ibm.com
Directly use rq to save some code.
Link: http://lkml.kernel.org/r/51AD87EB.1070605@linux.vnet.ibm.com
[ Peter, this is based off of some of my work, I ran it though a few
tests and it passed. I also reviewed it, and added my SOB as I am
somewhat a co-author to it. ]
Based on the patch by Steven Rostedt from previous year:
https://lkml.org/lkml/2012/4/18/517
1)Simplify pull_rt_task() logic: search in pushable tasks of dest runqueue.
The only pullable tasks are the tasks which are pushable in their local rq,
and no others.
2)Remove .leaf_rt_rq_list member of struct rt_rq and functions connected
with it: nobody uses it since now.
Signed-off-by: Kirill Tkhai <tkhai@yandex.ru>
Link: http://lkml.kernel.org/r/287571370557898@web7d.yandex.ru
Merge in fixes before applying ongoing new work.
I have faced a sequence where the Idle Load Balance was sometime not
triggered for a while on my platform, in the following scenario:
CPU 0 and CPU 1 are running tasks and CPU 2 is idle
CPU 1 kicks the Idle Load Balance
CPU 1 selects CPU 2 as the new Idle Load Balancer
CPU 2 sets NOHZ_BALANCE_KICK for CPU 2
CPU 2 sends a reschedule IPI to CPU 2
While CPU 3 wakes up, CPU 0 or CPU 1 migrates a waking up task A on CPU 2
CPU 2 finally wakes up, runs task A and discards the Idle Load Balance
task A quickly goes back to sleep (before a tick occurs on CPU 2)
CPU 2 goes back to idle with NOHZ_BALANCE_KICK set
Whenever CPU 2 will be selected as the ILB, no reschedule IPI will be sent
because NOHZ_BALANCE_KICK is already set and no Idle Load Balance will be
performed.
We must wait for the sched softirq to be raised on CPU 2 thanks to another
part the kernel to come back to clear NOHZ_BALANCE_KICK.
The proposed solution clears NOHZ_BALANCE_KICK in schedule_ipi if
we can't raise the sched_softirq for the Idle Load Balance.
Change since V1:
- move the clear of NOHZ_BALANCE_KICK in got_nohz_idle_kick if the ILB
can't run on this CPU (as suggested by Peter)
Signed-off-by: Vincent Guittot <vincent.guittot@linaro.org>
Link: http://lkml.kernel.org/r/1370419991-13870-1-git-send-email-vincent.guittot@linaro.org
Commit 78becc2709 ("sched: Use an accessor to read the rq clock")
introduces rq_clock(), which obsoletes the use of the "rq" variable
in expire_cfs_rq_runtime() and triggers this build warning:
kernel/sched/fair.c: In function 'expire_cfs_rq_runtime':
kernel/sched/fair.c:2159:13: warning: unused variable 'rq' [-Wunused-variable]
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
Acked-by: Paul Turner <pjt@google.com>
Link: http://lkml.kernel.org/r/1369904660-14169-1-git-send-email-kamalesh@linux.vnet.ibm.com
While computing the cputime delta of dynticks CPUs,
we are mixing up clocks of differents natures:
* local_clock() which takes care of unstable clock
sources and fix these if needed.
* sched_clock() which is the weaker version of
local_clock(). It doesn't compute any fixup in case
of unstable source.
If the clock source is stable, those two clocks are the
same and we can safely compute the difference against
two random points.
Otherwise it results in random deltas as sched_clock()
can randomly drift away, back or forward, from local_clock().
As a consequence, some strange behaviour with unstable tsc
has been observed such as non progressing constant zero cputime.
(The 'top' command showing no load).
Fix this by only using local_clock(), or its irq safe/remote
equivalent, in vtime code.
Reported-by: Mike Galbraith <efault@gmx.de>
Suggested-by: Mike Galbraith <efault@gmx.de>
Cc: Li Zhong <zhong@linux.vnet.ibm.com>
Simple cleanup.
Reported-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1367501673-6563-1-git-send-email-sgruszka@redhat.com
Read the runqueue clock through an accessor. This
prepares for adding a debugging infrastructure to
detect missing or redundant calls to update_rq_clock()
between a scheduler's entry and exit point.
Cc: Paul Turner <pjt@google.com>
Link: http://lkml.kernel.org/r/1365724262-20142-6-git-send-email-fweisbec@gmail.com
In this function we are making use of rq->clock right before the
update of the rq clock, let's just call update_rq_clock() just
before that to avoid using a stale rq clock value.
Link: http://lkml.kernel.org/r/1365724262-20142-5-git-send-email-fweisbec@gmail.com
check_preempt_curr() of fair class needs an uptodate sched clock
value to update runtime stats of the current task of the target's rq.
When a task is woken up, activate_task() is usually called right before
ttwu_do_wakeup() unless the task is still in the runqueue. In the latter
case we need to update the rq clock explicitly because activate_task()
isn't here to do the job for us.
Link: http://lkml.kernel.org/r/1365724262-20142-4-git-send-email-fweisbec@gmail.com
Because we may update the execution time in
sched_group_set_shares()->update_cfs_shares()->reweight_entity()->update_curr()
before reweighting the entity while setting the group shares and this requires
an uptodate version of the runqueue clock.
Link: http://lkml.kernel.org/r/1365724262-20142-3-git-send-email-fweisbec@gmail.com
