commit aac74dc495456412c4130a1167ce4beb6c1f0b38 upstream.
After learning we'll need some sort of deferred printk functionality in
the timekeeping core, Peter suggested we rename the printk_sched function
so it can be reused by needed subsystems.
This only changes the function name. No logic changes.
Signed-off-by: John Stultz <john.stultz@linaro.org>
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Jan Kara <jack@suse.cz>
Cc: Jiri Bohac <jbohac@suse.cz>
commit b0ab99e7736af88b8ac1b7ae50ea287fffa2badc upstream.
proc_sched_show_task() does:
if (nr_switches)
do_div(avg_atom, nr_switches);
nr_switches is unsigned long and do_div truncates it to 32 bits, which
means it can test non-zero on e.g. x86-64 and be truncated to zero for
division.
Fix the problem by using div64_ul() instead.
As a side effect calculations of avg_atom for big nr_switches are now correct.
Signed-off-by: Mateusz Guzik <mguzik@redhat.com>
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1402750809-31991-1-git-send-email-mguzik@redhat.com
commit 6acbfb96976fc3350e30d964acb1dbbdf876d55e upstream.
Lai found that:
WARNING: CPU: 1 PID: 13 at arch/x86/kernel/smp.c:124 native_smp_send_reschedule+0x2d/0x4b()
migration_cpu_stop+0x1d/0x22
was caused by set_cpus_allowed_ptr() assuming that cpu_active_mask is
always a sub-set of cpu_online_mask.
This isn't true since 5fbd036b552f ("sched: Cleanup cpu_active madness").
So set active and online at the same time to avoid this particular
problem.
Fixes: 5fbd036b552f ("sched: Cleanup cpu_active madness")
Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Cc: Gautham R. Shenoy <ego@linux.vnet.ibm.com>
Cc: Michael wang <wangyun@linux.vnet.ibm.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Link: http://lkml.kernel.org/r/53758B12.8060609@cn.fujitsu.com
commit 2d513868e2a33e1d5315490ef4c861ee65babd65 upstream.
Russell reported, that irqtime_account_idle_ticks() takes ages due to:
for (i = 0; i < ticks; i++)
irqtime_account_process_tick(current, 0, rq);
It's sad, that this code was written way _AFTER_ the NOHZ idle
functionality was available. I charge myself guitly for not paying
attention when that crap got merged with commit abb74cefa ("sched:
Export ns irqtimes through /proc/stat")
So instead of looping nr_ticks times just apply the whole thing at
once.
As a side note: The whole cputime_t vs. u64 business in that context
wants to be cleaned up as well. There is no point in having all these
back and forth conversions. Lets standardise on u64 nsec for all
kernel internal accounting and be done with it. Everything else does
not make sense at all for fine grained accounting. Frederic, can you
please take care of that?
Reported-by: Russell King <rmk+kernel@arm.linux.org.uk>
Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Cc: Venkatesh Pallipadi <venki@google.com>
Cc: Shaun Ruffell <sruffell@digium.com>
Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1405022307000.6261@ionos.tec.linutronix.de
commit 6227cb00cc120f9a43ce8313bb0475ddabcb7d01 upstream.
The check at the beginning of cpupri_find() makes sure that the task_pri
variable does not exceed the cp->pri_to_cpu array length. But that length
is CPUPRI_NR_PRIORITIES not MAX_RT_PRIO, where it will miss the last two
priorities in that array.
As task_pri is computed from convert_prio() which should never be bigger
than CPUPRI_NR_PRIORITIES, if the check should cause a panic if it is
hit.
Reported-by: Mike Galbraith <umgwanakikbuti@gmail.com>
Link: http://lkml.kernel.org/r/1397015410.5212.13.camel@marge.simpson.net
commit 41261b6a832ea0e788627f6a8707854423f9ff49 upstream.
In autogroup_create(), a tg is allocated and added to the task_groups
list. If CONFIG_RT_GROUP_SCHED is set, this tg is then modified while on
the list, without locking. This can race with someone walking the list,
like __enable_runtime() during CPU unplug, and result in a use-after-free
bug.
To fix this, move sched_online_group(), which adds the tg to the list,
to the end of the autogroup_create() function after the modification.
Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com>
Link: http://lkml.kernel.org/r/1369411669-46971-2-git-send-email-gerald.schaefer@de.ibm.com
Signed-off-by: Preeti U Murthy <preeti@linux.vnet.ibm.com>
commit 791c9e0292671a3bfa95286bb5c08129d8605618 upstream.
dequeue_entity() is called when p->on_rq and sets se->on_rq = 0
which appears to guarentee that the !se->on_rq condition is met.
If the task has done set_current_state(TASK_INTERRUPTIBLE) without
schedule() the second condition will be met and vruntime will be
incorrectly adjusted twice.
In certain cases this can result in the task's vruntime never increasing
past the vruntime of other tasks on the CFS' run queue, starving them of
CPU time.
This patch changes switched_from_fair() to use !p->on_rq instead of
!se->on_rq.
I'm able to cause a task with a priority of 120 to starve all other
tasks with the same priority on an ARM platform running 3.2.51-rt72
PREEMPT RT by writing one character at time to a serial tty (16550 UART)
in a tight loop. I'm also able to verify making this change corrects the
problem on that platform and kernel version.
Signed-off-by: George McCollister <george.mccollister@gmail.com>
Link: http://lkml.kernel.org/r/1392767811-28916-1-git-send-email-george.mccollister@gmail.com
commit 0ac9b1c21874d2490331233b3242085f8151e166 upstream.
Currently, group entity load-weights are initialized to zero. This
admits some races with respect to the first time they are re-weighted in
earlty use. ( Let g[x] denote the se for "g" on cpu "x". )
Suppose that we have root->a and that a enters a throttled state,
immediately followed by a[0]->t1 (the only task running on cpu[0])
blocking:
put_prev_task(group_cfs_rq(a[0]), t1)
put_prev_entity(..., t1)
check_cfs_rq_runtime(group_cfs_rq(a[0]))
throttle_cfs_rq(group_cfs_rq(a[0]))
Then, before unthrottling occurs, let a[0]->b[0]->t2 wake for the first
time:
enqueue_task_fair(rq[0], t2)
enqueue_entity(group_cfs_rq(b[0]), t2)
enqueue_entity_load_avg(group_cfs_rq(b[0]), t2)
account_entity_enqueue(group_cfs_ra(b[0]), t2)
update_cfs_shares(group_cfs_rq(b[0]))
< skipped because b is part of a throttled hierarchy >
enqueue_entity(group_cfs_rq(a[0]), b[0])
We now have b[0] enqueued, yet group_cfs_rq(a[0])->load.weight == 0
which violates invariants in several code-paths. Eliminate the
possibility of this by initializing group entity weight.
Signed-off-by: Paul Turner <pjt@google.com>
Link: http://lkml.kernel.org/r/20131016181627.22647.47543.stgit@sword-of-the-dawn.mtv.corp.google.com
Cc: Chris J Arges <chris.j.arges@canonical.com>
commit 927b54fccbf04207ec92f669dce6806848cbec7d upstream.
__start_cfs_bandwidth calls hrtimer_cancel while holding rq->lock,
waiting for the hrtimer to finish. However, if sched_cfs_period_timer
runs for another loop iteration, the hrtimer can attempt to take
rq->lock, resulting in deadlock.
Fix this by ensuring that cfs_b->timer_active is cleared only if the
_latest_ call to do_sched_cfs_period_timer is returning as idle. Then
__start_cfs_bandwidth can just call hrtimer_try_to_cancel and wait for
that to succeed or timer_active == 1.
Signed-off-by: Ben Segall <bsegall@google.com>
Cc: pjt@google.com
Link: http://lkml.kernel.org/r/20131016181622.22647.16643.stgit@sword-of-the-dawn.mtv.corp.google.com
commit db06e78cc13d70f10877e0557becc88ab3ad2be8 upstream.
hrtimer_expires_remaining does not take internal hrtimer locks and thus
must be guarded against concurrent __hrtimer_start_range_ns (but
returning HRTIMER_RESTART is safe). Use cfs_b->lock to make it safe.
Cc: pjt@google.com
Link: http://lkml.kernel.org/r/20131016181617.22647.73829.stgit@sword-of-the-dawn.mtv.corp.google.com
commit 1ee14e6c8cddeeb8a490d7b54cd9016e4bb900b4 upstream.
When we transition cfs_bandwidth_used to false, any currently
throttled groups will incorrectly return false from cfs_rq_throttled.
While tg_set_cfs_bandwidth will unthrottle them eventually, currently
running code (including at least dequeue_task_fair and
distribute_cfs_runtime) will cause errors.
Fix this by turning off cfs_bandwidth_used only after unthrottling all
cfs_rqs.
Tested: toggle bandwidth back and forth on a loaded cgroup. Caused
crashes in minutes without the patch, hasn't crashed with it.
Cc: pjt@google.com
Link: http://lkml.kernel.org/r/20131016181611.22647.80365.stgit@sword-of-the-dawn.mtv.corp.google.com
commit e0acd0a68ec7dbf6b7a81a87a867ebd7ac9b76c4 upstream.
This is only theoretical, but after try_to_wake_up(p) was changed
to check p->state under p->pi_lock the code like
__set_current_state(TASK_INTERRUPTIBLE);
schedule();
can miss a signal. This is the special case of wait-for-condition,
it relies on try_to_wake_up/schedule interaction and thus it does
not need mb() between __set_current_state() and if(signal_pending).
However, this __set_current_state() can move into the critical
section protected by rq->lock, now that try_to_wake_up() takes
another lock we need to ensure that it can't be reordered with
"if (signal_pending(current))" check inside that section.
The patch is actually one-liner, it simply adds smp_wmb() before
spin_lock_irq(rq->lock). This is what try_to_wake_up() already
does by the same reason.
We turn this wmb() into the new helper, smp_mb__before_spinlock(),
for better documentation and to allow the architectures to change
the default implementation.
While at it, kill smp_mb__after_lock(), it has no callers.
Perhaps we can also add smp_mb__before/after_spinunlock() for
prepare_to_wait().
Acked-by: Peter Zijlstra <peterz@infradead.org>
commit 757dfcaa41844595964f1220f1d33182dae49976 upstream.
This patch touches the RT group scheduling case.
Functions inc_rt_prio_smp() and dec_rt_prio_smp() change (global) rq's
priority, while rt_rq passed to them may be not the top-level rt_rq.
This is wrong, because changing of priority on a child level does not
guarantee that the priority is the highest all over the rq. So, this
leak makes RT balancing unusable.
The short example: the task having the highest priority among all rq's
RT tasks (no one other task has the same priority) are waking on a
throttle rt_rq. The rq's cpupri is set to the task's priority
equivalent, but real rq->rt.highest_prio.curr is less.
The patch below fixes the problem.
Signed-off-by: Kirill Tkhai <tkhai@yandex.ru>
CC: Steven Rostedt <rostedt@goodmis.org>
Link: http://lkml.kernel.org/r/49231385567953@web4m.yandex.ru
commit 3c67f474558748b604e247d92b55dfe89654c81d upstream.
Inaccessible VMA should not be trapping NUMA hint faults. Skip them.
Cc: Alex Thorlton <athorlton@sgi.com>
commit f9f9ffc237dd924f048204e8799da74f9ecf40cf upstream.
throttle_cfs_rq() doesn't check to make sure that period_timer is running,
and while update_curr/assign_cfs_runtime does, a concurrently running
period_timer on another cpu could cancel itself between this cpu's
update_curr and throttle_cfs_rq(). If there are no other cfs_rqs running
in the tg to restart the timer, this causes the cfs_rq to be stranded
forever.
Fix this by calling __start_cfs_bandwidth() in throttle if the timer is
inactive.
(Also add some sched_debug lines for cfs_bandwidth.)
Tested: make a run/sleep task in a cgroup, loop switching the cgroup
between 1ms/100ms quota and unlimited, checking for timer_active=0 and
throttled=1 as a failure. With the throttle_cfs_rq() change commented out
this fails, with the full patch it passes.
Cc: pjt@google.com
Link: http://lkml.kernel.org/r/20131016181632.22647.84174.stgit@sword-of-the-dawn.mtv.corp.google.com
invalid ones
commit 6c9a27f5da9609fca46cb2b183724531b48f71ad upstream.
There is a small race between copy_process() and cgroup_attach_task()
where child->se.parent,cfs_rq points to invalid (old) ones.
parent doing fork() | someone moving the parent to another cgroup
copy_process()
+ dup_task_struct()
-> parent->se is copied to child->se.
se.parent,cfs_rq of them point to old ones.
+ cgroup_task_migrate()
-> parent->cgroup is updated.
+ cpu_cgroup_attach()
+ sched_move_task()
+ task_move_group_fair()
+- set_task_rq()
-> se.parent,cfs_rq of parent
are updated.
+ cgroup_fork()
-> parent->cgroup is copied to child->cgroup. (*1)
+ sched_fork()
+ task_fork_fair()
-> se.parent,cfs_rq of child are accessed
while they point to old ones. (*2)
In the worst case, this bug can lead to "use-after-free" and cause a panic,
because it's new cgroup's refcount that is incremented at (*1),
so the old cgroup(and related data) can be freed before (*2).
In fact, a panic caused by this bug was originally caught in RHEL6.4.
BUG: unable to handle kernel NULL pointer dereference at (null)
IP: [<ffffffff81051e3e>] sched_slice+0x6e/0xa0
Call Trace:
[<ffffffff81051f25>] place_entity+0x75/0xa0
[<ffffffff81056a3a>] task_fork_fair+0xaa/0x160
[<ffffffff81063c0b>] sched_fork+0x6b/0x140
[<ffffffff8106c3c2>] copy_process+0x5b2/0x1450
[<ffffffff81063b49>] ? wake_up_new_task+0xd9/0x130
[<ffffffff8106d2f4>] do_fork+0x94/0x460
[<ffffffff81072a9e>] ? sys_wait4+0xae/0x100
[<ffffffff81009598>] sys_clone+0x28/0x30
[<ffffffff8100b393>] stub_clone+0x13/0x20
[<ffffffff8100b072>] ? system_call_fastpath+0x16/0x1b
Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp>
Link: http://lkml.kernel.org/r/039601ceae06$733d3130$59b79390$@mxp.nes.nec.co.jp
commit 5a8e01f8fa51f5cbce8f37acc050eb2319d12956 upstream.
scale_stime() silently assumes that stime < rtime, otherwise
when stime == rtime and both values are big enough (operations
on them do not fit in 32 bits), the resulting scaling stime can
be bigger than rtime. In consequence utime = rtime - stime
results in negative value.
User space visible symptoms of the bug are overflowed TIME
values on ps/top, for example:
$ ps aux | grep rcu
root 8 0.0 0.0 0 0 ? S 12:42 0:00 [rcuc/0]
root 9 0.0 0.0 0 0 ? S 12:42 0:00 [rcub/0]
root 10 62422329 0.0 0 0 ? R 12:42 21114581:37 [rcu_preempt]
root 11 0.1 0.0 0 0 ? S 12:42 0:02 [rcuop/0]
root 12 62422329 0.0 0 0 ? S 12:42 21114581:35 [rcuop/1]
or overflowed utime values read directly from /proc/$PID/stat
Reference:
https://lkml.org/lkml/2013/8/20/259
Reported-and-tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Cc: stable@vger.kernel.org
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20130904131602.GC2564@redhat.com
continuously-running tasks
commit bf0bd948d1682e3996adc093b43021ed391983e6 upstream.
We typically update a task_group's shares within the dequeue/enqueue
path. However, continuously running tasks sharing a CPU are not
subject to these updates as they are only put/picked. Unfortunately,
when we reverted f269ae046 (in 17bc14b7), we lost the augmenting
periodic update that was supposed to account for this; resulting in a
potential loss of fairness.
To fix this, re-introduce the explicit update in
update_cfs_rq_blocked_load() [called via entity_tick()].
Reported-by: Max Hailperin <max@gustavus.edu>
Reviewed-by: Paul Turner <pjt@google.com>
Link: http://lkml.kernel.org/n/tip-9545m3apw5d93ubyrotrj31y@git.kernel.org
Pull scheduler fixes from Ingo Molnar:
"Two smaller fixes - plus a context tracking tracing fix that is a bit
bigger"
* 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
tracing/context-tracking: Add preempt_schedule_context() for tracing
sched: Fix clear NOHZ_BALANCE_KICK
sched/x86: Construct all sibling maps if smt
I have faced a sequence where the Idle Load Balance was sometime not
triggered for a while on my platform, in the following scenario:
CPU 0 and CPU 1 are running tasks and CPU 2 is idle
CPU 1 kicks the Idle Load Balance
CPU 1 selects CPU 2 as the new Idle Load Balancer
CPU 2 sets NOHZ_BALANCE_KICK for CPU 2
CPU 2 sends a reschedule IPI to CPU 2
While CPU 3 wakes up, CPU 0 or CPU 1 migrates a waking up task A on CPU 2
CPU 2 finally wakes up, runs task A and discards the Idle Load Balance
task A quickly goes back to sleep (before a tick occurs on CPU 2)
CPU 2 goes back to idle with NOHZ_BALANCE_KICK set
Whenever CPU 2 will be selected as the ILB, no reschedule IPI will be sent
because NOHZ_BALANCE_KICK is already set and no Idle Load Balance will be
performed.
We must wait for the sched softirq to be raised on CPU 2 thanks to another
part the kernel to come back to clear NOHZ_BALANCE_KICK.
The proposed solution clears NOHZ_BALANCE_KICK in schedule_ipi if
we can't raise the sched_softirq for the Idle Load Balance.
Change since V1:
- move the clear of NOHZ_BALANCE_KICK in got_nohz_idle_kick if the ILB
can't run on this CPU (as suggested by Peter)
Signed-off-by: Vincent Guittot <vincent.guittot@linaro.org>
Link: http://lkml.kernel.org/r/1370419991-13870-1-git-send-email-vincent.guittot@linaro.org
While computing the cputime delta of dynticks CPUs,
we are mixing up clocks of differents natures:
* local_clock() which takes care of unstable clock
sources and fix these if needed.
* sched_clock() which is the weaker version of
local_clock(). It doesn't compute any fixup in case
of unstable source.
If the clock source is stable, those two clocks are the
same and we can safely compute the difference against
two random points.
Otherwise it results in random deltas as sched_clock()
can randomly drift away, back or forward, from local_clock().
As a consequence, some strange behaviour with unstable tsc
has been observed such as non progressing constant zero cputime.
(The 'top' command showing no load).
Fix this by only using local_clock(), or its irq safe/remote
equivalent, in vtime code.
Reported-by: Mike Galbraith <efault@gmx.de>
Suggested-by: Mike Galbraith <efault@gmx.de>
Cc: Li Zhong <zhong@linux.vnet.ibm.com>
Pull 'full dynticks' support from Ingo Molnar:
"This tree from Frederic Weisbecker adds a new, (exciting! :-) core
kernel feature to the timer and scheduler subsystems: 'full dynticks',
or CONFIG_NO_HZ_FULL=y.
This feature extends the nohz variable-size timer tick feature from
idle to busy CPUs (running at most one task) as well, potentially
reducing the number of timer interrupts significantly.
This feature got motivated by real-time folks and the -rt tree, but
the general utility and motivation of full-dynticks runs wider than
that:
- HPC workloads get faster: CPUs running a single task should be able
to utilize a maximum amount of CPU power. A periodic timer tick at
HZ=1000 can cause a constant overhead of up to 1.0%. This feature
removes that overhead - and speeds up the system by 0.5%-1.0% on
typical distro configs even on modern systems.
- Real-time workload latency reduction: CPUs running critical tasks
should experience as little jitter as possible. The last remaining
source of kernel-related jitter was the periodic timer tick.
- A single task executing on a CPU is a pretty common situation,
especially with an increasing number of cores/CPUs, so this feature
helps desktop and mobile workloads as well.
The cost of the feature is mainly related to increased timer
reprogramming overhead when a CPU switches its tick period, and thus
slightly longer to-idle and from-idle latency.
Configuration-wise a third mode of operation is added to the existing
two NOHZ kconfig modes:
- CONFIG_HZ_PERIODIC: [formerly !CONFIG_NO_HZ], now explicitly named
as a config option. This is the traditional Linux periodic tick
design: there's a HZ tick going on all the time, regardless of
whether a CPU is idle or not.
- CONFIG_NO_HZ_IDLE: [formerly CONFIG_NO_HZ=y], this turns off the
periodic tick when a CPU enters idle mode.
- CONFIG_NO_HZ_FULL: this new mode, in addition to turning off the
tick when a CPU is idle, also slows the tick down to 1 Hz (one
timer interrupt per second) when only a single task is running on a
CPU.
The .config behavior is compatible: existing !CONFIG_NO_HZ and
CONFIG_NO_HZ=y settings get translated to the new values, without the
user having to configure anything. CONFIG_NO_HZ_FULL is turned off by
default.
This feature is based on a lot of infrastructure work that has been
steadily going upstream in the last 2-3 cycles: related RCU support
and non-periodic cputime support in particular is upstream already.
This tree adds the final pieces and activates the feature. The pull
request is marked RFC because:
- it's marked 64-bit only at the moment - the 32-bit support patch is
small but did not get ready in time.
- it has a number of fresh commits that came in after the merge
window. The overwhelming majority of commits are from before the
merge window, but still some aspects of the tree are fresh and so I
marked it RFC.
- it's a pretty wide-reaching feature with lots of effects - and
while the components have been in testing for some time, the full
combination is still not very widely used. That it's default-off
should reduce its regression abilities and obviously there are no
known regressions with CONFIG_NO_HZ_FULL=y enabled either.
- the feature is not completely idempotent: there is no 100%
equivalent replacement for a periodic scheduler/timer tick. In
particular there's ongoing work to map out and reduce its effects
on scheduler load-balancing and statistics. This should not impact
correctness though, there are no known regressions related to this
feature at this point.
- it's a pretty ambitious feature that with time will likely be
enabled by most Linux distros, and we'd like you to make input on
its design/implementation, if you dislike some aspect we missed.
Without flaming us to crisp! :-)
Future plans:
- there's ongoing work to reduce 1Hz to 0Hz, to essentially shut off
the periodic tick altogether when there's a single busy task on a
CPU. We'd first like 1 Hz to be exposed more widely before we go
for the 0 Hz target though.
- once we reach 0 Hz we can remove the periodic tick assumption from
nr_running>=2 as well, by essentially interrupting busy tasks only
as frequently as the sched_latency constraints require us to do -
once every 4-40 msecs, depending on nr_running.
I am personally leaning towards biting the bullet and doing this in
v3.10, like the -rt tree this effort has been going on for too long -
but the final word is up to you as usual.
More technical details can be found in Documentation/timers/NO_HZ.txt"
* 'timers-nohz-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (39 commits)
sched: Keep at least 1 tick per second for active dynticks tasks
rcu: Fix full dynticks' dependency on wide RCU nocb mode
nohz: Protect smp_processor_id() in tick_nohz_task_switch()
nohz_full: Add documentation.
cputime_nsecs: use math64.h for nsec resolution conversion helpers
nohz: Select VIRT_CPU_ACCOUNTING_GEN from full dynticks config
nohz: Reduce overhead under high-freq idling patterns
nohz: Remove full dynticks' superfluous dependency on RCU tree
nohz: Fix unavailable tick_stop tracepoint in dynticks idle
nohz: Add basic tracing
nohz: Select wide RCU nocb for full dynticks
nohz: Disable the tick when irq resume in full dynticks CPU
nohz: Re-evaluate the tick for the new task after a context switch
nohz: Prepare to stop the tick on irq exit
nohz: Implement full dynticks kick
nohz: Re-evaluate the tick from the scheduler IPI
sched: New helper to prevent from stopping the tick in full dynticks
sched: Kick full dynticks CPU that have more than one task enqueued.
perf: New helper to prevent full dynticks CPUs from stopping tick
perf: Kick full dynticks CPU if events rotation is needed
The scheduler doesn't yet fully support environments
with a single task running without a periodic tick.
In order to ensure we still maintain the duties of scheduler_tick(),
keep at least 1 tick per second.
This makes sure that we keep the progression of various scheduler
accounting and background maintainance even with a very low granularity.
Examples include cpu load, sched average, CFS entity vruntime,
avenrun and events such as load balancing, amongst other details
handled in sched_class::task_tick().
This limitation will be removed in the future once we get
these individual items to work in full dynticks CPUs.
Suggested-by: Ingo Molnar <mingo@kernel.org>
Cc: Christoph Lameter <cl@linux.com>
Cc: Hakan Akkan <hakanakkan@gmail.com>
Cc: Kevin Hilman <khilman@linaro.org>
"This fixes the cputime scaling overflow problems for good without
having bad 32-bit overhead, and gets rid of the div64_u64_rem() helper
as well."
Revert "math64: New div64_u64_rem helper"
sched: Avoid prev->stime underflow
sched: Do not account bogus utime
sched: Avoid cputime scaling overflow
The full dynticks tree needs the latest RCU and sched
upstream updates in order to fix some dependencies.
Merge a common upstream merge point that has these
updates.
include/linux/perf_event.h
kernel/rcutree.h
kernel/rcutree_plugin.h
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
One of the problems that arise when converting dedicated custom
threadpool to workqueue is that the shared worker pool used by workqueue
anonimizes each worker making it more difficult to identify what the
worker was doing on which target from the output of sysrq-t or debug
dump from oops, BUG() and friends.
This patch implements set_worker_desc() which can be called from any
workqueue work function to set its description. When the worker task is
dumped for whatever reason - sysrq-t, WARN, BUG, oops, lockdep assertion
and so on - the description will be printed out together with the
workqueue name and the worker function pointer.
The printing side is implemented by print_worker_info() which is called
from functions in task dump paths - sched_show_task() and
dump_stack_print_info(). print_worker_info() can be safely called on
any task in any state as long as the task struct itself is accessible.
It uses probe_*() functions to access worker fields. It may print
garbage if something went very wrong, but it wouldn't cause (another)
oops.
The description is currently limited to 24bytes including the
terminating \0. worker->desc_valid and workder->desc[] are added and
the 64 bytes marker which was already incorrect before adding the new
fields is moved to the correct position.
Here's an example dump with writeback updated to set the bdi name as
worker desc.
Hardware name: Bochs
Modules linked in:
Pid: 7, comm: kworker/u9:0 Not tainted 3.9.0-rc1-work+ #1
Workqueue: writeback bdi_writeback_workfn (flush-8:0)
ffffffff820a3ab0 ffff88000f6e9cb8 ffffffff81c61845 ffff88000f6e9cf8
ffffffff8108f50f 0000000000000000 0000000000000000 ffff88000cde16b0
ffff88000cde1aa8 ffff88001ee19240 ffff88000f6e9fd8 ffff88000f6e9d08
Call Trace:
[<ffffffff81c61845>] dump_stack+0x19/0x1b
[<ffffffff8108f50f>] warn_slowpath_common+0x7f/0xc0
[<ffffffff8108f56a>] warn_slowpath_null+0x1a/0x20
[<ffffffff81200150>] bdi_writeback_workfn+0x2a0/0x3b0
Acked-by: Jan Kara <jack@suse.cz>
Dave Hansen reported strange utime/stime values on his system:
https://lkml.org/lkml/2013/4/4/435
This happens because prev->stime value is bigger than rtime
value. Root of the problem are non-monotonic rtime values (i.e.
current rtime is smaller than previous rtime) and that should be
debugged and fixed.
But since problem did not manifest itself before commit
62188451f0d63add7ad0cd2a1ae269d600c1663d "cputime: Avoid
multiplication overflow on utime scaling", it should be threated
as regression, which we can easily fixed on cputime_adjust()
function.
For now, let's apply this fix, but further work is needed to fix
root of the problem.
Reported-and-tested-by: Dave Hansen <dave@sr71.net>
Cc: <stable@vger.kernel.org> # 3.9+
Cc: rostedt@goodmis.org
Cc: Dave Hansen <dave@sr71.net>
Link: http://lkml.kernel.org/r/1367314507-9728-3-git-send-email-sgruszka@redhat.com
Due to rounding in scale_stime(), for big numbers, scaled stime
values will grow in chunks. Since rtime grow in jiffies and we
calculate utime like below:
prev->stime = max(prev->stime, stime);
prev->utime = max(prev->utime, rtime - prev->stime);
we could erroneously account stime values as utime. To prevent
that only update prev->{u,s}time values when they are smaller
than current rtime.
Link: http://lkml.kernel.org/r/1367314507-9728-2-git-send-email-sgruszka@redhat.com
Here is patch, which adds Linus's cputime scaling algorithm to the
kernel.
This is a follow up (well, fix) to commit
d9a3c9823a2e6a543eb7807fb3d15d8233817ec5 ("sched: Lower chances
of cputime scaling overflow") which commit tried to avoid
multiplication overflow, but did not guarantee that the overflow
would not happen.
Linus crated a different algorithm, which completely avoids the
multiplication overflow by dropping precision when numbers are
big.
It was tested by me and it gives good relative error of
scaled numbers. Testing method is described here:
http://marc.info/?l=linux-kernel&m=136733059505406&w=2
Originally-From: Linus Torvalds <torvalds@linux-foundation.org>
Link: http://lkml.kernel.org/r/20130430151441.GC10465@redhat.com
Pull SMP/hotplug changes from Ingo Molnar:
"This is a pretty large, multi-arch series unifying and generalizing
the various disjunct pieces of idle routines that architectures have
historically copied from each other and have grown in random, wildly
inconsistent and sometimes buggy directions:
101 files changed, 455 insertions(+), 1328 deletions(-)
this went through a number of review and test iterations before it was
committed, it was tested on various architectures, was exposed to
linux-next for quite some time - nevertheless it might cause problems
on architectures that don't read the mailing lists and don't regularly
test linux-next.
This cat herding excercise was motivated by the -rt kernel, and was
brought to you by Thomas "the Whip" Gleixner."
* 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (40 commits)
idle: Remove GENERIC_IDLE_LOOP config switch
um: Use generic idle loop
ia64: Make sure interrupts enabled when we "safe_halt()"
sparc: Use generic idle loop
idle: Remove unused ARCH_HAS_DEFAULT_IDLE
bfin: Fix typo in arch_cpu_idle()
xtensa: Use generic idle loop
x86: Use generic idle loop
unicore: Use generic idle loop
tile: Use generic idle loop
tile: Enter idle with preemption disabled
sh: Use generic idle loop
score: Use generic idle loop
s390: Use generic idle loop
powerpc: Use generic idle loop
parisc: Use generic idle loop
openrisc: Use generic idle loop
mn10300: Use generic idle loop
mips: Use generic idle loop
microblaze: Use generic idle loop
Pull scheduler changes from Ingo Molnar:
"The main changes in this development cycle were:
- full dynticks preparatory work by Frederic Weisbecker
- factor out the cpu time accounting code better, by Li Zefan
- multi-CPU load balancer cleanups and improvements by Joonsoo Kim
- various smaller fixes and cleanups"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (45 commits)
sched: Fix init NOHZ_IDLE flag
sched: Prevent to re-select dst-cpu in load_balance()
sched: Rename load_balance_tmpmask to load_balance_mask
sched: Move up affinity check to mitigate useless redoing overhead
sched: Don't consider other cpus in our group in case of NEWLY_IDLE
sched: Explicitly cpu_idle_type checking in rebalance_domains()
sched: Change position of resched_cpu() in load_balance()
sched: Fix wrong rq's runnable_avg update with rt tasks
sched: Document task_struct::personality field
sched/cpuacct/UML: Fix header file dependency bug on the UML build
cgroup: Kill subsys.active flag
sched/cpuacct: No need to check subsys active state
sched/cpuacct: Initialize cpuacct subsystem earlier
sched/cpuacct: Initialize root cpuacct earlier
sched/cpuacct: Allocate per_cpu cpuusage for root cpuacct statically
sched/cpuacct: Clean up cpuacct.h
sched/cpuacct: Remove redundant NULL checks in cpuacct_acount_field()
sched/cpuacct: Remove redundant NULL checks in cpuacct_charge()
sched/cpuacct: Add cpuacct_acount_field()
sched/cpuacct: Add cpuacct_init()
Pull workqueue updates from Tejun Heo:
"A lot of activities on workqueue side this time. The changes achieve
the followings.
- WQ_UNBOUND workqueues - the workqueues which are per-cpu - are
updated to be able to interface with multiple backend worker pools.
This involved a lot of churning but the end result seems actually
neater as unbound workqueues are now a lot closer to per-cpu ones.
- The ability to interface with multiple backend worker pools are
used to implement unbound workqueues with custom attributes.
Currently the supported attributes are the nice level and CPU
affinity. It may be expanded to include cgroup association in
future. The attributes can be specified either by calling
apply_workqueue_attrs() or through /sys/bus/workqueue/WQ_NAME/* if
the workqueue in question is exported through sysfs.
The backend worker pools are keyed by the actual attributes and
shared by any workqueues which share the same attributes. When
attributes of a workqueue are changed, the workqueue binds to the
worker pool with the specified attributes while leaving the work
items which are already executing in its previous worker pools
alone.
This allows converting custom worker pool implementations which
want worker attribute tuning to use workqueues. The writeback pool
is already converted in block tree and there are a couple others
are likely to follow including btrfs io workers.
- WQ_UNBOUND's ability to bind to multiple worker pools is also used
to make it NUMA-aware. Because there's no association between work
item issuer and the specific worker assigned to execute it, before
this change, using unbound workqueue led to unnecessary cross-node
bouncing and it couldn't be helped by autonuma as it requires tasks
to have implicit node affinity and workers are assigned randomly.
After these changes, an unbound workqueue now binds to multiple
NUMA-affine worker pools so that queued work items are executed in
the same node. This is turned on by default but can be disabled
system-wide or for individual workqueues.
Crypto was requesting NUMA affinity as encrypting data across
different nodes can contribute noticeable overhead and doing it
per-cpu was too limiting for certain cases and IO throughput could
be bottlenecked by one CPU being fully occupied while others have
idle cycles.
While the new features required a lot of changes including
restructuring locking, it didn't complicate the execution paths much.
The unbound workqueue handling is now closer to per-cpu ones and the
new features are implemented by simply associating a workqueue with
different sets of backend worker pools without changing queue,
execution or flush paths.
As such, even though the amount of change is very high, I feel
relatively safe in that it isn't likely to cause subtle issues with
basic correctness of work item execution and handling. If something
is wrong, it's likely to show up as being associated with worker pools
with the wrong attributes or OOPS while workqueue attributes are being
changed or during CPU hotplug.
While this creates more backend worker pools, it doesn't add too many
more workers unless, of course, there are many workqueues with unique
combinations of attributes. Assuming everything else is the same,
NUMA awareness costs an extra worker pool per NUMA node with online
CPUs.
There are also a couple things which are being routed outside the
workqueue tree.
- block tree pulled in workqueue for-3.10 so that writeback worker
pool can be converted to unbound workqueue with sysfs control
exposed. This simplifies the code, makes writeback workers
NUMA-aware and allows tuning nice level and CPU affinity via sysfs.
- The conversion to workqueue means that there's no 1:1 association
between a specific worker, which makes writeback folks unhappy as
they want to be able to tell which filesystem caused a problem from
backtrace on systems with many filesystems mounted. This is
resolved by allowing work items to set debug info string which is
printed when the task is dumped. As this change involves unifying
implementations of dump_stack() and friends in arch codes, it's
being routed through Andrew's -mm tree."
* 'for-3.10' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (84 commits)
workqueue: use kmem_cache_free() instead of kfree()
workqueue: avoid false negative WARN_ON() in destroy_workqueue()
workqueue: update sysfs interface to reflect NUMA awareness and a kernel param to disable NUMA affinity
workqueue: implement NUMA affinity for unbound workqueues
workqueue: introduce put_pwq_unlocked()
workqueue: introduce numa_pwq_tbl_install()
workqueue: use NUMA-aware allocation for pool_workqueues
workqueue: break init_and_link_pwq() into two functions and introduce alloc_unbound_pwq()
workqueue: map an unbound workqueues to multiple per-node pool_workqueues
workqueue: move hot fields of workqueue_struct to the end
workqueue: make workqueue->name[] fixed len
workqueue: add workqueue->unbound_attrs
workqueue: determine NUMA node of workers accourding to the allowed cpumask
workqueue: drop 'H' from kworker names of unbound worker pools
workqueue: add wq_numa_tbl_len and wq_numa_possible_cpumask[]
workqueue: move pwq_pool_locking outside of get/put_unbound_pool()
workqueue: fix memory leak in apply_workqueue_attrs()
workqueue: fix unbound workqueue attrs hashing / comparison
workqueue: fix race condition in unbound workqueue free path
workqueue: remove pwq_lock which is no longer used
Pull locking changes from Ingo Molnar:
"The most noticeable change are mutex speedups from Waiman Long, for
higher loads. These scalability changes should be most noticeable on
larger server systems.
There are also cleanups, fixes and debuggability improvements."
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
lockdep: Consolidate bug messages into a single print_lockdep_off() function
lockdep: Print out additional debugging advice when we hit lockdep BUGs
mutex: Back out architecture specific check for negative mutex count
mutex: Queue mutex spinners with MCS lock to reduce cacheline contention
mutex: Make more scalable by doing less atomic operations
mutex: Move mutex spinning code from sched/core.c back to mutex.c
locking/rtmutex/tester: Set correct permissions on sysfs files
lockdep: Remove unnecessary 'hlock_next' variable
On my SMP platform which is made of 5 cores in 2 clusters, I
have the nr_busy_cpu field of sched_group_power struct that is
not null when the platform is fully idle - which makes the
scheduler unhappy.
The root cause is:
During the boot sequence, some CPUs reach the idle loop and set
their NOHZ_IDLE flag while waiting for others CPUs to boot. But
the nr_busy_cpus field is initialized later with the assumption
that all CPUs are in the busy state whereas some CPUs have
already set their NOHZ_IDLE flag.
More generally, the NOHZ_IDLE flag must be initialized when new
sched_domains are created in order to ensure that NOHZ_IDLE and
nr_busy_cpus are aligned.
This condition can be ensured by adding a synchronize_rcu()
between the destruction of old sched_domains and the creation of
new ones so the NOHZ_IDLE flag will not be updated with old
sched_domain once it has been initialized. But this solution
introduces a additionnal latency in the rebuild sequence that is
called during cpu hotplug.
As suggested by Frederic Weisbecker, another solution is to have
the same rcu lifecycle for both NOHZ_IDLE and sched_domain
struct. A new nohz_idle field is added to sched_domain so both
status and sched_domain will share the same RCU lifecycle and
will be always synchronized. In addition, there is no more need
to protect nohz_idle against concurrent access as it is only
modified by 2 exclusive functions called by local cpu.
This solution has been prefered to the creation of a new struct
with an extra pointer indirection for sched_domain.
The synchronization is done at the cost of :
- An additional indirection and a rcu_dereference for accessing nohz_idle.
- We use only the nohz_idle field of the top sched_domain.
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: linaro-kernel@lists.linaro.org
Cc: peterz@infradead.org
Cc: fweisbec@gmail.com
Cc: pjt@google.com
Cc: efault@gmx.de
Link: http://lkml.kernel.org/r/1366729142-14662-1-git-send-email-vincent.guittot@linaro.org
[ Fixed !NO_HZ build bug. ]
Commit 88b8dac0 makes load_balance() consider other cpus in its
group. But, in that, there is no code for preventing to
re-select dst-cpu. So, same dst-cpu can be selected over and
over.
This patch add functionality to load_balance() in order to
exclude cpu which is selected once. We prevent to re-select
dst_cpu via env's cpus, so now, env's cpus is a candidate not
only for src_cpus, but also dst_cpus.
With this patch, we can remove lb_iterations and
max_lb_iterations, because we decide whether we can go ahead or
not via env's cpus.
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Tested-by: Jason Low <jason.low2@hp.com>
Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com>
Cc: Davidlohr Bueso <davidlohr.bueso@hp.com>
Link: http://lkml.kernel.org/r/1366705662-3587-7-git-send-email-iamjoonsoo.kim@lge.com
This name doesn't represent specific meaning.
So rename it to imply it's purpose.
Link: http://lkml.kernel.org/r/1366705662-3587-6-git-send-email-iamjoonsoo.kim@lge.com
Currently, LBF_ALL_PINNED is cleared after affinity check is
passed. So, if task migration is skipped by small load value or
small imbalance value in move_tasks(), we don't clear
LBF_ALL_PINNED. At last, we trigger 'redo' in load_balance().
Imbalance value is often so small that any tasks cannot be moved
to other cpus and, of course, this situation may be continued
after we change the target cpu. So this patch move up affinity
check code and clear LBF_ALL_PINNED before evaluating load value
in order to mitigate useless redoing overhead.
In addition, re-order some comments correctly.
Link: http://lkml.kernel.org/r/1366705662-3587-5-git-send-email-iamjoonsoo.kim@lge.com
group, regardless of idle type. When we do NEWLY_IDLE balancing,
we should not consider it, because a motivation of NEWLY_IDLE
balancing is to turn this cpu to non idle state if needed. This
is not the case of other cpus. So, change code not to consider
other cpus for NEWLY_IDLE balancing.
With this patch, assign 'if (pulled_task) this_rq->idle_stamp =
0' in idle_balance() is corrected, because NEWLY_IDLE balancing
doesn't consider other cpus. Assigning to 'this_rq->idle_stamp'
is now valid.
Link: http://lkml.kernel.org/r/1366705662-3587-4-git-send-email-iamjoonsoo.kim@lge.com
After commit 88b8dac0, dst-cpu can be changed in load_balance(),
then we can't know cpu_idle_type of dst-cpu when load_balance()
return positive. So, add explicit cpu_idle_type checking.
Link: http://lkml.kernel.org/r/1366705662-3587-3-git-send-email-iamjoonsoo.kim@lge.com
cur_ld_moved is reset if env.flags hit LBF_NEED_BREAK.
So, there is possibility that we miss doing resched_cpu().
Correct it as changing position of resched_cpu()
before checking LBF_NEED_BREAK.
Link: http://lkml.kernel.org/r/1366705662-3587-2-git-send-email-iamjoonsoo.kim@lge.com
When a task is scheduled in, it may have some properties
of its own that could make the CPU reconsider the need for
the tick: posix cpu timers, perf events, ...
So notify the full dynticks subsystem when a task gets
scheduled in and re-check the tick dependency at this
stage. This is done through a self IPI to avoid messing
up with any current lock scenario.
Cc: Chris Metcalf <cmetcalf@tilera.com>
Cc: Geoff Levand <geoff@infradead.org>
Cc: Gilad Ben Yossef <gilad@benyossef.com>
The scheduler IPI is used by the scheduler to kick
full dynticks CPUs asynchronously when more than one
task are running or when a new timer list timer is
enqueued. This way the destination CPU can decide
to restart the tick to handle this new situation.
Now let's call that kick in the scheduler IPI.
(Reusing the scheduler IPI rather than implementing
a new IPI was suggested by Peter Zijlstra a while ago)
Provide a new helper to be called from the full dynticks engine
before stopping the tick in order to make sure we don't stop
it when there is more than one task running on the CPU.
This way we make sure that the tick stays alive to maintain
fairness.
Kick the tick on full dynticks CPUs when they get more
than one task running on their queue. This makes sure that
local fairness is maintained by the tick on the destination.
This is done regardless of these tasks' class. We should
be able to be more clever in the future depending on these. eg:
a CPU that runs a SCHED_FIFO task doesn't need to maintain
fairness against local pending tasks of the fair class.
But keep things simple for now.
The current update of the rq's load can be erroneous when RT
tasks are involved.
The update of the load of a rq that becomes idle, is done only
if the avg_idle is less than sysctl_sched_migration_cost. If RT
tasks and short idle duration alternate, the runnable_avg will
not be updated correctly and the time will be accounted as idle
time when a CFS task wakes up.
A new idle_enter function is called when the next task is the
idle function so the elapsed time will be accounted as run time
in the load of the rq, whatever the average idle time is. The
function update_rq_runnable_avg is removed from idle_balance.
When a RT task is scheduled on an idle CPU, the update of the
rq's load is not done when the rq exit idle state because CFS's
functions are not called. Then, the idle_balance, which is
called just before entering the idle function, updates the rq's
load and makes the assumption that the elapsed time since the
last update, was only running time.
As a consequence, the rq's load of a CPU that only runs a
periodic RT task, is close to LOAD_AVG_MAX whatever the running
duration of the RT task is.
A new idle_exit function is called when the prev task is the
idle function so the elapsed time will be accounted as idle time
in the rq's load.
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Cc: pjt@google.com
Cc: efault@gmx.de
Link: http://lkml.kernel.org/r/1366302867-5055-1-git-send-email-vincent.guittot@linaro.org
As mentioned by Ingo, the SCHED_FEAT_OWNER_SPIN scheduler
feature bit was really just an early hack to make with/without
mutex-spinning testable. So it is no longer necessary.
This patch removes the SCHED_FEAT_OWNER_SPIN feature bit and
move the mutex spinning code from kernel/sched/core.c back to
kernel/mutex.c which is where they should belong.
Signed-off-by: Waiman Long <Waiman.Long@hp.com>
Cc: Chandramouleeswaran Aswin <aswin@hp.com>
Cc: Norton Scott J <scott.norton@hp.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Clark Williams <williams@redhat.com>
Link: http://lkml.kernel.org/r/1366226594-5506-2-git-send-email-Waiman.Long@hp.com
"Extended nohz" was used as a naming base for the full dynticks
API and Kconfig symbols. It reflects the fact the system tries
to stop the tick in more places than just idle.
But that "extended" name is a bit opaque and vague. Rename it to
"full" makes it clearer what the system tries to do under this
config: try to shutdown the tick anytime it can. The various
constraints that prevent that to happen shouldn't be considered
as fundamental properties of this feature but rather technical
issues that may be solved in the future.
Reported-by: Ingo Molnar <mingo@kernel.org>
"Misc fixlets"
sched/cputime: Fix accounting on multi-threaded processes
sched/debug: Fix sd->*_idx limit range avoiding overflow
sched_clock: Prevent 64bit inatomicity on 32bit systems
sched: Convert BUG_ON()s in try_to_wake_up_local() to WARN_ON_ONCE()s
