commit 5167e8d5417bf5c322a703d2927daec727ea40dd upstream.
Thanks to Charles Wang for spotting the defects in the current code:
- If we go idle during the sample window -- after sampling, we get a
negative bias because we can negate our own sample.
- If we wake up during the sample window we get a positive bias
because we push the sample to a known active period.
So rewrite the entire nohz load-avg muck once again, now adding
copious documentation to the code.
Reported-and-tested-by: Doug Smythies <dsmythies@telus.net>
Reported-and-tested-by: Charles Wang <muming.wq@gmail.com>
Link: http://lkml.kernel.org/r/1340373782.18025.74.camel@twins
[ minor edits ]
[bwh: Backported to 3.2: adjust filenames, context]
In preparation of calling select_task_rq() without rq->lock held, drop
the dependency on the rq argument.
Reviewed-by: Frank Rowand <frank.rowand@am.sony.com>
Cc: Nick Piggin <npiggin@kernel.dk>
Link: http://lkml.kernel.org/r/20110405152729.031077745@chello.nl
Correct ->dequeue_tree() thinko into sched_class->dequeue_task
and drop all references to ->task_new() since it is obviously
gone.
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
LKML-Reference: <1300815978-16618-1-git-send-email-bp@amd64.org>
When a task is taken out of the fair class we must ensure the vruntime
is properly normalized because when we put it back in it will assume
to be normalized.
The case that goes wrong is when changing away from the fair class
while sleeping. Sleeping tasks have non-normalized vruntime in order
to make sleeper-fairness work. So treat the switch away from fair as a
wakeup and preserve the relative vruntime.
Also update sysrq-n to call the ->switch_{to,from} methods.
Reported-by: Onkalo Samu <samu.p.onkalo@nokia.com>
LKML-Reference: <new-submission>
Since commit 48c5ccae88dcd (sched: Simplify cpu-hot-unplug task
migration) this should no longer happen, so remove the code.
Chase reported that due to us decrementing calc_load_task prematurely
(before the next LOAD_FREQ sample), the load average could be scewed
by as much as the number of CPUs in the machine.
This patch, based on Chase's patch, cures the problem by keeping the
delta of the CPU going into NO_HZ idle separately and folding that in
on the next LOAD_FREQ update.
This restores the balance and we get strict LOAD_FREQ period samples.
Acked-by: Chase Douglas <chase.douglas@canonical.com>
LKML-Reference: <1271934490.1776.343.camel@laptop>
In order to reduce the dependency on TASK_WAKING rework the enqueue
interface to support a proper flags field.
Replace the int wakeup, bool head arguments with an int flags argument
and create the following flags:
ENQUEUE_WAKEUP - the enqueue is a wakeup of a sleeping task,
ENQUEUE_WAKING - the enqueue has relative vruntime due to
having sched_class::task_waking() called,
ENQUEUE_HEAD - the waking task should be places on the head
of the priority queue (where appropriate).
For symmetry also convert sched_class::dequeue() to a flags scheme.
Oleg noticed a few races with the TASK_WAKING usage on fork.
- since TASK_WAKING is basically a spinlock, it should be IRQ safe
- since we set TASK_WAKING (*) without holding rq->lock it could
be there still is a rq->lock holder, thereby not actually
providing full serialization.
(*) in fact we clear PF_STARTING, which in effect enables TASK_WAKING.
Cure the second issue by not setting TASK_WAKING in sched_fork(), but
only temporarily in wake_up_new_task() while calling select_task_rq().
Cure the first by holding rq->lock around the select_task_rq() call,
this will disable IRQs, this however requires that we push down the
rq->lock release into select_task_rq_fair()'s cgroup stuff.
Because select_task_rq_fair() still needs to drop the rq->lock we
cannot fully get rid of TASK_WAKING.
Reported-by: Oleg Nesterov <oleg@redhat.com>
Take out the sched_class methods for load-balancing.
kernel/sched: don't expose local functions
The get_rr_interval_* functions are all class methods of
struct sched_class. They are not exported so make them
static.
LKML-Reference: <201001132021.53253.hartleys@visionengravers.com>
Revert the braindead pr_* crap. (Commit 663997d "sched: Use
pr_fmt() and pr_<level>()")
It's dumb and causes stupid "sched: " strings all over the place.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Acked-by: Mike Galbraith <efault@gmx.de>
Cc: Joe Perches <joe@perches.com>
LKML-Reference: <1261315437.4314.6.camel@laptop>
[ i dont mind the pr_*() patterns that much - but Peter dislikes them with a vengence. ]
[ - v2: remove spurious diffstat from changelog :-/ ]
kernel/sched_idletask.c
Merge reason: resolve the conflicts, pick up latest changes.
Convert locks which cannot be sleeping locks in preempt-rt to
raw_spinlocks.
Acked-by: Peter Zijlstra <peterz@infradead.org>
- Convert printk(KERN_<level> to pr_<level> (not KERN_DEBUG)
- Add #define pr_fmt(fmt) KBUILD_MODNAME ": " fmt
- Coalesce long format strings
- Add missing \n to "ERROR: !SD_LOAD_BALANCE domain has parent"
LKML-Reference: <1260655047.2637.7.camel@Joe-Laptop.home>
sched_rr_get_param calls
task->sched_class->get_rr_interval(task) without protection
against a concurrent sched_setscheduler() call which modifies
task->sched_class.
Serialize the access with task_rq_lock(task) and hand the rq
pointer into get_rr_interval() as it's needed at least in the
sched_fair implementation.
LKML-Reference: <alpine.LFD.2.00.0912090930120.3089@localhost.localdomain>
By removing the need for it to know details of scheduling classes.
This allows PlugSched to define orthogonal scheduling classes.
Signed-off-by: Peter Williams <pwil3058@bigpond.net.au>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
LKML-Reference: <06d1b89ee15a0eef82d7.1253496713@mudlark.pw.nest>
In order to extend the functions to have more than 1 flag (sync),
rename the argument to flags, and explicitly define a WF_ space for
individual flags.
In order to be able to rename the sync argument, we need to rename
the current flag argument.
Rather ugly patch to fully place the sched_balance_self() code
inside the fair class.
Dimitri Sivanich noticed that xtime_lock is held write locked across
calc_load() which iterates over all online CPUs. That can cause long
latencies for xtime_lock readers on large SMP systems.
The load average calculation is an rough estimate anyway so there is
no real need to protect the readers vs. the update. It's not a problem
when the avenrun array is updated while a reader copies the values.
Instead of iterating over all online CPUs let the scheduler_tick code
update the number of active tasks shortly before the avenrun update
happens. The avenrun update itself is handled by the CPU which calls
do_timer().
[ Impact: reduce xtime_lock write locked section ]
a patch from Henrik Austad did this:
>> Do not declare select_task_rq as part of sched_class when CONFIG_SMP is
>> not set.
Peter observed:
> While a proper cleanup, could you do it by re-arranging the methods so
> as to not create an additional ifdef?
Do not declare select_task_rq and some other methods as part of sched_class
when CONFIG_SMP is not set.
Also gather those methods to avoid CONFIG_SMP mess.
Idea-by: Henrik Austad <henrik.austad@gmail.com>
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Acked-by: Henrik Austad <henrik@austad.us>
Lin Ming reported a 10% OLTP regression against 2.6.27-rc4.
The difference seems to come from different preemption agressiveness,
which affects the cache footprint of the workload and its effective
cache trashing.
Aggresively preempt a task if its avg overlap is very small, this should
avoid the task going to sleep and find it still running when we schedule
back to it - saving a wakeup.
Reported-by: Lin Ming <ming.m.lin@intel.com>
The C files are included directly in sched.c, so they are
effectively static.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Use HR-timers (when available) to deliver an accurate preemption tick.
The regular scheduler tick that runs at 1/HZ can be too coarse when nice
level are used. The fairness system will still keep the cpu utilisation 'fair'
by then delaying the task that got an excessive amount of CPU time but try to
minimize this by delivering preemption points spot-on.
The average frequency of this extra interrupt is sched_latency / nr_latency.
Which need not be higher than 1/HZ, its just that the distribution within the
sched_latency period is important.
Dmitry Adamushko found that the current implementation of the RT
balancing code left out changes to the sched_setscheduler and
rt_mutex_setprio.
This patch addresses this issue by adding methods to the schedule classes
to handle being switched out of (switched_from) and being switched into
(switched_to) a sched_class. Also a method for changing of priorities
is also added (prio_changed).
This patch also removes some duplicate logic between rt_mutex_setprio and
sched_setscheduler.
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
The current wake-up code path tries to determine if it can optimize the
wake-up to "this_cpu" by computing load calculations. The problem is that
these calculations are only relevant to SCHED_OTHER tasks where load is king.
For RT tasks, priority is king. So the load calculation is completely wasted
bandwidth.
Therefore, we create a new sched_class interface to help with
pre-wakeup routing decisions and move the load calculation as a function
of CFS task's class.
Signed-off-by: Gregory Haskins <ghaskins@novell.com>
At the moment, a lot of load balancing code that is irrelevant to non
SMP systems gets included during non SMP builds.
This patch addresses this issue and reduces the binary size on non
SMP systems:
10983 28 1192 12203 2fab sched.o.before
10739 28 1192 11959 2eb7 sched.o.after
At the moment, balance_tasks() provides low level functionality for both
move_tasks() and move_one_task() (indirectly) via the load_balance()
function (in the sched_class interface) which also provides dual
functionality. This dual functionality complicates the interfaces and
internal mechanisms and makes the run time overhead of operations that
are called with two run queue locks held.
This patch addresses this issue and reduces the overhead of these
operations.
mark scheduling classes as const. The speeds up the code
a bit and shrinks it:
40027 4018 292 44337 ad31 sched.o.before
40190 3842 292 44324 ad24 sched.o.after
Revert removal of set_curr_task.
Use put_prev_task/set_curr_task when changing groups/policies
Signed-off-by: Srivatsa Vaddagiri < vatsa@linux.vnet.ibm.com>
Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com>
rework enqueue/dequeue_entity() to get rid of
sched_class::set_curr_task(). This simplifies sched_setscheduler(),
rt_mutex_setprio() and sched_move_tasks().
24330 2734 20 27084 69cc sched.o.before
24233 2730 20 26983 6967 sched.o.after
Signed-off-by: Dmitry Adamushko <dmitry.adamushko@gmail.com>
Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com>
Add interface to control cpu bandwidth allocation to task-groups.
(not yet configurable, due to missing CONFIG_CONTAINERS)
remove the 'u64 now' parameter from ->put_prev_task().
( identity transformation that causes no change in functionality. )
remove the 'u64 now' parameter from ->pick_next_task().
remove the 'u64 now' parameter from ->dequeue_task().
There are two problems with balance_tasks() and how it used:
1. The variables best_prio and best_prio_seen (inherited from the old
move_tasks()) were only required to handle problems caused by the
active/expired arrays, the order in which they were processed and the
possibility that the task with the highest priority could be on either.
These issues are no longer present and the extra overhead associated
with their use is unnecessary (and possibly wrong).
2. In the absence of CONFIG_FAIR_GROUP_SCHED being set, the same
this_best_prio variable needs to be used by all scheduling classes or
there is a risk of moving too much load. E.g. if the highest priority
task on this at the beginning is a fairly low priority task and the rt
class migrates a task (during its turn) then that moved task becomes the
new highest priority task on this_rq but when the sched_fair class
initializes its copy of this_best_prio it will get the priority of the
original highest priority task as, due to the run queue locks being
held, the reschedule triggered by pull_task() will not have taken place.
This could result in inappropriate overriding of skip_for_load and
excessive load being moved.
The attached patch addresses these problems by deleting all reference to
best_prio and best_prio_seen and making this_best_prio a reference
parameter to the various functions involved.
load_balance_fair() has also been modified so that this_best_prio is
only reset (in the loop) if CONFIG_FAIR_GROUP_SCHED is set. This should
preserve the effect of helping spread groups' higher priority tasks
around the available CPUs while improving system performance when
CONFIG_FAIR_GROUP_SCHED isn't set.
The move_tasks() function is currently multiplexed with two distinct
capabilities:
1. attempt to move a specified amount of weighted load from one run
queue to another; and
2. attempt to move a specified number of tasks from one run queue to
another.
The first of these capabilities is used in two places, load_balance()
and load_balance_idle(), and in both of these cases the return value of
move_tasks() is used purely to decide if tasks/load were moved and no
notice of the actual number of tasks moved is taken.
The second capability is used in exactly one place,
active_load_balance(), to attempt to move exactly one task and, as
before, the return value is only used as an indicator of success or failure.
This multiplexing of sched_task() was introduced, by me, as part of the
smpnice patches and was motivated by the fact that the alternative, one
function to move specified load and one to move a single task, would
have led to two functions of roughly the same complexity as the old
move_tasks() (or the new balance_tasks()). However, the new modular
design of the new CFS scheduler allows a simpler solution to be adopted
and this patch addresses that solution by:
1. adding a new function, move_one_task(), to be used by
active_load_balance(); and
2. making move_tasks() a single purpose function that tries to move a
specified weighted load and returns 1 for success and 0 for failure.
One of the consequences of these changes is that neither move_one_task()
or the new move_tasks() care how many tasks sched_class.load_balance()
moves and this enables its interface to be simplified by returning the
amount of load moved as its result and removing the load_moved pointer
from the argument list. This helps simplify the new move_tasks() and
slightly reduces the amount of work done in each of
sched_class.load_balance()'s implementations.
Further simplification, e.g. changes to balance_tasks(), are possible
but (slightly) complicated by the special needs of load_balance_fair()
so I've left them to a later patch (if this one gets accepted).
NB Since move_tasks() gets called with two run queue locks held even
small reductions in overhead are worthwhile.
[ mingo@elte.hu ]
this change also reduces code size nicely:
39216 3618 24 42858 a76a sched.o.before
39173 3618 24 42815 a73f sched.o.after
add kernel/sched_idletask.c - which implements the idle thread
scheduling class. This further simplifies sched.c (under CFS),
for example a number of 'if (p == rq->idle)' type of special-cases
can be removed from sched.c, and schedule() gets simpler too.
