path: root/kernel/sched_stats.h
2007-11-28sched: clean up kernel/sched_stat.hIngo Molnar
clean up kernel/sched_stat.h. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-11-09sched: fix delay accounting regressionBalbir Singh
Fix the delay accounting regression introduced by commit 75d4ef16a6aa84f708188bada182315f80aab6fa. rq no longer has sched_info data associated with it. task_struct sched_info structure is used by delay accounting to provide back statistics to user space. also remove direct use of sched_clock() (which is not a valid thing to do anymore) and use rq->clock instead. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-18sched: reduce schedstat variable overhead a bitKen Chen
schedstat is useful in investigating CPU scheduler behavior. Ideally, I think it is beneficial to have it on all the time. However, the cost of turning it on in production system is quite high, largely due to number of events it collects and also due to its large memory footprint. Most of the fields probably don't need to be full 64-bit on 64-bit arch. Rolling over 4 billion events will most like take a long time and user space tool can be made to accommodate that. I'm proposing kernel to cut back most of variable width on 64-bit system. (note, the following patch doesn't affect 32-bit system). Signed-off-by: Ken Chen <kenchen@google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-15sched: clean up schedstats, cnt -> countIngo Molnar
rename all 'cnt' fields and variables to the less yucky 'count' name. yuckage noticed by Andrew Morton. no change in code, other than the /proc/sched_debug bkl_count string got a bit larger: text data bss dec hex filename 38236 3506 24 41766 a326 sched.o.before 38240 3506 24 41770 a32a sched.o.after Signed-off-by: Ingo Molnar <mingo@elte.hu> Reviewed-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-15sched: fix delay accounting performance regressionIngo Molnar
fix delay accounting performance regression - those sched_clock() calls are not needed. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: Thomas Gleixner <tglx@linutronix.de>
2007-08-02[PATCH] sched: add schedstat_set() APIIngo Molnar
add the schedstat_set() API, to allow the reduction of CONFIG_SCHEDSTAT related #ifdefs. No code changed. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-07-09sched: update delay-accounting to use CFS's precise statsBalbir Singh
update delay-accounting to use CFS's precise stats. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-07-09sched: move code into kernel/sched_stats.hIngo Molnar
create sched_stats.h and move sched.c schedstats code into it. This cleans up sched.c a bit. no code changes are caused by this patch. Signed-off-by: Ingo Molnar <mingo@elte.hu>
