path: root/kernel/sched_stats.h
2011-09-13locking, sched: Annotate thread_group_cputimer as rawThomas Gleixner
The thread_group_cputimer lock can be taken in atomic context and therefore cannot be preempted on -rt - annotate it. In mainline this change documents the low level nature of the lock - otherwise there's no functional difference. Lockdep and Sparse checking will work as usual. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-28sched: More sched_domain iterations fixesXiaotian Feng
sched_domain iterations needs to be protected by rcu_read_lock() now, this patch adds another two places which needs the rcu lock, which is spotted by following suspicious rcu_dereference_check() usage warnings. kernel/sched_rt.c:1244 invoked rcu_dereference_check() without protection! kernel/sched_stats.h:41 invoked rcu_dereference_check() without protection! Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1303469634-11678-1-git-send-email-dfeng@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-24sched_stat: Update sched_info_queue/dequeue() code commentsRakib Mullick
Remove some sched_info_queue(), sched_info_dequeue() code comment. We no longer belongs to the era of O(1) and we don't use active or expired array anymore. Signed-off-by: Rakib Mullick <rakib.mullick@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <AANLkTi=REu0WzOp5N=nVT1=ZJ=ZA+MZFV+4CHSJ3Q-Yv@mail.gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-06-18sched: Remove the obsolete exit_state/signal hacksOleg Nesterov
account_group_xxx() functions check ->exit_state to ensure that current->signal is valid and can't go away. This is not needed since ea6d290c, task->signal is pinned to task_struct. The comment and another hack in account_group_exec_runtime() refers to task_rq_unlock_wait() which was already removed by b7b8ff63. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20100610230952.GA25914@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-24sched: remove unused fields from struct rqLuis Henriques
Impact: cleanup, new schedstat ABI Since they are used on in statistics and are always set to zero, the following fields from struct rq have been removed: yld_exp_empty, yld_act_empty and yld_both_empty. Both Sched Debug and SCHEDSTAT_VERSION versions has also been incremented since ABIs have been changed. The schedtop tool has been updated to properly handle new version of schedstat: http://rt.wiki.kernel.org/index.php/Schedtop_utility Signed-off-by: Luis Henriques <henrix@sapo.pt> Acked-by: Gregory Haskins <ghaskins@novell.com> Acked-by: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20090324221002.GA10061@hades.domain.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-05timers: split process wide cpu clocks/timersPeter Zijlstra
Change the process wide cpu timers/clocks so that we: 1) don't mess up the kernel with too many threads, 2) don't have a per-cpu allocation for each process, 3) have no impact when not used. In order to accomplish this we're going to split it into two parts: - clocks; which can take all the time they want since they run from user context -- ie. sys_clock_gettime(CLOCK_PROCESS_CPUTIME_ID) - timers; which need constant time sampling but since they're explicity used, the user can pay the overhead. The clock readout will go back to a full sum of the thread group, while the timers will run of a global 'clock' that only runs when needed, so only programs that make use of the facility pay the price. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-07itimers: remove the per-cpu-ish-nessPeter Zijlstra
Either we bounce once cacheline per cpu per tick, yielding n^2 bounces or we just bounce a single.. Also, using per-cpu allocations for the thread-groups complicates the per-cpu allocator in that its currently aimed to be a fixed sized allocator and the only possible extention to that would be vmap based, which is seriously constrained on 32 bit archs. So making the per-cpu memory requirement depend on the number of processes is an issue. Lastly, it didn't deal with cpu-hotplug, although admittedly that might be fixable. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-02Merge branch 'cpus4096-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (66 commits) x86: export vector_used_by_percpu_irq x86: use logical apicid in x2apic_cluster's x2apic_cpu_mask_to_apicid_and() sched: nominate preferred wakeup cpu, fix x86: fix lguest used_vectors breakage, -v2 x86: fix warning in arch/x86/kernel/io_apic.c sched: fix warning in kernel/sched.c sched: move test_sd_parent() to an SMP section of sched.h sched: add SD_BALANCE_NEWIDLE at MC and CPU level for sched_mc>0 sched: activate active load balancing in new idle cpus sched: bias task wakeups to preferred semi-idle packages sched: nominate preferred wakeup cpu sched: favour lower logical cpu number for sched_mc balance sched: framework for sched_mc/smt_power_savings=N sched: convert BALANCE_FOR_xx_POWER to inline functions x86: use possible_cpus=NUM to extend the possible cpus allowed x86: fix cpu_mask_to_apicid_and to include cpu_online_mask x86: update io_apic.c to the new cpumask code x86: Introduce topology_core_cpumask()/topology_thread_cpumask() x86: xen: use smp_call_function_many() x86: use work_on_cpu in x86/kernel/cpu/mcheck/mce_amd_64.c ... Fixed up trivial conflict in kernel/time/tick-sched.c manually
2008-12-18schedstat: consolidate per-task cpu runtime statsKen Chen
Impact: simplify code When we turn on CONFIG_SCHEDSTATS, per-task cpu runtime is accumulated twice. Once in task->se.sum_exec_runtime and once in sched_info.cpu_time. These two stats are exactly the same. Given that task->se.sum_exec_runtime is always accumulated by the core scheduler, sched_info can reuse that data instead of duplicate the accounting. Signed-off-by: Ken Chen <kenchen@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-13Merge ../linux-2.6-x86Rusty Russell
Conflicts: arch/x86/kernel/io_apic.c kernel/sched.c kernel/sched_stats.h
2008-12-13cpumask: change cpumask_scnprintf, cpumask_parse_user, cpulist_parse, and ↵Rusty Russell
cpulist_scnprintf to take pointers. Impact: change calling convention of existing cpumask APIs Most cpumask functions started with cpus_: these have been replaced by cpumask_ ones which take struct cpumask pointers as expected. These four functions don't have good replacement names; fortunately they're rarely used, so we just change them over. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: paulus@samba.org Cc: mingo@redhat.com Cc: tony.luck@intel.com Cc: ralf@linux-mips.org Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: cl@linux-foundation.org Cc: srostedt@redhat.com
2008-11-24sched: wrap sched_group and sched_domain cpumask accesses.Rusty Russell
Impact: trivial wrap of member accesses This eases the transition in the next patch. We also get rid of a temporary cpumask in find_idlest_cpu() thanks to for_each_cpu_and, and sched_balance_self() due to getting weight before setting sd to NULL. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-17sched, signals: fix the racy usage of ->signal in ↵Oleg Nesterov
account_group_xxx/run_posix_cpu_timers Impact: fix potential NULL dereference Contrary to ad474caca3e2a0550b7ce0706527ad5ab389a4d4 changelog, other acct_group_xxx() helpers can be called after exit_notify() by timer tick. Thanks to Roland for pointing out this. Somehow I missed this simple fact when I read the original patch, and I am afraid I confused Frank during the discussion. Sorry. Fortunately, these helpers work with current, we can check ->exit_state to ensure that ->signal can't go away under us. Also, add the comment and compiler barrier to account_group_exec_runtime(), to make sure we load ->signal only once. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-23Merge branch 'proc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc * 'proc' of git://git.kernel.org/pub/scm/linux/kernel/git/adobriyan/proc: (35 commits) proc: remove fs/proc/proc_misc.c proc: move /proc/vmcore creation to fs/proc/vmcore.c proc: move pagecount stuff to fs/proc/page.c proc: move all /proc/kcore stuff to fs/proc/kcore.c proc: move /proc/schedstat boilerplate to kernel/sched_stats.h proc: move /proc/modules boilerplate to kernel/module.c proc: move /proc/diskstats boilerplate to block/genhd.c proc: move /proc/zoneinfo boilerplate to mm/vmstat.c proc: move /proc/vmstat boilerplate to mm/vmstat.c proc: move /proc/pagetypeinfo boilerplate to mm/vmstat.c proc: move /proc/buddyinfo boilerplate to mm/vmstat.c proc: move /proc/vmallocinfo to mm/vmalloc.c proc: move /proc/slabinfo boilerplate to mm/slub.c, mm/slab.c proc: move /proc/slab_allocators boilerplate to mm/slab.c proc: move /proc/interrupts boilerplate code to fs/proc/interrupts.c proc: move /proc/stat to fs/proc/stat.c proc: move rest of /proc/partitions code to block/genhd.c proc: move /proc/cpuinfo code to fs/proc/cpuinfo.c proc: move /proc/devices code to fs/proc/devices.c proc: move rest of /proc/locks to fs/locks.c ...
2008-10-23Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: disable the hrtick for now sched: revert back to per-rq vruntime sched: fair scheduler should not resched rt tasks sched: optimize group load balancer sched: minor fast-path overhead reduction sched: fix the wrong mask_len, cleanup sched: kill unused scheduler decl. sched: fix the wrong mask_len sched: only update rq->clock while holding rq->lock
2008-10-23proc: move /proc/schedstat boilerplate to kernel/sched_stats.hAlexey Dobriyan
2008-10-17sched: fix the wrong mask_len, cleanupPeter Zijlstra
Clean up the division in show_schedstat(). Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-17sched: fix the wrong mask_lenMiao Xie
If NR_CPUS isn't a multiple of 32, we get a truncated string of sched domains by catting /proc/schedstat. This is caused by the wrong mask_len. This patch fixes it. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Cc: <stable@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-27timers: fix itimer/many thread hang, v3Frank Mayhar
- fix UP lockup - another set of UP/SMP cleanups and simplifications Signed-off-by: Frank Mayhar <fmayhar@google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-23timers: fix itimer/many thread hang, v2Frank Mayhar
This is the second resubmission of the posix timer rework patch, posted a few days ago. This includes the changes from the previous resubmittion, which addressed Oleg Nesterov's comments, removing the RCU stuff from the patch and un-inlining the thread_group_cputime() function for SMP. In addition, per Ingo Molnar it simplifies the UP code, consolidating much of it with the SMP version and depending on lower-level SMP/UP handling to take care of the differences. It also cleans up some UP compile errors, moves the scheduler stats-related macros into kernel/sched_stats.h, cleans up a merge error in kernel/fork.c and has a few other minor fixes and cleanups as suggested by Oleg and Ingo. Thanks for the review, guys. Signed-off-by: Frank Mayhar <fmayhar@google.com> Cc: Roland McGrath <roland@redhat.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-04sched: fix accounting in task delay accounting & migrationAnkita Garg
On Thu, Jun 19, 2008 at 12:27:14PM +0200, Peter Zijlstra wrote: > On Thu, 2008-06-05 at 10:50 +0530, Ankita Garg wrote: > > > Thanks Peter for the explanation... > > > > I agree with the above and that is the reason why I did not see weird > > values with cpu_time. But, run_delay still would suffer skews as the end > > points for delta could be taken on different cpus due to migration (more > > so on RT kernel due to the push-pull operations). With the below patch, > > I could not reproduce the issue I had seen earlier. After every dequeue, > > we take the delta and start wait measurements from zero when moved to a > > different rq. > > OK, so task delay delay accounting is broken because it doesn't take > migration into account. > > What you've done is make it symmetric wrt enqueue, and account it like > > cpu0 cpu1 > > enqueue > <wait-d1> > dequeue > enqueue > <wait-d2> > run > > Where you add both d1 and d2 to the run_delay,.. right? > Thanks for reviewing the patch. The above is exactly what I have done. > This seems like a good fix, however it looks like the patch will break > compilation in !CONFIG_SCHEDSTATS && !CONFIG_TASK_DELAY_ACCT, of it > failing to provide a stub for sched_info_dequeue() in that case. Fixed. Pl. find the new patch below. Signed-off-by: Ankita Garg <ankita@in.ibm.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Cc: Gregory Haskins <ghaskins@novell.com> Cc: rostedt@goodmis.org Cc: suresh.b.siddha@intel.com Cc: aneesh.kumar@linux.vnet.ibm.com Cc: dhaval@linux.vnet.ibm.com Cc: vatsa@linux.vnet.ibm.com Cc: David Bahi <DBahi@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-06-19sched, delay accounting: fix incorrect delay time when constantly waiting on ↵Bharath Ravi
runqueue This patch corrects the incorrect value of per process run-queue wait time reported by delay statistics. The anomaly was due to the following reason. When a process leaves the CPU and immediately starts waiting for CPU on the runqueue (which means it remains in the TASK_RUNNABLE state), the time of re-entry into the run-queue is never recorded. Due to this, the waiting time on the runqueue from this point of re-entry upto the next time it hits the CPU is not accounted for. This is solved by recording the time of re-entry of a process leaving the CPU in the sched_info_depart() function IF the process will go back to waiting on the run-queue. This IF condition is verified by checking whether the process is still in the TASK_RUNNABLE state. The patch was tested on 2.6.26-rc6 using two simple CPU hog programs. The values noted prior to the fix did not account for the time spent on the runqueue waiting. After the fix, the correct values were reported back to user space. Signed-off-by: Bharath Ravi <bharathravi1@gmail.com> Signed-off-by: Madhava K R <madhavakr@gmail.com> Cc: dhaval@linux.vnet.ibm.com Cc: vatsa@in.ibm.com Cc: balbir@in.ibm.com Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-29show_schedstat(): fix memleakAdrian Bunk
The Coverity checker spotted a memleak introduced by commit 39106dcf85285e78f3b290022122c76f851379b8 (cpumask: use new cpus_scnprintf function). It seems the kfree() got lost between v2 and v3 of this patch... Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Mike Travis <travis@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-04-19cpumask: use new cpus_scnprintf functionMike Travis
* Cleaned up references to cpumask_scnprintf() and added new cpulist_scnprintf() interfaces where appropriate. * Fix some small bugs (or code efficiency improvments) for various uses of cpumask_scnprintf. * Clean up some checkpatch errors. Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-11-28sched: clean up kernel/sched_stat.hIngo Molnar
clean up kernel/sched_stat.h. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-11-09sched: fix delay accounting regressionBalbir Singh
Fix the delay accounting regression introduced by commit 75d4ef16a6aa84f708188bada182315f80aab6fa. rq no longer has sched_info data associated with it. task_struct sched_info structure is used by delay accounting to provide back statistics to user space. also remove direct use of sched_clock() (which is not a valid thing to do anymore) and use rq->clock instead. Signed-off-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-18sched: reduce schedstat variable overhead a bitKen Chen
schedstat is useful in investigating CPU scheduler behavior. Ideally, I think it is beneficial to have it on all the time. However, the cost of turning it on in production system is quite high, largely due to number of events it collects and also due to its large memory footprint. Most of the fields probably don't need to be full 64-bit on 64-bit arch. Rolling over 4 billion events will most like take a long time and user space tool can be made to accommodate that. I'm proposing kernel to cut back most of variable width on 64-bit system. (note, the following patch doesn't affect 32-bit system). Signed-off-by: Ken Chen <kenchen@google.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-15sched: clean up schedstats, cnt -> countIngo Molnar
rename all 'cnt' fields and variables to the less yucky 'count' name. yuckage noticed by Andrew Morton. no change in code, other than the /proc/sched_debug bkl_count string got a bit larger: text data bss dec hex filename 38236 3506 24 41766 a326 sched.o.before 38240 3506 24 41770 a32a sched.o.after Signed-off-by: Ingo Molnar <mingo@elte.hu> Reviewed-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-15sched: fix delay accounting performance regressionIngo Molnar
fix delay accounting performance regression - those sched_clock() calls are not needed. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: Thomas Gleixner <tglx@linutronix.de>
2007-08-02[PATCH] sched: add schedstat_set() APIIngo Molnar
add the schedstat_set() API, to allow the reduction of CONFIG_SCHEDSTAT related #ifdefs. No code changed. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-07-09sched: update delay-accounting to use CFS's precise statsBalbir Singh
update delay-accounting to use CFS's precise stats. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-07-09sched: move code into kernel/sched_stats.hIngo Molnar
create sched_stats.h and move sched.c schedstats code into it. This cleans up sched.c a bit. no code changes are caused by this patch. Signed-off-by: Ingo Molnar <mingo@elte.hu>
