path: root/kernel/sched_stoptask.c
2011-04-14sched: Drop the rq argument to sched_class::select_task_rq()Peter Zijlstra
In preparation of calling select_task_rq() without rq->lock held, drop the dependency on the rq argument. Reviewed-by: Frank Rowand <frank.rowand@am.sony.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/20110405152729.031077745@chello.nl Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-04-14sched: Provide p->on_rqPeter Zijlstra
Provide a generic p->on_rq because the p->se.on_rq semantics are unfavourable for lockless wakeups but needed for sched_fair. In particular, p->on_rq is only cleared when we actually dequeue the task in schedule() and not on any random dequeue as done by things like __migrate_task() and __sched_setscheduler(). This also allows us to remove p->se usage from !sched_fair code. Reviewed-by: Frank Rowand <frank.rowand@am.sony.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110405152728.949545047@chello.nl
2011-03-23sched, doc: Update sched-design-CFS.txtBorislav Petkov
Correct ->dequeue_tree() thinko into sched_class->dequeue_task and drop all references to ->task_new() since it is obviously gone. Signed-off-by: Borislav Petkov <borislav.petkov@amd.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> LKML-Reference: <1300815978-16618-1-git-send-email-bp@amd64.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-01-26sched: Fix switch_from_fair()Peter Zijlstra
When a task is taken out of the fair class we must ensure the vruntime is properly normalized because when we put it back in it will assume to be normalized. The case that goes wrong is when changing away from the fair class while sleeping. Sleeping tasks have non-normalized vruntime in order to make sleeper-fairness work. So treat the switch away from fair as a wakeup and preserve the relative vruntime. Also update sysrq-n to call the ->switch_{to,from} methods. Reported-by: Onkalo Samu <samu.p.onkalo@nokia.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-11sched: Fix cross-sched-class wakeup preemptionPeter Zijlstra
Instead of dealing with sched classes inside each check_preempt_curr() implementation, pull out this logic into the generic wakeup preemption path. This fixes a hang in KVM (and others) where we are waiting for the stop machine thread to run ... Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de> Tested-by: Marcelo Tosatti <mtosatti@redhat.com> Tested-by: Sergey Senozhatsky <sergey.senozhatsky@gmail.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1288891946.2039.31.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-10sched: Fix runnable condition for stoptaskPeter Zijlstra
Heiko reported that the TASK_RUNNING check is not sufficient for CONFIG_PREEMPT=y since we can get preempted with !TASK_RUNNING. He suggested adding a ->se.on_rq test to the existing TASK_RUNNING one, however TASK_RUNNING will always have ->se.on_rq, so we might as well reduce that to a single test. [ stop tasks should never get preempted, but its good to handle this case correctly should this ever happen ] Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-10-18sched: Create special class for stop/migrate workPeter Zijlstra
In order to separate the stop/migrate work thread from the SCHED_FIFO implementation, create a special class for it that is of higher priority than SCHED_FIFO itself. This currently solves a problem where cpu-hotplug consumes so much cpu-time that the SCHED_FIFO class gets throttled, but has the bandwidth replenishment timer pending on the now dead cpu. It is also required for when we add the planned deadline scheduling class above SCHED_FIFO, as the stop/migrate thread still needs to transcent those tasks. Tested-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1285165776.2275.1022.camel@laptop> Signed-off-by: Ingo Molnar <mingo@elte.hu>
