path: root/kernel/signal.c
2010-07-05signals: check_kill_permission(): don't check creds if same_thread_group()Oleg Nesterov
commit 065add3941bdca54fe04ed3471a96bce9af88793 upstream. Andrew Tridgell reports that aio_read(SIGEV_SIGNAL) can fail if the notification from the helper thread races with setresuid(), see http://samba.org/~tridge/junkcode/aio_uid.c This happens because check_kill_permission() doesn't permit sending a signal to the task with the different cred->xids. But there is not any security reason to check ->cred's when the task sends a signal (private or group-wide) to its sub-thread. Whatever we do, any thread can bypass all security checks and send SIGKILL to all threads, or it can block a signal SIG and do kill(gettid(), SIG) to deliver this signal to another sub-thread. Not to mention that CLONE_THREAD implies CLONE_VM. Change check_kill_permission() to avoid the credentials check when the sender and the target are from the same thread group. Also, move "cred = current_cred()" down to avoid calling get_current() twice. Note: David Howells pointed out we could relax this even more, the CLONE_SIGHAND (without CLONE_THREAD) case probably does not need these checks too. Roland said: : The glibc (libpthread) that does set*id across threads has : been in use for a while (2.3.4?), probably in distro's using kernels as old : or older than any active -stable streams. In the race in question, this : kernel bug is breaking valid POSIX application expectations. Reported-by: Andrew Tridgell <tridge@samba.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: David Howells <dhowells@redhat.com> Cc: Eric Paris <eparis@parisplace.org> Cc: Jakub Jelinek <jakub@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: Roland McGrath <roland@redhat.com> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-18kernel/signal.c: fix kernel information leak with print-fatal-signals=1Andi Kleen
commit b45c6e76bc2c72f6426c14bed64fdcbc9bf37cb0 upstream. When print-fatal-signals is enabled it's possible to dump any memory reachable by the kernel to the log by simply jumping to that address from user space. Or crash the system if there's some hardware with read side effects. The fatal signals handler will dump 16 bytes at the execution address, which is fully controlled by ring 3. In addition when something jumps to a unmapped address there will be up to 16 additional useless page faults, which might be potentially slow (and at least is not very efficient) Fortunately this option is off by default and only there on i386. But fix it by checking for kernel addresses and also stopping when there's a page fault. Signed-off-by: Andi Kleen <ak@linux.intel.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-24signals: inline __fatal_signal_pendingRoland McGrath
__fatal_signal_pending inlines to one instruction on x86, probably two instructions on other machines. It takes two longer x86 instructions just to call it and test its return value, not to mention the function itself. On my random x86_64 config, this saved 70 bytes of text (59 of those being __fatal_signal_pending itself). Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24signals: introduce do_send_sig_info() helperOleg Nesterov
Introduce do_send_sig_info() and convert group_send_sig_info(), send_sig_info(), do_send_specific() to use this helper. Hopefully it will have more users soon, it allows to specify specific/group behaviour via "bool group" argument. Shaves 80 bytes from .text. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: stephane eranian <eranian@googlemail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24signals: tracehook_notify_jctl changeRoland McGrath
This changes tracehook_notify_jctl() so it's called with the siglock held, and changes its argument and return value definition. These clean-ups make it a better fit for what new tracing hooks need to check. Tracing needs the siglock here, held from the time TASK_STOPPED was set, to avoid potential SIGCONT races if it wants to allow any blocking in its tracing hooks. This also folds the finish_stop() function into its caller do_signal_stop(). The function is short, called only once and only unconditionally. It aids readability to fold it in. [oleg@redhat.com: do not call tracehook_notify_jctl() in TASK_STOPPED state] [oleg@redhat.com: introduce tracehook_finish_jctl() helper] Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24ptrace: __ptrace_detach: do __wake_up_parent() if we reap the traceeOleg Nesterov
The bug is old, it wasn't cause by recent changes. Test case: static void *tfunc(void *arg) { int pid = (long)arg; assert(ptrace(PTRACE_ATTACH, pid, NULL, NULL) == 0); kill(pid, SIGKILL); sleep(1); return NULL; } int main(void) { pthread_t th; long pid = fork(); if (!pid) pause(); signal(SIGCHLD, SIG_IGN); assert(pthread_create(&th, NULL, tfunc, (void*)pid) == 0); int r = waitpid(-1, NULL, __WNOTHREAD); printf("waitpid: %d %m\n", r); return 0; } Before the patch this program hangs, after this patch waitpid() correctly fails with errno == -ECHILD. The problem is, __ptrace_detach() reaps the EXIT_ZOMBIE tracee if its ->real_parent is our sub-thread and we ignore SIGCHLD. But in this case we should wake up other threads which can sleep in do_wait(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Vitaly Mayatskikh <vmayatsk@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-01do_sigaltstack: small cleanupsLinus Torvalds
The previous commit ("do_sigaltstack: avoid copying 'stack_t' as a structure to user space") fixed a real bug. This one just cleans up the copy from user space to that gcc can generate better code for it (and so that it looks the same as the later copy back to user space). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-01do_sigaltstack: avoid copying 'stack_t' as a structure to user spaceLinus Torvalds
Ulrich Drepper correctly points out that there is generally padding in the structure on 64-bit hosts, and that copying the structure from kernel to user space can leak information from the kernel stack in those padding bytes. Avoid the whole issue by just copying the three members one by one instead, which also means that the function also can avoid the need for a stack frame. This also happens to match how we copy the new structure from user space, so it all even makes sense. [ The obvious solution of adding a memset() generates horrid code, gcc does really stupid things. ] Reported-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18ptrace: do_notify_parent_cldstop: fix the wrong ->nsproxy usageOleg Nesterov
If the non-traced sub-thread calls do_notify_parent_cldstop(), we send the notification to group_leader->real_parent and we report group_leader's pid. But, if group_leader is traced we use the wrong ->parent->nsproxy->pid_ns, the tracer and parent can live in different namespaces. Change the code to use "parent" instead of tsk->parent. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-18ptrace: do not use task->ptrace directly in core kernelOleg Nesterov
No functional changes. - Nobody except ptrace.c & co should use ptrace flags directly, we have task_ptrace() for that. - No need to specially check PT_PTRACED, we must not have other PT_ bits set without PT_PTRACED. And no need to know this flag exists. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-15signal: fix __send_signal() false positive kmemcheck warningVegard Nossum
This false positive is due to field padding in struct sigqueue. When this dynamically allocated structure is copied to the stack (in arch- specific delivery code), kmemcheck sees a read from the padding, which is, naturally, uninitialized. Hide the false positive using the __GFP_NOTRACK_FALSE_POSITIVE flag. Also made the rlimit override code a bit clearer by introducing a new variable. Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2009-06-11Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (44 commits) nommu: Provide mmap_min_addr definition. TOMOYO: Add description of lists and structures. TOMOYO: Remove unused field. integrity: ima audit dentry_open failure TOMOYO: Remove unused parameter. security: use mmap_min_addr indepedently of security models TOMOYO: Simplify policy reader. TOMOYO: Remove redundant markers. SELinux: define audit permissions for audit tree netlink messages TOMOYO: Remove unused mutex. tomoyo: avoid get+put of task_struct smack: Remove redundant initialization. integrity: nfsd imbalance bug fix rootplug: Remove redundant initialization. smack: do not beyond ARRAY_SIZE of data integrity: move ima_counts_get integrity: path_check update IMA: Add __init notation to ima functions IMA: Minimal IMA policy and boot param for TCB IMA policy selinux: remove obsolete read buffer limit from sel_read_bool ...
2009-06-10Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (244 commits) Revert "x86, bts: reenable ptrace branch trace support" tracing: do not translate event helper macros in print format ftrace/documentation: fix typo in function grapher name tracing/events: convert block trace points to TRACE_EVENT(), fix !CONFIG_BLOCK tracing: add protection around module events unload tracing: add trace_seq_vprint interface tracing: fix the block trace points print size tracing/events: convert block trace points to TRACE_EVENT() ring-buffer: fix ret in rb_add_time_stamp ring-buffer: pass in lockdep class key for reader_lock tracing: add annotation to what type of stack trace is recorded tracing: fix multiple use of __print_flags and __print_symbolic tracing/events: fix output format of user stack tracing/events: fix output format of kernel stack tracing/trace_stack: fix the number of entries in the header ring-buffer: discard timestamps that are at the start of the buffer ring-buffer: try to discard unneeded timestamps ring-buffer: fix bug in ring_buffer_discard_commit ftrace: do not profile functions when disabled tracing: make trace pipe recognize latency format flag ...
2009-05-08Merge branch 'master' into nextJames Morris
2009-04-30signals: implement sys_rt_tgsigqueueinfoThomas Gleixner
sys_kill has the per thread counterpart sys_tgkill. sigqueueinfo is missing a thread directed counterpart. Such an interface is important for migrating applications from other OSes which have the per thread delivery implemented. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Roland McGrath <roland@redhat.com> Acked-by: Ulrich Drepper <drepper@redhat.com>
2009-04-30signals: split do_tkillThomas Gleixner
Split out the code from do_tkill to make it reusable by the follow up patch which implements sys_rt_tgsigqueueinfo Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Oleg Nesterov <oleg@redhat.com>
2009-04-30SELinux: Don't flush inherited SIGKILL during execve()David Howells
Don't flush inherited SIGKILL during execve() in SELinux's post cred commit hook. This isn't really a security problem: if the SIGKILL came before the credentials were changed, then we were right to receive it at the time, and should honour it; if it came after the creds were changed, then we definitely should honour it; and in any case, all that will happen is that the process will be scrapped before it ever returns to userspace. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-04-14tracing/events: move trace point headers into include/trace/eventsSteven Rostedt
Impact: clean up Create a sub directory in include/trace called events to keep the trace point headers in their own separate directory. Only headers that declare trace points should be defined in this directory. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Zhao Lei <zhaolei@cn.fujitsu.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-14tracing: create automated trace definesSteven Rostedt
This patch lowers the number of places a developer must modify to add new tracepoints. The current method to add a new tracepoint into an existing system is to write the trace point macro in the trace header with one of the macros TRACE_EVENT, TRACE_FORMAT or DECLARE_TRACE, then they must add the same named item into the C file with the macro DEFINE_TRACE(name) and then add the trace point. This change cuts out the needing to add the DEFINE_TRACE(name). Every file that uses the tracepoint must still include the trace/<type>.h file, but the one C file must also add a define before the including of that file. #define CREATE_TRACE_POINTS #include <trace/mytrace.h> This will cause the trace/mytrace.h file to also produce the C code necessary to implement the trace point. Note, if more than one trace/<type>.h is used to create the C code it is best to list them all together. #define CREATE_TRACE_POINTS #include <trace/foo.h> #include <trace/bar.h> #include <trace/fido.h> Thanks to Mathieu Desnoyers and Christoph Hellwig for coming up with the cleaner solution of the define above the includes over my first design to have the C code include a "special" header. This patch converts sched, irq and lockdep and skb to use this new method. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Neil Horman <nhorman@tuxdriver.com> Cc: Zhao Lei <zhaolei@cn.fujitsu.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-02signals: SI_USER: Masquerade si_pid when crossing pid ns boundarySukadev Bhattiprolu
When sending a signal to a descendant namespace, set ->si_pid to 0 since the sender does not have a pid in the receiver's namespace. Note: - If rt_sigqueueinfo() sets si_code to SI_USER when sending a signal across a pid namespace boundary, the value in ->si_pid will be cleared to 0. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02signals: protect cinit from blocked fatal signalsSukadev Bhattiprolu
Normally SIG_DFL signals to global and container-init are dropped early. But if a signal is blocked when it is posted, we cannot drop the signal since the receiver may install a handler before unblocking the signal. Once this signal is queued however, the receiver container-init has no way of knowing if the signal was sent from an ancestor or descendant namespace. This patch ensures that contianer-init drops all SIG_DFL signals in get_signal_to_deliver() except SIGKILL/SIGSTOP. If SIGSTOP/SIGKILL originate from a descendant of container-init they are never queued (i.e dropped in sig_ignored() in an earler patch). If SIGSTOP/SIGKILL originate from parent namespace, the signal is queued and container-init processes the signal. IOW, if get_signal_to_deliver() sees a sig_kernel_only() signal for global or container-init, the signal must have been generated internally or must have come from an ancestor ns and we process the signal. Further, the signal_group_exit() check was needed to cover the case of a multi-threaded init sending SIGKILL to other threads when doing an exit() or exec(). But since the new sig_kernel_only() check covers the SIGKILL, the signal_group_exit() check is no longer needed and can be removed. Finally, now that we have all pieces in place, set SIGNAL_UNKILLABLE for container-inits. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02signals: protect cinit from unblocked SIG_DFL signalsSukadev Bhattiprolu
Drop early any SIG_DFL or SIG_IGN signals to container-init from within the same container. But queue SIGSTOP and SIGKILL to the container-init if they are from an ancestor container. Blocked, fatal signals (i.e when SIG_DFL is to terminate) from within the container can still terminate the container-init. That will be addressed in the next patch. Note: To be bisect-safe, SIGNAL_UNKILLABLE will be set for container-inits in a follow-on patch. Until then, this patch is just a preparatory step. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02signals: add from_ancestor_ns parameter to send_signal()Sukadev Bhattiprolu
send_signal() (or its helper) needs to determine the pid namespace of the sender. But a signal sent via kill_pid_info_as_uid() comes from within the kernel and send_signal() does not need to determine the pid namespace of the sender. So define a helper for send_signal() which takes an additional parameter, 'from_ancestor_ns' and have kill_pid_info_as_uid() use that helper directly. The 'from_ancestor_ns' parameter will be used in a follow-on patch. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02signals: protect init from unwanted signals moreOleg Nesterov
(This is a modified version of the patch submitted by Oleg Nesterov http://lkml.org/lkml/2008/11/18/249 and tries to address comments that came up in that discussion) init ignores the SIG_DFL signals but we queue them anyway, including SIGKILL. This is mostly OK, the signal will be dropped silently when dequeued, but the pending SIGKILL has 2 bad implications: - it implies fatal_signal_pending(), so we confuse things like wait_for_completion_killable/lock_page_killable. - for the sub-namespace inits, the pending SIGKILL can mask (legacy_queue) the subsequent SIGKILL from the parent namespace which must kill cinit reliably. (preparation, cinits don't have SIGNAL_UNKILLABLE yet) The patch can't help when init is ptraced, but ptracing of init is not "safe" anyway. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02signals: remove 'handler' parameter to tracehook functionsOleg Nesterov
Container-init must behave like global-init to processes within the container and hence it must be immune to unhandled fatal signals from within the container (i.e SIG_DFL signals that terminate the process). But the same container-init must behave like a normal process to processes in ancestor namespaces and so if it receives the same fatal signal from a process in ancestor namespace, the signal must be processed. Implementing these semantics requires that send_signal() determine pid namespace of the sender but since signals can originate from workqueues/ interrupt-handlers, determining pid namespace of sender may not always be possible or safe. This patchset implements the design/simplified semantics suggested by Oleg Nesterov. The simplified semantics for container-init are: - container-init must never be terminated by a signal from a descendant process. - container-init must never be immune to SIGKILL from an ancestor namespace (so a process in parent namespace must always be able to terminate a descendant container). - container-init may be immune to unhandled fatal signals (like SIGUSR1) even if they are from ancestor namespace. SIGKILL/SIGSTOP are the only reliable signals to a container-init from ancestor namespace. This patch: Based on an earlier patch submitted by Oleg Nesterov and comments from Roland McGrath (http://lkml.org/lkml/2008/11/19/258). The handler parameter is currently unused in the tracehook functions. Besides, the tracehook functions are called with siglock held, so the functions can check the handler if they later need to. Removing the parameter simiplifies changes to sig_ignored() in a follow-on patch. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-23fix ptrace slownessMiklos Szeredi
This patch fixes bug #12208: Bug-Entry : http://bugzilla.kernel.org/show_bug.cgi?id=12208 Subject : uml is very slow on 2.6.28 host This turned out to be not a scheduler regression, but an already existing problem in ptrace being triggered by subtle scheduler changes. The problem is this: - task A is ptracing task B - task B stops on a trace event - task A is woken up and preempts task B - task A calls ptrace on task B, which does ptrace_check_attach() - this calls wait_task_inactive(), which sees that task B is still on the runq - task A goes to sleep for a jiffy - ... Since UML does lots of the above sequences, those jiffies quickly add up to make it slow as hell. This patch solves this by not rescheduling in read_unlock() after ptrace_stop() has woken up the tracer. Thanks to Oleg Nesterov and Ingo Molnar for the feedback. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> CC: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-05signal: re-add dead task accumulation stats.Peter Zijlstra
We're going to split the process wide cpu accounting into two parts: - clocks; which can take all the time they want since they run from user context. - timers; which need constant time tracing but can affort the overhead because they're default off -- and rare. The clock readout will go back to a full sum of the thread group, for this we need to re-add the exit stats that were removed in the initial itimer rework (f06febc9: timers: fix itimer/many thread hang). Furthermore, since that full sum can be rather slow for large thread groups and we have the complete dead task stats, revert the do_notify_parent time computation. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-27signals, debug: fix BUG: using smp_processor_id() in preemptible code in ↵Ed Swierk
print_fatal_signal() With print-fatal-signals=1 on a kernel with CONFIG_PREEMPT=y, sending an unexpected signal to a process causes a BUG: using smp_processor_id() in preemptible code. get_signal_to_deliver() releases the siglock before calling print_fatal_signal(), which calls show_regs(), which calls smp_processor_id(), which is not supposed to be called from a preemptible thread. Make sure show_regs() runs with preemption disabled. Signed-off-by: Ed Swierk <eswierk@aristanetworks.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-01-14[CVE-2009-0029] System call wrappers part 32Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 09Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 08Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 07Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 04Heiko Carstens
2009-01-14[CVE-2009-0029] Convert all system calls to return a longHeiko Carstens
Convert all system calls to return a long. This should be a NOP since all converted types should have the same size anyway. With the exception of sys_exit_group which returned void. But that doesn't matter since the system call doesn't return. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2009-01-06SEND_SIG_NOINFO: set si_pid to tgid instead of pidSukadev Bhattiprolu
POSIX requires the si_pid to be the process id of the sender, so ->si_pid should really be set to 'tgid'. This change does have following changes in behavior: - When sending pdeath_signal on re-parent to a sub-thread, ->si_pid cannot be used to identify the thread that did the re-parent since it will now show the tgid instead of thread id. - A multi-threaded application that expects to find the specific thread that encountered a SIGPIPE using the ->si_pid will now break. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-By: Roland McGrath <roland@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06SEND_SIG_NOINFO: masquerade si_pid when crossing pid-ns boundarySukadev Bhattiprolu
For SEND_SIG_NOINFO, si_pid is currently set to the pid of sender in sender's active pid namespace. But if the receiver is in a Eg: when parent sends the 'pdeath_signal' to a child that is in a descendant pid namespace, we should set si_pid 0. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-By: Roland McGrath <roland@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-28Merge branch 'tracing-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (241 commits) sched, trace: update trace_sched_wakeup() tracing/ftrace: don't trace on early stage of a secondary cpu boot, v3 Revert "x86: disable X86_PTRACE_BTS" ring-buffer: prevent false positive warning ring-buffer: fix dangling commit race ftrace: enable format arguments checking x86, bts: memory accounting x86, bts: add fork and exit handling ftrace: introduce tracing_reset_online_cpus() helper tracing: fix warnings in kernel/trace/trace_sched_switch.c tracing: fix warning in kernel/trace/trace.c tracing/ring-buffer: remove unused ring_buffer size trace: fix task state printout ftrace: add not to regex on filtering functions trace: better use of stack_trace_enabled for boot up code trace: add a way to enable or disable the stack tracer x86: entry_64 - introduce FTRACE_ frame macro v2 tracing/ftrace: add the printk-msg-only option tracing/ftrace: use preempt_enable_no_resched_notrace in ring_buffer_time_stamp() x86, bts: correctly report invalid bts records ... Fixed up trivial conflict in scripts/recordmcount.pl due to SH bits being already partly merged by the SH merge.
2008-11-16tracepoints: add DECLARE_TRACE() and DEFINE_TRACE()Mathieu Desnoyers
Impact: API *CHANGE*. Must update all tracepoint users. Add DEFINE_TRACE() to tracepoints to let them declare the tracepoint structure in a single spot for all the kernel. It helps reducing memory consumption, especially when declaring a lot of tracepoints, e.g. for kmalloc tracing. *API CHANGE WARNING*: now, DECLARE_TRACE() must be used in headers for tracepoint declarations rather than DEFINE_TRACE(). This is the sane way to do it. The name previously used was misleading. Updates scheduler instrumentation to follow this API change. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-14CRED: Inaugurate COW credentialsDavid Howells
Inaugurate copy-on-write credentials management. This uses RCU to manage the credentials pointer in the task_struct with respect to accesses by other tasks. A process may only modify its own credentials, and so does not need locking to access or modify its own credentials. A mutex (cred_replace_mutex) is added to the task_struct to control the effect of PTRACE_ATTACHED on credential calculations, particularly with respect to execve(). With this patch, the contents of an active credentials struct may not be changed directly; rather a new set of credentials must be prepared, modified and committed using something like the following sequence of events: struct cred *new = prepare_creds(); int ret = blah(new); if (ret < 0) { abort_creds(new); return ret; } return commit_creds(new); There are some exceptions to this rule: the keyrings pointed to by the active credentials may be instantiated - keyrings violate the COW rule as managing COW keyrings is tricky, given that it is possible for a task to directly alter the keys in a keyring in use by another task. To help enforce this, various pointers to sets of credentials, such as those in the task_struct, are declared const. The purpose of this is compile-time discouragement of altering credentials through those pointers. Once a set of credentials has been made public through one of these pointers, it may not be modified, except under special circumstances: (1) Its reference count may incremented and decremented. (2) The keyrings to which it points may be modified, but not replaced. The only safe way to modify anything else is to create a replacement and commit using the functions described in Documentation/credentials.txt (which will be added by a later patch). This patch and the preceding patches have been tested with the LTP SELinux testsuite. This patch makes several logical sets of alteration: (1) execve(). This now prepares and commits credentials in various places in the security code rather than altering the current creds directly. (2) Temporary credential overrides. do_coredump() and sys_faccessat() now prepare their own credentials and temporarily override the ones currently on the acting thread, whilst preventing interference from other threads by holding cred_replace_mutex on the thread being dumped. This will be replaced in a future patch by something that hands down the credentials directly to the functions being called, rather than altering the task's objective credentials. (3) LSM interface. A number of functions have been changed, added or removed: (*) security_capset_check(), ->capset_check() (*) security_capset_set(), ->capset_set() Removed in favour of security_capset(). (*) security_capset(), ->capset() New. This is passed a pointer to the new creds, a pointer to the old creds and the proposed capability sets. It should fill in the new creds or return an error. All pointers, barring the pointer to the new creds, are now const. (*) security_bprm_apply_creds(), ->bprm_apply_creds() Changed; now returns a value, which will cause the process to be killed if it's an error. (*) security_task_alloc(), ->task_alloc_security() Removed in favour of security_prepare_creds(). (*) security_cred_free(), ->cred_free() New. Free security data attached to cred->security. (*) security_prepare_creds(), ->cred_prepare() New. Duplicate any security data attached to cred->security. (*) security_commit_creds(), ->cred_commit() New. Apply any security effects for the upcoming installation of new security by commit_creds(). (*) security_task_post_setuid(), ->task_post_setuid() Removed in favour of security_task_fix_setuid(). (*) security_task_fix_setuid(), ->task_fix_setuid() Fix up the proposed new credentials for setuid(). This is used by cap_set_fix_setuid() to implicitly adjust capabilities in line with setuid() changes. Changes are made to the new credentials, rather than the task itself as in security_task_post_setuid(). (*) security_task_reparent_to_init(), ->task_reparent_to_init() Removed. Instead the task being reparented to init is referred directly to init's credentials. NOTE! This results in the loss of some state: SELinux's osid no longer records the sid of the thread that forked it. (*) security_key_alloc(), ->key_alloc() (*) security_key_permission(), ->key_permission() Changed. These now take cred pointers rather than task pointers to refer to the security context. (4) sys_capset(). This has been simplified and uses less locking. The LSM functions it calls have been merged. (5) reparent_to_kthreadd(). This gives the current thread the same credentials as init by simply using commit_thread() to point that way. (6) __sigqueue_alloc() and switch_uid() __sigqueue_alloc() can't stop the target task from changing its creds beneath it, so this function gets a reference to the currently applicable user_struct which it then passes into the sigqueue struct it returns if successful. switch_uid() is now called from commit_creds(), and possibly should be folded into that. commit_creds() should take care of protecting __sigqueue_alloc(). (7) [sg]et[ug]id() and co and [sg]et_current_groups. The set functions now all use prepare_creds(), commit_creds() and abort_creds() to build and check a new set of credentials before applying it. security_task_set[ug]id() is called inside the prepared section. This guarantees that nothing else will affect the creds until we've finished. The calling of set_dumpable() has been moved into commit_creds(). Much of the functionality of set_user() has been moved into commit_creds(). The get functions all simply access the data directly. (8) security_task_prctl() and cap_task_prctl(). security_task_prctl() has been modified to return -ENOSYS if it doesn't want to handle a function, or otherwise return the return value directly rather than through an argument. Additionally, cap_task_prctl() now prepares a new set of credentials, even if it doesn't end up using it. (9) Keyrings. A number of changes have been made to the keyrings code: (a) switch_uid_keyring(), copy_keys(), exit_keys() and suid_keys() have all been dropped and built in to the credentials functions directly. They may want separating out again later. (b) key_alloc() and search_process_keyrings() now take a cred pointer rather than a task pointer to specify the security context. (c) copy_creds() gives a new thread within the same thread group a new thread keyring if its parent had one, otherwise it discards the thread keyring. (d) The authorisation key now points directly to the credentials to extend the search into rather pointing to the task that carries them. (e) Installing thread, process or session keyrings causes a new set of credentials to be created, even though it's not strictly necessary for process or session keyrings (they're shared). (10) Usermode helper. The usermode helper code now carries a cred struct pointer in its subprocess_info struct instead of a new session keyring pointer. This set of credentials is derived from init_cred and installed on the new process after it has been cloned. call_usermodehelper_setup() allocates the new credentials and call_usermodehelper_freeinfo() discards them if they haven't been used. A special cred function (prepare_usermodeinfo_creds()) is provided specifically for call_usermodehelper_setup() to call. call_usermodehelper_setkeys() adjusts the credentials to sport the supplied keyring as the new session keyring. (11) SELinux. SELinux has a number of changes, in addition to those to support the LSM interface changes mentioned above: (a) selinux_setprocattr() no longer does its check for whether the current ptracer can access processes with the new SID inside the lock that covers getting the ptracer's SID. Whilst this lock ensures that the check is done with the ptracer pinned, the result is only valid until the lock is released, so there's no point doing it inside the lock. (12) is_single_threaded(). This function has been extracted from selinux_setprocattr() and put into a file of its own in the lib/ directory as join_session_keyring() now wants to use it too. The code in SELinux just checked to see whether a task shared mm_structs with other tasks (CLONE_VM), but that isn't good enough. We really want to know if they're part of the same thread group (CLONE_THREAD). (13) nfsd. The NFS server daemon now has to use the COW credentials to set the credentials it is going to use. It really needs to pass the credentials down to the functions it calls, but it can't do that until other patches in this series have been applied. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Use RCU to access another task's creds and to release a task's own credsDavid Howells
Use RCU to access another task's creds and to release a task's own creds. This means that it will be possible for the credentials of a task to be replaced without another task (a) requiring a full lock to read them, and (b) seeing deallocated memory. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap task credential accesses in the core kernelDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: linux-audit@redhat.com Cc: containers@lists.linux-foundation.org Cc: linux-mm@kvack.org Signed-off-by: James Morris <jmorris@namei.org>
2008-10-30'kill sig -1' must only apply to caller's namespaceSukadev Bhattiprolu
Currently "kill <sig> -1" kills processes in all namespaces and breaks the isolation of namespaces. Earlier attempt to fix this was discussed at: http://lkml.org/lkml/2008/7/23/148 As suggested by Oleg Nesterov in that thread, use "task_pid_vnr() > 1" check since task_pid_vnr() returns 0 if process is outside the caller's namespace. Signed-off-by: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Acked-by: Eric W. Biederman <ebiederm@xmission.com> Tested-by: Daniel Hokka Zakrisson <daniel@hozac.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20Merge branch 'tracing-v28-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-v28-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (131 commits) tracing/fastboot: improve help text tracing/stacktrace: improve help text tracing/fastboot: fix initcalls disposition in bootgraph.pl tracing/fastboot: fix bootgraph.pl initcall name regexp tracing/fastboot: fix issues and improve output of bootgraph.pl tracepoints: synchronize unregister static inline tracepoints: tracepoint_synchronize_unregister() ftrace: make ftrace_test_p6nop disassembler-friendly markers: fix synchronize marker unregister static inline tracing/fastboot: add better resolution to initcall debug/tracing trace: add build-time check to avoid overrunning hex buffer ftrace: fix hex output mode of ftrace tracing/fastboot: fix initcalls disposition in bootgraph.pl tracing/fastboot: fix printk format typo in boot tracer ftrace: return an error when setting a nonexistent tracer ftrace: make some tracers reentrant ring-buffer: make reentrant ring-buffer: move page indexes into page headers tracing/fastboot: only trace non-module initcalls ftrace: move pc counter in irqtrace ... Manually fix conflicts: - init/main.c: initcall tracing - kernel/module.c: verbose level vs tracepoints - scripts/bootgraph.pl: fallout from cherry-picking commits.
2008-10-14tracing, sched: LTTng instrumentation - schedulerMathieu Desnoyers
Instrument the scheduler activity (sched_switch, migration, wakeups, wait for a task, signal delivery) and process/thread creation/destruction (fork, exit, kthread stop). Actually, kthread creation is not instrumented in this patch because it is architecture dependent. It allows to connect tracers such as ftrace which detects scheduling latencies, good/bad scheduler decisions. Tools like LTTng can export this scheduler information along with instrumentation of the rest of the kernel activity to perform post-mortem analysis on the scheduler activity. About the performance impact of tracepoints (which is comparable to markers), even without immediate values optimizations, tests done by Hideo Aoki on ia64 show no regression. His test case was using hackbench on a kernel where scheduler instrumentation (about 5 events in code scheduler code) was added. See the "Tracepoints" patch header for performance result detail. Changelog : - Change instrumentation location and parameter to match ftrace instrumentation, previously done with kernel markers. [ mingo@elte.hu: conflict resolutions ] Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Acked-by: 'Peter Zijlstra' <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-14timers: fix itimer/many thread hangFrank Mayhar
Overview This patch reworks the handling of POSIX CPU timers, including the ITIMER_PROF, ITIMER_VIRT timers and rlimit handling. It was put together with the help of Roland McGrath, the owner and original writer of this code. The problem we ran into, and the reason for this rework, has to do with using a profiling timer in a process with a large number of threads. It appears that the performance of the old implementation of run_posix_cpu_timers() was at least O(n*3) (where "n" is the number of threads in a process) or worse. Everything is fine with an increasing number of threads until the time taken for that routine to run becomes the same as or greater than the tick time, at which point things degrade rather quickly. This patch fixes bug 9906, "Weird hang with NPTL and SIGPROF." Code Changes This rework corrects the implementation of run_posix_cpu_timers() to make it run in constant time for a particular machine. (Performance may vary between one machine and another depending upon whether the kernel is built as single- or multiprocessor and, in the latter case, depending upon the number of running processors.) To do this, at each tick we now update fields in signal_struct as well as task_struct. The run_posix_cpu_timers() function uses those fields to make its decisions. We define a new structure, "task_cputime," to contain user, system and scheduler times and use these in appropriate places: struct task_cputime { cputime_t utime; cputime_t stime; unsigned long long sum_exec_runtime; }; This is included in the structure "thread_group_cputime," which is a new substructure of signal_struct and which varies for uniprocessor versus multiprocessor kernels. For uniprocessor kernels, it uses "task_cputime" as a simple substructure, while for multiprocessor kernels it is a pointer: struct thread_group_cputime { struct task_cputime totals; }; struct thread_group_cputime { struct task_cputime *totals; }; We also add a new task_cputime substructure directly to signal_struct, to cache the earliest expiration of process-wide timers, and task_cputime also replaces the it_*_expires fields of task_struct (used for earliest expiration of thread timers). The "thread_group_cputime" structure contains process-wide timers that are updated via account_user_time() and friends. In the non-SMP case the structure is a simple aggregator; unfortunately in the SMP case that simplicity was not achievable due to cache-line contention between CPUs (in one measured case performance was actually _worse_ on a 16-cpu system than the same test on a 4-cpu system, due to this contention). For SMP, the thread_group_cputime counters are maintained as a per-cpu structure allocated using alloc_percpu(). The timer functions update only the timer field in the structure corresponding to the running CPU, obtained using per_cpu_ptr(). We define a set of inline functions in sched.h that we use to maintain the thread_group_cputime structure and hide the differences between UP and SMP implementations from the rest of the kernel. The thread_group_cputime_init() function initializes the thread_group_cputime structure for the given task. The thread_group_cputime_alloc() is a no-op for UP; for SMP it calls the out-of-line function thread_group_cputime_alloc_smp() to allocate and fill in the per-cpu structures and fields. The thread_group_cputime_free() function, also a no-op for UP, in SMP frees the per-cpu structures. The thread_group_cputime_clone_thread() function (also a UP no-op) for SMP calls thread_group_cputime_alloc() if the per-cpu structures haven't yet been allocated. The thread_group_cputime() function fills the task_cputime structure it is passed with the contents of the thread_group_cputime fields; in UP it's that simple but in SMP it must also safely check that tsk->signal is non-NULL (if it is it just uses the appropriate fields of task_struct) and, if so, sums the per-cpu values for each online CPU. Finally, the three functions account_group_user_time(), account_group_system_time() and account_group_exec_runtime() are used by timer functions to update the respective fields of the thread_group_cputime structure. Non-SMP operation is trivial and will not be mentioned further. The per-cpu structure is always allocated when a task creates its first new thread, via a call to thread_group_cputime_clone_thread() from copy_signal(). It is freed at process exit via a call to thread_group_cputime_free() from cleanup_signal(). All functions that formerly summed utime/stime/sum_sched_runtime values from from all threads in the thread group now use thread_group_cputime() to snapshot the values in the thread_group_cputime structure or the values in the task structure itself if the per-cpu structure hasn't been allocated. Finally, the code in kernel/posix-cpu-timers.c has changed quite a bit. The run_posix_cpu_timers() function has been split into a fast path and a slow path; the former safely checks whether there are any expired thread timers and, if not, just returns, while the slow path does the heavy lifting. With the dedicated thread group fields, timers are no longer "rebalanced" and the process_timer_rebalance() function and related code has gone away. All summing loops are gone and all code that used them now uses the thread_group_cputime() inline. When process-wide timers are set, the new task_cputime structure in signal_struct is used to cache the earliest expiration; this is checked in the fast path. Performance The fix appears not to add significant overhead to existing operations. It generally performs the same as the current code except in two cases, one in which it performs slightly worse (Case 5 below) and one in which it performs very significantly better (Case 2 below). Overall it's a wash except in those two cases. I've since done somewhat more involved testing on a dual-core Opteron system. Case 1: With no itimer running, for a test with 100,000 threads, the fixed kernel took 1428.5 seconds, 513 seconds more than the unfixed system, all of which was spent in the system. There were twice as many voluntary context switches with the fix as without it. Case 2: With an itimer running at .01 second ticks and 4000 threads (the most an unmodified kernel can handle), the fixed kernel ran the test in eight percent of the time (5.8 seconds as opposed to 70 seconds) and had better tick accuracy (.012 seconds per tick as opposed to .023 seconds per tick). Case 3: A 4000-thread test with an initial timer tick of .01 second and an interval of 10,000 seconds (i.e. a timer that ticks only once) had very nearly the same performance in both cases: 6.3 seconds elapsed for the fixed kernel versus 5.5 seconds for the unfixed kernel. With fewer threads (eight in these tests), the Case 1 test ran in essentially the same time on both the modified and unmodified kernels (5.2 seconds versus 5.8 seconds). The Case 2 test ran in about the same time as well, 5.9 seconds versus 5.4 seconds but again with much better tick accuracy, .013 seconds per tick versus .025 seconds per tick for the unmodified kernel. Since the fix affected the rlimit code, I also tested soft and hard CPU limits. Case 4: With a hard CPU limit of 20 seconds and eight threads (and an itimer running), the modified kernel was very slightly favored in that while it killed the process in 19.997 seconds of CPU time (5.002 seconds of wall time), only .003 seconds of that was system time, the rest was user time. The unmodified kernel killed the process in 20.001 seconds of CPU (5.014 seconds of wall time) of which .016 seconds was system time. Really, though, the results were too close to call. The results were essentially the same with no itimer running. Case 5: With a soft limit of 20 seconds and a hard limit of 2000 seconds (where the hard limit would never be reached) and an itimer running, the modified kernel exhibited worse tick accuracy than the unmodified kernel: .050 seconds/tick versus .028 seconds/tick. Otherwise, performance was almost indistinguishable. With no itimer running this test exhibited virtually identical behavior and times in both cases. In times past I did some limited performance testing. those results are below. On a four-cpu Opteron system without this fix, a sixteen-thread test executed in 3569.991 seconds, of which user was 3568.435s and system was 1.556s. On the same system with the fix, user and elapsed time were about the same, but system time dropped to 0.007 seconds. Performance with eight, four and one thread were comparable. Interestingly, the timer ticks with the fix seemed more accurate: The sixteen-thread test with the fix received 149543 ticks for 0.024 seconds per tick, while the same test without the fix received 58720 for 0.061 seconds per tick. Both cases were configured for an interval of 0.01 seconds. Again, the other tests were comparable. Each thread in this test computed the primes up to 25,000,000. I also did a test with a large number of threads, 100,000 threads, which is impossible without the fix. In this case each thread computed the primes only up to 10,000 (to make the runtime manageable). System time dominated, at 1546.968 seconds out of a total 2176.906 seconds (giving a user time of 629.938s). It received 147651 ticks for 0.015 seconds per tick, still quite accurate. There is obviously no comparable test without the fix. Signed-off-by: Frank Mayhar <fmayhar@google.com> Cc: Roland McGrath <roland@redhat.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-19tracehook: fix SA_NOCLDWAITRoland McGrath
I outwitted myself again in commit 2b2a1ff64afbadac842bbc58c5166962cf4f7664, and broke the SA_NOCLDWAIT behavior so it leaks zombies. This fixes it. Reported-by: Andi Kleen <andi@firstfloor.org> Signed-off-by: Roland McGrath <roland@redhat.com>
2008-08-11Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: posix-timers: fix posix_timer_event() vs dequeue_signal() race posix-timers: do_schedule_next_timer: fix the setting of ->si_overrun
2008-07-27Merge branch 'timers/urgent' of ↵Ingo Molnar
ssh://master.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip into timers/urgent
2008-07-26tracehook: force signal_pending()Roland McGrath
This defines a new hook tracehook_force_sigpending() that lets tracing code decide to force TIF_SIGPENDING on in recalc_sigpending(). This is not used yet, so it compiles away to nothing for now. It lays the groundwork for new tracing code that can interrupt a task synthetically without actually sending a signal. Signed-off-by: Roland McGrath <roland@redhat.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Reviewed-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
