[ Upstream commit 3c00cb5e68dc719f2fc73a33b1b230aadfcb1309 ]
This function can leak kernel stack data when the user siginfo_t has a
positive si_code value. The top 16 bits of si_code descibe which fields
in the siginfo_t union are active, but they are treated inconsistently
between copy_siginfo_from_user32, copy_siginfo_to_user32 and
copy_siginfo_to_user.
copy_siginfo_from_user32 is called from rt_sigqueueinfo and
rt_tgsigqueueinfo in which the user has full control overthe top 16 bits
of si_code.
This fixes the following information leaks:
x86: 8 bytes leaked when sending a signal from a 32-bit process to
itself. This leak grows to 16 bytes if the process uses x32.
(si_code = __SI_CHLD)
x86: 100 bytes leaked when sending a signal from a 32-bit process to
a 64-bit process. (si_code = -1)
sparc: 4 bytes leaked when sending a signal from a 32-bit process to a
64-bit process. (si_code = any)
parsic and s390 have similar bugs, but they are not vulnerable because
rt_[tg]sigqueueinfo have checks that prevent sending a positive si_code
to a different process. These bugs are also fixed for consistency.
Signed-off-by: Amanieu d'Antras <amanieu@gmail.com>
Cc: Chris Metcalf <cmetcalf@ezchip.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
[ Upstream commit c08a75d950725cdd87c19232a5a3850c51520359 ]
commit 26135022f85105ad725cda103fa069e29e83bd16 upstream.
This function may copy the si_addr_lsb, si_lower and si_upper fields to
user mode when they haven't been initialized, which can leak kernel
stack data to user mode.
Just checking the value of si_code is insufficient because the same
si_code value is shared between multiple signals. This is solved by
checking the value of si_signo in addition to si_code.
git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc
Pull arch signal handling cleanup from Richard Weinberger:
"This patch series moves all remaining archs to the get_signal(),
signal_setup_done() and sigsp() functions.
Currently these archs use open coded variants of the said functions.
Further, unused parameters get removed from get_signal_to_deliver(),
tracehook_signal_handler() and signal_delivered().
At the end of the day we save around 500 lines of code."
* 'signal-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/rw/misc: (43 commits)
powerpc: Use sigsp()
openrisc: Use sigsp()
mn10300: Use sigsp()
mips: Use sigsp()
microblaze: Use sigsp()
metag: Use sigsp()
m68k: Use sigsp()
m32r: Use sigsp()
hexagon: Use sigsp()
frv: Use sigsp()
cris: Use sigsp()
c6x: Use sigsp()
blackfin: Use sigsp()
avr32: Use sigsp()
arm64: Use sigsp()
arc: Use sigsp()
sas_ss_flags: Remove nested ternary if
Rip out get_signal_to_deliver()
Clean up signal_delivered()
tracehook_signal_handler: Remove sig, info, ka and regs
Now we can turn get_signal() to the main function.
Signed-off-by: Richard Weinberger <richard@nod.at>
- Pass a ksignal struct to it
- Remove unused regs parameter
- Make it private as it's nowhere outside of kernel/signal.c is used
These parameters are nowhere used, so we can remove them.
The explicit local_irq_save() in __lock_task_sighand() is needed to avoid
a potential deadlock condition, as noted in a841796f11c90d53 (signal:
align __lock_task_sighand() irq disabling and RCU). However, someone
reading the code might be forgiven for concluding that this separate
local_irq_save() was completely unnecessary. This commit therefore adds
a comment referencing the shiny new block comment on rcu_read_unlock().
Reported-by: Oleg Nesterov <oleg@redhat.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Reviewed-by: Lai Jiangshan <laijs@cn.fujitsu.com>
Now that allow_signal() is really trivial we can unify it with
disallow_signal(). Add the new helper, kernel_sigaction(), and
reimplement allow_signal/disallow_signal as a trivial wrappers.
This saves one EXPORT_SYMBOL() and the new helper can have more users.
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Richard Weinberger <richard@nod.at>
Cc: Tejun Heo <tj@kernel.org>
disallow_signal() simply sets SIG_IGN, this is not enough and
recalc_sigpending() is simply pointless because in can never change the
state of TIF_SIGPENDING.
If we ignore a signal, we also need to do flush_sigqueue_mask() for the
case when this signal is pending, this way recalc_sigpending() can
actually clear TIF_SIGPENDING and we do not "leak" the allocated
siginfo's.
allow_signal() does sigdelset(current->blocked) due to historic reason,
previously it could be called by a daemonize()'ed kthread, and
daemonize() played with current->blocked.
Now that daemonize() has gone away we can remove sigdelset() and
recalc_sigpending(). If a user really wants to unblock a signal, it
must use sigprocmask() or set_current_block() explicitely.
Move the declaration/definition of allow_signal/disallow_signal to
signal.h/signal.c. The new place is more logical and allows to use the
static helpers in signal.c (see the next changes).
While at it, make them return void and remove the valid_signal() check.
Nobody checks the returned value, and in-kernel users must not pass the
wrong signal number.
The usage of "task_struct *t" and "current" in do_sigaction() looks really
annoying and chaotic. Initially "t" is used as a cached value of current
but not consistently, then it is reused as a loop variable and we have to
use "current" again.
Clean up this mess and also convert the code to use for_each_thread().
"rm_from_queue_full" looks ugly and misleading, especially now that
rm_from_queue() has gone away. Rename it to flush_sigqueue_mask(), this
matches flush_sigqueue() we already have.
Also remove the obsolete comment which explains the difference with
rm_from_queue() we already killed.
rm_from_queue() doesn't make sense. The only caller, prepare_signal(),
can use rm_from_queue_full() with the same effect.
While at it, change prepare_signal() to use for_each_thread() instead of
do/while_each_thread.
Cosmetic, but siginitset(0) looks a bit strange, sigemptyset() is what
do_sigtimedwait() needs.
__wake_up_bit() checks waitqueue_active() and thus the caller needs mb()
as wake_up_bit() documents, fix task_clear_jobctl_trapping().
sys_sgetmask and sys_ssetmask are obsolete system calls no longer
supported in libc.
This patch replaces architecture related __ARCH_WANT_SYS_SGETMAX by expert
mode configuration.That option is enabled by default for those
architectures.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Cc: Steven Miao <realmz6@gmail.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Helge Deller <deller@gmx.de>
Cc: Greg Ungerer <gerg@uclinux.org>
To increase compiler portability there is <linux/compiler.h> which
provides convenience macros for various gcc constructs. Eg: __weak for
__attribute__((weak)). I've replaced all instances of gcc attributes
with the right macro in the kernel subsystem.
Signed-off-by: Gideon Israel Dsouza <gidisrael@gmail.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
This patch fix spelling typo in Documentation/DocBook.
It is because .html and .xml files are generated by make htmldocs,
I have to fix a typo within the source files.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Change do_signal_stop() and do_sigaction() to avoid next_thread() and use
while_each_thread() instead.
Reviewed-by: Sameer Nanda <snanda@chromium.org>
I found the following pattern that leads in to interesting findings:
grep -r "ret.*|=.*__put_user" *
grep -r "ret.*|=.*__get_user" *
grep -r "ret.*|=.*__copy" *
The __put_user() calls in compat_ioctl.c, ptrace compat, signal compat,
since those appear in compat code, we could probably expect the kernel
addresses not to be reachable in the lower 32-bit range, so I think they
might not be exploitable.
For the "__get_user" cases, I don't think those are exploitable: the worse
that can happen is that the kernel will copy kernel memory into in-kernel
buffers, and will fail immediately afterward.
The alpha csum_partial_copy_from_user() seems to be missing the
access_ok() check entirely. The fix is inspired from x86. This could
lead to information leak on alpha. I also noticed that many architectures
map csum_partial_copy_from_user() to csum_partial_copy_generic(), but I
wonder if the latter is performing the access checks on every
architectures.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Matt Turner <mattst88@gmail.com>
Avoid waking up every thread sleeping in a sigtimedwait call during
suspend and resume by calling a freezable blocking call. Previous
patches modified the freezer to avoid sending wakeups to threads
that are blocked in freezable blocking calls.
This call was selected to be converted to a freezable call because
it doesn't hold any locks or release any resources when interrupted
that might be needed by another freezing task or a kernel driver
during suspend, and is a common site where idle userspace tasks are
blocked.
Acked-by: Tejun Heo <tj@kernel.org>
Signed-off-by: Colin Cross <ccross@android.com>
Pull networking updates from David Miller:
"Highlights (1721 non-merge commits, this has to be a record of some
sort):
1) Add 'random' mode to team driver, from Jiri Pirko and Eric
Dumazet.
2) Make it so that any driver that supports configuration of multiple
MAC addresses can provide the forwarding database add and del
calls by providing a default implementation and hooking that up if
the driver doesn't have an explicit set of handlers. From Vlad
Yasevich.
3) Support GSO segmentation over tunnels and other encapsulating
devices such as VXLAN, from Pravin B Shelar.
4) Support L2 GRE tunnels in the flow dissector, from Michael Dalton.
5) Implement Tail Loss Probe (TLP) detection in TCP, from Nandita
Dukkipati.
6) In the PHY layer, allow supporting wake-on-lan in situations where
the PHY registers have to be written for it to be configured.
Use it to support wake-on-lan in mv643xx_eth.
From Michael Stapelberg.
7) Significantly improve firewire IPV6 support, from YOSHIFUJI
Hideaki.
8) Allow multiple packets to be sent in a single transmission using
network coding in batman-adv, from Martin Hundebøll.
9) Add support for T5 cxgb4 chips, from Santosh Rastapur.
10) Generalize the VXLAN forwarding tables so that there is more
flexibility in configurating various aspects of the endpoints.
From David Stevens.
11) Support RSS and TSO in hardware over GRE tunnels in bxn2x driver,
from Dmitry Kravkov.
12) Zero copy support in nfnelink_queue, from Eric Dumazet and Pablo
Neira Ayuso.
13) Start adding networking selftests.
14) In situations of overload on the same AF_PACKET fanout socket, or
per-cpu packet receive queue, minimize drop by distributing the
load to other cpus/fanouts. From Willem de Bruijn and Eric
Dumazet.
15) Add support for new payload offset BPF instruction, from Daniel
Borkmann.
16) Convert several drivers over to mdoule_platform_driver(), from
Sachin Kamat.
17) Provide a minimal BPF JIT image disassembler userspace tool, from
Daniel Borkmann.
18) Rewrite F-RTO implementation in TCP to match the final
specification of it in RFC4138 and RFC5682. From Yuchung Cheng.
19) Provide netlink socket diag of netlink sockets ("Yo dawg, I hear
you like netlink, so I implemented netlink dumping of netlink
sockets.") From Andrey Vagin.
20) Remove ugly passing of rtnetlink attributes into rtnl_doit
functions, from Thomas Graf.
21) Allow userspace to be able to see if a configuration change occurs
in the middle of an address or device list dump, from Nicolas
Dichtel.
22) Support RFC3168 ECN protection for ipv6 fragments, from Hannes
Frederic Sowa.
23) Increase accuracy of packet length used by packet scheduler, from
Jason Wang.
24) Beginning set of changes to make ipv4/ipv6 fragment handling more
scalable and less susceptible to overload and locking contention,
from Jesper Dangaard Brouer.
25) Get rid of using non-type-safe NLMSG_* macros and use nlmsg_*()
instead. From Hong Zhiguo.
26) Optimize route usage in IPVS by avoiding reference counting where
possible, from Julian Anastasov.
27) Convert IPVS schedulers to RCU, also from Julian Anastasov.
28) Support cpu fanouts in xt_NFQUEUE netfilter target, from Holger
Eitzenberger.
29) Network namespace support for nf_log, ebt_log, xt_LOG, ipt_ULOG,
nfnetlink_log, and nfnetlink_queue. From Gao feng.
30) Implement RFC3168 ECN protection, from Hannes Frederic Sowa.
31) Support several new r8169 chips, from Hayes Wang.
32) Support tokenized interface identifiers in ipv6, from Daniel
Borkmann.
33) Use usbnet_link_change() helper in USB net driver, from Ming Lei.
34) Add 802.1ad vlan offload support, from Patrick McHardy.
35) Support mmap() based netlink communication, also from Patrick
McHardy.
36) Support HW timestamping in mlx4 driver, from Amir Vadai.
37) Rationalize AF_PACKET packet timestamping when transmitting, from
Willem de Bruijn and Daniel Borkmann.
38) Bring parity to what's provided by /proc/net/packet socket dumping
and the info provided by netlink socket dumping of AF_PACKET
sockets. From Nicolas Dichtel.
39) Fix peeking beyond zero sized SKBs in AF_UNIX, from Benjamin
Poirier"
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1722 commits)
filter: fix va_list build error
af_unix: fix a fatal race with bit fields
bnx2x: Prevent memory leak when cnic is absent
bnx2x: correct reading of speed capabilities
net: sctp: attribute printl with __printf for gcc fmt checks
netlink: kconfig: move mmap i/o into netlink kconfig
netpoll: convert mutex into a semaphore
netlink: Fix skb ref counting.
net_sched: act_ipt forward compat with xtables
mlx4_en: fix a build error on 32bit arches
Revert "bnx2x: allow nvram test to run when device is down"
bridge: avoid OOPS if root port not found
drivers: net: cpsw: fix kernel warn on cpsw irq enable
sh_eth: use random MAC address if no valid one supplied
3c509.c: call SET_NETDEV_DEV for all device types (ISA/ISAPnP/EISA)
tg3: fix to append hardware time stamping flags
unix/stream: fix peeking with an offset larger than data in queue
unix/dgram: fix peeking with an offset larger than data in queue
unix/dgram: peek beyond 0-sized skbs
openvswitch: Remove unneeded ovs_netdev_get_ifindex()
There are 2 well known and ancient problems with coredump/signals, and a
lot of related bug reports:
- do_coredump() clears TIF_SIGPENDING but of course this can't help
if, say, SIGCHLD comes after that.
In this case the coredump can fail unexpectedly. See for example
wait_for_dump_helper()->signal_pending() check but there are other
reasons.
- At the same time, dumping a huge core on the slow media can take a
lot of time/resources and there is no way to kill the coredumping
task reliably. In particular this is not oom_kill-friendly.
This patch tries to fix the 1st problem, and makes the preparation for the
next changes.
We add the new SIGNAL_GROUP_COREDUMP flag set by zap_threads() to indicate
that this process dumps the core. prepare_signal() checks this flag and
nacks any signal except SIGKILL.
Note that this check tries to be conservative, in the long term we should
probably treat the SIGNAL_GROUP_EXIT case equally but this needs more
discussion. See marc.info/?l=linux-kernel&m=120508897917439
Notes:
- recalc_sigpending() doesn't check SIGNAL_GROUP_COREDUMP.
The patch assumes that dump_write/etc paths should never
call it, but we can change it as well.
- There is another source of TIF_SIGPENDING, freezer. This
will be addressed separately.
Tested-by: Mandeep Singh Baines <msb@chromium.org>
Cc: Neil Horman <nhorman@redhat.com>
Cc: Roland McGrath <roland@hack.frob.com>
After the recent generic debug info on dump_stack() and friends, arc
is printing duplicate information on debug dumps.
[ARCLinux]$ ./crash
crash/50: potentially unexpected fatal signal 11. <-- [1]
/sbin/crash, TGID 50 <-- [2]
Pid: 50, comm: crash Not tainted 3.9.0-rc4+ #132 <-- [3]
Remove them.
[tj@kernel.org: updated patch desc]
Signed-off-by: Vineet Gupta <vgupta@synopsys.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Fengguang Wu <fengguang.wu@intel.com>
Cc: Mike Frysinger <vapier@gentoo.org>
drivers/net/ethernet/emulex/benet/be_main.c
drivers/net/ethernet/intel/igb/igb_main.c
drivers/net/wireless/brcm80211/brcmsmac/mac80211_if.c
include/net/scm.h
net/batman-adv/routing.c
net/ipv4/tcp_input.c
The e{uid,gid} --> {uid,gid} credentials fix conflicted with the
cleanup in net-next to now pass cred structs around.
The be2net driver had a bug fix in 'net' that overlapped with the VLAN
interface changes by Patrick McHardy in net-next.
An IGB conflict existed because in 'net' the build_skb() support was
reverted, and in 'net-next' there was a comment style fix within that
code.
Several batman-adv conflicts were resolved by making sure that all
calls to batadv_is_my_mac() are changed to have a new bat_priv first
argument.
Eric Dumazet's TS ECR fix in TCP in 'net' conflicted with the F-RTO
rewrite in 'net-next', mostly overlapping changes.
Thanks to Stephen Rothwell and Antonio Quartulli for help with several
of these merge resolutions.
This fixes a kernel memory contents leak via the tkill and tgkill syscalls
for compat processes.
This is visible in the siginfo_t->_sifields._rt.si_sigval.sival_ptr field
when handling signals delivered from tkill.
The place of the infoleak:
int copy_siginfo_to_user32(compat_siginfo_t __user *to, siginfo_t *from)
put_user_ex(ptr_to_compat(from->si_ptr), &to->si_ptr);
Signed-off-by: Emese Revfy <re.emese@gmail.com>
Reviewed-by: PaX Team <pageexec@freemail.hu>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Serge Hallyn <serge.hallyn@canonical.com>
Cc: <stable@vger.kernel.org>
Process connector can now also detect coredumping events.
Main aim of patch is get notified at start of coredumping, instead of
having to wait for it to finish and then being notified through EXIT
event.
Could be used for instance by process-managers that want to get
notified as soon as possible about process failures, and not
necessarily beeing notified after coredump, which could be in the
order of minutes depending on size of coredump, piping and so on.
Signed-off-by: Jesper Derehag <jderehag@hotmail.com>
__ARCH_HAS_SA_RESTORER is the preferred conditional for use in 3.9 and
later kernels, per Kees.
Cc: Emese Revfy <re.emese@gmail.com>
Cc: PaX Team <pageexec@freemail.hu>
Cc: Julien Tinnes <jln@google.com>
When the new signal handlers are set up, the location of sa_restorer is
not cleared, leaking a parent process's address space location to
children. This allows for a potential bypass of the parent's ASLR by
examining the sa_restorer value returned when calling sigaction().
Based on what should be considered "secret" about addresses, it only
matters across the exec not the fork (since the VMAs haven't changed
until the exec). But since exec sets SIG_DFL and keeps sa_restorer,
this is where it should be fixed.
Given the few uses of sa_restorer, a "set" function was not written
since this would be the only use. Instead, we use
__ARCH_HAS_SA_RESTORER, as already done in other places.
Example of the leak before applying this patch:
$ cat /proc/$$/maps
7fb9f3083000-7fb9f3238000 r-xp 00000000 fd:01 404469 .../libc-2.15.so
$ ./leak
7f278bc74000-7f278be29000 r-xp 00000000 fd:01 404469 .../libc-2.15.so
1 0 (nil) 0x7fb9f30b94a0
2 4000000 (nil) 0x7f278bcaa4a0
3 4000000 (nil) 0x7f278bcaa4a0
4 0 (nil) 0x7fb9f30b94a0
[akpm@linux-foundation.org: use SA_RESTORER for backportability]
Reported-by: Emese Revfy <re.emese@gmail.com>
Fix new kernel-doc warnings in kernel/signal.c:
Warning(kernel/signal.c:2689): No description found for parameter 'uset'
Warning(kernel/signal.c:2689): Excess function parameter 'set' description in 'sys_rt_sigpending'
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull sigprocmask compat fix from Al Viro:
"generic compat_sys_rt_sigprocmask() had a very dumb braino; I'd spent
quite a while staring at the offending commit before finally managing
to spot the idiocy ;-/"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
fix compat_sys_rt_sigprocmask()
Converting bitmask to 32bit granularity is fine, but we'd better
_do_ something with the result. Such as "copy it to userland"...
Several printk's were missing KERN_INFO and KERN_CONT flags. In
addition, a printk that was outside a #if/#endif should have been
inside, which would result in stray blank line on non-x86 boxes.
Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
The idea is simple. We need to get the siginfo for each signal on
checkpointing dump, and then return it back on restore.
The first problem is that the kernel doesn't report complete siginfos to
userspace. In a signal handler the kernel strips SI_CODE from siginfo.
When a siginfo is received from signalfd, it has a different format with
fixed sizes of fields. The interface of signalfd was extended. If a
signalfd is created with the flag SFD_RAW, it returns siginfo in a raw
format.
rt_sigqueueinfo looks suitable for restoring signals, but it can't send
siginfo with a positive si_code, because these codes are reserved for
the kernel. In the real world each person has right to do anything with
himself, so I think a process should able to send any siginfo to itself.
This patch:
The kernel prevents sending of siginfo with positive si_code, because
these codes are reserved for kernel. I think we can allow a task to
send such a siginfo to itself. This operation should not be dangerous.
This functionality is required for restoring signals in
checkpoint/restart.
Signed-off-by: Andrey Vagin <avagin@openvz.org>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Reviewed-by: Oleg Nesterov <oleg@redhat.com>
Pull signal handling cleanups from Al Viro:
"This is the first pile; another one will come a bit later and will
contain SYSCALL_DEFINE-related patches.
- a bunch of signal-related syscalls (both native and compat)
unified.
- a bunch of compat syscalls switched to COMPAT_SYSCALL_DEFINE
(fixing several potential problems with missing argument
validation, while we are at it)
- a lot of now-pointless wrappers killed
- a couple of architectures (cris and hexagon) forgot to save
altstack settings into sigframe, even though they used the
(uninitialized) values in sigreturn; fixed.
- microblaze fixes for delivery of multiple signals arriving at once
- saner set of helpers for signal delivery introduced, several
architectures switched to using those."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: (143 commits)
x86: convert to ksignal
sparc: convert to ksignal
arm: switch to struct ksignal * passing
alpha: pass k_sigaction and siginfo_t using ksignal pointer
burying unused conditionals
make do_sigaltstack() static
arm64: switch to generic old sigaction() (compat-only)
arm64: switch to generic compat rt_sigaction()
arm64: switch compat to generic old sigsuspend
arm64: switch to generic compat rt_sigqueueinfo()
arm64: switch to generic compat rt_sigpending()
arm64: switch to generic compat rt_sigprocmask()
arm64: switch to generic sigaltstack
sparc: switch to generic old sigsuspend
sparc: COMPAT_SYSCALL_DEFINE does all sign-extension as well as SYSCALL_DEFINE
sparc: kill sign-extending wrappers for native syscalls
kill sparc32_open()
sparc: switch to use of generic old sigaction
sparc: switch sys_compat_rt_sigaction() to COMPAT_SYSCALL_DEFINE
mips: switch to generic sys_fork() and sys_clone()
__ARCH_WANT_SYS_RT_SIGACTION,
__ARCH_WANT_SYS_RT_SIGSUSPEND,
__ARCH_WANT_COMPAT_SYS_RT_SIGSUSPEND,
__ARCH_WANT_COMPAT_SYS_SCHED_RR_GET_INTERVAL - not used anymore
CONFIG_GENERIC_{SIGALTSTACK,COMPAT_RT_SIG{ACTION,QUEUEINFO,PENDING,PROCMASK}} -
can be assumed always set.
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/linux-dynticks into sched/core
Pull full-dynticks (user-space execution is undisturbed and
receives no timer IRQs) preparation changes that convert the
cputime accounting code to be full-dynticks ready,
from Frederic Weisbecker:
"This implements the cputime accounting on full dynticks CPUs.
Typical cputime stats infrastructure relies on the timer tick and
its periodic polling on the CPU to account the amount of time
spent by the CPUs and the tasks per high level domains such as
userspace, kernelspace, guest, ...
Now we are preparing to implement full dynticks capability on
Linux for Real Time and HPC users who want full CPU isolation.
This feature requires a cputime accounting that doesn't depend
on the timer tick.
To implement it, this new cputime infrastructure plugs into
kernel/user/guest boundaries to take snapshots of cputime and
flush these to the stats when needed. This performs pretty
much like CONFIG_VIRT_CPU_ACCOUNTING except that context location
and cputime snaphots are synchronized between write and read
side such that the latter can safely retrieve the pending tickless
cputime of a task and add it to its latest cputime snapshot to
return the correct result to the user."
mips was the last architecture not using the generic variant.
Both native and compat variants switched to generic, which is
made unconditional now.
usual "call force_sigsegv or signal_delivered" logics. Takes
ksignal instead of separate siginfo/k_sigaction.
conditional on OLD_SIGACTION/COMPAT_OLD_SIGACTION
Again, protected by a temporary config symbol (GENERIC_COMPAT_RT_SIGACTION);
will be gone by the end of series.
C ABI violations on sparc, ppc and mips
conditional on OLD_SIGSUSPEND/OLD_SIGSUSPEND3, depending on which
variety of that fossil is needed.
conditional on GENERIC_COMPAT_RT_SIGQUEUEINFO; by the end of that series
it will become the same thing as COMPAT and conditional will die out.
conditional on GENERIC_COMPAT_RT_SIGPENDING; by the end of that series
conditional on GENERIC_COMPAT_RT_SIGPROCMASK; by the end of that series
