dequeue_signal:
if (__SI_TIMER) {
spin_unlock(&tsk->sighand->siglock);
do_schedule_next_timer(info);
spin_lock(&tsk->sighand->siglock);
Unless tsk == curent, this is absolutely unsafe: nothing prevents tsk from
exiting. If signalfd was passed to another process, do_schedule_next_timer()
is just wrong.
Add yet another "tsk == current" check into dequeue_signal().
This patch fixes an oopsable bug, but breaks the scheduling of posix timers
if the shared __SI_TIMER signal was fetched via signalfd attached to another
sub-thread. Mostly fixed by the next patch.
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Davide Libenzi <davidel@xmailserver.org>
Cc: Michael Kerrisk <mtk-manpages@gmx.net>
Cc: Roland McGrath <roland@redhat.com>
Don't let signalfd dequeue private signals off other threads (in the
case of things like SIGILL or SIGSEGV, trying to do so would result
in undefined behaviour on who actually gets the signal, since they
are force unblocked).
Acked-by: Davide Libenzi <davidel@xmailserver.org>
This patch should get a few birds. It prevents sigaction calls from
clearing TIF_SIGPENDING in other threads, which could leak -ERESTART*.
And It fixes ptrace_stop not to clear it, which done at the syscall exit
stop could leak -ERESTART*. It probably removes the harm from signalfd,
at least assuming it never calls dequeue_signal on kernel threads that
might have used block_all_signals.
Signed-off-by: Roland McGrath <roland@redhat.com>
Cc: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com>
Steve Hawkes discovered a problem where recalc_sigpending_tsk was called in
do_sigaction but no signal_wake_up call was made, preventing later signals
from waking up blocked threads with TIF_SIGPENDING already set.
In fact, the few other calls to recalc_sigpending_tsk outside the signals
code are also subject to this problem in other race conditions.
This change makes recalc_sigpending_tsk private to the signals code. It
changes the outside calls, as well as do_sigaction, to use the new
recalc_sigpending_and_wake instead.
Cc: <Steve.Hawkes@motorola.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current
* 'audit.b38' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current:
[PATCH] Abnormal End of Processes
[PATCH] match audit name data
[PATCH] complete message queue auditing
[PATCH] audit inode for all xattr syscalls
[PATCH] initialize name osid
[PATCH] audit signal recipients
[PATCH] add SIGNAL syscall class (v3)
[PATCH] auditing ptrace
This patch series implements the new signalfd() system call.
I took part of the original Linus code (and you know how badly it can be
broken :), and I added even more breakage ;) Signals are fetched from the same
signal queue used by the process, so signalfd will compete with standard
kernel delivery in dequeue_signal(). If you want to reliably fetch signals on
the signalfd file, you need to block them with sigprocmask(SIG_BLOCK). This
seems to be working fine on my Dual Opteron machine. I made a quick test
program for it:
http://www.xmailserver.org/signafd-test.c
The signalfd() system call implements signal delivery into a file descriptor
receiver. The signalfd file descriptor if created with the following API:
int signalfd(int ufd, const sigset_t *mask, size_t masksize);
The "ufd" parameter allows to change an existing signalfd sigmask, w/out going
to close/create cycle (Linus idea). Use "ufd" == -1 if you want a brand new
signalfd file.
The "mask" allows to specify the signal mask of signals that we are interested
in. The "masksize" parameter is the size of "mask".
The signalfd fd supports the poll(2) and read(2) system calls. The poll(2)
will return POLLIN when signals are available to be dequeued. As a direct
consequence of supporting the Linux poll subsystem, the signalfd fd can use
used together with epoll(2) too.
The read(2) system call will return a "struct signalfd_siginfo" structure in
the userspace supplied buffer. The return value is the number of bytes copied
in the supplied buffer, or -1 in case of error. The read(2) call can also
return 0, in case the sighand structure to which the signalfd was attached,
has been orphaned. The O_NONBLOCK flag is also supported, and read(2) will
return -EAGAIN in case no signal is available.
If the size of the buffer passed to read(2) is lower than sizeof(struct
signalfd_siginfo), -EINVAL is returned. A read from the signalfd can also
return -ERESTARTSYS in case a signal hits the process. The format of the
struct signalfd_siginfo is, and the valid fields depends of the (->code &
__SI_MASK) value, in the same way a struct siginfo would:
struct signalfd_siginfo {
__u32 signo; /* si_signo */
__s32 err; /* si_errno */
__s32 code; /* si_code */
__u32 pid; /* si_pid */
__u32 uid; /* si_uid */
__s32 fd; /* si_fd */
__u32 tid; /* si_fd */
__u32 band; /* si_band */
__u32 overrun; /* si_overrun */
__u32 trapno; /* si_trapno */
__s32 status; /* si_status */
__s32 svint; /* si_int */
__u64 svptr; /* si_ptr */
__u64 utime; /* si_utime */
__u64 stime; /* si_stime */
__u64 addr; /* si_addr */
[akpm@linux-foundation.org: fix signalfd_copyinfo() on i386]
Signed-off-by: Davide Libenzi <davidel@xmailserver.org>
When auditing syscalls that send signals, log the pid and security
context for each target process. Optimize the data collection by
adding a counter for signal-related rules, and avoiding allocating an
aux struct unless we have more than one target process. For process
groups, collect pid/context data in blocks of 16. Move the
audit_signal_info() hook up in check_kill_permission() so we audit
attempts where permission is denied.
Signed-off-by: Amy Griffis <amy.griffis@hp.com>
Currently kernel threads use sigprocmask(SIG_BLOCK) to protect against
signals. This doesn't prevent the signal delivery, this only blocks
signal_wake_up(). Every "killall -33 kthreadd" means a "struct siginfo"
leak.
Change kthreadd_setup() to set all handlers to SIG_IGN instead of blocking
them (make a new helper ignore_signals() for that). If the kernel thread
needs some signal, it should use allow_signal() anyway, and in that case it
should not use CLONE_SIGHAND.
Note that we can't change daemonize() (should die!) in the same way,
because it can be used along with CLONE_SIGHAND. This means that
allow_signal() still should unblock the signal to work correctly with
daemonize()ed threads.
However, disallow_signal() doesn't block the signal any longer but ignores
it.
NOTE: with or without this patch the kernel threads are not protected from
handle_stop_signal(), this seems harmless, but not good.
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
We already depend on fact that all sub-threads have ->exit_signal == -1, no
need to set it in zap_other_threads().
This patch moves the sig_kernel_* and related macros from kernel/signal.c
to linux/signal.h, and cleans them up slightly. I need the sig_kernel_*
macros for default signal behavior in the utrace code, and want to avoid
duplication or overhead to share the knowledge.
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
This patch provides a new macro
KMEM_CACHE(<struct>, <flags>)
to simplify slab creation. KMEM_CACHE creates a slab with the name of the
struct, with the size of the struct and with the alignment of the struct.
Additional slab flags may be specified if necessary.
Example
struct test_slab {
int a,b,c;
struct list_head;
} __cacheline_aligned_in_smp;
test_slab_cache = KMEM_CACHE(test_slab, SLAB_PANIC)
will create a new slab named "test_slab" of the size sizeof(struct
test_slab) and aligned to the alignment of test slab. If it fails then we
panic.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
* master.kernel.org:/pub/scm/linux/kernel/git/kyle/parisc-2.6: (78 commits)
[PARISC] Use symbolic last syscall in __NR_Linux_syscalls
[PARISC] Add missing statfs64 and fstatfs64 syscalls
Revert "[PARISC] Optimize TLB flush on SMP systems"
[PARISC] Compat signal fixes for 64-bit parisc
[PARISC] Reorder syscalls to match unistd.h
Revert "[PATCH] make kernel/signal.c:kill_proc_info() static"
[PARISC] fix sys_rt_sigqueueinfo
[PARISC] fix section mismatch warnings in harmony sound driver
[PARISC] do not export get_register/set_register
[PARISC] add ENTRY()/ENDPROC() and simplify assembly of HP/UX emulation code
[PARISC] convert to use CONFIG_64BIT instead of __LP64__
[PARISC] use CONFIG_64BIT instead of __LP64__
[PARISC] add ASM_EXCEPTIONTABLE_ENTRY() macro
[PARISC] more ENTRY(), ENDPROC(), END() conversions
[PARISC] fix ENTRY() and ENDPROC() for 64bit-parisc
[PARISC] Fixes /proc/cpuinfo cache output on B160L
[PARISC] implement standard ENTRY(), END() and ENDPROC()
[PARISC] kill ENTRY_SYS_CPUS
[PARISC] clean up debugging printks in smp.c
[PARISC] factor syscall_restart code out of do_signal
Fix conflict in include/linux/sched.h due to kill_proc_info() being made
publicly available to PARISC again.
This reverts commit d3228a887cae75ef2b8b1211c31c539bef5a5698.
DeBunk this code. We need it for compat_sys_rt_sigqueueinfo.
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
Fix potential setitimer DoS with high-res timers by pushing itimer rearm
processing to process context.
[Fixes from: Ingo Molnar <mingo@elte.hu>]
Cc: john stultz <johnstul@us.ibm.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Now that I have changed all of the in-tree users remove the old version of
these functions. This should make it clear to any out of tree users that they
should be using kill_pgrp kill_pgrp_info or __kill_pgrp_info instead.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Every call to is_orphaned_pgrp passed in process_group(current) which is racy
with respect to another thread changing our process group. It didn't bite us
because we were dealing with integers and the worse we would get would be a
stale answer.
In switching the checks to use struct pid to be a little more efficient and
prepare the way for pid namespaces this race became apparent.
So I simplified the calls to the more specialized is_current_pgrp_orphaned so
I didn't have to worry about making logic changes to avoid the race.
The goal is to remove users of the old signal helper functions so they can be
removed.
A variety of (mostly) innocuous fixes to the embedded kernel-doc content in
source files, including:
* make multi-line initial descriptions single line
* denote some function names, constants and structs as such
* change erroneous opening '/*' to '/**' in a few places
* reword some text for clarity
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Cc: "Randy.Dunlap" <rdunlap@xenotime.net>
Kill acquired_tasklist_lock, sig_needs_tasklist() is very cheap nowadays.
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Currently, if a task is stopped (ie. it's in the TASK_STOPPED state), it
is considered by the freezer as unfreezeable. However, there may be a race
between the freezer and the delivery of the continuation signal to the task
resulting in the task running after we have finished freezing the other
tasks. This, in turn, may lead to undesirable effects up to and including
data corruption.
To prevent this from happening we first need to make the freezer consider
stopped tasks as freezeable. For this purpose we need to make freezeable()
stop returning 0 for these tasks and we need to force them to enter the
refrigerator. However, if there's no continuation signal in the meantime,
the stopped tasks should remain stopped after all processes have been
thawed, so we need to send an additional SIGSTOP to each of them before
waking it up.
Also, a stopped task that has just been woken up should first check if
there's a freezing request for it and go to the refrigerator if that's the
case.
Acked-by: Pavel Machek <pavel@ucw.cz>
Add a per pid_namespace child-reaper. This is needed so processes are reaped
within the same pid space and do not spill over to the parent pid space. Its
also needed so containers preserve existing semantic that pid == 1 would reap
orphaned children.
This is based on Eric Biederman's patch: http://lkml.org/lkml/2006/2/6/285
Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Signed-off-by: Cedric Le Goater <clg@fr.ibm.com>
Cc: Kirill Korotaev <dev@openvz.org>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Herbert Poetzl <herbert@13thfloor.at>
Replace occurences of task->signal->session by a new process_session() helper
routine.
It will be useful for pid namespaces to abstract the session pid number.
Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Move process freezing functions from include/linux/sched.h to freezer.h, so
that modifications to the freezer or the kernel configuration don't require
recompiling just about everything.
[akpm@osdl.org: fix ueagle driver]
Signed-off-by: Nigel Cunningham <nigel@suspend2.net>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Pavel Machek <pavel@ucw.cz>
Replace all uses of kmem_cache_t with struct kmem_cache.
The patch was generated using the following script:
#!/bin/sh
# Replace one string by another in all the kernel sources.
set -e
for file in `find * -name "*.c" -o -name "*.h"|xargs grep -l $1`; do
quilt add $file
sed -e "1,\$s/$1/$2/g" $file >/tmp/$$
mv /tmp/$$ $file
quilt refresh
done
The script was run like this
sh replace kmem_cache_t "struct kmem_cache"
The previous commit (45c18b0bb579b5c1b89f8c99f1b6ffa4c586ba08, aka "Fix
unlikely (but possible) race condition on task->user access") fixed a
potential oops due to __sigqueue_alloc() getting its "user" pointer out
of sync with switch_user(), and accessing a user pointer that had been
de-allocated on another CPU.
It still left another (much less serious) problem, where a concurrent
__sigqueue_alloc and swich_user could cause sigqueue_alloc to do signal
pending reference counting for a _different_ user than the one it then
actually ended up using. No oops, but we'd end up with the wrong signal
accounting.
Another case of Oleg's eagle-eyes picking up the problem.
This is trivially fixed by just making sure we load whichever "user"
structure we decide to use (it doesn't matter _which_ one we pick, we
just need to pick one) just once.
Acked-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Andrew Morton <akpm@osdl.org>
The problem with remembering a user space process by its pid is that it is
possible that the process will exit, pid wrap around will occur.
Converting to a struct pid avoid that problem, and paves the way for
implementing a pid namespace.
Also since usb is the only user of kill_proc_info_as_uid rename
kill_proc_info_as_uid to kill_pid_info_as_uid and have the new version take
a struct pid.
Currently the signal functions all either take a task or a pid_t argument.
This patch implements variants that take a struct pid *. After all of the
users have been update it is my intention to remove the variants that take a
pid_t as using pid_t can be more work (an extra hash table lookup) and
difficult to get right in the presence of multiple pid namespaces.
There are two kinds of functions introduced in this patch. The are the
general use functions kill_pgrp and kill_pid which take a priv argument that
is ultimately used to create the appropriate siginfo information, Then there
are _kill_pgrp_info, kill_pgrp_info, kill_pid_info the internal implementation
helpers that take an explicit siginfo.
The distinction is made because filling out an explcit siginfo is tricky, and
will be even more tricky when pid namespaces are introduced.
This tightens up __dequeue_signal a little. It also avoids doing
recalc_sigpending twice in a row, instead doing it once in dequeue_signal.
Move the fallback arch_vma_name() to a sensible place (kernel/signal.c).
Currently it's in fs/proc/task_mmu.c, a file that is dependent on both
CONFIG_PROC_FS and CONFIG_MMU being enabled, but it's used from
kernel/signal.c from where it is called unconditionally.
[akpm@osdl.org: build fix]
Suresh points out that commit b0423a0d9cc836b2c3d796623cd19236bfedfe63
broke the semantics of a synchronous signal like SIGSEGV occurring
recursively inside its own handler handler (or, indeed, any other
context when the signal was blocked).
That was unintentional, and this fixes things up by reinstating the old
semantics, but without reverting the cleanups.
Cc: Paul E. McKenney <paulmck@us.ibm.com>
Acked-by: Suresh Siddha <suresh.b.siddha@intel.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial:
Remove obsolete #include <linux/config.h>
remove obsolete swsusp_encrypt
arch/arm26/Kconfig typos
Documentation/IPMI typos
Kconfig: Typos in net/sched/Kconfig
v9fs: do not include linux/version.h
Documentation/DocBook/mtdnand.tmpl: typo fixes
typo fixes: specfic -> specific
typo fixes in Documentation/networking/pktgen.txt
typo fixes: occuring -> occurring
typo fixes: infomation -> information
typo fixes: disadvantadge -> disadvantage
typo fixes: aquire -> acquire
typo fixes: mecanism -> mechanism
typo fixes: bandwith -> bandwidth
fix a typo in the RTC_CLASS help text
smb is no longer maintained
Manually merged trivial conflict in arch/um/kernel/vmlinux.lds.S
This patch adds a call to the extended security_task_kill hook introduced by
the prior patch to the kill_proc_info_as_uid function so that these signals
can be properly mediated by security modules. It also updates the existing
hook call in check_kill_permission.
Signed-off-by: David Quigley <dpquigl@tycho.nsa.gov>
Signed-off-by: James Morris <jmorris@namei.org>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Chris Wright <chrisw@sous-sol.org>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
With this patch zap_process() sets SIGNAL_GROUP_EXIT while sending SIGKILL to
the thread group. This means that a TASK_TRACED task
1. Will be awakened by signal_wake_up(1)
2. Can't sleep again via ptrace_notify()
3. Can't go to do_signal_stop() after return
from ptrace_stop() in get_signal_to_deliver()
So we can remove all ptrace related stuff from coredump path.
This reverts most of commit 30e0fca6c1d7d26f3f2daa4dd2b12c51dadc778a.
It broke the case of non-leader MT exec when ptraced.
I think the bug it was intended to fix was already addressed by commit
788e05a67c343fa22f2ae1d3ca264e7f15c25eaf.
Commit e56d090310d7625ecb43a1eeebd479f04affb48b
[PATCH] RCU signal handling
made this BUG_ON() unsafe. This code runs under ->siglock,
while switch_exec_pids() takes tasklist_lock.
this changes if() BUG(); constructs to BUG_ON() which is
cleaner, contains unlikely() and can better optimized away.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
strace /bin/bash misbehaves after resume; this fixes it.
(akpm: it's scary calling refrigerator() in state TASK_TRACED, but it seems to
do the right thing).
Signed-off-by: Pavel Machek <pavel@suse.cz>
send_sigqueue() checks PF_EXITING, then locks p->sighand->siglock. This is
unsafe: 'p' can exit in between and set ->sighand = NULL. The race is
theoretical, the window is tiny and irqs are disabled by the caller, so I
don't think we need the fix for -stable tree.
Convert send_sigqueue() to use lock_task_sighand() helper.
Also, delete 'p->flags & PF_EXITING' re-check, it is unneeded and the
comment is wrong.
The previous patch has changed callsites of do_notify_parent_cldstop() so that
to_self == (->ptrace & PT_PTRACED) always (as it should be). We can remove
this parameter now.
Remove an obscure 'stop_count < 0' check in finish_stop(). The previous patch
made this case impossible.
do_signal_stop() considers 'thread_group_empty()' as a special case.
This was needed to avoid taking tasklist_lock. Since this lock is
unneeded any longer, we can remove this special case and simplify
the code even more.
Also, before this patch, finish_stop() was called with stop_count == -1
for 'thread_group_empty()' case. This is not strictly wrong, but confusing
and unneeded.
do_sigaction() does not need tasklist_lock anymore, we can simplify the code.
do_signal_stop() does not need tasklist_lock anymore. So it does not need to
do misc re-checks, and we can simplify the code.
handle_stop_signal() does not need tasklist_lock for SIG_KERNEL_STOP_MASK
signals anymore.
__exit_signal() is private to release_task() now. I think it is better to
make it static in kernel/exit.c and export flush_sigqueue() instead - this
function is much more simple and straightforward.
Cosmetic, rename __exit_sighand to cleanup_sighand and move it close to
copy_sighand().
This matches copy_signal/cleanup_signal naming, and I think it is easier to
follow.
Acked-by: "Paul E. McKenney" <paulmck@us.ibm.com>
