path: root/kernel/smpboot.c
2012-05-24smpboot, idle: Fix comment mismatch over idle_threads_init()Srivatsa S. Bhat
The comment over idle_threads_init() really talks about the functionality of idle_init(). Move that comment to idle_init(), and add a suitable comment over idle_threads_init(). Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: suresh.b.siddha@intel.com Cc: venki@google.com Cc: nikunj@linux.vnet.ibm.com Link: http://lkml.kernel.org/r/20120524151100.2549.66501.stgit@srivatsabhat.in.ibm.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-05-24smpboot, idle: Optimize calls to smp_processor_id() in idle_threads_init()Srivatsa S. Bhat
While trying to initialize idle threads for all cpus, idle_threads_init() calls smp_processor_id() in a loop, which is unnecessary. The intent is to initialize idle threads for all non-boot cpus. So just use a variable to note the boot cpu and use it in the loop. Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: suresh.b.siddha@intel.com Cc: venki@google.com Cc: nikunj@linux.vnet.ibm.com Link: http://lkml.kernel.org/r/20120524151055.2549.64309.stgit@srivatsabhat.in.ibm.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-05-03smp, idle: Allocate idle thread for each possible cpu during bootSuresh Siddha
percpu areas are already allocated during boot for each possible cpu. percpu idle threads can be considered as an extension of the percpu areas, and allocate them for each possible cpu during boot. This will eliminate the need for workqueue based idle thread allocation. In future we can move the idle thread area into the percpu area too. [ tglx: Moved the loop into smpboot.c and added an error check when the init code failed to allocate an idle thread for a cpu which should be onlined ] Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Tejun Heo <tj@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: venki@google.com Link: http://lkml.kernel.org/r/1334966930.28674.245.camel@sbsiddha-desk.sc.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-04-26smp: Provide generic idle thread allocationThomas Gleixner
All SMP architectures have magic to fork the idle task and to store it for reusage when cpu hotplug is enabled. Provide a generic infrastructure for it. Create/reinit the idle thread for the cpu which is brought up in the generic code and hand the thread pointer to the architecture code via __cpu_up(). Note, that fork_idle() is called via a workqueue, because this guarantees that the idle thread does not get a reference to a user space VM. This can happen when the boot process did not bring up all possible cpus and a later cpu_up() is initiated via the sysfs interface. In that case fork_idle() would be called in the context of the user space task and take a reference on the user space VM. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Richard Weinberger <richard@nod.at> Cc: x86@kernel.org Acked-by: Venkatesh Pallipadi <venki@google.com> Link: http://lkml.kernel.org/r/20120420124557.102478630@linutronix.de
2012-04-26smp: Add generic smpboot facilityThomas Gleixner
Start a new file, which will hold SMP and CPU hotplug related generic infrastructure. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Matt Turner <mattst88@gmail.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Richard Kuo <rkuo@codeaurora.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Richard Weinberger <richard@nod.at> Cc: x86@kernel.org Link: http://lkml.kernel.org/r/20120420124557.035417523@linutronix.de
