path: root/kernel/softirq.c
2018-08-15Mark HI and TASKLET softirq synchronousLinus Torvalds
commit 3c53776e29f81719efcf8f7a6e30cdf753bee94d upstream. Way back in 4.9, we committed 4cd13c21b207 ("softirq: Let ksoftirqd do its job"), and ever since we've had small nagging issues with it. For example, we've had: 1ff688209e2e ("watchdog: core: make sure the watchdog_worker is not deferred") 8d5755b3f77b ("watchdog: softdog: fire watchdog even if softirqs do not get to run") 217f69743681 ("net: busy-poll: allow preemption in sk_busy_loop()") all of which worked around some of the effects of that commit. The DVB people have also complained that the commit causes excessive USB URB latencies, which seems to be due to the USB code using tasklets to schedule USB traffic. This seems to be an issue mainly when already living on the edge, but waiting for ksoftirqd to handle it really does seem to cause excessive latencies. Now Hanna Hawa reports that this issue isn't just limited to USB URB and DVB, but also causes timeout problems for the Marvell SoC team: "I'm facing kernel panic issue while running raid 5 on sata disks connected to Macchiatobin (Marvell community board with Armada-8040 SoC with 4 ARMv8 cores of CA72) Raid 5 built with Marvell DMA engine and async_tx mechanism (ASYNC_TX_DMA [=y]); the DMA driver (mv_xor_v2) uses a tasklet to clean the done descriptors from the queue" The latency problem causes a panic: mv_xor_v2 f0400000.xor: dma_sync_wait: timeout! Kernel panic - not syncing: async_tx_quiesce: DMA error waiting for transaction We've discussed simply just reverting the original commit entirely, and also much more involved solutions (with per-softirq threads etc). This patch is intentionally stupid and fairly limited, because the issue still remains, and the other solutions either got sidetracked or had other issues. We should probably also consider the timer softirqs to be synchronous and not be delayed to ksoftirqd (since they were the issue with the earlier watchdog problems), but that should be done as a separate patch. This does only the tasklet cases. Reported-and-tested-by: Hanna Hawa <hannah@marvell.com> Reported-and-tested-by: Josef Griebichler <griebichler.josef@gmx.at> Reported-by: Mauro Carvalho Chehab <mchehab@s-opensource.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Eric Dumazet <edumazet@google.com> Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-21softirq: Display IRQ_POLL for irq-poll statisticsSagi Grimberg
This library was moved to the generic area and was renamed to irq-poll. Hence, update proc/softirqs output accordingly. Signed-off-by: Sagi Grimberg <sagi@grimberg.me> Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-10-15Merge tag 'gcc-plugins-v4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux Pull gcc plugins update from Kees Cook: "This adds a new gcc plugin named "latent_entropy". It is designed to extract as much possible uncertainty from a running system at boot time as possible, hoping to capitalize on any possible variation in CPU operation (due to runtime data differences, hardware differences, SMP ordering, thermal timing variation, cache behavior, etc). At the very least, this plugin is a much more comprehensive example for how to manipulate kernel code using the gcc plugin internals" * tag 'gcc-plugins-v4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux: latent_entropy: Mark functions with __latent_entropy gcc-plugins: Add latent_entropy plugin
2016-10-10latent_entropy: Mark functions with __latent_entropyEmese Revfy
The __latent_entropy gcc attribute can be used only on functions and variables. If it is on a function then the plugin will instrument it for gathering control-flow entropy. If the attribute is on a variable then the plugin will initialize it with random contents. The variable must be an integer, an integer array type or a structure with integer fields. These specific functions have been selected because they are init functions (to help gather boot-time entropy), are called at unpredictable times, or they have variable loops, each of which provide some level of latent entropy. Signed-off-by: Emese Revfy <re.emese@gmail.com> [kees: expanded commit message] Signed-off-by: Kees Cook <keescook@chromium.org>
2016-10-03Merge branch 'smp-hotplug-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull CPU hotplug updates from Thomas Gleixner: "Yet another batch of cpu hotplug core updates and conversions: - Provide core infrastructure for multi instance drivers so the drivers do not have to keep custom lists. - Convert custom lists to the new infrastructure. The block-mq custom list conversion comes through the block tree and makes the diffstat tip over to more lines removed than added. - Handle unbalanced hotplug enable/disable calls more gracefully. - Remove the obsolete CPU_STARTING/DYING notifier support. - Convert another batch of notifier users. The relayfs changes which conflicted with the conversion have been shipped to me by Andrew. The remaining lot is targeted for 4.10 so that we finally can remove the rest of the notifiers" * 'smp-hotplug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (46 commits) cpufreq: Fix up conversion to hotplug state machine blk/mq: Reserve hotplug states for block multiqueue x86/apic/uv: Convert to hotplug state machine s390/mm/pfault: Convert to hotplug state machine mips/loongson/smp: Convert to hotplug state machine mips/octeon/smp: Convert to hotplug state machine fault-injection/cpu: Convert to hotplug state machine padata: Convert to hotplug state machine cpufreq: Convert to hotplug state machine ACPI/processor: Convert to hotplug state machine virtio scsi: Convert to hotplug state machine oprofile/timer: Convert to hotplug state machine block/softirq: Convert to hotplug state machine lib/irq_poll: Convert to hotplug state machine x86/microcode: Convert to hotplug state machine sh/SH-X3 SMP: Convert to hotplug state machine ia64/mca: Convert to hotplug state machine ARM/OMAP/wakeupgen: Convert to hotplug state machine ARM/shmobile: Convert to hotplug state machine arm64/FP/SIMD: Convert to hotplug state machine ...
2016-09-30softirq: Let ksoftirqd do its jobEric Dumazet
A while back, Paolo and Hannes sent an RFC patch adding threaded-able napi poll loop support : (https://patchwork.ozlabs.org/patch/620657/) The problem seems to be that softirqs are very aggressive and are often handled by the current process, even if we are under stress and that ksoftirqd was scheduled, so that innocent threads would have more chance to make progress. This patch makes sure that if ksoftirq is running, we let it perform the softirq work. Jonathan Corbet summarized the issue in https://lwn.net/Articles/687617/ Tested: - NIC receiving traffic handled by CPU 0 - UDP receiver running on CPU 0, using a single UDP socket. - Incoming flood of UDP packets targeting the UDP socket. Before the patch, the UDP receiver could almost never get CPU cycles and could only receive ~2,000 packets per second. After the patch, CPU cycles are split 50/50 between user application and ksoftirqd/0, and we can effectively read ~900,000 packets per second, a huge improvement in DOS situation. (Note that more packets are now dropped by the NIC itself, since the BH handlers get less CPU cycles to drain RX ring buffer) Since the load runs in well identified threads context, an admin can more easily tune process scheduling parameters if needed. Reported-by: Paolo Abeni <pabeni@redhat.com> Reported-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: David Miller <davem@davemloft.net> Cc: Hannes Frederic Sowa <hannes@redhat.com> Cc: Jesper Dangaard Brouer <jbrouer@redhat.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Rik van Riel <riel@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1472665349.14381.356.camel@edumazet-glaptop3.roam.corp.google.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-09-06kernel/softirq: Convert to hotplug state machineSebastian Andrzej Siewior
Install the callbacks via the state machine. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: rt@linutronix.de Link: http://lkml.kernel.org/r/20160818125731.27256-7-bigeasy@linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-03-25arch, ftrace: for KASAN put hard/soft IRQ entries into separate sectionsAlexander Potapenko
KASAN needs to know whether the allocation happens in an IRQ handler. This lets us strip everything below the IRQ entry point to reduce the number of unique stack traces needed to be stored. Move the definition of __irq_entry to <linux/interrupt.h> so that the users don't need to pull in <linux/ftrace.h>. Also introduce the __softirq_entry macro which is similar to __irq_entry, but puts the corresponding functions to the .softirqentry.text section. Signed-off-by: Alexander Potapenko <glider@google.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Andrey Konovalov <adech.fo@gmail.com> Cc: Dmitry Vyukov <dvyukov@google.com> Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-02-29sched/debug: Fix preempt_disable_ip recording for preempt_disable()Sebastian Andrzej Siewior
The preempt_disable() invokes preempt_count_add() which saves the caller in ->preempt_disable_ip. It uses CALLER_ADDR1 which does not look for its caller but for the parent of the caller. Which means we get the correct caller for something like spin_lock() unless the architectures inlines those invocations. It is always wrong for preempt_disable() or local_bh_disable(). This patch makes the function get_lock_parent_ip() which tries CALLER_ADDR0,1,2 if the former is a locking function. This seems to record the preempt_disable() caller properly for preempt_disable() itself as well as for get_cpu_var() or local_bh_disable(). Steven asked for the get_parent_ip() -> get_lock_parent_ip() rename. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20160226135456.GB18244@linutronix.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-02-09Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core locking updates from Ingo Molnar: "The main changes are: - mutex, completions and rtmutex micro-optimizations - lock debugging fix - various cleanups in the MCS and the futex code" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: locking/rtmutex: Optimize setting task running after being blocked locking/rwsem: Use task->state helpers sched/completion: Add lock-free checking of the blocking case sched/completion: Remove unnecessary ->wait.lock serialization when reading completion state locking/mutex: Explicitly mark task as running after wakeup futex: Fix argument handling in futex_lock_pi() calls doc: Fix misnamed FUTEX_CMP_REQUEUE_PI op constants locking/Documentation: Update code path softirq/preempt: Add missing current->preempt_disable_ip update locking/osq: No need for load/acquire when acquire-polling locking/mcs: Better differentiate between MCS variants locking/mutex: Introduce ww_mutex_set_context_slowpath() locking/mutex: Move MCS related comments to proper location locking/mutex: Checking the stamp is WW only
2015-01-14ksoftirqd: Use new cond_resched_rcu_qs() functionPaul E. McKenney
Simplify run_ksoftirqd() by using the new cond_resched_rcu_qs() function that conditionally reschedules, but unconditionally supplies an RCU quiescent state. This commit is separate from the previous commit by Calvin Owens because Calvin's approach can be backported, while this commit cannot be. The reason that this commit cannot be backported is that cond_resched_rcu_qs() does not always provide the needed quiescent state in earlier kernels. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2015-01-14ksoftirqd: Enable IRQs and call cond_resched() before poking RCUCalvin Owens
While debugging an issue with excessive softirq usage, I encountered the following note in commit 3e339b5dae24a706 ("softirq: Use hotplug thread infrastructure"): [ paulmck: Call rcu_note_context_switch() with interrupts enabled. ] ...but despite this note, the patch still calls RCU with IRQs disabled. This seemingly innocuous change caused a significant regression in softirq CPU usage on the sending side of a large TCP transfer (~1 GB/s): when introducing 0.01% packet loss, the softirq usage would jump to around 25%, spiking as high as 50%. Before the change, the usage would never exceed 5%. Moving the call to rcu_note_context_switch() after the cond_sched() call, as it was originally before the hotplug patch, completely eliminated this problem. Signed-off-by: Calvin Owens <calvinowens@fb.com> Cc: stable@vger.kernel.org Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2015-01-14softirq/preempt: Add missing current->preempt_disable_ip updateHeiko Carstens
While debugging some "sleeping function called from invalid context" bug I realized that the debugging message "Preemption disabled at:" pointed to an incorrect function. In particular if the last function/action that disabled preemption was spin_lock_bh() then current->preempt_disable_ip won't be updated. The reason for this is that __local_bh_disable_ip() will increase preempt_count manually instead of calling preempt_count_add(), which would handle the update correctly. It look like the manual handling was done to work around some lockdep issue. So add the missing update of current->preempt_disable_ip to __local_bh_disable_ip() as well. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20150107090441.GC4365@osiris Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-11-03rcu: Remove "cpu" argument to rcu_note_context_switch()Paul E. McKenney
The "cpu" argument to rcu_note_context_switch() is always the current CPU, so drop it. This in turn allows the "cpu" argument to rcu_preempt_note_context_switch() to be removed, which allows the sole use of "cpu" in both functions to be replaced with a this_cpu_ptr(). Again, the anticipated cross-CPU uses of these functions has been replaced by NO_HZ_FULL. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Pranith Kumar <bobby.prani@gmail.com>
2014-10-15Merge branch 'for-3.18-consistent-ops' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu Pull percpu consistent-ops changes from Tejun Heo: "Way back, before the current percpu allocator was implemented, static and dynamic percpu memory areas were allocated and handled separately and had their own accessors. The distinction has been gone for many years now; however, the now duplicate two sets of accessors remained with the pointer based ones - this_cpu_*() - evolving various other operations over time. During the process, we also accumulated other inconsistent operations. This pull request contains Christoph's patches to clean up the duplicate accessor situation. __get_cpu_var() uses are replaced with with this_cpu_ptr() and __this_cpu_ptr() with raw_cpu_ptr(). Unfortunately, the former sometimes is tricky thanks to C being a bit messy with the distinction between lvalues and pointers, which led to a rather ugly solution for cpumask_var_t involving the introduction of this_cpu_cpumask_var_ptr(). This converts most of the uses but not all. Christoph will follow up with the remaining conversions in this merge window and hopefully remove the obsolete accessors" * 'for-3.18-consistent-ops' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (38 commits) irqchip: Properly fetch the per cpu offset percpu: Resolve ambiguities in __get_cpu_var/cpumask_var_t -fix ia64: sn_nodepda cannot be assigned to after this_cpu conversion. Use __this_cpu_write. percpu: Resolve ambiguities in __get_cpu_var/cpumask_var_t Revert "powerpc: Replace __get_cpu_var uses" percpu: Remove __this_cpu_ptr clocksource: Replace __this_cpu_ptr with raw_cpu_ptr sparc: Replace __get_cpu_var uses avr32: Replace __get_cpu_var with __this_cpu_write blackfin: Replace __get_cpu_var uses tile: Use this_cpu_ptr() for hardware counters tile: Replace __get_cpu_var uses powerpc: Replace __get_cpu_var uses alpha: Replace __get_cpu_var ia64: Replace __get_cpu_var uses s390: cio driver &__get_cpu_var replacements s390: Replace __get_cpu_var uses mips: Replace __get_cpu_var uses MIPS: Replace __get_cpu_var uses in FPU emulator. arm: Replace __this_cpu_ptr with raw_cpu_ptr ...
2014-09-07rcu: Per-CPU operation cleanups to rcu_*_qs() functionsPaul E. McKenney
The rcu_bh_qs(), rcu_preempt_qs(), and rcu_sched_qs() functions use old-style per-CPU variable access and write to ->passed_quiesce even if it is already set. This commit therefore updates to use the new-style per-CPU variable access functions and avoids the spurious writes. This commit also eliminates the "cpu" argument to these functions because they are always invoked on the indicated CPU. Reported-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2014-08-26time: Replace __get_cpu_var usesChristoph Lameter
Convert uses of __get_cpu_var for creating a address from a percpu offset to this_cpu_ptr. The two cases where get_cpu_var is used to actually access a percpu variable are changed to use this_cpu_read/raw_cpu_read. Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-05-22Merge branch 'rcu/next' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-rcu into core/rcu Pull RCU updates from Paul E. McKenney: " 1. Update RCU documentation. These were posted to LKML at https://lkml.org/lkml/2014/4/28/634. 2. Miscellaneous fixes. These were posted to LKML at https://lkml.org/lkml/2014/4/28/645. 3. Torture-test changes. These were posted to LKML at https://lkml.org/lkml/2014/4/28/667. 4. Variable-name renaming cleanup, sent separately due to conflicts. This was posted to LKML at https://lkml.org/lkml/2014/5/13/854. 5. Patch to suppress RCU stall warnings while sysrq requests are being processed. This patch is the RCU portions of the patch that Rik posted to LKML at https://lkml.org/lkml/2014/4/29/457. The reason for pushing this patch ahead instead of waiting until 3.17 is that the NMI-based stack traces are messing up sysrq output, and in some cases also messing up the system as well." Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-05asmlinkage: Add explicit __visible to drivers/*, lib/*, kernel/*Andi Kleen
As requested by Linus add explicit __visible to the asmlinkage users. This marks functions visible to assembler. Tree sweep for rest of tree. Signed-off-by: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/1398984278-29319-4-git-send-email-andi@firstfloor.org Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2014-04-29softirq: A single rcu_bh_qs() call per softirq set is enoughEric Dumazet
Calling rcu_bh_qs() after every softirq action is not really needed. What RCU needs is at least one rcu_bh_qs() per softirq round to note a quiescent state was passed for rcu_bh. Note for Paul and myself : this could be inlined as a single instruction and avoid smp_processor_id() (sone this_cpu_write(rcu_bh_data.passed_quiesce, 1)) Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2014-04-28genirq: x86: Ensure that dynamic irq allocation does not conflictThomas Gleixner
On x86 the allocation of irq descriptors may allocate interrupts which are in the range of the GSI interrupts. That's wrong as those interrupts are hardwired and we don't have the irq domain translation like PPC. So one of these interrupts can be hooked up later to one of the devices which are hard wired to it and the io_apic init code for that particular interrupt line happily reuses that descriptor with a completely different configuration so hell breaks lose. Inside x86 we allocate dynamic interrupts from above nr_gsi_irqs, except for a few usage sites which have not yet blown up in our face for whatever reason. But for drivers which need an irq range, like the GPIO drivers, we have no limit in place and we don't want to expose such a detail to a driver. To cure this introduce a function which an architecture can implement to impose a lower bound on the dynamic interrupt allocations. Implement it for x86 and set the lower bound to nr_gsi_irqs, which is the end of the hardwired interrupt space, so all dynamic allocations happen above. That not only allows the GPIO driver to work sanely, it also protects the bogus callsites of create_irq_nr() in hpet, uv, irq_remapping and htirq code. They need to be cleaned up as well, but that's a separate issue. Reported-by: Jin Yao <yao.jin@linux.intel.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com> Cc: Mathias Nyman <mathias.nyman@linux.intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Grant Likely <grant.likely@linaro.org> Cc: H. Peter Anvin <hpa@linux.intel.com> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: Krogerus Heikki <heikki.krogerus@intel.com> Cc: Linus Walleij <linus.walleij@linaro.org> Link: http://lkml.kernel.org/r/alpine.DEB.2.02.1404241617360.28206@ionos.tec.linutronix.de Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-03-19softirq: Add linux/irq.h to make it compile againThomas Gleixner
On Sparc and S390 the removal of irq.h from kernel_stat.h causes: kernel/softirq.c:774:9: error: 'NR_IRQS_LEGACY' undeclared Reported-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2014-01-31Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer/dynticks updates from Ingo Molnar: "This tree contains misc dynticks updates: a fix and three cleanups" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/nohz: Fix overflow error in scheduler_tick_max_deferment() nohz_full: fix code style issue of tick_nohz_full_stop_tick nohz: Get timekeeping max deferment outside jiffies_lock tick: Rename tick_check_idle() to tick_irq_enter()
2014-01-27softirq: use const char * const for softirq_to_name, whitespace neateningJoe Perches
Reduce data size a little. Reduce checkpatch noise. $ size kernel/softirq.o* text data bss dec hex filename 11554 6013 4008 21575 5447 kernel/softirq.o.new 11474 6093 4008 21575 5447 kernel/softirq.o.old Signed-off-by: Joe Perches <joe@perches.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-27softirq: convert printks to pr_<level>Joe Perches
Use a more current logging style. Signed-off-by: Joe Perches <joe@perches.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-27softirq: use ffs() in __do_softirq()Joe Perches
Possible speed improvement of __do_softirq() by using ffs() instead of using a while loop with an & 1 test then single bit shift. Signed-off-by: Joe Perches <joe@perches.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-25Merge branch 'timers/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/linux-dynticks into timers/urgent Pull dynticks cleanups from Frederic Weisbecker. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-20Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer changes from Ingo Molnar: - ARM clocksource/clockevent improvements and fixes - generic timekeeping updates: TAI fixes/improvements, cleanups - Posix cpu timer cleanups and improvements - dynticks updates: full dynticks bugfixes, optimizations and cleanups * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (46 commits) clocksource: Timer-sun5i: Switch to sched_clock_register() timekeeping: Remove comment that's mostly out of date rtc-cmos: Add an alarm disable quirk timekeeper: fix comment typo for tk_setup_internals() timekeeping: Fix missing timekeeping_update in suspend path timekeeping: Fix CLOCK_TAI timer/nanosleep delays tick/timekeeping: Call update_wall_time outside the jiffies lock timekeeping: Avoid possible deadlock from clock_was_set_delayed timekeeping: Fix potential lost pv notification of time change timekeeping: Fix lost updates to tai adjustment clocksource: sh_cmt: Add clk_prepare/unprepare support clocksource: bcm_kona_timer: Remove unused bcm_timer_ids clocksource: vt8500: Remove deprecated IRQF_DISABLED clocksource: tegra: Remove deprecated IRQF_DISABLED clocksource: misc drivers: Remove deprecated IRQF_DISABLED clocksource: sh_mtu2: Remove unnecessary platform_set_drvdata() clocksource: sh_tmu: Remove unnecessary platform_set_drvdata() clocksource: armada-370-xp: Enable timer divider only when needed clocksource: clksrc-of: Warn if no clock sources are found clocksource: orion: Switch to sched_clock_register() ...
2014-01-20Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: - Add the initial implementation of SCHED_DEADLINE support: a real-time scheduling policy where tasks that meet their deadlines and periodically execute their instances in less than their runtime quota see real-time scheduling and won't miss any of their deadlines. Tasks that go over their quota get delayed (Available to privileged users for now) - Clean up and fix preempt_enable_no_resched() abuse all around the tree - Do sched_clock() performance optimizations on x86 and elsewhere - Fix and improve auto-NUMA balancing - Fix and clean up the idle loop - Apply various cleanups and fixes * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (60 commits) sched: Fix __sched_setscheduler() nice test sched: Move SCHED_RESET_ON_FORK into attr::sched_flags sched: Fix up attr::sched_priority warning sched: Fix up scheduler syscall LTP fails sched: Preserve the nice level over sched_setscheduler() and sched_setparam() calls sched/core: Fix htmldocs warnings sched/deadline: No need to check p if dl_se is valid sched/deadline: Remove unused variables sched/deadline: Fix sparse static warnings m68k: Fix build warning in mac_via.h sched, thermal: Clean up preempt_enable_no_resched() abuse sched, net: Fixup busy_loop_us_clock() sched, net: Clean up preempt_enable_no_resched() abuse sched/preempt: Fix up missed PREEMPT_NEED_RESCHED folding sched/preempt, locking: Rework local_bh_{dis,en}able() sched/clock, x86: Avoid a runtime condition in native_sched_clock() sched/clock: Fix up clear_sched_clock_stable() sched/clock, x86: Use a static_key for sched_clock_stable sched/clock: Remove local_irq_disable() from the clocks sched/clock, x86: Rewrite cyc2ns() to avoid the need to disable IRQs ...
2014-01-15tick: Rename tick_check_idle() to tick_irq_enter()Frederic Weisbecker
This makes the code more symetric against the existing tick functions called on irq exit: tick_irq_exit() and tick_nohz_irq_exit(). These function are also symetric as they mirror each other's action: we start to account idle time on irq exit and we stop this accounting on irq entry. Also the tick is stopped on irq exit and timekeeping catches up with the tickless time elapsed until we reach irq entry. This rename was suggested by Peter Zijlstra a long while ago but it got forgotten in the mass. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Alex Shi <alex.shi@linaro.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: John Stultz <john.stultz@linaro.org> Cc: Kevin Hilman <khilman@linaro.org> Link: http://lkml.kernel.org/r/1387320692-28460-2-git-send-email-fweisbec@gmail.com Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2014-01-13sched/preempt, locking: Rework local_bh_{dis,en}able()Peter Zijlstra
Currently local_bh_disable() is out-of-line for no apparent reason. So inline it to save a few cycles on call/return nonsense, the function body is a single add on x86 (a few loads and store extra on load/store archs). Also expose two new local_bh functions: __local_bh_{dis,en}able_ip(unsigned long ip, unsigned int cnt); Which implement the actual local_bh_{dis,en}able() behaviour. The next patch uses the exposed @cnt argument to optimize bh lock functions. With build fixes from Jacob Pan. Cc: rjw@rjwysocki.net Cc: rui.zhang@intel.com Cc: jacob.jun.pan@linux.intel.com Cc: Mike Galbraith <bitbucket@online.de> Cc: hpa@zytor.com Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: lenb@kernel.org Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20131119151338.GF3694@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-01-13locking: Optimize lock_bh functionsPeter Zijlstra
Currently all _bh_ lock functions do two preempt_count operations: local_bh_disable(); preempt_disable(); and for the unlock: preempt_enable_no_resched(); local_bh_enable(); Since its a waste of perfectly good cycles to modify the same variable twice when you can do it in one go; use the new __local_bh_{dis,en}able_ip() functions that allow us to provide a preempt_count value to add/sub. So define SOFTIRQ_LOCK_OFFSET as the offset a _bh_ lock needs to add/sub to be done in one go. As a bonus it gets rid of the preempt_enable_no_resched() usage. This reduces a 1000 loops of: spin_lock_bh(&bh_lock); spin_unlock_bh(&bh_lock); from 53596 cycles to 51995 cycles. I didn't do enough measurements to say for absolute sure that the result is significant but the the few runs I did for each suggest it is so. Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: jacob.jun.pan@linux.intel.com Cc: Mike Galbraith <bitbucket@online.de> Cc: hpa@zytor.com Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: lenb@kernel.org Cc: rjw@rjwysocki.net Cc: rui.zhang@intel.com Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/20131119151338.GF3694@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-12-02nohz: Convert a few places to use local per cpu accessesFrederic Weisbecker
A few functions use remote per CPU access APIs when they deal with local values. Just do the right conversion to improve performance, code readability and debug checks. While at it, lets extend some of these function names with *_this_cpu() suffix in order to display their purpose more clearly. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org>
2013-11-27lockdep: Simplify a bit hardirq <-> softirq transitionsFrederic Weisbecker
Instead of saving the hardirq state on a per CPU variable, which require an explicit call before the softirq handling and some complication, just save and restore the hardirq tracing state through functions return values and parameters. It simplifies a bit the black magic that works around the fact that softirqs can be called from hardirqs while hardirqs can nest on softirqs but those two cases have very different semantics and only the latter case assume both states. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1384906054-30676-1-git-send-email-fweisbec@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-27Merge branch 'core/urgent' into core/lockingIngo Molnar
Prepare for dependent patch. Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-19lockdep: Correctly annotate hardirq context in irq_exit()Peter Zijlstra
There was a reported deadlock on -rt which lockdep didn't report. It turns out that in irq_exit() we tell lockdep that the hardirq context ends and then do all kinds of locking afterwards. To fix it, move trace_hardirq_exit() to the very end of irq_exit(), this ensures all locking in tick_irq_exit() and rcu_irq_exit() are properly recorded as happening from hardirq context. This however leads to the 'fun' little problem of running softirqs while in hardirq context. To cure this make the softirq code a little more complex (in the CONFIG_TRACE_IRQFLAGS case). Due to stack swizzling arch dependent trickery we cannot pass an argument to __do_softirq() to tell it if it was done from hardirq context or not; so use a side-band argument. When we do __do_softirq() from hardirq context, 'atomically' flip to softirq context and back, so that no locking goes without being in either hard- or soft-irq context. I didn't find any new problems in mainline using this patch, but it did show the -rt problem. Reported-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-dgwc5cdksbn0jk09vbmcc9sa@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-11-15revert "softirq: Add support for triggering softirq work on softirqs"Christoph Hellwig
This commit was incomplete in that code to remove items from the per-cpu lists was missing and never acquired a user in the 5 years it has been in the tree. We're going to implement what it seems to try to archive in a simpler way, and this code is in the way of doing so. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Jan Kara <jack@suse.cz> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-12Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler changes from Ingo Molnar: "The main changes in this cycle are: - (much) improved CONFIG_NUMA_BALANCING support from Mel Gorman, Rik van Riel, Peter Zijlstra et al. Yay! - optimize preemption counter handling: merge the NEED_RESCHED flag into the preempt_count variable, by Peter Zijlstra. - wait.h fixes and code reorganization from Peter Zijlstra - cfs_bandwidth fixes from Ben Segall - SMP load-balancer cleanups from Peter Zijstra - idle balancer improvements from Jason Low - other fixes and cleanups" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (129 commits) ftrace, sched: Add TRACE_FLAG_PREEMPT_RESCHED stop_machine: Fix race between stop_two_cpus() and stop_cpus() sched: Remove unnecessary iteration over sched domains to update nr_busy_cpus sched: Fix asymmetric scheduling for POWER7 sched: Move completion code from core.c to completion.c sched: Move wait code from core.c to wait.c sched: Move wait.c into kernel/sched/ sched/wait: Fix __wait_event_interruptible_lock_irq_timeout() sched: Avoid throttle_cfs_rq() racing with period_timer stopping sched: Guarantee new group-entities always have weight sched: Fix hrtimer_cancel()/rq->lock deadlock sched: Fix cfs_bandwidth misuse of hrtimer_expires_remaining sched: Fix race on toggling cfs_bandwidth_used sched: Remove extra put_online_cpus() inside sched_setaffinity() sched/rt: Fix task_tick_rt() comment sched/wait: Fix build breakage sched/wait: Introduce prepare_to_wait_event() sched/wait: Add ___wait_cond_timeout() to wait_event*_timeout() too sched: Remove get_online_cpus() usage sched: Fix race in migrate_swap_stop() ...
2013-10-09Merge tag 'v3.12-rc4' into sched/coreIngo Molnar
Merge Linux v3.12-rc4 to fix a conflict and also to refresh the tree before applying more scheduler patches. Conflicts: arch/avr32/include/asm/Kbuild Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-10-01irq: Optimize softirq stack selection in irq exitFrederic Weisbecker
If irq_exit() is called on the arch's specified irq stack, it should be safe to run softirqs inline under that same irq stack as it is near empty by the time we call irq_exit(). For example if we use the same stack for both hard and soft irqs here, the worst case scenario is: hardirq -> softirq -> hardirq. But then the softirq supersedes the first hardirq as the stack user since irq_exit() is called in a mostly empty stack. So the stack merge in this case looks acceptable. Stack overrun still have a chance to happen if hardirqs have more opportunities to nest, but then it's another problem to solve. So lets adapt the irq exit's softirq stack on top of a new Kconfig symbol that can be defined when irq_exit() runs on the irq stack. That way we can spare some stack switch on irq processing and all the cache issues that come along. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@au1.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul Mackerras <paulus@au1.ibm.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: David S. Miller <davem@davemloft.net> Cc: Andrew Morton <akpm@linux-foundation.org>
2013-10-01irq: Justify the various softirq stack choicesFrederic Weisbecker
For clarity, comment the various stack choices for softirqs processing, whether we execute them from ksoftirqd or local_irq_enable() calls. Their use on irq_exit() is already commented. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@au1.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul Mackerras <paulus@au1.ibm.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: David S. Miller <davem@davemloft.net> Cc: Andrew Morton <akpm@linux-foundation.org>
2013-10-01irq: Improve a bit softirq debuggingFrederic Weisbecker
do_softirq() has a debug check that verifies that it is not nesting on softirqs processing, nor miscounting the softirq part of the preempt count. But making sure that softirqs processing don't nest is actually a more generic concern that applies to any caller of __do_softirq(). Do take it one step further and generalize that debug check to any softirq processing. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@au1.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul Mackerras <paulus@au1.ibm.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: David S. Miller <davem@davemloft.net> Cc: Andrew Morton <akpm@linux-foundation.org>
2013-10-01irq: Optimize call to softirq on hardirq exitFrederic Weisbecker
Before processing softirqs on hardirq exit, we already do the check for pending softirqs while hardirqs are guaranteed to be disabled. So we can take a shortcut and safely jump to the arch specific implementation directly. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@au1.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul Mackerras <paulus@au1.ibm.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: David S. Miller <davem@davemloft.net> Cc: Andrew Morton <akpm@linux-foundation.org>
2013-10-01irq: Consolidate do_softirq() arch overriden implementationsFrederic Weisbecker
All arch overriden implementations of do_softirq() share the following common code: disable irqs (to avoid races with the pending check), check if there are softirqs pending, then execute __do_softirq() on a specific stack. Consolidate the common parts such that archs only worry about the stack switch. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@au1.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul Mackerras <paulus@au1.ibm.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: David S. Miller <davem@davemloft.net> Cc: Andrew Morton <akpm@linux-foundation.org>
2013-10-01irq: Force hardirq exit's softirq processing on its own stackFrederic Weisbecker
The commit facd8b80c67a3cf64a467c4a2ac5fb31f2e6745b ("irq: Sanitize invoke_softirq") converted irq exit calls of do_softirq() to __do_softirq() on all architectures, assuming it was only used there for its irq disablement properties. But as a side effect, the softirqs processed in the end of the hardirq are always called on the inline current stack that is used by irq_exit() instead of the softirq stack provided by the archs that override do_softirq(). The result is mostly safe if the architecture runs irq_exit() on a separate irq stack because then softirqs are processed on that same stack that is near empty at this stage (assuming hardirq aren't nesting). Otherwise irq_exit() runs in the task stack and so does the softirq too. The interrupted call stack can be randomly deep already and the softirq can dig through it even further. To add insult to the injury, this softirq can be interrupted by a new hardirq, maximizing the chances for a stack overrun as reported in powerpc for example: do_IRQ: stack overflow: 1920 CPU: 0 PID: 1602 Comm: qemu-system-ppc Not tainted 3.10.4-300.1.fc19.ppc64p7 #1 Call Trace: [c0000000050a8740] .show_stack+0x130/0x200 (unreliable) [c0000000050a8810] .dump_stack+0x28/0x3c [c0000000050a8880] .do_IRQ+0x2b8/0x2c0 [c0000000050a8930] hardware_interrupt_common+0x154/0x180 --- Exception: 501 at .cp_start_xmit+0x3a4/0x820 [8139cp] LR = .cp_start_xmit+0x390/0x820 [8139cp] [c0000000050a8d40] .dev_hard_start_xmit+0x394/0x640 [c0000000050a8e00] .sch_direct_xmit+0x110/0x260 [c0000000050a8ea0] .dev_queue_xmit+0x260/0x630 [c0000000050a8f40] .br_dev_queue_push_xmit+0xc4/0x130 [bridge] [c0000000050a8fc0] .br_dev_xmit+0x198/0x270 [bridge] [c0000000050a9070] .dev_hard_start_xmit+0x394/0x640 [c0000000050a9130] .dev_queue_xmit+0x428/0x630 [c0000000050a91d0] .ip_finish_output+0x2a4/0x550 [c0000000050a9290] .ip_local_out+0x50/0x70 [c0000000050a9310] .ip_queue_xmit+0x148/0x420 [c0000000050a93b0] .tcp_transmit_skb+0x4e4/0xaf0 [c0000000050a94a0] .__tcp_ack_snd_check+0x7c/0xf0 [c0000000050a9520] .tcp_rcv_established+0x1e8/0x930 [c0000000050a95f0] .tcp_v4_do_rcv+0x21c/0x570 [c0000000050a96c0] .tcp_v4_rcv+0x734/0x930 [c0000000050a97a0] .ip_local_deliver_finish+0x184/0x360 [c0000000050a9840] .ip_rcv_finish+0x148/0x400 [c0000000050a98d0] .__netif_receive_skb_core+0x4f8/0xb00 [c0000000050a99d0] .netif_receive_skb+0x44/0x110 [c0000000050a9a70] .br_handle_frame_finish+0x2bc/0x3f0 [bridge] [c0000000050a9b20] .br_nf_pre_routing_finish+0x2ac/0x420 [bridge] [c0000000050a9bd0] .br_nf_pre_routing+0x4dc/0x7d0 [bridge] [c0000000050a9c70] .nf_iterate+0x114/0x130 [c0000000050a9d30] .nf_hook_slow+0xb4/0x1e0 [c0000000050a9e00] .br_handle_frame+0x290/0x330 [bridge] [c0000000050a9ea0] .__netif_receive_skb_core+0x34c/0xb00 [c0000000050a9fa0] .netif_receive_skb+0x44/0x110 [c0000000050aa040] .napi_gro_receive+0xe8/0x120 [c0000000050aa0c0] .cp_rx_poll+0x31c/0x590 [8139cp] [c0000000050aa1d0] .net_rx_action+0x1dc/0x310 [c0000000050aa2b0] .__do_softirq+0x158/0x330 [c0000000050aa3b0] .irq_exit+0xc8/0x110 [c0000000050aa430] .do_IRQ+0xdc/0x2c0 [c0000000050aa4e0] hardware_interrupt_common+0x154/0x180 --- Exception: 501 at .bad_range+0x1c/0x110 LR = .get_page_from_freelist+0x908/0xbb0 [c0000000050aa7d0] .list_del+0x18/0x50 (unreliable) [c0000000050aa850] .get_page_from_freelist+0x908/0xbb0 [c0000000050aa9e0] .__alloc_pages_nodemask+0x21c/0xae0 [c0000000050aaba0] .alloc_pages_vma+0xd0/0x210 [c0000000050aac60] .handle_pte_fault+0x814/0xb70 [c0000000050aad50] .__get_user_pages+0x1a4/0x640 [c0000000050aae60] .get_user_pages_fast+0xec/0x160 [c0000000050aaf10] .__gfn_to_pfn_memslot+0x3b0/0x430 [kvm] [c0000000050aafd0] .kvmppc_gfn_to_pfn+0x64/0x130 [kvm] [c0000000050ab070] .kvmppc_mmu_map_page+0x94/0x530 [kvm] [c0000000050ab190] .kvmppc_handle_pagefault+0x174/0x610 [kvm] [c0000000050ab270] .kvmppc_handle_exit_pr+0x464/0x9b0 [kvm] [c0000000050ab320] kvm_start_lightweight+0x1ec/0x1fc [kvm] [c0000000050ab4f0] .kvmppc_vcpu_run_pr+0x168/0x3b0 [kvm] [c0000000050ab9c0] .kvmppc_vcpu_run+0xc8/0xf0 [kvm] [c0000000050aba50] .kvm_arch_vcpu_ioctl_run+0x5c/0x1a0 [kvm] [c0000000050abae0] .kvm_vcpu_ioctl+0x478/0x730 [kvm] [c0000000050abc90] .do_vfs_ioctl+0x4ec/0x7c0 [c0000000050abd80] .SyS_ioctl+0xd4/0xf0 [c0000000050abe30] syscall_exit+0x0/0x98 Since this is a regression, this patch proposes a minimalistic and low-risk solution by blindly forcing the hardirq exit processing of softirqs on the softirq stack. This way we should reduce significantly the opportunities for task stack overflow dug by softirqs. Longer term solutions may involve extending the hardirq stack coverage to irq_exit(), etc... Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: #3.9.. <stable@vger.kernel.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@au1.ibm.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul Mackerras <paulus@au1.ibm.com> Cc: James Hogan <james.hogan@imgtec.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: David S. Miller <davem@davemloft.net> Cc: Andrew Morton <akpm@linux-foundation.org>
2013-09-25sched: Extract the basic add/sub preempt_count modifiersPeter Zijlstra
Rewrite the preempt_count macros in order to extract the 3 basic preempt_count value modifiers: __preempt_count_add() __preempt_count_sub() and the new: __preempt_count_dec_and_test() And since we're at it anyway, replace the unconventional $op_preempt_count names with the more conventional preempt_count_$op. Since these basic operators are equivalent to the previous _notrace() variants, do away with the _notrace() versions. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-ewbpdbupy9xpsjhg960zwbv8@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-25sched: Introduce preempt_count accessor functionsPeter Zijlstra
Replace the single preempt_count() 'function' that's an lvalue with two proper functions: preempt_count() - returns the preempt_count value as rvalue preempt_count_set() - Allows setting the preempt-count value Also provide preempt_count_ptr() as a convenience wrapper to implement all modifying operations. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/n/tip-orxrbycjozopqfhb4dxdkdvb@git.kernel.org [ Fixed build failure. ] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-09-13Remove GENERIC_HARDIRQ config optionMartin Schwidefsky
After the last architecture switched to generic hard irqs the config options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code for !CONFIG_GENERIC_HARDIRQS can be removed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-07-14kernel: delete __cpuinit usage from all core kernel filesPaul Gortmaker
The __cpuinit type of throwaway sections might have made sense some time ago when RAM was more constrained, but now the savings do not offset the cost and complications. For example, the fix in commit 5e427ec2d0 ("x86: Fix bit corruption at CPU resume time") is a good example of the nasty type of bugs that can be created with improper use of the various __init prefixes. After a discussion on LKML[1] it was decided that cpuinit should go the way of devinit and be phased out. Once all the users are gone, we can then finally remove the macros themselves from linux/init.h. This removes all the uses of the __cpuinit macros from C files in the core kernel directories (kernel, init, lib, mm, and include) that don't really have a specific maintainer. [1] https://lkml.org/lkml/2013/5/20/589 Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2013-07-02Merge branch 'irq-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull core irq changes from Ingo Molnar: "The main changes: - generic-irqchip driver additions, cleanups and fixes - 3 new irqchip drivers: ARMv7-M NVIC, TB10x and Marvell Orion SoCs - irq_get_trigger_type() simplification and cross-arch cleanup - various cleanups, simplifications - documentation updates" * 'irq-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (26 commits) softirq: Use _RET_IP_ genirq: Add the generic chip to the genirq docbook genirq: generic-chip: Export some irq_gc_ functions genirq: Fix can_request_irq() for IRQs without an action irqchip: exynos-combiner: Staticize combiner_init irqchip: Add support for ARMv7-M NVIC irqchip: Add TB10x interrupt controller driver irqdomain: Use irq_get_trigger_type() to get IRQ flags MIPS: octeon: Use irq_get_trigger_type() to get IRQ flags arm: orion: Use irq_get_trigger_type() to get IRQ flags mfd: stmpe: use irq_get_trigger_type() to get IRQ flags mfd: twl4030-irq: Use irq_get_trigger_type() to get IRQ flags gpio: mvebu: Use irq_get_trigger_type() to get IRQ flags genirq: Add irq_get_trigger_type() to get IRQ flags genirq: Irqchip: document gcflags arg of irq_alloc_domain_generic_chips genirq: Set irq thread to RT priority on creation irqchip: Add support for Marvell Orion SoCs genirq: Add kerneldoc for irq_disable. genirq: irqchip: Add mask to block out invalid irqs genirq: Generic chip: Add linear irq domain support ...
