path: root/kernel/softirq.c
2005-11-07[PATCH] cpu hoptlug: avoid usage of smp_processor_id() in preemptible codeHeiko Carstens
Replace smp_processor_id() with any_online_cpu(cpu_online_map) in order to avoid lots of "BUG: using smp_processor_id() in preemptible [00000001] code:..." messages in case taking a cpu online fails. All the traces start at the last notifier_call_chain(...) in kernel/cpu.c. Since we hold the cpu_control semaphore it shouldn't be any problem to access cpu_online_map. The reason why cpu_up failed is simply that the cpu that was supposed to be taken online wasn't even there. That is because on s390 we never know when a new cpu comes and therefore cpu_possible_map consists of only ones and doesn't reflect reality. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-12[PATCH] x86-64: Some cleanup and optimization to the processor data area.Andi Kleen
- Remove unused irqrsp field - Remove pda->me - Optimize set_softirq_pending slightly Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-30[PATCH] revert bogus softirq changesAndrew Morton
This snuck in with an x86_64 change. Thanks to Richard Purdie <rpurdie@rpsys.net> for spotting it. Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] x86_64: Switch to the interrupt stack when running a softirq in ↵Andi Kleen
local_bh_enable() This avoids some potential stack overflows with very deep softirq callchains. i386 does this too. TOADD CFI annotation Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
