path: root/kernel/sys.c
2009-04-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: Remove two unneeded exports and make two symbols static in fs/mpage.c Cleanup after commit 585d3bc06f4ca57f975a5a1f698f65a45ea66225 Trim includes of fdtable.h Don't crap into descriptor table in binfmt_som Trim includes in binfmt_elf Don't mess with descriptor table in load_elf_binary() Get rid of indirect include of fs_struct.h New helper - current_umask() check_unsafe_exec() doesn't care about signal handlers sharing New locking/refcounting for fs_struct Take fs_struct handling to new file (fs/fs_struct.c) Get rid of bumping fs_struct refcount in pivot_root(2) Kill unsharing fs_struct in __set_personality()
2009-04-02pids: kill signal_struct-> __pgrp/__session and friendsOleg Nesterov
We are wasting 2 words in signal_struct without any reason to implement task_pgrp_nr() and task_session_nr(). task_session_nr() has no callers since 2e2ba22ea4fd4bb85f0fa37c521066db6775cbef, we can remove it. task_pgrp_nr() is still (I believe wrongly) used in fs/autofsX and fs/coda. This patch reimplements task_pgrp_nr() via task_pgrp_nr_ns(), and kills __pgrp/__session and the related helpers. The change in drivers/char/tty_io.c is cosmetic, but hopefully makes sense anyway. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Alan Cox <number6@the-village.bc.nu> [tty parts] Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Sukadev Bhattiprolu <sukadev@linux.vnet.ibm.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-31Get rid of indirect include of fs_struct.hAl Viro
Don't pull it in sched.h; very few files actually need it and those can include directly. sched.h itself only needs forward declaration of struct fs_struct; Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-02-27sched: don't allow setuid to succeed if the user does not have rt bandwidthDhaval Giani
Impact: fix hung task with certain (non-default) rt-limit settings Corey Hickey reported that on using setuid to change the uid of a rt process, the process would be unkillable and not be running. This is because there was no rt runtime for that user group. Add in a check to see if a user can attach an rt task to its task group. On failure, return EINVAL, which is also returned in CONFIG_CGROUP_SCHED. Reported-by: Corey Hickey <bugfood-ml@fatooh.org> Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-05revert "rlimit: permit setting RLIMIT_NOFILE to RLIM_INFINITY"Andrew Morton
Revert commit 0c2d64fb6cae9aae480f6a46cfe79f8d7d48b59f because it causes (arguably poorly designed) existing userspace to spend interminable periods closing billions of not-open file descriptors. We could bring this back, with some sort of opt-in tunable in /proc, which defaults to "off". Peter's alanysis follows: : I spent several hours trying to get to the bottom of a serious : performance issue that appeared on one of our servers after upgrading to : 2.6.28. In the end it's what could be considered a userspace bug that : was triggered by a change in 2.6.28. Since this might also affect other : people I figured I'd at least document what I found here, and maybe we : can even do something about it: : : : So, I upgraded some of debian.org's machines to 2.6.28.1 and immediately : the team maintaining our ftp archive complained that one of their : scripts that previously ran in a few minutes still hadn't even come : close to being done after an hour or so. Downgrading to 2.6.27 fixed : that. : : Turns out that script is forking a lot and something in it or python or : whereever closes all the file descriptors it doesn't want to pass on. : That is, it starts at zero and goes up to ulimit -n/RLIMIT_NOFILE and : closes them all with a few exceptions. : : Turns out that takes a long time when your limit -n is now 2^20 (1048576). : : With 2.6.27.* the ulimit -n was the standard 1024, but with 2.6.28 it is : now a thousand times that. : : 2.6.28 included a patch titled "rlimit: permit setting RLIMIT_NOFILE to : RLIM_INFINITY" (0c2d64fb6cae9aae480f6a46cfe79f8d7d48b59f)[1] that : allows, as the title implies, to set the limit for number of files to : infinity. : : Closer investigation showed that the broken default ulimit did not apply : to "system" processes (like stuff started from init). In the end I : could establish that all processes that passed through pam_limit at one : point had the bad resource limit. : : Apparently the pam library in Debian etch (4.0) initializes the limits : to some default values when it doesn't have any settings in limit.conf : to override them. Turns out that for nofiles this is RLIM_INFINITY. : Commenting out "case RLIMIT_NOFILE" in pam_limit.c:267 of our pam : package version 0.79-5 fixes that - tho I'm not sure what side effects : that has. : : Debian lenny (the upcoming 5.0 version) doesn't have this issue as it : uses a different pam (version). Reported-by: Peter Palfrader <weasel@debian.org> Cc: Adam Tkac <vonsch@gmail.com> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <stable@kernel.org> [2.6.28.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] System call wrappers part 31Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 26Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 24Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 23Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 07Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 04Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 03Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 02Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 01Heiko Carstens
2009-01-06Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: fix section mismatch sched: fix double kfree in failure path sched: clean up arch_reinit_sched_domains() sched: mark sched_create_sysfs_power_savings_entries() as __init getrusage: RUSAGE_THREAD should return ru_utime and ru_stime sched: fix sched_slice() sched_clock: prevent scd->clock from moving backwards, take #2 sched: sched.c declare variables before they get used
2009-01-06Allow times and time system calls to return small negative valuesPaul Mackerras
At the moment, the times() system call will appear to fail for a period shortly after boot, while the value it want to return is between -4095 and -1. The same thing will also happen for the time() system call on 32-bit platforms some time in 2106 or so. On some platforms, such as x86, this is unavoidable because of the system call ABI, but other platforms such as powerpc have a separate error indication from the return value, so system calls can in fact return small negative values without indicating an error. On those platforms, force_successful_syscall_return() provides a way to indicate that the system call return value should not be treated as an error even if it is in the range which would normally be taken as a negative error number. This adds a force_successful_syscall_return() call to the time() and times() system calls plus their 32-bit compat versions, so that they don't erroneously indicate an error on those platforms whose system call ABI has a separate error indication. This will not affect anything on other platforms. Joakim Tjernlund added the fix for time() and the compat versions of time() and times(), after I did the fix for times(). Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se> Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-04getrusage: RUSAGE_THREAD should return ru_utime and ru_stimeKOSAKI Motohiro
Impact: task stats regression fix Original getrusage(RUSAGE_THREAD) implementation can return ru_utime and ru_stime. But commit "f06febc: timers: fix itimer/many thread hang" broke it. this patch restores it. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Roland McGrath <roland@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-12-30Merge branch 'core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (63 commits) stacktrace: provide save_stack_trace_tsk() weak alias rcu: provide RCU options on non-preempt architectures too printk: fix discarding message when recursion_bug futex: clean up futex_(un)lock_pi fault handling "Tree RCU": scalable classic RCU implementation futex: rename field in futex_q to clarify single waiter semantics x86/swiotlb: add default swiotlb_arch_range_needs_mapping x86/swiotlb: add default phys<->bus conversion x86: unify pci iommu setup and allow swiotlb to compile for 32 bit x86: add swiotlb allocation functions swiotlb: consolidate swiotlb info message printing swiotlb: support bouncing of HighMem pages swiotlb: factor out copy to/from device swiotlb: add arch hook to force mapping swiotlb: allow architectures to override phys<->bus<->phys conversions swiotlb: add comment where we handle the overflow of a dma mask on 32 bit rcu: fix rcutorture behavior during reboot resources: skip sanity check of busy resources swiotlb: move some definitions to header swiotlb: allow architectures to override swiotlb pool allocation ... Fix up trivial conflicts in arch/x86/kernel/Makefile arch/x86/mm/init_32.c include/linux/hardirq.h as per Ingo's suggestions.
2008-11-24User namespaces: set of cleanups (v2)Serge Hallyn
The user_ns is moved from nsproxy to user_struct, so that a struct cred by itself is sufficient to determine access (which it otherwise would not be). Corresponding ecryptfs fixes (by David Howells) are here as well. Fix refcounting. The following rules now apply: 1. The task pins the user struct. 2. The user struct pins its user namespace. 3. The user namespace pins the struct user which created it. User namespaces are cloned during copy_creds(). Unsharing a new user_ns is no longer possible. (We could re-add that, but it'll cause code duplication and doesn't seem useful if PAM doesn't need to clone user namespaces). When a user namespace is created, its first user (uid 0) gets empty keyrings and a clean group_info. This incorporates a previous patch by David Howells. Here is his original patch description: >I suggest adding the attached incremental patch. It makes the following >changes: > > (1) Provides a current_user_ns() macro to wrap accesses to current's user > namespace. > > (2) Fixes eCryptFS. > > (3) Renames create_new_userns() to create_user_ns() to be more consistent > with the other associated functions and because the 'new' in the name is > superfluous. > > (4) Moves the argument and permission checks made for CLONE_NEWUSER to the > beginning of do_fork() so that they're done prior to making any attempts > at allocation. > > (5) Calls create_user_ns() after prepare_creds(), and gives it the new creds > to fill in rather than have it return the new root user. I don't imagine > the new root user being used for anything other than filling in a cred > struct. > > This also permits me to get rid of a get_uid() and a free_uid(), as the > reference the creds were holding on the old user_struct can just be > transferred to the new namespace's creator pointer. > > (6) Makes create_user_ns() reset the UIDs and GIDs of the creds under > preparation rather than doing it in copy_creds(). > >David >Signed-off-by: David Howells <dhowells@redhat.com> Changelog: Oct 20: integrate dhowells comments 1. leave thread_keyring alone 2. use current_user_ns() in set_user() Signed-off-by: Serge Hallyn <serue@us.ibm.com>
2008-11-17thread_group_cputime: move a couple of callsites outside of ->siglockOleg Nesterov
Impact: relax the locking of cpu-time accounting calls ->siglock buys nothing for thread_group_cputime() in do_sys_times() and wait_task_zombie() (which btw takes the unrelated parent's ->siglock). Actually I think do_sys_times() doesn't need ->siglock at all. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-14CRED: Inaugurate COW credentialsDavid Howells
Inaugurate copy-on-write credentials management. This uses RCU to manage the credentials pointer in the task_struct with respect to accesses by other tasks. A process may only modify its own credentials, and so does not need locking to access or modify its own credentials. A mutex (cred_replace_mutex) is added to the task_struct to control the effect of PTRACE_ATTACHED on credential calculations, particularly with respect to execve(). With this patch, the contents of an active credentials struct may not be changed directly; rather a new set of credentials must be prepared, modified and committed using something like the following sequence of events: struct cred *new = prepare_creds(); int ret = blah(new); if (ret < 0) { abort_creds(new); return ret; } return commit_creds(new); There are some exceptions to this rule: the keyrings pointed to by the active credentials may be instantiated - keyrings violate the COW rule as managing COW keyrings is tricky, given that it is possible for a task to directly alter the keys in a keyring in use by another task. To help enforce this, various pointers to sets of credentials, such as those in the task_struct, are declared const. The purpose of this is compile-time discouragement of altering credentials through those pointers. Once a set of credentials has been made public through one of these pointers, it may not be modified, except under special circumstances: (1) Its reference count may incremented and decremented. (2) The keyrings to which it points may be modified, but not replaced. The only safe way to modify anything else is to create a replacement and commit using the functions described in Documentation/credentials.txt (which will be added by a later patch). This patch and the preceding patches have been tested with the LTP SELinux testsuite. This patch makes several logical sets of alteration: (1) execve(). This now prepares and commits credentials in various places in the security code rather than altering the current creds directly. (2) Temporary credential overrides. do_coredump() and sys_faccessat() now prepare their own credentials and temporarily override the ones currently on the acting thread, whilst preventing interference from other threads by holding cred_replace_mutex on the thread being dumped. This will be replaced in a future patch by something that hands down the credentials directly to the functions being called, rather than altering the task's objective credentials. (3) LSM interface. A number of functions have been changed, added or removed: (*) security_capset_check(), ->capset_check() (*) security_capset_set(), ->capset_set() Removed in favour of security_capset(). (*) security_capset(), ->capset() New. This is passed a pointer to the new creds, a pointer to the old creds and the proposed capability sets. It should fill in the new creds or return an error. All pointers, barring the pointer to the new creds, are now const. (*) security_bprm_apply_creds(), ->bprm_apply_creds() Changed; now returns a value, which will cause the process to be killed if it's an error. (*) security_task_alloc(), ->task_alloc_security() Removed in favour of security_prepare_creds(). (*) security_cred_free(), ->cred_free() New. Free security data attached to cred->security. (*) security_prepare_creds(), ->cred_prepare() New. Duplicate any security data attached to cred->security. (*) security_commit_creds(), ->cred_commit() New. Apply any security effects for the upcoming installation of new security by commit_creds(). (*) security_task_post_setuid(), ->task_post_setuid() Removed in favour of security_task_fix_setuid(). (*) security_task_fix_setuid(), ->task_fix_setuid() Fix up the proposed new credentials for setuid(). This is used by cap_set_fix_setuid() to implicitly adjust capabilities in line with setuid() changes. Changes are made to the new credentials, rather than the task itself as in security_task_post_setuid(). (*) security_task_reparent_to_init(), ->task_reparent_to_init() Removed. Instead the task being reparented to init is referred directly to init's credentials. NOTE! This results in the loss of some state: SELinux's osid no longer records the sid of the thread that forked it. (*) security_key_alloc(), ->key_alloc() (*) security_key_permission(), ->key_permission() Changed. These now take cred pointers rather than task pointers to refer to the security context. (4) sys_capset(). This has been simplified and uses less locking. The LSM functions it calls have been merged. (5) reparent_to_kthreadd(). This gives the current thread the same credentials as init by simply using commit_thread() to point that way. (6) __sigqueue_alloc() and switch_uid() __sigqueue_alloc() can't stop the target task from changing its creds beneath it, so this function gets a reference to the currently applicable user_struct which it then passes into the sigqueue struct it returns if successful. switch_uid() is now called from commit_creds(), and possibly should be folded into that. commit_creds() should take care of protecting __sigqueue_alloc(). (7) [sg]et[ug]id() and co and [sg]et_current_groups. The set functions now all use prepare_creds(), commit_creds() and abort_creds() to build and check a new set of credentials before applying it. security_task_set[ug]id() is called inside the prepared section. This guarantees that nothing else will affect the creds until we've finished. The calling of set_dumpable() has been moved into commit_creds(). Much of the functionality of set_user() has been moved into commit_creds(). The get functions all simply access the data directly. (8) security_task_prctl() and cap_task_prctl(). security_task_prctl() has been modified to return -ENOSYS if it doesn't want to handle a function, or otherwise return the return value directly rather than through an argument. Additionally, cap_task_prctl() now prepares a new set of credentials, even if it doesn't end up using it. (9) Keyrings. A number of changes have been made to the keyrings code: (a) switch_uid_keyring(), copy_keys(), exit_keys() and suid_keys() have all been dropped and built in to the credentials functions directly. They may want separating out again later. (b) key_alloc() and search_process_keyrings() now take a cred pointer rather than a task pointer to specify the security context. (c) copy_creds() gives a new thread within the same thread group a new thread keyring if its parent had one, otherwise it discards the thread keyring. (d) The authorisation key now points directly to the credentials to extend the search into rather pointing to the task that carries them. (e) Installing thread, process or session keyrings causes a new set of credentials to be created, even though it's not strictly necessary for process or session keyrings (they're shared). (10) Usermode helper. The usermode helper code now carries a cred struct pointer in its subprocess_info struct instead of a new session keyring pointer. This set of credentials is derived from init_cred and installed on the new process after it has been cloned. call_usermodehelper_setup() allocates the new credentials and call_usermodehelper_freeinfo() discards them if they haven't been used. A special cred function (prepare_usermodeinfo_creds()) is provided specifically for call_usermodehelper_setup() to call. call_usermodehelper_setkeys() adjusts the credentials to sport the supplied keyring as the new session keyring. (11) SELinux. SELinux has a number of changes, in addition to those to support the LSM interface changes mentioned above: (a) selinux_setprocattr() no longer does its check for whether the current ptracer can access processes with the new SID inside the lock that covers getting the ptracer's SID. Whilst this lock ensures that the check is done with the ptracer pinned, the result is only valid until the lock is released, so there's no point doing it inside the lock. (12) is_single_threaded(). This function has been extracted from selinux_setprocattr() and put into a file of its own in the lib/ directory as join_session_keyring() now wants to use it too. The code in SELinux just checked to see whether a task shared mm_structs with other tasks (CLONE_VM), but that isn't good enough. We really want to know if they're part of the same thread group (CLONE_THREAD). (13) nfsd. The NFS server daemon now has to use the COW credentials to set the credentials it is going to use. It really needs to pass the credentials down to the functions it calls, but it can't do that until other patches in this series have been applied. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Use RCU to access another task's creds and to release a task's own credsDavid Howells
Use RCU to access another task's creds and to release a task's own creds. This means that it will be possible for the credentials of a task to be replaced without another task (a) requiring a full lock to read them, and (b) seeing deallocated memory. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap current->cred and a few other accessorsDavid Howells
Wrap current->cred and a few other accessors to hide their actual implementation. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap task credential accesses in the core kernelDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: linux-audit@redhat.com Cc: containers@lists.linux-foundation.org Cc: linux-mm@kvack.org Signed-off-by: James Morris <jmorris@namei.org>
2008-10-22Merge branch 'timers/range-hrtimers' into v28-range-hrtimers-for-linus-v2Thomas Gleixner
Conflicts: kernel/time/tick-sched.c Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-10-20Merge branches 'timers/clocksource', 'timers/hrtimers', 'timers/nohz', ↵Thomas Gleixner
'timers/ntp', 'timers/posixtimers' and 'timers/debug' into v28-timers-for-linus
2008-10-17Merge commit 'linus/master' into merge-linusArjan van de Ven
Conflicts: arch/x86/kvm/i8254.c
2008-10-16kernel/sys.c: improve code generationAndrew Morton
utsname() is quite expensive to calculate. Cache it in a local. text data bss dec hex filename before: 11136 720 16 11872 2e60 kernel/sys.o after: 11096 720 16 11832 2e38 kernel/sys.o Acked-by: Vegard Nossum <vegard.nossum@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: "Serge E. Hallyn" <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16utsname: completely overwrite prior informationVegard Nossum
On sethostname() and setdomainname(), previous information may be retained if it was longer than than the new hostname/domainname. This can be demonstrated trivially by calling sethostname() first with a long name, then with a short name, and then calling uname() to retrieve the full buffer that contains the hostname (and possibly parts of the old hostname), one just has to look past the terminating zero. I don't know if we should really care that much (hence the RFC); the only scenarios I can possibly think of is administrator putting something sensitive in the hostname (or domain name) by accident, and changing it back will not undo the mistake entirely, though it's not like we can recover gracefully from "rm -rf /" either... The other scenario is namespaces (CLONE_NEWUTS) where some information may be unintentionally "inherited" from the previous namespace (a program wants to hide the original name and does clone + sethostname, but some information is still left). I think the patch may be defended on grounds of the principle of least surprise. But I am not adamant :-) (I guess the question now is whether userspace should be able to write embedded NULs into the buffer or not...) At least the observation has been made and the patch has been presented. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "Serge E. Hallyn" <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16rlimit: permit setting RLIMIT_NOFILE to RLIM_INFINITYAdam Tkac
When a process wants to set the limit of open files to RLIM_INFINITY it gets EPERM even if it has CAP_SYS_RESOURCE capability. For example, BIND does: ... #elif defined(NR_OPEN) && defined(__linux__) /* * Some Linux kernels don't accept RLIM_INFINIT; the maximum * possible value is the NR_OPEN defined in linux/fs.h. */ if (resource == isc_resource_openfiles && rlim_value == RLIM_INFINITY) { rl.rlim_cur = rl.rlim_max = NR_OPEN; unixresult = setrlimit(unixresource, &rl); if (unixresult == 0) return (ISC_R_SUCCESS); } #elif ... If we allow setting RLIMIT_NOFILE to RLIM_INFINITY we increase portability - you don't have to check if OS is linux and then use different schema for limits. The spec says "Specifying RLIM_INFINITY as any resource limit value on a successful call to setrlimit() shall inhibit enforcement of that resource limit." and we're presently not doing that. Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13tty: Add a kref countAlan Cox
Introduce a kref to the tty structure and use it to protect the tty->signal tty references. For now we don't introduce it for anything else. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-14timers: fix itimer/many thread hangFrank Mayhar
Overview This patch reworks the handling of POSIX CPU timers, including the ITIMER_PROF, ITIMER_VIRT timers and rlimit handling. It was put together with the help of Roland McGrath, the owner and original writer of this code. The problem we ran into, and the reason for this rework, has to do with using a profiling timer in a process with a large number of threads. It appears that the performance of the old implementation of run_posix_cpu_timers() was at least O(n*3) (where "n" is the number of threads in a process) or worse. Everything is fine with an increasing number of threads until the time taken for that routine to run becomes the same as or greater than the tick time, at which point things degrade rather quickly. This patch fixes bug 9906, "Weird hang with NPTL and SIGPROF." Code Changes This rework corrects the implementation of run_posix_cpu_timers() to make it run in constant time for a particular machine. (Performance may vary between one machine and another depending upon whether the kernel is built as single- or multiprocessor and, in the latter case, depending upon the number of running processors.) To do this, at each tick we now update fields in signal_struct as well as task_struct. The run_posix_cpu_timers() function uses those fields to make its decisions. We define a new structure, "task_cputime," to contain user, system and scheduler times and use these in appropriate places: struct task_cputime { cputime_t utime; cputime_t stime; unsigned long long sum_exec_runtime; }; This is included in the structure "thread_group_cputime," which is a new substructure of signal_struct and which varies for uniprocessor versus multiprocessor kernels. For uniprocessor kernels, it uses "task_cputime" as a simple substructure, while for multiprocessor kernels it is a pointer: struct thread_group_cputime { struct task_cputime totals; }; struct thread_group_cputime { struct task_cputime *totals; }; We also add a new task_cputime substructure directly to signal_struct, to cache the earliest expiration of process-wide timers, and task_cputime also replaces the it_*_expires fields of task_struct (used for earliest expiration of thread timers). The "thread_group_cputime" structure contains process-wide timers that are updated via account_user_time() and friends. In the non-SMP case the structure is a simple aggregator; unfortunately in the SMP case that simplicity was not achievable due to cache-line contention between CPUs (in one measured case performance was actually _worse_ on a 16-cpu system than the same test on a 4-cpu system, due to this contention). For SMP, the thread_group_cputime counters are maintained as a per-cpu structure allocated using alloc_percpu(). The timer functions update only the timer field in the structure corresponding to the running CPU, obtained using per_cpu_ptr(). We define a set of inline functions in sched.h that we use to maintain the thread_group_cputime structure and hide the differences between UP and SMP implementations from the rest of the kernel. The thread_group_cputime_init() function initializes the thread_group_cputime structure for the given task. The thread_group_cputime_alloc() is a no-op for UP; for SMP it calls the out-of-line function thread_group_cputime_alloc_smp() to allocate and fill in the per-cpu structures and fields. The thread_group_cputime_free() function, also a no-op for UP, in SMP frees the per-cpu structures. The thread_group_cputime_clone_thread() function (also a UP no-op) for SMP calls thread_group_cputime_alloc() if the per-cpu structures haven't yet been allocated. The thread_group_cputime() function fills the task_cputime structure it is passed with the contents of the thread_group_cputime fields; in UP it's that simple but in SMP it must also safely check that tsk->signal is non-NULL (if it is it just uses the appropriate fields of task_struct) and, if so, sums the per-cpu values for each online CPU. Finally, the three functions account_group_user_time(), account_group_system_time() and account_group_exec_runtime() are used by timer functions to update the respective fields of the thread_group_cputime structure. Non-SMP operation is trivial and will not be mentioned further. The per-cpu structure is always allocated when a task creates its first new thread, via a call to thread_group_cputime_clone_thread() from copy_signal(). It is freed at process exit via a call to thread_group_cputime_free() from cleanup_signal(). All functions that formerly summed utime/stime/sum_sched_runtime values from from all threads in the thread group now use thread_group_cputime() to snapshot the values in the thread_group_cputime structure or the values in the task structure itself if the per-cpu structure hasn't been allocated. Finally, the code in kernel/posix-cpu-timers.c has changed quite a bit. The run_posix_cpu_timers() function has been split into a fast path and a slow path; the former safely checks whether there are any expired thread timers and, if not, just returns, while the slow path does the heavy lifting. With the dedicated thread group fields, timers are no longer "rebalanced" and the process_timer_rebalance() function and related code has gone away. All summing loops are gone and all code that used them now uses the thread_group_cputime() inline. When process-wide timers are set, the new task_cputime structure in signal_struct is used to cache the earliest expiration; this is checked in the fast path. Performance The fix appears not to add significant overhead to existing operations. It generally performs the same as the current code except in two cases, one in which it performs slightly worse (Case 5 below) and one in which it performs very significantly better (Case 2 below). Overall it's a wash except in those two cases. I've since done somewhat more involved testing on a dual-core Opteron system. Case 1: With no itimer running, for a test with 100,000 threads, the fixed kernel took 1428.5 seconds, 513 seconds more than the unfixed system, all of which was spent in the system. There were twice as many voluntary context switches with the fix as without it. Case 2: With an itimer running at .01 second ticks and 4000 threads (the most an unmodified kernel can handle), the fixed kernel ran the test in eight percent of the time (5.8 seconds as opposed to 70 seconds) and had better tick accuracy (.012 seconds per tick as opposed to .023 seconds per tick). Case 3: A 4000-thread test with an initial timer tick of .01 second and an interval of 10,000 seconds (i.e. a timer that ticks only once) had very nearly the same performance in both cases: 6.3 seconds elapsed for the fixed kernel versus 5.5 seconds for the unfixed kernel. With fewer threads (eight in these tests), the Case 1 test ran in essentially the same time on both the modified and unmodified kernels (5.2 seconds versus 5.8 seconds). The Case 2 test ran in about the same time as well, 5.9 seconds versus 5.4 seconds but again with much better tick accuracy, .013 seconds per tick versus .025 seconds per tick for the unmodified kernel. Since the fix affected the rlimit code, I also tested soft and hard CPU limits. Case 4: With a hard CPU limit of 20 seconds and eight threads (and an itimer running), the modified kernel was very slightly favored in that while it killed the process in 19.997 seconds of CPU time (5.002 seconds of wall time), only .003 seconds of that was system time, the rest was user time. The unmodified kernel killed the process in 20.001 seconds of CPU (5.014 seconds of wall time) of which .016 seconds was system time. Really, though, the results were too close to call. The results were essentially the same with no itimer running. Case 5: With a soft limit of 20 seconds and a hard limit of 2000 seconds (where the hard limit would never be reached) and an itimer running, the modified kernel exhibited worse tick accuracy than the unmodified kernel: .050 seconds/tick versus .028 seconds/tick. Otherwise, performance was almost indistinguishable. With no itimer running this test exhibited virtually identical behavior and times in both cases. In times past I did some limited performance testing. those results are below. On a four-cpu Opteron system without this fix, a sixteen-thread test executed in 3569.991 seconds, of which user was 3568.435s and system was 1.556s. On the same system with the fix, user and elapsed time were about the same, but system time dropped to 0.007 seconds. Performance with eight, four and one thread were comparable. Interestingly, the timer ticks with the fix seemed more accurate: The sixteen-thread test with the fix received 149543 ticks for 0.024 seconds per tick, while the same test without the fix received 58720 for 0.061 seconds per tick. Both cases were configured for an interval of 0.01 seconds. Again, the other tests were comparable. Each thread in this test computed the primes up to 25,000,000. I also did a test with a large number of threads, 100,000 threads, which is impossible without the fix. In this case each thread computed the primes only up to 10,000 (to make the runtime manageable). System time dominated, at 1546.968 seconds out of a total 2176.906 seconds (giving a user time of 629.938s). It received 147651 ticks for 0.015 seconds per tick, still quite accurate. There is obviously no comparable test without the fix. Signed-off-by: Frank Mayhar <fmayhar@google.com> Cc: Roland McGrath <roland@redhat.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-09-05hrtimer: create a "timer_slack" field in the task structArjan van de Ven
We want to be able to control the default "rounding" that is used by select() and poll() and friends. This is a per process property (so that we can have a "nice" like program to start certain programs with a looser or stricter rounding) that can be set/get via a prctl(). For this purpose, a field called "timer_slack_ns" is added to the task struct. In addition, a field called "default_timer_slack"ns" is added so that tasks easily can temporarily to a more/less accurate slack and then back to the default. The default value of the slack is set to 50 usec; this is significantly less than 2.6.27's average select() and poll() timing error but still allows the kernel to group timers somewhat to preserve power behavior. Applications and admins can override this via the prctl() Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2008-08-20fix setpriority(PRIO_PGRP) thread iterator breakageKen Chen
When user calls sys_setpriority(PRIO_PGRP ...) on a NPTL style multi-LWP process, only the task leader of the process is affected, all other sibling LWP threads didn't receive the setting. The problem was that the iterator used in sys_setpriority() only iteartes over one task for each process, ignoring all other sibling thread. Introduce a new macro do_each_pid_thread / while_each_pid_thread to walk each thread of a process. Convert 4 call sites in {set/get}priority and ioprio_{set/get}. Signed-off-by: Ken Chen <kenchen@google.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-15kexec jump: remove duplication of kexec_restart_prepare()Huang Ying
Call kernel_restart_prepare() in kernel_kexec() instead of duplicating the code. Signed-off-by: Huang Ying <ying.huang@intel.com> Acked-by: Pavel Machek <pavel@suse.cz> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26kexec jumpHuang Ying
This patch provides an enhancement to kexec/kdump. It implements the following features: - Backup/restore memory used by the original kernel before/after kexec. - Save/restore CPU state before/after kexec. The features of this patch can be used as a general method to call program in physical mode (paging turning off). This can be used to call BIOS code under Linux. kexec-tools needs to be patched to support kexec jump. The patches and the precompiled kexec can be download from the following URL: source: http://khibernation.sourceforge.net/download/release_v10/kexec-tools/kexec-tools-src_git_kh10.tar.bz2 patches: http://khibernation.sourceforge.net/download/release_v10/kexec-tools/kexec-tools-patches_git_kh10.tar.bz2 binary: http://khibernation.sourceforge.net/download/release_v10/kexec-tools/kexec_git_kh10 Usage example of calling some physical mode code and return: 1. Compile and install patched kernel with following options selected: CONFIG_X86_32=y CONFIG_KEXEC=y CONFIG_PM=y CONFIG_KEXEC_JUMP=y 2. Build patched kexec-tool or download the pre-built one. 3. Build some physical mode executable named such as "phy_mode" 4. Boot kernel compiled in step 1. 5. Load physical mode executable with /sbin/kexec. The shell command line can be as follow: /sbin/kexec --load-preserve-context --args-none phy_mode 6. Call physical mode executable with following shell command line: /sbin/kexec -e Implementation point: To support jumping without reserving memory. One shadow backup page (source page) is allocated for each page used by kexeced code image (destination page). When do kexec_load, the image of kexeced code is loaded into source pages, and before executing, the destination pages and the source pages are swapped, so the contents of destination pages are backupped. Before jumping to the kexeced code image and after jumping back to the original kernel, the destination pages and the source pages are swapped too. C ABI (calling convention) is used as communication protocol between kernel and called code. A flag named KEXEC_PRESERVE_CONTEXT for sys_kexec_load is added to indicate that the loaded kernel image is used for jumping back. Now, only the i386 architecture is supported. Signed-off-by: Huang Ying <ying.huang@intel.com> Acked-by: Vivek Goyal <vgoyal@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25unexport uts_semAdrian Bunk
With the removal of the Solaris binary emulation the export of uts_sem became unused. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25call_usermodehelper(): increase reliabilityKOSAKI Motohiro
Presently call_usermodehelper_setup() uses GFP_ATOMIC. but it can return NULL _very_ easily. GFP_ATOMIC is needed only when we can't sleep. and, GFP_KERNEL is robust and better. thus, I add gfp_mask argument to call_usermodehelper_setup(). So, its callers pass the gfp_t as below: call_usermodehelper() and call_usermodehelper_keys(): depend on 'wait' argument. call_usermodehelper_pipe(): always GFP_KERNEL because always run under process context. orderly_poweroff(): pass to GFP_ATOMIC because may run under interrupt context. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: "Paul Menage" <menage@google.com> Reviewed-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-24sys_prctl(): fix return of uninitialized valueShi Weihua
If none of the switch cases match, the PR_SET_PDEATHSIG and PR_SET_DUMPABLE cases of the switch statement will never write to local variable `error'. Signed-off-by: Shi Weihua <shiwh@cn.fujitsu.com> Cc: Andrew G. Morgan <morgan@kernel.org> Acked-by: "Serge E. Hallyn" <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30pids: sys_getpgid: fix unsafe *pid usage, s/tasklist/rcu/Oleg Nesterov
1. sys_getpgid() needs rcu_read_lock() to derive the pgrp _nr, even if the task is current, otherwise we can race with another thread which does sys_setpgid(). 2. Use rcu_read_lock() instead of tasklist_lock when pid != 0, make sure that we don't use the NULL pid if the task exits right after successful find_task_by_vpid(). Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30pids: sys_getsid: fix unsafe *pid usage, fix possible 0 instead of -ESRCHOleg Nesterov
1. sys_getsid() needs rcu_read_lock() to derive the session _nr, even if the task is current, otherwise we can race with another thread which does sys_setsid(). 2. The task can exit between find_task_by_vpid() and task_session_vnr(), in that unlikely case sys_getsid() returns 0 instead of -ESRCH. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30pids: sys_setpgid: use change_pid() helperOleg Nesterov
Use change_pid() instead of detach_pid() + attach_pid() in sys_setpgid(). This way task_pgrp() is not NULL in between. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-30k_getrusage: don't take rcu_read_lock()Oleg Nesterov
Just a trivial example, more to come. k_getrusage() holds rcu_read_lock() because it was previously required by lock_task_sighand(). Unneeded now. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29add RUSAGE_THREADSripathi Kodi
Add the RUSAGE_THREAD option for the getrusage system call. This is essentially Roland's patch from http://lkml.org/lkml/2008/1/18/589, but the line about RUSAGE_LWP line has been removed, as suggested by Ulrich and Christoph. Signed-off-by: Roland McGrath <roland@redhat.com> Signed-off-by: Sripathi Kodi <sripathik@in.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28capabilities: implement per-process securebitsAndrew G. Morgan
Filesystem capability support makes it possible to do away with (set)uid-0 based privilege and use capabilities instead. That is, with filesystem support for capabilities but without this present patch, it is (conceptually) possible to manage a system with capabilities alone and never need to obtain privilege via (set)uid-0. Of course, conceptually isn't quite the same as currently possible since few user applications, certainly not enough to run a viable system, are currently prepared to leverage capabilities to exercise privilege. Further, many applications exist that may never get upgraded in this way, and the kernel will continue to want to support their setuid-0 base privilege needs. Where pure-capability applications evolve and replace setuid-0 binaries, it is desirable that there be a mechanisms by which they can contain their privilege. In addition to leveraging the per-process bounding and inheritable sets, this should include suppressing the privilege of the uid-0 superuser from the process' tree of children. The feature added by this patch can be leveraged to suppress the privilege associated with (set)uid-0. This suppression requires CAP_SETPCAP to initiate, and only immediately affects the 'current' process (it is inherited through fork()/exec()). This reimplementation differs significantly from the historical support for securebits which was system-wide, unwieldy and which has ultimately withered to a dead relic in the source of the modern kernel. With this patch applied a process, that is capable(CAP_SETPCAP), can now drop all legacy privilege (through uid=0) for itself and all subsequently fork()'d/exec()'d children with: prctl(PR_SET_SECUREBITS, 0x2f); This patch represents a no-op unless CONFIG_SECURITY_FILE_CAPABILITIES is enabled at configure time. [akpm@linux-foundation.org: fix uninitialised var warning] [serue@us.ibm.com: capabilities: use cap_task_prctl when !CONFIG_SECURITY] Signed-off-by: Andrew G. Morgan <morgan@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Reviewed-by: James Morris <jmorris@namei.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Paul Moore <paul.moore@hp.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-19generic, x86: add prctl commands PR_GET_TSC and PR_SET_TSCErik Bosman
This patch adds prctl commands that make it possible to deny the execution of timestamp counters in userspace. If this is not implemented on a specific architecture, prctl will return -EINVAL. ned-off-by: Erik Bosman <ejbosman@cs.vu.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-08Pidns: make full use of xxx_vnr() callsPavel Emelyanov
Some time ago the xxx_vnr() calls (e.g. pid_vnr or find_task_by_vpid) were _all_ converted to operate on the current pid namespace. After this each call like xxx_nr_ns(foo, current->nsproxy->pid_ns) is nothing but a xxx_vnr(foo) one. Switch all the xxx_nr_ns() callers to use the xxx_vnr() calls where appropriate. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Reviewed-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08sys_getsid: don't use ->nsproxy directlyOleg Nesterov
With the new semantics of find_vpid() we don't need to play with ->nsproxy explicitely, _vxx() do the right things. Also s/tasklist/rcu/. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08sys_setsid: remove now unneeded session != 1 checkOleg Nesterov
Eric's "fix clone(CLONE_NEWPID)" eliminated the last reason for this hack. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Roland McGrath <roland@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
