path: root/kernel/sys_ni.c
2006-02-20[PATCH] Fix compile for CONFIG_SYSVIPC=n or CONFIG_SYSCTL=nStephen Rothwell
The compat syscalls are added to sys_ni.c since they are not defined if the above CONFIG options are off. Also, nfs would not build with CONFIG_SYSCTL off. Noticed by Arthur Othieno. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: "David S. Miller" <davem@davemloft.net> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc-mergeLinus Torvalds
2006-01-08[PATCH] Make vm86 support optionalMatt Mackall
This adds an option to remove vm86 support under CONFIG_EMBEDDED. Saves about 5k. This version eliminates most of the #ifdefs of the previous version and instead uses function stubs in vm86.h. Also, release_vm86_irqs is moved from asm-i386/irq.h to a more appropriate home in vm86.h so that the stubs can live together. $ size vmlinux-baseline vmlinux-novm86 text data bss dec hex filename 2920821 523232 190652 3634705 377611 vmlinux-baseline 2916268 523100 190492 3629860 376324 vmlinux-novm86 Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] tiny: Make *[ug]id16 support optionalMatt Mackall
Configurable 16-bit UID and friends support This allows turning off the legacy 16 bit UID interfaces on embedded platforms. text data bss dec hex filename 3330172 529036 190556 4049764 3dcb64 vmlinux-baseline 3328268 529040 190556 4047864 3dc3f8 vmlinux From: Adrian Bunk <bunk@stusta.de> UID16 was accidentially disabled for !EMBEDDED. Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Swap Migration V5: sys_migrate_pages interfaceChristoph Lameter
sys_migrate_pages implementation using swap based page migration This is the original API proposed by Ray Bryant in his posts during the first half of 2005 on linux-mm@kvack.org and linux-kernel@vger.kernel.org. The intent of sys_migrate is to migrate memory of a process. A process may have migrated to another node. Memory was allocated optimally for the prior context. sys_migrate_pages allows to shift the memory to the new node. sys_migrate_pages is also useful if the processes available memory nodes have changed through cpuset operations to manually move the processes memory. Paul Jackson is working on an automated mechanism that will allow an automatic migration if the cpuset of a process is changed. However, a user may decide to manually control the migration. This implementation is put into the policy layer since it uses concepts and functions that are also needed for mbind and friends. The patch also provides a do_migrate_pages function that may be useful for cpusets to automatically move memory. sys_migrate_pages does not modify policies in contrast to Ray's implementation. The current code here is based on the swap based page migration capability and thus is not able to preserve the physical layout relative to it containing nodeset (which may be a cpuset). When direct page migration becomes available then the implementation needs to be changed to do a isomorphic move of pages between different nodesets. The current implementation simply evicts all pages in source nodeset that are not in the target nodeset. Patch supports ia64, i386 and x86_64. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] spufs: The SPU file system, baseArnd Bergmann
This is the current version of the spu file system, used for driving SPEs on the Cell Broadband Engine. This release is almost identical to the version for the 2.6.14 kernel posted earlier, which is available as part of the Cell BE Linux distribution from http://www.bsc.es/projects/deepcomputing/linuxoncell/. The first patch provides all the interfaces for running spu application, but does not have any support for debugging SPU tasks or for scheduling. Both these functionalities are added in the subsequent patches. See Documentation/filesystems/spufs.txt on how to use spufs. Signed-off-by: Arnd Bergmann <arndb@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-08-01[PATCH] remove sys_set_zone_reclaim()Ingo Molnar
This removes sys_set_zone_reclaim() for now. While i'm sure Martin is trying to solve a real problem, we must not hard-code an incomplete and insufficient approach into a syscall, because syscalls are pretty much for eternity. I am quite strongly convinced that this syscall must not hit v2.6.13 in its current form. Firstly, the syscall lacks basic syscall design: e.g. it allows the global setting of VM policy for unprivileged users. (!) [ Imagine an Oracle installation and a SAP installation on the same NUMA box fighting over the 'optimal' setting for this flag. What will they do? Will they try to set the flag to their own preferred value every second or so? ] Secondly, it was added based on a single datapoint from Martin: http://marc.theaimsgroup.com/?l=linux-mm&m=111763597218177&w=2 where Martin characterizes the numbers the following way: ' Run-to-run variability for "make -j" is huge, so these numbers aren't terribly useful except to see that with reclaim the benchmark still finishes in a reasonable amount of time. ' in other words: the fundamental problem has likely not been solved, only a tendential move into the right direction has been observed, and a handful of numbers were picked out of a set of hugely variable results, without showing the variability data. How much variance is there run-to-run? I'd really suggest to first walk the walk and see what's needed to get stable & predictable kernel compilation numbers on that NUMA box, before adding random syscalls to tune a particular aspect of the VM ... which approach might not even matter once the whole picture has been analyzed and understood! The third, most important point is that the syscall exposes VM tuning internals in a completely unstructured way. What sense does it make to have a _GLOBAL_ per-node setting for 'should we go to another node for reclaim'? If then it might make sense to do this per-app, via numalib or so. The change is minimalistic in that it doesnt remove the syscall and the underlying infrastructure changes, only the user-visible changes. We could perhaps add a CAP_SYS_ADMIN-only sysctl for this hack, a'ka /proc/sys/vm/swappiness, but even that looks quite counterproductive when the generic approach is that we are trying to reduce the number of external factors in the VM balance picture. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] inotifyRobert Love
inotify is intended to correct the deficiencies of dnotify, particularly its inability to scale and its terrible user interface: * dnotify requires the opening of one fd per each directory that you intend to watch. This quickly results in too many open files and pins removable media, preventing unmount. * dnotify is directory-based. You only learn about changes to directories. Sure, a change to a file in a directory affects the directory, but you are then forced to keep a cache of stat structures. * dnotify's interface to user-space is awful. Signals? inotify provides a more usable, simple, powerful solution to file change notification: * inotify's interface is a system call that returns a fd, not SIGIO. You get a single fd, which is select()-able. * inotify has an event that says "the filesystem that the item you were watching is on was unmounted." * inotify can watch directories or files. Inotify is currently used by Beagle (a desktop search infrastructure), Gamin (a FAM replacement), and other projects. See Documentation/filesystems/inotify.txt. Signed-off-by: Robert Love <rml@novell.com> Cc: John McCutchan <ttb@tentacle.dhs.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kexec: add kexec syscallsEric W. Biederman
This patch introduces the architecture independent implementation the sys_kexec_load, the compat_sys_kexec_load system calls. Kexec on panic support has been integrated into the core patch and is relatively clean. In addition the hopefully architecture independent option crashkernel=size@location has been docuemented. It's purpose is to reserve space for the panic kernel to live, and where no DMA transfer will ever be setup to access. Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Alexander Nyberg <alexn@telia.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] VM: early zone reclaimMartin Hicks
This is the core of the (much simplified) early reclaim. The goal of this patch is to reclaim some easily-freed pages from a zone before falling back onto another zone. One of the major uses of this is NUMA machines. With the default allocator behavior the allocator would look for memory in another zone, which might be off-node, before trying to reclaim from the current zone. This adds a zone tuneable to enable early zone reclaim. It is selected on a per-zone basis and is turned on/off via syscall. Adding some extra throttling on the reclaim was also required (patch 4/4). Without the machine would grind to a crawl when doing a "make -j" kernel build. Even with this patch the System Time is higher on average, but it seems tolerable. Here are some numbers for kernbench runs on a 2-node, 4cpu, 8Gig RAM Altix in the "make -j" run: wall user sys %cpu ctx sw. sleeps ---- ---- --- ---- ------ ------ No patch 1009 1384 847 258 298170 504402 w/patch, no reclaim 880 1376 667 288 254064 396745 w/patch & reclaim 1079 1385 926 252 291625 548873 These numbers are the average of 2 runs of 3 "make -j" runs done right after system boot. Run-to-run variability for "make -j" is huge, so these numbers aren't terribly useful except to seee that with reclaim the benchmark still finishes in a reasonable amount of time. I also looked at the NUMA hit/miss stats for the "make -j" runs and the reclaim doesn't make any difference when the machine is thrashing away. Doing a "make -j8" on a single node that is filled with page cache pages takes 700 seconds with reclaim turned on and 735 seconds without reclaim (due to remote memory accesses). The simple zone_reclaim syscall program is at http://www.bork.org/~mort/sgi/zone_reclaim.c Signed-off-by: Martin Hicks <mort@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] consolidate sys_shmatStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
