path: root/kernel/sysctl.c
2013-04-29mm: replace hardcoded 3% with admin_reserve_pages knobAndrew Shewmaker
Add an admin_reserve_kbytes knob to allow admins to change the hardcoded memory reserve to something other than 3%, which may be multiple gigabytes on large memory systems. Only about 8MB is necessary to enable recovery in the default mode, and only a few hundred MB are required even when overcommit is disabled. This affects OVERCOMMIT_GUESS and OVERCOMMIT_NEVER. admin_reserve_kbytes is initialized to min(3% free pages, 8MB) I arrived at 8MB by summing the RSS of sshd or login, bash, and top. Please see first patch in this series for full background, motivation, testing, and full changelog. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: make init_admin_reserve() static] Signed-off-by: Andrew Shewmaker <agshew@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29mm: limit growth of 3% hardcoded other user reserveAndrew Shewmaker
Add user_reserve_kbytes knob. Limit the growth of the memory reserved for other user processes to min(3% current process size, user_reserve_pages). Only about 8MB is necessary to enable recovery in the default mode, and only a few hundred MB are required even when overcommit is disabled. user_reserve_pages defaults to min(3% free pages, 128MB) I arrived at 128MB by taking the max VSZ of sshd, login, bash, and top ... then adding the RSS of each. This only affects OVERCOMMIT_NEVER mode. Background 1. user reserve __vm_enough_memory reserves a hardcoded 3% of the current process size for other applications when overcommit is disabled. This was done so that a user could recover if they launched a memory hogging process. Without the reserve, a user would easily run into a message such as: bash: fork: Cannot allocate memory 2. admin reserve Additionally, a hardcoded 3% of free memory is reserved for root in both overcommit 'guess' and 'never' modes. This was intended to prevent a scenario where root-cant-log-in and perform recovery operations. Note that this reserve shrinks, and doesn't guarantee a useful reserve. Motivation The two hardcoded memory reserves should be updated to account for current memory sizes. Also, the admin reserve would be more useful if it didn't shrink too much. When the current code was originally written, 1GB was considered "enterprise". Now the 3% reserve can grow to multiple GB on large memory systems, and it only needs to be a few hundred MB at most to enable a user or admin to recover a system with an unwanted memory hogging process. I've found that reducing these reserves is especially beneficial for a specific type of application load: * single application system * one or few processes (e.g. one per core) * allocating all available memory * not initializing every page immediately * long running I've run scientific clusters with this sort of load. A long running job sometimes failed many hours (weeks of CPU time) into a calculation. They weren't initializing all of their memory immediately, and they weren't using calloc, so I put systems into overcommit 'never' mode. These clusters run diskless and have no swap. However, with the current reserves, a user wishing to allocate as much memory as possible to one process may be prevented from using, for example, almost 2GB out of 32GB. The effect is less, but still significant when a user starts a job with one process per core. I have repeatedly seen a set of processes requesting the same amount of memory fail because one of them could not allocate the amount of memory a user would expect to be able to allocate. For example, Message Passing Interfce (MPI) processes, one per core. And it is similar for other parallel programming frameworks. Changing this reserve code will make the overcommit never mode more useful by allowing applications to allocate nearly all of the available memory. Also, the new admin_reserve_kbytes will be safer than the current behavior since the hardcoded 3% of available memory reserve can shrink to something useless in the case where applications have grabbed all available memory. Risks * "bash: fork: Cannot allocate memory" The downside of the first patch-- which creates a tunable user reserve that is only used in overcommit 'never' mode--is that an admin can set it so low that a user may not be able to kill their process, even if they already have a shell prompt. Of course, a user can get in the same predicament with the current 3% reserve--they just have to launch processes until 3% becomes negligible. * root-cant-log-in problem The second patch, adding the tunable rootuser_reserve_pages, allows the admin to shoot themselves in the foot by setting it too small. They can easily get the system into a state where root-can't-log-in. However, the new admin_reserve_kbytes will be safer than the current behavior since the hardcoded 3% of available memory reserve can shrink to something useless in the case where applications have grabbed all available memory. Alternatives * Memory cgroups provide a more flexible way to limit application memory. Not everyone wants to set up cgroups or deal with their overhead. * We could create a fourth overcommit mode which provides smaller reserves. The size of useful reserves may be drastically different depending on the whether the system is embedded or enterprise. * Force users to initialize all of their memory or use calloc. Some users don't want/expect the system to overcommit when they malloc. Overcommit 'never' mode is for this scenario, and it should work well. The new user and admin reserve tunables are simple to use, with low overhead compared to cgroups. The patches preserve current behavior where 3% of memory is less than 128MB, except that the admin reserve doesn't shrink to an unusable size under pressure. The code allows admins to tune for embedded and enterprise usage. FAQ * How is the root-cant-login problem addressed? What happens if admin_reserve_pages is set to 0? Root is free to shoot themselves in the foot by setting admin_reserve_kbytes too low. On x86_64, the minimum useful reserve is: 8MB for overcommit 'guess' 128MB for overcommit 'never' admin_reserve_pages defaults to min(3% free memory, 8MB) So, anyone switching to 'never' mode needs to adjust admin_reserve_pages. * How do you calculate a minimum useful reserve? A user or the admin needs enough memory to login and perform recovery operations, which includes, at a minimum: sshd or login + bash (or some other shell) + top (or ps, kill, etc.) For overcommit 'guess', we can sum resident set sizes (RSS) because we only need enough memory to handle what the recovery programs will typically use. On x86_64 this is about 8MB. For overcommit 'never', we can take the max of their virtual sizes (VSZ) and add the sum of their RSS. We use VSZ instead of RSS because mode forces us to ensure we can fulfill all of the requested memory allocations-- even if the programs only use a fraction of what they ask for. On x86_64 this is about 128MB. When swap is enabled, reserves are useful even when they are as small as 10MB, regardless of overcommit mode. When both swap and overcommit are disabled, then the admin should tune the reserves higher to be absolutley safe. Over 230MB each was safest in my testing. * What happens if user_reserve_pages is set to 0? Note, this only affects overcomitt 'never' mode. Then a user will be able to allocate all available memory minus admin_reserve_kbytes. However, they will easily see a message such as: "bash: fork: Cannot allocate memory" And they won't be able to recover/kill their application. The admin should be able to recover the system if admin_reserve_kbytes is set appropriately. * What's the difference between overcommit 'guess' and 'never'? "Guess" allows an allocation if there are enough free + reclaimable pages. It has a hardcoded 3% of free pages reserved for root. "Never" allows an allocation if there is enough swap + a configurable percentage (default is 50) of physical RAM. It has a hardcoded 3% of free pages reserved for root, like "Guess" mode. It also has a hardcoded 3% of the current process size reserved for additional applications. * Why is overcommit 'guess' not suitable even when an app eventually writes to every page? It takes free pages, file pages, available swap pages, reclaimable slab pages into consideration. In other words, these are all pages available, then why isn't overcommit suitable? Because it only looks at the present state of the system. It does not take into account the memory that other applications have malloced, but haven't initialized yet. It overcommits the system. Test Summary There was little change in behavior in the default overcommit 'guess' mode with swap enabled before and after the patch. This was expected. Systems run most predictably (i.e. no oom kills) in overcommit 'never' mode with swap enabled. This also allowed the most memory to be allocated to a user application. Overcommit 'guess' mode without swap is a bad idea. It is easy to crash the system. None of the other tested combinations crashed. This matches my experience on the Roadrunner supercomputer. Without the tunable user reserve, a system in overcommit 'never' mode and without swap does not allow the admin to recover, although the admin can. With the new tunable reserves, a system in overcommit 'never' mode and without swap can be configured to: 1. maximize user-allocatable memory, running close to the edge of recoverability 2. maximize recoverability, sacrificing allocatable memory to ensure that a user cannot take down a system Test Description Fedora 18 VM - 4 x86_64 cores, 5725MB RAM, 4GB Swap System is booted into multiuser console mode, with unnecessary services turned off. Caches were dropped before each test. Hogs are user memtester processes that attempt to allocate all free memory as reported by /proc/meminfo In overcommit 'never' mode, memory_ratio=100 Test Results 3.9.0-rc1-mm1 Overcommit | Swap | Hogs | MB Got/Wanted | OOMs | User Recovery | Admin Recovery ---------- ---- ---- ------------- ---- ------------- -------------- guess yes 1 5432/5432 no yes yes guess yes 4 5444/5444 1 yes yes guess no 1 5302/5449 no yes yes guess no 4 - crash no no never yes 1 5460/5460 1 yes yes never yes 4 5460/5460 1 yes yes never no 1 5218/5432 no no yes never no 4 5203/5448 no no yes 3.9.0-rc1-mm1-tunablereserves User and Admin Recovery show their respective reserves, if applicable. Overcommit | Swap | Hogs | MB Got/Wanted | OOMs | User Recovery | Admin Recovery ---------- ---- ---- ------------- ---- ------------- -------------- guess yes 1 5419/5419 no - yes 8MB yes guess yes 4 5436/5436 1 - yes 8MB yes guess no 1 5440/5440 * - yes 8MB yes guess no 4 - crash - no 8MB no * process would successfully mlock, then the oom killer would pick it never yes 1 5446/5446 no 10MB yes 20MB yes never yes 4 5456/5456 no 10MB yes 20MB yes never no 1 5387/5429 no 128MB no 8MB barely never no 1 5323/5428 no 226MB barely 8MB barely never no 1 5323/5428 no 226MB barely 8MB barely never no 1 5359/5448 no 10MB no 10MB barely never no 1 5323/5428 no 0MB no 10MB barely never no 1 5332/5428 no 0MB no 50MB yes never no 1 5293/5429 no 0MB no 90MB yes never no 1 5001/5427 no 230MB yes 338MB yes never no 4* 4998/5424 no 230MB yes 338MB yes * more memtesters were launched, able to allocate approximately another 100MB Future Work - Test larger memory systems. - Test an embedded image. - Test other architectures. - Time malloc microbenchmarks. - Would it be useful to be able to set overcommit policy for each memory cgroup? - Some lines are slightly above 80 chars. Perhaps define a macro to convert between pages and kb? Other places in the kernel do this. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: make init_user_reserve() static] Signed-off-by: Andrew Shewmaker <agshew@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-29fs: don't compile in drop_caches.c when CONFIG_SYSCTL=nJosh Triplett
drop_caches.c provides code only invokable via sysctl, so don't compile it in when CONFIG_SYSCTL=n. Signed-off-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-02Merge tag 'arc-v3.9-rc1-late' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc Pull new ARC architecture from Vineet Gupta: "Initial ARC Linux port with some fixes on top for 3.9-rc1: I would like to introduce the Linux port to ARC Processors (from Synopsys) for 3.9-rc1. The patch-set has been discussed on the public lists since Nov and has received a fair bit of review, specially from Arnd, tglx, Al and other subsystem maintainers for DeviceTree, kgdb... The arch bits are in arch/arc, some asm-generic changes (acked by Arnd), a minor change to PARISC (acked by Helge). The series is a touch bigger for a new port for 2 main reasons: 1. It enables a basic kernel in first sub-series and adds ptrace/kgdb/.. later 2. Some of the fallout of review (DeviceTree support, multi-platform- image support) were added on top of orig series, primarily to record the revision history. This updated pull request additionally contains - fixes due to our GNU tools catching up with the new syscall/ptrace ABI - some (minor) cross-arch Kconfig updates." * tag 'arc-v3.9-rc1-late' of git://git.kernel.org/pub/scm/linux/kernel/git/vgupta/arc: (82 commits) ARC: split elf.h into uapi and export it for userspace ARC: Fixup the current ABI version ARC: gdbserver using regset interface possibly broken ARC: Kconfig cleanup tracking cross-arch Kconfig pruning in merge window ARC: make a copy of flat DT ARC: [plat-arcfpga] DT arc-uart bindings change: "baud" => "current-speed" ARC: Ensure CONFIG_VIRT_TO_BUS is not enabled ARC: Fix pt_orig_r8 access ARC: [3.9] Fallout of hlist iterator update ARC: 64bit RTSC timestamp hardware issue ARC: Don't fiddle with non-existent caches ARC: Add self to MAINTAINERS ARC: Provide a default serial.h for uart drivers needing BASE_BAUD ARC: [plat-arcfpga] defconfig for fully loaded ARC Linux ARC: [Review] Multi-platform image #8: platform registers SMP callbacks ARC: [Review] Multi-platform image #7: SMP common code to use callbacks ARC: [Review] Multi-platform image #6: cpu-to-dma-addr optional ARC: [Review] Multi-platform image #5: NR_IRQS defined by ARC core ARC: [Review] Multi-platform image #4: Isolate platform headers ARC: [Review] Multi-platform image #3: switch to board callback ...
2013-02-27coredump: remove redundant defines for dumpable statesKees Cook
The existing SUID_DUMP_* defines duplicate the newer SUID_DUMPABLE_* defines introduced in 54b501992dd2 ("coredump: warn about unsafe suid_dumpable / core_pattern combo"). Remove the new ones, and use the prior values instead. Signed-off-by: Kees Cook <keescook@chromium.org> Reported-by: Chen Gang <gang.chen@asianux.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Alan Cox <alan@linux.intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Doug Ledford <dledford@redhat.com> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: James Morris <james.l.morris@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-25Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module update from Rusty Russell: "The sweeping change is to make add_taint() explicitly indicate whether to disable lockdep, but it's a mechanical change." * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: MODSIGN: Add option to not sign modules during modules_install MODSIGN: Add -s <signature> option to sign-file MODSIGN: Specify the hash algorithm on sign-file command line MODSIGN: Simplify Makefile with a Kconfig helper module: clean up load_module a little more. modpost: Ignore ARC specific non-alloc sections module: constify within_module_* taint: add explicit flag to show whether lock dep is still OK. module: printk message when module signature fail taints kernel.
2013-02-23page-writeback.c: subtract min_free_kbytes from dirtyable memoryPaul Szabo
When calculating amount of dirtyable memory, min_free_kbytes should be subtracted because it is not intended for dirty pages. Addresses http://bugs.debian.org/695182 [akpm@linux-foundation.org: fix up min_free_kbytes extern declarations] [akpm@linux-foundation.org: fix min() warning] Signed-off-by: Paul Szabo <psz@maths.usyd.edu.au> Acked-by: Rik van Riel <riel@redhat.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-21Merge tag 'please-pull-misc-3.9' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux Pull misc ia64 bits from Tony Luck. * tag 'please-pull-misc-3.9' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: MAINTAINERS: update SGI & ia64 Altix stuff sysctl: Enable IA64 "ignore-unaligned-usertrap" to be used cross-arch
2013-02-15sysctl: Enable PARISC "unaligned-trap" to be used cross-archVineet Gupta
PARISC defines /proc/sys/kernel/unaligned-trap to runtime toggle unaligned access emulation. The exact mechanics of enablig/disabling are still arch specific, we can make the sysctl usable by other arches. Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Acked-by: Helge Deller <deller@gmx.de> Cc: "James E.J. Bottomley" <jejb@parisc-linux.org> Cc: Helge Deller <deller@gmx.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Serge Hallyn <serge.hallyn@canonical.com>
2013-02-07sched/rt: Add a tuning knob to allow changing SCHED_RR timesliceClark Williams
Add a /proc/sys/kernel scheduler knob named sched_rr_timeslice_ms that allows global changing of the SCHED_RR timeslice value. User visable value is in milliseconds but is stored as jiffies. Setting to 0 (zero) resets to the default (currently 100ms). Signed-off-by: Clark Williams <williams@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/20130207094704.13751796@riff.lan Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-02-07sched: Move sched.h sysctl bits into separate headerClark Williams
Move the sysctl-related bits from include/linux/sched.h into a new file: include/linux/sched/sysctl.h. Then update source files requiring access to those bits by including the new header file. Signed-off-by: Clark Williams <williams@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/20130207094659.06dced96@riff.lan Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-01-21taint: add explicit flag to show whether lock dep is still OK.Rusty Russell
Fix up all callers as they were before, with make one change: an unsigned module taints the kernel, but doesn't turn off lockdep. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2013-01-09sysctl: Enable IA64 "ignore-unaligned-usertrap" to be used cross-archVineet Gupta
IA64 defines /proc/sys/kernel/ignore-unaligned-usertrap to control verbose warnings on unaligned access emulation. Although the exact mechanics of what to do with sysctl (ignore/shout) are arch specific, this change enables the sysctl to be usable cross-arch. Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2012-12-16Merge tag 'balancenuma-v11' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma Pull Automatic NUMA Balancing bare-bones from Mel Gorman: "There are three implementations for NUMA balancing, this tree (balancenuma), numacore which has been developed in tip/master and autonuma which is in aa.git. In almost all respects balancenuma is the dumbest of the three because its main impact is on the VM side with no attempt to be smart about scheduling. In the interest of getting the ball rolling, it would be desirable to see this much merged for 3.8 with the view to building scheduler smarts on top and adapting the VM where required for 3.9. The most recent set of comparisons available from different people are mel: https://lkml.org/lkml/2012/12/9/108 mingo: https://lkml.org/lkml/2012/12/7/331 tglx: https://lkml.org/lkml/2012/12/10/437 srikar: https://lkml.org/lkml/2012/12/10/397 The results are a mixed bag. In my own tests, balancenuma does reasonably well. It's dumb as rocks and does not regress against mainline. On the other hand, Ingo's tests shows that balancenuma is incapable of converging for this workloads driven by perf which is bad but is potentially explained by the lack of scheduler smarts. Thomas' results show balancenuma improves on mainline but falls far short of numacore or autonuma. Srikar's results indicate we all suffer on a large machine with imbalanced node sizes. My own testing showed that recent numacore results have improved dramatically, particularly in the last week but not universally. We've butted heads heavily on system CPU usage and high levels of migration even when it shows that overall performance is better. There are also cases where it regresses. Of interest is that for specjbb in some configurations it will regress for lower numbers of warehouses and show gains for higher numbers which is not reported by the tool by default and sometimes missed in treports. Recently I reported for numacore that the JVM was crashing with NullPointerExceptions but currently it's unclear what the source of this problem is. Initially I thought it was in how numacore batch handles PTEs but I'm no longer think this is the case. It's possible numacore is just able to trigger it due to higher rates of migration. These reports were quite late in the cycle so I/we would like to start with this tree as it contains much of the code we can agree on and has not changed significantly over the last 2-3 weeks." * tag 'balancenuma-v11' of git://git.kernel.org/pub/scm/linux/kernel/git/mel/linux-balancenuma: (50 commits) mm/rmap, migration: Make rmap_walk_anon() and try_to_unmap_anon() more scalable mm/rmap: Convert the struct anon_vma::mutex to an rwsem mm: migrate: Account a transhuge page properly when rate limiting mm: numa: Account for failed allocations and isolations as migration failures mm: numa: Add THP migration for the NUMA working set scanning fault case build fix mm: numa: Add THP migration for the NUMA working set scanning fault case. mm: sched: numa: Delay PTE scanning until a task is scheduled on a new node mm: sched: numa: Control enabling and disabling of NUMA balancing if !SCHED_DEBUG mm: sched: numa: Control enabling and disabling of NUMA balancing mm: sched: Adapt the scanning rate if a NUMA hinting fault does not migrate mm: numa: Use a two-stage filter to restrict pages being migrated for unlikely task<->node relationships mm: numa: migrate: Set last_nid on newly allocated page mm: numa: split_huge_page: Transfer last_nid on tail page mm: numa: Introduce last_nid to the page frame sched: numa: Slowly increase the scanning period as NUMA faults are handled mm: numa: Rate limit setting of pte_numa if node is saturated mm: numa: Rate limit the amount of memory that is migrated between nodes mm: numa: Structures for Migrate On Fault per NUMA migration rate limiting mm: numa: Migrate pages handled during a pmd_numa hinting fault mm: numa: Migrate on reference policy ...
2012-12-11mm: sched: Adapt the scanning rate if a NUMA hinting fault does not migrateMel Gorman
The PTE scanning rate and fault rates are two of the biggest sources of system CPU overhead with automatic NUMA placement. Ideally a proper policy would detect if a workload was properly placed, schedule and adjust the PTE scanning rate accordingly. We do not track the necessary information to do that but we at least know if we migrated or not. This patch scans slower if a page was not migrated as the result of a NUMA hinting fault up to sysctl_numa_balancing_scan_period_max which is now higher than the previous default. Once every minute it will reset the scanner in case of phase changes. This is hilariously crude and the numbers are arbitrary. Workloads will converge quite slowly in comparison to what a proper policy should be able to do. On the plus side, we will chew up less CPU for workloads that have no need for automatic balancing. Signed-off-by: Mel Gorman <mgorman@suse.de>
2012-12-11mm: sched: numa: Implement slow start for working set samplingPeter Zijlstra
Add a 1 second delay before starting to scan the working set of a task and starting to balance it amongst nodes. [ note that before the constant per task WSS sampling rate patch the initial scan would happen much later still, in effect that patch caused this regression. ] The theory is that short-run tasks benefit very little from NUMA placement: they come and go, and they better stick to the node they were started on. As tasks mature and rebalance to other CPUs and nodes, so does their NUMA placement have to change and so does it start to matter more and more. In practice this change fixes an observable kbuild regression: # [ a perf stat --null --repeat 10 test of ten bzImage builds to /dev/shm ] !NUMA: 45.291088843 seconds time elapsed ( +- 0.40% ) 45.154231752 seconds time elapsed ( +- 0.36% ) +NUMA, no slow start: 46.172308123 seconds time elapsed ( +- 0.30% ) 46.343168745 seconds time elapsed ( +- 0.25% ) +NUMA, 1 sec slow start: 45.224189155 seconds time elapsed ( +- 0.25% ) 45.160866532 seconds time elapsed ( +- 0.17% ) and it also fixes an observable perf bench (hackbench) regression: # perf stat --null --repeat 10 perf bench sched messaging -NUMA: -NUMA: 0.246225691 seconds time elapsed ( +- 1.31% ) +NUMA no slow start: 0.252620063 seconds time elapsed ( +- 1.13% ) +NUMA 1sec delay: 0.248076230 seconds time elapsed ( +- 1.35% ) The implementation is simple and straightforward, most of the patch deals with adding the /proc/sys/kernel/numa_balancing_scan_delay_ms tunable knob. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> [ Wrote the changelog, ran measurements, tuned the default. ] Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com>
2012-12-11mm: sched: numa: Implement constant, per task Working Set Sampling (WSS) ratePeter Zijlstra
Previously, to probe the working set of a task, we'd use a very simple and crude method: mark all of its address space PROT_NONE. That method has various (obvious) disadvantages: - it samples the working set at dissimilar rates, giving some tasks a sampling quality advantage over others. - creates performance problems for tasks with very large working sets - over-samples processes with large address spaces but which only very rarely execute Improve that method by keeping a rotating offset into the address space that marks the current position of the scan, and advance it by a constant rate (in a CPU cycles execution proportional manner). If the offset reaches the last mapped address of the mm then it then it starts over at the first address. The per-task nature of the working set sampling functionality in this tree allows such constant rate, per task, execution-weight proportional sampling of the working set, with an adaptive sampling interval/frequency that goes from once per 100ms up to just once per 8 seconds. The current sampling volume is 256 MB per interval. As tasks mature and converge their working set, so does the sampling rate slow down to just a trickle, 256 MB per 8 seconds of CPU time executed. This, beyond being adaptive, also rate-limits rarely executing systems and does not over-sample on overloaded systems. [ In AutoNUMA speak, this patch deals with the effective sampling rate of the 'hinting page fault'. AutoNUMA's scanning is currently rate-limited, but it is also fundamentally single-threaded, executing in the knuma_scand kernel thread, so the limit in AutoNUMA is global and does not scale up with the number of CPUs, nor does it scan tasks in an execution proportional manner. So the idea of rate-limiting the scanning was first implemented in the AutoNUMA tree via a global rate limit. This patch goes beyond that by implementing an execution rate proportional working set sampling rate that is not implemented via a single global scanning daemon. ] [ Dan Carpenter pointed out a possible NULL pointer dereference in the first version of this patch. ] Based-on-idea-by: Andrea Arcangeli <aarcange@redhat.com> Bug-Found-By: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> [ Wrote changelog and fixed bug. ] Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Mel Gorman <mgorman@suse.de> Reviewed-by: Rik van Riel <riel@redhat.com>
2012-12-11mm: numa: Add fault driven placement and migrationPeter Zijlstra
NOTE: This patch is based on "sched, numa, mm: Add fault driven placement and migration policy" but as it throws away all the policy to just leave a basic foundation I had to drop the signed-offs-by. This patch creates a bare-bones method for setting PTEs pte_numa in the context of the scheduler that when faulted later will be faulted onto the node the CPU is running on. In itself this does nothing useful but any placement policy will fundamentally depend on receiving hints on placement from fault context and doing something intelligent about it. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com>
2012-11-28sysctl: remove CONFIG_HOTPLUG ifdefsBill Pemberton
Remove conditional code based on CONFIG_HOTPLUG being false. It's always on now in preparation of it going away as an option. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-09Kconfig: clean up the "#if defined(arch)" list for exception-trace sysctl entryCatalin Marinas
Introduce SYSCTL_EXCEPTION_TRACE config option and selec it in the architectures requiring support for the "exception-trace" debug_table entry in kernel/sysctl.c. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06coredump: make core dump functionality optionalAlex Kelly
Adds an expert Kconfig option, CONFIG_COREDUMP, which allows disabling of core dump. This saves approximately 2.6k in the compiled kernel, and complements CONFIG_ELF_CORE, which now depends on it. CONFIG_COREDUMP also disables coredump-related sysctls, except for suid_dumpable and related functions, which are necessary for ptrace. [akpm@linux-foundation.org: fix binfmt_aout.c build] Signed-off-by: Alex Kelly <alex.page.kelly@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-01Merge tag 'arm64-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64 Pull arm64 support from Catalin Marinas: "Linux support for the 64-bit ARM architecture (AArch64) Features currently supported: - 39-bit address space for user and kernel (each) - 4KB and 64KB page configurations - Compat (32-bit) user applications (ARMv7, EABI only) - Flattened Device Tree (mandated for all AArch64 platforms) - ARM generic timers" * tag 'arm64-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cmarinas/linux-aarch64: (35 commits) arm64: ptrace: remove obsolete ptrace request numbers from user headers arm64: Do not set the SMP/nAMP processor bit arm64: MAINTAINERS update arm64: Build infrastructure arm64: Miscellaneous header files arm64: Generic timers support arm64: Loadable modules arm64: Miscellaneous library functions arm64: Performance counters support arm64: Add support for /proc/sys/debug/exception-trace arm64: Debugging support arm64: Floating point and SIMD arm64: 32-bit (compat) applications support arm64: User access library functions arm64: Signal handling support arm64: VDSO support arm64: System calls handling arm64: ELF definitions arm64: SMP support arm64: DMA mapping API ...
2012-09-17arm64: Add support for /proc/sys/debug/exception-traceCatalin Marinas
This patch allows setting of the show_unhandled_signals variable via /proc/sys/debug/exception-trace. The default value is currently 1 showing unhandled user faults (undefined instructions, data aborts) and invalid signal stack frames. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Olof Johansson <olof@lixom.net> Acked-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
2012-09-04sched: Add time unit suffix to sched sysctl knobsNamhyung Kim
Unlike others, sched_migration_cost, sched_time_avg and sched_shares_window doesn't have time unit as suffix. Add them. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1345083330-19486-1-git-send-email-namhyung@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2012-08-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull second vfs pile from Al Viro: "The stuff in there: fsfreeze deadlock fixes by Jan (essentially, the deadlock reproduced by xfstests 068), symlink and hardlink restriction patches, plus assorted cleanups and fixes. Note that another fsfreeze deadlock (emergency thaw one) is *not* dealt with - the series by Fernando conflicts a lot with Jan's, breaks userland ABI (FIFREEZE semantics gets changed) and trades the deadlock for massive vfsmount leak; this is going to be handled next cycle. There probably will be another pull request, but that stuff won't be in it." Fix up trivial conflicts due to unrelated changes next to each other in drivers/{staging/gdm72xx/usb_boot.c, usb/gadget/storage_common.c} * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (54 commits) delousing target_core_file a bit Documentation: Correct s_umount state for freeze_fs/unfreeze_fs fs: Remove old freezing mechanism ext2: Implement freezing btrfs: Convert to new freezing mechanism nilfs2: Convert to new freezing mechanism ntfs: Convert to new freezing mechanism fuse: Convert to new freezing mechanism gfs2: Convert to new freezing mechanism ocfs2: Convert to new freezing mechanism xfs: Convert to new freezing code ext4: Convert to new freezing mechanism fs: Protect write paths by sb_start_write - sb_end_write fs: Skip atime update on frozen filesystem fs: Add freezing handling to mnt_want_write() / mnt_drop_write() fs: Improve filesystem freezing handling switch the protection of percpu_counter list to spinlock nfsd: Push mnt_want_write() outside of i_mutex btrfs: Push mnt_want_write() outside of i_mutex fat: Push mnt_want_write() outside of i_mutex ...
2012-07-31mm: prepare for removal of obsolete /proc/sys/vm/nr_pdflush_threadsWanpeng Li
Since per-BDI flusher threads were introduced in 2.6, the pdflush mechanism is not used any more. But the old interface exported through /proc/sys/vm/nr_pdflush_threads still exists and is obviously useless. For back-compatibility, printk warning information and return 2 to notify the users that the interface is removed. Signed-off-by: Wanpeng Li <liwp@linux.vnet.ibm.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30sysctl: suppress kmemleak messagesSteven Rostedt
register_sysctl_table() is a strange function, as it makes internal allocations (a header) to register a sysctl_table. This header is a handle to the table that is created, and can be used to unregister the table. But if the table is permanent and never unregistered, the header acts the same as a static variable. Unfortunately, this allocation of memory that is never expected to be freed fools kmemleak in thinking that we have leaked memory. For those sysctl tables that are never unregistered, and have no pointer referencing them, kmemleak will think that these are memory leaks: unreferenced object 0xffff880079fb9d40 (size 192): comm "swapper/0", pid 0, jiffies 4294667316 (age 12614.152s) hex dump (first 32 bytes): 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ backtrace: [<ffffffff8146b590>] kmemleak_alloc+0x73/0x98 [<ffffffff8110a935>] kmemleak_alloc_recursive.constprop.42+0x16/0x18 [<ffffffff8110b852>] __kmalloc+0x107/0x153 [<ffffffff8116fa72>] kzalloc.constprop.8+0xe/0x10 [<ffffffff811703c9>] __register_sysctl_paths+0xe1/0x160 [<ffffffff81170463>] register_sysctl_paths+0x1b/0x1d [<ffffffff8117047d>] register_sysctl_table+0x18/0x1a [<ffffffff81afb0a1>] sysctl_init+0x10/0x14 [<ffffffff81b05a6f>] proc_sys_init+0x2f/0x31 [<ffffffff81b0584c>] proc_root_init+0xa5/0xa7 [<ffffffff81ae5b7e>] start_kernel+0x3d0/0x40a [<ffffffff81ae52a7>] x86_64_start_reservations+0xae/0xb2 [<ffffffff81ae53ad>] x86_64_start_kernel+0x102/0x111 [<ffffffffffffffff>] 0xffffffffffffffff The sysctl_base_table used by sysctl itself is one such instance that registers the table to never be unregistered. Use kmemleak_not_leak() to suppress the kmemleak false positive. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-30coredump: warn about unsafe suid_dumpable / core_pattern comboKees Cook
When suid_dumpable=2, detect unsafe core_pattern settings and warn when they are seen. Signed-off-by: Kees Cook <keescook@chromium.org> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Alan Cox <alan@linux.intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Doug Ledford <dledford@redhat.com> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: James Morris <james.l.morris@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-29fs: add link restrictionsKees Cook
This adds symlink and hardlink restrictions to the Linux VFS. Symlinks: A long-standing class of security issues is the symlink-based time-of-check-time-of-use race, most commonly seen in world-writable directories like /tmp. The common method of exploitation of this flaw is to cross privilege boundaries when following a given symlink (i.e. a root process follows a symlink belonging to another user). For a likely incomplete list of hundreds of examples across the years, please see: http://cve.mitre.org/cgi-bin/cvekey.cgi?keyword=/tmp The solution is to permit symlinks to only be followed when outside a sticky world-writable directory, or when the uid of the symlink and follower match, or when the directory owner matches the symlink's owner. Some pointers to the history of earlier discussion that I could find: 1996 Aug, Zygo Blaxell http://marc.info/?l=bugtraq&m=87602167419830&w=2 1996 Oct, Andrew Tridgell http://lkml.indiana.edu/hypermail/linux/kernel/9610.2/0086.html 1997 Dec, Albert D Cahalan http://lkml.org/lkml/1997/12/16/4 2005 Feb, Lorenzo Hernández García-Hierro http://lkml.indiana.edu/hypermail/linux/kernel/0502.0/1896.html 2010 May, Kees Cook https://lkml.org/lkml/2010/5/30/144 Past objections and rebuttals could be summarized as: - Violates POSIX. - POSIX didn't consider this situation and it's not useful to follow a broken specification at the cost of security. - Might break unknown applications that use this feature. - Applications that break because of the change are easy to spot and fix. Applications that are vulnerable to symlink ToCToU by not having the change aren't. Additionally, no applications have yet been found that rely on this behavior. - Applications should just use mkstemp() or O_CREATE|O_EXCL. - True, but applications are not perfect, and new software is written all the time that makes these mistakes; blocking this flaw at the kernel is a single solution to the entire class of vulnerability. - This should live in the core VFS. - This should live in an LSM. (https://lkml.org/lkml/2010/5/31/135) - This should live in an LSM. - This should live in the core VFS. (https://lkml.org/lkml/2010/8/2/188) Hardlinks: On systems that have user-writable directories on the same partition as system files, a long-standing class of security issues is the hardlink-based time-of-check-time-of-use race, most commonly seen in world-writable directories like /tmp. The common method of exploitation of this flaw is to cross privilege boundaries when following a given hardlink (i.e. a root process follows a hardlink created by another user). Additionally, an issue exists where users can "pin" a potentially vulnerable setuid/setgid file so that an administrator will not actually upgrade a system fully. The solution is to permit hardlinks to only be created when the user is already the existing file's owner, or if they already have read/write access to the existing file. Many Linux users are surprised when they learn they can link to files they have no access to, so this change appears to follow the doctrine of "least surprise". Additionally, this change does not violate POSIX, which states "the implementation may require that the calling process has permission to access the existing file"[1]. This change is known to break some implementations of the "at" daemon, though the version used by Fedora and Ubuntu has been fixed[2] for a while. Otherwise, the change has been undisruptive while in use in Ubuntu for the last 1.5 years. [1] http://pubs.opengroup.org/onlinepubs/9699919799/functions/linkat.html [2] http://anonscm.debian.org/gitweb/?p=collab-maint/at.git;a=commitdiff;h=f4114656c3a6c6f6070e315ffdf940a49eda3279 This patch is based on the patches in Openwall and grsecurity, along with suggestions from Al Viro. I have added a sysctl to enable the protected behavior, and documentation. Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-04-05sysctl: fix write access to dmesg_restrict/kptr_restrictKees Cook
Commit bfdc0b4 adds code to restrict access to dmesg_restrict, however, it incorrectly alters kptr_restrict rather than dmesg_restrict. The original patch from Richard Weinberger (https://lkml.org/lkml/2011/3/14/362) alters dmesg_restrict as expected, and so the patch seems to have been misapplied. This adds the CAP_SYS_ADMIN check to both dmesg_restrict and kptr_restrict, since both are sensitive. Reported-by: Phillip Lougher <plougher@redhat.com> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Richard Weinberger <richard@nod.at> Cc: stable@vger.kernel.org Signed-off-by: James Morris <james.l.morris@oracle.com>
2012-03-28Merge branch 'akpm' (Andrew's patch-bomb)Linus Torvalds
Merge third batch of patches from Andrew Morton: - Some MM stragglers - core SMP library cleanups (on_each_cpu_mask) - Some IPI optimisations - kexec - kdump - IPMI - the radix-tree iterator work - various other misc bits. "That'll do for -rc1. I still have ~10 patches for 3.4, will send those along when they've baked a little more." * emailed from Andrew Morton <akpm@linux-foundation.org>: (35 commits) backlight: fix typo in tosa_lcd.c crc32: add help text for the algorithm select option mm: move hugepage test examples to tools/testing/selftests/vm mm: move slabinfo.c to tools/vm mm: move page-types.c from Documentation to tools/vm selftests/Makefile: make `run_tests' depend on `all' selftests: launch individual selftests from the main Makefile radix-tree: use iterators in find_get_pages* functions radix-tree: rewrite gang lookup using iterator radix-tree: introduce bit-optimized iterator fs/proc/namespaces.c: prevent crash when ns_entries[] is empty nbd: rename the nbd_device variable from lo to nbd pidns: add reboot_pid_ns() to handle the reboot syscall sysctl: use bitmap library functions ipmi: use locks on watchdog timeout set on reboot ipmi: simplify locking ipmi: fix message handling during panics ipmi: use a tasklet for handling received messages ipmi: increase KCS timeouts ipmi: decrease the IPMI message transaction time in interrupt mode ...
2012-03-28sysctl: use bitmap library functionsAkinobu Mita
Use bitmap_set() instead of using set_bit() for each bit. This conversion is valid because the bitmap is private in the function call and atomic bitops were unnecessary. This also includes minor change. - Use bitmap_copy() for shorter typing Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-28Disintegrate asm/system.h for SparcDavid Howells
Disintegrate asm/system.h for Sparc. Signed-off-by: David Howells <dhowells@redhat.com> cc: sparclinux@vger.kernel.org
2012-03-23Merge git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctlLinus Torvalds
Pull sysctl updates from Eric Biederman: - Rewrite of sysctl for speed and clarity. Insert/remove/Lookup in sysctl are all now O(NlogN) operations, and are no longer bottlenecks in the process of adding and removing network devices. sysctl is now focused on being a filesystem instead of system call and the code can all be found in fs/proc/proc_sysctl.c. Hopefully this means the code is now approachable. Much thanks is owed to Lucian Grinjincu for keeping at this until something was found that was usable. - The recent proc_sys_poll oops found by the fuzzer during hibernation is fixed. * git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl: (36 commits) sysctl: protect poll() in entries that may go away sysctl: Don't call sysctl_follow_link unless we are a link. sysctl: Comments to make the code clearer. sysctl: Correct error return from get_subdir sysctl: An easier to read version of find_subdir sysctl: fix memset parameters in setup_sysctl_set() sysctl: remove an unused variable sysctl: Add register_sysctl for normal sysctl users sysctl: Index sysctl directories with rbtrees. sysctl: Make the header lists per directory. sysctl: Move sysctl_check_dups into insert_header sysctl: Modify __register_sysctl_paths to take a set instead of a root and an nsproxy sysctl: Replace root_list with links between sysctl_table_sets. sysctl: Add sysctl_print_dir and use it in get_subdir sysctl: Stop requiring explicit management of sysctl directories sysctl: Add a root pointer to ctl_table_set sysctl: Rewrite proc_sys_readdir in terms of first_entry and next_entry sysctl: Rewrite proc_sys_lookup introducing find_entry and lookup_entry. sysctl: Normalize the root_table data structure. sysctl: Factor out insert_header and erase_header ...
2012-02-14security: trim security.hAl Viro
Trim security.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Morris <jmorris@namei.org>
2012-01-24sysctl: Move the implementation into fs/proc/proc_sysctl.cEric W. Biederman
Move the core sysctl code from kernel/sysctl.c and kernel/sysctl_check.c into fs/proc/proc_sysctl.c. Currently sysctl maintenance is hampered by the sysctl implementation being split across 3 files with artificial layering between them. Consolidate the entire sysctl implementation into 1 file so that it is easier to see what is going on and hopefully allowing for simpler maintenance. For functions that are now only used in fs/proc/proc_sysctl.c remove their declarations from sysctl.h and make them static in fs/proc/proc_sysctl.c Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-01-24sysctl: Register the base sysctl table like any other sysctl table.Eric W. Biederman
Simplify the code by treating the base sysctl table like any other sysctl table and register it with register_sysctl_table. To ensure this table is registered early enough to avoid problems call sysctl_init from proc_sys_init. Rename sysctl_net.c:sysctl_init() to net_sysctl_init() to avoid name conflicts now that kernel/sysctl.c:sysctl_init() is no longer static. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-01-24sysctl: Consolidate !CONFIG_SYSCTL handlingEric W. Biederman
- In sysctl.h move functions only available if CONFIG_SYSCL is defined inside of #ifdef CONFIG_SYSCTL - Move the stub function definitions for !CONFIG_SYSCTL into sysctl.h and make them static inlines. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2011-12-05x86: Panic on detection of stack overflowMitsuo Hayasaka
Currently, messages are just output on the detection of stack overflow, which is not sufficient for systems that need a high reliability. This is because in general the overflow may corrupt data, and the additional corruption may occur due to reading them unless systems stop. This patch adds the sysctl parameter kernel.panic_on_stackoverflow and causes a panic when detecting the overflows of kernel, IRQ and exception stacks except user stack according to the parameter. It is disabled by default. Signed-off-by: Mitsuo Hayasaka <mitsuo.hayasaka.hu@hitachi.com> Cc: yrl.pp-manager.tt@hitachi.com Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: "H. Peter Anvin" <hpa@zytor.com> Link: http://lkml.kernel.org/r/20111129060836.11076.12323.stgit@ltc219.sdl.hitachi.co.jp Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-10-31Merge branch 'akpm' (Andrew's incoming)Linus Torvalds
Quoth Andrew: - Most of MM. Still waiting for the poweroc guys to get off their butts and review some threaded hugepages patches. - alpha - vfs bits - drivers/misc - a few core kerenl tweaks - printk() features - MAINTAINERS updates - backlight merge - leds merge - various lib/ updates - checkpatch updates * akpm: (127 commits) epoll: fix spurious lockdep warnings checkpatch: add a --strict check for utf-8 in commit logs kernel.h/checkpatch: mark strict_strto<foo> and simple_strto<foo> as obsolete llist-return-whether-list-is-empty-before-adding-in-llist_add-fix wireless: at76c50x: follow rename pack_hex_byte to hex_byte_pack fat: follow rename pack_hex_byte() to hex_byte_pack() security: follow rename pack_hex_byte() to hex_byte_pack() kgdb: follow rename pack_hex_byte() to hex_byte_pack() lib: rename pack_hex_byte() to hex_byte_pack() lib/string.c: fix strim() semantics for strings that have only blanks lib/idr.c: fix comment for ida_get_new_above() lib/percpu_counter.c: enclose hotplug only variables in hotplug ifdef lib/bitmap.c: quiet sparse noise about address space lib/spinlock_debug.c: print owner on spinlock lockup lib/kstrtox: common code between kstrto*() and simple_strto*() functions drivers/leds/leds-lp5521.c: check if reset is successful leds: turn the blink_timer off before starting to blink leds: save the delay values after a successful call to blink_set() drivers/leds/leds-gpio.c: use gpio_get_value_cansleep() when initializing drivers/leds/leds-lm3530.c: add __devexit_p where needed ...
2011-10-31kernel/sysctl.c: add cap_last_cap to /proc/sys/kernelDan Ballard
Userspace needs to know the highest valid capability of the running kernel, which right now cannot reliably be retrieved from the header files only. The fact that this value cannot be determined properly right now creates various problems for libraries compiled on newer header files which are run on older kernels. They assume capabilities are available which actually aren't. libcap-ng is one example. And we ran into the same problem with systemd too. Now the capability is exported in /proc/sys/kernel/cap_last_cap. [akpm@linux-foundation.org: make cap_last_cap const, per Ulrich] Signed-off-by: Dan Ballard <dan@mindstab.net> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Lennart Poettering <lennart@poettering.net> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Ulrich Drepper <drepper@akkadia.org> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-30[S390] sparse: fix sparse warnings about missing prototypesMartin Schwidefsky
Add prototypes and includes for functions used in different modules. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-08-14sched: Accumulate per-cfs_rq cpu usage and charge against bandwidthPaul Turner
Account bandwidth usage on the cfs_rq level versus the task_groups to which they belong. Whether we are tracking bandwidth on a given cfs_rq is maintained under cfs_rq->runtime_enabled. cfs_rq's which belong to a bandwidth constrained task_group have their runtime accounted via the update_curr() path, which withdraws bandwidth from the global pool as desired. Updates involving the global pool are currently protected under cfs_bandwidth->lock, local runtime is protected by rq->lock. This patch only assigns and tracks quota, no action is taken in the case that cfs_rq->runtime_used exceeds cfs_rq->runtime_assigned. Signed-off-by: Paul Turner <pjt@google.com> Signed-off-by: Nikhil Rao <ncrao@google.com> Signed-off-by: Bharata B Rao <bharata@linux.vnet.ibm.com> Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110721184757.179386821@google.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-20sysctl,rcu: Convert call_rcu(free_head) to kfreePaul E. McKenney
The RCU callback free_head just calls kfree(), so we can use kfree_rcu() instead of call_rcu(). Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Josh Triplett <josh@joshtriplett.org>
2011-06-04perf: Comment /proc/sys/kernel/perf_event_paranoid to be part of user ABIVince Weaver
Turns out that distro packages use this file as an indicator of the perf event subsystem - this is easier to check for from scripts than the existence of the system call. This is easy enough to keep around for the kernel, so add a comment to make sure it stays so. Signed-off-by: Vince Weaver <vweaver1@eecs.utk.edu> Cc: David Ahern <dsahern@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: paulus@samba.org Cc: acme@redhat.com Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/alpine.DEB.2.00.1106031751170.29381@cl320.eecs.utk.edu Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: (26 commits) arch/tile: prefer "tilepro" as the name of the 32-bit architecture compat: include aio_abi.h for aio_context_t arch/tile: cleanups for tilegx compat mode arch/tile: allocate PCI IRQs later in boot arch/tile: support signal "exception-trace" hook arch/tile: use better definitions of xchg() and cmpxchg() include/linux/compat.h: coding-style fixes tile: add an RTC driver for the Tilera hypervisor arch/tile: finish enabling support for TILE-Gx 64-bit chip compat: fixes to allow working with tile arch arch/tile: update defconfig file to something more useful tile: do_hardwall_trap: do not play with task->sighand tile: replace mm->cpu_vm_mask with mm_cpumask() tile,mn10300: add device parameter to dma_cache_sync() audit: support the "standard" <asm-generic/unistd.h> arch/tile: clarify flush_buffer()/finv_buffer() function names arch/tile: kernel-related cleanups from removing static page size arch/tile: various header improvements for building drivers arch/tile: disable GX prefetcher during cache flush arch/tile: tolerate disabling CONFIG_BLK_DEV_INITRD ...
2011-05-24Merge branch 'next' into for-linusJames Morris
2011-05-23watchdog: Disable watchdog when thresh is zeroMandeep Singh Baines
This restores the previous behavior of softlock_thresh. Currently, setting watchdog_thresh to zero causes the watchdog kthreads to consume a lot of CPU. In addition, the logic of proc_dowatchdog_thresh and proc_dowatchdog_enabled has been factored into proc_dowatchdog. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Cc: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/1306127423-3347-3-git-send-email-msb@chromium.org Signed-off-by: Ingo Molnar <mingo@elte.hu> LKML-Reference: <20110517071018.GE22305@elte.hu>
