path: root/kernel/sysctl.c
2010-01-18kernel/sysctl.c: fix stable merge error in NOMMU mmap_min_addrMike Frysinger
Stable commit 0399123f3dcce1a515d021107ec0fb4413ca3efa didn't match the original upstream commit. The CONFIG_MMU check was added much too early in the list disabling a lot of proc entries in the process. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06kernel/sysctl.c: fix the incomplete part of ↵WANG Cong
sysctl_max_map_count-should-be-non-negative.patch commit 3e26120cc7c819c97bc07281ca1fb9017cfe9a39 upstream. It is a mistake that we used 'proc_dointvec', it should be 'proc_dointvec_minmax', as in the original patch. Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06'sysctl_max_map_count' should be non-negativeAmerigo Wang
commit 70da2340fbc68e91e701762f785479ab495a0869 upstream. Jan Engelhardt reported we have this problem: setting max_map_count to a value large enough results in programs dying at first try. This is on 2.6.31.6: 15:59 borg:/proc/sys/vm # echo $[1<<31-1] >max_map_count 15:59 borg:/proc/sys/vm # cat max_map_count 1073741824 15:59 borg:/proc/sys/vm # echo $[1<<31] >max_map_count 15:59 borg:/proc/sys/vm # cat max_map_count Killed This is because we have a chance to make 'max_map_count' negative. but it's meaningless. Make it only accept non-negative values. Reported-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: James Morris <jmorris@namei.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-06NOMMU: Optimise away the {dac_,}mmap_min_addr testsDavid Howells
commit 6e1415467614e854fee660ff6648bd10fa976e95 upstream. In NOMMU mode clamp dac_mmap_min_addr to zero to cause the tests on it to be skipped by the compiler. We do this as the minimum mmap address doesn't make any sense in NOMMU mode. mmap_min_addr and round_hint_to_min() can be discarded entirely in NOMMU mode. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-24Merge branch 'hwpoison' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6 * 'hwpoison' of git://git.kernel.org/pub/scm/linux/kernel/git/ak/linux-mce-2.6: (21 commits) HWPOISON: Enable error_remove_page on btrfs HWPOISON: Add simple debugfs interface to inject hwpoison on arbitary PFNs HWPOISON: Add madvise() based injector for hardware poisoned pages v4 HWPOISON: Enable error_remove_page for NFS HWPOISON: Enable .remove_error_page for migration aware file systems HWPOISON: The high level memory error handler in the VM v7 HWPOISON: Add PR_MCE_KILL prctl to control early kill behaviour per process HWPOISON: shmem: call set_page_dirty() with locked page HWPOISON: Define a new error_remove_page address space op for async truncation HWPOISON: Add invalidate_inode_page HWPOISON: Refactor truncate to allow direct truncating of page v2 HWPOISON: check and isolate corrupted free pages v2 HWPOISON: Handle hardware poisoned pages in try_to_unmap HWPOISON: Use bitmask/action code for try_to_unmap behaviour HWPOISON: x86: Add VM_FAULT_HWPOISON handling to x86 page fault handler v2 HWPOISON: Add poison check to page fault handling HWPOISON: Add basic support for poisoned pages in fault handler v3 HWPOISON: Add new SIGBUS error codes for hardware poison signals HWPOISON: Add support for poison swap entries v2 HWPOISON: Export some rmap vma locking to outside world ...
2009-09-24sysctl: remove "struct file *" argument of ->proc_handlerAlexey Dobriyan
It's unused. It isn't needed -- read or write flag is already passed and sysctl shouldn't care about the rest. It _was_ used in two places at arch/frv for some reason. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-24exec: let do_coredump() limit the number of concurrent dumps to pipesNeil Horman
Introduce core pipe limiting sysctl. Since we can dump cores to pipe, rather than directly to the filesystem, we create a condition in which a user can create a very high load on the system simply by running bad applications. If the pipe reader specified in core_pattern is poorly written, we can have lots of ourstandig resources and processes in the system. This sysctl introduces an ability to limit that resource consumption. core_pipe_limit defines how many in-flight dumps may be run in parallel, dumps beyond this value are skipped and a note is made in the kernel log. A special value of 0 in core_pipe_limit denotes unlimited core dumps may be handled (this is the default value). [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Reported-by: Earl Chew <earl_chew@agilent.com> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Andi Kleen <andi@firstfloor.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23headers: utsname.h reduxAlexey Dobriyan
* remove asm/atomic.h inclusion from linux/utsname.h -- not needed after kref conversion * remove linux/utsname.h inclusion from files which do not need it NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however due to some personality stuff it _is_ needed -- cowardly leave ELF-related headers and files alone. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23printk: add printk_delay to make messages readable for some scenariosDave Young
When syslog is not possible, at the same time there's no serial/net console available, it will be hard to read the printk messages. For example oops/panic/warning messages in shutdown phase. Add a printk delay feature, we can make each printk message delay some milliseconds. Setting the delay by proc/sysctl interface: /proc/sys/kernel/printk_delay The value range from 0 - 10000, default value is 0 [akpm@linux-foundation.org: fix a few things] Signed-off-by: Dave Young <hidave.darkstar@gmail.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-16HWPOISON: The high level memory error handler in the VM v7Andi Kleen
Add the high level memory handler that poisons pages that got corrupted by hardware (typically by a two bit flip in a DIMM or a cache) on the Linux level. The goal is to prevent everyone from accessing these pages in the future. This done at the VM level by marking a page hwpoisoned and doing the appropriate action based on the type of page it is. The code that does this is portable and lives in mm/memory-failure.c To quote the overview comment: High level machine check handler. Handles pages reported by the hardware as being corrupted usually due to a 2bit ECC memory or cache failure. This focuses on pages detected as corrupted in the background. When the current CPU tries to consume corruption the currently running process can just be killed directly instead. This implies that if the error cannot be handled for some reason it's safe to just ignore it because no corruption has been consumed yet. Instead when that happens another machine check will happen. Handles page cache pages in various states. The tricky part here is that we can access any page asynchronous to other VM users, because memory failures could happen anytime and anywhere, possibly violating some of their assumptions. This is why this code has to be extremely careful. Generally it tries to use normal locking rules, as in get the standard locks, even if that means the error handling takes potentially a long time. Some of the operations here are somewhat inefficient and have non linear algorithmic complexity, because the data structures have not been optimized for this case. This is in particular the case for the mapping from a vma to a process. Since this case is expected to be rare we hope we can get away with this. There are in principle two strategies to kill processes on poison: - just unmap the data and wait for an actual reference before killing - kill as soon as corruption is detected. Both have advantages and disadvantages and should be used in different situations. Right now both are implemented and can be switched with a new sysctl vm.memory_failure_early_kill The default is early kill. The patch does some rmap data structure walking on its own to collect processes to kill. This is unusual because normally all rmap data structure knowledge is in rmap.c only. I put it here for now to keep everything together and rmap knowledge has been seeping out anyways Includes contributions from Johannes Weiner, Chris Mason, Fengguang Wu, Nick Piggin (who did a lot of great work) and others. Cc: npiggin@suse.de Cc: riel@redhat.com Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rik van Riel <riel@redhat.com> Reviewed-by: Hidehiro Kawai <hidehiro.kawai.ez@hitachi.com>
2009-09-15block: fix linkage problem with blk_iopoll and !CONFIG_BLOCKJens Axboe
kernel/built-in.o:(.data+0x17b0): undefined reference to `blk_iopoll_enabled' Since the extern declaration makes the compile work, but the actual symbol is missing when block/blk-iopoll.o isn't linked in. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-14Merge branch 'for-2.6.32' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.32' of git://git.kernel.dk/linux-2.6-block: (29 commits) block: use blkdev_issue_discard in blk_ioctl_discard Make DISCARD_BARRIER and DISCARD_NOBARRIER writes instead of reads block: don't assume device has a request list backing in nr_requests store block: Optimal I/O limit wrapper cfq: choose a new next_req when a request is dispatched Seperate read and write statistics of in_flight requests aoe: end barrier bios with EOPNOTSUPP block: trace bio queueing trial only when it occurs block: enable rq CPU completion affinity by default cfq: fix the log message after dispatched a request block: use printk_once cciss: memory leak in cciss_init_one() splice: update mtime and atime on files block: make blk_iopoll_prep_sched() follow normal 0/1 return convention cfq-iosched: get rid of must_alloc flag block: use interrupts disabled version of raise_softirq_irqoff() block: fix comment in blk-iopoll.c block: adjust default budget for blk-iopoll block: fix long lines in block/blk-iopoll.c block: add blk-iopoll, a NAPI like approach for block devices ...
2009-09-11Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (64 commits) sched: Fix sched::sched_stat_wait tracepoint field sched: Disable NEW_FAIR_SLEEPERS for now sched: Keep kthreads at default priority sched: Re-tune the scheduler latency defaults to decrease worst-case latencies sched: Turn off child_runs_first sched: Ensure that a child can't gain time over it's parent after fork() sched: enable SD_WAKE_IDLE sched: Deal with low-load in wake_affine() sched: Remove short cut from select_task_rq_fair() sched: Turn on SD_BALANCE_NEWIDLE sched: Clean up topology.h sched: Fix dynamic power-balancing crash sched: Remove reciprocal for cpu_power sched: Try to deal with low capacity, fix update_sd_power_savings_stats() sched: Try to deal with low capacity sched: Scale down cpu_power due to RT tasks sched: Implement dynamic cpu_power sched: Add smt_gain sched: Update the cpu_power sum during load-balance sched: Add SD_PREFER_SIBLING ...
2009-09-11block: add blk-iopoll, a NAPI like approach for block devicesJens Axboe
This borrows some code from NAPI and implements a polled completion mode for block devices. The idea is the same as NAPI - instead of doing the command completion when the irq occurs, schedule a dedicated softirq in the hopes that we will complete more IO when the iopoll handler is invoked. Devices have a budget of commands assigned, and will stay in polled mode as long as they continue to consume their budget from the iopoll softirq handler. If they do not, the device is set back to interrupt completion mode. This patch holds the core bits for blk-iopoll, device driver support sold separately. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-09sched: Turn off child_runs_firstMike Galbraith
Set child_runs_first default to off. It hurts 'optimal' make -j<NR_CPUS> workloads as make jobs get preempted by child tasks, reducing parallelism. Note, this patch might make existing races in user applications more prominent than before - so breakages might be bisected to this commit. Child-runs-first is broken on SMP to begin with, and we already had it off briefly in v2.6.23 so most of the offenders ought to be fixed. Would be nice not to revert this commit but fix those apps finally ... Signed-off-by: Mike Galbraith <efault@gmx.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1252486344.28645.18.camel@marge.simson.net> [ made the sysctl independent of CONFIG_SCHED_DEBUG, in case people want to work around broken apps. ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-07Security/SELinux: includecheck fix kernel/sysctl.cJaswinder Singh Rajput
fix the following 'make includecheck' warning: kernel/sysctl.c: linux/security.h is included more than once. Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-09-04sched: Scale down cpu_power due to RT tasksPeter Zijlstra
Keep an average on the amount of time spend on RT tasks and use that fraction to scale down the cpu_power for regular tasks. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Tested-by: Andreas Herrmann <andreas.herrmann3@amd.com> Acked-by: Andreas Herrmann <andreas.herrmann3@amd.com> Acked-by: Gautham R Shenoy <ego@in.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> LKML-Reference: <20090901083826.287778431@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-17Security/SELinux: seperate lsm specific mmap_min_addrEric Paris
Currently SELinux enforcement of controls on the ability to map low memory is determined by the mmap_min_addr tunable. This patch causes SELinux to ignore the tunable and instead use a seperate Kconfig option specific to how much space the LSM should protect. The tunable will now only control the need for CAP_SYS_RAWIO and SELinux permissions will always protect the amount of low memory designated by CONFIG_LSM_MMAP_MIN_ADDR. This allows users who need to disable the mmap_min_addr controls (usual reason being they run WINE as a non-root user) to do so and still have SELinux controls preventing confined domains (like a web server) from being able to map some area of low memory. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-06-28Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, delay: tsc based udelay should have rdtsc_barrier x86, setup: correct include file in <asm/boot.h> x86, setup: Fix typo "CONFIG_x86_64" in <asm/boot.h> x86, mce: percpu mcheck_timer should be pinned x86: Add sysctl to allow panic on IOCK NMI error x86: Fix uv bau sending buffer initialization x86, mce: Fix mce resume on 32bit x86: Move init_gbpages() to setup_arch() x86: ensure percpu lpage doesn't consume too much vmalloc space x86: implement percpu_alloc kernel parameter x86: fix pageattr handling for lpage percpu allocator and re-enable it x86: reorganize cpa_process_alias() x86: prepare setup_pcpu_lpage() for pageattr fix x86: rename remap percpu first chunk allocator to lpage x86: fix duplicate free in setup_pcpu_remap() failure path percpu: fix too lazy vunmap cache flushing x86: Set cpu_llc_id on AMD CPUs
2009-06-25x86: Add sysctl to allow panic on IOCK NMI errorKurt Garloff
This patch introduces a new sysctl: /proc/sys/kernel/panic_on_io_nmi which defaults to 0 (off). When enabled, the kernel panics when the kernel receives an NMI caused by an IO error. The IO error triggered NMI indicates a serious system condition, which could result in IO data corruption. Rather than contiuing, panicing and dumping might be a better choice, so one can figure out what's causing the IO error. This could be especially important to companies running IO intensive applications where corruption must be avoided, e.g. a bank's databases. [ SuSE has been shipping it for a while, it was done at the request of a large database vendor, for their users. ] Signed-off-by: Kurt Garloff <garloff@suse.de> Signed-off-by: Roberto Angelino <robertangelino@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: "Eric W. Biederman" <ebiederm@xmission.com> LKML-Reference: <20090624213211.GA11291@kroah.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-23timers: Fix timer_migration interface which accepts any number as inputArun R Bharadwaj
Poornima Nayek reported: | Timer migration interface /proc/sys/kernel/timer_migration in | 2.6.30-git9 accepts any numerical value as input. | | Steps to reproduce: | 1. echo -6666666 > /proc/sys/kernel/timer_migration | 2. cat /proc/sys/kernel/timer_migration | -6666666 | | 1. echo 44444444444444444444444444444444444444444444444444444444444 > /proc/sys/kernel/timer_migration | 2. cat /proc/sys/kernel/timer_migration | -1357789412 | | Expected behavior: Should 'echo: write error: Invalid argument' while | setting any value other then 0 & 1 Restrict valid values to 0 and 1. Reported-by: Poornima Nayak <mpnayak@linux.vnet.ibm.com> Tested-by: Poornima Nayak <mpnayak@linux.vnet.ibm.com> Signed-off-by: Arun R Bharadwaj <arun@linux.vnet.ibm.com> Cc: poornima nayak <mpnayak@linux.vnet.ibm.com> Cc: Arun Bharadwaj <arun@linux.vnet.ibm.com> LKML-Reference: <20090623043058.GA3249@linux.vnet.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-18sysctl.c: remove unused variableSukanto Ghosh
Remoce the unused variable 'val' from __do_proc_dointvec() The integer has been declared and used as 'val = -val' and there is no reference to it anywhere. Signed-off-by: Sukanto Ghosh <sukanto.cse.iitb@gmail.com> Cc: Jaswinder Singh Rajput <jaswinder@kernel.org> Cc: Sukanto Ghosh <sukanto.cse.iitb@gmail.com> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16Merge branch 'akpm'Linus Torvalds
* akpm: (182 commits) fbdev: bf54x-lq043fb: use kzalloc over kmalloc/memset fbdev: *bfin*: fix __dev{init,exit} markings fbdev: *bfin*: drop unnecessary calls to memset fbdev: bfin-t350mcqb-fb: drop unused local variables fbdev: blackfin has __raw I/O accessors, so use them in fb.h fbdev: s1d13xxxfb: add accelerated bitblt functions tcx: use standard fields for framebuffer physical address and length fbdev: add support for handoff from firmware to hw framebuffers intelfb: fix a bug when changing video timing fbdev: use framebuffer_release() for freeing fb_info structures radeon: P2G2CLK_ALWAYS_ONb tested twice, should 2nd be P2G2CLK_DAC_ALWAYS_ONb? s3c-fb: CPUFREQ frequency scaling support s3c-fb: fix resource releasing on error during probing carminefb: fix possible access beyond end of carmine_modedb[] acornfb: remove fb_mmap function mb862xxfb: use CONFIG_OF instead of CONFIG_PPC_OF mb862xxfb: restrict compliation of platform driver to PPC Samsung SoC Framebuffer driver: add Alpha Channel support atmel-lcdc: fix pixclock upper bound detection offb: use framebuffer_alloc() to allocate fb_info struct ... Manually fix up conflicts due to kmemcheck in mm/slab.c
2009-06-16mm: remove CONFIG_UNEVICTABLE_LRU config optionKOSAKI Motohiro
Currently, nobody wants to turn UNEVICTABLE_LRU off. Thus this configurability is unnecessary. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Andi Kleen <andi@firstfloor.org> Acked-by: Minchan Kim <minchan.kim@gmail.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Rik van Riel <riel@redhat.com> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16Merge branch 'for-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vegard/kmemcheck * 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/vegard/kmemcheck: (39 commits) signal: fix __send_signal() false positive kmemcheck warning fs: fix do_mount_root() false positive kmemcheck warning fs: introduce __getname_gfp() trace: annotate bitfields in struct ring_buffer_event net: annotate struct sock bitfield c2port: annotate bitfield for kmemcheck net: annotate inet_timewait_sock bitfields ieee1394/csr1212: fix false positive kmemcheck report ieee1394: annotate bitfield net: annotate bitfields in struct inet_sock net: use kmemcheck bitfields API for skbuff kmemcheck: introduce bitfield API kmemcheck: add opcode self-testing at boot x86: unify pte_hidden x86: make _PAGE_HIDDEN conditional kmemcheck: make kconfig accessible for other architectures kmemcheck: enable in the x86 Kconfig kmemcheck: add hooks for the page allocator kmemcheck: add hooks for page- and sg-dma-mappings kmemcheck: don't track page tables ...
2009-06-15Merge branch 'timers-for-linus-migration' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-for-linus-migration' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: timers: Logic to move non pinned timers timers: /proc/sys sysctl hook to enable timer migration timers: Identifying the existing pinned timers timers: Framework for identifying pinned timers timers: allow deferrable timers for intervals tv2-tv5 to be deferred Fix up conflicts in kernel/sched.c and kernel/timer.c manually
2009-06-13kmemcheck: add the kmemcheck coreVegard Nossum
General description: kmemcheck is a patch to the linux kernel that detects use of uninitialized memory. It does this by trapping every read and write to memory that was allocated dynamically (e.g. using kmalloc()). If a memory address is read that has not previously been written to, a message is printed to the kernel log. Thanks to Andi Kleen for the set_memory_4k() solution. Andrew Morton suggested documenting the shadow member of struct page. Signed-off-by: Vegard Nossum <vegardno@ifi.uio.no> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> [export kmemcheck_mark_initialized] [build fix for setup_max_cpus] Signed-off-by: Ingo Molnar <mingo@elte.hu> [rebased for mainline inclusion] Signed-off-by: Vegard Nossum <vegardno@ifi.uio.no>
2009-06-11Merge branch 'perfcounters-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perfcounters-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (574 commits) perf_counter: Turn off by default perf_counter: Add counter->id to the throttle event perf_counter: Better align code perf_counter: Rename L2 to LL cache perf_counter: Standardize event names perf_counter: Rename enums perf_counter tools: Clean up u64 usage perf_counter: Rename perf_counter_limit sysctl perf_counter: More paranoia settings perf_counter: powerpc: Implement generalized cache events for POWER processors perf_counters: powerpc: Add support for POWER7 processors perf_counter: Accurate period data perf_counter: Introduce struct for sample data perf_counter tools: Normalize data using per sample period data perf_counter: Annotate exit ctx recursion perf_counter tools: Propagate signals properly perf_counter tools: Small frequency related fixes perf_counter: More aggressive frequency adjustment perf_counter/x86: Fix the model number of Intel Core2 processors perf_counter, x86: Correct some event and umask values for Intel processors ...
2009-06-11Merge branch 'linus' into perfcounters/coreIngo Molnar
Conflicts: arch/x86/kernel/irqinit.c arch/x86/kernel/irqinit_64.c arch/x86/kernel/traps.c arch/x86/mm/fault.c include/linux/sched.h kernel/exit.c
2009-06-11perf_counter: Rename perf_counter_limit sysctlPeter Zijlstra
Rename perf_counter_limit to perf_counter_max_sample_rate and prohibit creation of counters with a known higher sample frequency. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-11perf_counter: More paranoia settingsPeter Zijlstra
Rename the perf_counter_priv knob to perf_counter_paranoia (because priv can be read as private, as opposed to privileged) and provide one more level: 0 - permissive 1 - restrict cpu counters to privilidged contexts 2 - restrict kernel-mode code counting and profiling Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-11Merge branch 'next' into for-linusJames Morris
2009-06-10Merge branch 'x86-kbuild-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-kbuild-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (46 commits) x86, boot: add new generated files to the appropriate .gitignore files x86, boot: correct the calculation of ZO_INIT_SIZE x86-64: align __PHYSICAL_START, remove __KERNEL_ALIGN x86, boot: correct sanity checks in boot/compressed/misc.c x86: add extension fields for bootloader type and version x86, defconfig: update kernel position parameters x86, defconfig: update to current, no material changes x86: make CONFIG_RELOCATABLE the default x86: default CONFIG_PHYSICAL_START and CONFIG_PHYSICAL_ALIGN to 16 MB x86: document new bzImage fields x86, boot: make kernel_alignment adjustable; new bzImage fields x86, boot: remove dead code from boot/compressed/head_*.S x86, boot: use LOAD_PHYSICAL_ADDR on 64 bits x86, boot: make symbols from the main vmlinux available x86, boot: determine compressed code offset at compile time x86, boot: use appropriate rep string for move and clear x86, boot: zero EFLAGS on 32 bits x86, boot: set up the decompression stack as early as possible x86, boot: straighten out ranges to copy/zero in compressed/head*.S x86, boot: stylistic cleanups for boot/compressed/head_64.S ... Fixed trivial conflict in arch/x86/configs/x86_64_defconfig manually
2009-06-04security: use mmap_min_addr indepedently of security modelsChristoph Lameter
This patch removes the dependency of mmap_min_addr on CONFIG_SECURITY. It also sets a default mmap_min_addr of 4096. mmapping of addresses below 4096 will only be possible for processes with CAP_SYS_RAWIO. Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Acked-by: Eric Paris <eparis@redhat.com> Looks-ok-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: James Morris <jmorris@namei.org>
2009-05-25perf_counter: Generic per counter interrupt throttlePeter Zijlstra
Introduce a generic per counter interrupt throttle. This uses the perf_counter_overflow() quick disable to throttle a specific counter when its going too fast when a pmu->unthrottle() method is provided which can undo the quick disable. Power needs to implement both the quick disable and the unthrottle method. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: John Kacur <jkacur@redhat.com> LKML-Reference: <20090525153931.703093461@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-22Merge branch 'master' into nextJames Morris
Conflicts: fs/exec.c Removed IMA changes (the IMA checks are now performed via may_open()). Signed-off-by: James Morris <jmorris@namei.org>
2009-05-18Merge commit 'v2.6.30-rc6' into perfcounters/coreIngo Molnar
Merge reason: this branch was on an -rc4 base, merge it up to -rc6 to get the latest upstream fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-15Revert "mm: add /proc controls for pdflush threads"Jens Axboe
This reverts commit fafd688e4c0c34da0f3de909881117d374e4c7af. Work is progressing to switch away from pdflush as the process backing for flushing out dirty data. So it seems pointless to add more knobs to control pdflush threads. The original author of the patch did not have any specific use cases for adding the knobs, so we can easily revert this before 2.6.30 to avoid having to maintain this API forever. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-13timers: /proc/sys sysctl hook to enable timer migrationArun R Bharadwaj
* Arun R Bharadwaj <arun@linux.vnet.ibm.com> [2009-04-16 12:11:36]: This patch creates the /proc/sys sysctl interface at /proc/sys/kernel/timer_migration Timer migration is enabled by default. To disable timer migration, when CONFIG_SCHED_DEBUG = y, echo 0 > /proc/sys/kernel/timer_migration Signed-off-by: Arun R Bharadwaj <arun@linux.vnet.ibm.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-05-11x86: add extension fields for bootloader type and versionH. Peter Anvin
A long ago, in days of yore, it all began with a god named Thor. There were vikings and boats and some plans for a Linux kernel header. Unfortunately, a single 8-bit field was used for bootloader type and version. This has generally worked without *too* much pain, but we're getting close to flat running out of ID fields. Add extension fields for both type and version. The type will be extended if it the old field is 0xE; the version is a simple MSB extension. Keep /proc/sys/kernel/bootloader_type containing (type << 4) + (ver & 0xf) for backwards compatiblity, but also add /proc/sys/kernel/bootloader_version which contains the full version number. [ Impact: new feature to support more bootloaders ] Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-05-08Merge branch 'master' into nextJames Morris
2009-05-05perf_counter: provide an mlock thresholdPeter Zijlstra
Provide a threshold to relax the mlock accounting, increasing usability. Each counter gets perf_counter_mlock_kb for free. [ Impact: allow more mmap buffering ] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> LKML-Reference: <20090505155437.112113632@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-05-02mm: prevent divide error for small values of vm_dirty_bytesAndrea Righi
Avoid setting less than two pages for vm_dirty_bytes: this is necessary to avoid potential division by 0 (like the following) in get_dirty_limits(). [ 49.951610] divide error: 0000 [#1] PREEMPT SMP [ 49.952195] last sysfs file: /sys/devices/pci0000:00/0000:00:01.1/host0/target0:0:0/0:0:0:0/block/sda/uevent [ 49.952195] CPU 1 [ 49.952195] Modules linked in: pcspkr [ 49.952195] Pid: 3064, comm: dd Not tainted 2.6.30-rc3 #1 [ 49.952195] RIP: 0010:[<ffffffff802d39a9>] [<ffffffff802d39a9>] get_dirty_limits+0xe9/0x2c0 [ 49.952195] RSP: 0018:ffff88001de03a98 EFLAGS: 00010202 [ 49.952195] RAX: 00000000000000c0 RBX: ffff88001de03b80 RCX: 28f5c28f5c28f5c3 [ 49.952195] RDX: 0000000000000000 RSI: 00000000000000c0 RDI: 0000000000000000 [ 49.952195] RBP: ffff88001de03ae8 R08: 0000000000000000 R09: 0000000000000000 [ 49.952195] R10: ffff88001ddda9a0 R11: 0000000000000001 R12: 0000000000000001 [ 49.952195] R13: ffff88001fbc8218 R14: ffff88001de03b70 R15: ffff88001de03b78 [ 49.952195] FS: 00007fe9a435b6f0(0000) GS:ffff8800025d9000(0000) knlGS:0000000000000000 [ 49.952195] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 49.952195] CR2: 00007fe9a39ab000 CR3: 000000001de38000 CR4: 00000000000006e0 [ 49.952195] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 49.952195] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 49.952195] Process dd (pid: 3064, threadinfo ffff88001de02000, task ffff88001ddda250) [ 49.952195] Stack: [ 49.952195] ffff88001fa0de00 ffff88001f2dbd70 ffff88001f9fe800 000080b900000000 [ 49.952195] 00000000000000c0 ffff8800027a6100 0000000000000400 ffff88001fbc8218 [ 49.952195] 0000000000000000 0000000000000600 ffff88001de03bb8 ffffffff802d3ed7 [ 49.952195] Call Trace: [ 49.952195] [<ffffffff802d3ed7>] balance_dirty_pages_ratelimited_nr+0x1d7/0x3f0 [ 49.952195] [<ffffffff80368f8e>] ? ext3_writeback_write_end+0x9e/0x120 [ 49.952195] [<ffffffff802cc7df>] generic_file_buffered_write+0x12f/0x330 [ 49.952195] [<ffffffff802cce8d>] __generic_file_aio_write_nolock+0x26d/0x460 [ 49.952195] [<ffffffff802cda32>] ? generic_file_aio_write+0x52/0xd0 [ 49.952195] [<ffffffff802cda49>] generic_file_aio_write+0x69/0xd0 [ 49.952195] [<ffffffff80365fa6>] ext3_file_write+0x26/0xc0 [ 49.952195] [<ffffffff803034d1>] do_sync_write+0xf1/0x140 [ 49.952195] [<ffffffff80290d1a>] ? get_lock_stats+0x2a/0x60 [ 49.952195] [<ffffffff80280730>] ? autoremove_wake_function+0x0/0x40 [ 49.952195] [<ffffffff8030411b>] vfs_write+0xcb/0x190 [ 49.952195] [<ffffffff803042d0>] sys_write+0x50/0x90 [ 49.952195] [<ffffffff8022ff6b>] system_call_fastpath+0x16/0x1b [ 49.952195] Code: 00 00 00 2b 05 09 1c 17 01 48 89 c6 49 0f af f4 48 c1 ee 02 48 89 f0 48 f7 e1 48 89 d6 31 d2 48 c1 ee 02 48 0f af 75 d0 48 89 f0 <48> f7 f7 41 8b 95 ac 01 00 00 48 89 c7 49 0f af d4 48 c1 ea 02 [ 49.952195] RIP [<ffffffff802d39a9>] get_dirty_limits+0xe9/0x2c0 [ 49.952195] RSP <ffff88001de03a98> [ 50.096523] ---[ end trace 008d7aa02f244d7b ]--- Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: David Rientjes <rientjes@google.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-29Merge branch 'linus' into perfcounters/coreIngo Molnar
Merge reason: This brach was on -rc1, refresh it to almost-rc4 to pick up the latest upstream fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-13mm: move the scan_unevictable_pages sysctl to the vm tablePeter Zijlstra
vm knobs should go in the vm table. Probably too late for randomize_va_space though. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-09perf_counter: sysctl for system wide perf countersPeter Zijlstra
Impact: add sysctl for paranoid/relaxed perfcounters policy Allow the use of system wide perf counters to everybody, but provide a sysctl to disable it for the paranoid security minded. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> LKML-Reference: <20090409085524.514046352@chello.nl> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-07Merge branch 'core/softlockup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core/softlockup' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: softlockup: make DETECT_HUNG_TASK default depend on DETECT_SOFTLOCKUP softlockup: move 'one' to the softlockup section in sysctl.c softlockup: ensure the task has been switched out once softlockup: remove timestamp checking from hung_task softlockup: convert read_lock in hung_task to rcu_read_lock softlockup: check all tasks in hung_task softlockup: remove unused definition for spawn_softlockup_task softlockup: fix potential race in hung_task when resetting timeout softlockup: fix to allow compiling with !DETECT_HUNG_TASK softlockup: decouple hung tasks check from softlockup detection
2009-04-07mm: add /proc controls for pdflush threadsPeter W Morreale
Add /proc entries to give the admin the ability to control the minimum and maximum number of pdflush threads. This allows finer control of pdflush on both large and small machines. The rationale is simply one size does not fit all. Admins on large and/or small systems may want to tune the min/max pdflush thread count to best suit their needs. Right now the min/max is hardcoded to 2/8. While probably a fair estimate for smaller machines, large machines with large numbers of CPUs and large numbers of filesystems/block devices may benefit from larger numbers of threads working on different block devices. Even if the background flushing algorithm is radically changed, it is still likely that multiple threads will be involved and admins would still desire finer control on the min/max other than to have to recompile the kernel. The patch adds '/proc/sys/vm/nr_pdflush_threads_min' and '/proc/sys/vm/nr_pdflush_threads_max' with r/w permissions. The minimum value for nr_pdflush_threads_min is 1 and the maximum value is the current value of nr_pdflush_threads_max. This minimum is required since additional thread creation is performed in a pdflush thread itself. The minimum value for nr_pdflush_threads_max is the current value of nr_pdflush_threads_min and the maximum value can be 1000. Documentation/sysctl/vm.txt is also updated. [akpm@linux-foundation.org: fix comment, fix whitespace, use __read_mostly] Signed-off-by: Peter W Morreale <pmorreale@novell.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Merge branch 'linus' into core/softlockupIngo Molnar
Conflicts: kernel/sysctl.c
