path: root/kernel/test_kprobes.c
2008-02-06kprobes: kretprobe user entry-handlerAbhishek Sagar
Provide support to add an optional user defined callback to be run at function entry of a kretprobe'd function. Also modify the kprobe smoke tests to include an entry-handler during the kretprobe sanity test. Signed-off-by: Abhishek Sagar <sagar.abhishek@gmail.com> Cc: Prasanna S Panchamukhi <prasanna@in.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Acked-by: Jim Keniston <jkenisto@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-30x86: kprobes: add kprobes smoke tests that run on bootAnanth N Mavinakayanahalli
Here is a quick and naive smoke test for kprobes. This is intended to just verify if some unrelated change broke the *probes subsystem. It is self contained, architecture agnostic and isn't of any great use by itself. This needs to be built in the kernel and runs a basic set of tests to verify if kprobes, jprobes and kretprobes run fine on the kernel. In case of an error, it'll print out a message with a "BUG" prefix. This is a start; we intend to add more tests to this bucket over time. Thanks to Jim Keniston and Masami Hiramatsu for comments and suggestions. Tested on x86 (32/64) and powerpc. Signed-off-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
