path: root/kernel/time/timer_list.c
2013-08-28timer_list: correct the iterator for timer_listNathan Zimmer
Correct an issue with /proc/timer_list reported by Holger. When reading from the proc file with a sufficiently small buffer, 2k so not really that small, there was one could get hung trying to read the file a chunk at a time. The timer_list_start function failed to account for the possibility that the offset was adjusted outside the timer_list_next. Signed-off-by: Nathan Zimmer <nzimmer@sgi.com> Reported-by: Holger Hans Peter Freyther <holger@freyther.de> Cc: John Stultz <john.stultz@linaro.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Berke Durak <berke.durak@xiphos.com> Cc: Jeff Layton <jlayton@redhat.com> Tested-by: Al Viro <viro@zeniv.linux.org.uk> Cc: <stable@vger.kernel.org> # 3.10.x Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-17timer_list: Convert timer list to be a proper seq_fileNathan Zimmer
When running with 4096 cores attemping to read /proc/timer_list will fail with an ENOMEM condition. On a sufficantly large systems the total amount of data is more then 4mb, so it won't fit into a single buffer. The failure can also occur on smaller systems when memory fragmentation is high as reported by Dave Jones. Convert /proc/timer_list to a proper seq_file with its own iterator. This is a little more complex given that we have to make two passes with two separate headers. sysrq_timer_list_show also needed to be updated to reflect the fact that now timer_list_show only does one cpu at at time. Signed-off-by: Nathan Zimmer <nzimmer@sgi.com> Reported-by: Dave Jones <davej@redhat.com> Cc: John Stultz <johnstul@us.ibm.com> Cc: Stephen Boyd <sboyd@codeaurora.org> Link: http://lkml.kernel.org/r/1364345790-14577-3-git-send-email-nzimmer@sgi.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2013-04-17timer_list: Split timer_list_show_tickdevicesNathan Zimmer
Split timer_list_show_tickdevices() into the header printout and pull the rest up to timer_list_show. This is a preparatory patch for converting timer_list to a proper seqfile with its own iterator Signed-off-by: Nathan Zimmer <nzimmer@sgi.com> Reported-by: Dave Jones <davej@redhat.com> Cc: John Stultz <johnstul@us.ibm.com> Cc: Stephen Boyd <sboyd@codeaurora.org> Link: http://lkml.kernel.org/r/1364345790-14577-2-git-send-email-nzimmer@sgi.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2012-06-11nohz: Rename ts->idle_tick to ts->last_tickFrederic Weisbecker
Now that idle and nohz logics are going to be independant each others, ts->idle_tick becomes too much a biased name to describe the field that saves the last scheduled tick on top of which we re-calculate the next tick to schedule when the timer is restarted. We want to reuse this even to stop the tick outside idle cases. So let's rename it to some more generic name: ts->last_tick. This changes a bit the timer list stat export so we need to increase its version. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Alessio Igor Bogani <abogani@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Avi Kivity <avi@redhat.com> Cc: Chris Metcalf <cmetcalf@tilera.com> Cc: Christoph Lameter <cl@linux.com> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Geoff Levand <geoff@infradead.org> Cc: Gilad Ben Yossef <gilad@benyossef.com> Cc: Hakan Akkan <hakanakkan@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Kevin Hilman <khilman@ti.com> Cc: Max Krasnyansky <maxk@qualcomm.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Sven-Thorsten Dietrich <thebigcorporation@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de>
2011-02-12timer debug: Hide kernel addresses via %pK in /proc/timer_listKees Cook
In the continuing effort to avoid kernel addresses leaking to unprivileged users, this patch switches to %pK for /proc/timer_list reporting. Signed-off-by: Kees Cook <kees.cook@canonical.com> Cc: John Stultz <johnstul@us.ibm.com> Cc: Dan Rosenberg <drosenberg@vsecurity.com> Cc: Eugene Teo <eugeneteo@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <20110212032125.GA23571@outflux.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-10hrtimers: Convert hrtimers to use timerlist infrastructureJohn Stultz
Converts the hrtimer code to use the new timerlist infrastructure Signed-off-by: John Stultz <john.stultz@linaro.org> LKML Reference: <1290136329-18291-3-git-send-email-john.stultz@linaro.org> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Thomas Gleixner <tglx@linutronix.de> CC: Richard Cochran <richardcochran@gmail.com>
2010-05-09sched: Intoduce get_cpu_iowait_time_us()Arjan van de Ven
For the ondemand cpufreq governor, it is desired that the iowait time is microaccounted in a similar way as idle time is. This patch introduces the infrastructure to account and expose this information via the get_cpu_iowait_time_us() function. [akpm@linux-foundation.org: fix CONFIG_NO_HZ=n build] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Reviewed-by: Rik van Riel <riel@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: davej@redhat.com LKML-Reference: <20100509082523.284feab6@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-12clockevents: Sanitize min_delta_ns adjustment and prevent overflowsThomas Gleixner
The current logic which handles clock events programming failures can increase min_delta_ns unlimited and even can cause overflows. Sanitize it by: - prevent zero increase when min_delta_ns == 1 - limiting min_delta_ns to a jiffie - bail out if the jiffie limit is hit - add retries stats for /proc/timer_list so we can gather data Reported-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-12-17cpumask: avoid dereferencing struct cpumaskRusty Russell
struct cpumask will be undefined soon with CONFIG_CPUMASK_OFFSTACK=y, to avoid them being declared on the stack. cpumask_bits() does what we want here (of course, this code is crap). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> To: Thomas Gleixner <tglx@linutronix.de>
2009-12-14hrtimers: Convert to raw_spinlocksThomas Gleixner
Convert locks which cannot be sleeping locks in preempt-rt to raw_spinlocks. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Ingo Molnar <mingo@elte.hu>
2009-12-10hrtimer: Tune hrtimer_interrupt hang logicThomas Gleixner
The hrtimer_interrupt hang logic adjusts min_delta_ns based on the execution time of the hrtimer callbacks. This is error-prone for virtual machines, where a guest vcpu can be scheduled out during the execution of the callbacks (and the callbacks themselves can do operations that translate to blocking operations in the hypervisor), which in can lead to large min_delta_ns rendering the system unusable. Replace the current heuristics with something more reliable. Allow the interrupt code to try 3 times to catch up with the lost time. If that fails use the total time spent in the interrupt handler to defer the next timer interrupt so the system can catch up with other things which got delayed. Limit that deferment to 100ms. The retry events and the maximum time spent in the interrupt handler are recorded and exposed via /proc/timer_list Inspired by a patch from Marcelo. Reported-by: Michael Tokarev <mjt@tls.msk.ru> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Marcelo Tosatti <mtosatti@redhat.com> Cc: kvm@vger.kernel.org
2009-11-13nohz: Allow 32-bit machines to sleep for more than 2.15 secondsJon Hunter
In the dynamic tick code, "max_delta_ns" (member of the "clock_event_device" structure) represents the maximum sleep time that can occur between timer events in nanoseconds. The variable, "max_delta_ns", is defined as an unsigned long which is a 32-bit integer for 32-bit machines and a 64-bit integer for 64-bit machines (if -m64 option is used for gcc). The value of max_delta_ns is set by calling the function "clockevent_delta2ns()" which returns a maximum value of LONG_MAX. For a 32-bit machine LONG_MAX is equal to 0x7fffffff and in nanoseconds this equates to ~2.15 seconds. Hence, the maximum sleep time for a 32-bit machine is ~2.15 seconds, where as for a 64-bit machine it will be many years. This patch changes the type of max_delta_ns to be "u64" instead of "unsigned long" so that this variable is a 64-bit type for both 32-bit and 64-bit machines. It also changes the maximum value returned by clockevent_delta2ns() to KTIME_MAX. Hence this allows a 32-bit machine to sleep for longer than ~2.15 seconds. Please note that this patch also changes "min_delta_ns" to be "u64" too and although this is unnecessary, it makes the patch simpler as it avoids to fixup all callers of clockevent_delta2ns(). [ tglx: changed "unsigned long long" to u64 as we use this data type through out the time code ] Signed-off-by: Jon Hunter <jon-hunter@ti.com> Cc: John Stultz <johnstul@us.ibm.com> LKML-Reference: <1250617512-23567-3-git-send-email-jon-hunter@ti.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-11-13clockevents: Use u32 for mult and shift factorsThomas Gleixner
The mult and shift factors of clock events differ in their data type from those of clock sources for no reason. u32 is sufficient for both. shift is always <= 32 and mult is limited to 2^32-1 to avoid 64bit multiplication overflows in the conversion. Preparatory patch for a generic mult/shift factor calculation function. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: Mikael Pettersson <mikpe@it.uu.se> Acked-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Cc: John Stultz <johnstul@us.ibm.com> LKML-Reference: <20091111134229.725664788@linutronix.de>
2009-10-01const: constify remaining file_operationsAlexey Dobriyan
[akpm@linux-foundation.org: fix KVM] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-08-17timers: Drop write permission on /proc/timer_listAmerigo Wang
/proc/timer_list and /proc/slabinfo are not supposed to be written, so there should be no write permissions on it. Signed-off-by: WANG Cong <amwang@redhat.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Vegard Nossum <vegard.nossum@gmail.com> Cc: Eduard - Gabriel Munteanu <eduard.munteanu@linux360.ro> Cc: linux-mm@kvack.org Cc: Christoph Lameter <cl@linux-foundation.org> Cc: David Rientjes <rientjes@google.com> Cc: Amerigo Wang <amwang@redhat.com> Cc: Matt Mackall <mpm@selenic.com> Cc: Arjan van de Ven <arjan@linux.intel.com> LKML-Reference: <20090817094525.6355.88682.sendpatchset@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-22Merge branch 'timers/range-hrtimers' into v28-range-hrtimers-for-linus-v2Thomas Gleixner
Conflicts: kernel/time/tick-sched.c Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-10-20timer_list: add base address to clock baseThomas Gleixner
The base address of a (per cpu) clock base is a useful debug info. Add it and bump the version number of timer_lists. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-10-20timer_list: print cpu number of clockevents deviceThomas Gleixner
The per cpu clock events device output of timer_list lacks an association of the device to the cpu which is annoying when looking at the output of /proc/timer_list from a 128 way system. Add the CPU number info and mark the broadcast device in the device list printout. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-10-20timer_list: print real timer addressThomas Gleixner
The current timer_list output prints the address of the on stack copy of the active hrtimer instead of the hrtimer itself. Print the address of the real timer instead. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-09-07hrtimer: show the timer ranges in /proc/timer_listArjan van de Ven
to help debugging and visibility of timer ranges, show them in the existing timer list in /proc/timer_list Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2008-09-05hrtimer: convert kernel/* to the new hrtimer apisArjan van de Ven
In order to be able to do range hrtimers we need to use accessor functions to the "expire" member of the hrtimer struct. This patch converts kernel/* to these accessors. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
2008-04-29kernel: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create()/proc_create_data() to make sure that ->proc_fops and ->data be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-17timer_list: print relative expiry time signedPavel Machek
Relative expiry time can get negative, so it should be signed. Signed-off-by: Pavel Machek <Pavel@suse.cz> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-02-01tick-sched: add more debug informationThomas Gleixner
To allow better diagnosis of tick-sched related, especially NOHZ related problems, we need to know when the last wakeup via an irq happened and when the CPU left the idle state. Add two fields (idle_waketime, idle_exittime) to the tick_sched structure and add them to the timer_list output. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-29timer_list: Fix printk format stringsVegard Nossum
This makes sure printk format strings contain no more than a single line. Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-07-31Fix leaks on /proc/{*/sched,sched_debug,timer_list,timer_stats}Alexey Dobriyan
On every open/close one struct seq_operations leaks. Kudos to /proc/slab_allocators. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17kallsyms: make KSYM_NAME_LEN include space for trailing '\0'Tejun Heo
KSYM_NAME_LEN is peculiar in that it does not include the space for the trailing '\0', forcing all users to use KSYM_NAME_LEN + 1 when allocating buffer. This is nonsense and error-prone. Moreover, when the caller forgets that it's very likely to subtly bite back by corrupting the stack because the last position of the buffer is always cleared to zero. This patch increments KSYM_NAME_LEN by one and updates code accordingly. * off-by-one bug in asm-powerpc/kprobes.h::kprobe_lookup_name() macro is fixed. * Where MODULE_NAME_LEN and KSYM_NAME_LEN were used together, MODULE_NAME_LEN was treated as if it didn't include space for the trailing '\0'. Fix it. Signed-off-by: Tejun Heo <htejun@gmail.com> Acked-by: Paulo Marques <pmarques@grupopie.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Fix printk format warnings in timer_list.cDavid Miller
u64 and s64 are not necessarily 'long long' on some 64-bit platforms, so explicit the type to kill the compiler warnings. Also consistently use '%Lu' which is unsigned. Signed-off-by: David S. Miller <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix race between cat /proc/*/wchan and rmmod et alAlexey Dobriyan
kallsyms_lookup() can go iterating over modules list unprotected which is OK for emergency situations (oops), but not OK for regular stuff like /proc/*/wchan. Introduce lookup_symbol_name()/lookup_module_symbol_name() which copy symbol name into caller-supplied buffer or return -ERANGE. All copying is done with module_mutex held, so... Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Simplify kallsyms_lookup()Alexey Dobriyan
Several kallsyms_lookup() pass dummy arguments but only need, say, module's name. Make kallsyms_lookup() accept NULLs where possible. Also, makes picture clearer about what interfaces are needed for all symbol resolving business. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-23[PATCH] time: fix formatting in /proc/timer_listJames Morris
Fix the print formatting of three unsigned long fields in /proc/timer_list, which are currently being formatted as signed long. Signed-off-by: James Morris <jmorris@namei.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] Add debugging feature /proc/timer_listIngo Molnar
add /proc/timer_list, which prints all currently pending (high-res) timers, all clock-event sources and their parameters in a human-readable form. Sample output: Timer List Version: v0.1 HRTIMER_MAX_CLOCK_BASES: 2 now at 4246046273872 nsecs cpu: 0 clock 0: .index: 0 .resolution: 1 nsecs .get_time: ktime_get_real .offset: 1273998312645738432 nsecs active timers: clock 1: .index: 1 .resolution: 1 nsecs .get_time: ktime_get .offset: 0 nsecs active timers: #0: <f5a90ec8>, hrtimer_sched_tick, hrtimer_stop_sched_tick, swapper/0 # expires at 4246432689566 nsecs [in 386415694 nsecs] #1: <f5a90ec8>, hrtimer_wakeup, do_nanosleep, pcscd/2050 # expires at 4247018194689 nsecs [in 971920817 nsecs] #2: <f5a90ec8>, hrtimer_wakeup, do_nanosleep, irqbalance/1909 # expires at 4247351358392 nsecs [in 1305084520 nsecs] #3: <f5a90ec8>, hrtimer_wakeup, do_nanosleep, crond/2157 # expires at 4249097614968 nsecs [in 3051341096 nsecs] #4: <f5a90ec8>, it_real_fn, do_setitimer, syslogd/1888 # expires at 4251329900926 nsecs [in 5283627054 nsecs] .expires_next : 4246432689566 nsecs .hres_active : 1 .check_clocks : 0 .nr_events : 31306 .idle_tick : 4246020791890 nsecs .tick_stopped : 1 .idle_jiffies : 986504 .idle_calls : 40700 .idle_sleeps : 36014 .idle_entrytime : 4246019418883 nsecs .idle_sleeptime : 4178181972709 nsecs cpu: 1 clock 0: .index: 0 .resolution: 1 nsecs .get_time: ktime_get_real .offset: 1273998312645738432 nsecs active timers: clock 1: .index: 1 .resolution: 1 nsecs .get_time: ktime_get .offset: 0 nsecs active timers: #0: <f5a90ec8>, hrtimer_sched_tick, hrtimer_restart_sched_tick, swapper/0 # expires at 4246050084568 nsecs [in 3810696 nsecs] #1: <f5a90ec8>, hrtimer_wakeup, do_nanosleep, atd/2227 # expires at 4261010635003 nsecs [in 14964361131 nsecs] #2: <f5a90ec8>, hrtimer_wakeup, do_nanosleep, smartd/2332 # expires at 5469485798970 nsecs [in 1223439525098 nsecs] .expires_next : 4246050084568 nsecs .hres_active : 1 .check_clocks : 0 .nr_events : 24043 .idle_tick : 4246046084568 nsecs .tick_stopped : 0 .idle_jiffies : 986510 .idle_calls : 26360 .idle_sleeps : 22551 .idle_entrytime : 4246043874339 nsecs .idle_sleeptime : 4170763761184 nsecs tick_broadcast_mask: 00000003 event_broadcast_mask: 00000001 CPU#0's local event device: Clock Event Device: lapic capabilities: 0000000e max_delta_ns: 807385544 min_delta_ns: 1443 mult: 44624025 shift: 32 set_next_event: lapic_next_event set_mode: lapic_timer_setup event_handler: hrtimer_interrupt .installed: 1 .expires: 4246432689566 nsecs CPU#1's local event device: Clock Event Device: lapic capabilities: 0000000e max_delta_ns: 807385544 min_delta_ns: 1443 mult: 44624025 shift: 32 set_next_event: lapic_next_event set_mode: lapic_timer_setup event_handler: hrtimer_interrupt .installed: 1 .expires: 4246050084568 nsecs Clock Event Device: hpet capabilities: 00000007 max_delta_ns: 2147483647 min_delta_ns: 3352 mult: 61496110 shift: 32 set_next_event: hpet_next_event set_mode: hpet_set_mode event_handler: handle_nextevt_broadcast Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: john stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
