path: root/kernel/time
2006-10-28[PATCH] time_adjust cleared before useJim Houston
I notice that the code which implements adjtime clears the time_adjust value before using it. The attached patch makes the obvious fix. Acked-by: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Jim Houston <jim.houston@ccur.com> Cc: John Stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] i386 Time: Avoid PIT SMP lockupsjohn stultz
Avoid possible PIT livelock issues seen on SMP systems (and reported by Andi), by not allowing it as a clocksource on SMP boxes. However, since the PIT may no longer be present, we have to properly handle the cases where SMP systems have TSC skew and fall back from the TSC. Since the PIT isn't there, it would "fall back" to the TSC again. So this changes the jiffies rating to 1, and the TSC-bad rating value to 0. Thus you will get the following behavior priority on i386 systems: tsc [if present & stable] hpet [if present] cyclone [if present] acpi_pm [if present] pit [if UP] jiffies Rather then the current more complicated: tsc [if present & stable] hpet [if present] cyclone [if present] acpi_pm [if present] pit [if cpus < 4] tsc [if present & unstable] jiffies Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Andi Kleen <ak@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] kernel/time/ntp.c: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make the following needlessly global function static: - ntp_update_frequency() - make the following needlessly global variables static: - time_state - time_offset - time_constant - time_reftime - remove the following read-only global variable: - time_precision Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] ntp: convert to the NTP4 reference modelRoman Zippel
This converts the kernel ntp model into a model which matches the nanokernel reference implementations. The previous patches already increased the resolution and precision of the computations, so that this conversion becomes quite simple. <linux@horizon.com> explains: The original NTP kernel interface was defined in units of microseconds. That's what Linux implements. As computers have gotten faster and can now split microseconds easily, a new kernel interface using nanosecond units was defined ("the nanokernel", confusing as that name is to OS hackers), and there's an STA_NANO bit in the adjtimex() status field to tell the application which units it's using. The current ntpd supports both, but Linux loses some possible timing resolution because of quantization effects, and the ntpd hackers would really like to be able to drop the backwards compatibility code. Ulrich Windl has been maintaining a patch set to do the conversion for years, but it's hard to keep in sync. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] ntp: convert time_freq to nsec valueRoman Zippel
This converts time_freq to a scaled nsec value and adds around 6bit of extra resolution. This pushes the time_freq to its 32bit limits so the calculatons have to be done with 64bit. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] ntp: remove time_toleranceRoman Zippel
time_tolerance isn't changed at all in the kernel, so simply remove it, this simplifies the next patch, as it avoids a number of conversions. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] ntp: add time_adjust to tick lengthRoman Zippel
This folds update_ntp_one_tick() into second_overflow() and adds time_adjust to the tick length, this makes time_next_adjust unnecessary. This slightly changes the adjtime() behaviour, instead of applying it to the next tick, it's applied to the next second. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] ntp: prescale time_offsetRoman Zippel
This converts time_offset into a scaled per tick value. This avoids now completely the crude compensation in second_overflow(). Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] ntp: add time_freq to tick lengthRoman Zippel
This adds the frequency part to ntp_update_frequency(). Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] ntp: add time_adj to tick lengthRoman Zippel
This makes time_adj local to second_overflow() and integrates it into the tick length instead of adding it everytime. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] ntp: add ntp_update_frequencyRoman Zippel
This introduces ntp_update_frequency() and deinlines ntp_clear() (as it's not performance critical). ntp_update_frequency() calculates the base tick length using tick_usec and adds a base adjustment, in case the frequency doesn't divide evenly by HZ. Signed-off-by: Roman Zippel <zippel@linux-m68k.org> Cc: john stultz <johnstul@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] NTP: Move all the NTP related code to ntp.cjohn stultz
Move all the NTP related code to ntp.c [akpm@osdl.org: cleanups, build fix] Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] time: rename clocksource functionsjohn stultz
As suggested by Roman Zippel, change clocksource functions to use clocksource_xyz rather then xyz_clocksource to avoid polluting the namespace. Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Time: i386 Clocksource Driversjohn stultz
Implement the time sources for i386 (acpi_pm, cyclone, hpet, pit, and tsc). With this patch, the conversion of the i386 arch to the generic timekeeping code should be complete. The patch should be fairly straight forward, only adding the new clocksources. [hirofumi@mail.parknet.co.jp: acpi_pm cleanup] Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Time: Use clocksource infrastructure for update_wall_timejohn stultz
Modify the update_wall_time function so it increments time using the clocksource abstraction instead of jiffies. Since the only clocksource driver currently provided is the jiffies clocksource, this should result in no functional change. Additionally, a timekeeping_init and timekeeping_resume function has been added to initialize and maintain some of the new timekeping state. [hirofumi@mail.parknet.co.jp: fixlet] Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] Time: Clocksource Infrastructurejohn stultz
This introduces the clocksource management infrastructure. A clocksource is a driver-like architecture generic abstraction of a free-running counter. This code defines the clocksource structure, and provides management code for registering, selecting, accessing and scaling clocksources. Additionally, this includes the trivial jiffies clocksource, a lowest common denominator clocksource, provided mainly for use as an example. [hirofumi@mail.parknet.co.jp: Don't enable IRQ too early] Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
