Needed in followon patch.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
avenrun is an rough estimate so we don't have to worry about
consistency of the three avenrun values. Remove the xtime lock
dependency and provide a function to scale the values. Cleanup the
users.
[ Impact: cleanup ]
Acked-by: Peter Zijlstra <peterz@infradead.org>
Dimitri Sivanich noticed that xtime_lock is held write locked across
calc_load() which iterates over all online CPUs. That can cause long
latencies for xtime_lock readers on large SMP systems.
The load average calculation is an rough estimate anyway so there is
no real need to protect the readers vs. the update. It's not a problem
when the avenrun array is updated while a reader copies the values.
Instead of iterating over all online CPUs let the scheduler_tick code
update the number of active tasks shortly before the avenrun update
happens. The avenrun update itself is handled by the CPU which calls
do_timer().
[ Impact: reduce xtime_lock write locked section ]
* Arun R Bharadwaj <arun@linux.vnet.ibm.com> [2009-04-16 12:11:36]:
This patch migrates all non pinned timers and hrtimers to the current
idle load balancer, from all the idle CPUs. Timers firing on busy CPUs
are not migrated.
While migrating hrtimers, care should be taken to check if migrating
a hrtimer would result in a latency or not. So we compare the expiry of the
hrtimer with the next timer interrupt on the target cpu and migrate the
hrtimer only if it expires *after* the next interrupt on the target cpu.
So, added a clockevents_get_next_event() helper function to return the
next_event on the target cpu's clock_event_device.
[ tglx: cleanups and simplifications ]
Signed-off-by: Arun R Bharadwaj <arun@linux.vnet.ibm.com>
This patch creates a new framework for identifying cpu-pinned timers
and hrtimers.
This framework is needed because pinned timers are expected to fire on
the same CPU on which they are queued. So it is essential to identify
these and not migrate them, in case there are any.
For regular timers, the currently existing add_timer_on() can be used
queue pinned timers and subsequently mod_timer_pinned() can be used
to modify the 'expires' field.
For hrtimers, new modes HRTIMER_ABS_PINNED and HRTIMER_REL_PINNED are
added to queue cpu-pinned hrtimer.
[ tglx: use .._PINNED mode argument instead of creating tons of new
functions ]
In the current kernel implementation only kernel timers for time interval
tv1 are being deferred. This patch allows any timer that is configured as
deferrable to be defer regardless of time interval.
This patch was previously discussed in
http://marc.info/?l=linux-kernel&m=123196343531966&w=2 and was acked by
Venki Pallipadi, the author of the original deferrable timer patch.
Signed-off-by: Jon Hunter <jon-hunter@ti.com>
Acked-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com>
Merge reason: This brach was on -rc1, refresh it to almost-rc4 to pick up
the latest upstream fixes.
'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip
* 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
printk: fix wrong format string iter for printk
futex: comment requeue key reference semantics
* 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
irq: fix cpumask memory leak on offstack cpumask kernels
* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
posix-timers: fix RLIMIT_CPU && setitimer(CPUCLOCK_PROF)
posix-timers: fix RLIMIT_CPU && fork()
timers: add missing kernel-doc
While going over the wakeup code I noticed delayed wakeups only work
for hardware counters but basically all software counters rely on
them.
This patch unifies and generalizes the delayed wakeup to fix this
issue.
Since we're dealing with NMI context bits here, use a cmpxchg() based
single link list implementation to track counters that have pending
wakeups.
[ This should really be generic code for delayed wakeups, but since we
cannot use cmpxchg()/xchg() in generic code, I've let it live in the
perf_counter code. -- Eric Dumazet could use it to aggregate the
network wakeups. ]
Furthermore, the x86 method of using TIF flags was flawed in that its
quite possible to end up setting the bit on the idle task, loosing the
wakeup.
The powerpc method uses per-cpu storage and does appear to be
sufficient.
Acked-by: Paul Mackerras <paulus@samba.org>
Orig-LKML-Reference: <20090330171023.153932974@chello.nl>
Add missing kernel-doc parameter notation and change function
name to its new name:
Warning(kernel/timer.c:543): No description found for parameter 'name'
Warning(kernel/timer.c:543): No description found for parameter 'key'
Cc: akpm <akpm@linux-foundation.org>
Cc: Johannes Berg <johannes@sipsolutions.net>
LKML-Reference: <20090401174723.f0bea0eb.randy.dunlap@oracle.com>
* 'locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (33 commits)
lockdep: fix deadlock in lockdep_trace_alloc
lockdep: annotate reclaim context (__GFP_NOFS), fix SLOB
lockdep: build fix for !PROVE_LOCKING
lockstat: warn about disabled lock debugging
lockdep: use stringify.h
lockdep: simplify check_prev_add_irq()
lockdep: get_user_chars() redo
lockdep: simplify get_user_chars()
lockdep: add comments to mark_lock_irq()
lockdep: remove macro usage from mark_held_locks()
lockdep: fully reduce mark_lock_irq()
lockdep: merge the !_READ mark_lock_irq() helpers
lockdep: merge the _READ mark_lock_irq() helpers
lockdep: simplify mark_lock_irq() helpers #3
lockdep: further simplify mark_lock_irq() helpers
lockdep: simplify the mark_lock_irq() helpers
lockdep: split up mark_lock_irq()
lockdep: generate usage strings
lockdep: generate the state bit definitions
Impact: new timer API
Based on an idea from Martin Josefsson with the help of
Patrick McHardy and Stephen Hemminger:
introduce the mod_timer_pending() API which is a mod_timer()
offspring that is an invariant on already removed timers.
(regular mod_timer() re-activates non-pending timers.)
This is useful for the networking code in that it can
allow unserialized mod_timer_pending() timer-forwarding
calls, but a single del_timer*() will stop the timer
from being reactivated again.
Also while at it:
- optimize the regular mod_timer() path some more, the
timer-stat and a debug check was needlessly duplicated
in __mod_timer().
- make the exports come straight after the function, as
most other exports in timer.c already did.
- eliminate __mod_timer() as an external API, change the
users to mod_timer().
The regular mod_timer() code path is not impacted
significantly, due to inlining optimizations and due to
the simplifications.
Based-on-patch-from: Stephen Hemminger <shemminger@vyatta.com>
Acked-by: Stephen Hemminger <shemminger@vyatta.com>
Cc: Patrick McHardy <kaber@trash.net>
Cc: netdev@vger.kernel.org
This modifies the timer code in a way to allow lockdep to detect
deadlocks resulting from a lock being taken in the timer function
as well as around the del_timer_sync() call.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Convert all system calls to return a long. This should be a NOP since all
converted types should have the same size anyway.
With the exception of sys_exit_group which returned void. But that doesn't
matter since the system call doesn't return.
The cpu time spent by the idle process actually doing something is
currently accounted as idle time. This is plain wrong, the architectures
that support VIRT_CPU_ACCOUNTING=y can do better: distinguish between the
time spent doing nothing and the time spent by idle doing work. The first
is accounted with account_idle_time and the second with account_system_time.
The architectures that use the account_xxx_time interface directly and not
the account_xxx_ticks interface now need to do the check for the idle
process in their arch code. In particular to improve the system vs true
idle time accounting the arch code needs to measure the true idle time
instead of just testing for the idle process.
To improve the tick based accounting as well we would need an architecture
primitive that can tell us if the pt_regs of the interrupted context
points to the magic instruction that halts the cpu.
In addition idle time is no more added to the stime of the idle process.
This field now contains the system time of the idle process as it should
be. On systems without VIRT_CPU_ACCOUNTING this will always be zero as
every tick that occurs while idle is running will be accounted as idle
time.
This patch contains the necessary common code changes to be able to
distinguish idle system time and true idle time. The architectures with
support for VIRT_CPU_ACCOUNTING need some changes to exploit this.
The utimescaled / stimescaled fields in the task structure and the
global cpustat should be set on all architectures. On s390 the calls
to account_user_time_scaled and account_system_time_scaled never have
been added. In addition system time that is accounted as guest time
to the user time of a process is accounted to the scaled system time
instead of the scaled user time.
To fix the bugs and to prevent future forgetfulness this patch merges
account_system_time_scaled into account_system_time and
account_user_time_scaled into account_user_time.
Cc: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Cc: Jeremy Fitzhardinge <jeremy@xensource.com>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: Michael Neuling <mikey@neuling.org>
security/keys/internal.h
security/keys/process_keys.c
security/keys/request_key.c
Fixed conflicts above by using the non 'tsk' versions.
Signed-off-by: James Morris <jmorris@namei.org>
Wrap access to task credentials so that they can be separated more easily from
the task_struct during the introduction of COW creds.
Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id().
Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more
sense to use RCU directly rather than a convenient wrapper; these will be
addressed by later patches.
Reviewed-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Cc: linux-audit@redhat.com
Cc: containers@lists.linux-foundation.org
Cc: linux-mm@kvack.org
This patch (as1158b) adds round_jiffies_up() and friends. These
routines work like the analogous round_jiffies() functions, except
that they will never round down.
The new routines will be useful for timeouts where we don't care
exactly when the timer expires, provided it doesn't expire too soon.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
'timers/ntp', 'timers/posixtimers' and 'timers/debug' into v28-timers-for-linus
Add the comment to explain why the double lock in migrate_timers()
can't deadlock.
Change the code to use spinlock_irq() instead of local_irq_disable()
+ spin_lock().
Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru>
Acked-by: Steven Rostedt <srostedt@redhat.com>
Avoid deadlocks against rq->lock and xtime_lock by deferring the klogd
wakeup by polling from the timer tick.
* 'for-linus' of master.kernel.org:/home/rmk/linux-2.6-arm: (241 commits)
[ARM] 5171/1: ep93xx: fix compilation of modules using clocks
[ARM] 5133/2: at91sam9g20 defconfig file
[ARM] 5130/4: Support for the at91sam9g20
[ARM] 5160/1: IOP3XX: gpio/gpiolib support
[ARM] at91: Fix NAND FLASH timings for at91sam9x evaluation kits.
[ARM] 5084/1: zylonite: Register AC97 device
[ARM] 5085/2: PXA: Move AC97 over to the new central device declaration model
[ARM] 5120/1: pxa: correct platform driver names for PXA25x and PXA27x UDC drivers
[ARM] 5147/1: pxaficp_ir: drop pxa_gpio_mode calls, as pin setting
[ARM] 5145/1: PXA2xx: provide api to control IrDA pins state
[ARM] 5144/1: pxaficp_ir: cleanup includes
[ARM] pxa: remove pxa_set_cken()
[ARM] pxa: allow clk aliases
[ARM] Feroceon: don't disable BPU on boot
[ARM] Orion: LED support for HP mv2120
[ARM] Orion: add RD88F5181L-FXO support
[ARM] Orion: add RD88F5181L-GE support
[ARM] Orion: add Netgear WNR854T support
[ARM] s3c2410_defconfig: update for current build
[ARM] Acer n30: Minor style and indentation fixes.
As git-grep shows, open_softirq() is always called with the last argument
being NULL
block/blk-core.c: open_softirq(BLOCK_SOFTIRQ, blk_done_softirq, NULL);
kernel/hrtimer.c: open_softirq(HRTIMER_SOFTIRQ, run_hrtimer_softirq, NULL);
kernel/rcuclassic.c: open_softirq(RCU_SOFTIRQ, rcu_process_callbacks, NULL);
kernel/rcupreempt.c: open_softirq(RCU_SOFTIRQ, rcu_process_callbacks, NULL);
kernel/sched.c: open_softirq(SCHED_SOFTIRQ, run_rebalance_domains, NULL);
kernel/softirq.c: open_softirq(TASKLET_SOFTIRQ, tasklet_action, NULL);
kernel/softirq.c: open_softirq(HI_SOFTIRQ, tasklet_hi_action, NULL);
kernel/timer.c: open_softirq(TIMER_SOFTIRQ, run_timer_softirq, NULL);
net/core/dev.c: open_softirq(NET_TX_SOFTIRQ, net_tx_action, NULL);
net/core/dev.c: open_softirq(NET_RX_SOFTIRQ, net_rx_action, NULL);
This observation has already been made by Matthew Wilcox in June 2002
(http://www.cs.helsinki.fi/linux/linux-kernel/2002-25/0687.html)
"I notice that none of the current softirq routines use the data element
passed to them."
and the situation hasn't changed since them. So it appears we can safely
remove that extra argument to save 128 (54) bytes of kernel data (text).
Signed-off-by: Carlos R. Mafra <crmafra@ift.unesp.br>
Remove the last reminants of dyntick support from the generic kernel.
Add calls to the generic object debugging infrastructure and provide fixup
functions which allow to keep the system alive when recoverable problems have
been detected by the object debugging core code.
Cc: Greg KH <greg@kroah.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
In order to avoid the false positive from lockdep, each per-cpu base->lock has
the separate lock class and migrate_timers() uses double_spin_lock().
This all is overcomplicated: except for migrate_timers() we never take 2 locks
at once, and migrate_timers() can use spin_lock_nested().
Cc: Arjan van de Ven <arjan@linux.intel.com>
add_timer_on() can add a timer on a CPU which is currently in a long
idle sleep, but the timer wheel is not reevaluated by the nohz code on
that CPU. So a timer can be delayed for quite a long time. This
triggered a false positive in the clocksource watchdog code.
To avoid this we need to wake up the idle CPU and enforce the
reevaluation of the timer wheel for the next timer event.
Add a function, which checks a given CPU for idle state, marks the
idle task with NEED_RESCHED and sends a reschedule IPI to notify the
other CPU of the change in the timer wheel.
Call this function from add_timer_on().
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
Cc: stable@kernel.org
include/linux/sched.h | 6 ++++++
kernel/sched.c | 43 +++++++++++++++++++++++++++++++++++++++++++
kernel/timer.c | 10 +++++++++-
3 files changed, 58 insertions(+), 1 deletion(-)
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Some time ago the xxx_vnr() calls (e.g. pid_vnr or find_task_by_vpid) were
_all_ converted to operate on the current pid namespace. After this each call
like xxx_nr_ns(foo, current->nsproxy->pid_ns) is nothing but a xxx_vnr(foo)
one.
Switch all the xxx_nr_ns() callers to use the xxx_vnr() calls where
appropriate.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Reviewed-by: Oleg Nesterov <oleg@tv-sign.ru>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Balbir Singh <balbir@in.ibm.com>
This moves the ability to scale cputime into generic code. This allows us
to fix the issue in kernel/timer.c (noticed by Balbir) where we could only
add an unscaled value to the scaled utime/stime.
This adds a cputime_to_scaled function. As before, the POWERPC version
does the scaling based on the last SPURR/PURR ratio calculated. The
generic and s390 (only other arch to implement asm/cputime.h) versions are
both NOPs.
Also moves the SPURR and PURR snapshots closer.
Signed-off-by: Michael Neuling <mikey@neuling.org>
Cc: Jay Lan <jlan@engr.sgi.com>
git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc
* 'task_killable' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/misc: (22 commits)
Remove commented-out code copied from NFS
NFS: Switch from intr mount option to TASK_KILLABLE
Add wait_for_completion_killable
Add wait_event_killable
Add schedule_timeout_killable
Use mutex_lock_killable in vfs_readdir
Add mutex_lock_killable
Use lock_page_killable
Add lock_page_killable
Add fatal_signal_pending
Add TASK_WAKEKILL
exit: Use task_is_*
signal: Use task_is_*
sched: Use task_contributes_to_load, TASK_ALL and TASK_NORMAL
ptrace: Use task_is_*
power: Use task_is_*
wait: Use TASK_NORMAL
proc/base.c: Use task_is_*
proc/array.c: Use TASK_REPORT
perfmon: Use task_is_*
Fixed up conflicts in NFS/sunrpc manually..
Small cleanups to tick-related code. Wrong preempt count is followed
by BUG(), so it is hardly KERN_WARNING.
Signed-off-by: Pavel Machek <pavel@suse.cz>
Cc: john stultz <johnstul@us.ibm.com>
Clean up hungarian notation from timer code.
Currently all highres=off timers are run from softirq context, but
HRTIMER_CB_IRQSAFE_NO_SOFTIRQ timers expect to run from irq context.
Fix this up by splitting it similar to the highres=on case.
The caller is __cpuinit.
Also, this code block and its caller are inside #ifdef CONFIG_HOTPLUG_CPU
blocks, so this code should reflect that config symbol's usage.
WARNING: vmlinux.o(.text+0x4252f): Section mismatch: reference to .init.text: (between 'timer_cpu_notify' and 'msleep')
Signed-off-by: Linus Torvalds <torvalds@akpm@linux-foundation.org>
task_ppid_nr_ns is called in three places. One of these should never
have called it. In the other two, using it broke the existing
semantics. This was presumably accidental. If the function had not
been there, it would have been much more obvious to the eye that those
patches were changing the behavior. We don't need this function.
In task_state, the pid of the ptracer is not the ppid of the ptracer.
In do_task_stat, ppid is the tgid of the real_parent, not its pid.
I also moved the call outside of lock_task_sighand, since it doesn't
need it.
In sys_getppid, ppid is the tgid of the real_parent, not its pid.
Signed-off-by: Roland McGrath <roland@redhat.com>
This patch fixes the following section mismatches with CONFIG_HOTPLUG=n,
CONFIG_HOTPLUG_CPU=y:
WARNING: vmlinux.o(.text+0x41cd3): Section mismatch: reference to .init.data:tvec_base_done.22610 (between 'timer_cpu_notify' and 'run_timer_softirq')
WARNING: vmlinux.o(.text+0x41d67): Section mismatch: reference to .init.data:tvec_base_done.22610 (between 'timer_cpu_notify' and 'run_timer_softirq')
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Since powerpc started using CONFIG_GENERIC_CLOCKEVENTS, the
deterministic CPU accounting (CONFIG_VIRT_CPU_ACCOUNTING) has been
broken on powerpc, because we end up counting user time twice: once in
timer_interrupt() and once in update_process_times().
This fixes the problem by pulling the code in update_process_times
that updates utime and stime into a separate function called
account_process_tick. If CONFIG_VIRT_CPU_ACCOUNTING is not defined,
there is a version of account_process_tick in kernel/timer.c that
simply accounts a whole tick to either utime or stime as before. If
CONFIG_VIRT_CPU_ACCOUNTING is defined, then arch code gets to
implement account_process_tick.
This also lets us simplify the s390 code a bit; it means that the s390
timer interrupt can now call update_process_times even when
CONFIG_VIRT_CPU_ACCOUNTING is turned on, and can just implement a
suitable account_process_tick().
account_process_tick() now takes the task_struct * as an argument.
Tested both with and without CONFIG_VIRT_CPU_ACCOUNTING.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
This is the largest patch in the set. Make all (I hope) the places where
the pid is shown to or get from user operate on the virtual pids.
The idea is:
- all in-kernel data structures must store either struct pid itself
or the pid's global nr, obtained with pid_nr() call;
- when seeking the task from kernel code with the stored id one
should use find_task_by_pid() call that works with global pids;
- when showing pid's numerical value to the user the virtual one
should be used, but however when one shows task's pid outside this
task's namespace the global one is to be used;
- when getting the pid from userspace one need to consider this as
the virtual one and use appropriate task/pid-searching functions.
[akpm@linux-foundation.org: build fix]
[akpm@linux-foundation.org: nuther build fix]
[akpm@linux-foundation.org: yet nuther build fix]
[akpm@linux-foundation.org: remove unneeded casts]
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Paul Menage <menage@google.com>
This adds items to the taststats struct to account for user and system
time based on scaling the CPU frequency and instruction issue rates.
Adds account_(user|system)_time_scaled callbacks which architectures
can use to account for time using this mechanism.
Signed-off-by: Daniel Walker <dwalker@mvista.com>
Remove time_interpolator code (This is generic code, but
only user was ia64. It has been superseded by the
CONFIG_GENERIC_TIME code).
Signed-off-by: Bob Picco <bob.picco@hp.com>
Signed-off-by: John Stultz <johnstul@us.ibm.com>
Signed-off-by: Peter Keilty <peter.keilty@hp.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
