Revert the RT patch:
Author: Ingo Molnar <mingo@elte.hu>
Date: Fri Jul 3 08:30:32 2009 -0500
timers: fix timer hotplug on -rt
Here we are in the CPU_DEAD notifier, and we must not sleep nor
enable interrupts.
There's no problem with sleeping in this notifier.
But the get_cpu_var() had to be converted to a get_local_var().
Replace the previous fix with the get_local_var() convert.
Cc: Carsten Emde <C.Emde@osadl.org>
Cc: John Kacur <jkacur@redhat.com>
Cc: Clark Williams <clark.williams@gmail.com>
Cc: stable-rt@vger.kernel.org
Link: http://lkml.kernel.org/r/20120301190344.948157137@goodmis.org
On RT that code is preemptible, so we cannot assign NULL to timers
base as a preempter would spin forever in lock_timer_base().
People were complaining about broken balancing with the recent -rt
series.
A look at /proc/sched_debug yielded:
cpu#0, 2393.874 MHz
.nr_running : 0
.load : 0
.cpu_load[0] : 177522
.cpu_load[1] : 177522
.cpu_load[2] : 177522
.cpu_load[3] : 177522
.cpu_load[4] : 177522
cpu#1, 2393.874 MHz
.nr_running : 4
.load : 4096
.cpu_load[0] : 181618
.cpu_load[1] : 180850
.cpu_load[2] : 180274
.cpu_load[3] : 179938
.cpu_load[4] : 179758
Which indicated the cpu_load computation was hosed, the 177522 value
indicates that there is one RT task runnable. Initially I thought the
old problem of calculating the cpu_load from a softirq had re-surfaced,
however looking at the code shows its being done from scheduler_tick().
[ we really should fix this RT/cfs interaction some day... ]
A few trace_printk()s later:
sirq-timer/1-19 [001] 174.289744: 19: 50:S ==> [001] 0:140:R <idle>
<idle>-0 [001] 174.290724: enqueue_task_rt: adding task: 19/sirq-timer/1 with load: 177522
<idle>-0 [001] 174.290725: 0:140:R + [001] 19: 50:S sirq-timer/1
<idle>-0 [001] 174.290730: scheduler_tick: current load: 177522
<idle>-0 [001] 174.290732: scheduler_tick: current: 0/swapper
<idle>-0 [001] 174.290736: 0:140:R ==> [001] 19: 50:R sirq-timer/1
sirq-timer/1-19 [001] 174.290741: dequeue_task_rt: removing task: 19/sirq-timer/1 with load: 177522
sirq-timer/1-19 [001] 174.290743: 19: 50:S ==> [001] 0:140:R <idle>
We see that we always raise the timer softirq before doing the load
calculation. Avoid this by re-ordering the scheduler_tick() call in
update_process_times() to occur before we deal with timers.
This lowers the load back to sanity and restores regular load-balancing
behaviour.
enable interrupts.
When softirqs can be preempted we need to make sure that cancelling
the timer from the active thread can not deadlock vs. a running timer
callback. Add a waitqueue to resolve that.
* 'core-debugobjects-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
timer: Use debugobjects to catch deletion of uninitialized timers
timer: Setup uninitialized timer with a stub callback
debugobjects: Extend to assert that an object is initialized
debugobjects: Be smarter about static objects
In order to safely dereference current->real_parent inside an
rcu_read_lock, we need an rcu_dereference.
Signed-off-by: Mandeep Singh Baines <msb@chromium.org>
Cc: Pavel Emelyanov <xemul@openvz.org>
del_timer_sync() calls debug_object_assert_init() to assert that
a timer has been initialized before calling lock_timer_base().
lock_timer_base() would spin forever on a NULL(uninit-ed) base.
The check is added to del_timer() to prevent silent failure, even
though it would not get stuck in an infinite loop.
[ sboyd@codeaurora.org: Remove WARN, intialize timer function]
Signed-off-by: Christine Chan <cschan@codeaurora.org>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: John Stultz <john.stultz@linaro.org>
Link: http://lkml.kernel.org/r/1320724108-20788-4-git-send-email-sboyd@codeaurora.org
Remove the WARN_ON() in timer_fixup_activate() as we now get the
debugobjects printout in the debugobjects activate check.
We also assign a dummy timer callback so that if the timer is
actually set to fire we don't oops.
[ tglx@linutronix.de: Split out the debugobjects vs. the timer change ]
Cc: Christine Chan <cschan@codeaurora.org>
Link: http://lkml.kernel.org/r/1320724108-20788-2-git-send-email-sboyd@codeaurora.org
The changed files were only including linux/module.h for the
EXPORT_SYMBOL infrastructure, and nothing else. Revector them
onto the isolated export header for faster compile times.
Nothing to see here but a whole lot of instances of:
-#include <linux/module.h>
+#include <linux/export.h>
This commit is only changing the kernel dir; next targets
will probably be mm, fs, the arch dirs, etc.
There is an optimization which does not update the timer if the timer
was pending and the expiration time was unchanged.
Since commit 3bbb9ec9 ("timers: Introduce the concept of timer slack
for legacy timers") this optimization is no longer applied for timers
where the expiration time got extended due to the slack value. So we
need to check again after the expiration time might have been updated.
[ tglx: Made it a single check by applying slack first and sorting
out the slack = 0 value (all timeouts < 256 jiffies) early ]
Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Link: http://lkml.kernel.org/r/20110521105828.GA29442@Chamillionaire.breakpoint.cc
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (62 commits)
posix-clocks: Check write permissions in posix syscalls
hrtimer: Remove empty hrtimer_init_hres_timer()
hrtimer: Update hrtimer->state documentation
hrtimer: Update base[CLOCK_BOOTTIME].offset correctly
timers: Export CLOCK_BOOTTIME via the posix timers interface
timers: Add CLOCK_BOOTTIME hrtimer base
time: Extend get_xtime_and_monotonic_offset() to also return sleep
time: Introduce get_monotonic_boottime and ktime_get_boottime
hrtimers: extend hrtimer base code to handle more then 2 clockids
ntp: Remove redundant and incorrect parameter check
mn10300: Switch do_timer() to xtimer_update()
posix clocks: Introduce dynamic clocks
posix-timers: Cleanup namespace
posix-timers: Add support for fd based clocks
x86: Add clock_adjtime for x86
posix-timers: Introduce a syscall for clock tuning.
time: Splitout compat timex accessors
ntp: Add ADJ_SETOFFSET mode bit
time: Introduce timekeeping_inject_offset
posix-timer: Update comment
Fix up new system-call-related conflicts in
arch/x86/ia32/ia32entry.S
arch/x86/include/asm/unistd_32.h
arch/x86/include/asm/unistd_64.h
arch/x86/kernel/syscall_table_32.S
(name_to_handle_at()/open_by_handle_at() vs clock_adjtime()), and some
due to movement of get_jiffies_64() in:
kernel/time.c
* 'core-locking-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rtmutex: tester: Remove the remaining BKL leftovers
lockdep/timers: Explain in detail the locking problems del_timer_sync() may cause
rtmutex: Simplify PI algorithm and make highest prio task get lock
rwsem: Remove redundant asmregparm annotation
rwsem: Move duplicate function prototypes to linux/rwsem.h
rwsem: Unify the duplicate rwsem_is_locked() inlines
rwsem: Move duplicate init macros and functions to linux/rwsem.h
rwsem: Move duplicate struct rwsem declaration to linux/rwsem.h
x86: Cleanup rwsem_count_t typedef
rwsem: Cleanup includes
locking: Remove deprecated lock initializers
cred: Replace deprecated spinlock initialization
kthread: Replace deprecated spinlock initialization
xtensa: Replace deprecated spinlock initialization
um: Replace deprecated spinlock initialization
sparc: Replace deprecated spinlock initialization
mips: Replace deprecated spinlock initialization
cris: Replace deprecated spinlock initialization
alpha: Replace deprecated spinlock initialization
rtmutex-tester: Remove BKL tests
In complex subsystems like mac80211 structures can contain several
timers and work structs, so identifying a specific instance from the
call trace and object type output of debugobjects can be hard.
Allow the subsystems which support debugobjects to provide a hint
function. This function returns a pointer to a kernel address
(preferrably the objects callback function) which is printed along
with the debugobjects type.
Add hint methods for timer_list, work_struct and hrtimer.
[ tglx: Massaged changelog, made it compile ]
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
LKML-Reference: <20110307085809.GA9334@redhat.com>
cause
Twice I had to explain the output about why lockdep gives an error with
locks in IRQ context and with del_timer_sync(). Might as well write it
up and place it in the comments above the code in del_timer_sync().
Perhaps the next time this lockdep dump triggers people will understand
the issues.
It is a ticky issue and very subtle, explaining it in detail in the code
may help others understand the issue when they stumble upon the bug
again.
LKML-Reference: <1297186794.23343.19.camel@gandalf.stny.rr.com>
Both attempts at trying to allow softirq usage for
del_timer_sync() failed (produced bogus warnings),
so revert the commit for this release:
f266a5110d45: lockdep, timer: Fix del_timer_sync() annotation
and try again later.
Reported-by: Borislav Petkov <bp@alien8.de>
Cc: Yong Zhang <yong.zhang0@gmail.com>
LKML-Reference: <1297174680.13327.107.camel@laptop>
Calling local_bh_enable() will want to actually start processing
softirqs, which isn't a good idea since this can get called with IRQs
disabled.
Cure this by using _local_bh_enable() which doesn't start processing
softirqs, and use raw_local_irq_save() to avoid any softirqs from
happening without letting lockdep think IRQs are in fact disabled.
Reported-by: Nick Bowler <nbowler@elliptictech.com>
Reviewed-by: Yong Zhang <yong.zhang0@gmail.com>
LKML-Reference: <20110203141548.039540914@chello.nl>
do_timer() is primary timekeeping related. calc_global_load() is
called from do_timer() as well, but that's more for historical
reasons.
[ tglx: Fixed up the calc_global_load() reject andmassaged changelog ]
Signed-off-by: Torben Hohn <torbenh@gmx.de>
Cc: johnstul@us.ibm.com
Cc: yong.zhang0@gmail.com
Cc: hch@infradead.org
LKML-Reference: <20110127145855.23248.56933.stgit@localhost>
* 'timers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
MAINTAINERS: Update timer related entries
timers: Use this_cpu_read
timerqueue: Make timerqueue_getnext() static inline
hrtimer: fix timerqueue conversion flub
hrtimers: Convert hrtimers to use timerlist infrastructure
timers: Fixup allmodconfig build issue
timers: Rename timerlist infrastructure to timerqueue
timers: Introduce timerlist infrastructure.
hrtimer: Remove stale comment on curr_timer
timer: Warn when del_timer_sync() is called in hardirq context
timer: Del_timer_sync() can be used in softirq context
timer: Make try_to_del_timer_sync() the same on SMP and UP
posix-timers: Annotate lock_timer()
timer: Permit statically-declared work with deferrable timers
time: Use ARRAY_SIZE macro in timecompare.c
timer: Initialize the field slack of timer_list
timer_list: Remove alignment padding on 64 bit when CONFIG_TIMER_STATS
time: Compensate for rounding on odd-frequency clocksources
Fix up trivial conflict in MAINTAINERS
Eric asked for this.
[tglx: Because it generates faster code according to Erics ]
Signed-off-by: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@cs.helsinki.fi>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Tejun Heo <tj@kernel.org>
Cc: linux-mm@kvack.org
LKML-Reference: <alpine.DEB.2.00.1011301404490.4039@router.home>
This fixes a bug as seen on 2.6.32 based kernels where timers got
enqueued on offline cpus.
If a cpu goes offline it might still have pending timers. These will
be migrated during CPU_DEAD handling after the cpu is offline.
However while the cpu is going offline it will schedule the idle task
which will then call tick_nohz_stop_sched_tick().
That function in turn will call get_next_timer_intterupt() to figure
out if the tick of the cpu can be stopped or not. If it turns out that
the next tick is just one jiffy off (delta_jiffies == 1)
tick_nohz_stop_sched_tick() incorrectly assumes that the tick should
not stop and takes an early exit and thus it won't update the load
balancer cpu.
Just afterwards the cpu will be killed and the load balancer cpu could
be the offline cpu.
On 2.6.32 based kernel get_nohz_load_balancer() gets called to decide
on which cpu a timer should be enqueued (see __mod_timer()). Which
leads to the possibility that timers get enqueued on an offline cpu.
These will never expire and can cause a system hang.
This has been observed 2.6.32 kernels. On current kernels
__mod_timer() uses get_nohz_timer_target() which doesn't have that
problem. However there might be other problems because of the too
early exit tick_nohz_stop_sched_tick() in case a cpu goes offline.
The easiest and probably safest fix seems to be to let
get_next_timer_interrupt() just lie and let it say there isn't any
pending timer if the current cpu is offline.
I also thought of moving migrate_[hr]timers() from CPU_DEAD to
CPU_DYING, but seeing that there already have been fixes at least in
the hrtimer code in this area I'm afraid that this could add new
subtle bugs.
LKML-Reference: <20101201091109.GA8984@osiris.boeblingen.de.ibm.com>
Cc: stable@kernel.org
There's a long-running regression that proved difficult to fix and
which is hitting certain people and is rather annoying in its effects.
Damien reported that after 74f5187ac8 (sched: Cure load average vs
NO_HZ woes) his load average is unnaturally high, he also noted that
even with that patch reverted the load avgerage numbers are not
correct.
The problem is that the previous patch only solved half the NO_HZ
problem, it addressed the part of going into NO_HZ mode, not of
comming out of NO_HZ mode. This patch implements that missing half.
When comming out of NO_HZ mode there are two important things to take
care of:
- Folding the pending idle delta into the global active count.
- Correctly aging the averages for the idle-duration.
So with this patch the NO_HZ interaction should be complete and
behaviour between CONFIG_NO_HZ=[yn] should be equivalent.
Furthermore, this patch slightly changes the load average computation
by adding a rounding term to the fixed point multiplication.
Reported-by: Damien Wyart <damien.wyart@free.fr>
Reported-by: Tim McGrath <tmhikaru@gmail.com>
Tested-by: Damien Wyart <damien.wyart@free.fr>
Tested-by: Orion Poplawski <orion@cora.nwra.com>
Tested-by: Kyle McMartin <kyle@mcmartin.ca>
Cc: Chase Douglas <chase.douglas@canonical.com>
LKML-Reference: <1291129145.32004.874.camel@laptop>
Add explict warning when del_timer_sync() is called in hardirq
context.
Signed-off-by: Yong Zhang <yong.zhang0@gmail.com>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Actually we have used del_timer_sync() in softirq context for a long time,
e.g. in __dst_free()::cancel_delayed_work().
So change the comments of it to warn on hardirq context only, and make
lockdep know about this change.
On UP try_to_del_timer_sync() is mapped to del_timer() which does not
take the running timer callback into account, so it has different
semantics.
Remove the SMP dependency of try_to_del_timer_sync() by using
base->running_timer in the UP case as well.
[ tglx: Removed set_running_timer() inline and tweaked the changelog ]
Currently, you have to just define a delayed_work uninitialised, and then
initialise it before first use. That's a tad clumsy. At risk of playing
mind-games with the compiler, fooling it into doing pointer arithmetic
with compile-time-constants, this lets clients properly initialise delayed
work with deferrable timers statically.
This patch was inspired by the issues which lead Artem Bityutskiy to
commit 8eab945c5616fc984 ("sunrpc: make the cache cleaner workqueue
deferrable").
Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Acked-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Cc: Arjan van de Ven <arjan@infradead.org>
Provide a mechanism that allows running code in IRQ context. It is
most useful for NMI code that needs to interact with the rest of the
system -- like wakeup a task to drain buffers.
Perf currently has such a mechanism, so extract that and provide it as
a generic feature, independent of perf so that others may also
benefit.
The IRQ context callback is generated through self-IPIs where
possible, or on architectures like powerpc the decrementer (the
built-in timer facility) is set to generate an interrupt immediately.
Architectures that don't have anything like this get to do with a
callback from the timer tick. These architectures can call
irq_work_run() at the tail of any IRQ handlers that might enqueue such
work (like the perf IRQ handler) to avoid undue latencies in
processing the work.
Acked-by: Kyle McMartin <kyle@mcmartin.ca>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
[ various fixes ]
Signed-off-by: Huang Ying <ying.huang@intel.com>
LKML-Reference: <1287036094.7768.291.camel@yhuang-dev>
Fix kernel-doc warning, add @timer description:
Warning(kernel/timer.c:335): No description found for parameter 'timer'
Documentation: Add timers/timers-howto.txt
timer: Added usleep_range timer
Revert "timer: Added usleep[_range] timer"
clockevents: Remove the per cpu tick skew
posix_timer: Move copy_to_user(created_timer_id) down in timer_create()
timers: Document meaning of deferrable timer
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits)
sched: Use correct macro to display sched_child_runs_first in /proc/sched_debug
sched: No need for bootmem special cases
sched: Revert nohz_ratelimit() for now
sched: Reduce update_group_power() calls
sched: Update rq->clock for nohz balanced cpus
sched: Fix spelling of sibling
sched, cpuset: Drop __cpuexit from cpu hotplug callbacks
sched: Fix the racy usage of thread_group_cputimer() in fastpath_timer_check()
sched: run_posix_cpu_timers: Don't check ->exit_state, use lock_task_sighand()
sched: thread_group_cputime: Simplify, document the "alive" check
sched: Remove the obsolete exit_state/signal hacks
sched: task_tick_rt: Remove the obsolete ->signal != NULL check
sched: __sched_setscheduler: Read the RLIMIT_RTPRIO value lockless
sched: Fix comments to make them DocBook happy
sched: Fix fix_small_capacity
powerpc: Exclude arch_sd_sibiling_asym_packing() on UP
powerpc: Enable asymmetric SMT scheduling on POWER7
sched: Add asymmetric group packing option for sibling domain
sched: Fix capacity calculations for SMT4
sched: Change nohz idle load balancing logic to push model
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (162 commits)
tracing/kprobes: unregister_trace_probe needs to be called under mutex
perf: expose event__process function
perf events: Fix mmap offset determination
perf, powerpc: fsl_emb: Restore setting perf_sample_data.period
perf, powerpc: Convert the FSL driver to use local64_t
perf tools: Don't keep unreferenced maps when unmaps are detected
perf session: Invalidate last_match when removing threads from rb_tree
perf session: Free the ref_reloc_sym memory at the right place
x86,mmiotrace: Add support for tracing STOS instruction
perf, sched migration: Librarize task states and event headers helpers
perf, sched migration: Librarize the GUI class
perf, sched migration: Make the GUI class client agnostic
perf, sched migration: Make it vertically scrollable
perf, sched migration: Parameterize cpu height and spacing
perf, sched migration: Fix key bindings
perf, sched migration: Ignore unhandled task states
perf, sched migration: Handle ignored migrate out events
perf: New migration tool overview
tracing: Drop cpparg() macro
perf: Use tracepoint_synchronize_unregister() to flush any pending tracepoint call
Fix up trivial conflicts in Makefile and drivers/cpufreq/cpufreq.c
kernel/Makefile
Merge reason: Add the now complete topic, fix the conflict.
usleep_range is a finer precision implementations of msleep
and is designed to be a drop-in replacement for udelay where
a precise sleep / busy-wait is unnecessary.
Since an easy interface to hrtimers could lead to an undesired
proliferation of interrupts, we provide only a "range" API,
forcing the caller to think about an acceptable tolerance on
both ends and hopefully avoiding introducing another interrupt.
INTRO
As discussed here ( http://lkml.org/lkml/2007/8/3/250 ), msleep(1) is not
precise enough for many drivers (yes, sleep precision is an unfair notion,
but consistently sleeping for ~an order of magnitude greater than requested
is worth fixing). This patch adds a usleep API so that udelay does not have
to be used. Obviously not every udelay can be replaced (those in atomic
contexts or being used for simple bitbanging come to mind), but there are
many, many examples of
mydriver_write(...)
/* Wait for hardware to latch */
udelay(100)
in various drivers where a busy-wait loop is neither beneficial nor
necessary, but msleep simply does not provide enough precision and people
are using a busy-wait loop instead.
CONCERNS FROM THE RFC
Why is udelay a problem / necessary? Most callers of udelay are in device/
driver initialization code, which is serial...
As I see it, there is only benefit to sleeping over a delay; the
notion of "refactoring" areas that use udelay was presented, but
I see usleep as the refactoring. Consider i2c, if the bus is busy,
you need to wait a bit (say 100us) before trying again, your
current options are:
* udelay(100)
* msleep(1) <-- As noted above, actually as high as ~20ms
on some platforms, so not really an option
* Manually set up an hrtimer to try again in 100us (which
is what usleep does anyway...)
People choose the udelay route because it is EASY; we need to
provide a better easy route.
Device / driver / boot code is *currently* serial, but every few
months someone makes noise about parallelizing boot, and IMHO, a
little forward-thinking now is one less thing to worry about
if/when that ever happens
udelay's could be preempted
Sure, but if udelay plans on looping 1000 times, and it gets
preempted on loop 200, whenever it's scheduled again, it is
going to do the next 800 loops.
Is the interruptible case needed?
Probably not, but I see usleep as a very logical parallel to msleep,
so it made sense to include the "full" API. Processors are getting
faster (albeit not as quickly as they are becoming more parallel),
so if someone wanted to be interruptible for a few usecs, why not
let them? If this is a contentious point, I'm happy to remove it.
OTHER THOUGHTS
I believe there is also value in exposing the usleep_range option; it gives
the scheduler a lot more flexibility and allows the programmer to express
his intent much more clearly; it's something I would hope future driver
writers will take advantage of.
To get the results in the NUMBERS section below, I literally s/udelay/usleep
the kernel tree; I had to go in and undo the changes to the USB drivers, but
everything else booted successfully; I find that extremely telling in and
of itself -- many people are using a delay API where a sleep will suit them
just fine.
SOME ATTEMPTS AT NUMBERS
It turns out that calculating quantifiable benefit on this is challenging,
so instead I will simply present the current state of things, and I hope
this to be sufficient:
How many udelay calls are there in 2.6.35-rc5?
udealy(ARG) >= | COUNT
1000 | 319
500 | 414
100 | 1146
20 | 1832
I am working on Android, so that is my focus for this. The following table
is a modified usleep that simply printk's the amount of time requested to
sleep; these tests were run on a kernel with udelay >= 20 --> usleep
"boot" is power-on to lock screen
"power collapse" is when the power button is pushed and the device suspends
"resume" is when the power button is pushed and the lock screen is displayed
(no touchscreen events or anything, just turning on the display)
"use device" is from the unlock swipe to clicking around a bit; there is no
sd card in this phone, so fail loading music, video, camera
ACTION | TOTAL NUMBER OF USLEEP CALLS | NET TIME (us)
boot | 22 | 1250
power-collapse | 9 | 1200
resume | 5 | 500
use device | 59 | 7700
The most interesting category to me is the "use device" field; 7700us of
busy-wait time that could be put towards better responsiveness, or at the
least less power usage.
Signed-off-by: Patrick Pannuto <ppannuto@codeaurora.org>
Cc: apw@canonical.com
Cc: corbet@lwn.net
Cc: arjan@linux.intel.com
Cc: Randy Dunlap <rdunlap@xenotime.net>
This reverts commit 22b8f15c2f7130bb0386f548428df2ffd4e81903 to merge
an advanced version.
In some cases (for instance with kernel threads) it may be desireable to
use on-stack deferrable timers to get their power saving benefits. Add
interfaces to support this for the IPS driver.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
usleep[_range] are finer precision implementations of msleep
and are designed to be drop-in replacements for udelay where
a precise sleep / busy-wait is unnecessary. They also allow
an easy interface to specify slack when a precise (ish)
wakeup is unnecessary to help minimize wakeups
Cc: akinobu.mita@gmail.com
Cc: sboyd@codeaurora.org
Acked-by: Arjan van de Ven <arjan@linux.intel.com>
LKML-Reference: <4C44CDD2.1070708@codeaurora.org>
Steal some text from 6e453a67510 "Add support for deferrable timers". A
reader shouldn't have to dig through the git logs for the basic
description of a deferrable timer.
Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
In the new push model, all idle CPUs indeed go into nohz mode. There is
still the concept of idle load balancer (performing the load balancing
on behalf of all the idle cpu's in the system). Busy CPU kicks the nohz
balancer when any of the nohz CPUs need idle load balancing.
The kickee CPU does the idle load balancing on behalf of all idle CPUs
instead of the normal idle balance.
This addresses the below two problems with the current nohz ilb logic:
* the idle load balancer continued to have periodic ticks during idle and
wokeup frequently, even though it did not have any rebalancing to do on
behalf of any of the idle CPUs.
* On x86 and CPUs that have APIC timer stoppage on idle CPUs, this
periodic wakeup can result in a periodic additional interrupt on a CPU
doing the timer broadcast.
Also currently we are migrating the unpinned timers from an idle to the cpu
doing idle load balancing (when all the cpus in the system are idle,
there is no idle load balancing cpu and timers get added to the same idle cpu
where the request was made. So the existing optimization works only on semi idle
system).
And In semi idle system, we no longer have periodic ticks on the idle load
balancer CPU. Using that cpu will add more delays to the timers than intended
(as that cpu's timer base may not be uptodate wrt jiffies etc). This was
causing mysterious slowdowns during boot etc.
For now, in the semi idle case, use the nearest busy cpu for migrating timers
from an idle cpu. This is good for power-savings anyway.
Signed-off-by: Venkatesh Pallipadi <venki@google.com>
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
LKML-Reference: <1274486981.2840.46.camel@sbs-t61.sc.intel.com>
The commit 80b5184cc537718122e036afe7e62d202b70d077 ("kernel/: convert cpu
notifier to return encapsulate errno value") changed the return value of
cpu notifier callbacks.
Those callbacks don't return NOTIFY_BAD on failures anymore. But there
are a few callbacks which are called directly at init time and checking
the return value.
I forgot to change BUG_ON checking by the direct callers in the commit.
* 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
posix_timer: Fix error path in timer_create
hrtimer: Avoid double seqlock
timers: Move local variable into else section
timers: Fix slack calculation really
By the previous modification, the cpu notifier can return encapsulate
errno value. This converts the cpu notifiers for kernel/*.c
Fix nit-picking coding style detail.
commit f00e047ef (timers: Fix slack calculation for expired timers)
fixed the issue of slack on expired timers only partially. Linus
noticed that jiffies is volatile so it is reloaded twice, which
generates bad code.
But its worse. This can defeat the time_after() check if jiffies are
incremented between time_after() and the slack calculation.
Fix it by reading jiffies into a local variable, which prevents the
compiler from loading it twice. While at it make the > -1 check into
>= 0 which is easier to read.
Cc: Arjan van de Ven <arjan@linux.intel.com>
commit 3bbb9ec946 (timers: Introduce the concept of timer slack for
legacy timers) does not take the case into account when the timer is
already expired. This broke wireless drivers.
The solution is not to apply slack to already expired timers.
Just some code cleanup to make touch_softlockup clearer and remove the
softlockup_tick function as it is no longer needed.
Also remove the /proc softlockup_thres call as it has been changed to
watchdog_thres.
Signed-off-by: Don Zickus <dzickus@redhat.com>
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
Cc: Eric Paris <eparis@redhat.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
LKML-Reference: <1273266711-18706-3-git-send-email-dzickus@redhat.com>
Reason: Further posix_cpu_timer patches depend on mainline changes
