path: root/kernel/trace/Kconfig
2010-01-26tracing/documentation: Cover new frame pointer semanticsMike Frysinger
Update the graph tracer examples to cover the new frame pointer semantics (in terms of passing it along). Move the HAVE_FUNCTION_GRAPH_FP_TEST docs out of the Kconfig, into the right place, and expand on the details. Signed-off-by: Mike Frysinger <vapier@gentoo.org> LKML-Reference: <1264165967-18938-1-git-send-email-vapier@gentoo.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-12-28tracing: Kconfig spelling fixes and cleanupsRandy Dunlap
Fix filename reference (ftrace-implementation.txt -> ftrace-design.txt). Fix spelling, punctuation, grammar. Fix help text indentation and line lengths to reduce need for horizontal scrolling or larger window sizes. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091221120117.3fb49cdc.randy.dunlap@oracle.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-21Merge branch 'tracing/hw-breakpoints' into perf/coreIngo Molnar
Conflicts: arch/x86/kernel/kprobes.c kernel/trace/Makefile Merge reason: hw-breakpoints perf integration is looking good in testing and in reviews, plus conflicts are mounting up - so merge & resolve. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-04tracing/kprobes: Rename Kprobe-tracer to kprobe-eventMasami Hiramatsu
Rename Kprobes-based event tracer to kprobes-based tracing event (kprobe-event), since it is not a tracer but an extensible tracing event interface. This also changes CONFIG_KPROBE_TRACER to CONFIG_KPROBE_EVENT and sets it y by default. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> LKML-Reference: <20091104001247.3454.14131.stgit@harusame> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-18Merge commit 'perf/core' into perf/hw-breakpointFrederic Weisbecker
Conflicts: kernel/Makefile kernel/trace/Makefile kernel/trace/trace.h samples/Makefile Merge reason: We need to be uptodate with the perf events development branch because we plan to rewrite the breakpoints API on top of perf events.
2009-09-23Merge commit 'linus/master' into tracing/kprobesFrederic Weisbecker
Conflicts: kernel/trace/Makefile kernel/trace/trace.h kernel/trace/trace_event_types.h kernel/trace/trace_export.c Merge reason: Sync with latest significant tracing core changes.
2009-09-21trivial: Fix duplicated word "options" in commentUwe Kleine-Koenig
this was introduced in 5e0a093 (tracing: fix config options to not show when automatically selected) Signed-off-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: trivial@kernel.org Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-14ftrace: document function and function graph implementationMike Frysinger
While implementing function tracer and function tracer graph support, I found the exact arch implementation details to be a bit lacking (and my x86 foo ain't great). So after pounding out support for the Blackfin arch, start documenting the requirements/details. Signed-off-by: Mike Frysinger <vapier@gentoo.org> LKML-Reference: <1252973415-21264-1-git-send-email-vapier@gentoo.org> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-09-14tracing: make testing syscall events a separate configurationSteven Rostedt
Parag noticed that the number of event tests has increased tremendously: grep "Testing event" dmesg.31rc9 |wc -l 100 grep "Testing event" dmesg.31git |wc -l 1172 This is due to the testing of every syscall event when ftrace self test is enabled. This adds a bit more time to kernel boot up and can affect development by slowing down the time it takes between reboots. This option makes the testing of the syscall events into a separate config, to still be able to test most of ftrace internals at boot up but not have to wait for all the syscall events to be tested. The syscall event testing only tests the enabling and disabling of the trace point, since the syscalls are not executed. What really needs to be done is to somehow have a userspace tool test the syscall tracepoints as well. Reported-by: Parag Warudkar <parag.lkml@gmail.com> LKML-Reference: <f7848160909130815l3e768a30n3b28808bbe5c254b@mail.gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-09-11Merge commit 'tracing/core' into tracing/kprobesFrederic Weisbecker
Conflicts: kernel/trace/trace_export.c kernel/trace/trace_kprobe.c Merge reason: This topic branch lacks an important build fix in tracing/core: 0dd7b74787eaf7858c6c573353a83c3e2766e674: tracing: Fix double CPP substitution in TRACE_EVENT_FN that prevents from multiple tracepoint headers inclusion crashes. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-09-07Merge branch 'tracing/core' into tracing/hw-breakpointsIngo Molnar
Conflicts: arch/Kconfig kernel/trace/trace.h Merge reason: resolve the conflicts, plus adopt to the new ring-buffer APIs. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-04ring-buffer: only enable ring_buffer_swap_cpu when neededSteven Rostedt
Since the ability to swap the cpu buffers adds a small overhead to the recording of a trace, we only want to add it when needed. Only the irqsoff and preemptoff tracers use this feature, and both are not recommended for production kernels. This patch disables its use when neither irqsoff nor preemptoff is configured. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-08-27tracing: remove legacy select of MARKERS by context switch tracingSteven Rostedt
The context switch tracer was made before tracepoints were mature, and the original version used markers. This is no longer true and this patch removes the select. Reported-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-08-27tracing: Add kprobe-based event tracerMasami Hiramatsu
Add kprobes-based event tracer on ftrace. This tracer is similar to the events tracer which is based on Tracepoint infrastructure. Instead of Tracepoint, this tracer is based on kprobes (kprobe and kretprobe). It probes anywhere where kprobes can probe(this means, all functions body except for __kprobes functions). Similar to the events tracer, this tracer doesn't need to be activated via current_tracer, instead of that, just set probe points via /sys/kernel/debug/tracing/kprobe_events. And you can set filters on each probe events via /sys/kernel/debug/tracing/events/kprobes/<EVENT>/filter. This tracer supports following probe arguments for each probe. %REG : Fetch register REG sN : Fetch Nth entry of stack (N >= 0) sa : Fetch stack address. @ADDR : Fetch memory at ADDR (ADDR should be in kernel) @SYM[+|-offs] : Fetch memory at SYM +|- offs (SYM should be a data symbol) aN : Fetch function argument. (N >= 0) rv : Fetch return value. ra : Fetch return address. +|-offs(FETCHARG) : fetch memory at FETCHARG +|- offs address. See Documentation/trace/kprobetrace.txt in the next patch for details. Changes from v13: - Support 'sa' for stack address. - Use call->data instead of container_of() macro. [fweisbec@gmail.com: Fixed conflict against latest tracing/core] Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Avi Kivity <avi@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jason Baron <jbaron@redhat.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Przemysław Pawełczyk <przemyslaw@pawelczyk.it> Cc: Roland McGrath <roland@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Vegard Nossum <vegard.nossum@gmail.com> LKML-Reference: <20090813203510.31965.29123.stgit@localhost.localdomain> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-08-26tracing: Rename FTRACE_SYSCALLS for tracepointsJosh Stone
s/HAVE_FTRACE_SYSCALLS/HAVE_SYSCALL_TRACEPOINTS/g s/TIF_SYSCALL_FTRACE/TIF_SYSCALL_TRACEPOINT/g The syscall enter/exit tracing is no longer specific to just ftrace, so they now have names that reflect their tie to tracepoints instead. Signed-off-by: Josh Stone <jistone@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Jiaying Zhang <jiayingz@google.com> Cc: Martin Bligh <mbligh@google.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> LKML-Reference: <1251150194-1713-2-git-send-email-jistone@redhat.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-06-29tracing/fastboot: Document the need of initcall_debugLi Zefan
To use boot tracer, one should pass initcall_debug as well as ftrace=initcall to the command line. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <4A48735E.9050002@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-20Merge branch 'tracing-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (24 commits) tracing/urgent: warn in case of ftrace_start_up inbalance tracing/urgent: fix unbalanced ftrace_start_up function-graph: add stack frame test function-graph: disable when both x86_32 and optimize for size are configured ring-buffer: have benchmark test print to trace buffer ring-buffer: do not grab locks in nmi ring-buffer: add locks around rb_per_cpu_empty ring-buffer: check for less than two in size allocation ring-buffer: remove useless compile check for buffer_page size ring-buffer: remove useless warn on check ring-buffer: use BUF_PAGE_HDR_SIZE in calculating index tracing: update sample event documentation tracing/filters: fix race between filter setting and module unload tracing/filters: free filter_string in destroy_preds() ring-buffer: use commit counters for commit pointer accounting ring-buffer: remove unused variable ring-buffer: have benchmark test handle discarded events ring-buffer: prevent adding write in discarded area tracing/filters: strloc should be unsigned short tracing/filters: operand can be negative ... Fix up kmemcheck-induced conflict in kernel/trace/ring_buffer.c manually
2009-06-18function-graph: add stack frame testSteven Rostedt
In case gcc does something funny with the stack frames, or the return from function code, we would like to detect that. An arch may implement passing of a variable that is unique to the function and can be saved on entering a function and can be tested when exiting the function. Usually the frame pointer can be used for this purpose. This patch also implements this for x86. Where it passes in the stack frame of the parent function, and will test that frame on exit. There was a case in x86_32 with optimize for size (-Os) where, for a few functions, gcc would align the stack frame and place a copy of the return address into it. The function graph tracer modified the copy and not the actual return address. On return from the funtion, it did not go to the tracer hook, but returned to the parent. This broke the function graph tracer, because the return of the parent (where gcc did not do this funky manipulation) returned to the location that the child function was suppose to. This caused strange kernel crashes. This test detected the problem and pointed out where the issue was. This modifies the parameters of one of the functions that the arch specific code calls, so it includes changes to arch code to accommodate the new prototype. Note, I notice that the parsic arch implements its own push_return_trace. This is now a generic function and the ftrace_push_return_trace should be used instead. This patch does not touch that code. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Helge Deller <deller@gmx.de> Cc: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-06-18function-graph: disable when both x86_32 and optimize for size are configuredSteven Rostedt
On x86_32, when optimize for size is set, gcc may align the frame pointer and make a copy of the the return address inside the stack frame. The return address that is located in the stack frame may not be the one used to return to the calling function. This will break the function graph tracer. The function graph tracer replaces the return address with a jump to a hook function that can trace the exit of the function. If it only replaces a copy, then the hook will not be called when the function returns. Worse yet, when the parent function returns, the function graph tracer will return back to the location of the child function which will easily crash the kernel with weird results. To see the problem, when i386 is compiled with -Os we get: c106be03: 57 push %edi c106be04: 8d 7c 24 08 lea 0x8(%esp),%edi c106be08: 83 e4 e0 and $0xffffffe0,%esp c106be0b: ff 77 fc pushl 0xfffffffc(%edi) c106be0e: 55 push %ebp c106be0f: 89 e5 mov %esp,%ebp c106be11: 57 push %edi c106be12: 56 push %esi c106be13: 53 push %ebx c106be14: 81 ec 8c 00 00 00 sub $0x8c,%esp c106be1a: e8 f5 57 fb ff call c1021614 <mcount> When it is compiled with -O2 instead we get: c10896f0: 55 push %ebp c10896f1: 89 e5 mov %esp,%ebp c10896f3: 83 ec 28 sub $0x28,%esp c10896f6: 89 5d f4 mov %ebx,0xfffffff4(%ebp) c10896f9: 89 75 f8 mov %esi,0xfffffff8(%ebp) c10896fc: 89 7d fc mov %edi,0xfffffffc(%ebp) c10896ff: e8 d0 08 fa ff call c1029fd4 <mcount> The compile with -Os will align the stack pointer then set up the frame pointer (%ebp), and it copies the return address back into the stack frame. The change to the return address in mcount is done to the copy and not the real place holder of the return address. Then compile with -O2 sets up the frame pointer first, this makes the change to the return address by mcount affect where the function will jump on exit. Reported-by: Jake Edge <jake@lwn.net> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-06-17Merge branch 'linus' into tracing/hw-breakpointsIngo Molnar
Conflicts: arch/x86/Kconfig arch/x86/kernel/traps.c arch/x86/power/cpu.c arch/x86/power/cpu_32.c kernel/Makefile Semantic conflict: arch/x86/kernel/hw_breakpoint.c Merge reason: Resolve the conflicts, move from put_cpu_no_sched() to put_cpu() in arch/x86/kernel/hw_breakpoint.c. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-15debugfs: Fix terminology inconsistency of dir name to mount debugfs filesystem.GeunSik Lim
Many developers use "/debug/" or "/debugfs/" or "/sys/kernel/debug/" directory name to mount debugfs filesystem for ftrace according to ./Documentation/tracers/ftrace.txt file. And, three directory names(ex:/debug/, /debugfs/, /sys/kernel/debug/) is existed in kernel source like ftrace, DRM, Wireless, Documentation, Network[sky2]files to mount debugfs filesystem. debugfs means debug filesystem for debugging easy to use by greg kroah hartman. "/sys/kernel/debug/" name is suitable as directory name of debugfs filesystem. - debugfs related reference: http://lwn.net/Articles/334546/ Fix inconsistency of directory name to mount debugfs filesystem. * From Steven Rostedt - find_debugfs() and tracing_files() in this patch. Signed-off-by: GeunSik Lim <geunsik.lim@samsung.com> Acked-by : Inaky Perez-Gonzalez <inaky@linux.intel.com> Reviewed-by : Steven Rostedt <rostedt@goodmis.org> Reviewed-by : James Smart <james.smart@emulex.com> CC: Jiri Kosina <trivial@kernel.org> CC: David Airlie <airlied@linux.ie> CC: Peter Osterlund <petero2@telia.com> CC: Ananth N Mavinakayanahalli <ananth@in.ibm.com> CC: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> CC: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-02hw-breakpoints: ftrace plugin for kernel symbol tracing using HW Breakpoint ↵K.Prasad
interfaces This patch adds an ftrace plugin to detect and profile memory access over kernel variables. It uses HW Breakpoint interfaces to 'watch memory addresses. Signed-off-by: K.Prasad <prasad@linux.vnet.ibm.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-06-01tracing: combine the default tracers into one configSteven Rostedt
Both event tracer and sched switch plugin are selected by default by all generic tracers. But if no generic tracer is enabled, their options appear. But ether one of them will select the other, thus it only makes sense to have the default tracers be selected by one option. [ Impact: clean up kconfig menu ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-06-01tracing: fix config options to not show when automatically selectedSteven Rostedt
There are two options that are selected by all tracers, but we want to have those options available when no tracer is selected. These are The event tracer and sched switch tracer. The are enabled by all tracers, but if a tracer is not selected we want the options to appear. All tracers including them select TRACING. Thus what we would like to do is: config EVENT_TRACER bool "prompt" depends on TRACING select TRACING But that gives us a bug in the kbuild system since we just created a circular dependency. We only want the prompt to show when TRACING is off. This patch adds GENERIC_TRACER that all tracers will select instead of TRACING. The two options (sched switch and event tracer) will select TRACING directly and depend on !GENERIC_TRACER. This solves the cicular dependency. [ Impact: hide options that are selected by default ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-05-26ftrace: Add task_comm support for trace_eventZhaolei
If we enable a trace event alone without any tracer running (such as function tracer, sched switch tracer, etc...) it can't output enough task command information. We need to use the tracing_{start/stop}_cmdline_record() helpers which are designed to keep track of cmdlines for any tasks that were scheduled during the tracing. Before this patch: # echo 1 > debugfs/tracing/events/sched/sched_switch/enable # cat debugfs/tracing/trace # tracer: nop # # TASK-PID CPU# TIMESTAMP FUNCTION # | | | | | <...>-2289 [000] 526276.724790: sched_switch: task bash:2289 [120] ==> sshd:2287 [120] <...>-2287 [000] 526276.725231: sched_switch: task sshd:2287 [120] ==> bash:2289 [120] <...>-2289 [000] 526276.725452: sched_switch: task bash:2289 [120] ==> sshd:2287 [120] <...>-2287 [000] 526276.727181: sched_switch: task sshd:2287 [120] ==> swapper:0 [140] <idle>-0 [000] 526277.032734: sched_switch: task swapper:0 [140] ==> events/0:5 [115] <...>-5 [000] 526277.032782: sched_switch: task events/0:5 [115] ==> swapper:0 [140] ... After this patch: # tracer: nop # # TASK-PID CPU# TIMESTAMP FUNCTION # | | | | | bash-2269 [000] 527347.989229: sched_switch: task bash:2269 [120] ==> sshd:2267 [120] sshd-2267 [000] 527347.990960: sched_switch: task sshd:2267 [120] ==> bash:2269 [120] bash-2269 [000] 527347.991143: sched_switch: task bash:2269 [120] ==> sshd:2267 [120] sshd-2267 [000] 527347.992959: sched_switch: task sshd:2267 [120] ==> swapper:0 [140] <idle>-0 [000] 527348.531989: sched_switch: task swapper:0 [140] ==> events/0:5 [115] events/0-5 [000] 527348.532115: sched_switch: task events/0:5 [115] ==> swapper:0 [140] ... Changelog: v1->v2: Update Kconfig to select CONTEXT_SWITCH_TRACER in ENABLE_EVENT_TRACING v2->v3: v2 can solve problem that was caused by config EVENT_TRACING alone, but when CONFIG_FTRACE is off and CONFIG_TRACING is selected by other config, compile fail happened again. This version solves it. [ Impact: fix incomplete output of event tracing ] Signed-off-by: Zhao Lei <zhaolei@cn.fujitsu.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <4A14FDFE.2080402@cn.fujitsu.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-05-07tracing: have menu default enabled when kernel debug is configuredSteven Rostedt
Tracing can be very helpful to debug the kernel. When DEBUG_KERNEL is enabled it is nice to enable the trace menu as well. This patch only make the tracing menu enabled by default, it does not make any of the tracers enabled. And the menu is only enabled by default if DEBUG_KERNEL is enabled. [ Impact: show tracing options to those debugging the kernel ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-05-06ring-buffer: add benchmark and testerSteven Rostedt
This patch adds code that can benchmark the ring buffer as well as test it. This code can be compiled into the kernel (not recommended) or as a module. A separate ring buffer is used to not interfer with other users, like ftrace. It creates a producer and a consumer (option to disable creation of the consumer) and will run for 10 seconds, then sleep for 10 seconds and then repeat. While running, the producer will write 10 byte loads into the ring buffer with just putting in the current CPU number. The reader will continually try to read the buffer. The reader will alternate from reading the buffer via event by event, or by full pages. The output is a pr_info, thus it will fill up the syslogs. Starting ring buffer hammer End ring buffer hammer Time: 9000349 (usecs) Overruns: 12578640 Read: 5358440 (by events) Entries: 0 Total: 17937080 Missed: 0 Hit: 17937080 Entries per millisec: 1993 501 ns per entry Sleeping for 10 secs Starting ring buffer hammer End ring buffer hammer Time: 9936350 (usecs) Overruns: 0 Read: 28146644 (by pages) Entries: 74 Total: 28146718 Missed: 0 Hit: 28146718 Entries per millisec: 2832 353 ns per entry Sleeping for 10 secs Time: is the time the test ran Overruns: the number of events that were overwritten and not read Read: the number of events read (either by pages or events) Entries: the number of entries left in the buffer (the by pages will only read full pages) Total: Entries + Read + Overruns Missed: the number of entries that failed to write Hit: the number of entries that were written The above example shows that it takes ~353 nanosecs per entry when there is a reader, reading by pages (and no overruns) The event by event reader slowed the producer down to 501 nanosecs. [ Impact: see how changes to the ring buffer affect stability and performance ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-20tracing: rename EVENT_TRACER config to ENABLE_EVENT_TRACINGSteven Rostedt
Currently we have two configs: EVENT_TRACING and EVENT_TRACER. All tracers enable EVENT_TRACING. The EVENT_TRACER is only a convenience to enable the EVENT_TRACING when no other tracers are enabled. The names EVENT_TRACER and EVENT_TRACING are too similar and confusing. This patch renames EVENT_TRACER to ENABLE_EVENT_TRACING to be more appropriate to what it actually does, as well as add a comment in the help menu to explain the option's purpose. [ Impact: rename config option to reduce confusion ] Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-20tracing: create menuconfig for tracing infrastructureSteven Rostedt
During testing we often use randconfig to test various kernels. The current configuration set up does not give an easy way to disable all tracing with a single config. The case where randconfig would test all tracing disabled is very unlikely. This patch adds a config option to enable or disable all tracing. It is hooked into the tracing menu just like other submenus are done. [ Impact: allow randconfig to easily produce all traces disabled ] Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-20tracing: change branch profiling to a choice selectionSteven Rostedt
This patch makes the branch profiling into a choice selection: None - no branch profiling likely/unlikely - only profile likely/unlikely branches all - profile all branches The all profiler will also enable the likely/unlikely branches. This does not change the way the profiler works or the dependencies between the profilers. What this patch does, is keep the branch profiling from being selected by an allyesconfig make. The branch profiler is very intrusive and it is known to break various architecture builds when selected as an allyesconfig. [ Impact: prevent branch profiler from being selected in allyesconfig ] Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com> Reported-by: Al Viro <viro@zeniv.linux.org.uk> Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-04-14Merge branch 'linus' into tracing/coreIngo Molnar
Merge reason: merge latest tracing fixes to avoid conflicts in kernel/trace/trace_events_filter.c with upcoming change Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-14tracing/infrastructure: separate event tracer from event supportTom Zanussi
Add a new config option, CONFIG_EVENT_TRACING that gets selected when CONFIG_TRACING is selected and adds everything needed by the stuff in trace_export - basically all the event tracing support needed by e.g. bprint, minus the actual events, which are only included if CONFIG_EVENT_TRACER is selected. So CONFIG_EVENT_TRACER can be used to turn on or off the generated events (what I think of as the 'event tracer'), while CONFIG_EVENT_TRACING turns on or off the base event tracing support used by both the event tracer and the other things such as bprint that can't be configured out. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: fweisbec@gmail.com LKML-Reference: <1239178441.10295.34.camel@tropicana> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-10tracing: fix document referencesLi Zefan
When moving documents to Documentation/trace/, I forgot to grep Kconfig to find out those references. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Pekka Paalanen <pq@iki.fi> Cc: eduard.munteanu@linux360.ro LKML-Reference: <49DE97EF.7080208@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-07Merge branch 'linus' into tracing/coreIngo Molnar
Merge reason: update to upstream tracing facilities Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-05Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (413 commits) tracing, net: fix net tree and tracing tree merge interaction tracing, powerpc: fix powerpc tree and tracing tree interaction ring-buffer: do not remove reader page from list on ring buffer free function-graph: allow unregistering twice trace: make argument 'mem' of trace_seq_putmem() const tracing: add missing 'extern' keywords to trace_output.h tracing: provide trace_seq_reserve() blktrace: print out BLK_TN_MESSAGE properly blktrace: extract duplidate code blktrace: fix memory leak when freeing struct blk_io_trace blktrace: fix blk_probes_ref chaos blktrace: make classic output more classic blktrace: fix off-by-one bug blktrace: fix the original blktrace blktrace: fix a race when creating blk_tree_root in debugfs blktrace: fix timestamp in binary output tracing, Text Edit Lock: cleanup tracing: filter fix for TRACE_EVENT_FORMAT events ftrace: Using FTRACE_WARN_ON() to check "freed record" in ftrace_release() x86: kretprobe-booster interrupt emulation code fix ... Fix up trivial conflicts in arch/parisc/include/asm/ftrace.h include/linux/memory.h kernel/extable.c kernel/module.c
2009-03-30trivial: fix typos/grammar errors in Kconfig textsMatt LaPlante
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-24tracing: move function profiler data out of function structSteven Rostedt
Impact: reduce size of memory in function profiler The function profiler originally introduces its counters into the function records itself. There is 20 thousand different functions on a normal system, and that is adding 20 thousand counters for profiling event when not needed. A normal run of the profiler yields only a couple of thousand functions executed, depending on what is being profiled. This means we have around 18 thousand useless counters. This patch rectifies this by moving the data out of the function records used by dynamic ftrace. Data is preallocated to hold the functions when the profiling begins. Checks are made during profiling to see if more recorcds should be allocated, and they are allocated if it is safe to do so. This also removes the dependency from using dynamic ftrace, and also removes the overhead by having it enabled. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-03-24tracing: add function profilerSteven Rostedt
Impact: new profiling feature This patch adds a function profiler. In debugfs/tracing/ two new files are created. function_profile_enabled - to enable or disable profiling trace_stat/functions - the profiled functions. For example: echo 1 > /debugfs/tracing/function_profile_enabled ./hackbench 50 echo 0 > /debugfs/tracing/function_profile_enabled yields: cat /debugfs/tracing/trace_stat/functions Function Hit -------- --- _spin_lock 10106442 _spin_unlock 10097492 kfree 6013704 _spin_unlock_irqrestore 4423941 _spin_lock_irqsave 4406825 __phys_addr 4181686 __slab_free 4038222 dput 4030130 path_put 4023387 unroll_tree_refs 4019532 [...] The most hit functions are listed first. Functions that are not hit are not listed. This feature depends on and uses dynamic function tracing. When the function profiling is disabled, no overhead occurs. But it still takes up around 300KB to hold the data, thus it is not recomended to keep it enabled for systems low on memory. When a '1' is echoed into the function_profile_enabled file, the counters for is function is reset back to zero. Thus you can see what functions are hit most by different programs. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-03-23tracing: Fix TRACING_SUPPORT dependency for PPC32Anton Vorontsov
commit 40ada30f9621fbd831ac2437b9a2a399aa ("tracing: clean up menu"), despite the "clean up" in its purpose, introduced a behavioural change for Kconfig symbols: we no longer able to select tracing support on PPC32 (because IRQFLAGS_SUPPORT isn't yet implemented). The IRQFLAGS_SUPPORT is not mandatory for most tracers, tracing core has a special case for platforms w/o irqflags (which, by the way, has become useless as of the commit above). Though according to Ingo Molnar, there was periodic build failures on weird, unmaintained architectures that had no irqflags-tracing support and hence didn't know the raw_irqs_save/restore primitives. Thus we'd better not enable irqflags-less tracing for all architectures. This patch restores the old behaviour for PPC32, and thus brings the tracing back. Other architectures can either add themselves to the exception list or (better) implement TRACE_IRQFLAGS_SUPPORT. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Acked-b: Steven Rostedt <rostedt@goodmis.org> Cc: linuxppc-dev@ozlabs.org LKML-Reference: <20090323220724.GA9851@oksana.dev.rtsoft.ru> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-16tracing/syscalls: select kallsysmsFrederic Weisbecker
Syscall tracing must select kallsysms. The arch code builds a table to find the syscall metadata by syscall number. It needs the syscalls names resolution from the symbol table to know which name found on the syscalls metadatas match a function pointer from the arch sys_call_table. Reported-by: Andrew Morton <akpm@linux-foundation.org> Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1237151439-6755-4-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13tracing/ftrace: syscall tracing infrastructure, basicsFrederic Weisbecker
Provide basic callbacks to do syscall tracing. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> LKML-Reference: <1236401580-5758-2-git-send-email-fweisbec@gmail.com> [ simplified it to a trace_printk() for now. ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-06tracing/core: drop the old trace_printk() implementation in favour of ↵Frederic Weisbecker
trace_bprintk() Impact: faster and lighter tracing Now that we have trace_bprintk() which is faster and consume lesser memory than trace_printk() and has the same purpose, we can now drop the old implementation in favour of the binary one from trace_bprintk(), which means we move all the implementation of trace_bprintk() to trace_printk(), so the Api doesn't change except that we must now use trace_seq_bprintk() to print the TRACE_PRINT entries. Some changes result of this: - Previously, trace_bprintk depended of a single tracer and couldn't work without. This tracer has been dropped and the whole implementation of trace_printk() (like the module formats management) is now integrated in the tracing core (comes with CONFIG_TRACING), though we keep the file trace_printk (previously trace_bprintk.c) where we can find the module management. Thus we don't overflow trace.c - changes some parts to use trace_seq_bprintk() to print TRACE_PRINT entries. - change a bit trace_printk/trace_vprintk macros to support non-builtin formats constants, and fix 'const' qualifiers warnings. But this is all transparent for developers. - etc... V2: - Rebase against last changes - Fix mispell on the changelog V3: - Rebase against last changes (moving trace_printk() to kernel.h) Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1236356510-8381-5-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-06tracing: infrastructure for supporting binary recordLai Jiangshan
Impact: save on memory for tracing Current tracers are typically using a struct(like struct ftrace_entry, struct ctx_switch_entry, struct special_entr etc...)to record a binary event. These structs can only record a their own kind of events. A new kind of tracer need a new struct and a lot of code too handle it. So we need a generic binary record for events. This infrastructure is for this purpose. [fweisbec@gmail.com: rebase against latest -tip, make it safe while sched tracing as reported by Steven Rostedt] Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1236356510-8381-3-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-06tracing: current tip/master can't enable ftraceKOSAKI Motohiro
After commit 40ada30f9621fbd831ac2437b9a2a399aad34b00, "make menuconfig" doesn't display "Tracer" item. Following modification restores it.
2009-03-05tracing: clean up menuIngo Molnar
Clean up menu structure, introduce TRACING_SUPPORT switch that signals whether an architecture supports various instrumentation mechanisms. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-24tracing: add event trace infrastructureSteven Rostedt
This patch creates the event tracing infrastructure of ftrace. It will create the files: /debug/tracing/available_events /debug/tracing/set_event The available_events will list the trace points that have been registered with the event tracer. set_events will allow the user to enable or disable an event hook. example: # echo sched_wakeup > /debug/tracing/set_event Will enable the sched_wakeup event (if it is registered). # echo "!sched_wakeup" >> /debug/tracing/set_event Will disable the sched_wakeup event (and only that event). # echo > /debug/tracing/set_event Will disable all events (notice the '>') # cat /debug/tracing/available_events > /debug/tracing/set_event Will enable all registered event hooks. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-02-19Merge branches 'tracing/blktrace', 'tracing/ftrace' and 'tracing/urgent' ↵Ingo Molnar
into tracing/core
2009-02-18tracing: have function trace select kallsymsSteven Rostedt
Impact: fix output of function tracer to be useful The function tracer is pretty useless if KALLSYMS is not configured. Unless you are good at reading hex values, the function tracer should select the KALLSYMS configuration. Also, the dynamic function tracer will fail its self test if KALLSYMS is not selected. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-02-15trace: mmiotrace to the tracer menu in KconfigPekka Paalanen
Impact: cosmetic change in Kconfig menu layout This patch was originally suggested by Peter Zijlstra, but seems it was forgotten. CONFIG_MMIOTRACE and CONFIG_MMIOTRACE_TEST were selectable directly under the Kernel hacking / debugging menu in the kernel configuration system. They were present only for x86 and x86_64. Other tracers that use the ftrace tracing framework are in their own sub-menu. This patch moves the mmiotrace configuration options there. Since the Kconfig file, where the tracer menu is, is not architecture specific, HAVE_MMIOTRACE_SUPPORT is introduced and provided only by x86/x86_64. CONFIG_MMIOTRACE now depends on it. Signed-off-by: Pekka Paalanen <pq@iki.fi> Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-11tracing/sysprof: add missing tracing_{start,stop}_record_cmdline()Frederic Weisbecker
Add the missing pair tracing_{start,stop}_record_cmdline() to record well the cmdline associated with pid. Changes in v2: - fix a build error, the sched_switch tracer is needed to record the cmdline. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
