commit 9ef16693aff8137faa21d16ffe65bb9832d24d71 upstream.
The ftrace set_ftrace_filter and set_ftrace_notrace files are specific for
an instance now. They need to take a reference to the instance otherwise
there could be a race between accessing the files and deleting the instance.
It wasn't until the :mod: caching where these file operations started
referencing the trace_array directly.
Cc: stable@vger.kernel.org
Fixes: 673feb9d76ab3 ("ftrace: Add :mod: caching infrastructure to trace_array")
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit 372e0d01da71c84dcecf7028598a33813b0d5256 upstream.
The race between adding a function probe and reading the probes that exist
is very subtle. It needs a comment. Also, the issue can also happen if the
probe has has the EMPTY_HASH as its func_hash.
Fixes: 7b60f3d876156 ("ftrace: Dynamically create the probe ftrace_ops for the trace_array")
commit 5b0022dd32b7c2e15edf1827ba80aa1407edf9ff upstream.
In register_ftrace_function_probe(), we are not checking the return
value of alloc_and_copy_ftrace_hash(). The subsequent call to
ftrace_match_records() may end up dereferencing the same. Add a check to
ensure this doesn't happen.
Link: http://lkml.kernel.org/r/26e92574f25ad23e7cafa3cf5f7a819de1832cbe.1562249521.git.naveen.n.rao@linux.vnet.ibm.com
Fixes: 1ec3a81a0cf42 ("ftrace: Have each function probe use its own ftrace_ops")
Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
commit 7bd46644ea0f6021dc396a39a8bfd3a58f6f1f9f upstream.
LTP testsuite on powerpc results in the below crash:
Unable to handle kernel paging request for data at address 0x00000000
Faulting instruction address: 0xc00000000029d800
Oops: Kernel access of bad area, sig: 11 [#1]
LE SMP NR_CPUS=2048 NUMA PowerNV
CPU: 68 PID: 96584 Comm: cat Kdump: loaded Tainted: G W
NIP: c00000000029d800 LR: c00000000029dac4 CTR: c0000000001e6ad0
REGS: c0002017fae8ba10 TRAP: 0300 Tainted: G W
MSR: 9000000000009033 <SF,HV,EE,ME,IR,DR,RI,LE> CR: 28022422 XER: 20040000
CFAR: c00000000029d90c DAR: 0000000000000000 DSISR: 40000000 IRQMASK: 0
NIP [c00000000029d800] t_probe_next+0x60/0x180
LR [c00000000029dac4] t_mod_start+0x1a4/0x1f0
Call Trace:
[c0002017fae8bc90] [c000000000cdbc40] _cond_resched+0x10/0xb0 (unreliable)
[c0002017fae8bce0] [c0000000002a15b0] t_start+0xf0/0x1c0
[c0002017fae8bd30] [c0000000004ec2b4] seq_read+0x184/0x640
[c0002017fae8bdd0] [c0000000004a57bc] sys_read+0x10c/0x300
[c0002017fae8be30] [c00000000000b388] system_call+0x5c/0x70
The test (ftrace_set_ftrace_filter.sh) is part of ftrace stress tests
and the crash happens when the test does 'cat
$TRACING_PATH/set_ftrace_filter'.
The address points to the second line below, in t_probe_next(), where
filter_hash is dereferenced:
hash = iter->probe->ops.func_hash->filter_hash;
size = 1 << hash->size_bits;
This happens due to a race with register_ftrace_function_probe(). A new
ftrace_func_probe is created and added into the func_probes list in
trace_array under ftrace_lock. However, before initializing the filter,
we drop ftrace_lock, and re-acquire it after acquiring regex_lock. If
another process is trying to read set_ftrace_filter, it will be able to
acquire ftrace_lock during this window and it will end up seeing a NULL
filter_hash.
Fix this by just checking for a NULL filter_hash in t_probe_next(). If
the filter_hash is NULL, then this probe is just being added and we can
simply return from here.
Link: http://lkml.kernel.org/r/05e021f757625cbbb006fad41380323dbe4e3b43.1562249521.git.naveen.n.rao@linux.vnet.ibm.com
[ Upstream commit a124692b698b00026a58d89831ceda2331b2e1d0 ]
Custom trampolines can only be enabled if there is only a single ops
attached to it. If there's only a single callback registered to a function,
and the ops has a trampoline registered for it, then we can call the
trampoline directly. This is very useful for improving the performance of
ftrace and livepatch.
If more than one callback is registered to a function, the general
trampoline is used, and the custom trampoline is not restored back to the
direct call even if all the other callbacks were unregistered and we are
back to one callback for the function.
To fix this, set FTRACE_FL_TRAMP flag if rec count is decremented
to one, and the ops that left has a trampoline.
Testing After this patch :
insmod livepatch_unshare_files.ko
cat /sys/kernel/debug/tracing/enabled_functions
unshare_files (1) R I tramp: 0xffffffffc0000000(klp_ftrace_handler+0x0/0xa0) ->ftrace_ops_assist_func+0x0/0xf0
echo unshare_files > /sys/kernel/debug/tracing/set_ftrace_filter
echo function > /sys/kernel/debug/tracing/current_tracer
unshare_files (2) R I ->ftrace_ops_list_func+0x0/0x150
echo nop > /sys/kernel/debug/tracing/current_tracer
Link: http://lkml.kernel.org/r/1556969979-111047-1-git-send-email-cj.chengjian@huawei.com
Signed-off-by: Cheng Jian <cj.chengjian@huawei.com>
ftrace_run_update_code()
commit d5b844a2cf507fc7642c9ae80a9d585db3065c28 upstream.
The commit 9f255b632bf12c4dd7 ("module: Fix livepatch/ftrace module text
permissions race") causes a possible deadlock between register_kprobe()
and ftrace_run_update_code() when ftrace is using stop_machine().
The existing dependency chain (in reverse order) is:
-> #1 (text_mutex){+.+.}:
validate_chain.isra.21+0xb32/0xd70
__lock_acquire+0x4b8/0x928
lock_acquire+0x102/0x230
__mutex_lock+0x88/0x908
mutex_lock_nested+0x32/0x40
register_kprobe+0x254/0x658
init_kprobes+0x11a/0x168
do_one_initcall+0x70/0x318
kernel_init_freeable+0x456/0x508
kernel_init+0x22/0x150
ret_from_fork+0x30/0x34
kernel_thread_starter+0x0/0xc
-> #0 (cpu_hotplug_lock.rw_sem){++++}:
check_prev_add+0x90c/0xde0
cpus_read_lock+0x62/0xd0
stop_machine+0x2e/0x60
arch_ftrace_update_code+0x2e/0x40
ftrace_run_update_code+0x40/0xa0
ftrace_startup+0xb2/0x168
register_ftrace_function+0x64/0x88
klp_patch_object+0x1a2/0x290
klp_enable_patch+0x554/0x980
do_init_module+0x6e/0x250
load_module+0x1782/0x1990
__s390x_sys_finit_module+0xaa/0xf0
system_call+0xd8/0x2d0
Possible unsafe locking scenario:
CPU0 CPU1
lock(text_mutex);
lock(cpu_hotplug_lock.rw_sem);
lock(text_mutex);
It is similar problem that has been solved by the commit 2d1e38f56622b9b
("kprobes: Cure hotplug lock ordering issues"). Many locks are involved.
To be on the safe side, text_mutex must become a low level lock taken
after cpu_hotplug_lock.rw_sem.
This can't be achieved easily with the current ftrace design.
For example, arm calls set_all_modules_text_rw() already in
ftrace_arch_code_modify_prepare(), see arch/arm/kernel/ftrace.c.
This functions is called:
+ outside stop_machine() from ftrace_run_update_code()
+ without stop_machine() from ftrace_module_enable()
Fortunately, the problematic fix is needed only on x86_64. It is
the only architecture that calls set_all_modules_text_rw()
in ftrace path and supports livepatching at the same time.
Therefore it is enough to move text_mutex handling from the generic
kernel/trace/ftrace.c into arch/x86/kernel/ftrace.c:
ftrace_arch_code_modify_post_process()
This patch basically reverts the ftrace part of the problematic
text permissions race"). And provides x86_64 specific-fix.
Some refactoring of the ftrace code will be needed when livepatching
is implemented for arm or nds32. These architectures call
set_all_modules_text_rw() and use stop_machine() at the same time.
Link: http://lkml.kernel.org/r/20190627081334.12793-1-pmladek@suse.com
Fixes: 9f255b632bf12c4dd7 ("module: Fix livepatch/ftrace module text permissions race")
Reported-by: Miroslav Benes <mbenes@suse.cz>
Reviewed-by: Miroslav Benes <mbenes@suse.cz>
Reviewed-by: Josh Poimboeuf <jpoimboe@redhat.com>
Signed-off-by: Petr Mladek <pmladek@suse.com>
As reviewed by Miroslav Benes <mbenes@suse.cz>, removed return value of
ftrace_run_update_code() as it is a void function.
[ Upstream commit 04e03d9a616c19a47178eaca835358610e63a1dd ]
The mapper may be NULL when called from register_ftrace_function_probe()
with probe->data == NULL.
This issue can be reproduced as follow (it may be covered by compiler
optimization sometime):
/ # cat /sys/kernel/debug/tracing/set_ftrace_filter
#### all functions enabled ####
/ # echo foo_bar:dump > /sys/kernel/debug/tracing/set_ftrace_filter
[ 206.949100] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000000
[ 206.952402] Mem abort info:
[ 206.952819] ESR = 0x96000006
[ 206.955326] Exception class = DABT (current EL), IL = 32 bits
[ 206.955844] SET = 0, FnV = 0
[ 206.956272] EA = 0, S1PTW = 0
[ 206.956652] Data abort info:
[ 206.957320] ISV = 0, ISS = 0x00000006
[ 206.959271] CM = 0, WnR = 0
[ 206.959938] user pgtable: 4k pages, 48-bit VAs, pgdp=0000000419f3a000
[ 206.960483] [0000000000000000] pgd=0000000411a87003, pud=0000000411a83003, pmd=0000000000000000
[ 206.964953] Internal error: Oops: 96000006 [#1] SMP
[ 206.971122] Dumping ftrace buffer:
[ 206.973677] (ftrace buffer empty)
[ 206.975258] Modules linked in:
[ 206.976631] Process sh (pid: 281, stack limit = 0x(____ptrval____))
[ 206.978449] CPU: 10 PID: 281 Comm: sh Not tainted 5.2.0-rc1+ #17
[ 206.978955] Hardware name: linux,dummy-virt (DT)
[ 206.979883] pstate: 60000005 (nZCv daif -PAN -UAO)
[ 206.980499] pc : free_ftrace_func_mapper+0x2c/0x118
[ 206.980874] lr : ftrace_count_free+0x68/0x80
[ 206.982539] sp : ffff0000182f3ab0
[ 206.983102] x29: ffff0000182f3ab0 x28: ffff8003d0ec1700
[ 206.983632] x27: ffff000013054b40 x26: 0000000000000001
[ 206.984000] x25: ffff00001385f000 x24: 0000000000000000
[ 206.984394] x23: ffff000013453000 x22: ffff000013054000
[ 206.984775] x21: 0000000000000000 x20: ffff00001385fe28
[ 206.986575] x19: ffff000013872c30 x18: 0000000000000000
[ 206.987111] x17: 0000000000000000 x16: 0000000000000000
[ 206.987491] x15: ffffffffffffffb0 x14: 0000000000000000
[ 206.987850] x13: 000000000017430e x12: 0000000000000580
[ 206.988251] x11: 0000000000000000 x10: cccccccccccccccc
[ 206.988740] x9 : 0000000000000000 x8 : ffff000013917550
[ 206.990198] x7 : ffff000012fac2e8 x6 : ffff000012fac000
[ 206.991008] x5 : ffff0000103da588 x4 : 0000000000000001
[ 206.991395] x3 : 0000000000000001 x2 : ffff000013872a28
[ 206.991771] x1 : 0000000000000000 x0 : 0000000000000000
[ 206.992557] Call trace:
[ 206.993101] free_ftrace_func_mapper+0x2c/0x118
[ 206.994827] ftrace_count_free+0x68/0x80
[ 206.995238] release_probe+0xfc/0x1d0
[ 206.995555] register_ftrace_function_probe+0x4a8/0x868
[ 206.995923] ftrace_trace_probe_callback.isra.4+0xb8/0x180
[ 206.996330] ftrace_dump_callback+0x50/0x70
[ 206.996663] ftrace_regex_write.isra.29+0x290/0x3a8
[ 206.997157] ftrace_filter_write+0x44/0x60
[ 206.998971] __vfs_write+0x64/0xf0
[ 206.999285] vfs_write+0x14c/0x2f0
[ 206.999591] ksys_write+0xbc/0x1b0
[ 206.999888] __arm64_sys_write+0x3c/0x58
[ 207.000246] el0_svc_common.constprop.0+0x408/0x5f0
[ 207.000607] el0_svc_handler+0x144/0x1c8
[ 207.000916] el0_svc+0x8/0xc
[ 207.003699] Code: aa0003f8 a9025bf5 aa0103f5 f946ea80 (f9400303)
[ 207.008388] ---[ end trace 7b6d11b5f542bdf1 ]---
[ 207.010126] Kernel panic - not syncing: Fatal exception
[ 207.011322] SMP: stopping secondary CPUs
[ 207.013956] Dumping ftrace buffer:
[ 207.014595] (ftrace buffer empty)
[ 207.015632] Kernel Offset: disabled
[ 207.017187] CPU features: 0x002,20006008
[ 207.017985] Memory Limit: none
[ 207.019825] ---[ end Kernel panic - not syncing: Fatal exception ]---
Link: http://lkml.kernel.org/r/20190606031754.10798-1-liwei391@huawei.com
Signed-off-by: Wei Li <liwei391@huawei.com>
[ Upstream commit 9f255b632bf12c4dd7fc31caee89aa991ef75176 ]
It's possible for livepatch and ftrace to be toggling a module's text
permissions at the same time, resulting in the following panic:
BUG: unable to handle page fault for address: ffffffffc005b1d9
#PF: supervisor write access in kernel mode
#PF: error_code(0x0003) - permissions violation
PGD 3ea0c067 P4D 3ea0c067 PUD 3ea0e067 PMD 3cc13067 PTE 3b8a1061
Oops: 0003 [#1] PREEMPT SMP PTI
CPU: 1 PID: 453 Comm: insmod Tainted: G O K 5.2.0-rc1-a188339ca5 #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.12.0-20181126_142135-anatol 04/01/2014
RIP: 0010:apply_relocate_add+0xbe/0x14c
Code: fa 0b 74 21 48 83 fa 18 74 38 48 83 fa 0a 75 40 eb 08 48 83 38 00 74 33 eb 53 83 38 00 75 4e 89 08 89 c8 eb 0a 83 38 00 75 43 <89> 08 48 63 c1 48 39 c8 74 2e eb 48 83 38 00 75 32 48 29 c1 89 08
RSP: 0018:ffffb223c00dbb10 EFLAGS: 00010246
RAX: ffffffffc005b1d9 RBX: 0000000000000000 RCX: ffffffff8b200060
RDX: 000000000000000b RSI: 0000004b0000000b RDI: ffff96bdfcd33000
RBP: ffffb223c00dbb38 R08: ffffffffc005d040 R09: ffffffffc005c1f0
R10: ffff96bdfcd33c40 R11: ffff96bdfcd33b80 R12: 0000000000000018
R13: ffffffffc005c1f0 R14: ffffffffc005e708 R15: ffffffff8b2fbc74
FS: 00007f5f447beba8(0000) GS:ffff96bdff900000(0000) knlGS:0000000000000000
CR2: ffffffffc005b1d9 CR3: 000000003cedc002 CR4: 0000000000360ea0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
klp_init_object_loaded+0x10f/0x219
? preempt_latency_start+0x21/0x57
klp_enable_patch+0x662/0x809
? virt_to_head_page+0x3a/0x3c
? kfree+0x8c/0x126
patch_init+0x2ed/0x1000 [livepatch_test02]
? 0xffffffffc0060000
do_one_initcall+0x9f/0x1c5
? kmem_cache_alloc_trace+0xc4/0xd4
? do_init_module+0x27/0x210
do_init_module+0x5f/0x210
load_module+0x1c41/0x2290
? fsnotify_path+0x3b/0x42
? strstarts+0x2b/0x2b
? kernel_read+0x58/0x65
__do_sys_finit_module+0x9f/0xc3
? __do_sys_finit_module+0x9f/0xc3
__x64_sys_finit_module+0x1a/0x1c
do_syscall_64+0x52/0x61
entry_SYSCALL_64_after_hwframe+0x44/0xa9
The above panic occurs when loading two modules at the same time with
ftrace enabled, where at least one of the modules is a livepatch module:
CPU0 CPU1
klp_enable_patch()
klp_init_object_loaded()
module_disable_ro()
set_all_modules_text_ro()
klp_write_object_relocations()
apply_relocate_add()
*patches read-only code* - BOOM
A similar race exists when toggling ftrace while loading a livepatch
module.
Fix it by ensuring that the livepatch and ftrace code patching
operations -- and their respective permissions changes -- are protected
by the text_mutex.
Link: http://lkml.kernel.org/r/ab43d56ab909469ac5d2520c5d944ad6d4abd476.1560474114.git.jpoimboe@redhat.com
Reported-by: Johannes Erdfelt <johannes@erdfelt.com>
Fixes: 444d13ff10fb ("modules: add ro_after_init support")
Acked-by: Jessica Yu <jeyu@kernel.org>
Reviewed-by: Petr Mladek <pmladek@suse.com>
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
commit fabe38ab6b2bd9418350284c63825f13b8a6abba upstream.
Mark ftrace mcount handler functions nokprobe since
probing on these functions with kretprobe pushes
return address incorrectly on kretprobe shadow stack.
Reported-by: Francis Deslauriers <francis.deslauriers@efficios.com>
Tested-by: Andrea Righi <righi.andrea@gmail.com>
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Link: http://lkml.kernel.org/r/155094062044.6137.6419622920568680640.stgit@devbox
commit 2840f84f74035e5a535959d5f17269c69fa6edc5 upstream.
The following commands will cause a memory leak:
# cd /sys/kernel/tracing
# mkdir instances/foo
# echo schedule > instance/foo/set_ftrace_filter
# rmdir instances/foo
The reason is that the hashes that hold the filters to set_ftrace_filter and
set_ftrace_notrace are not freed if they contain any data on the instance
and the instance is removed.
Found by kmemleak detector.
Fixes: 591dffdade9f ("ftrace: Allow for function tracing instance to filter functions")
commit 7b6586562708d2b3a04fe49f217ddbadbbbb0546 upstream.
__unregister_ftrace_function_probe() will incorrectly parse the glob filter
because it resets the search variable that was setup by filter_parse_regex().
Al Viro reported this:
After that call of filter_parse_regex() we could have func_g.search not
equal to glob only if glob started with '!' or '*'. In the former case
we would've buggered off with -EINVAL (not = 1). In the latter we
would've set func_g.search equal to glob + 1, calculated the length of
that thing in func_g.len and proceeded to reset func_g.search back to
glob.
Suppose the glob is e.g. *foo*. We end up with
func_g.type = MATCH_MIDDLE_ONLY;
func_g.len = 3;
func_g.search = "*foo";
Feeding that to ftrace_match_record() will not do anything sane - we
will be looking for names containing "*foo" (->len is ignored for that
one).
Link: http://lkml.kernel.org/r/20180127031706.GE13338@ZenIV.linux.org.uk
Fixes: 3ba009297149f ("ftrace: Introduce ftrace_glob structure")
Reviewed-by: Dmitry Safonov <0x7f454c46@gmail.com>
Reviewed-by: Masami Hiramatsu <mhiramat@kernel.org>
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
The trampoline allocated by function tracer was overwriten by function_graph
tracer, and caused a memory leak. The save_global_trampoline should have
saved the previous trampoline in register_ftrace_graph() and restored it in
unregister_ftrace_graph(). But as it is implemented, save_global_trampoline was
only used in unregister_ftrace_graph as default value 0, and it overwrote the
previous trampoline's value. Causing the previous allocated trampoline to be
lost.
kmmeleak backtrace:
kmemleak_vmalloc+0x77/0xc0
__vmalloc_node_range+0x1b5/0x2c0
module_alloc+0x7c/0xd0
arch_ftrace_update_trampoline+0xb5/0x290
ftrace_startup+0x78/0x210
register_ftrace_function+0x8b/0xd0
function_trace_init+0x4f/0x80
tracing_set_tracer+0xe6/0x170
tracing_set_trace_write+0x90/0xd0
__vfs_write+0x37/0x170
vfs_write+0xb2/0x1b0
SyS_write+0x55/0xc0
do_syscall_64+0x67/0x180
return_from_SYSCALL_64+0x0/0x6a
Looking further into this, I found that this was left over from when the
function and function graph tracers shared the same ftrace_ops. But in
commit 5f151b2401 ("ftrace: Fix function_profiler and function tracer
together"), the two were separated, and the save_global_trampoline no
longer was necessary (and it may have been broken back then too).
-- Steven Rostedt
Link: http://lkml.kernel.org/r/20170912021454.5976-1-shuwang@redhat.com
Fixes: 5f151b2401 ("ftrace: Fix function_profiler and function tracer together")
Signed-off-by: Shu Wang <shuwang@redhat.com>
If function tracing is disabled by the user via the function-trace option or
the proc sysctl file, and a ftrace_ops that was allocated on the heap is
unregistered, then the shutdown code exits out without doing the proper
clean up. This was found via kmemleak and running the ftrace selftests, as
one of the tests unregisters with function tracing disabled.
# cat kmemleak
unreferenced object 0xffffffffa0020000 (size 4096):
comm "swapper/0", pid 1, jiffies 4294668889 (age 569.209s)
hex dump (first 32 bytes):
55 ff 74 24 10 55 48 89 e5 ff 74 24 18 55 48 89 U.t$.UH...t$.UH.
e5 48 81 ec a8 00 00 00 48 89 44 24 50 48 89 4c .H......H.D$PH.L
backtrace:
[<ffffffff81d64665>] kmemleak_vmalloc+0x85/0xf0
[<ffffffff81355631>] __vmalloc_node_range+0x281/0x3e0
[<ffffffff8109697f>] module_alloc+0x4f/0x90
[<ffffffff81091170>] arch_ftrace_update_trampoline+0x160/0x420
[<ffffffff81249947>] ftrace_startup+0xe7/0x300
[<ffffffff81249bd2>] register_ftrace_function+0x72/0x90
[<ffffffff81263786>] trace_selftest_ops+0x204/0x397
[<ffffffff82bb8971>] trace_selftest_startup_function+0x394/0x624
[<ffffffff81263a75>] run_tracer_selftest+0x15c/0x1d7
[<ffffffff82bb83f1>] init_trace_selftests+0x75/0x192
[<ffffffff81002230>] do_one_initcall+0x90/0x1e2
[<ffffffff82b7d620>] kernel_init_freeable+0x350/0x3fe
[<ffffffff81d61ec3>] kernel_init+0x13/0x122
[<ffffffff81d72c6a>] ret_from_fork+0x2a/0x40
[<ffffffffffffffff>] 0xffffffffffffffff
Fixes: 12cce594fa ("ftrace/x86: Allow !CONFIG_PREEMPT dynamic ops to use allocated trampolines")
When a ftrace filter has a module function, and that module is removed, the
filter still has its address as being enabled. This can cause interesting
side effects. Nothing dangerous, but unwanted functions can be traced
because of it.
# echo ':mod:snd_seq' > set_ftrace_filter
# cat set_ftrace_filter
snd_use_lock_sync_helper [snd_seq]
check_event_type_and_length [snd_seq]
snd_seq_ioctl_pversion [snd_seq]
snd_seq_ioctl_client_id [snd_seq]
snd_seq_ioctl_get_queue_tempo [snd_seq]
update_timestamp_of_queue [snd_seq]
snd_seq_ioctl_get_queue_status [snd_seq]
snd_seq_set_queue_tempo [snd_seq]
snd_seq_ioctl_set_queue_tempo [snd_seq]
snd_seq_ioctl_get_queue_timer [snd_seq]
seq_free_client1 [snd_seq]
# rmmod snd_seq
# modprobe kvm
kvm_set_cr4 [kvm]
kvm_emulate_hypercall [kvm]
kvm_set_dr [kvm]
This is because removing the snd_seq module after it was being filtered,
left the address of the snd_seq functions in the hash. When the kvm module
was loaded, some of its functions were loaded at the same address as the
snd_seq module. This would enable them to be filtered and traced.
Now we don't want to clear the hash completely. That would cause removing a
module where only its functions are filtered, to cause the tracing to enable
all functions, as an empty filter means to trace all functions. Instead,
just set the hash ip address to zero. Then it will never match any function.
There's a small race when function graph shutsdown and the calling of the
registered function graph entry callback. The callback must not reference
the task's ret_stack without first checking that it is not NULL. Note, when
a ret_stack is allocated for a task, it stays allocated until the task exits.
The problem here, is that function_graph is shutdown, and a new task was
created, which doesn't have its ret_stack allocated. But since some of the
functions are still being traced, the callbacks can still be called.
The normal function_graph code handles this, but starting with commit
8861dd303c ("ftrace: Access ret_stack->subtime only in the function
profiler") the profiler code references the ret_stack on function entry, but
doesn't check if it is NULL first.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=196611
Fixes: 8861dd303c ("ftrace: Access ret_stack->subtime only in the function profiler")
Reported-by: lilydjwg@gmail.com
The variables which are processed by RCU functions should be annotated
as RCU, otherwise sparse will report the errors like below:
"error: incompatible types in comparison expression (different
address spaces)"
Link: http://lkml.kernel.org/r/1496823171-7758-1-git-send-email-zhang.chunyan@linaro.org
Signed-off-by: Chunyan Zhang <zhang.chunyan@linaro.org>
[ Updated to not be 100% 80 column strict ]
My static checker complains that if "func" is NULL then "clear_filter"
is uninitialized. This seems like it could be true, although it's
possible something subtle is happening that I haven't seen.
kernel/trace/ftrace.c:3844 match_records()
error: uninitialized symbol 'clear_filter'.
Link: http://lkml.kernel.org/r/20170712073556.h6tkpjcdzjaozozs@mwanda
Fixes: f0a3b154bd7 ("ftrace: Clarify code for mod command")
"func" can't be NULL and it doesn't make sense to check because we've
already derefenced it.
Link: http://lkml.kernel.org/r/20170712073340.4enzeojeoupuds5a@mwanda
When modules are disabled, we get a harmless build warning:
kernel/trace/ftrace.c:4051:13: error: 'process_cached_mods' defined but not used [-Werror=unused-function]
This adds the same #ifdef around the new code that exists around
its caller.
Link: http://lkml.kernel.org/r/20170710084413.1820568-1-arnd@arndb.de
Fixes: d7fbf8df7ca0 ("ftrace: Implement cached modules tracing on module load")
As writing into stack_trace_filter, the iter-tr is not set and is NULL.
Check if it is NULL before dereferencing it in ftrace_regex_release().
Fixes: 8c08f0d5c6fb ("ftrace: Have cached module filters be an active filter")
Need to get the changes from 0f17976568b3 ("ftrace: Fix regression with
module command in stack_trace_filter") as it is required to fix some other
changes with stack_trace_filter and the new development code.
When doing the following command:
# echo ":mod:kvm_intel" > /sys/kernel/tracing/stack_trace_filter
it triggered a crash.
This happened with the clean up of probes. It required all callers to the
regex function (doing ftrace filtering) to have ops->private be a pointer to
a trace_array. But for the stack tracer, that is not the case.
Allow for the ops->private to be NULL, and change the function command
callbacks to handle the trace_array pointer being NULL as well.
Fixes: d2afd57a4b96 ("tracing/ftrace: Allow instances to have their own function probes")
Init boot up functions may be traced, but they are also freed when the
kernel finishes booting. These are removed from the ftrace tables, and the
debug variable for dyn_ftrace_total_info needs to reflect that as well.
If the new_hash fails to allocate, then unlock the hash mutex on error.
Reported-by: Julia Lawall <julia.lawall@lip6.fr>
The dyn_ftrace_total_info file is used to show how many functions have been
converted into nops and can be used by ftrace. The problem is that it does
not get decremented when functions are removed (init boot code being freed,
and modules being freed). That means the number is very inaccurate everytime
functions are removed from the ftrace tables. Decrement it when functions
are removed.
When a module filter is added to set_ftrace_filter, if the module is not
loaded, it is cached. This should be considered an active filter, and
function tracing should be filtered by this. That is, if a cached module
filter is the only filter set, then no function tracing should be happening,
as all the functions available will be filtered out.
This makes sense, as the reason to add a cached module filter, is to trace
the module when you load it. There shouldn't be any other tracing happening
until then.
If a module is cached in the set_ftrace_filter, and that module is loaded,
then enable tracing on that module as if the cached module text was written
into set_ftrace_filter just as the module is loaded.
# cat /sys/kernel/tracing/set_ftrace_filter
:mod:kvm_intel
# modprobe kvm_intel
vmx_get_rflags [kvm_intel]
vmx_get_pkru [kvm_intel]
vmx_get_interrupt_shadow [kvm_intel]
vmx_rdtscp_supported [kvm_intel]
vmx_invpcid_supported [kvm_intel]
When writing in a module filter into set_ftrace_filter for a module that is
not yet loaded, it it cached, and will be executed when the module is loaded
(although that is not implemented yet at this commit). Display the list of
cached modules to be traced.
This is the start of the infrastructure work to allow for tracing module
functions before it is loaded.
Currently the following command:
# echo :mod:some-mod > set_ftrace_filter
will enable tracing of all functions within the module "some-mod" if it is
loaded. What we want, is if the module is not loaded, that line will be
saved. When the module is loaded, then the "some-mod" will have that line
executed on it, so that the functions within it starts being traced.
ftrace_hash is being kfree'ed in ftrace_graph_release(), however the
->buckets field is not. This results in a memory leak that is easily
captured by kmemleak:
unreferenced object 0xffff880038afe000 (size 8192):
comm "trace-cmd", pid 238, jiffies 4294916898 (age 9.736s)
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff815f561e>] kmemleak_alloc+0x4e/0xb0
[<ffffffff8113964d>] __kmalloc+0x12d/0x1a0
[<ffffffff810bf6d1>] alloc_ftrace_hash+0x51/0x80
[<ffffffff810c0523>] __ftrace_graph_open.isra.39.constprop.46+0xa3/0x100
[<ffffffff810c05e8>] ftrace_graph_open+0x68/0xa0
[<ffffffff8114003d>] do_dentry_open.isra.1+0x1bd/0x2d0
[<ffffffff81140df7>] vfs_open+0x47/0x60
[<ffffffff81150f95>] path_openat+0x2a5/0x1020
[<ffffffff81152d6a>] do_filp_open+0x8a/0xf0
[<ffffffff811411df>] do_sys_open+0x12f/0x200
[<ffffffff811412ce>] SyS_open+0x1e/0x20
[<ffffffff815fa6e0>] entry_SYSCALL_64_fastpath+0x13/0x94
Link: http://lkml.kernel.org/r/20170525152038.7661-1-lhenriques@suse.com
Fixes: b9b0c831bed2 ("ftrace: Convert graph filter to use hash tables")
Signed-off-by: Luis Henriques <lhenriques@suse.com>
If instance directories are deleted while there are registered function
triggers:
# cd /sys/kernel/debug/tracing/instances
# mkdir test
# echo "schedule:enable_event:sched:sched_switch" > test/set_ftrace_filter
# rmdir test
Unable to handle kernel paging request for data at address 0x00000008
Faulting instruction address: 0xc0000000021edde8
SMP NR_CPUS=2048
NUMA
pSeries
Modules linked in: iptable_mangle ipt_MASQUERADE nf_nat_masquerade_ipv4 iptable_nat nf_nat_ipv4 nf_nat nf_conntrack_ipv4 nf_defrag_ipv4 xt_conntrack nf_conntrack ipt_REJECT nf_reject_ipv4 xt_tcpudp tun bridge stp llc kvm iptable_filter fuse binfmt_misc pseries_rng rng_core vmx_crypto ib_iser rdma_cm iw_cm ib_cm ib_core libiscsi scsi_transport_iscsi ip_tables x_tables autofs4 btrfs raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c multipath virtio_net virtio_blk virtio_pci crc32c_vpmsum virtio_ring virtio
CPU: 8 PID: 8694 Comm: rmdir Not tainted 4.11.0-nnr+ #113
task: c0000000bab52800 task.stack: c0000000baba0000
NIP: c0000000021edde8 LR: c0000000021f0590 CTR: c000000002119620
REGS: c0000000baba3870 TRAP: 0300 Not tainted (4.11.0-nnr+)
MSR: 8000000000009033 <SF,EE,ME,IR,DR,RI,LE>
CR: 22002422 XER: 20000000
CFAR: 00007fffabb725a8 DAR: 0000000000000008 DSISR: 40000000 SOFTE: 0
GPR00: c00000000220f750 c0000000baba3af0 c000000003157e00 0000000000000000
GPR04: 0000000000000040 00000000000000eb 0000000000000040 0000000000000000
GPR08: 0000000000000000 0000000000000113 0000000000000000 c00000000305db98
GPR12: c000000002119620 c00000000fd42c00 0000000000000000 0000000000000000
GPR16: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
GPR20: 0000000000000000 0000000000000000 c0000000bab52e90 0000000000000000
GPR24: 0000000000000000 00000000000000eb 0000000000000040 c0000000baba3bb0
GPR28: c00000009cb06eb0 c0000000bab52800 c00000009cb06eb0 c0000000baba3bb0
NIP [c0000000021edde8] ring_buffer_lock_reserve+0x8/0x4e0
LR [c0000000021f0590] trace_event_buffer_lock_reserve+0xe0/0x1a0
Call Trace:
[c0000000baba3af0] [c0000000021f96c8] trace_event_buffer_commit+0x1b8/0x280 (unreliable)
[c0000000baba3b60] [c00000000220f750] trace_event_buffer_reserve+0x80/0xd0
[c0000000baba3b90] [c0000000021196b8] trace_event_raw_event_sched_switch+0x98/0x180
[c0000000baba3c10] [c0000000029d9980] __schedule+0x6e0/0xab0
[c0000000baba3ce0] [c000000002122230] do_task_dead+0x70/0xc0
[c0000000baba3d10] [c0000000020ea9c8] do_exit+0x828/0xd00
[c0000000baba3dd0] [c0000000020eaf70] do_group_exit+0x60/0x100
[c0000000baba3e10] [c0000000020eb034] SyS_exit_group+0x24/0x30
[c0000000baba3e30] [c00000000200bcec] system_call+0x38/0x54
Instruction dump:
60000000 60420000 7d244b78 7f63db78 4bffaa09 393efff8 793e0020 39200000
4bfffecc 60420000 3c4c00f7 3842a020 <81230008> 2f890000 409e02f0 a14d0008
---[ end trace b917b8985d0e650b ]---
To address this, let's clear all registered function probes before
deleting the ftrace instance.
Link: http://lkml.kernel.org/r/c5f1ca624043690bd94642bb6bffd3f2fc504035.1494956770.git.naveen.n.rao@linux.vnet.ibm.com
Reported-by: Michael Ellerman <mpe@ellerman.id.au>
Handle a NULL glob properly and simplify the check.
Link: http://lkml.kernel.org/r/5df74d4ffb4721db6d5a22fa08ca031d62ead493.1494956770.git.naveen.n.rao@linux.vnet.ibm.com
Dan Carpenter sent a patch to remove a check in ftrace_match_record()
because the logic of the code made the check redundant. I looked deeper into
the code, and made the following logic table, with the three variables and
the result of the original code.
modname mod_matches exclude_mod result
0 0 0 return 0
0 0 1 func_match
0 1 * < cannot exist >
1 0 0 return 0
1 0 1 func_match
1 1 0 func_match
1 1 1 return 0
Notice that when mod_matches == exclude mod, the result is always to
return 0, and when mod_matches != exclude_mod, then the result is to test
the function. This means we only need test if mod_matches is equal to
exclude_mod.
Cc: Dan Carpenter <dan.carpenter@oracle.com>
We know that "mod_matches" is true here so there is no need to check
again.
Link: http://lkml.kernel.org/r/20170331152130.GA4947@mwanda
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing updates from Steven Rostedt:
"New features for this release:
- Pretty much a full rewrite of the processing of function plugins.
i.e. echo do_IRQ:stacktrace > set_ftrace_filter
- The rewrite was needed to add plugins to be unique to tracing
instances. i.e. mkdir instance/foo; cd instances/foo; echo
do_IRQ:stacktrace > set_ftrace_filter The old way was written very
hacky. This removes a lot of those hacks.
- New "function-fork" tracing option. When set, pids in the
set_ftrace_pid will have their children added when the processes
with their pids listed in the set_ftrace_pid file forks.
- Exposure of "maxactive" for kretprobe in kprobe_events
- Allow for builtin init functions to be traced by the function
tracer (via the kernel command line). Module init function tracing
will come in the next release.
- Added more selftests, and have selftests also test in an instance"
* tag 'trace-v4.12' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (60 commits)
ring-buffer: Return reader page back into existing ring buffer
selftests: ftrace: Allow some event trigger tests to run in an instance
selftests: ftrace: Have some basic tests run in a tracing instance too
selftests: ftrace: Have event tests also run in an tracing instance
selftests: ftrace: Make func_event_triggers and func_traceonoff_triggers tests do instances
selftests: ftrace: Allow some tests to be run in a tracing instance
tracing/ftrace: Allow for instances to trigger their own stacktrace probes
tracing/ftrace: Allow for the traceonoff probe be unique to instances
tracing/ftrace: Enable snapshot function trigger to work with instances
tracing/ftrace: Add a better way to pass data via the probe functions
tracing: Pass the trace_array into ftrace_probe_ops functions
tracing: Have the trace_array hold the list of registered func probes
ftrace: If the hash for a probe fails to update then free what was initialized
ftrace: Have the function probes call their own function
ftrace: Have unregister_ftrace_function_probe_func() return a value
ftrace: Add helper function ftrace_hash_move_and_update_ops()
ftrace: Remove data field from ftrace_func_probe structure
Pass around the local trace_array that is the descriptor for tracing
instances, when enabling and disabling probes. This by default sets the
enable/disable of event probe triggers to work with instances.
The other probes will need some more work to get them working with
instances.
With the redesign of the registration and execution of the function probes
(triggers), data can now be passed from the setup of the probe to the probe
callers that are specific to the trace_array it is on. Although, all probes
still only affect the toplevel trace array, this change will allow for
instances to have their own probes separated from other instances and the
top array.
That is, something like the stacktrace probe can be set to trace only in an
instance and not the toplevel trace array. This isn't implement yet, but
this change sets the ground work for the change.
When a probe callback is triggered (someone writes the probe format into
set_ftrace_filter), it calls register_ftrace_function_probe() passing in
init_data that will be used to initialize the probe. Then for every matching
function, register_ftrace_function_probe() will call the probe_ops->init()
function with the init data that was passed to it, as well as an address to
a place holder that is associated with the probe and the instance. The first
occurrence will have a NULL in the pointer. The init() function will then
initialize it. If other probes are added, or more functions are part of the
probe, the place holder will be passed to the init() function with the place
holder data that it was initialized to the last time.
Then this place_holder is passed to each of the other probe_ops functions,
where it can be used in the function callback. When the probe_ops free()
function is called, it can be called either with the rip of the function
that is being removed from the probe, or zero, indicating that there are no
more functions attached to the probe, and the place holder is about to be
freed. This gives the probe_ops a way to free the data it assigned to the
place holder if it was allocade during the first init call.
In order to eventually have each trace_array instance have its own unique
set of function probes (triggers), the trace array needs to hold the ops and
the filters for the probes.
This is the first step to accomplish this. Instead of having the private
data of the probe ops point to the trace_array, create a separate list that
the trace_array holds. There's only one private_data for a probe, we need
one per trace_array. The probe ftrace_ops will be dynamically created for
each instance, instead of being static.
Pass the trace_array associated to a ftrace_probe_ops into the probe_ops
func(), init() and free() functions. The trace_array is the descriptor that
describes a tracing instance. This will help create the infrastructure that
will allow having function probes unique to tracing instances.
Add a link list to the trace_array to hold func probes that are registered.
Currently, all function probes are the same for all instances as it was
before, that is, only the top level trace_array holds the function probes.
But this lays the ground work to have function probes be attached to
individual instances, and having the event trigger only affect events in the
given instance. But that work is still to be done.
If the ftrace_hash_move_and_update_ops() fails, and an ops->free() function
exists, then it needs to be called on all the ops that were added by this
registration.
Now that the function probes have their own ftrace_ops, there's no reason to
continue using the ftrace_func_hash to find which probe to call in the
function callback. The ops that is passed in to the function callback is
part of the probe_ops to call.
Have the function probes have their own ftrace_ops, and remove the
trace_probe_ops. This simplifies some of the ftrace infrastructure code.
Individual entries for each function is still allocated for the use of the
output for set_ftrace_filter, but they will be removed soon too.
Currently unregister_ftrace_function_probe_func() is a void function. It
does not give any feedback if an error occurred or no item was found to
remove and nothing was done.
Change it to return status and success if it removed something. Also update
the callers to return that feedback to the user.
The processes of updating a ops filter_hash is a bit complex, and requires
setting up an old hash to perform the update. This is done exactly the same
in two locations for the same reasons. Create a helper function that does it
in one place.
No users of the function probes uses the data field anymore. Remove it, and
change the init function to take a void *data parameter instead of a
void **data, because the init will just get the data that the registering
function was received, and there's no state after it is called.
The other functions for ftrace_probe_ops still take the data parameter, but
it will currently only be passed NULL. It will stay as a parameter for
future data to be passed to these functions.
None of the probe users uses the data field anymore of the entry. They all
have their own print() function. Remove showing the data field in the
generic function as the data field will be going away.
There are no users of unregister_ftrace_function_probe_all(). The only probe
function that is used is unregister_ftrace_function_probe_func(). Rename the
internal static function __unregister_ftrace_function_probe() to
unregister_ftrace_function_probe_func() and make it global.
Also remove the PROBE_TEST_FUNC as it would be always set.
Nothing calls unregister_ftrace_function_probe(). Remove it as well as the
flag PROBE_TEST_DATA, as this function was the only one to set it.
In order to move the ops to the function probes directly, they need a way to
map function ips to their own data without depending on the infrastructure
of the function probes, as the data field will be going away.
New helper functions are added that are based on the ftrace_hash code.
ftrace_func_mapper functions are there to let the probes map ips to their
data. These can be allocated by the probe ops, and referenced in the
function callbacks.
