path: root/kernel/trace/trace_export.c
2015-11-02tracing: ftrace_event_is_function() can return booleanYaowei Bai
Make ftrace_event_is_function() return bool to improve readability due to this particular function only using either one or zero as its return value. No functional change. Link: http://lkml.kernel.org/r/1443537816-5788-9-git-send-email-bywxiaobai@163.com Signed-off-by: Yaowei Bai <bywxiaobai@163.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-05-13tracing: Rename ftrace_event_{call,class} to trace_event_{call,class}Steven Rostedt (Red Hat)
The name "ftrace" really refers to the function hook infrastructure. It is not about the trace_events. The structures ftrace_event_call and ftrace_event_class have nothing to do with the function hooks, and are really trace_event structures. Rename ftrace_event_* to trace_event_*. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-03-25tracing: remove ftrace:function TRACE_EVENT_FL_USE_CALL_FILTER flagHe Kuang
TRACE_EVENT_FL_USE_CALL_FILTER flag in ftrace:functon event can be removed. This flag was first introduced in commit f306cc82a93d ("tracing: Update event filters for multibuffer"). Now, the only place uses this flag is ftrace:function, but the filter of ftrace:function has a different code path with events/syscalls and events/tracepoints. It uses ftrace_filter_write() and perf's ftrace_profile_set_filter() to set the filter, the functionality of file 'tracing/events/ftrace/function/filter' is bypassed in function init_pred(), in which case, neither call->filter nor file->filter is used. So we can safely remove TRACE_EVENT_FL_USE_CALL_FILTER flag from ftrace:function events. Link: http://lkml.kernel.org/r/1425367294-27852-1-git-send-email-hekuang@huawei.com Signed-off-by: He Kuang <hekuang@huawei.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-01-22tracing: Remove unneeded includes of debugfs.h and fs.hSteven Rostedt (Red Hat)
The creation of tracing files and directories is for the most part encapsulated in helper functions in trace.c. Other files do not need to include debugfs.h or fs.h, as they may have needed to in the past. Remove them from the files that do not need them. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-04-09tracing: Fix anonymous unions in struct ftrace_event_callMathieu Desnoyers
gcc <= 4.5.x has significant limitations with respect to initialization of anonymous unions within structures. They need to be surrounded by brackets, _and_ they need to be initialized in the same order in which they appear in the structure declaration. Link: http://gcc.gnu.org/bugzilla/show_bug.cgi?id=10676 Link: http://lkml.kernel.org/r/1397077568-3156-1-git-send-email-mathieu.desnoyers@efficios.com Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-03-20tracing: Fix array size mismatch in format stringVaibhav Nagarnaik
In event format strings, the array size is reported in two locations. One in array subscript and then via the "size:" attribute. The values reported there have a mismatch. For e.g., in sched:sched_switch the prev_comm and next_comm character arrays have subscript values as [32] where as the actual field size is 16. name: sched_switch ID: 301 format: field:unsigned short common_type; offset:0; size:2; signed:0; field:unsigned char common_flags; offset:2; size:1; signed:0; field:unsigned char common_preempt_count; offset:3; size:1;signed:0; field:int common_pid; offset:4; size:4; signed:1; field:char prev_comm[32]; offset:8; size:16; signed:1; field:pid_t prev_pid; offset:24; size:4; signed:1; field:int prev_prio; offset:28; size:4; signed:1; field:long prev_state; offset:32; size:8; signed:1; field:char next_comm[32]; offset:40; size:16; signed:1; field:pid_t next_pid; offset:56; size:4; signed:1; field:int next_prio; offset:60; size:4; signed:1; After bisection, the following commit was blamed: 92edca0 tracing: Use direct field, type and system names This commit removes the duplication of strings for field->name and field->type assuming that all the strings passed in __trace_define_field() are immutable. This is not true for arrays, where the type string is created in event_storage variable and field->type for all array fields points to event_storage. Use __stringify() to create a string constant for the type string. Also, get rid of event_storage and event_storage_mutex that are not needed anymore. also, an added benefit is that this reduces the overhead of events a bit more: text data bss dec hex filename 8424787 2036472 1302528 11763787 b3804b vmlinux 8420814 2036408 1302528 11759750 b37086 vmlinux.patched Link: http://lkml.kernel.org/r/1392349908-29685-1-git-send-email-vnagarnaik@google.com Cc: Laurent Chavey <chavey@google.com> Cc: stable@vger.kernel.org # 3.10+ Signed-off-by: Vaibhav Nagarnaik <vnagarnaik@google.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-11-05tracing: Update event filters for multibufferTom Zanussi
The trace event filters are still tied to event calls rather than event files, which means you don't get what you'd expect when using filters in the multibuffer case: Before: # echo 'bytes_alloc > 8192' > /sys/kernel/debug/tracing/events/kmem/kmalloc/filter # cat /sys/kernel/debug/tracing/events/kmem/kmalloc/filter bytes_alloc > 8192 # mkdir /sys/kernel/debug/tracing/instances/test1 # echo 'bytes_alloc > 2048' > /sys/kernel/debug/tracing/instances/test1/events/kmem/kmalloc/filter # cat /sys/kernel/debug/tracing/events/kmem/kmalloc/filter bytes_alloc > 2048 # cat /sys/kernel/debug/tracing/instances/test1/events/kmem/kmalloc/filter bytes_alloc > 2048 Setting the filter in tracing/instances/test1/events shouldn't affect the same event in tracing/events as it does above. After: # echo 'bytes_alloc > 8192' > /sys/kernel/debug/tracing/events/kmem/kmalloc/filter # cat /sys/kernel/debug/tracing/events/kmem/kmalloc/filter bytes_alloc > 8192 # mkdir /sys/kernel/debug/tracing/instances/test1 # echo 'bytes_alloc > 2048' > /sys/kernel/debug/tracing/instances/test1/events/kmem/kmalloc/filter # cat /sys/kernel/debug/tracing/events/kmem/kmalloc/filter bytes_alloc > 8192 # cat /sys/kernel/debug/tracing/instances/test1/events/kmem/kmalloc/filter bytes_alloc > 2048 We'd like to just move the filter directly from ftrace_event_call to ftrace_event_file, but there are a couple cases that don't yet have multibuffer support and therefore have to continue using the current event_call-based filters. For those cases, a new USE_CALL_FILTER bit is added to the event_call flags, whose main purpose is to keep the old behavior for those cases until they can be updated with multibuffer support; at that point, the USE_CALL_FILTER flag (and the new associated call_filter_check_discard() function) can go away. The multibuffer support also made filter_current_check_discard() redundant, so this change removes that function as well and replaces it with filter_check_discard() (or call_filter_check_discard() as appropriate). Link: http://lkml.kernel.org/r/f16e9ce4270c62f46b2e966119225e1c3cca7e60.1382620672.git.tom.zanussi@linux.intel.com Signed-off-by: Tom Zanussi <tom.zanussi@linux.intel.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-03-15tracing: Fix some section mismatch warningsLi Zefan
As we've added __init annotation to field-defining functions, we should add __refdata annotation to event_call variables, which reference those functions. Link: http://lkml.kernel.org/r/51343C1F.2050502@huawei.com Reported-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-03-15tracing: Annotate event field-defining functions with __initLi Zefan
Those functions are called either during kernel boot or module init. Before: $ dmesg | grep 'Freeing unused kernel memory' Freeing unused kernel memory: 1208k freed Freeing unused kernel memory: 1360k freed Freeing unused kernel memory: 1960k freed After: $ dmesg | grep 'Freeing unused kernel memory' Freeing unused kernel memory: 1236k freed Freeing unused kernel memory: 1388k freed Freeing unused kernel memory: 1960k freed Link: http://lkml.kernel.org/r/5125877D.5000201@huawei.com Signed-off-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-05-10tracing: Do not enable function event with enableSteven Rostedt
With the adding of function tracing event to perf, it caused a side effect that produces the following warning when enabling all events in ftrace: # echo 1 > /sys/kernel/debug/tracing/events/enable [console] event trace: Could not enable event function This is because when enabling all events via the debugfs system it ignores events that do not have a ->reg() function assigned. This was to skip over the ftrace internal events (as they are not TRACE_EVENTs). But as the ftrace function event now has a ->reg() function attached to it for use with perf, it is no longer ignored. Worse yet, this ->reg() function is being called when it should not be. It returns an error and causes the above warning to be printed. By adding a new event_call flag (TRACE_EVENT_FL_IGNORE_ENABLE) and have all ftrace internel event structures have it set, setting the events/enable will no longe try to incorrectly enable the function event and does not warn. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-03-24Merge branch 'tip/perf/urgent' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into perf/urgent
2012-03-22tracing: Fix ftrace stack trace entriesWolfgang Mauerer
8 hex characters tell only half the tale for 64 bit CPUs, so use the appropriate length. Link: http://lkml.kernel.org/r/1332411501-8059-2-git-send-email-wolfgang.mauerer@siemens.com Cc: stable@vger.kernel.org Signed-off-by: Wolfgang Mauerer <wolfgang.mauerer@siemens.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-02-21ftrace: Allow to specify filter field type for ftrace eventsJiri Olsa
Adding FILTER_TRACE_FN event field type for function tracepoint event, so it can be properly recognized within filtering code. Currently all fields of ftrace subsystem events share the common field type FILTER_OTHER. Since the function trace fields need special care within the filtering code we need to recognize it properly, hence adding the FILTER_TRACE_FN event type. Adding filter parameter to the FTRACE_ENTRY macro, to specify the filter field type for the event. Link: http://lkml.kernel.org/r/1329317514-8131-7-git-send-email-jolsa@redhat.com Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-02-21ftrace, perf: Add support to use function tracepoint in perfJiri Olsa
Adding perf registration support for the ftrace function event, so it is now possible to register it via perf interface. The perf_event struct statically contains ftrace_ops as a handle for function tracer. The function tracer is registered/unregistered in open/close actions. To be efficient, we enable/disable ftrace_ops each time the traced process is scheduled in/out (via TRACE_REG_PERF_(ADD|DELL) handlers). This way tracing is enabled only when the process is running. Intentionally using this way instead of the event's hw state PERF_HES_STOPPED, which would not disable the ftrace_ops. It is now possible to use function trace within perf commands like: perf record -e ftrace:function ls perf stat -e ftrace:function ls Allowed only for root. Link: http://lkml.kernel.org/r/1329317514-8131-6-git-send-email-jolsa@redhat.com Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-02-21ftrace: Add FTRACE_ENTRY_REG macro to allow event registrationJiri Olsa
Adding FTRACE_ENTRY_REG macro so particular ftrace entries could specify registration function and thus become accesible via perf. This will be used in upcomming patch for function trace. Link: http://lkml.kernel.org/r/1329317514-8131-5-git-send-email-jolsa@redhat.com Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-02-02tracing: Replace trace_event struct array with pointer arraySteven Rostedt
Currently the trace_event structures are placed in the _ftrace_events section, and at link time, the linker makes one large array of all the trace_event structures. On boot up, this array is read (much like the initcall sections) and the events are processed. The problem is that there is no guarantee that gcc will place complex structures nicely together in an array format. Two structures in the same file may be placed awkwardly, because gcc has no clue that they are suppose to be in an array. A hack was used previous to force the alignment to 4, to pack the structures together. But this caused alignment issues with other architectures (sparc). Instead of packing the structures into an array, the structures' addresses are now put into the _ftrace_event section. As pointers are always the natural alignment, gcc should always pack them tightly together (otherwise initcall, extable, etc would also fail). By having the pointers to the structures in the section, we can still iterate the trace_events without causing unnecessary alignment problems with other architectures, or depending on the current behaviour of gcc that will likely change in the future just to tick us kernel developers off a little more. The _ftrace_event section is also moved into the .init.data section as it is now only needed at boot up. Suggested-by: David Miller <davem@davemloft.net> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-11-19tracing/events: Show real number in array fieldsSteven Rostedt
Currently we have in something like the sched_switch event: field:char prev_comm[TASK_COMM_LEN]; offset:12; size:16; signed:1; When a userspace tool such as perf tries to parse this, the TASK_COMM_LEN is meaningless. This is done because the TRACE_EVENT() macro simply uses a #len to show the string of the length. When the length is an enum, we get a string that means nothing for tools. By adding a static buffer and a mutex to protect it, we can store the string into that buffer with snprintf and show the actual number. Now we get: field:char prev_comm[16]; offset:12; size:16; signed:1; Something much more useful. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-06-28tracing: Remove redundant raw_init callbacksLi Zefan
raw_init callback is optional. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4BFA37D4.7070500@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Remove duplicate id information in event structureSteven Rostedt
Now that the trace_event structure is embedded in the ftrace_event_call structure, there is no need for the ftrace_event_call id field. The id field is the same as the trace_event type field. Removing the id and re-arranging the structure brings down the tracepoint footprint by another 5K. text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4895024 1023812 861512 6780348 6775bc vmlinux.print 4894944 1018052 861512 6774508 675eec vmlinux.id Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Move raw_init from events to classSteven Rostedt
The raw_init function pointer in the event is used to initialize various kinds of events. The type of initialization needed is usually classed to the kind of event it is. Two events with the same class will always have the same initialization function, so it makes sense to move this to the class structure. Perhaps even making a special system structure would work since the initialization is the same for all events within a system. But since there's no system structure (yet), this will just move it to the class. text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4900375 1053380 861512 6815267 67fe23 vmlinux.fields 4900382 1048964 861512 6810858 67ecea vmlinux.init The text grew very slightly, but this is a constant growth that happened with the changing of the C files that call the init code. The bigger savings is the data which will be saved the more events share a class. Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Move fields from event to class structureSteven Rostedt
Move the defined fields from the event to the class structure. Since the fields of the event are defined by the class they belong to, it makes sense to have the class hold the information instead of the individual events. The events of the same class would just hold duplicate information. After this change the size of the kernel dropped another 3K: text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4900252 1057412 861512 6819176 680d68 vmlinux.regs 4900375 1053380 861512 6815267 67fe23 vmlinux.fields Although the text increased, this was mainly due to the C files having to adapt to the change. This is a constant increase, where new tracepoints will not increase the Text. But the big drop is in the data size (as well as needed allocations to hold the fields). This will give even more savings as more tracepoints are created. Note, if just TRACE_EVENT()s are used and not DECLARE_EVENT_CLASS() with several DEFINE_EVENT()s, then the savings will be lost. But we are pushing developers to consolidate events with DEFINE_EVENT() so this should not be an issue. The kprobes define a unique class to every new event, but are dynamic so it should not be a issue. The syscalls however have a single class but the fields for the individual events are different. The syscalls use a metadata to define the fields. I moved the fields list from the event to the metadata and added a "get_fields()" function to the class. This function is used to find the fields. For normal events and kprobes, get_fields() just returns a pointer to the fields list_head in the class. For syscall events, it returns the fields list_head in the metadata for the event. v2: Fixed the syscall fields. The syscall metadata needs a list of fields for both enter and exit. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-05-14tracing: Create class struct for eventsSteven Rostedt
This patch creates a ftrace_event_class struct that event structs point to. This class struct will be made to hold information to modify the events. Currently the class struct only holds the events system name. This patch slightly increases the size, but this change lays the ground work of other changes to make the footprint of tracepoints smaller. With 82 standard tracepoints, and 618 system call tracepoints (two tracepoints per syscall: enter and exit): text data bss dec hex filename 4913961 1088356 861512 6863829 68bbd5 vmlinux.orig 4914025 1088868 861512 6864405 68be15 vmlinux.class This patch also cleans up some stale comments in ftrace.h. v2: Fixed missing semi-colon in macro. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-01-06tracing: Remove show_format and related macros from TRACE_EVENTLai Jiangshan
The previous patches added the use of print_fmt string and changes the trace_define_field() function to also create the fields and format output for the event format files. text data bss dec hex filename 5857201 1355780 9336808 16549789 fc879d vmlinux 5884589 1351684 9337896 16574169 fce6d9 vmlinux-orig The above shows the size of the vmlinux after this patch set compared to the vmlinux-orig which is before the patch set. This saves us 27k on text, 1k on bss and adds just 4k of data. The total savings of 24k in size. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> LKML-Reference: <4B273D4D.40604@cn.fujitsu.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-01-06tracing: Add print_fmt fieldLai Jiangshan
This is part of a patch set that removes the show_format method in the ftrace event macros. The print_fmt field is added to hold the string that shows the print_fmt in the event format files. This patch only adds the field but it is currently not used. Later patches will use this field to enable us to remove the show_format field and function. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> LKML-Reference: <4B273D3E.2000704@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2010-01-06tracing: Have __dynamic_array() define a fieldLai Jiangshan
This is part of a patch set that removes the show_format method in the ftrace event macros. This patch set requires that all fields are added to the ftrace_event_call->fields. This patch changes __dynamic_array() to call trace_define_field() to include fields that use __dynamic_array(). Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> LKML-Reference: <4B273D36.8090100@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-12-30tracing: Fix sign fields in ftrace_define_fields_##call()Lai Jiangshan
Add is_signed_type() call to trace_define_field() in ftrace macros. The code previously just passed in 0 (false), disregarding whether or not the field was actually a signed type. Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> LKML-Reference: <4B273D3A.6020007@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-12-13tracing: Pull up calls to trace_define_common_fields()Li Zefan
Call trace_define_common_fields() in event_create_dir() only. This avoids trace events to handle it from their define_fields callbacks and shrinks the kernel code size: text data bss dec hex filename 5346802 1961864 7103260 14411926 dbe896 vmlinux.o.old 5345151 1961864 7103260 14410275 dbe223 vmlinux.o Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jason Baron <jbaron@redhat.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> LKML-Reference: <4B1DC49C.8000107@cn.fujitsu.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-12-05Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (470 commits) x86: Fix comments of register/stack access functions perf tools: Replace %m with %a in sscanf hw-breakpoints: Keep track of user disabled breakpoints tracing/syscalls: Make syscall events print callbacks static tracing: Add DEFINE_EVENT(), DEFINE_SINGLE_EVENT() support to docbook perf: Don't free perf_mmap_data until work has been done perf_event: Fix compile error perf tools: Fix _GNU_SOURCE macro related strndup() build error trace_syscalls: Remove unused syscall_name_to_nr() trace_syscalls: Simplify syscall profile trace_syscalls: Remove duplicate init_enter_##sname() trace_syscalls: Add syscall_nr field to struct syscall_metadata trace_syscalls: Remove enter_id exit_id trace_syscalls: Set event_enter_##sname->data to its metadata trace_syscalls: Remove unused event_syscall_enter and event_syscall_exit perf_event: Initialize data.period in perf_swevent_hrtimer() perf probe: Simplify event naming perf probe: Add --list option for listing current probe events perf probe: Add argv_split() from lib/argv_split.c perf probe: Move probe event utility functions to probe-event.c ...
2009-11-02tracing: Fix to use __always_unused attributeLi Zefan
____ftrace_check_##name() is used for compile-time check on F_printk() only, so it should be marked as __unused instead of __used. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <4AEE2D01.4010305@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-23Merge branch 'perf/core' into perf/probesIngo Molnar
Conflicts: tools/perf/Makefile Merge reason: - fix the conflict - pick up the pr_*() infrastructure to queue up dependent patch Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-06tracing/events: Add 'signed' field to format filesTom Zanussi
The sign info used for filters in the kernel is also useful to applications that process the trace stream. Add it to the format files and make it available to userspace. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: rostedt@goodmis.org Cc: lizf@cn.fujitsu.com Cc: hch@infradead.org Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1254809398-8078-2-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-23Merge commit 'linus/master' into tracing/kprobesFrederic Weisbecker
Conflicts: kernel/trace/Makefile kernel/trace/trace.h kernel/trace/trace_event_types.h kernel/trace/trace_export.c Merge reason: Sync with latest significant tracing core changes.
2009-09-14tracing: remove some unused macrosLi Zefan
- remove FTRACE_ENTRY_STRUCT_ONLY() - remove TRACE_XXX() macros Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4AADF6E6.3080606@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-09-14ftrace: add compile-time check on F_printk()Li Zefan
Make sure F_printk() has corrent format and args, and make sure changes in F_STRUCT() won't break F_printk(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4AADF6CC.1060809@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-09-12tracing: use the new trace_entries.h to create format filesSteven Rostedt
This patch changes the way the format files in debugfs/tracing/events/ftrace/*/format are created. It uses the new trace_entries.h file to automate the creation of the format files to ensure that they are always in sync with the actual structures. This is the same methodology used to create the format files for the TRACE_EVENT macro. This also updates the filter creation that was built on the creation of the format files. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-09-11Merge commit 'tracing/core' into tracing/kprobesFrederic Weisbecker
Conflicts: kernel/trace/trace_export.c kernel/trace/trace_kprobe.c Merge reason: This topic branch lacks an important build fix in tracing/core: 0dd7b74787eaf7858c6c573353a83c3e2766e674: tracing: Fix double CPP substitution in TRACE_EVENT_FN that prevents from multiple tracepoint headers inclusion crashes. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-08-31tracing/filters: Defer pred allocationLi Zefan
init_preds() allocates about 5392 bytes of memory (on x86_32) for a TRACE_EVENT. With my config, at system boot total memory occupied is: 5392 * (642 + 15) == 3459KB 642 == cat available_events | wc -l 15 == number of dirs in events/ftrace That's quite a lot, so we'd better defer memory allocation util it's needed, that's when filter is used. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> LKML-Reference: <4A9B8EA5.6020700@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-27tracing: Introduce TRACE_FIELD_ZERO() macroMasami Hiramatsu
Use TRACE_FIELD_ZERO(type, item) instead of TRACE_FIELD_ZERO_CHAR(item). This also includes a typo fix of TRACE_ZERO_CHAR() macro. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Avi Kivity <avi@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jason Baron <jbaron@redhat.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Przemysław Pawełczyk <przemyslaw@pawelczyk.it> Cc: Roland McGrath <roland@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Vegard Nossum <vegard.nossum@gmail.com> LKML-Reference: <20090813203501.31965.30172.stgit@localhost.localdomain> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-08-27tracing: Ftrace dynamic ftrace_event_call supportMasami Hiramatsu
Add dynamic ftrace_event_call support to ftrace. Trace engines can add new ftrace_event_call to ftrace on the fly. Each operator function of the call takes an ftrace_event_call data structure as an argument, because these functions may be shared among several ftrace_event_calls. Changes from v13: - Define remove_subsystem_dir() always (revirt a2ca5e03), because trace_remove_event_call() uses it. - Modify syscall tracer because of ftrace_event_call change. [fweisbec@gmail.com: Fixed conflict against latest tracing/core] Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Avi Kivity <avi@redhat.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jason Baron <jbaron@redhat.com> Cc: Jim Keniston <jkenisto@us.ibm.com> Cc: K.Prasad <prasad@linux.vnet.ibm.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Przemysław Pawełczyk <przemyslaw@pawelczyk.it> Cc: Roland McGrath <roland@redhat.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Vegard Nossum <vegard.nossum@gmail.com> LKML-Reference: <20090813203453.31965.71901.stgit@localhost.localdomain> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-08-26tracing/filters: Add __field_ext() to TRACE_EVENTLi Zefan
Add __field_ext(), so a field can be assigned to a specific filter_type, which matches a corresponding filter function. For example, a later patch will allow this: __field_ext(const char *, str, FILTER_PTR_STR); Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4A7B9272.6050709@cn.fujitsu.com> [ Fixed a -1 to FILTER_OTHER Forward ported to latest kernel. ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-08-19tracing/events: Add trace_define_common_fields()Li Zefan
Extract duplicate code. Also prepare for the later patch. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <4A8BAFB8.1010304@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-19tracing/events: Add ftrace_event_call param to define_fields()Li Zefan
This parameter is needed by syscall events to add define_fields() handler. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <4A8BAF90.6060801@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-11tracing: Add ftrace event call parameter to its field descriptor handlerFrederic Weisbecker
Add the struct ftrace_event_call as a parameter of its show_format() callback. This way we can use it from the syscall trace events to retrieve the syscall name from the ftrace event call parameter and describe its fields using the syscalls metadata. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Jiaying Zhang <jiayingz@google.com> Cc: Martin Bligh <mbligh@google.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Jason Baron <jbaron@redhat.com>
2009-04-29tracing/filters: distinguish between signed and unsigned fieldsTom Zanussi
The new filter comparison ops need to be able to distinguish between signed and unsigned field types, so add an is_signed flag/param to the event field struct/trace_define_fields(). Also define a simple macro, is_signed_type() to determine the signedness at compile time, used in the trace macros. If the is_signed_type() macro won't work with a specific type, a new slightly modified version of TRACE_FIELD() called TRACE_FIELD_SIGN(), allows the signedness to be set explicitly. [ Impact: extend trace-filter code for new feature ] Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: fweisbec@gmail.com Cc: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <1240905893.6416.120.camel@tropicana> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-23tracing: add size checks for exported ftrace internal structuresSteven Rostedt
The events exported by TRACE_EVENT are automated and are guaranteed to be correct when used. The internal ftrace structures on the other hand are more manually exported. These require the ftrace maintainer to make sure they are up to date. This patch adds a size check to help flag when a type changes in an internal ftrace data structure, and the update needs to be reflected in the export. If a export is incorrect, then the only harm is that the user space tools will not know how to correctly read the internal structures of ftrace. [ Impact: help prevent inconsistent ftrace format print outs ] Signed-off-by: Steven Rostedt <srostedt@redhat.com>
2009-04-14tracing/filters: allow on-the-fly filter switchingTom Zanussi
This patch allows event filters to be safely removed or switched on-the-fly while avoiding the use of rcu or the suspension of tracing of previous versions. It does it by adding a new filter_pred_none() predicate function which does nothing and by never deallocating either the predicates or any of the filter_pred members used in matching; the predicate lists are allocated and initialized during ftrace_event_calls initialization. Whenever a filter is removed or replaced, the filter_pred_* functions currently in use by the affected ftrace_event_call are immediately switched over to to the filter_pred_none() function, while the rest of the filter_pred members are left intact, allowing any currently executing filter_pred_* functions to finish up, using the values they're currently using. In the case of filter replacement, the new predicate values are copied into the old predicates after the above step, and the filter_pred_none() functions are replaced by the filter_pred_* functions for the new filter. In this case, it is possible though very unlikely that a previous filter_pred_* is still running even after the filter_pred_none() switch and the switch to the new filter_pred_*. In that case, however, because nothing has been deallocated in the filter_pred, the worst that can happen is that the old filter_pred_* function sees the new values and as a result produces either a false positive or a false negative, depending on the values it finds. So one downside to this method is that rarely, it can produce a bad match during the filter switch, but it should be possible to live with that, IMHO. The other downside is that at least in this patch the predicate lists are always pre-allocated, taking up memory from the start. They could probably be allocated on first-use, and de-allocated when tracing is completely stopped - if this patch makes sense, I could create another one to do that later on. Oh, and it also places a restriction on the size of __arrays in events, currently set to 128, since they can't be larger than the now embedded str_val arrays in the filter_pred struct. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: paulmck@linux.vnet.ibm.com LKML-Reference: <1239610670.6660.49.camel@tropicana> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-14tracing/filters: add TRACE_EVENT_FORMAT_NOFILTER event macroTom Zanussi
Frederic Weisbecker suggested that the trace_special event shouldn't be filterable; this patch adds a TRACE_EVENT_FORMAT_NOFILTER event macro that allows an event format to be exported without having a filter attached, and removes filtering from the trace_special event. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-14tracing/filters: add run-time field descriptions to TRACE_EVENT_FORMAT eventsTom Zanussi
This patch adds run-time field descriptions to all the event formats exported using TRACE_EVENT_FORMAT. It also hooks up all the tracers that use them (i.e. the tracers in the 'ftrace subsystem') so they can also have their output filtered by the event-filtering mechanism. When I was testing this, there were a couple of things that fooled me into thinking the filters weren't working, when actually they were - I'll mention them here so others don't make the same mistakes (and file bug reports. ;-) One is that some of the tracers trace multiple events e.g. the sched_switch tracer uses the context_switch and wakeup events, and if you don't set filters on all of the traced events, the unfiltered output from the events without filters on them can make it look like the filtering as a whole isn't working properly, when actually it is doing what it was asked to do - it just wasn't asked to do the right thing. The other is that for the really high-volume tracers e.g. the function tracer, the volume of filtered events can be so high that it pushes the unfiltered events out of the ring buffer before they can be read so e.g. cat'ing the trace file repeatedly shows either no output, or once in awhile some output but that isn't there the next time you read the trace, which isn't what you normally expect when reading the trace file. If you read from the trace_pipe file though, you can catch them before they disappear. Changes from v1: As suggested by Frederic Weisbecker: - get rid of externs in functions - added unlikely() to filter_check_discard() Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-07ftrace: Correct a text align for event format outputZhaolei
If we cat debugfs/tracing/events/ftrace/bprint/format, we'll see: name: bprint ID: 6 format: field:unsigned char common_type; offset:0; size:1; field:unsigned char common_flags; offset:1; size:1; field:unsigned char common_preempt_count; offset:2; size:1; field:int common_pid; offset:4; size:4; field:int common_tgid; offset:8; size:4; field:unsigned long ip; offset:12; size:4; field:char * fmt; offset:16; size:4; field: char buf; offset:20; size:0; print fmt: "%08lx (%d) fmt:%p %s" There is an inconsistent blank before char buf. Signed-off-by: Zhao Lei <zhaolei@cn.fujitsu.com> LKML-Reference: <49D5E3EE.70201@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-10tracing: remove funky whitespace in the trace codeSteven Rostedt
Impact: clean up There existed a lot of <space><tab>'s in the tracing code. This patch removes them. Signed-off-by: Steven Rostedt <srostedt@redhat.com>
