[ Upstream commit 5cf99a0f3161bc3ae2391269d134d6bf7e26f00e ]
The tracefs file set_graph_function is used to only function graph functions
that are listed in that file (or all functions if the file is empty). The
way this is implemented is that the function graph tracer looks at every
function, and if the current depth is zero and the function matches
something in the file then it will trace that function. When other functions
are called, the depth will be greater than zero (because the original
function will be at depth zero), and all functions will be traced where the
depth is greater than zero.
The issue is that when a function is first entered, and the handler that
checks this logic is called, the depth is set to zero. If an interrupt comes
in and a function in the interrupt handler is traced, its depth will be
greater than zero and it will automatically be traced, even if the original
function was not. But because the logic only looks at depth it may trace
interrupts when it should not be.
The recent design change of the function graph tracer to fix other bugs
caused the depth to be zero while the function graph callback handler is
being called for a longer time, widening the race of this happening. This
bug was actually there for a longer time, but because the race window was so
small it seldom happened. The Fixes tag below is for the commit that widen
the race window, because that commit belongs to a series that will also help
fix the original bug.
Cc: stable@kernel.org
Fixes: 39eb456dacb5 ("function_graph: Use new curr_ret_depth to manage depth instead of curr_ret_stack")
Reported-by: Joe Lawrence <joe.lawrence@redhat.com>
Tested-by: Joe Lawrence <joe.lawrence@redhat.com>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
commit 1fe4293f4b8de75824935f8d8e9a99c7fc6873da upstream.
The function_graph tracer does not show the interrupt return marker for the
leaf entry. On leaf entries, we see an unbalanced interrupt marker (the
interrupt was entered, but nevern left).
Before:
1) | SyS_write() {
1) | __fdget_pos() {
1) 0.061 us | __fget_light();
1) 0.289 us | }
1) | vfs_write() {
1) 0.049 us | rw_verify_area();
1) + 15.424 us | __vfs_write();
1) ==========> |
1) 6.003 us | smp_apic_timer_interrupt();
1) 0.055 us | __fsnotify_parent();
1) 0.073 us | fsnotify();
1) + 23.665 us | }
1) + 24.501 us | }
After:
0) | SyS_write() {
0) | __fdget_pos() {
0) 0.052 us | __fget_light();
0) 0.328 us | }
0) | vfs_write() {
0) 0.057 us | rw_verify_area();
0) | __vfs_write() {
0) ==========> |
0) 8.548 us | smp_apic_timer_interrupt();
0) <========== |
0) + 36.507 us | } /* __vfs_write */
0) 0.049 us | __fsnotify_parent();
0) 0.066 us | fsnotify();
0) + 50.064 us | }
0) + 50.952 us | }
Link: http://lkml.kernel.org/r/1517413729-20411-1-git-send-email-changbin.du@intel.com
Cc: stable@vger.kernel.org
Fixes: f8b755ac8e0cc ("tracing/function-graph-tracer: Output arrows signal on hardirq call/return")
Signed-off-by: Changbin Du <changbin.du@intel.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
First, number of CPUs can't be negative number.
Second, different signnnedness leads to suboptimal code in the following
cases:
1)
kmalloc(nr_cpu_ids * sizeof(X));
"int" has to be sign extended to size_t.
2)
while (loff_t *pos < nr_cpu_ids)
MOVSXD is 1 byte longed than the same MOV.
Other cases exist as well. Basically compiler is told that nr_cpu_ids
can't be negative which can't be deduced if it is "int".
Code savings on allyesconfig kernel: -3KB
add/remove: 0/0 grow/shrink: 25/264 up/down: 261/-3631 (-3370)
function old new delta
coretemp_cpu_online 450 512 +62
rcu_init_one 1234 1272 +38
pci_device_probe 374 399 +25
pgdat_reclaimable_pages 628 556 -72
select_fallback_rq 446 369 -77
task_numa_find_cpu 1923 1807 -116
Link: http://lkml.kernel.org/r/20170819114959.GA30580@avx2
Currently both the wakeup and irqsoff traces do not handle set_graph_notrace
well. The ftrace infrastructure will ignore the return paths of all
functions leaving them hanging without an end:
# echo '*spin*' > set_graph_notrace
# cat trace
_raw_spin_lock() {
preempt_count_add() {
do_raw_spin_lock() {
update_rq_clock();
Where the '*spin*' functions should have looked like this:
_raw_spin_lock() {
preempt_count_add();
do_raw_spin_lock();
update_rq_clock();
Instead, have the wakeup and irqsoff tracers ignore the functions that are
set by the set_graph_notrace like the function_graph tracer does. Move
the logic in the function_graph tracer into a header to allow wakeup and
irqsoff tracers to use it as well.
Cc: Namhyung Kim <namhyung.kim@lge.com>
Both the wakeup and irqsoff tracers can use the function graph tracer when
the display-graph option is set. The problem is that they ignore the notrace
file, and record the entry of functions that would be ignored by the
function_graph tracer. This causes the trace->depth to be recorded into the
ring buffer. The set_graph_notrace uses a trick by adding a large negative
number to the trace->depth when a graph function is to be ignored.
On trace output, the graph function uses the depth to record a stack of
functions. But since the depth is negative, it accesses the array with a
negative number and causes an out of bounds access that can cause a kernel
oops or corrupt data.
Have the print functions handle cases where a tracer still records functions
even when they are in set_graph_notrace.
Also add warnings if the depth is below zero before accessing the array.
Note, the function graph logic will still prevent the return of these
functions from being recorded, which means that they will be left hanging
without a return. For example:
# echo 1 > options/display-graph
# echo wakeup > current_tracer
# cat trace
_raw_spin_lock() {
update_rq_clock();
Where it should look like:
_raw_spin_lock() {
do_raw_spin_lock();
update_rq_clock();
Fixes: 29ad23b00474 ("ftrace: Add set_graph_notrace filter")
The function __buffer_unlock_commit() is called in a few places outside of
trace.c. But for the most part, it should really be inlined, as it is in the
hot path of the trace_events. For the callers outside of trace.c, create a
new function trace_buffer_unlock_commit_nostack(), as the reason it was used
was to avoid the stack tracing that trace_buffer_unlock_commit() could do.
Link: http://lkml.kernel.org/r/20161121183700.GW26852@two.firstfloor.org
Reported-by: Andi Kleen <andi@firstfloor.org>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace
Pull tracing updates from Steven Rostedt:
"This release cycle is rather small. Just a few fixes to tracing.
The big change is the addition of the hwlat tracer. It not only
detects SMIs, but also other latency that's caused by the hardware. I
have detected some latency from large boxes having bus contention"
* tag 'trace-v4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Call traceoff trigger after event is recorded
ftrace/scripts: Add helper script to bisect function tracing problem functions
tracing: Have max_latency be defined for HWLAT_TRACER as well
tracing: Add NMI tracing in hwlat detector
tracing: Have hwlat trace migrate across tracing_cpumask CPUs
tracing: Add documentation for hwlat_detector tracer
tracing: Added hardware latency tracer
ftrace: Access ret_stack->subtime only in the function profiler
function_graph: Handle TRACE_BPUTS in print_graph_comment
tracing/uprobe: Drop isdigit() check in create_trace_uprobe
The subtime is used only for function profiler with function graph
tracer enabled. Move the definition of subtime under
CONFIG_FUNCTION_PROFILER to reduce the memory usage. Also move the
initialization of subtime into the graph entry callback.
Link: http://lkml.kernel.org/r/20160831025529.24018-1-namhyung@kernel.org
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
It missed to handle TRACE_BPUTS so messages recorded by trace_bputs()
will be shown with symbol info unnecessarily.
You can see it with the trace_printk sample code:
# cd /sys/kernel/tracing/
# echo sys_sync > set_graph_function
# echo 1 > options/sym-offset
# echo function_graph > current_tracer
Note that the sys_sync filter was there to prevent recording other
functions and the sym-offset option was needed since the first message
was called from a module init function so kallsyms doesn't have the
symbol and omitted in the output.
# cd ~/build/kernel
# insmod samples/trace_printk/trace-printk.ko
# cd -
# head trace
Before:
# tracer: function_graph
# CPU DURATION FUNCTION CALLS
1) | /* 0xffffffffa0002000: This is a static string that will use trace_bputs */
1) | /* This is a dynamic string that will use trace_puts */
1) | /* trace_printk_irq_work+0x5/0x7b [trace_printk]: (irq) This is a static string that will use trace_bputs */
1) | /* (irq) This is a dynamic string that will use trace_puts */
1) | /* (irq) This is a static string that will use trace_bprintk() */
1) | /* (irq) This is a dynamic string that will use trace_printk */
After:
1) | /* This is a static string that will use trace_bputs */
1) | /* (irq) This is a static string that will use trace_bputs */
Link: http://lkml.kernel.org/r/20160901024354.13720-1-namhyung@kernel.org
When function graph tracing is enabled for a function, ftrace modifies
the stack by replacing the original return address with the address of a
hook function (return_to_handler).
Stack unwinders need a way to get the original return address. Add an
arch-independent helper function for that named ftrace_graph_ret_addr().
This adds two variations of the function: one depends on
HAVE_FUNCTION_GRAPH_RET_ADDR_PTR, and the other relies on an index state
variable.
The former is recommended because, in some cases, the latter can cause
problems when the unwinder skips stack frames. It can get out of sync
with the ret_stack index and wrong addresses can be reported for the
stack trace.
Once all arches have been ported to use
HAVE_FUNCTION_GRAPH_RET_ADDR_PTR, we can get rid of the distinction.
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Acked-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Byungchul Park <byungchul.park@lge.com>
Cc: Denys Vlasenko <dvlasenk@redhat.com>
Cc: Nilay Vaish <nilayvaish@gmail.com>
Link: http://lkml.kernel.org/r/36bd90f762fc5e5af3929e3797a68a64906421cf.1471607358.git.jpoimboe@redhat.com
Storing this value will help prevent unwinders from getting out of sync
with the function graph tracer ret_stack. Now instead of needing a
stateful iterator, they can compare the return address pointer to find
the right ret_stack entry.
Note that an array of 50 ftrace_ret_stack structs is allocated for every
task. So when an arch implements this, it will add either 200 or 400
bytes of memory usage per task (depending on whether it's a 32-bit or
64-bit platform).
Link: http://lkml.kernel.org/r/a95cfcc39e8f26b89a430c56926af0bb217bc0a1.1471607358.git.jpoimboe@redhat.com
This saves some memory when HAVE_FUNCTION_GRAPH_FP_TEST isn't defined.
On x86_64 with newer versions of gcc which have -mfentry, it saves 400
bytes per task.
Link: http://lkml.kernel.org/r/5c7747d9ea7b5cb47ef0a8ce8a6cea6bf7aa94bf.1471607358.git.jpoimboe@redhat.com
Make HAVE_FUNCTION_GRAPH_FP_TEST a normal define, independent from
kconfig. This removes some config file pollution and simplifies the
checking for the fp test.
Suggested-by: Steven Rostedt <rostedt@goodmis.org>
Link: http://lkml.kernel.org/r/2c4e5f05054d6d367f702fd153af7a0109dd5c81.1471607358.git.jpoimboe@redhat.com
Function graph tracer currently ignores filters if tracing_thresh is set.
For example, even if set_ftrace_pid is set, then its ignored if tracing_thresh
set, resulting in all processes being traced.
To fix this, we reuse the same entry function as when tracing_thresh is not
set and do everything as in the regular case except for writing the function entry
to the ring buffer.
Link: http://lkml.kernel.org/r/1466228694-2677-1-git-send-email-agnel.joel@gmail.com
Signed-off-by: Joel Fernandes <agnel.joel@gmail.com>
Convert set_ftrace_pid to use the bitmap like set_event_pid does. This
allows for instances to use the pid filtering as well, and will allow for
function-fork option to set if the children of a traced function should be
traced or not.
KASAN needs to know whether the allocation happens in an IRQ handler.
This lets us strip everything below the IRQ entry point to reduce the
number of unique stack traces needed to be stored.
Move the definition of __irq_entry to <linux/interrupt.h> so that the
users don't need to pull in <linux/ftrace.h>. Also introduce the
__softirq_entry macro which is similar to __irq_entry, but puts the
corresponding functions to the .softirqentry.text section.
Signed-off-by: Alexander Potapenko <glider@google.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Andrey Konovalov <adech.fo@gmail.com>
Cc: Dmitry Vyukov <dvyukov@google.com>
Cc: Andrey Ryabinin <ryabinin.a.a@gmail.com>
Cc: Konstantin Serebryany <kcc@google.com>
Cc: Dmitry Chernenkov <dmitryc@google.com>
Use the more common logging method with the eventual goal of removing
pr_warning altogether.
Miscellanea:
- Realign arguments
- Coalesce formats
- Add missing space between a few coalesced formats
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> [kernel/power/suspend.c]
Since the ring buffer is lockless, there is no need to disable ftrace on
CPU. And no one doing so: after commit 68179686ac67cb ("tracing: Remove
ftrace_disable/enable_cpu()") ftrace_cpu_disabled stays the same after
initialization, nothing changes it.
ftrace_cpu_disabled shouldn't be used by any external module since it
disables only function and graph_function tracers but not any other
tracer.
Link: http://lkml.kernel.org/r/1446836846-22239-1-git-send-email-0x7f454c46@gmail.com
Signed-off-by: Dmitry Safonov <0x7f454c46@gmail.com>
In preparation to make trace options per instance, the global trace_flags
needs to be moved from being a global variable to a field within the trace
instance trace_array structure.
There's still more work to do, as there's some functions that use
trace_flags without passing in a way to get to the current_trace array. For
those, the global_trace is used directly (from trace.c). This includes
setting and clearing the trace_flags. This means that when a new instance is
created, it just gets the trace_flags of the global_trace and will not be
able to modify them. Depending on the functions that have access to the
trace_array, the flags of an instance may not affect parts of its trace,
where the global_trace is used. These will be fixed in future changes.
The sleep-time and graph-time options are only for the function graph tracer
and are not used by anything else. As tracer options are now visible when
the tracer is not activated, its better to move the function graph specific
tracer options into the function graph tracer.
Jungseok Lee noticed the following:
Currently, row's width of 7-digit duration numbers not aligned with
other cases like the following example.
3) $ 3999884 us | }
3) | finish_task_switch() {
3) 0.365 us | _raw_spin_unlock_irq();
3) 3.333 us | }
3) $ 3999976 us | }
3) $ 3999979 us | } /* schedule */
As adding a single white space in case of 7-digit numbers, the format
could be unified easily as follows.
3) $ 2237472 us | }
3) 0.364 us | _raw_spin_unlock_irq();
3) 3.125 us | }
3) $ 2237556 us | }
3) $ 2237559 us | } /* schedule */
Instead of making a special case for 7-digit numbers, the logic
of the len and the space loop is slightly modified to make the
two cases have the same format.
Link: http://lkml.kernel.org/r/1436626300-1679-2-git-send-email-jungseoklee85@gmail.com
Reported-by: Jungseok Lee <jungseoklee85@gmail.com>
The name "ftrace" really refers to the function hook infrastructure. It
is not about the trace_events. The structures ftrace_event_call and
ftrace_event_class have nothing to do with the function hooks, and are
really trace_event structures. Rename ftrace_event_* to trace_event_*.
is not about the trace_events. The functions (un)register_ftrace_event() is
really about trace_events, and the name should be register_trace_event()
instead.
Also renamed ftrace_event_reg() to trace_event_reg() for the same reason.
Pull tracing fixes from Steven Rostedt:
"This adds three fixes for the tracing code.
The first is a bug when ftrace_dump_on_oops is triggered in atomic
context and function graph tracer is the tracer that is being
reported.
The second fix is bad parsing of the trace_events from the kernel
command line, where it would ignore specific events if the system name
is used with defining the event(it enables all events within the
system).
The last one is a fix to the TRACE_DEFINE_ENUM(), where a check was
missing to see if the ptr was incremented to the end of the string,
but the loop increments it again and can miss the nul delimiter to
stop processing"
* tag 'trace-v4.1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
tracing: Fix possible out of bounds memory access when parsing enums
tracing: Fix incorrect enabling of trace events by boot cmdline
tracing: Handle ftrace_dump() atomic context in graph_trace_open()
graph_trace_open() can be called in atomic context from ftrace_dump().
Use GFP_ATOMIC for the memory allocations when that's the case, in order
to avoid the following splat.
BUG: sleeping function called from invalid context at mm/slab.c:2849
in_atomic(): 1, irqs_disabled(): 128, pid: 0, name: swapper/0
Backtrace:
[<8004dc94>] (__might_sleep) from [<801371f4>] (kmem_cache_alloc_trace+0x160/0x238)
r7:87800040 r6:000080d0 r5:810d16e8 r4:000080d0
[<80137094>] (kmem_cache_alloc_trace) from [<800cbd60>] (graph_trace_open+0x30/0xd0)
r10:00000100 r9:809171a8 r8:00008e28 r7:810d16f0 r6:00000001 r5:810d16e8
r4:810d16f0
[<800cbd30>] (graph_trace_open) from [<800c79c4>] (trace_init_global_iter+0x50/0x9c)
r8:00008e28 r7:808c853c r6:00000001 r5:810d16e8 r4:810d16f0 r3:800cbd30
[<800c7974>] (trace_init_global_iter) from [<800c7aa0>] (ftrace_dump+0x90/0x2ec)
r4:810d2580 r3:00000000
[<800c7a10>] (ftrace_dump) from [<80414b2c>] (sysrq_ftrace_dump+0x1c/0x20)
r10:00000100 r9:809171a8 r8:808f6e7c r7:00000001 r6:00000007 r5:0000007a
r4:808d5394
[<80414b10>] (sysrq_ftrace_dump) from [<800169b8>] (return_to_handler+0x0/0x18)
[<80415498>] (__handle_sysrq) from [<800169b8>] (return_to_handler+0x0/0x18)
r8:808c8100 r7:808c8444 r6:00000101 r5:00000010 r4:84eb3210
[<80415668>] (handle_sysrq) from [<800169b8>] (return_to_handler+0x0/0x18)
[<8042a760>] (pl011_int) from [<800169b8>] (return_to_handler+0x0/0x18)
r10:809171bc r9:809171a8 r8:00000001 r7:00000026 r6:808c6000 r5:84f01e60
r4:8454fe00
[<8007782c>] (handle_irq_event_percpu) from [<80077b44>] (handle_irq_event+0x4c/0x6c)
r10:808c7ef0 r9:87283e00 r8:00000001 r7:00000000 r6:8454fe00 r5:84f01e60
r4:84f01e00
[<80077af8>] (handle_irq_event) from [<8007aa28>] (handle_fasteoi_irq+0xf0/0x1ac)
r6:808f52a4 r5:84f01e60 r4:84f01e00 r3:00000000
[<8007a938>] (handle_fasteoi_irq) from [<80076dc0>] (generic_handle_irq+0x3c/0x4c)
r6:00000026 r5:00000000 r4:00000026 r3:8007a938
[<80076d84>] (generic_handle_irq) from [<80077128>] (__handle_domain_irq+0x8c/0xfc)
r4:808c1e38 r3:0000002e
[<8007709c>] (__handle_domain_irq) from [<800087b8>] (gic_handle_irq+0x34/0x6c)
r10:80917748 r9:00000001 r8:88802100 r7:808c7ef0 r6:808c8fb0 r5:00000015
r4:8880210c r3:808c7ef0
[<80008784>] (gic_handle_irq) from [<80014044>] (__irq_svc+0x44/0x7c)
Link: http://lkml.kernel.org/r/1428953721-31349-1-git-send-email-rabin@rab.in
Link: http://lkml.kernel.org/r/1428957012-2319-1-git-send-email-rabin@rab.in
Cc: stable@vger.kernel.org # 3.13+
Signed-off-by: Rabin Vincent <rabin@rab.in>
debugfs was fine for the tracing facility as a quick way to get
an interface. Now that tracing has matured, it should separate itself
from debugfs such that it can be mounted separately without needing
to mount all of debugfs with it. That is, users resist using tracing
because it requires mounting debugfs. Having tracing have its own file
system lets users get the features of tracing without needing to bring
in the rest of the kernel's debug infrastructure.
Another reason for tracefs is that debubfs does not support mkdir.
Currently, to create instances, one does a mkdir in the tracing/instance
directory. This is implemented via a hack that forces debugfs to do
something it is not intended on doing. By converting over to tracefs, this
hack can be removed and mkdir can be properly implemented. This patch does
not address this yet, but it lays the ground work for that to be done.
tracing_init_dentry() will soon return NULL as a valid pointer for the
top level tracing directroy. NULL can not be used as an error value.
Instead, switch to ERR_PTR() and check the return status with
IS_ERR().
Pull nmi-safe seq_buf printk update from Steven Rostedt:
"This code is a fork from the trace-3.19 pull as it needed the
trace_seq clean ups from that branch.
This code solves the issue of performing stack dumps from NMI context.
The issue is that printk() is not safe from NMI context as if the NMI
were to trigger when a printk() was being performed, the NMI could
deadlock from the printk() internal locks. This has been seen in
practice.
With lots of review from Petr Mladek, this code went through several
iterations, and we feel that it is now at a point of quality to be
accepted into mainline.
Here's what is contained in this patch set:
- Creates a "seq_buf" generic buffer utility that allows a descriptor
to be passed around where functions can write their own "printk()"
formatted strings into it. The generic version was pulled out of
the trace_seq() code that was made specifically for tracing.
- The seq_buf code was change to model the seq_file code. I have a
patch (not included for 3.19) that converts the seq_file.c code
over to use seq_buf.c like the trace_seq.c code does. This was
done to make sure that seq_buf.c is compatible with seq_file.c. I
may try to get that patch in for 3.20.
- The seq_buf.c file was moved to lib/ to remove it from being
dependent on CONFIG_TRACING.
- The printk() was updated to allow for a per_cpu "override" of the
internal calls. That is, instead of writing to the console, a call
to printk() may do something else. This made it easier to allow
the NMI to change what printk() does in order to call dump_stack()
without needing to update that code as well.
- Finally, the dump_stack from all CPUs via NMI code was converted to
use the seq_buf code. The caller to trigger the NMI code would
wait till all the NMIs finished, and then it would print the
seq_buf data to the console safely from a non NMI context
One added bonus is that this code also makes the NMI dump stack work
on PREEMPT_RT kernels. As printk() includes sleeping locks on
PREEMPT_RT, printk() only writes to console if the console does not
use any rt_mutex converted spin locks. Which a lot do"
* tag 'trace-seq-buf-3.19' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace:
x86/nmi: Fix use of unallocated cpumask_var_t
printk/percpu: Define printk_func when printk is not defined
x86/nmi: Perform a safe NMI stack trace on all CPUs
printk: Add per_cpu printk func to allow printk to be diverted
seq_buf: Move the seq_buf code to lib/
seq-buf: Make seq_buf_bprintf() conditional on CONFIG_BINARY_PRINTF
tracing: Add seq_buf_get_buf() and seq_buf_commit() helper functions
tracing: Have seq_buf use full buffer
seq_buf: Add seq_buf_can_fit() helper function
tracing: Add paranoid size check in trace_printk_seq()
tracing: Use trace_seq_used() and seq_buf_used() instead of len
tracing: Clean up tracing_fill_pipe_page()
seq_buf: Create seq_buf_used() to find out how much was written
tracing: Add a seq_buf_clear() helper and clear len and readpos in init
tracing: Convert seq_buf fields to be like seq_file fields
tracing: Convert seq_buf_path() to be like seq_path()
tracing: Create seq_buf layer in trace_seq
Currently, function graph tracer prints "!" or "+" just before
function execution time to signal a function overhead, depending
on the time. And some tracers tracing latency also print "!" or
"+" just after time to signal overhead, depending on the interval
between events. Even it is usually enough to do that, we sometimes
need to signal for bigger execution time than 100 micro seconds.
For example, I used function graph tracer to detect if there is
any case that exit_mm() takes too much time. I did following steps
in /sys/kernel/debug/tracing. It was easier to detect very large
excution time with patched kernel than with original kernel.
$ echo exit_mm > set_graph_function
$ echo function_graph > current_tracer
$ echo > trace
$ cat trace_pipe > $LOGFILE
... (do something and terminate logging)
$ grep "\\$" $LOGFILE
3) $ 22082032 us | } /* kernel_map_pages */
3) $ 22082040 us | } /* free_pages_prepare */
3) $ 22082113 us | } /* free_hot_cold_page */
3) $ 22083455 us | } /* free_hot_cold_page_list */
3) $ 22083895 us | } /* release_pages */
3) $ 22177873 us | } /* free_pages_and_swap_cache */
3) $ 22178929 us | } /* unmap_single_vma */
3) $ 22198885 us | } /* unmap_vmas */
3) $ 22206949 us | } /* exit_mmap */
3) $ 22207659 us | } /* mmput */
3) $ 22207793 us | } /* exit_mm */
And then, it was easy to find out that a schedule-out occured by
sub_preempt_count() within kernel_map_pages().
To detect very large function exection time caused by either problematic
function implementation or scheduling issues, this patch can be useful.
Link: http://lkml.kernel.org/r/1416789259-24038-1-git-send-email-byungchul.park@lge.com
Signed-off-by: Byungchul Park <byungchul.park@lge.com>
As the seq_buf->len will soon be +1 size when there's an overflow, we
must use trace_seq_used() or seq_buf_used() methods to get the real
length. This will prevent buffer overflow issues if just the len
of the seq_buf descriptor is used to copy memory.
Link: http://lkml.kernel.org/r/20141114121911.09ba3d38@gandalf.local.home
Reported-by: Petr Mladek <pmladek@suse.cz>
Create a seq_buf layer that trace_seq sits on. The seq_buf will not
be limited to page size. This will allow other usages of seq_buf
instead of a hard set PAGE_SIZE one that trace_seq has.
Link: http://lkml.kernel.org/r/20141104160221.864997179@goodmis.org
Link: http://lkml.kernel.org/r/20141114011412.170377300@goodmis.org
Tested-by: Jiri Kosina <jkosina@suse.cz>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Reviewed-by: Petr Mladek <pmladek@suse.cz>
Instead of doing individual checks all over the place that makes the code
very messy. Just check trace_seq_has_overflowed() at the end or in
strategic places.
This makes the code much cleaner and also helps with getting closer
to removing the return values of trace_seq_printf() and friends.
Link: http://lkml.kernel.org/r/20141114011410.987913836@goodmis.org
Usually, "msecs" notation means milli-seconds, and "usecs" notation
means micro-seconds. Since the unit used in the code is micro-seconds,
the notation should be replaced from msecs to usecs.
Link: http://lkml.kernel.org/r/1415171926-9782-2-git-send-email-byungchul.park@lge.com
On the function_graph tracer, the print_graph_irq() function prints a
trace line with the flag ==========> on an irq handler entry, and the
flag <========== on an irq handler return.
But when the latency-format is enable, it is not printing the
latency-format flags, causing the following error in the trace output:
0) ==========> |
0) d... | smp_apic_timer_interrupt() {
This patch fixes this issue by printing the latency-format flags when
it is enable.
Link: http://lkml.kernel.org/r/7c2e226dac20c940b6242178fab7f0e3c9b5ce58.1415233316.git.bristot@redhat.com
Reviewed-by: Luis Claudio R. Goncalves <lgoncalv@redhat.com>
Signed-off-by: Daniel Bristot de Oliveira <bristot@redhat.com>
Printing a single character to a seqfile might as well be done with
seq_putc instead of seq_puts; this avoids a strlen() call and a memory
access. It also shaves another few bytes off the generated code.
Link: http://lkml.kernel.org/r/1415479332-25944-4-git-send-email-linux@rasmusvillemoes.dk
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Using seq_printf to print a simple string or a single character is a
lot more expensive than it needs to be, since seq_puts and seq_putc
exist.
These patches do
seq_printf(m, s) -> seq_puts(m, s)
seq_printf(m, "%s", s) -> seq_puts(m, s)
seq_printf(m, "%c", c) -> seq_putc(m, c)
Subsequent patches will simplify further.
Link: http://lkml.kernel.org/r/1415479332-25944-2-git-send-email-linux@rasmusvillemoes.dk
Local functions should be static.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Currently, tracing_thresh works only if we specify it before selecting
function_graph tracer. If we do the opposite, tracing_thresh will change
it's value, but it will not be applied.
To fix it, we add update_thresh callback which is called whenever
tracing_thresh is updated and for function_graph tracer we register
handler which reinitializes tracer depending on tracing_thresh.
Link: http://lkml.kernel.org/p/20140718111727.GA3206@stfomichev-desktop.yandex.net
Signed-off-by: Stanislav Fomichev <stfomichev@yandex-team.ru>
All archs now use ftrace_graph_is_dead() to stop function graph
tracing. Remove the usage of ftrace_stop() as that is no longer
needed.
Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
ftrace_stop() is going away as it disables parts of function tracing
that affects users that should not be affected. But ftrace_graph_stop()
is built on ftrace_stop(). Here's another example of killing all of
function tracing because something went wrong with function graph
tracing.
Instead of disabling all users of function tracing on function graph
error, disable only function graph tracing.
A new function is created called ftrace_graph_is_dead(). This is called
in strategic paths to prevent function graph from doing more harm and
allowing at least a warning to be printed before the system crashes.
NOTE: ftrace_stop() is still used until all the archs are converted over
to use ftrace_graph_is_dead(). After that, ftrace_stop() will be removed.
In the function-graph tracer, add a funcgraph_tail option
to print the function name on all } lines, not just
functions whose first line is no longer in the trace
buffer.
If a function calls other traced functions, its total
time appears on its } line. This change allows grep
to be used to determine the function for which the
line corresponds.
Update Documentation/trace/ftrace.txt to describe
this new option.
Link: http://lkml.kernel.org/p/20140520221041.8359.6782.stgit@beardog.cce.hp.com
Signed-off-by: Robert Elliott <elliott@hp.com>
Eliminate duplicate TRACE_GRAPH_PRINT_xx defines
in trace_functions_graph.c that are already in
trace.h.
Add TRACE_GRAPH_PRINT_IRQS to trace.h, which is
the only one that is missing.
Link: http://lkml.kernel.org/p/20140520221031.8359.24733.stgit@beardog.cce.hp.com
Now that the ring buffer has a built in way to wake up readers
when there's data, using irq_work such that it is safe to do it
in any context. But it was still using the old "poor man's"
wait polling that checks every 1/10 of a second to see if it
should wake up a waiter. This makes the latency for a wake up
excruciatingly long. No need to do that anymore.
Completely remove the different wait_poll types from the tracers
and have them all use the default one now.
Reported-by: Johannes Berg <johannes@sipsolutions.net>
As options (flags) may affect instances instead of being global
the set_flag() callbacks need to receive the trace_array descriptor
of the instance they will be modifying.
The duration field of print_graph_duration() can also be used
to do the space filling by passing an enum in it:
DURATION_FILL_FULL
DURATION_FILL_START
DURATION_FILL_END
The problem is that these are enums and defined as negative,
but the duration field is unsigned long long. Most archs are
fine with this but blackfin fails to compile because of it:
kernel/built-in.o: In function `print_graph_duration':
kernel/trace/trace_functions_graph.c:782: undefined reference to `__ucmpdi2'
Overloading a unsigned long long with an signed enum is just
bad in principle. We can accomplish the same thing by using
part of the flags field instead.
Cc: Mike Frysinger <vapier@gentoo.org>
The trace event filters are still tied to event calls rather than
event files, which means you don't get what you'd expect when using
filters in the multibuffer case:
Before:
# echo 'bytes_alloc > 8192' > /sys/kernel/debug/tracing/events/kmem/kmalloc/filter
# cat /sys/kernel/debug/tracing/events/kmem/kmalloc/filter
bytes_alloc > 8192
# mkdir /sys/kernel/debug/tracing/instances/test1
# echo 'bytes_alloc > 2048' > /sys/kernel/debug/tracing/instances/test1/events/kmem/kmalloc/filter
bytes_alloc > 2048
# cat /sys/kernel/debug/tracing/instances/test1/events/kmem/kmalloc/filter
bytes_alloc > 2048
Setting the filter in tracing/instances/test1/events shouldn't affect
the same event in tracing/events as it does above.
After:
bytes_alloc > 8192
bytes_alloc > 8192
bytes_alloc > 2048
We'd like to just move the filter directly from ftrace_event_call to
ftrace_event_file, but there are a couple cases that don't yet have
multibuffer support and therefore have to continue using the current
event_call-based filters. For those cases, a new USE_CALL_FILTER bit
is added to the event_call flags, whose main purpose is to keep the
old behavior for those cases until they can be updated with
multibuffer support; at that point, the USE_CALL_FILTER flag (and the
new associated call_filter_check_discard() function) can go away.
The multibuffer support also made filter_current_check_discard()
redundant, so this change removes that function as well and replaces
it with filter_check_discard() (or call_filter_check_discard() as
appropriate).
Link: http://lkml.kernel.org/r/f16e9ce4270c62f46b2e966119225e1c3cca7e60.1382620672.git.tom.zanussi@linux.intel.com
Signed-off-by: Tom Zanussi <tom.zanussi@linux.intel.com>
The set_graph_notrace filter is analogous to set_ftrace_notrace and
can be used for eliminating uninteresting part of function graph trace
output. It also works with set_graph_function nicely.
# cd /sys/kernel/debug/tracing/
# echo do_page_fault > set_graph_function
# perf ftrace live true
2) | do_page_fault() {
2) | __do_page_fault() {
2) 0.381 us | down_read_trylock();
2) 0.055 us | __might_sleep();
2) 0.696 us | find_vma();
2) | handle_mm_fault() {
2) | handle_pte_fault() {
2) | __do_fault() {
2) | filemap_fault() {
2) | find_get_page() {
2) 0.033 us | __rcu_read_lock();
2) 0.035 us | __rcu_read_unlock();
2) 1.696 us | }
2) 0.031 us | __might_sleep();
2) 2.831 us | }
2) | _raw_spin_lock() {
2) 0.046 us | add_preempt_count();
2) 0.841 us | }
2) 0.033 us | page_add_file_rmap();
2) | _raw_spin_unlock() {
2) 0.057 us | sub_preempt_count();
2) 0.568 us | }
2) | unlock_page() {
2) 0.084 us | page_waitqueue();
2) 0.126 us | __wake_up_bit();
2) 1.117 us | }
2) 7.729 us | }
2) 8.397 us | }
2) 8.956 us | }
2) 0.085 us | up_read();
2) + 12.745 us | }
2) + 13.401 us | }
# echo handle_mm_fault > set_graph_notrace
1) | do_page_fault() {
1) | __do_page_fault() {
1) 0.205 us | down_read_trylock();
1) 0.041 us | __might_sleep();
1) 0.344 us | find_vma();
1) 0.069 us | up_read();
1) 4.692 us | }
1) 5.311 us | }
Link: http://lkml.kernel.org/r/1381739066-7531-5-git-send-email-namhyung@kernel.org
The selftest for function and function graph tracers are defined as
__init, as they are only executed at boot up. The "tracer" structs
that are associated to those tracers are not setup as __init as they
are used after boot. To stop mismatch warnings, those structures
need to be annotated with __ref_data.
Currently, the tracer structures are defined to __read_mostly, as they
do not really change. But in the future they should be converted to
consts, but that will take a little work because they have a "next"
pointer that gets updated when they are registered. That will have to
wait till the next major release.
Link: http://lkml.kernel.org/r/1373596735.17876.84.camel@gandalf.local.home
Reported-by: Chen Gang <gang.chen@asianux.com>
For string without format specifiers, use trace_seq_puts()
or trace_seq_putc().
Link: http://lkml.kernel.org/r/51E3B3AC.1000605@huawei.com
Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com>
[ fixed a trace_seq_putc(s, " ") to trace_seq_putc(s, ' ') ]
