path: root/kernel/trace
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-21Merge branch 'tip/perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core
2011-07-21Merge branch 'perf/urgent' into perf/coreIngo Molnar
Merge reason: pick up the latest fixes - they won't make v3.0. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-15tracing/kprobe: Update symbol reference when loading moduleMasami Hiramatsu
Since the address of a module-local variable can only be solved after the target module is loaded, the symbol fetch-argument should be updated when loading target module. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Link: http://lkml.kernel.org/r/20110627072703.6528.75042.stgit@fedora15 Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-15tracing/kprobes: Support module init function probingMasami Hiramatsu
To support probing module init functions, kprobe-tracer allows user to define a probe on non-existed function when it is given with a module name. This also enables user to set a probe on a function on a specific module, even if a same name (but different) function is locally defined in another module. The module name must be in the front of function name and separated by a ':'. e.g. btrfs:btrfs_init_sysfs Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Link: http://lkml.kernel.org/r/20110627072656.6528.89970.stgit@fedora15 Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-15tracing/kprobes: Merge trace probe enable/disable functionsMasami Hiramatsu
Merge redundant enable/disable functions into enable_trace_probe() and disable_trace_probe(). Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: yrl.pp-manager.tt@hitachi.com Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Link: http://lkml.kernel.org/r/20110627072644.6528.26910.stgit@fedora15 [ converted kprobe selftest to use enable_trace_probe ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-14ftrace: Fix regression where ftrace breaks when modules are loadedSteven Rostedt
Enabling function tracer to trace all functions, then load a module and then disable function tracing will cause ftrace to fail. This can also happen by enabling function tracing on the command line: ftrace=function and during boot up, modules are loaded, then you disable function tracing with 'echo nop > current_tracer' you will trigger a bug in ftrace that will shut itself down. The reason is, the new ftrace code keeps ref counts of all ftrace_ops that are registered for tracing. When one or more ftrace_ops are registered, all the records that represent the functions that the ftrace_ops will trace have a ref count incremented. If this ref count is not zero, when the code modification runs, that function will be enabled for tracing. If the ref count is zero, that function will be disabled from tracing. To make sure the accounting was working, FTRACE_WARN_ON()s were added to updating of the ref counts. If the ref count hits its max (> 2^30 ftrace_ops added), or if the ref count goes below zero, a FTRACE_WARN_ON() is triggered which disables all modification of code. Since it is common for ftrace_ops to trace all functions in the kernel, instead of creating > 20,000 hash items for the ftrace_ops, the hash count is just set to zero, and it represents that the ftrace_ops is to trace all functions. This is where the issues arrise. If you enable function tracing to trace all functions, and then add a module, the modules function records do not get the ref count updated. When the function tracer is disabled, all function records ref counts are subtracted. Since the modules never had their ref counts incremented, they go below zero and the FTRACE_WARN_ON() is triggered. The solution to this is rather simple. When modules are loaded, and their functions are added to the the ftrace pool, look to see if any ftrace_ops are registered that trace all functions. And for those, update the ref count for the module function records. Reported-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-14tracing/kprobes: Rename probe_* to trace_probe_*Masami Hiramatsu
Rename probe_* to trace_probe_* for avoiding namespace confliction. This also fixes improper names of find_probe_event() and cleanup_all_probes() to find_trace_probe() and release_all_trace_probes() respectively. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Link: http://lkml.kernel.org/r/20110627072636.6528.60374.stgit@fedora15 Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-14tracing: Have dynamic size event stack tracesSteven Rostedt
Currently the stack trace per event in ftace is only 8 frames. This can be quite limiting and sometimes useless. Especially when the "ignore frames" is wrong and we also use up stack frames for the event processing itself. Change this to be dynamic by adding a percpu buffer that we can write a large stack frame into and then copy into the ring buffer. For interrupts and NMIs that come in while another event is being process, will only get to use the 8 frame stack. That should be enough as the task that it interrupted will have the full stack frame anyway. Requested-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-13ftrace: Fix dynamic selftest failure on some archsSteven Rostedt
Archs that do not implement CONFIG_HAVE_FUNCTION_TRACE_MCOUNT_TEST, will fail the dynamic ftrace selftest. The function tracer has a quick 'off' variable that will prevent the call back functions from being called. This variable is called function_trace_stop. In x86, this is implemented directly in the mcount assembly, but for other archs, an intermediate function is used called ftrace_test_stop_func(). In dynamic ftrace, the function pointer variable ftrace_trace_function is used to update the caller code in the mcount caller. But for archs that do not have CONFIG_HAVE_FUNCTION_TRACE_MCOUNT_TEST set, it only calls ftrace_test_stop_func() instead, which in turn calls __ftrace_trace_function. When more than one ftrace_ops is registered, the function it calls is ftrace_ops_list_func(), which will iterate over all registered ftrace_ops and call the callbacks that have their hash matching. The issue happens when two ftrace_ops are registered for different functions and one is then unregistered. The __ftrace_trace_function is then pointed to the remaining ftrace_ops callback function directly. This mean it will be called for all functions that were registered to trace by both ftrace_ops that were registered. This is not an issue for archs with CONFIG_HAVE_FUNCTION_TRACE_MCOUNT_TEST, because the update of ftrace_trace_function doesn't happen until after all functions have been updated, and then the mcount caller is updated. But for those archs that do use the ftrace_test_stop_func(), the update is immediate. The dynamic selftest fails because it hits this situation, and the ftrace_ops that it registers fails to only trace what it was suppose to and instead traces all other functions. The solution is to delay the setting of __ftrace_trace_function until after all the functions have been updated according to the registered ftrace_ops. Also, function_trace_stop is set during the update to prevent function tracing from calling code that is caused by the function tracer itself. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-13ftrace: Update filter when tracing enabled in set_ftrace_filter()Steven Rostedt
Currently, if set_ftrace_filter() is called when the ftrace_ops is active, the function filters will not be updated. They will only be updated when tracing is disabled and re-enabled. Update the functions immediately during set_ftrace_filter(). Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-13ftrace: Balance records when updating the hashSteven Rostedt
Whenever the hash of the ftrace_ops is updated, the record counts must be balance. This requires disabling the records that are set in the original hash, and then enabling the records that are set in the updated hash. Moving the update into ftrace_hash_move() removes the bug where the hash was updated but the records were not, which results in ftrace triggering a warning and disabling itself because the ftrace_ops filter is updated while the ftrace_ops was registered, and then the failure happens when the ftrace_ops is unregistered. The current code will not trigger this bug, but new code will. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-07ftrace: Do not disable interrupts for modules in mcount updateSteven Rostedt
When I mounted an NFS directory, it caused several modules to be loaded. At the time I was running the preemptirqsoff tracer, and it showed the following output: # tracer: preemptirqsoff # # preemptirqsoff latency trace v1.1.5 on 2.6.33.9-rt30-mrg-test # -------------------------------------------------------------------- # latency: 1177 us, #4/4, CPU#3 | (M:preempt VP:0, KP:0, SP:0 HP:0 #P:4) # ----------------- # | task: modprobe-19370 (uid:0 nice:0 policy:0 rt_prio:0) # ----------------- # => started at: ftrace_module_notify # => ended at: ftrace_module_notify # # # _------=> CPU# # / _-----=> irqs-off # | / _----=> need-resched # || / _---=> hardirq/softirq # ||| / _--=> preempt-depth # |||| /_--=> lock-depth # |||||/ delay # cmd pid |||||| time | caller # \ / |||||| \ | / modprobe-19370 3d.... 0us!: ftrace_process_locs <-ftrace_module_notify modprobe-19370 3d.... 1176us : ftrace_process_locs <-ftrace_module_notify modprobe-19370 3d.... 1178us : trace_hardirqs_on <-ftrace_module_notify modprobe-19370 3d.... 1178us : <stack trace> => ftrace_process_locs => ftrace_module_notify => notifier_call_chain => __blocking_notifier_call_chain => blocking_notifier_call_chain => sys_init_module => system_call_fastpath That's over 1ms that interrupts are disabled on a Real-Time kernel! Looking at the cause (being the ftrace author helped), I found that the interrupts are disabled before the code modification of mcounts into nops. The interrupts only need to be disabled on start up around this code, not when modules are being loaded. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-07tracing: Still trace filtered irq functions when irq trace is disabledSteven Rostedt
If a function is set to be traced by the set_graph_function, but the option funcgraph-irqs is zero, and the traced function happens to be called from a interrupt, it will not be traced. The point of funcgraph-irqs is to not trace interrupts when we are preempted by an irq, not to not trace functions we want to trace that happen to be *in* a irq. Luckily the current->trace_recursion element is perfect to add a flag to help us be able to trace functions within an interrupt even when we are not tracing interrupts that preempt the trace. Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com> Tested-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-07ftrace: Fix regression of :mod:module function enablingSteven Rostedt
The new code that allows different utilities to pick and choose what functions they trace broke the :mod: hook that allows users to trace only functions of a particular module. The reason is that the :mod: hook bypasses the hash that is setup to allow individual users to trace their own functions and uses the global hash directly. But if the global hash has not been set up, it will cause a bug: echo '*:mod:radeon' > /sys/kernel/debug/set_ftrace_filter produces: [drm:drm_mode_getfb] *ERROR* invalid framebuffer id [drm:radeon_crtc_page_flip] *ERROR* failed to reserve new rbo buffer before flip BUG: unable to handle kernel paging request at ffffffff8160ec90 IP: [<ffffffff810d9136>] add_hash_entry+0x66/0xd0 PGD 1a05067 PUD 1a09063 PMD 80000000016001e1 Oops: 0003 [#1] SMP Jul 7 04:02:28 phyllis kernel: [55303.858604] CPU 1 Modules linked in: cryptd aes_x86_64 aes_generic binfmt_misc rfcomm bnep ip6table_filter hid radeon r8169 ahci libahci mii ttm drm_kms_helper drm video i2c_algo_bit intel_agp intel_gtt Pid: 10344, comm: bash Tainted: G WC 3.0.0-rc5 #1 Dell Inc. Inspiron N5010/0YXXJJ RIP: 0010:[<ffffffff810d9136>] [<ffffffff810d9136>] add_hash_entry+0x66/0xd0 RSP: 0018:ffff88003a96bda8 EFLAGS: 00010246 RAX: ffff8801301735c0 RBX: ffffffff8160ec80 RCX: 0000000000306ee0 RDX: 0000000000000000 RSI: 0000000000000000 RDI: ffff880137c92940 RBP: ffff88003a96bdb8 R08: ffff880137c95680 R09: 0000000000000000 R10: 0000000000000001 R11: 0000000000000000 R12: ffffffff81c9df78 R13: ffff8801153d1000 R14: 0000000000000000 R15: 0000000000000000 FS: 00007f329c18a700(0000) GS:ffff880137c80000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: ffffffff8160ec90 CR3: 000000003002b000 CR4: 00000000000006e0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process bash (pid: 10344, threadinfo ffff88003a96a000, task ffff88012fcfc470) Stack: 0000000000000fd0 00000000000000fc ffff88003a96be38 ffffffff810d92f5 ffff88011c4c4e00 ffff880000000000 000000000b69f4d0 ffffffff8160ec80 ffff8800300e6f06 0000000081130295 0000000000000282 ffff8800300e6f00 Call Trace: [<ffffffff810d92f5>] match_records+0x155/0x1b0 [<ffffffff810d940c>] ftrace_mod_callback+0xbc/0x100 [<ffffffff810dafdf>] ftrace_regex_write+0x16f/0x210 [<ffffffff810db09f>] ftrace_filter_write+0xf/0x20 [<ffffffff81166e48>] vfs_write+0xc8/0x190 [<ffffffff81167001>] sys_write+0x51/0x90 [<ffffffff815c7e02>] system_call_fastpath+0x16/0x1b Code: 48 8b 33 31 d2 48 85 f6 75 33 49 89 d4 4c 03 63 08 49 8b 14 24 48 85 d2 48 89 10 74 04 48 89 42 08 49 89 04 24 4c 89 60 08 31 d2 RIP [<ffffffff810d9136>] add_hash_entry+0x66/0xd0 RSP <ffff88003a96bda8> CR2: ffffffff8160ec90 ---[ end trace a5d031828efdd88e ]--- Reported-by: Brian Marete <marete@toshnix.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-07tracing: Have "enable" file use refcounts like the "filter" fileSteven Rostedt
The "enable" file for the event system can be removed when a module is unloaded and the event system only has events from that module. As the event system nr_events count goes to zero, it may be freed if its ref_count is also set to zero. Like the "filter" file, the "enable" file may be opened by a task and referenced later, after a module has been unloaded and the events for that event system have been removed. Although the "filter" file referenced the event system structure, the "enable" file only references a pointer to the event system name. Since the name is freed when the event system is removed, it is possible that an access to the "enable" file may reference a freed pointer. Update the "enable" file to use the subsystem_open() routine that the "filter" file uses, to keep a reference to the event system structure while the "enable" file is opened. Cc: <stable@kernel.org> Reported-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-07tracing: Fix bug when reading system filters on module removalSteven Rostedt
The event system is freed when its nr_events is set to zero. This happens when a module created an event system and then later the module is removed. Modules may share systems, so the system is allocated when it is created and freed when the modules are unloaded and all the events under the system are removed (nr_events set to zero). The problem arises when a task opened the "filter" file for the system. If the module is unloaded and it removed the last event for that system, the system structure is freed. If the task that opened the filter file accesses the "filter" file after the system has been freed, the system will access an invalid pointer. By adding a ref_count, and using it to keep track of what is using the event system, we can free it after all users are finished with the event system. Cc: <stable@kernel.org> Reported-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-05Merge branch 'tip/perf/core-2' of ↵Ingo Molnar
2011-06-14tracing/kprobes: Fix kprobe-tracer to support stack traceMasami Hiramatsu
Fix to support kernel stack trace correctly on kprobe-tracer. Since the execution path of kprobe-based dynamic events is different from other tracepoint-based events, normal ftrace_trace_stack() doesn't work correctly. To fix that, this introduces ftrace_trace_stack_regs() which traces stack via pt_regs instead of current stack register. e.g. # echo p schedule+4 > /sys/kernel/debug/tracing/kprobe_events # echo 1 > /sys/kernel/debug/tracing/options/stacktrace # echo 1 > /sys/kernel/debug/tracing/events/kprobes/enable # head -n 20 /sys/kernel/debug/tracing/trace bash-2968 [000] 10297.050245: p_schedule_4: (schedule+0x4/0x4ca) bash-2968 [000] 10297.050247: <stack trace> => schedule_timeout => n_tty_read => tty_read => vfs_read => sys_read => system_call_fastpath kworker/0:1-2940 [000] 10297.050265: p_schedule_4: (schedule+0x4/0x4ca) kworker/0:1-2940 [000] 10297.050266: <stack trace> => worker_thread => kthread => kernel_thread_helper sshd-1132 [000] 10297.050365: p_schedule_4: (schedule+0x4/0x4ca) sshd-1132 [000] 10297.050365: <stack trace> => sysret_careful Note: Even with this fix, the first entry will be skipped if the probe is put on the function entry area before the frame pointer is set up (usually, that is 4 bytes (push %bp; mov %sp %bp) on x86), because stack unwinder depends on the frame pointer. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: yrl.pp-manager.tt@hitachi.com Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Namhyung Kim <namhyung@gmail.com> Link: http://lkml.kernel.org/r/20110608070934.17777.17116.stgit@fedora15 Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-14ring-buffer: Set __GFP_NORETRY flag for ring buffer allocating processVaibhav Nagarnaik
The tracing ring buffer is allocated from kernel memory. While allocating a large chunk of memory, OOM might happen which destabilizes the system. Thus random processes might get killed during the allocation. This patch adds __GFP_NORETRY flag to the ring buffer allocation calls to make it fail more gracefully if the system will not be able to complete the allocation request. Acked-by: David Rientjes <rientjes@google.com> Signed-off-by: Vaibhav Nagarnaik <vnagarnaik@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Michael Rubin <mrubin@google.com> Cc: David Sharp <dhsharp@google.com> Link: http://lkml.kernel.org/r/1307491302-9236-1-git-send-email-vnagarnaik@google.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-14tracing: Convert to kstrtoul_from_userPeter Huewe
This patch replaces the code for getting an unsigned long from a userspace buffer by a simple call to kstroul_from_user. This makes it easier to read and less error prone. Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Link: http://lkml.kernel.org/r/1307476707-14762-1-git-send-email-peterhuewe@gmx.de Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-14tracing, function_graph: Add context-info support for function_graph tracerJiri Olsa
The function_graph tracer does not follow global context-info option. Adding TRACE_ITER_CONTEXT_INFO trace_flags check to enable it. With following commands: # echo function_graph > ./current_tracer # echo 0 > options/context-info # cat trace This is what it looked like before: # tracer: function_graph # # TIME CPU DURATION FUNCTION CALLS # | | | | | | | | 1) 0.079 us | } /* __vma_link_rb */ 1) 0.056 us | copy_page_range(); 1) | security_vm_enough_memory() { ... This is what it looks like now: # tracer: function_graph # } /* update_ts_time_stats */ timekeeping_max_deferment(); ... Signed-off-by: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1307113131-10045-6-git-send-email-jolsa@redhat.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-14tracing, function_graph: Remove lock-depth from latency traceJiri Olsa
The lock_depth was removed in commit e6e1e25 tracing: Remove lock_depth from event entry Removing the lock_depth info from function_graph latency header. With following commands: # echo function_graph > ./current_tracer # echo 1 > options/latency-format # cat trace This is what it looked like before: # tracer: function_graph # # function_graph latency trace v1.1.5 on 3.0.0-rc1-tip+ # -------------------------------------------------------------------- # latency: 0 us, #59756/311298, CPU#0 | (M:preempt VP:0, KP:0, SP:0 HP:0 #P:2) # ----------------- # | task: -0 (uid:0 nice:0 policy:0 rt_prio:0) # ----------------- # # _-----=> irqs-off # / _----=> need-resched # | / _---=> hardirq/softirq # || / _--=> preempt-depth # ||| / _-=> lock-depth # |||| / # CPU||||| DURATION FUNCTION CALLS # | ||||| | | | | | | 0) .... 0.068 us | } /* __rcu_read_unlock */ ... This is what it looks like now: # tracer: function_graph # # function_graph latency trace v1.1.5 on 3.0.0-rc1-tip+ # -------------------------------------------------------------------- # latency: 0 us, #59747/1744610, CPU#0 | (M:preempt VP:0, KP:0, SP:0 HP:0 #P:2) # ----------------- # | task: -0 (uid:0 nice:0 policy:0 rt_prio:0) # ----------------- # # _-----=> irqs-off # / _----=> need-resched # | / _---=> hardirq/softirq # || / _--=> preempt-depth # ||| / # CPU|||| DURATION FUNCTION CALLS # | |||| | | | | | | 0) ..s. 1.641 us | } /* __rcu_process_callbacks */ ... Signed-off-by: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1307113131-10045-5-git-send-email-jolsa@redhat.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-14tracing, function: Fix trace header to follow context-info optionJiri Olsa
The header display of function tracer does not follow the context-info option, so field names are displayed even if this option is off. Added check for TRACE_ITER_CONTEXT_INFO trace_flags. With following commands: # echo function > ./current_tracer # echo 0 > options/context-info # cat trace This is what it looked like before: # tracer: function # # TASK-PID CPU# TIMESTAMP FUNCTION # | | | | | add_preempt_count <-schedule rcu_note_context_switch <-schedule ... This is what it looks like now: # tracer: function # _raw_spin_unlock_irqrestore <-hrtimer_try_to_cancel ... Signed-off-by: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1307113131-10045-4-git-send-email-jolsa@redhat.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-14tracing, function_graph: Merge overhead and duration display functionsJiri Olsa
Functions print_graph_overhead() and print_graph_duration() displays data for one field - DURATION. I merged them into single function print_graph_duration(), and added a way to display the empty parts of the field. This way the print_graph_irq() function can use this column to display the IRQ signs if needed and the DURATION field details stays inside the print_graph_duration() function. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1307113131-10045-3-git-send-email-jolsa@redhat.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-14tracing, function_graph: Remove dependency of abstime and duration fields on ↵Jiri Olsa
latency The display of absolute time and duration fields is based on the latency field. This was added during the irqsoff/wakeup tracers graph support changes. It's causing confusion in what fields will be displayed for the function_graph tracer itself. So I'm removing this depency, and adding absolute time and duration fields to the preemptirqsoff preemptoff irqsoff wakeup tracers. With following commands: # echo function_graph > ./current_tracer # cat trace This is what it looked like before: # tracer: function_graph # # TIME CPU DURATION FUNCTION CALLS # | | | | | | | | 0) 0.068 us | } /* page_add_file_rmap */ 0) | _raw_spin_unlock() { ... This is what it looks like now: # tracer: function_graph # # CPU DURATION FUNCTION CALLS # | | | | | | | 0) 0.068 us | } /* add_preempt_count */ 0) 0.993 us | } /* vfsmount_lock_local_lock */ ... For preemptirqsoff preemptoff irqsoff wakeup tracers, this is what it looked like before: SNIP # _-----=> irqs-off # / _----=> need-resched # | / _---=> hardirq/softirq # || / _--=> preempt-depth # ||| / _-=> lock-depth # |||| / # CPU TASK/PID ||||| DURATION FUNCTION CALLS # | | | ||||| | | | | | | 1) <idle>-0 | d..1 0.000 us | acpi_idle_enter_simple(); ... This is what it looks like now: SNIP # # _-----=> irqs-off # / _----=> need-resched # | / _---=> hardirq/softirq # || / _--=> preempt-depth # ||| / # TIME CPU TASK/PID |||| DURATION FUNCTION CALLS # | | | | |||| | | | | | | 19.847735 | 1) <idle>-0 | d..1 0.000 us | acpi_idle_enter_simple(); ... Signed-off-by: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1307113131-10045-2-git-send-email-jolsa@redhat.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-14ftrace: Fixed an include coding style issuePaul McQuade
Removed <asm/ftrace.h> because <linux/ftrace.h> was already declared. Braces of struct's coding style fixed. Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Paul McQuade <tungstentide@gmail.com> Link: http://lkml.kernel.org/r/4DE59711.3090900@gmail.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-14tracing: Add disable_on_free optionSteven Rostedt
Add a trace option to disable tracing on free. When this option is set, a write into the free_buffer file will not only shrink the ring buffer down to zero, but it will also disable tracing. Cc: Vaibhav Nagarnaik <vnagarnaik@google.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-14tracing: Add a proc file to stop tracing and free bufferVaibhav Nagarnaik
The proc file entry buffer_size_kb is used to set the size of tracing buffer. The memory to expand the buffer size is kernel memory. Consider a use case where tracing is handled by a user space utility, which acts as a gate keeper for tracing requests. In an OOM condition, tracing is considered a low priority task and if the utility gets killed the ring buffer memory cannot be released back to the kernel. This patch adds a proc file called "free_buffer" whose purpose is to stop tracing and free up the ring buffer when it is closed. The user space process can then set the desired size in buffer_size_kb file and open the fd to the "free_buffer" file. Under OOM condition, if the process gets killed, the kernel closes the file descriptor. The release handler stops the tracing and releases the kernel memory automatically. Cc: Ingo Molnar <mingo@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Michael Rubin <mrubin@google.com> Cc: David Sharp <dhsharp@google.com> Signed-off-by: Vaibhav Nagarnaik <vnagarnaik@google.com> Link: http://lkml.kernel.org/r/1308012717-11148-1-git-send-email-vnagarnaik@google.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-14tracing: Use NUMA allocation for per-cpu ring buffer pagesVaibhav Nagarnaik
The tracing ring buffer is a group of per-cpu ring buffers where allocation and logging is done on a per-cpu basis. The events that are generated on a particular CPU are logged in the corresponding buffer. This is to provide wait-free writes between CPUs and good NUMA node locality while accessing the ring buffer. However, the allocation routines consider NUMA locality only for buffer page metadata and not for the actual buffer page. This causes the pages to be allocated on the NUMA node local to the CPU where the allocation routine is running at the time. This patch fixes the problem by using a NUMA node specific allocation routine so that the pages are allocated from a NUMA node local to the logging CPU. I tested with the getuid_microbench from autotest. It is a simple binary that calls getuid() in a loop and measures the average time for the syscall to complete. The following command was used to test: $ getuid_microbench 1000000 Compared the numbers found on kernel with and without this patch and found that logging latency decreases by 30-50 ns/call. tracing with non-NUMA allocation - 569 ns/call tracing with NUMA allocation - 512 ns/call Signed-off-by: Vaibhav Nagarnaik <vnagarnaik@google.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Michael Rubin <mrubin@google.com> Cc: David Sharp <dhsharp@google.com> Link: http://lkml.kernel.org/r/1304470602-20366-1-git-send-email-vnagarnaik@google.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-14tracing: Schedule a delayed work to call wakeup()Vaibhav Nagarnaik
In using syscall tracing by concurrent processes, the wakeup() that is called in the event commit function causes contention on the spin lock of the waitqueue. I enabled sys_enter_getuid and sys_exit_getuid tracepoints, and by running getuid_microbench from autotest in parallel I found that the contention causes exponential latency increase in the tracing path. The autotest binary getuid_microbench calls getuid() in a tight loop for the given number of iterations and measures the average time required to complete a single invocation of syscall. The patch schedules a delayed work after 2 ms once an event commit calls to wake up the trace wait_queue. This removes the delay caused by contention on spin lock in wakeup() and amortizes the wakeup() calls scheduled over the 2 ms period. In the following example, the script enables the sys_enter_getuid and sys_exit_getuid tracepoints and runs the getuid_microbench in parallel with the given number of processes. The output clearly shows the latency increase caused by contentions. $ ~/getuid.sh 1 1000000 calls in 0.720974253 s (720.974253 ns/call) $ ~/getuid.sh 2 1000000 calls in 1.166457554 s (1166.457554 ns/call) 1000000 calls in 1.168933765 s (1168.933765 ns/call) $ ~/getuid.sh 3 1000000 calls in 1.783827516 s (1783.827516 ns/call) 1000000 calls in 1.795553270 s (1795.553270 ns/call) 1000000 calls in 1.796493376 s (1796.493376 ns/call) $ ~/getuid.sh 4 1000000 calls in 4.483041796 s (4483.041796 ns/call) 1000000 calls in 4.484165388 s (4484.165388 ns/call) 1000000 calls in 4.484850762 s (4484.850762 ns/call) 1000000 calls in 4.485643576 s (4485.643576 ns/call) $ ~/getuid.sh 5 1000000 calls in 6.497521653 s (6497.521653 ns/call) 1000000 calls in 6.502000236 s (6502.000236 ns/call) 1000000 calls in 6.501709115 s (6501.709115 ns/call) 1000000 calls in 6.502124100 s (6502.124100 ns/call) 1000000 calls in 6.502936358 s (6502.936358 ns/call) After the patch, the latencies scale better. 1000000 calls in 0.728720455 s (728.720455 ns/call) 1000000 calls in 0.842782857 s (842.782857 ns/call) 1000000 calls in 0.883803135 s (883.803135 ns/call) 1000000 calls in 0.902077764 s (902.077764 ns/call) 1000000 calls in 0.902838202 s (902.838202 ns/call) 1000000 calls in 0.908896885 s (908.896885 ns/call) 1000000 calls in 0.932523515 s (932.523515 ns/call) 1000000 calls in 0.958009672 s (958.009672 ns/call) 1000000 calls in 0.986188020 s (986.188020 ns/call) 1000000 calls in 0.989771102 s (989.771102 ns/call) 1000000 calls in 0.933518391 s (933.518391 ns/call) 1000000 calls in 0.958897947 s (958.897947 ns/call) 1000000 calls in 1.031038897 s (1031.038897 ns/call) 1000000 calls in 1.089516025 s (1089.516025 ns/call) 1000000 calls in 1.141998347 s (1141.998347 ns/call) Signed-off-by: Vaibhav Nagarnaik <vnagarnaik@google.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Michael Rubin <mrubin@google.com> Cc: David Sharp <dhsharp@google.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1305059241-7629-1-git-send-email-vnagarnaik@google.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-09tracing: Fix regression in printk_formats fileSteven Rostedt
The fix to fix the printk_formats of modules broke the printk_formats of trace_printks in the kernel. The update of what to show via the seq_file was only updated if the passed in fmt was NULL, which happens only on the first iteration. The result was showing the first format every time instead of iterating through the available formats. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-07ftrace: Revert 8ab2b7efd ftrace: Remove unnecessary disabling of irqsSteven Rostedt
Revert the commit that removed the disabling of interrupts around the initial modifying of mcount callers to nops, and update the comment. The original comment was outdated and stated that the interrupts were being disabled to prevent kstop machine, which was required with the old ftrace daemon, but was no longer the case. What the comment failed to mention was that interrupts needed to be disabled to keep interrupts from preempting the modifying of the code and then executing the code that was partially modified. Revert the commit and update the comment. Reported-by: Richard W.M. Jones <rjones@redhat.com> Tested-by: Richard W.M. Jones <rjones@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-07kprobes/trace: Fix kprobe selftest for gcc 4.6Steven Rostedt
With gcc 4.6, the self test kprobe function: kprobe_trace_selftest_target() is optimized such that kallsyms does not list it. The kprobes test uses this function to insert a probe and test it. But it will fail the test if the function is not listed in kallsyms. Adding a __used annotation keeps the symbol in the kallsyms table. Suggested-by: David Daney <ddaney@caviumnetworks.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-06-06ftrace: Fix possible undefined return codeGuoWen Li
kernel/trace/ftrace.c: In function 'ftrace_regex_write.clone.15': kernel/trace/ftrace.c:2743:6: warning: 'ret' may be used uninitialized in this function Signed-off-by: GuoWen Li <guowen.li.linux@gmail.com> Link: http://lkml.kernel.org/r/201106011918.47939.guowen.li.linux@gmail.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25ftrace: Add internal recursive checksSteven Rostedt
Witold reported a reboot caused by the selftests of the dynamic function tracer. He sent me a config and I used ktest to do a config_bisect on it (as my config did not cause the crash). It pointed out that the problem config was CONFIG_PROVE_RCU. What happened was that if multiple callbacks are attached to the function tracer, we iterate a list of callbacks. Because the list is managed by synchronize_sched() and preempt_disable, the access to the pointers uses rcu_dereference_raw(). When PROVE_RCU is enabled, the rcu_dereference_raw() calls some debugging functions, which happen to be traced. The tracing of the debug function would then call rcu_dereference_raw() which would then call the debug function and then... well you get the idea. I first wrote two different patches to solve this bug. 1) add a __rcu_dereference_raw() that would not do any checks. 2) add notrace to the offending debug functions. Both of these patches worked. Talking with Paul McKenney on IRC, he suggested to add recursion detection instead. This seemed to be a better solution, so I decided to implement it. As the task_struct already has a trace_recursion to detect recursion in the ring buffer, and that has a very small number it allows, I decided to use that same variable to add flags that can detect the recursion inside the infrastructure of the function tracer. I plan to change it so that the task struct bit can be checked in mcount, but as that requires changes to all archs, I will hold that off to the next merge window. Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1306348063.1465.116.camel@gandalf.stny.rr.com Reported-by: Witold Baryluk <baryluk@smp.if.uj.edu.pl> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25tracing: Add __print_symbolic_u64 to avoid warnings on 32bit machineliubo
Filesystem, like Btrfs, has some "ULL" macros, and when these macros are passed to tracepoints'__print_symbolic(), there will be 64->32 truncate WARNINGS during compiling on 32bit box. Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Link: http://lkml.kernel.org/r/4DACE6E0.7000507@cn.fujitsu.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25ftrace: Set ops->flag to enabled even on static function tracingSteven Rostedt
When dynamic ftrace is not configured, the ops->flags still needs to have its FTRACE_OPS_FL_ENABLED bit set in ftrace_startup(). Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25tracing: Have event with function tracer check error returnSteven Rostedt
The self tests for event tracer does not check if the function tracing was successfully activated. It needs to before it continues the tests, otherwise the wrong errors may be reported. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-25ftrace: Have ftrace_startup() return failure codeSteven Rostedt
The register_ftrace_function() returns an error code on failure except if the call to ftrace_startup() fails. Add a error return to ftrace_startup() if it fails to start, allowing register_ftrace_funtion() to return a proper error value. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-19Merge branches 'sched-core-for-linus' and 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (60 commits) sched: Fix and optimise calculation of the weight-inverse sched: Avoid going ahead if ->cpus_allowed is not changed sched, rt: Update rq clock when unthrottling of an otherwise idle CPU sched: Remove unused parameters from sched_fork() and wake_up_new_task() sched: Shorten the construction of the span cpu mask of sched domain sched: Wrap the 'cfs_rq->nr_spread_over' field with CONFIG_SCHED_DEBUG sched: Remove unused 'this_best_prio arg' from balance_tasks() sched: Remove noop in alloc_rt_sched_group() sched: Get rid of lock_depth sched: Remove obsolete comment from scheduler_tick() sched: Fix sched_domain iterations vs. RCU sched: Next buddy hint on sleep and preempt path sched: Make set_*_buddy() work on non-task entities sched: Remove need_migrate_task() sched: Move the second half of ttwu() to the remote cpu sched: Restructure ttwu() some more sched: Rename ttwu_post_activation() to ttwu_do_wakeup() sched: Remove rq argument from ttwu_stat() sched: Remove rq->lock from the first half of ttwu() sched: Drop rq->lock from sched_exec() ... * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched: Fix rt_rq runtime leakage bug
2011-05-18ftrace: Add self-tests for multiple function trace usersSteven Rostedt
Add some basic sanity tests for multiple users of the function tracer at startup. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-18ftrace: Modify ftrace_set_filter/notrace to take opsSteven Rostedt
Since users of the function tracer can now pick and choose which functions they want to trace agnostically from other users of the function tracer, we need to pass the ops struct to the ftrace_set_filter() functions. The functions ftrace_set_global_filter() and ftrace_set_global_notrace() is added to keep the old filter functions which are used to modify the generic function tracers. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-18ftrace: Allow dynamically allocated function tracersSteven Rostedt
Now that functions may be selected individually, it only makes sense that we should allow dynamically allocated trace structures to be traced. This will allow perf to allocate a ftrace_ops structure at runtime and use it to pick and choose which functions that structure will trace. Note, a dynamically allocated ftrace_ops will always be called indirectly instead of being called directly from the mcount in entry.S. This is because there's no safe way to prevent mcount from being preempted before calling the function, unless we modify every entry.S to do so (not likely). Thus, dynamically allocated functions will now be called by the ftrace_ops_list_func() that loops through the ops that are allocated if there are more than one op allocated at a time. This loop is protected with a preempt_disable. To determine if an ftrace_ops structure is allocated or not, a new util function was added to the kernel/extable.c called core_kernel_data(), which returns 1 if the address is between _sdata and _edata. Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-18ftrace: Implement separate user function filteringSteven Rostedt
ftrace_ops that are registered to trace functions can now be agnostic to each other in respect to what functions they trace. Each ops has their own hash of the functions they want to trace and a hash to what they do not want to trace. A empty hash for the functions they want to trace denotes all functions should be traced that are not in the notrace hash. Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-18ftrace: Free hash with call_rcu_sched()Steven Rostedt
When a hash is modified and might be in use, we need to perform a schedule RCU operation on it, as the hashes will soon be used directly in the function tracer callback. Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-18ftrace: Have global_ops store the functions that are to be tracedSteven Rostedt
This is a step towards each ops structure defining its own set of functions to trace. As the current code with pid's and such are specific to the global_ops, it is restructured to be used with the global ops. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-18ftrace: Add ops parameter to ftrace_startup/shutdown functionsSteven Rostedt
In order to allow different ops to enable different functions, the ftrace_startup() and ftrace_shutdown() functions need the ops parameter passed to them. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-18ftrace: Add enabled_functions fileSteven Rostedt
Add the enabled_functions file that is used to show all the functions that have been enabled for tracing as well as their ref counts. This helps seeing if any function has been registered and what functions are being traced. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-05-18ftrace: Use counters to enable functions to traceSteven Rostedt
Every function has its own record that stores the instruction pointer and flags for the function to be traced. There are only two flags: enabled and free. The enabled flag states that tracing for the function has been enabled (actively traced), and the free flag states that the record no longer points to a function and can be used by new functions (loaded modules). These flags are now moved to the MSB of the flags (actually just the top 32bits). The rest of the bits (30 bits) are now used as a ref counter. Everytime a tracer register functions to trace, those functions will have its counter incremented. When tracing is enabled, to determine if a function should be traced, the counter is examined, and if it is non-zero it is set to trace. When a ftrace_ops is registered to trace functions, its hashes are examined. If the ftrace_ops filter_hash count is zero, then all functions are set to be traced, otherwise only the functions in the hash are to be traced. The exception to this is if a function is also in the ftrace_ops notrace_hash. Then that function's counter is not incremented for this ftrace_ops. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
