commit 45ab2813d40d88fc575e753c38478de242d03f88 upstream.
If a module fails to add its tracepoints due to module tainting, do not
create the module event infrastructure in the debugfs directory. As the events
will not work and worse yet, they will silently fail, making the user wonder
why the events they enable do not display anything.
Having a warning on module load and the events not visible to the users
will make the cause of the problem much clearer.
Link: http://lkml.kernel.org/r/20140227154923.265882695@goodmis.org
Fixes: 6d723736e472 "tracing/events: add support for modules to TRACE_EVENT"
Acked-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
commit d651aa1d68a2f0a7ee65697b04c6a92f8c0a12f2 upstream.
Each sub-buffer (buffer page) has a full 64 bit timestamp. The events on
that page use a 27 bit delta against that timestamp in order to save on
bits written to the ring buffer. If the time between events is larger than
what the 27 bits can hold, a "time extend" event is added to hold the
entire 64 bit timestamp again and the events after that hold a delta from
that timestamp.
As a "time extend" is always paired with an event, it is logical to just
allocate the event with the time extend, to make things a bit more efficient.
Unfortunately, when the pairing code was written, it removed the "delta = 0"
from the first commit on a page, causing the events on the page to be
slightly skewed.
Fixes: 69d1b839f7ee "ring-buffer: Bind time extend and data events together"
commit 23a8e8441a0a74dd612edf81dc89d1600bc0a3d1 upstream.
Doing some different tests, I discovered that function graph tracing, when
filtered via the set_ftrace_filter and set_ftrace_notrace files, does
not always keep with them if another function ftrace_ops is registered
to trace functions.
The reason is that function graph just happens to trace all functions
that the function tracer enables. When there was only one user of
function tracing, the function graph tracer did not need to worry about
being called by functions that it did not want to trace. But now that there
are other users, this becomes a problem.
For example, one just needs to do the following:
# cd /sys/kernel/debug/tracing
# echo schedule > set_ftrace_filter
# echo function_graph > current_tracer
# cat trace
0) | schedule() {
0) <idle>-0 => rcu_pre-7
0) ! 2980.314 us | }
0) | schedule() {
0) rcu_pre-7 => <idle>-0
0) + 20.701 us | }
# echo 1 > /proc/sys/kernel/stack_tracer_enabled
# cat trace
1) + 20.825 us | }
1) + 21.651 us | }
1) + 30.924 us | } /* SyS_ioctl */
1) | do_page_fault() {
1) | __do_page_fault() {
1) 0.274 us | down_read_trylock();
1) 0.098 us | find_vma();
1) | handle_mm_fault() {
1) | _raw_spin_lock() {
1) 0.102 us | preempt_count_add();
1) 0.097 us | do_raw_spin_lock();
1) 2.173 us | }
1) | do_wp_page() {
1) 0.079 us | vm_normal_page();
1) 0.086 us | reuse_swap_page();
1) 0.076 us | page_move_anon_rmap();
1) | unlock_page() {
1) 0.082 us | page_waitqueue();
1) 0.086 us | __wake_up_bit();
1) 1.801 us | }
1) 0.075 us | ptep_set_access_flags();
1) | _raw_spin_unlock() {
1) 0.098 us | do_raw_spin_unlock();
1) 0.105 us | preempt_count_sub();
1) 1.884 us | }
1) 9.149 us | }
1) + 13.083 us | }
1) 0.146 us | up_read();
When the stack tracer was enabled, it enabled all functions to be traced, which
now the function graph tracer also traces. This is a side effect that should
not occur.
To fix this a test is added when the function tracing is changed, as well as when
the graph tracer is enabled, to see if anything other than the ftrace global_ops
function tracer is enabled. If so, then the graph tracer calls a test trampoline
that will look at the function that is being traced and compare it with the
filters defined by the global_ops.
As an optimization, if there's no other function tracers registered, or if
the only registered function tracers also use the global ops, the function
graph infrastructure will call the registered function graph callback directly
and not go through the test trampoline.
Fixes: d2d45c7a03a2 "tracing: Have stack_tracer use a separate list of functions"
commit a4c35ed241129dd142be4cadb1e5a474a56d5464 upstream.
The synchronization needed after ftrace_ops are unregistered must happen
after the callback is disabled from becing called by functions.
The current location happens after the function is being removed from the
internal lists, but not after the function callbacks were disabled, leaving
the functions susceptible of being called after their callbacks are freed.
This affects perf and any externel users of function tracing (LTTng and
SystemTap).
Fixes: cdbe61bfe704 "ftrace: Allow dynamically allocated function tracers"
commit 405e1d834807e51b2ebd3dea81cb51e53fb61504 upstream.
[ Partial commit backported to 3.4. The ftrace_sync() code by this is
required for other fixes that 3.4 needs. ]
ftrace_trace_function is a variable that holds what function will be called
directly by the assembly code (mcount). If just a single function is
registered and it handles recursion itself, then the assembly will call that
function directly without any helper function. It also passes in the
ftrace_op that was registered with the callback. The ftrace_op to send is
stored in the function_trace_op variable.
The ftrace_trace_function and function_trace_op needs to be coordinated such
that the called callback wont be called with the wrong ftrace_op, otherwise
bad things can happen if it expected a different op. Luckily, there's no
callback that doesn't use the helper functions that requires this. But
there soon will be and this needs to be fixed.
Use a set_function_trace_op to store the ftrace_op to set the
function_trace_op to when it is safe to do so (during the update function
within the breakpoint or stop machine calls). Or if dynamic ftrace is not
being used (static tracing) then we have to do a bit more synchronization
when the ftrace_trace_function is set as that takes affect immediately
(as oppose to dynamic ftrace doing it with the modification of the trampoline).
commit c4602c1c818bd6626178d6d3fcc152d9f2f48ac0 upstream.
Ftrace currently initializes only the online CPUs. This implementation has
two problems:
- If we online a CPU after we enable the function profile, and then run the
test, we will lose the trace information on that CPU.
Steps to reproduce:
# echo 0 > /sys/devices/system/cpu/cpu1/online
# cd <debugfs>/tracing/
# echo <some function name> >> set_ftrace_filter
# echo 1 > function_profile_enabled
# echo 1 > /sys/devices/system/cpu/cpu1/online
# run test
- If we offline a CPU before we enable the function profile, we will not clear
the trace information when we enable the function profile. It will trouble
the users.
Steps to reproduce:
# run test
# cat trace_stat/function*
# echo 0 > function_profile_enabled
# run test
So it is better that we initialize the ftrace profiler for each possible cpu
every time we enable the function profile instead of just the online ones.
Link: http://lkml.kernel.org/r/1387178401-10619-1-git-send-email-miaox@cn.fujitsu.com
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
commit 8a56d7761d2d041ae5e8215d20b4167d8aa93f51 upstream.
Commit 8c4f3c3fa9681 "ftrace: Check module functions being traced on reload"
fixed module loading and unloading with respect to function tracing, but
it missed the function graph tracer. If you perform the following
# modprobe nfsd
# echo nop > current_tracer
You'll get the following oops message:
WARNING: CPU: 2 PID: 2910 at /linux.git/kernel/trace/ftrace.c:1640 __ftrace_hash_rec_update.part.35+0x168/0x1b9()
Modules linked in: nfsd exportfs nfs_acl lockd ipt_MASQUERADE sunrpc ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 ip6table_filter ip6_tables uinput snd_hda_codec_idt
CPU: 2 PID: 2910 Comm: bash Not tainted 3.13.0-rc1-test #7
Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS SDBLI944.86P 05/08/2007
0000000000000668 ffff8800787efcf8 ffffffff814fe193 ffff88007d500000
0000000000000000 ffff8800787efd38 ffffffff8103b80a 0000000000000668
ffffffff810b2b9a ffffffff81a48370 0000000000000001 ffff880037aea000
Call Trace:
[<ffffffff814fe193>] dump_stack+0x4f/0x7c
[<ffffffff8103b80a>] warn_slowpath_common+0x81/0x9b
[<ffffffff810b2b9a>] ? __ftrace_hash_rec_update.part.35+0x168/0x1b9
[<ffffffff8103b83e>] warn_slowpath_null+0x1a/0x1c
[<ffffffff810b2b9a>] __ftrace_hash_rec_update.part.35+0x168/0x1b9
[<ffffffff81502f89>] ? __mutex_lock_slowpath+0x364/0x364
[<ffffffff810b2cc2>] ftrace_shutdown+0xd7/0x12b
[<ffffffff810b47f0>] unregister_ftrace_graph+0x49/0x78
[<ffffffff810c4b30>] graph_trace_reset+0xe/0x10
[<ffffffff810bf393>] tracing_set_tracer+0xa7/0x26a
[<ffffffff810bf5e1>] tracing_set_trace_write+0x8b/0xbd
[<ffffffff810c501c>] ? ftrace_return_to_handler+0xb2/0xde
[<ffffffff811240a8>] ? __sb_end_write+0x5e/0x5e
[<ffffffff81122aed>] vfs_write+0xab/0xf6
[<ffffffff8150a185>] ftrace_graph_caller+0x85/0x85
[<ffffffff81122dbd>] SyS_write+0x59/0x82
[<ffffffff8150a2d2>] system_call_fastpath+0x16/0x1b
---[ end trace 940358030751eafb ]---
The above mentioned commit didn't go far enough. Well, it covered the
function tracer by adding checks in __register_ftrace_function(). The
problem is that the function graph tracer circumvents that (for a slight
efficiency gain when function graph trace is running with a function
tracer. The gain was not worth this).
The problem came with ftrace_startup() which should always be called after
__register_ftrace_function(), if you want this bug to be completely fixed.
Anyway, this solution moves __register_ftrace_function() inside of
ftrace_startup() and removes the need to call them both.
Reported-by: Dave Wysochanski <dwysocha@redhat.com>
Fixes: ed926f9b35cd ("ftrace: Use counters to enable functions to trace")
commit 12ae030d54ef250706da5642fc7697cc60ad0df7 upstream.
The current default perf paranoid level is "1" which has
"perf_paranoid_kernel()" return false, and giving any operations that
use it, access to normal users. Unfortunately, this includes function
tracing and normal users should not be allowed to enable function
tracing by default.
The proper level is defined at "-1" (full perf access), which
"perf_paranoid_tracepoint_raw()" will only give access to. Use that
check instead for enabling function tracing.
Reported-by: Dave Jones <davej@redhat.com>
Reported-by: Vince Weaver <vincent.weaver@maine.edu>
Tested-by: Vince Weaver <vincent.weaver@maine.edu>
Cc: Jiri Olsa <jolsa@redhat.com>
CVE: CVE-2013-2930
Fixes: ced39002f5ea ("ftrace, perf: Add support to use function tracepoint in perf")
commit 057db8488b53d5e4faa0cedb2f39d4ae75dfbdbb upstream.
Andrey reported the following report:
ERROR: AddressSanitizer: heap-buffer-overflow on address ffff8800359c99f3
ffff8800359c99f3 is located 0 bytes to the right of 243-byte region [ffff8800359c9900, ffff8800359c99f3)
Accessed by thread T13003:
#0 ffffffff810dd2da (asan_report_error+0x32a/0x440)
#1 ffffffff810dc6b0 (asan_check_region+0x30/0x40)
#2 ffffffff810dd4d3 (__tsan_write1+0x13/0x20)
#3 ffffffff811cd19e (ftrace_regex_release+0x1be/0x260)
#4 ffffffff812a1065 (__fput+0x155/0x360)
#5 ffffffff812a12de (____fput+0x1e/0x30)
#6 ffffffff8111708d (task_work_run+0x10d/0x140)
#7 ffffffff810ea043 (do_exit+0x433/0x11f0)
#8 ffffffff810eaee4 (do_group_exit+0x84/0x130)
#9 ffffffff810eafb1 (SyS_exit_group+0x21/0x30)
#10 ffffffff81928782 (system_call_fastpath+0x16/0x1b)
Allocated by thread T5167:
#0 ffffffff810dc778 (asan_slab_alloc+0x48/0xc0)
#1 ffffffff8128337c (__kmalloc+0xbc/0x500)
#2 ffffffff811d9d54 (trace_parser_get_init+0x34/0x90)
#3 ffffffff811cd7b3 (ftrace_regex_open+0x83/0x2e0)
#4 ffffffff811cda7d (ftrace_filter_open+0x2d/0x40)
#5 ffffffff8129b4ff (do_dentry_open+0x32f/0x430)
#6 ffffffff8129b668 (finish_open+0x68/0xa0)
#7 ffffffff812b66ac (do_last+0xb8c/0x1710)
#8 ffffffff812b7350 (path_openat+0x120/0xb50)
#9 ffffffff812b8884 (do_filp_open+0x54/0xb0)
#10 ffffffff8129d36c (do_sys_open+0x1ac/0x2c0)
#11 ffffffff8129d4b7 (SyS_open+0x37/0x50)
#12 ffffffff81928782 (system_call_fastpath+0x16/0x1b)
Shadow bytes around the buggy address:
ffff8800359c9700: fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd fd
ffff8800359c9780: fd fd fd fd fd fd fd fd fa fa fa fa fa fa fa fa
ffff8800359c9800: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
ffff8800359c9880: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
ffff8800359c9900: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
=>ffff8800359c9980: 00 00 00 00 00 00 00 00 00 00 00 00 00 00[03]fb
ffff8800359c9a00: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
ffff8800359c9a80: fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa fa
ffff8800359c9b00: fa fa fa fa fa fa fa fa 00 00 00 00 00 00 00 00
ffff8800359c9b80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffff8800359c9c00: 00 00 00 00 00 00 00 00 fa fa fa fa fa fa fa fa
Shadow byte legend (one shadow byte represents 8 application bytes):
Addressable: 00
Partially addressable: 01 02 03 04 05 06 07
Heap redzone: fa
Heap kmalloc redzone: fb
Freed heap region: fd
Shadow gap: fe
The out-of-bounds access happens on 'parser->buffer[parser->idx] = 0;'
Although the crash happened in ftrace_regex_open() the real bug
occurred in trace_get_user() where there's an incrementation to
parser->idx without a check against the size. The way it is triggered
is if userspace sends in 128 characters (EVENT_BUF_SIZE + 1), the loop
that reads the last character stores it and then breaks out because
there is no more characters. Then the last character is read to determine
what to do next, and the index is incremented without checking size.
Then the caller of trace_get_user() usually nulls out the last character
with a zero, but since the index is equal to the size, it writes a nul
character after the allocated space, which can corrupt memory.
Luckily, only root user has write access to this file.
Link: http://lkml.kernel.org/r/20131009222323.04fd1a0d@gandalf.local.home
Reported-by: Andrey Konovalov <andreyknvl@google.com>
commit ed5467da0e369e65b247b99eb6403cb79172bcda upstream.
tracing_read_pipe zeros all fields bellow "seq". The declaration contains
a comment about that, but it doesn't help.
The first field is "snapshot", it's true when current open file is
snapshot. Looks obvious, that it should not be zeroed.
The second field is "started". It was converted from cpumask_t to
cpumask_var_t (v2.6.28-4983-g4462344), in other words it was
converted from cpumask to pointer on cpumask.
Currently the reference on "started" memory is lost after the first read
from tracing_read_pipe and a proper object will never be freed.
The "started" is never dereferenced for trace_pipe, because trace_pipe
can't have the TRACE_FILE_ANNOTATE options.
Link: http://lkml.kernel.org/r/1375463803-3085183-1-git-send-email-avagin@openvz.org
Signed-off-by: Andrew Vagin <avagin@openvz.org>
commit 11034ae9c20f4057a6127fc965906417978e69b2 upstream
Initialization of variable irq_flags and pc was missed when backport
11034ae9c to linux-3.0.y and linux-3.4.y, my fault.
Signed-off-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com>
commit 11034ae9c20f4057a6127fc965906417978e69b2 upstream.
All syscall tracing irqs-off tags are wrong, the syscall enter entry doesn't
disable irqs.
[root@jovi tracing]#echo "syscalls:sys_enter_open" > set_event
[root@jovi tracing]# cat trace
# tracer: nop
# entries-in-buffer/entries-written: 13/13 #P:2
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
irqbalance-513 [000] d... 56115.496766: sys_open(filename: 804e1a6, flags: 0, mode: 1b6)
irqbalance-513 [000] d... 56115.497008: sys_open(filename: 804e1bb, flags: 0, mode: 1b6)
sendmail-771 [000] d... 56115.827982: sys_open(filename: b770e6d1, flags: 0, mode: 1b6)
The reason is syscall tracing doesn't record irq_flags into buffer.
The proper display is:
# tracer: nop
# entries-in-buffer/entries-written: 14/14 #P:2
# _-----=> irqs-off
# ||| / delay
irqbalance-514 [001] .... 46.213921: sys_open(filename: 804e1a6, flags: 0, mode: 1b6)
irqbalance-514 [001] .... 46.214160: sys_open(filename: 804e1bb, flags: 0, mode: 1b6)
<...>-920 [001] .... 47.307260: sys_open(filename: 4e82a0c5, flags: 80000, mode: 0)
Link: http://lkml.kernel.org/r/1365564393-10972-3-git-send-email-jovi.zhangwei@huawei.com
Cc: stable@vger.kernel.org # 2.6.35
commit f17a5194859a82afe4164e938b92035b86c55794 upstream.
The irqsoff tracer records the max time that interrupts are disabled.
There are hooks in the assembly code that calls back into the tracer when
interrupts are disabled or enabled.
When they are enabled, the tracer checks if the amount of time they
were disabled is larger than the previous recorded max interrupts off
time. If it is, it creates a snapshot of the currently running trace
to store where the last largest interrupts off time was held and how
it happened.
During testing, this RCU lockdep dump appeared:
[ 1257.829021] ===============================
[ 1257.829021] [ INFO: suspicious RCU usage. ]
[ 1257.829021] 3.10.0-rc1-test+ #171 Tainted: G W
[ 1257.829021] -------------------------------
[ 1257.829021] /home/rostedt/work/git/linux-trace.git/include/linux/rcupdate.h:780 rcu_read_lock() used illegally while idle!
[ 1257.829021]
[ 1257.829021] other info that might help us debug this:
[ 1257.829021]
[ 1257.829021]
[ 1257.829021] RCU used illegally from idle CPU!
[ 1257.829021] rcu_scheduler_active = 1, debug_locks = 0
[ 1257.829021] RCU used illegally from extended quiescent state!
[ 1257.829021] 2 locks held by trace-cmd/4831:
[ 1257.829021] #0: (max_trace_lock){......}, at: [<ffffffff810e2b77>] stop_critical_timing+0x1a3/0x209
[ 1257.829021] #1: (rcu_read_lock){.+.+..}, at: [<ffffffff810dae5a>] __update_max_tr+0x88/0x1ee
[ 1257.829021]
[ 1257.829021] stack backtrace:
[ 1257.829021] CPU: 3 PID: 4831 Comm: trace-cmd Tainted: G W 3.10.0-rc1-test+ #171
[ 1257.829021] Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS SDBLI944.86P 05/08/2007
[ 1257.829021] 0000000000000001 ffff880065f49da8 ffffffff8153dd2b ffff880065f49dd8
[ 1257.829021] ffffffff81092a00 ffff88006bd78680 ffff88007add7500 0000000000000003
[ 1257.829021] ffff88006bd78680 ffff880065f49e18 ffffffff810daebf ffffffff810dae5a
[ 1257.829021] Call Trace:
[ 1257.829021] [<ffffffff8153dd2b>] dump_stack+0x19/0x1b
[ 1257.829021] [<ffffffff81092a00>] lockdep_rcu_suspicious+0x109/0x112
[ 1257.829021] [<ffffffff810daebf>] __update_max_tr+0xed/0x1ee
[ 1257.829021] [<ffffffff810dae5a>] ? __update_max_tr+0x88/0x1ee
[ 1257.829021] [<ffffffff811002b9>] ? user_enter+0xfd/0x107
[ 1257.829021] [<ffffffff810dbf85>] update_max_tr_single+0x11d/0x12d
[ 1257.829021] [<ffffffff810e2b15>] stop_critical_timing+0x141/0x209
[ 1257.829021] [<ffffffff8109569a>] ? trace_hardirqs_on+0xd/0xf
[ 1257.829021] [<ffffffff810e3057>] time_hardirqs_on+0x2a/0x2f
[ 1257.829021] [<ffffffff8109550c>] trace_hardirqs_on_caller+0x16/0x197
[ 1257.829021] [<ffffffff8109569a>] trace_hardirqs_on+0xd/0xf
[ 1257.829021] [<ffffffff811002b9>] user_enter+0xfd/0x107
[ 1257.829021] [<ffffffff810029b4>] do_notify_resume+0x92/0x97
[ 1257.829021] [<ffffffff8154bdca>] int_signal+0x12/0x17
What happened was entering into the user code, the interrupts were enabled
and a max interrupts off was recorded. The trace buffer was saved along with
various information about the task: comm, pid, uid, priority, etc.
The uid is recorded with task_uid(tsk). But this is a macro that uses rcu_read_lock()
to retrieve the data, and this happened to happen where RCU is blind (user_enter).
As only the preempt and irqs off tracers can have this happen, and they both
only have the tsk == current, if tsk == current, use current_uid() instead of
task_uid(), as current_uid() does not use RCU as only current can change its uid.
This fixes the RCU suspicious splat.
commit 7f49ef69db6bbf756c0abca7e9b65b32e999eec8 upstream.
As ftrace_filter_lseek is now used with ftrace_pid_fops, it needs to
be moved out of the #ifdef CONFIG_DYNAMIC_FTRACE section as the
ftrace_pid_fops is defined when DYNAMIC_FTRACE is not.
Cc: Namhyung Kim <namhyung@kernel.org>
[ lizf: adjust context ]
Signed-off-by: Li Zefan <lizefan@huawei.com>
commit 6a76f8c0ab19f215af2a3442870eeb5f0e81998d upstream.
Currently set_ftrace_pid and set_graph_function files use seq_lseek
for their fops. However seq_open() is called only for FMODE_READ in
the fops->open() so that if an user tries to seek one of those file
when she open it for writing, it sees NULL seq_file and then panic.
It can be easily reproduced with following command:
$ cd /sys/kernel/debug/tracing
$ echo 1234 | sudo tee -a set_ftrace_pid
In this example, GNU coreutils' tee opens the file with fopen(, "a")
and then the fopen() internally calls lseek().
Link:
http://lkml.kernel.org/r/1365663302-2170-1-git-send-email-namhyung@kernel.org
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Cc: Namhyung Kim <namhyung.kim@lge.com>
commit 60705c89460fdc7227f2d153b68b3f34814738a4 upstream.
Special preds are created when folding a series of preds that
can be done in serial. These are allocated in an ops field of
the pred structure. But they were never freed, causing memory
leaks.
This was discovered using the kmemleak checker:
unreferenced object 0xffff8800797fd5e0 (size 32):
comm "swapper/0", pid 1, jiffies 4294690605 (age 104.608s)
hex dump (first 32 bytes):
00 00 01 00 03 00 05 00 07 00 09 00 0b 00 0d 00 ................
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
backtrace:
[<ffffffff814b52af>] kmemleak_alloc+0x73/0x98
[<ffffffff8111ff84>] kmemleak_alloc_recursive.constprop.42+0x16/0x18
[<ffffffff81120e68>] __kmalloc+0xd7/0x125
[<ffffffff810d47eb>] kcalloc.constprop.24+0x2d/0x2f
[<ffffffff810d4896>] fold_pred_tree_cb+0xa9/0xf4
[<ffffffff810d3781>] walk_pred_tree+0x47/0xcc
[<ffffffff810d5030>] replace_preds.isra.20+0x6f8/0x72f
[<ffffffff810d50b5>] create_filter+0x4e/0x8b
[<ffffffff81b1c30d>] ftrace_test_event_filter+0x5a/0x155
[<ffffffff8100028d>] do_one_initcall+0xa0/0x137
[<ffffffff81afbedf>] kernel_init_freeable+0x14d/0x1dc
[<ffffffff814b24b7>] kernel_init+0xe/0xdb
[<ffffffff814d539c>] ret_from_fork+0x7c/0xb0
[<ffffffffffffffff>] 0xffffffffffffffff
Cc: Tom Zanussi <tzanussi@gmail.com>
commit 7fe70b579c9e3daba71635e31b6189394e7b79d3 upstream.
ftrace_dump() had a lot of issues. What ftrace_dump() does, is when
ftrace_dump_on_oops is set (via a kernel parameter or sysctl), it
will dump out the ftrace buffers to the console when either a oops,
panic, or a sysrq-z occurs.
This was written a long time ago when ftrace was fragile to recursion.
But it wasn't written well even for that.
There's a possible deadlock that can occur if a ftrace_dump() is happening
and an NMI triggers another dump. This is because it grabs a lock
before checking if the dump ran.
It also totally disables ftrace, and tracing for no good reasons.
As the ring_buffer now checks if it is read via a oops or NMI, where
there's a chance that the buffer gets corrupted, it will disable
itself. No need to have ftrace_dump() do the same.
ftrace_dump() is now cleaned up where it uses an atomic counter to
make sure only one dump happens at a time. A simple atomic_inc_return()
is enough that is needed for both other CPUs and NMIs. No need for
a spinlock, as if one CPU is running the dump, no other CPU needs
to do it too.
The tracing_on variable is turned off and not turned on. The original
code did this, but it wasn't pretty. By just disabling this variable
we get the result of not seeing traces that happen between crashes.
For sysrq-z, it doesn't get turned on, but the user can always write
a '1' to the tracing_on file. If they are using sysrq-z, then they should
know about tracing_on.
The new code is much easier to read and less error prone. No more
deadlock possibility when an NMI triggers here.
Reported-by: zhangwei(Jovi) <jovi.zhangwei@huawei.com>
commit 9f50afccfdc15d95d7331acddcb0f7703df089ae upstream.
The ftrace_graph_count can be decreased with a "!" pattern, so that
the enabled flag should be updated too.
Link: http://lkml.kernel.org/r/1365663698-2413-1-git-send-email-namhyung@kernel.org
commit ed6f1c996bfe4b6e520cf7a74b51cd6988d84420 upstream.
Check return value and bail out if it's NULL.
Link: http://lkml.kernel.org/r/1365553093-10180-2-git-send-email-namhyung@kernel.org
commit 39e30cd1537937d3c00ef87e865324e981434e5b upstream.
The first page was allocated separately, so no need to start from 0.
Link: http://lkml.kernel.org/r/1364820385-32027-2-git-send-email-namhyung@kernel.org
commit 4df297129f622bdc18935c856f42b9ddd18f9f28 upstream.
Currently, the depth reported in the stack tracer stack_trace file
does not match the stack_max_size file. This is because the stack_max_size
includes the overhead of stack tracer itself while the depth does not.
The first time a max is triggered, a calculation is not performed that
figures out the overhead of the stack tracer and subtracts it from
the stack_max_size variable. The overhead is stored and is subtracted
from the reported stack size for comparing for a new max.
Now the stack_max_size corresponds to the reported depth:
# cat stack_max_size
4640
# cat stack_trace
Depth Size Location (48 entries)
0) 4640 32 _raw_spin_lock+0x18/0x24
1) 4608 112 ____cache_alloc+0xb7/0x22d
2) 4496 80 kmem_cache_alloc+0x63/0x12f
3) 4416 16 mempool_alloc_slab+0x15/0x17
While testing against and older gcc on x86 that uses mcount instead
of fentry, I found that pasing in ip + MCOUNT_INSN_SIZE let the
stack trace show one more function deep which was missing before.
commit d4ecbfc49b4b1d4b597fb5ba9e4fa25d62f105c5 upstream.
When gcc 4.6 on x86 is used, the function tracer will use the new
option -mfentry which does a call to "fentry" at every function
instead of "mcount". The significance of this is that fentry is
called as the first operation of the function instead of the mcount
usage of being called after the stack.
This causes the stack tracer to show some bogus results for the size
of the last function traced, as well as showing "ftrace_call" instead
of the function. This is due to the stack frame not being set up
by the function that is about to be traced.
# cat stack_trace
0) 4824 216 ftrace_call+0x5/0x2f
The 216 size for ftrace_call includes both the ftrace_call stack
(which includes the saving of registers it does), as well as the
stack size of the parent.
To fix this, if CC_USING_FENTRY is defined, then the stack_tracer
will reserve the first item in stack_dump_trace[] array when
calling save_stack_trace(), and it will fill it in with the parent ip.
Then the code will look for the parent pointer on the stack and
give the real size of the parent's stack pointer:
# cat stack_trace
Depth Size Location (14 entries)
0) 2640 48 update_group_power+0x26/0x187
1) 2592 224 update_sd_lb_stats+0x2a5/0x4ac
2) 2368 160 find_busiest_group+0x31/0x1f1
3) 2208 256 load_balance+0xd9/0x662
I'm Cc'ing stable, although it's not urgent, as it only shows bogus
size for item #0, the rest of the trace is legit. It should still be
corrected in previous stable releases.
commit 87889501d0adfae10e3b0f0e6f2d7536eed9ae84 upstream.
Use the stack of stack_trace_call() instead of check_stack() as
the test pointer for max stack size. It makes it a bit cleaner
and a little more accurate.
Adding stable, as a later fix depends on this patch.
commit 83e03b3fe4daffdebbb42151d5410d730ae50bd1 upstream.
On the failure path, stat->start and stat->pages will refer same page.
So it'll attempt to free the same page again and get kernel panic.
Link: http://lkml.kernel.org/r/1364820385-32027-1-git-send-email-namhyung@kernel.org
commit 5000c418840b309251c5887f0b56503aae30f84c upstream.
If we reenable ftrace via syctl, we currently set ftrace_trace_function
based on the previous simplistic algorithm. This is inconsistent with
what update_ftrace_function does. So better call that helper instead.
Link: http://lkml.kernel.org/r/5151D26F.1070702@siemens.com
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
commit 613f04a0f51e6e68ac6fe571ab79da3c0a5eb4da upstream.
The latency tracers require the buffers to be in overwrite mode,
otherwise they get screwed up. Force the buffers to stay in overwrite
mode when latency tracers are enabled.
Added a flag_changed() method to the tracer structure to allow
the tracers to see what flags are being changed, and also be able
to prevent the change from happing.
[Backported for 3.4-stable. Re-added current_trace NULL checks; removed
allocated_snapshot field; adapted to tracing_trace_options_write without
trace_set_options.]
Signed-off-by: Lingzhu Xiang <lxiang@redhat.com>
Reviewed-by: CAI Qian <caiqian@redhat.com>
commit 69d34da2984c95b33ea21518227e1f9470f11d95 upstream.
Seems that the tracer flags have never been protected from
synchronous writes. Luckily, admins don't usually modify the
tracing flags via two different tasks. But if scripts were to
be used to modify them, then they could get corrupted.
Move the trace_types_lock that protects against tracers changing
to also protect the flags being set.
[Backported for 3.4, 3.0-stable. Moved return to after unlock.]
commit 740466bc89ad8bd5afcc8de220f715f62b21e365 upstream.
Because function tracing is very invasive, and can even trace
calls to rcu_read_lock(), RCU access in function tracing is done
with preempt_disable_notrace(). This requires a synchronize_sched()
for updates and not a synchronize_rcu().
Function probes (traceon, traceoff, etc) must be freed after
a synchronize_sched() after its entry has been removed from the
hash. But call_rcu() is used. Fix this by using call_rcu_sched().
Also fix the usage to use hlist_del_rcu() instead of hlist_del().
Cc: Paul McKenney <paulmck@linux.vnet.ibm.com>
commit 2721e72dd10f71a3ba90f59781becf02638aa0d9 upstream.
Although the swap is wrapped with a spin_lock, the assignment
of the temp buffer used to swap is not within that lock.
It needs to be moved into that lock, otherwise two swaps
happening on two different CPUs, can end up using the wrong
temp buffer to assign in the swap.
Luckily, all current callers of the swap function appear to have
their own locks. But in case something is added that allows two
different callers to call the swap, then there's a chance that
this race can trigger and corrupt the buffers.
New code is coming soon that will allow for this race to trigger.
I've Cc'd stable, so this bug will not show up if someone backports
one of the changes that can trigger this bug.
commit db05021d49a994ee40a9735d9c3cb0060c9babb8 upstream.
The prompt to enable DYNAMIC_FTRACE (the ability to nop and
enable function tracing at run time) had a confusing statement:
"enable/disable ftrace tracepoints dynamically"
This was written before tracepoints were added to the kernel,
but now that tracepoints have been added, this is very confusing
and has confused people enough to give wrong information during
presentations.
Not only that, I looked at the help text, and it still references
that dreaded daemon that use to wake up once a second to update
the nop locations and brick NICs, that hasn't been around for over
five years.
Time to bring the text up to the current decade.
Reported-by: Ezequiel Garcia <elezegarcia@gmail.com>
commit 8c189ea64eea01ca20d102ddb74d6936dd16c579 upstream.
Commit: c1bf08ac "ftrace: Be first to run code modification on modules"
changed ftrace module notifier's priority to INT_MAX in order to
process the ftrace nops before anything else could touch them
(namely kprobes). This was the correct thing to do.
Unfortunately, the ftrace module notifier also contains the ftrace
clean up code. As opposed to the set up code, this code should be
run *after* all the module notifiers have run in case a module is doing
correct clean-up and unregisters its ftrace hooks. Basically, ftrace
needs to do clean up on module removal, as it needs to know about code
being removed so that it doesn't try to modify that code. But after it
removes the module from its records, if a ftrace user tries to remove
a probe, that removal will fail due as the record of that code segment
no longer exists.
Nothing really bad happens if the probe removal is called after ftrace
did the clean up, but the ftrace removal function will return an error.
Correct code (such as kprobes) will produce a WARN_ON() if it fails
to remove the probe. As people get annoyed by frivolous warnings, it's
best to do the ftrace clean up after everything else.
By splitting the ftrace_module_notifier into two notifiers, one that
does the module load setup that is run at high priority, and the other
that is called for module clean up that is run at low priority, the
problem is solved.
Reported-by: Frank Ch. Eigler <fche@redhat.com>
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
commit c1bf08ac26e92122faab9f6c32ea8aba94612dae upstream.
If some other kernel subsystem has a module notifier, and adds a kprobe
to a ftrace mcount point (now that kprobes work on ftrace points),
when the ftrace notifier runs it will fail and disable ftrace, as well
as kprobes that are attached to ftrace points.
Here's the error:
WARNING: at kernel/trace/ftrace.c:1618 ftrace_bug+0x239/0x280()
Hardware name: Bochs
Modules linked in: fat(+) stap_56d28a51b3fe546293ca0700b10bcb29__8059(F) nfsv4 auth_rpcgss nfs dns_resolver fscache xt_nat iptable_nat nf_conntrack_ipv4 nf_defrag_ipv4 nf_nat_ipv4 nf_nat nf_conntrack lockd sunrpc ppdev parport_pc parport microcode virtio_net i2c_piix4 drm_kms_helper ttm drm i2c_core [last unloaded: bid_shared]
Pid: 8068, comm: modprobe Tainted: GF 3.7.0-0.rc8.git0.1.fc19.x86_64 #1
Call Trace:
[<ffffffff8105e70f>] warn_slowpath_common+0x7f/0xc0
[<ffffffff81134106>] ? __probe_kernel_read+0x46/0x70
[<ffffffffa0180000>] ? 0xffffffffa017ffff
[<ffffffff8105e76a>] warn_slowpath_null+0x1a/0x20
[<ffffffff810fd189>] ftrace_bug+0x239/0x280
[<ffffffff810fd626>] ftrace_process_locs+0x376/0x520
[<ffffffff810fefb7>] ftrace_module_notify+0x47/0x50
[<ffffffff8163912d>] notifier_call_chain+0x4d/0x70
[<ffffffff810882f8>] __blocking_notifier_call_chain+0x58/0x80
[<ffffffff81088336>] blocking_notifier_call_chain+0x16/0x20
[<ffffffff810c2a23>] sys_init_module+0x73/0x220
[<ffffffff8163d719>] system_call_fastpath+0x16/0x1b
---[ end trace 9ef46351e53bbf80 ]---
ftrace failed to modify [<ffffffffa0180000>] init_once+0x0/0x20 [fat]
actual: cc:bb:d2:4b:e1
A kprobe was added to the init_once() function in the fat module on load.
But this happened before ftrace could have touched the code. As ftrace
didn't run yet, the kprobe system had no idea it was a ftrace point and
simply added a breakpoint to the code (0xcc in the cc:bb:d2:4b:e1).
Then when ftrace went to modify the location from a call to mcount/fentry
into a nop, it didn't see a call op, but instead it saw the breakpoint op
and not knowing what to do with it, ftrace shut itself down.
The solution is to simply give the ftrace module notifier the max priority.
This should have been done regardless, as the core code ftrace modification
also happens very early on in boot up. This makes the module modification
closer to core modification.
Link: http://lkml.kernel.org/r/20130107140333.593683061@goodmis.org
commit 9366c1ba13fbc41bdb57702e75ca4382f209c82f upstream.
The function rb_check_pages() was added to make sure the ring buffer's
pages were sane. This check is done when the ring buffer size is modified
as well as when the iterator is released (closing the "trace" file),
as that was considered a non fast path and a good place to do a sanity
check.
The problem is that the check does not have any locks around it.
If one process were to read the trace file, and another were to read
the raw binary file, the check could happen while the reader is reading
the file.
The issues with this is that the check requires to clear the HEAD page
before doing the full check and it restores it afterward. But readers
require the HEAD page to exist before it can read the buffer, otherwise
it gives a nasty warning and disables the buffer.
By adding the reader lock around the check, this keeps the race from
happening.
commit 70f77b3f7ec010ff9624c1f2e39a81babc9e2429 upstream.
There is a typo here where '&' is used instead of '|' and it turns the
statement into a noop. The original code is equivalent to:
iter->flags &= ~((1 << 2) & (1 << 4));
Link: http://lkml.kernel.org/r/20120609161027.GD6488@elgon.mountain
commit 047fe3605235888f3ebcda0c728cb31937eadfe6 upstream.
Dave Jones reported a kernel BUG at mm/slub.c:3474! triggered
by splice_shrink_spd() called from vmsplice_to_pipe()
commit 35f3d14dbbc5 (pipe: add support for shrinking and growing pipes)
added capability to adjust pipe->buffers.
Problem is some paths don't hold pipe mutex and assume pipe->buffers
doesn't change for their duration.
Fix this by adding nr_pages_max field in struct splice_pipe_desc, and
use it in place of pipe->buffers where appropriate.
splice_shrink_spd() loses its struct pipe_inode_info argument.
Cc: Tom Herbert <therbert@google.com>
Tested-by: Dave Jones <davej@redhat.com>
[bwh: Backported to 3.2:
- Adjust context in vmsplice_to_pipe()
- Update one more call to splice_shrink_spd(), from skb_splice_bits()]
commit 71babb2705e2203a64c27ede13ae3508a0d2c16c upstream.
According to Documentation/trace/ftrace.txt:
tracing_cpumask:
This is a mask that lets the user only trace
on specified CPUS. The format is a hex string
representing the CPUS.
The tracing_cpumask currently doesn't affect the tracing state of
per-CPU ring buffers.
This patch enables/disables CPU recording as its corresponding bit in
tracing_cpumask is set/unset.
Link: http://lkml.kernel.org/r/1336096792-25373-3-git-send-email-vnagarnaik@google.com
Cc: Laurent Chavey <chavey@google.com>
Cc: Justin Teravest <teravest@google.com>
Cc: David Sharp <dhsharp@google.com>
Signed-off-by: Vaibhav Nagarnaik <vnagarnaik@google.com>
commit f2bf1f6f5f89d031245067512449fc889b2f4bb2 upstream.
A recent update to have tracing_on/off() only affect the ftrace ring
buffers instead of all ring buffers had a cut and paste error.
The tracing_off() did the exact same thing as tracing_on() and
would not actually turn off tracing. Unfortunately, tracing_off()
is more important to be working than tracing_on() as this is a key
development tool, as it lets the developer turn off tracing as soon
as a problem is discovered. It is also used by panic and oops code.
This bug also breaks the 'echo func:traceoff > set_ftrace_filter'
With the adding of function tracing event to perf, it caused a
side effect that produces the following warning when enabling all
events in ftrace:
# echo 1 > /sys/kernel/debug/tracing/events/enable
[console]
event trace: Could not enable event function
This is because when enabling all events via the debugfs system
it ignores events that do not have a ->reg() function assigned.
This was to skip over the ftrace internal events (as they are
not TRACE_EVENTs). But as the ftrace function event now has
a ->reg() function attached to it for use with perf, it is no
longer ignored.
Worse yet, this ->reg() function is being called when it should
not be. It returns an error and causes the above warning to
be printed.
By adding a new event_call flag (TRACE_EVENT_FL_IGNORE_ENABLE)
and have all ftrace internel event structures have it set,
setting the events/enable will no longe try to incorrectly enable
the function event and does not warn.
While debugging a latency with someone on IRC (mirage335) on #linux-rt (OFTC),
we discovered that the stacktrace output of the latency tracers
(preemptirqsoff) was empty.
This bug was caused by the creation of the dynamic length stack trace
again (like commit 12b5da3 "tracing: Fix ent_size in trace output" was).
This bug is caused by the latency tracers requiring the next event
to determine the time between the current event and the next. But by
grabbing the next event, the iter->ent_size is set to the next event
instead of the current one. As the stacktrace event is the last event,
this makes the ent_size zero and causes nothing to be printed for
the stack trace. The dynamic stacktrace uses the ent_size to determine
how much of the stack can be printed. The ent_size of zero means
no stack.
The simple fix is to save the iter->ent_size before finding the next event.
Note, mirage335 asked to remain anonymous from LKML and git, so I will
not add the Reported-by and Tested-by tags, even though he did report
the issue and tested the fix.
Cc: stable@vger.kernel.org # 3.1+
The change to make tracing_on affect only the ftrace ring buffer, caused
a bug where it wont affect any ring buffer. The problem was that the buffer
of the trace_array was passed to the write function and not the trace array
itself.
The trace_array can change the buffer when running a latency tracer. If this
happens, then the buffer being disabled may not be the buffer currently used
by ftrace. This will cause the tracing_on file to become useless.
The simple fix is to pass the trace_array to the write function instead of
the buffer. Then the actual buffer may be changed.
Today's -next fails to link for me:
kernel/built-in.o:(.data+0x178e50): undefined reference to `perf_ftrace_event_register'
It looks like multiple fixes have been merged for the issue fixed by
commit fa73dc9 (tracing: Fix build breakage without CONFIG_PERF_EVENTS)
though I can't identify the other changes that have gone in at the
minute, it's possible that the changes which caused the breakage fixed
by the previous commit got dropped but the fix made it in.
Link: http://lkml.kernel.org/r/1334307179-21255-1-git-send-email-broonie@opensource.wolfsonmicro.com
Merge batch of fixes from Andrew Morton:
"The simple_open() cleanup was held back while I wanted for laggards to
merge things.
I still need to send a few checkpoint/restore patches. I've been
wobbly about merging them because I'm wobbly about the overall
prospects for success of the project. But after speaking with Pavel
at the LSF conference, it sounds like they're further toward
completion than I feared - apparently davem is at the "has stopped
complaining" stage regarding the net changes. So I need to go back
and re-review those patchs and their (lengthy) discussion."
* emailed from Andrew Morton <akpm@linux-foundation.org>: (16 patches)
memcg swap: use mem_cgroup_uncharge_swap fix
backlight: add driver for DA9052/53 PMIC v1
C6X: use set_current_blocked() and block_sigmask()
MAINTAINERS: add entry for sparse checker
MAINTAINERS: fix REMOTEPROC F: typo
alpha: use set_current_blocked() and block_sigmask()
simple_open: automatically convert to simple_open()
scripts/coccinelle/api/simple_open.cocci: semantic patch for simple_open()
libfs: add simple_open()
hugetlbfs: remove unregister_filesystem() when initializing module
drivers/rtc/rtc-88pm860x.c: fix rtc irq enable callback
fs/xattr.c:setxattr(): improve handling of allocation failures
fs/xattr.c:listxattr(): fall back to vmalloc() if kmalloc() failed
fs/xattr.c: suppress page allocation failure warnings from sys_listxattr()
sysrq: use SEND_SIG_FORCED instead of force_sig()
proc: fix mount -t proc -o AAA
Many users of debugfs copy the implementation of default_open() when
they want to support a custom read/write function op. This leads to a
proliferation of the default_open() implementation across the entire
tree.
Now that the common implementation has been consolidated into libfs we
can replace all the users of this function with simple_open().
This replacement was done with the following semantic patch:
<smpl>
@ open @
identifier open_f != simple_open;
identifier i, f;
-int open_f(struct inode *i, struct file *f)
-if (i->i_private)
-f->private_data = i->i_private;
-return 0;
@ has_open depends on open @
identifier fops;
identifier open.open_f;
struct file_operations fops = {
-.open = open_f,
+.open = simple_open,
</smpl>
[akpm@linux-foundation.org: checkpatch fixes]
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
When reading the trace file, the records of each of the per_cpu buffers
are examined to find the next event to print out. At the point of looking
at the event, the size of the event is recorded. But if the first event is
chosen, the other events in the other CPU buffers will reset the event size
that is stored in the iterator descriptor, causing the event size passed to
the output functions to be incorrect.
In most cases this is not a problem, but for the case of stack traces, it
is. With the change to the stack tracing to record a dynamic number of
back traces, the output depends on the size of the entry instead of the
fixed 8 back traces. When the entry size is not correct, the back traces
would not be fully printed.
Note, reading from the per-cpu trace files were not affected.
Reported-by: Thomas Gleixner <tglx@linutronix.de>
Tested-by: Thomas Gleixner <tglx@linutronix.de>
Merge reason: we need to fix a non-trivial merge conflict.
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into perf/urgent
8 hex characters tell only half the tale for 64 bit CPUs,
so use the appropriate length.
Link: http://lkml.kernel.org/r/1332411501-8059-2-git-send-email-wolfgang.mauerer@siemens.com
Signed-off-by: Wolfgang Mauerer <wolfgang.mauerer@siemens.com>
Pull vfs pile 1 from Al Viro:
"This is _not_ all; in particular, Miklos' and Jan's stuff is not there
yet."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits)
ext4: initialization of ext4_li_mtx needs to be done earlier
debugfs-related mode_t whack-a-mole
hfsplus: add an ioctl to bless files
hfsplus: change finder_info to u32
hfsplus: initialise userflags
qnx4: new helper - try_extent()
qnx4: get rid of qnx4_bread/qnx4_getblk
take removal of PF_FORKNOEXEC to flush_old_exec()
trim includes in inode.c
um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it
um: embed ->stub_pages[] into mmu_context
gadgetfs: list_for_each_safe() misuse
ocfs2: fix leaks on failure exits in module_init
ecryptfs: make register_filesystem() the last potential failure exit
ntfs: forgets to unregister sysctls on register_filesystem() failure
logfs: missing cleanup on register_filesystem() failure
jfs: mising cleanup on register_filesystem() failure
make configfs_pin_fs() return root dentry on success
configfs: configfs_create_dir() has parent dentry in dentry->d_parent
configfs: sanitize configfs_create()
Today's -next fails to build for me:
CC kernel/trace/trace_export.o
In file included from kernel/trace/trace_export.c:197: kernel/trace/trace_entries.h:58: error: 'perf_ftrace_event_register' undeclared here (not in a function)
make[2]: *** [kernel/trace/trace_export.o] Error 1
make[1]: *** [kernel/trace] Error 2
make: *** [kernel] Error 2
because as of ced390 (ftrace, perf: Add support to use function
tracepoint in perf) perf_trace_event_register() is declared in trace.h
only if CONFIG_PERF_EVENTS is enabled but I don't have that set.
Ensure that we always have a definition of perf_trace_event_register()
by making the definition unconditional.
Link: http://lkml.kernel.org/r/1330426967-17067-1-git-send-email-broonie@opensource.wolfsonmicro.com
