path: root/kernel/tsacct.c
2012-09-18userns: Convert taskstats to handle the user and pid namespaces.Eric W. Biederman
- Explicitly limit exit task stat broadcast to the initial user and pid namespaces, as it is already limited to the initial network namespace. - For broadcast task stats explicitly generate all of the idenitiers in terms of the initial user namespace and the initial pid namespace. - For request stats report them in terms of the current user namespace and the current pid namespace. Netlink messages are delivered syncrhonously to the kernel allowing us to get the user namespace and the pid namespace from the current task. - Pass the namespaces for representing pids and uids and gids into bacct_add_task. Cc: Balbir Singh <bsingharora@gmail.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2011-12-15[S390] cputime: add sparse checking and cleanupMartin Schwidefsky
Make cputime_t and cputime64_t nocast to enable sparse checking to detect incorrect use of cputime. Drop the cputime macros for simple scalar operations. The conversion macros are still needed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2011-09-19Make taskstats round statistics down to nearest 1k bytes/eventsLinus Torvalds
Even with just the interface limited to admin, there really is little to reason to give byte-per-byte counts for taskstats. So round it down to something less intrusive. Acked-by: Balbir Singh <bsingharora@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27taskstats: use real microsecond granularity for CPU timesMichael Holzheu
The taskstats interface uses microsecond granularity for the user and system time values. The conversion from cputime to the taskstats values uses the cputime_to_msecs primitive which effectively limits the granularity to milliseconds. Add the cputime_to_usecs primitive for architectures that have better, more precise CPU time values. Remove cputime_to_msecs primitive because there are no more users left. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Luck Tony <tony.luck@intel.com> Cc: Shailabh Nagar <nagar1234@in.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Shailabh Nagar <nagar@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-06mm: clean up mm_counterKAMEZAWA Hiroyuki
Presently, per-mm statistics counter is defined by macro in sched.h This patch modifies it to - defined in mm.h as inlinf functions - use array instead of macro's name creation. This patch is for reducing patch size in future patch to modify implementation of per-mm counter. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Reviewed-by: Minchan Kim <minchan.kim@gmail.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-09Fix fixpoint divide exception in acct_update_integralsHeiko Carstens
Frans Pop reported the crash below when running an s390 kernel under Hercules: Kernel BUG at 000738b4 verbose debug info unavailable! fixpoint divide exception: 0009 #1! SMP Modules linked in: nfs lockd nfs_acl sunrpc ctcm fsm tape_34xx cu3088 tape ccwgroup tape_class ext3 jbd mbcache dm_mirror dm_log dm_snapshot dm_mod dasd_eckd_mod dasd_mod CPU: 0 Not tainted 2.6.27.19 #13 Process awk (pid: 2069, task: 0f9ed9b8, ksp: 0f4f7d18) Krnl PSW : 070c1000 800738b4 (acct_update_integrals+0x4c/0x118) R:0 T:1 IO:1 EX:1 Key:0 M:1 W:0 P:0 AS:0 CC:1 PM:0 Krnl GPRS: 00000000 000007d0 7fffffff fffff830 00000000 ffffffff 00000002 0f9ed9b8 00000000 00008ca0 00000000 0f9ed9b8 0f9edda4 8007386e 0f4f7ec8 0f4f7e98 Krnl Code: 800738aa: a71807d0 lhi %r1,2000 800738ae: 8c200001 srdl %r2,1 800738b2: 1d21 dr %r2,%r1 >800738b4: 5810d10e l %r1,270(%r13) 800738b8: 1823 lr %r2,%r3 800738ba: 4130f060 la %r3,96(%r15) 800738be: 0de1 basr %r14,%r1 800738c0: 5800f060 l %r0,96(%r15) Call Trace: ( <000000000004fdea>! blocking_notifier_call_chain+0x1e/0x2c) <0000000000038502>! do_exit+0x106/0x7c0 <0000000000038c36>! do_group_exit+0x7a/0xb4 <0000000000038c8e>! SyS_exit_group+0x1e/0x30 <0000000000021c28>! sysc_do_restart+0x12/0x16 <0000000077e7e924>! 0x77e7e924 Reason for this is that cpu time accounting usually only happens from interrupt context, but acct_update_integrals gets also called from process context with interrupts enabled. So in acct_update_integrals we may end up with the following scenario: Between reading tsk->stime/tsk->utime and tsk->acct_timexpd an interrupt happens which updates accouting values. This causes acct_timexpd to be greater than the former stime + utime. The subsequent calculation of dtime = cputime_sub(time, tsk->acct_timexpd); will be negative and the division performed by cputime_to_jiffies(dtime) will generate an exception since the result won't fit into a 32 bit register. In order to fix this just always disable interrupts while accessing any of the accounting values. Reported by: Frans Pop <elendil@planet.nl> Tested by: Frans Pop <elendil@planet.nl> Cc: stable@kernel.org Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06mm: introduce get_mm_hiwater_xxx(), fix taskstats->hiwater_xxx accountingOleg Nesterov
xacct_add_tsk() relies on do_exit()->update_hiwater_xxx() and uses mm->hiwater_xxx directly, this leads to 2 problems: - taskstats_user_cmd() can call fill_pid()->xacct_add_tsk() at any moment before the task exits, so we should check the current values of rss/vm anyway. - do_exit()->update_hiwater_xxx() calls are racy. An exiting thread can be preempted right before mm->hiwater_xxx = new_val, and another thread can use A_LOT of memory and exit in between. When the first thread resumes it can be the last thread in the thread group, in that case we report the wrong hiwater_xxx values which do not take A_LOT into account. Introduce get_mm_hiwater_rss() and get_mm_hiwater_vm() helpers and change xacct_add_tsk() to use them. The first helper will also be used by rusage->ru_maxrss accounting. Kill do_exit()->update_hiwater_xxx() calls. Unless we are going to decrease rss/vm there is no point to update mm->hiwater_xxx, and nobody can look at this mm_struct when exit_mmap() actually unmaps the memory. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Hugh Dickins <hugh@veritas.com> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-14CRED: Use RCU to access another task's creds and to release a task's own credsDavid Howells
Use RCU to access another task's creds and to release a task's own creds. This means that it will be possible for the credentials of a task to be replaced without another task (a) requiring a full lock to read them, and (b) seeing deallocated memory. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Separate task security context from task_structDavid Howells
Separate the task security context from task_struct. At this point, the security data is temporarily embedded in the task_struct with two pointers pointing to it. Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in entry.S via asm-offsets. With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-07-27task IO accounting: move all IO statistics in struct task_io_accountingAndrea Righi
Simplify the code of include/linux/task_io_accounting.h. It is also more reasonable to have all the task i/o-related statistics in a single struct (task_io_accounting). Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-27task IO accounting: improve code readabilityAndrea Righi
Put all i/o statistics in struct proc_io_accounting and use inline functions to initialize and increment statistics, removing a lot of single variable assignments. This also reduces the kernel size as following (with CONFIG_TASK_XACCT=y and CONFIG_TASK_IO_ACCOUNTING=y). text data bss dec hex filename 11651 0 0 11651 2d83 kernel/exit.o.before 11619 0 0 11619 2d63 kernel/exit.o.after 10886 132 136 11154 2b92 kernel/fork.o.before 10758 132 136 11026 2b12 kernel/fork.o.after 3082029 807968 4818600 8708597 84e1f5 vmlinux.o.before 3081869 807968 4818600 8708437 84e155 vmlinux.o.after Signed-off-by: Andrea Righi <righi.andrea@gmail.com> Acked-by: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25tsacct: fix bacct_add_tsk()'s use of do_div()David Howells
Fix bacct_add_tsk()'s use of do_div() on an s64 by making ac_etime a u64 instead and dividing that. Possibly this should be guarded lest the interval calculation turn up negative, but the possible negativity of the result of the division is cast away, and it shouldn't end up negative anyway. This was introduced by patch f3cef7a99469afc159fec3a61b42dc7ca5b6824f. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Jay Lan <jlan@engr.sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25accounting: account for user time when updating memory integralsJonathan Lim
Adapt acct_update_integrals() to include user time when calculating the time difference. The units of acct_rss_mem1 and acct_vm_mem1 are also changed from pages-jiffies to pages-usecs to avoid calling jiffies_to_usecs() in xacct_add_tsk() which might overflow. Signed-off-by: Jonathan Lim <jlim@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18Add scaled time to taskstats based process accountingMichael Neuling
This adds items to the taststats struct to account for user and system time based on scaling the CPU frequency and instruction issue rates. Adds account_(user|system)_time_scaled callbacks which architectures can use to account for time using this mechanism. Signed-off-by: Michael Neuling <mikey@neuling.org> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@engr.sgi.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-25Cleanup non-arch xtime uses, use get_seconds() or current_kernel_time().john stultz
This avoids use of the kernel-internal "xtime" variable directly outside of the actual time-related functions. Instead, use the helper functions that we already have available to us. This doesn't actually change any behaviour, but this will allow us to fix the fact that "xtime" isn't updated very often with CONFIG_NO_HZ (because much of the realtime information is maintained as separate offsets to 'xtime'), which has caused interfaces that use xtime directly to get a time that is out of sync with the real-time clock by up to a third of a second or so. Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] time: x86_64: split x86_64/kernel/time.c upjohn stultz
In preparation for the x86_64 generic time conversion, this patch splits out TSC and HPET related code from arch/x86_64/kernel/time.c into respective hpet.c and tsc.c files. [akpm@osdl.org: fix printk timestamps] [akpm@osdl.org: cleanup] Signed-off-by: John Stultz <johnstul@us.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Andi Kleen <ak@muc.de> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-10[PATCH] io-accounting: via taskstatsAndrew Morton
Deliver IO accounting via taskstats. Cc: Jay Lan <jlan@sgi.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Chris Sturtivant <csturtiv@sgi.com> Cc: Tony Ernst <tee@sgi.com> Cc: Guillaume Thouvenin <guillaume.thouvenin@bull.net> Cc: David Wright <daw@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] xacct_add_tsk: fix pure theoretical ->mm use-after-freeOleg Nesterov
Paranoid fix. The task can free its ->mm after the 'if (p->mm)' check. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jay Lan <jlan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] bacct_add_tsk: fix unsafe and wrong parent/group_leader dereferenceOleg Nesterov
1. ts = timespec_sub(uptime, current->group_leader->start_time); It is possible that current != tsk. Probably it was supposed to be 'tsk->group_leader->start_time. But why we are reading group_leader's start_time ? This accounting is per thread, not per procees, I changed this to 'tsk->start_time. Please corect me. 2. stats->ac_ppid = (tsk->parent) ? tsk->parent->pid : 0; tsk->parent never == NULL, and it is unsafe to dereference it. Both the task and it's parent may exit after the caller unlocks tasklist_lock, the memory could be unmapped (DEBUG_SLAB). (And we should use ->real_parent->tgid in fact). Q: I don't understand the 'if (thread_group_leader(tsk))' check. Why it is needed ? Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Acked-by: Jay Lan <jlan@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] csa accounting taskstats updateJay Lan
ChangeLog: Feedbacks from Andrew Morton: - define TS_COMM_LEN to 32 - change acct_stimexpd field of task_struct to be of cputime_t, which is to be used to save the tsk->stime of last timer interrupt update. - a new Documentation/accounting/taskstats-struct.txt to describe fields of taskstats struct. Feedback from Balbir Singh: - keep the stime of a task to be zero when both stime and utime are zero as recoreded in task_struct. Misc: - convert accumulated RSS/VM from platform dependent pages-ticks to MBytes-usecs in the kernel Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Chris Sturtivant <csturtiv@sgi.com> Cc: Tony Ernst <tee@sgi.com> Cc: Guillaume Thouvenin <guillaume.thouvenin@bull.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] csa: convert CONFIG tag for extended accounting routinesJay Lan
There were a few accounting data/macros that are used in CSA but are #ifdef'ed inside CONFIG_BSD_PROCESS_ACCT. This patch is to change those ifdef's from CONFIG_BSD_PROCESS_ACCT to CONFIG_TASK_XACCT. A few defines are moved from kernel/acct.c and include/linux/acct.h to kernel/tsacct.c and include/linux/tsacct_kern.h. Signed-off-by: Jay Lan <jlan@sgi.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Chris Sturtivant <csturtiv@sgi.com> Cc: Tony Ernst <tee@sgi.com> Cc: Guillaume Thouvenin <guillaume.thouvenin@bull.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] csa: Extended system accounting over taskstatsJay Lan
Add extended system accounting handling over taskstats interface. A CONFIG_TASK_XACCT flag is created to enable the extended accounting code. Signed-off-by: Jay Lan <jlan@sgi.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Chris Sturtivant <csturtiv@sgi.com> Cc: Tony Ernst <tee@sgi.com> Cc: Guillaume Thouvenin <guillaume.thouvenin@bull.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] csa: basic accounting over taskstatsJay Lan
Add some basic accounting fields to the taskstats struct, add a new kernel/tsacct.c to handle basic accounting data handling upon exit. A handle is added to taskstats.c to invoke the basic accounting data handling. Signed-off-by: Jay Lan <jlan@sgi.com> Cc: Shailabh Nagar <nagar@watson.ibm.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Jes Sorensen <jes@sgi.com> Cc: Chris Sturtivant <csturtiv@sgi.com> Cc: Tony Ernst <tee@sgi.com> Cc: Guillaume Thouvenin <guillaume.thouvenin@bull.net> Cc: "Michal Piotrowski" <michal.k.k.piotrowski@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
