Various SMP balancing algorithms require that the bandwidth period
run in sync.
Possible improvements are moving the rt_bandwidth thing into root_domain
and keeping a span per rt_bandwidth which marks throttled cpus.
Make the rt group scheduler compile time configurable.
Keep it experimental for now.
Change the rt_ratio interface to rt_runtime_us, to match rt_period_us.
This avoids picking a granularity for the ratio.
Extend the /sys/kernel/uids/<uid>/ interface to allow setting
the group's rt_runtime.
Make the user_namespace.o compilation depend on this option and move the
init_user_ns into user.c file to make the kernel compile and work without the
namespaces support. This make the user namespace code be organized similar to
other namespaces'.
Also mask the USER_NS option as "depend on NAMESPACES".
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Cc: Cedric Le Goater <clg@fr.ibm.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Herbert Poetzl <herbert@13thfloor.at>
Cc: Kirill Korotaev <dev@sw.ru>
Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com>
There are already 4 error paths in alloc_uid() that do incremental rollbacks.
I think it's time to merge them. This costs us 8 lines of code :)
Maybe it would be better to merge this patch with the previous one, but I
remember that some time ago I sent a similar patch (fixing the error path and
cleaning it), but I was told to make two patches in such cases.
Acked-by: Dhaval Giani <dhaval@linux.vnet.ibm.com>
This converts the code to use the new kobject functions, cleaning up the
logic in doing so.
Cc: Kay Sievers <kay.sievers@vrfy.org>
kernel_kset does not need to be a kset, but a much simpler kobject now
that we have kobj_attributes.
We also rename kernel_kset to kernel_kobj to catch all users of this
symbol with a build error instead of an easy-to-ignore build warning.
Clean up the use of ksets and kobjects. Kobjects are instances of
objects (like struct user_info), ksets are collections of objects of a
similar type (like the uids directory containing the user_info directories).
So, use kobjects for the user_info directories, and a kset for the "uids"
directory.
On object cleanup, the final kobject_put() was missing.
Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com>
Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Dynamically create the kset instead of declaring it statically. We also
rename kernel_subsys to kernel_kset to catch all users of this symbol
The commit
commit 5cb350baf580017da38199625b7365b1763d7180
Author: Dhaval Giani <dhaval@linux.vnet.ibm.com>
Date: Mon Oct 15 17:00:14 2007 +0200
sched: group scheduling, sysfs tunables
introduced the uids_mutex and the helpers to lock/unlock it.
Unfortunately, the error paths of alloc_uid() were not patched
to unlock it.
cpu_shares_{show,store}() can become static.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched:
sched: fix new task startup crash
sched: fix !SYSFS build breakage
sched: fix improper load balance across sched domain
sched: more robust sd-sysctl entry freeing
For those who deselect POSIX message queues.
Reduces SLAB size of user_struct from 64 to 32 bytes here, SLUB size -- from
40 bytes to 32 bytes.
[akpm@linux-foundation.org: fix build]
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
Save some space because uid_hash_find() has 3 callsites.
When CONFIG_SYSFS is not set, CONFIG_FAIR_USER_SCHED fails to build
with
kernel/built-in.o: In function `uids_kobject_init':
(.init.text+0x1488): undefined reference to `kernel_subsys'
(.init.text+0x1490): undefined reference to `kernel_subsys'
(.init.text+0x1480): undefined reference to `kernel_subsys'
(.init.text+0x1494): undefined reference to `kernel_subsys'
This patch fixes this build error.
Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com>
Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com>
Generate uevents when a user is being created/destroyed. These events
can be used to configure cpu share of a new user.
Add tunables in sysfs to modify a user's cpu share.
A directory is created in sysfs for each new user in the system.
/sys/kernel/uids/<uid>/cpu_share
Reading this file returns the cpu shares granted for the user.
Writing into this file modifies the cpu share for the user. Only an
administrator is allowed to modify a user's cpu share.
Ex:
# cd /sys/kernel/uids/
# cat 512/cpu_share
1024
# echo 2048 > 512/cpu_share
# cat 512/cpu_share
2048
cleanup: rename task_grp to task_group. No need to save two characters
and 'grp' is annoying to read.
Enable user-id based fair group scheduling. This is useful for anyone
who wants to test the group scheduler w/o having to enable
CONFIG_CGROUPS.
A separate scheduling group (i.e struct task_grp) is automatically created for
every new user added to the system. Upon uid change for a task, it is made to
move to the corresponding scheduling group.
A /proc tunable (/proc/root_user_share) is also provided to tune root
user's quota of cpu bandwidth.
It turned out, that the user namespace is released during the do_exit() in
exit_task_namespaces(), but the struct user_struct is released only during the
put_task_struct(), i.e. MUCH later.
On debug kernels with poisoned slabs this will cause the oops in
uid_hash_remove() because the head of the chain, which resides inside the
struct user_namespace, will be already freed and poisoned.
Since the uid hash itself is required only when someone can search it, i.e.
when the namespace is alive, we can safely unhash all the user_struct-s from
it during the namespace exiting. The subsequent free_uid() will complete the
user_struct destruction.
For example simple program
#include <sched.h>
char stack[2 * 1024 * 1024];
int f(void *foo)
return 0;
int main(void)
clone(f, stack + 1 * 1024 * 1024, 0x10000000, 0);
return 0;
run on kernel with CONFIG_USER_NS turned on will oops the
kernel immediately.
This was spotted during OpenVZ kernel testing.
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
Acked-by: "Serge E. Hallyn" <serue@us.ibm.com>
Surprisingly, but (spotted by Alexey Dobriyan) the uid hash still uses
list_heads, thus occupying twice as much place as it could. Convert it to
hlist_heads.
kernel/user.c: Convert list_for_each to list_for_each_entry in
uid_hash_find()
Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com>
Slab destructors were no longer supported after Christoph's
c59def9f222d44bb7e2f0a559f2906191a0862d7 change. They've been
BUGs for both slab and slub, and slob never supported them
either.
This rips out support for the dtor pointer from kmem_cache_create()
completely and fixes up every single callsite in the kernel (there were
about 224, not including the slab allocator definitions themselves,
or the documentation references).
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Basically, it will allow a process to unshare its user_struct table,
resetting at the same time its own user_struct and all the associated
accounting.
A new root user (uid == 0) is added to the user namespace upon creation.
Such root users have full privileges and it seems that theses privileges
should be controlled through some means (process capabilities ?)
The unshare is not included in this patch.
Changes since [try #4]:
- Updated get_user_ns and put_user_ns to accept NULL, and
get_user_ns to return the namespace.
Changes since [try #3]:
- moved struct user_namespace to files user_namespace.{c,h}
Changes since [try #2]:
- removed struct user_namespace* argument from find_user()
Changes since [try #1]:
- added a root_user per user namespace
Signed-off-by: Cedric Le Goater <clg@fr.ibm.com>
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Acked-by: Pavel Emelianov <xemul@openvz.org>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Chris Wright <chrisw@sous-sol.org>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Andrew Morgan <agm@google.com>
Replace all uses of kmem_cache_t with struct kmem_cache.
The patch was generated using the following script:
#!/bin/sh
# Replace one string by another in all the kernel sources.
set -e
for file in `find * -name "*.c" -o -name "*.h"|xargs grep -l $1`; do
quilt add $file
sed -e "1,\$s/$1/$2/g" $file >/tmp/$$
mv /tmp/$$ $file
quilt refresh
done
The script was run like this
sh replace kmem_cache_t "struct kmem_cache"
Signed-off-by: Christoph Lameter <clameter@sgi.com>
SLAB_KERNEL is an alias of GFP_KERNEL.
There's a possible race condition when doing a "switch_uid()" from one
user to another, which could race with another thread doing a signal
allocation and looking at the old thread ->user pointer as it is freed.
This explains an oops reported by Lukasz Trabinski:
http://permalink.gmane.org/gmane.linux.kernel/462241
We fix this by delaying the (reference-counted) freeing of the user
structure until the thread signal handler lock has been released, so
that we know that the signal allocation has either seen the new value or
has properly incremented the reference count of the old one.
Race identified by Oleg Nesterov.
Cc: Lukasz Trabinski <lukasz@wsisiz.edu.pl>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc: Andrew Morton <akpm@osdl.org>
Introduce SELinux hooks to support the access key retention subsystem
within the kernel. Incorporate new flask headers from a modified version
of the SELinux reference policy, with support for the new security class
representing retained keys. Extend the "key_alloc" security hook with a
task parameter representing the intended ownership context for the key
being allocated. Attach security information to root's default keyrings
within the SELinux initialization routine.
Has passed David's testsuite.
Signed-off-by: Michael LeMay <mdlemay@epoch.ncsc.mil>
Signed-off-by: James Morris <jmorris@namei.org>
Acked-by: Chris Wright <chrisw@sous-sol.org>
The following series of patches introduces a kernel API for inotify,
making it possible for kernel modules to benefit from inotify's
mechanism for watching inodes. With these patches, inotify will
maintain for each caller a list of watches (via an embedded struct
inotify_watch), where each inotify_watch is associated with a
corresponding struct inode. The caller registers an event handler and
specifies for which filesystem events their event handler should be
called per inotify_watch.
Signed-off-by: Amy Griffis <amy.griffis@hp.com>
Acked-by: Robert Love <rml@novell.com>
Acked-by: John McCutchan <john@johnmccutchan.com>
Reduce lock hold times in free_uid().
Cc: "Paul E. McKenney" <paulmck@us.ibm.com>
I get storms of warnings from local_bh_enable(). Better-tested patches,
please.
RCU task-struct freeing can call free_uid(), which is taking
uidhash_lock - while other users of uidhash_lock are softirq-unsafe.
The fix is to always take the uidhash_spinlock in a softirq-safe manner.
Acked-by: Paul E. McKenney <paulmck@us.ibm.com>
inotify is intended to correct the deficiencies of dnotify, particularly
its inability to scale and its terrible user interface:
* dnotify requires the opening of one fd per each directory
that you intend to watch. This quickly results in too many
open files and pins removable media, preventing unmount.
* dnotify is directory-based. You only learn about changes to
directories. Sure, a change to a file in a directory affects
the directory, but you are then forced to keep a cache of
stat structures.
* dnotify's interface to user-space is awful. Signals?
inotify provides a more usable, simple, powerful solution to file change
notification:
* inotify's interface is a system call that returns a fd, not SIGIO.
You get a single fd, which is select()-able.
* inotify has an event that says "the filesystem that the item
you were watching is on was unmounted."
* inotify can watch directories or files.
Inotify is currently used by Beagle (a desktop search infrastructure),
Gamin (a FAM replacement), and other projects.
See Documentation/filesystems/inotify.txt.
Signed-off-by: Robert Love <rml@novell.com>
Cc: John McCutchan <ttb@tentacle.dhs.org>
infrastructure for it.
Let it rip!
