Use the local_irq_*_nort variants to reduce latencies in RT. The code
is serialized by the locks. No need to disable interrupts.
The changed files were only including linux/module.h for the
EXPORT_SYMBOL infrastructure, and nothing else. Revector them
onto the isolated export header for faster compile times.
Nothing to see here but a whole lot of instances of:
-#include <linux/module.h>
+#include <linux/export.h>
This commit is only changing the kernel dir; next targets
will probably be mm, fs, the arch dirs, etc.
The expected course of development for user namespaces targeted
capabilities is laid out at https://wiki.ubuntu.com/UserNamespace.
Goals:
- Make it safe for an unprivileged user to unshare namespaces. They
will be privileged with respect to the new namespace, but this should
only include resources which the unprivileged user already owns.
- Provide separate limits and accounting for userids in different
namespaces.
Status:
Currently (as of 2.6.38) you can clone with the CLONE_NEWUSER flag to
get a new user namespace if you have the CAP_SYS_ADMIN, CAP_SETUID, and
CAP_SETGID capabilities. What this gets you is a whole new set of
userids, meaning that user 500 will have a different 'struct user' in
your namespace than in other namespaces. So any accounting information
stored in struct user will be unique to your namespace.
However, throughout the kernel there are checks which
- simply check for a capability. Since root in a child namespace
has all capabilities, this means that a child namespace is not
constrained.
- simply compare uid1 == uid2. Since these are the integer uids,
uid 500 in namespace 1 will be said to be equal to uid 500 in
namespace 2.
As a result, the lxc implementation at lxc.sf.net does not use user
namespaces. This is actually helpful because it leaves us free to
develop user namespaces in such a way that, for some time, user
namespaces may be unuseful.
Bugs aside, this patchset is supposed to not at all affect systems which
are not actively using user namespaces, and only restrict what tasks in
child user namespace can do. They begin to limit privilege to a user
namespace, so that root in a container cannot kill or ptrace tasks in the
parent user namespace, and can only get world access rights to files.
Since all files currently belong to the initila user namespace, that means
that child user namespaces can only get world access rights to *all*
files. While this temporarily makes user namespaces bad for system
containers, it starts to get useful for some sandboxing.
I've run the 'runltplite.sh' with and without this patchset and found no
difference.
This patch:
copy_process() handles CLONE_NEWUSER before the rest of the namespaces.
So in the case of clone(CLONE_NEWUSER|CLONE_NEWUTS) the new uts namespace
will have the new user namespace as its owner. That is what we want,
since we want root in that new userns to be able to have privilege over
it.
Changelog:
Feb 15: don't set uts_ns->user_ns if we didn't create
a new uts_ns.
Feb 23: Move extern init_user_ns declaration from
init/version.c to utsname.h.
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
Acked-by: Daniel Lezcano <daniel.lezcano@free.fr>
When racing on adding into user cache, the new allocated from mm slab
is freed without putting user namespace.
Since the user namespace is already operated by getting, putting has
to be issued.
Signed-off-by: Hillf Danton <dhillf@gmail.com>
Acked-by: Serge Hallyn <serge@hallyn.com>
Cc: stable@kernel.org
free_user() releases uidhash_lock but was missing annotation. Add it.
This removes following sparse warnings:
include/linux/spinlock.h:339:9: warning: context imbalance in 'free_user' - unexpected unlock
kernel/user.c:120:6: warning: context imbalance in 'free_uid' - wrong count at exit
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Cc: Dhaval Giani <dhaval.giani@gmail.com>
This comment should have been removed together with uids_mutex
when removing user sched.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
LKML-Reference: <4BE77C6B.5010402@cn.fujitsu.com>
This is left over from commit 7c9414385e ("sched: Remove USER_SCHED"")
Acked-by: Dhaval Giani <dhaval.giani@gmail.com>
LKML-Reference: <4BA9A05F.7010407@cn.fujitsu.com>
This was left over from "7c9414385e sched: Remove USER_SCHED"
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
LKML-Reference: <20100315082148.GD18181@bicker>
Remove the USER_SCHED feature. It has been scheduled to be removed in
2.6.34 as per http://marc.info/?l=linux-kernel&m=125728479022976&w=2
Signed-off-by: Dhaval Giani <dhaval.giani@gmail.com>
LKML-Reference: <1263990378.24844.3.camel@localhost>
Ingo triggered the following warning:
WARNING: at lib/debugobjects.c:255 debug_print_object+0x42/0x50()
Hardware name: System Product Name
ODEBUG: init active object type: timer_list
Modules linked in:
Pid: 2619, comm: dmesg Tainted: G W 2.6.32-rc5-tip+ #5298
Call Trace:
[<81035443>] warn_slowpath_common+0x6a/0x81
[<8120e483>] ? debug_print_object+0x42/0x50
[<81035498>] warn_slowpath_fmt+0x29/0x2c
[<8120e483>] debug_print_object+0x42/0x50
[<8120ec2a>] __debug_object_init+0x279/0x2d7
[<8120ecb3>] debug_object_init+0x13/0x18
[<810409d2>] init_timer_key+0x17/0x6f
[<81041526>] free_uid+0x50/0x6c
[<8104ed2d>] put_cred_rcu+0x61/0x72
[<81067fac>] rcu_do_batch+0x70/0x121
debugobjects warns about an enqueued timer being initialized. If
CONFIG_USER_SCHED=y the user management code uses delayed work to
remove the user from the hash table and tear down the sysfs objects.
free_uid is called from RCU and initializes/schedules delayed work if
the usage count of the user_struct is 0. The init/schedule happens
outside of the uidhash_lock protected region which allows a concurrent
caller of find_user() to reference the about to be destroyed
user_struct w/o preventing the work from being scheduled. If the next
free_uid call happens before the work timer expired then the active
timer is initialized and the work scheduled again.
The race was introduced in commit 5cb350ba (sched: group scheduling,
sysfs tunables) and made more prominent by commit 3959214f (sched:
delayed cleanup of user_struct)
Move the init/schedule_delayed_work inside of the uidhash_lock
protected region to prevent the race.
Acked-by: Dhaval Giani <dhaval@linux.vnet.ibm.com>
Cc: Paul E. McKenney <paulmck@us.ibm.com>
During bootup performance tracing we see repeated occurrences of
/sys/kernel/uid/* events for the same uid, leading to a,
in this case, rather pointless userspace processing for the
same uid over and over.
This is usually caused by tools which change their uid to "nobody",
to run without privileges to read data supplied by untrusted users.
This change delays the execution of the (already existing) scheduled
work, to cleanup the uid after one second, so the allocated and announced
uid can possibly be re-used by another process.
This is the current behavior, where almost every invocation of a
binary, which changes the uid, creates two events:
$ read START < /sys/kernel/uevent_seqnum; \
for i in `seq 100`; do su --shell=/bin/true bin; done; \
read END < /sys/kernel/uevent_seqnum; \
echo $(($END - $START))
178
With the delayed cleanup, we get only two events, and userspace finishes
a bit faster too:
1
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
We were returning early in the sysfs directory cleanup function if the
user belonged to a non init usernamespace. Due to this a lot of the
cleanup was not done and we were left with a leak. Fix the leak.
Reported-by: Serge Hallyn <serue@linux.vnet.ibm.com>
Signed-off-by: Dhaval Giani <dhaval@linux.vnet.ibm.com>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Tested-by: Serge Hallyn <serue@us.ibm.com>
Impact: fix hung task with certain (non-default) rt-limit settings
Corey Hickey reported that on using setuid to change the uid of a
rt process, the process would be unkillable and not be running.
This is because there was no rt runtime for that user group. Add
in a check to see if a user can attach an rt task to its task group.
On failure, return EINVAL, which is also returned in
CONFIG_CGROUP_SCHED.
Reported-by: Corey Hickey <bugfood-ml@fatooh.org>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
per-uid keys were looked by uid only. Use the user namespace
to distinguish the same uid in different namespaces.
This does not address key_permission. So a task can for instance
try to join a keyring owned by the same uid in another namespace.
That will be handled by a separate patch.
Signed-off-by: Serge E. Hallyn <serue@us.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
uids in namespaces other than init don't get a sysfs entry.
For those in the init namespace, while we're waiting to remove
the sysfs entry for the uid the uid is still hashed, and
alloc_uid() may re-grab that uid without getting a new
reference to the user_ns, which we've already put in free_user
before scheduling remove_user_sysfs_dir().
Reported-and-tested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Tested-by: Ingo Molnar <mingo@elte.hu>
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (31 commits)
sched: fix warning in fs/proc/base.c
schedstat: consolidate per-task cpu runtime stats
sched: use RCU variant of list traversal in for_each_leaf_rt_rq()
sched, cpuacct: export percpu cpuacct cgroup stats
sched, cpuacct: refactoring cpuusage_read / cpuusage_write
sched: optimize update_curr()
sched: fix wakeup preemption clock
sched: add missing arch_update_cpu_topology() call
sched: let arch_update_cpu_topology indicate if topology changed
sched: idle_balance() does not call load_balance_newidle()
sched: fix sd_parent_degenerate on non-numa smp machine
sched: add uid information to sched_debug for CONFIG_USER_SCHED
sched: move double_unlock_balance() higher
sched: update comment for move_task_off_dead_cpu
sched: fix inconsistency when redistribute per-cpu tg->cfs_rq shares
sched/rt: removed unneeded defintion
sched: add hierarchical accounting to cpu accounting controller
sched: include group statistics in /proc/sched_debug
sched: rename SCHED_NO_NO_OMIT_FRAME_POINTER => SCHED_OMIT_FRAME_POINTER
sched: clean up SCHED_CPUMASK_ALLOC
Documented the currently bogus state of support for CFS user groups with
user namespaces. In particular, all users in a user namespace should be
children of the user which created the user namespace. This is yet to
be implemented.
(These two patches are in the next-unacked branch of
git://git.kernel.org/pub/scm/linux/kernel/git/sergeh/userns-2.6.
If they get some ACKs, then I hope to feed this into security-next.
After these two, I think we're ready to tackle userns+capabilities)
Fairsched creates a per-uid directory under /sys/kernel/uids/.
So when you clone(CLONE_NEWUSER), it tries to create
/sys/kernel/uids/0, which already exists, and you get back
-ENOMEM.
This was supposed to be fixed by sysfs tagging, but that
was postponed (ok, rejected until sysfs locking is fixed).
So, just as with network namespaces, we just don't create
those directories for user namespaces other than the init.
Impact: extend information in /proc/sched_debug
This patch adds uid information in sched_debug for CONFIG_USER_SCHED
Signed-off-by: Arun R Bharadwaj <arun@linux.vnet.ibm.com>
Fix up the last current_user()->user_ns instance to use
current_user_ns().
The user_ns is moved from nsproxy to user_struct, so that a struct
cred by itself is sufficient to determine access (which it otherwise
would not be). Corresponding ecryptfs fixes (by David Howells) are
here as well.
Fix refcounting. The following rules now apply:
1. The task pins the user struct.
2. The user struct pins its user namespace.
3. The user namespace pins the struct user which created it.
User namespaces are cloned during copy_creds(). Unsharing a new user_ns
is no longer possible. (We could re-add that, but it'll cause code
duplication and doesn't seem useful if PAM doesn't need to clone user
namespaces).
When a user namespace is created, its first user (uid 0) gets empty
keyrings and a clean group_info.
This incorporates a previous patch by David Howells. Here
is his original patch description:
>I suggest adding the attached incremental patch. It makes the following
>changes:
> (1) Provides a current_user_ns() macro to wrap accesses to current's user
> namespace.
> (2) Fixes eCryptFS.
> (3) Renames create_new_userns() to create_user_ns() to be more consistent
> with the other associated functions and because the 'new' in the name is
> superfluous.
> (4) Moves the argument and permission checks made for CLONE_NEWUSER to the
> beginning of do_fork() so that they're done prior to making any attempts
> at allocation.
> (5) Calls create_user_ns() after prepare_creds(), and gives it the new creds
> to fill in rather than have it return the new root user. I don't imagine
> the new root user being used for anything other than filling in a cred
> struct.
> This also permits me to get rid of a get_uid() and a free_uid(), as the
> reference the creds were holding on the old user_struct can just be
> transferred to the new namespace's creator pointer.
> (6) Makes create_user_ns() reset the UIDs and GIDs of the creds under
> preparation rather than doing it in copy_creds().
>David
>Signed-off-by: David Howells <dhowells@redhat.com>
Changelog:
Oct 20: integrate dhowells comments
1. leave thread_keyring alone
2. use current_user_ns() in set_user()
Signed-off-by: Serge Hallyn <serue@us.ibm.com>
Inaugurate copy-on-write credentials management. This uses RCU to manage the
credentials pointer in the task_struct with respect to accesses by other tasks.
A process may only modify its own credentials, and so does not need locking to
access or modify its own credentials.
A mutex (cred_replace_mutex) is added to the task_struct to control the effect
of PTRACE_ATTACHED on credential calculations, particularly with respect to
execve().
With this patch, the contents of an active credentials struct may not be
changed directly; rather a new set of credentials must be prepared, modified
and committed using something like the following sequence of events:
struct cred *new = prepare_creds();
int ret = blah(new);
if (ret < 0) {
abort_creds(new);
return ret;
return commit_creds(new);
There are some exceptions to this rule: the keyrings pointed to by the active
credentials may be instantiated - keyrings violate the COW rule as managing
COW keyrings is tricky, given that it is possible for a task to directly alter
the keys in a keyring in use by another task.
To help enforce this, various pointers to sets of credentials, such as those in
the task_struct, are declared const. The purpose of this is compile-time
discouragement of altering credentials through those pointers. Once a set of
credentials has been made public through one of these pointers, it may not be
modified, except under special circumstances:
(1) Its reference count may incremented and decremented.
(2) The keyrings to which it points may be modified, but not replaced.
The only safe way to modify anything else is to create a replacement and commit
using the functions described in Documentation/credentials.txt (which will be
added by a later patch).
This patch and the preceding patches have been tested with the LTP SELinux
testsuite.
This patch makes several logical sets of alteration:
(1) execve().
This now prepares and commits credentials in various places in the
security code rather than altering the current creds directly.
(2) Temporary credential overrides.
do_coredump() and sys_faccessat() now prepare their own credentials and
temporarily override the ones currently on the acting thread, whilst
preventing interference from other threads by holding cred_replace_mutex
on the thread being dumped.
This will be replaced in a future patch by something that hands down the
credentials directly to the functions being called, rather than altering
the task's objective credentials.
(3) LSM interface.
A number of functions have been changed, added or removed:
(*) security_capset_check(), ->capset_check()
(*) security_capset_set(), ->capset_set()
Removed in favour of security_capset().
(*) security_capset(), ->capset()
New. This is passed a pointer to the new creds, a pointer to the old
creds and the proposed capability sets. It should fill in the new
creds or return an error. All pointers, barring the pointer to the
new creds, are now const.
(*) security_bprm_apply_creds(), ->bprm_apply_creds()
Changed; now returns a value, which will cause the process to be
killed if it's an error.
(*) security_task_alloc(), ->task_alloc_security()
Removed in favour of security_prepare_creds().
(*) security_cred_free(), ->cred_free()
New. Free security data attached to cred->security.
(*) security_prepare_creds(), ->cred_prepare()
New. Duplicate any security data attached to cred->security.
(*) security_commit_creds(), ->cred_commit()
New. Apply any security effects for the upcoming installation of new
security by commit_creds().
(*) security_task_post_setuid(), ->task_post_setuid()
Removed in favour of security_task_fix_setuid().
(*) security_task_fix_setuid(), ->task_fix_setuid()
Fix up the proposed new credentials for setuid(). This is used by
cap_set_fix_setuid() to implicitly adjust capabilities in line with
setuid() changes. Changes are made to the new credentials, rather
than the task itself as in security_task_post_setuid().
(*) security_task_reparent_to_init(), ->task_reparent_to_init()
Removed. Instead the task being reparented to init is referred
directly to init's credentials.
NOTE! This results in the loss of some state: SELinux's osid no
longer records the sid of the thread that forked it.
(*) security_key_alloc(), ->key_alloc()
(*) security_key_permission(), ->key_permission()
Changed. These now take cred pointers rather than task pointers to
refer to the security context.
(4) sys_capset().
This has been simplified and uses less locking. The LSM functions it
calls have been merged.
(5) reparent_to_kthreadd().
This gives the current thread the same credentials as init by simply using
commit_thread() to point that way.
(6) __sigqueue_alloc() and switch_uid()
__sigqueue_alloc() can't stop the target task from changing its creds
beneath it, so this function gets a reference to the currently applicable
user_struct which it then passes into the sigqueue struct it returns if
successful.
switch_uid() is now called from commit_creds(), and possibly should be
folded into that. commit_creds() should take care of protecting
__sigqueue_alloc().
(7) [sg]et[ug]id() and co and [sg]et_current_groups.
The set functions now all use prepare_creds(), commit_creds() and
abort_creds() to build and check a new set of credentials before applying
it.
security_task_set[ug]id() is called inside the prepared section. This
guarantees that nothing else will affect the creds until we've finished.
The calling of set_dumpable() has been moved into commit_creds().
Much of the functionality of set_user() has been moved into
commit_creds().
The get functions all simply access the data directly.
(8) security_task_prctl() and cap_task_prctl().
security_task_prctl() has been modified to return -ENOSYS if it doesn't
want to handle a function, or otherwise return the return value directly
rather than through an argument.
Additionally, cap_task_prctl() now prepares a new set of credentials, even
if it doesn't end up using it.
(9) Keyrings.
A number of changes have been made to the keyrings code:
(a) switch_uid_keyring(), copy_keys(), exit_keys() and suid_keys() have
all been dropped and built in to the credentials functions directly.
They may want separating out again later.
(b) key_alloc() and search_process_keyrings() now take a cred pointer
rather than a task pointer to specify the security context.
(c) copy_creds() gives a new thread within the same thread group a new
thread keyring if its parent had one, otherwise it discards the thread
keyring.
(d) The authorisation key now points directly to the credentials to extend
the search into rather pointing to the task that carries them.
(e) Installing thread, process or session keyrings causes a new set of
credentials to be created, even though it's not strictly necessary for
process or session keyrings (they're shared).
(10) Usermode helper.
The usermode helper code now carries a cred struct pointer in its
subprocess_info struct instead of a new session keyring pointer. This set
of credentials is derived from init_cred and installed on the new process
after it has been cloned.
call_usermodehelper_setup() allocates the new credentials and
call_usermodehelper_freeinfo() discards them if they haven't been used. A
special cred function (prepare_usermodeinfo_creds()) is provided
specifically for call_usermodehelper_setup() to call.
call_usermodehelper_setkeys() adjusts the credentials to sport the
supplied keyring as the new session keyring.
(11) SELinux.
SELinux has a number of changes, in addition to those to support the LSM
interface changes mentioned above:
(a) selinux_setprocattr() no longer does its check for whether the
current ptracer can access processes with the new SID inside the lock
that covers getting the ptracer's SID. Whilst this lock ensures that
the check is done with the ptracer pinned, the result is only valid
until the lock is released, so there's no point doing it inside the
lock.
(12) is_single_threaded().
This function has been extracted from selinux_setprocattr() and put into
a file of its own in the lib/ directory as join_session_keyring() now
wants to use it too.
The code in SELinux just checked to see whether a task shared mm_structs
with other tasks (CLONE_VM), but that isn't good enough. We really want
to know if they're part of the same thread group (CLONE_THREAD).
(13) nfsd.
The NFS server daemon now has to use the COW credentials to set the
credentials it is going to use. It really needs to pass the credentials
down to the functions it calls, but it can't do that until other patches
in this series have been applied.
Acked-by: James Morris <jmorris@namei.org>
Separate the task security context from task_struct. At this point, the
security data is temporarily embedded in the task_struct with two pointers
pointing to it.
Note that the Alpha arch is altered as it refers to (E)UID and (E)GID in
entry.S via asm-offsets.
With comment fixes Signed-off-by: Marc Dionne <marc.c.dionne@gmail.com>
rt_runtime is a signed value
Use kmem_cache_zalloc(), remove large amounts of initialisation code and
ifdeffery.
Note: this assumes that memset(*atomic_t, 0) correctly initialises the
atomic_t. This is true for all present archtiectures and if it becomes false
for a future architecture then we'll need to make large changes all over the
place anyway.
Don't generate the per-UID user and user session keyrings unless they're
explicitly accessed. This solves a problem during a login process whereby
set*uid() is called before the SELinux PAM module, resulting in the per-UID
keyrings having the wrong security labels.
This also cures the problem of multiple per-UID keyrings sometimes appearing
due to PAM modules (including pam_keyinit) setuiding and causing user_structs
to come into and go out of existence whilst the session keyring pins the user
keyring. This is achieved by first searching for extant per-UID keyrings
before inventing new ones.
The serial bound argument is also dropped from find_keyring_by_name() as it's
not currently made use of (setting it to 0 disables the feature).
Cc: <kwc@citi.umich.edu>
Cc: <arunsr@cse.iitk.ac.in>
Cc: <dwalsh@redhat.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Chris Wright <chrisw@sous-sol.org>
UID grouping doesn't actually have a task_group representing the root of
the task_group tree. Add one.
This patch makes the group scheduler multi hierarchy aware.
[a.p.zijlstra@chello.nl: rt-parts and assorted fixes]
Various SMP balancing algorithms require that the bandwidth period
run in sync.
Possible improvements are moving the rt_bandwidth thing into root_domain
and keeping a span per rt_bandwidth which marks throttled cpus.
Make the rt group scheduler compile time configurable.
Keep it experimental for now.
Change the rt_ratio interface to rt_runtime_us, to match rt_period_us.
This avoids picking a granularity for the ratio.
Extend the /sys/kernel/uids/<uid>/ interface to allow setting
the group's rt_runtime.
Make the user_namespace.o compilation depend on this option and move the
init_user_ns into user.c file to make the kernel compile and work without the
namespaces support. This make the user namespace code be organized similar to
other namespaces'.
Also mask the USER_NS option as "depend on NAMESPACES".
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Cc: Cedric Le Goater <clg@fr.ibm.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Herbert Poetzl <herbert@13thfloor.at>
Cc: Kirill Korotaev <dev@sw.ru>
Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com>
There are already 4 error paths in alloc_uid() that do incremental rollbacks.
I think it's time to merge them. This costs us 8 lines of code :)
Maybe it would be better to merge this patch with the previous one, but I
remember that some time ago I sent a similar patch (fixing the error path and
cleaning it), but I was told to make two patches in such cases.
This converts the code to use the new kobject functions, cleaning up the
logic in doing so.
kernel_kset does not need to be a kset, but a much simpler kobject now
that we have kobj_attributes.
We also rename kernel_kset to kernel_kobj to catch all users of this
symbol with a build error instead of an easy-to-ignore build warning.
Clean up the use of ksets and kobjects. Kobjects are instances of
objects (like struct user_info), ksets are collections of objects of a
similar type (like the uids directory containing the user_info directories).
So, use kobjects for the user_info directories, and a kset for the "uids"
directory.
On object cleanup, the final kobject_put() was missing.
Cc: Dhaval Giani <dhaval@linux.vnet.ibm.com>
Cc: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com>
Dynamically create the kset instead of declaring it statically. We also
rename kernel_subsys to kernel_kset to catch all users of this symbol
The commit
commit 5cb350baf580017da38199625b7365b1763d7180
Author: Dhaval Giani <dhaval@linux.vnet.ibm.com>
Date: Mon Oct 15 17:00:14 2007 +0200
sched: group scheduling, sysfs tunables
introduced the uids_mutex and the helpers to lock/unlock it.
Unfortunately, the error paths of alloc_uid() were not patched
to unlock it.
cpu_shares_{show,store}() can become static.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched:
sched: fix new task startup crash
sched: fix !SYSFS build breakage
sched: fix improper load balance across sched domain
sched: more robust sd-sysctl entry freeing
For those who deselect POSIX message queues.
Reduces SLAB size of user_struct from 64 to 32 bytes here, SLUB size -- from
40 bytes to 32 bytes.
[akpm@linux-foundation.org: fix build]
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
Save some space because uid_hash_find() has 3 callsites.
When CONFIG_SYSFS is not set, CONFIG_FAIR_USER_SCHED fails to build
with
kernel/built-in.o: In function `uids_kobject_init':
(.init.text+0x1488): undefined reference to `kernel_subsys'
(.init.text+0x1490): undefined reference to `kernel_subsys'
(.init.text+0x1480): undefined reference to `kernel_subsys'
(.init.text+0x1494): undefined reference to `kernel_subsys'
This patch fixes this build error.
Signed-off-by: Srivatsa Vaddagiri <vatsa@linux.vnet.ibm.com>
Generate uevents when a user is being created/destroyed. These events
can be used to configure cpu share of a new user.
Add tunables in sysfs to modify a user's cpu share.
A directory is created in sysfs for each new user in the system.
/sys/kernel/uids/<uid>/cpu_share
Reading this file returns the cpu shares granted for the user.
Writing into this file modifies the cpu share for the user. Only an
administrator is allowed to modify a user's cpu share.
Ex:
# cd /sys/kernel/uids/
# cat 512/cpu_share
1024
# echo 2048 > 512/cpu_share
# cat 512/cpu_share
2048
cleanup: rename task_grp to task_group. No need to save two characters
and 'grp' is annoying to read.
Enable user-id based fair group scheduling. This is useful for anyone
who wants to test the group scheduler w/o having to enable
CONFIG_CGROUPS.
A separate scheduling group (i.e struct task_grp) is automatically created for
every new user added to the system. Upon uid change for a task, it is made to
move to the corresponding scheduling group.
A /proc tunable (/proc/root_user_share) is also provided to tune root
user's quota of cpu bandwidth.
It turned out, that the user namespace is released during the do_exit() in
exit_task_namespaces(), but the struct user_struct is released only during the
put_task_struct(), i.e. MUCH later.
On debug kernels with poisoned slabs this will cause the oops in
uid_hash_remove() because the head of the chain, which resides inside the
struct user_namespace, will be already freed and poisoned.
Since the uid hash itself is required only when someone can search it, i.e.
when the namespace is alive, we can safely unhash all the user_struct-s from
it during the namespace exiting. The subsequent free_uid() will complete the
user_struct destruction.
For example simple program
#include <sched.h>
char stack[2 * 1024 * 1024];
int f(void *foo)
return 0;
int main(void)
clone(f, stack + 1 * 1024 * 1024, 0x10000000, 0);
return 0;
run on kernel with CONFIG_USER_NS turned on will oops the
kernel immediately.
This was spotted during OpenVZ kernel testing.
Signed-off-by: Alexey Dobriyan <adobriyan@openvz.org>
Acked-by: "Serge E. Hallyn" <serue@us.ibm.com>
Surprisingly, but (spotted by Alexey Dobriyan) the uid hash still uses
list_heads, thus occupying twice as much place as it could. Convert it to
hlist_heads.
