commit 551423748a4eba55f2eb0fc250d757986471f187 upstream.
The error message 'NMI watchdog failed to create perf event...'
does not make it clear that this is a fatal error for the
watchdog. It also currently prints the error value as a
pointer, rather than extracting the error code with PTR_ERR().
Fix that.
Add a note to the description of the 'nowatchdog' kernel
parameter to associate it with this message.
Reported-by: Cesare Leonardi <celeonar@gmail.com>
Cc: 599368@bugs.debian.org
Cc: 608138@bugs.debian.org
Cc: Don Zickus <dzickus@redhat.com>
LKML-Reference: <1294009362.3167.126.camel@localhost>
During my rewrite, the semantics of touch_nmi_watchdog and
touch_softlockup_watchdog changed enough to break some drivers
(mostly over preemptable regions).
These are cases where long delays on one CPU (due to
print_delay for example) can cause long delays on other
CPUs - so we must 'touch' the nmi_watchdog flag of those
other CPUs as well.
This change brings those touch_*_watchdog() functions back in line
with to how they used to work.
Signed-off-by: Don Zickus <dzickus@redhat.com>
Acked-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: peterz@infradead.org
Cc: fweisbec@gmail.com
LKML-Reference: <1283310009-22168-2-git-send-email-dzickus@redhat.com>
Stephane reported that when the machine locks up, the regular ticks,
which are responsible to resetting the throttle count, stop too.
Hence the NMI watchdog can end up being throttled before it reports on
the locked up state, and we end up being sad..
Cure this by having the watchdog overflow reset its own throttle count.
Reported-by: Stephane Eranian <eranian@google.com>
Tested-by: Stephane Eranian <eranian@google.com>
LKML-Reference: <1282215916.1926.4696.camel@laptop>
Variable on the stack is not initialized to zero, do it
explicitly.
This bug was found by a compiler warning:
kernel/watchdog.c:463: warning: 'result' may be used uninitialized in this function
Signed-off-by: Kulikov Vasiliy <segooon@gmail.com>
Acked-by: Don Zickus <dzickus@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <1278316854-28442-1-git-send-email-segooon@gmail.com>
Just a bunch of conversions as suggested by Frederic W.
__get_cpu_var() provides preemption disabled checks.
Plus it gives more readability as it makes it obvious
we are dealing locally now with these vars.
Cc: Cyrill Gorcunov <gorcunov@gmail.com>
LKML-Reference: <1274133966-18415-2-git-send-email-dzickus@redhat.com>
Combining the softlockup and hardlockup code causes watchdog.c
to build even without the hardlockup detection support.
So if an arch, that has the previous and the new nmi watchdog
implementations cohabiting, wants to know if the generic one
is in use, CONFIG_LOCKUP_DETECTOR is not a reliable check.
We need to use CONFIG_HARDLOCKUP_DETECTOR instead.
Fixes:
kernel/built-in.o: In function `touch_nmi_watchdog':
(.text+0x449bc): multiple definition of `touch_nmi_watchdog'
arch/sparc/kernel/built-in.o:(.text+0x11b28): first defined here
LKML-Reference: <20100514151121.GR15159@redhat.com>
[ use CONFIG_HARDLOCKUP_DETECTOR instead of CONFIG_PERF_EVENTS_NMI]
This new config is deemed to simplify even more the lockup detector
dependencies and can make it easier to bring a smooth sorting
between archs that support the new generic lockup detector and those
that still have their own, especially for those that are in the
middle of this migration.
Instead of checking whether we have CONFIG_LOCKUP_DETECTOR +
CONFIG_PERF_EVENTS_NMI each time an arch wants to know if it needs
to build its own lockup detector, take a shortcut with this new
config. It is enabled only if the hardlockup detection part of
the whole lockup detector is on.
There are modules that rely on it:
ERROR: "touch_softlockup_watchdog" [drivers/video/nvidia/nvidiafb.ko] undefined!
LKML-Reference: <1273713674-8434-1-git-send-regression-fweisbec@gmail.com>
When I combined the nmi_watchdog (hardlockup) and softlockup code, I
also combined the paths the touch_watchdog and touch_nmi_watchdog took.
This may not be the best idea as pointed out by Frederic W., that the
touch_watchdog case probably should not reset the hardlockup count.
Therefore the patch below falls back to the previous idea of keeping
the touch_nmi_watchdog a superset of the touch_watchdog case.
Cc: Eric Paris <eparis@redhat.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
LKML-Reference: <1273266711-18706-9-git-send-email-dzickus@redhat.com>
Just some code cleanup to make touch_softlockup clearer and remove the
softlockup_tick function as it is no longer needed.
Also remove the /proc softlockup_thres call as it has been changed to
watchdog_thres.
LKML-Reference: <1273266711-18706-3-git-send-email-dzickus@redhat.com>
The new nmi_watchdog (which uses the perf event subsystem) is very
similar in structure to the softlockup detector. Using Ingo's
suggestion, I combined the two functionalities into one file:
kernel/watchdog.c.
Now both the nmi_watchdog (or hardlockup detector) and softlockup
detector sit on top of the perf event subsystem, which is run every
60 seconds or so to see if there are any lockups.
To detect hardlockups, cpus not responding to interrupts, I
implemented an hrtimer that runs 5 times for every perf event
overflow event. If that stops counting on a cpu, then the cpu is
most likely in trouble.
To detect softlockups, tasks not yielding to the scheduler, I used the
previous kthread idea that now gets kicked every time the hrtimer fires.
If the kthread isn't being scheduled neither is anyone else and the
warning is printed to the console.
I tested this on x86_64 and both the softlockup and hardlockup paths
work.
V2:
- cleaned up the Kconfig and softlockup combination
- surrounded hardlockup cases with #ifdef CONFIG_PERF_EVENTS_NMI
- seperated out the softlockup case from perf event subsystem
- re-arranged the enabling/disabling nmi watchdog from proc space
- added cpumasks for hardlockup failure cases
- removed fallback to soft events if no PMU exists for hard events
V3:
- comment cleanups
- drop support for older softlockup code
- per_cpu cleanups
- completely remove software clock base hardlockup detector
- use per_cpu masking on hard/soft lockup detection
- #ifdef cleanups
- rename config option NMI_WATCHDOG to LOCKUP_DETECTOR
- documentation additions
V4:
- documentation fixes
- convert per_cpu to __get_cpu_var
- powerpc compile fixes
V5:
- split apart warn flags for hard and soft lockups
TODO:
- figure out how to make an arch-agnostic clock2cycles call
(if possible) to feed into perf events as a sample period
[fweisbec: merged conflict patch]
LKML-Reference: <1273266711-18706-2-git-send-email-dzickus@redhat.com>
