path: root/kernel/workqueue.c
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] fix workqueue oops during cpu offlineNathan Lynch
Use first_cpu(cpu_possible_map) for the single-thread workqueue case. We used to hardcode 0, but that broke on systems where !cpu_possible(0) when workqueue_struct->cpu_workqueue_struct was changed from a static array to alloc_percpu. Commit id bce61dd49d6ba7799be2de17c772e4c701558f14 ("Fix hardcoded cpu=0 in workqueue for per_cpu_ptr() calls") fixed that for Ben's funky sparc64 system, but it regressed my Power5. Offlining cpu 0 oopses upon the next call to queue_work for a single-thread workqueue, because now we try to manipulate per_cpu_ptr(wq->cpu_wq, 1), which is uninitialized. So we need to establish an unchanging "slot" for single-thread workqueues which will have a valid percpu allocation. Since alloc_percpu keys off of cpu_possible_map, which must not change after initialization, make this slot == first_cpu(cpu_possible_map). Signed-off-by: Nathan Lynch <ntl@pobox.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] Unchecked alloc_percpu() return in __create_workqueue()Ben Collins
__create_workqueue() not checking return of alloc_percpu() NULL dereference was possible. Signed-off-by: Ben Collins <bcollins@ubuntu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] add schedule_on_each_cpu()Christoph Lameter
swap migration's isolate_lru_page() currently uses an IPI to notify other processors that the lru caches need to be drained if the page cannot be found on the LRU. The IPI interrupt may interrupt a processor that is just processing lru requests and cause a race condition. This patch introduces a new function run_on_each_cpu() that uses the keventd() to run the LRU draining on each processor. Processors disable preemption when dealing the LRU caches (these are per processor) and thus executing LRU draining from another process is safe. Thanks to Lee Schermerhorn <lee.schermerhorn@hp.com> for finding this race condition. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-28[PATCH] Fix hardcoded cpu=0 in workqueue for per_cpu_ptr() callsBen Collins
Tracked this down on an Ultra Enterprise 3000. It's a 6-way machine. Odd thing about this machine (and it's good for finding bugs like this) is that the CPU id's are not 0 based. For instance, on my machine the CPU's are 6/7/10/11/14/15. This caused some NULL pointer dereference in kernel/workqueue.c because for single_threaded workqueue's, it hardcoded the cpu to 0. I changed the 0's to any_online_cpu(cpu_online_mask), which cpumask.h claims is "First cpu in mask". So this fits the same usage. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] cpu hoptlug: avoid usage of smp_processor_id() in preemptible codeHeiko Carstens
Replace smp_processor_id() with any_online_cpu(cpu_online_map) in order to avoid lots of "BUG: using smp_processor_id() in preemptible [00000001] code:..." messages in case taking a cpu online fails. All the traces start at the last notifier_call_chain(...) in kernel/cpu.c. Since we hold the cpu_control semaphore it shouldn't be any problem to access cpu_online_map. The reason why cpu_up failed is simply that the cpu that was supposed to be taken online wasn't even there. That is because on s390 we never know when a new cpu comes and therefore cpu_possible_map consists of only ones and doesn't reflect reality. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] Use alloc_percpu to allocate workqueues locallyChristoph Lameter
This patch makes the workqueus use alloc_percpu instead of an array. The workqueues are placed on nodes local to each processor. The workqueue structure can grow to a significant size on a system with lots of processors if this patch is not applied. 64 bit architectures with all debugging features enabled and configured for 512 processors will not be able to boot without this patch. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] introduce and use kzallocPekka J Enberg
This patch introduces a kzalloc wrapper and converts kernel/ to use it. It saves a little program text. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] create_workqueue_thread() signedness fixMika Kukkonen
With "-W -Wno-unused -Wno-sign-compare" I get the following compile warning: CC kernel/workqueue.o kernel/workqueue.c: In function `workqueue_cpu_callback': kernel/workqueue.c:504: warning: ordered comparison of pointer with integer zero On error create_workqueue_thread() returns NULL, not negative pointer, so following trivial patch suggests itself. Signed-off-by: Mika Kukkonen <mikukkon@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-10[PATCH] remove name length check in a workqueueJames Bottomley
We have a chek in there to make sure that the name won't overflow task_struct.comm[], but it's triggering for scsi with lots of HBAs, only scsi is using single-threaded workqueues which don't append the "/%d" anyway. All too hard. Just kill the BUG_ON. Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> [ kthread_create() uses vsnprintf() and limits the thing, so no actual overflow can actually happen regardless ] Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] re-export cancel_rearming_delayed_workqueueJames Bottomley
This was unexported by Arjan because we have no current users. However, during a conversion from tasklets to workqueues of the parisc led functions, we ran across a case where this was needed. In particular, the open coded equivalent of cancel_rearming_delayed_workqueue was implemented incorrectly, which is, I think, all the evidence necessary that this is a useful API. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
