path: root/kernel/workqueue.c
2011-07-22Merge branch 'for-3.1' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-3.1' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: separate out drain_workqueue() from destroy_workqueue() workqueue: remove cancel_rearming_delayed_work[queue]()
2011-05-24Merge branch 'for-2.6.40' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: Unify input section names percpu: Avoid extra NOP in percpu_cmpxchg16b_double percpu: Cast away printk format warning percpu: Always align percpu output section to PAGE_SIZE Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
2011-05-20workqueue: separate out drain_workqueue() from destroy_workqueue()Tejun Heo
There are users which want to drain workqueues without destroying it. Separate out drain functionality from destroy_workqueue() into drain_workqueue() and make it accessible to workqueue users. To guarantee forward-progress, only chain queueing is allowed while drain is in progress. If a new work item which isn't chained from the running or pending work items is queued while draining is in progress, WARN_ON_ONCE() is triggered. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: James Bottomley <James.Bottomley@hansenpartnership.com>
2011-04-29workqueue: fix deadlock in worker_maybe_bind_and_lock()Tejun Heo
If a rescuer and stop_machine() bringing down a CPU race with each other, they may deadlock on non-preemptive kernel. The CPU won't accept a new task, so the rescuer can't migrate to the target CPU, while stop_machine() can't proceed because the rescuer is holding one of the CPU retrying migration. GCWQ_DISASSOCIATED is never cleared and worker_maybe_bind_and_lock() retries indefinitely. This problem can be reproduced semi reliably while the system is entering suspend. http://thread.gmane.org/gmane.linux.kernel/1122051 A lot of kudos to Thilo-Alexander for reporting this tricky issue and painstaking testing. stable: This affects all kernels with cmwq, so all kernels since and including v2.6.36 need this fix. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Thilo-Alexander Ginkel <thilo@ginkel.com> Tested-by: Thilo-Alexander Ginkel <thilo@ginkel.com> Cc: stable@kernel.org
2011-03-24percpu: Always align percpu output section to PAGE_SIZETejun Heo
Percpu allocator honors alignment request upto PAGE_SIZE and both the percpu addresses in the percpu address space and the translated kernel addresses should be aligned accordingly. The calculation of the former depends on the alignment of percpu output section in the kernel image. The linker script macros PERCPU_VADDR() and PERCPU() are used to define this output section and the latter takes @align parameter. Several architectures are using @align smaller than PAGE_SIZE breaking percpu memory alignment. This patch removes @align parameter from PERCPU(), renames it to PERCPU_SECTION() and makes it always align to PAGE_SIZE. While at it, add PCPU_SETUP_BUG_ON() checks such that alignment problems are reliably detected and remove percpu alignment comment recently added in workqueue.c as the condition would trigger BUG way before reaching there. For um, this patch raises the alignment of percpu area. As the area is in .init, there shouldn't be any noticeable difference. This problem was discovered by David Howells while debugging boot failure on mn10300. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Mike Frysinger <vapier@gentoo.org> Cc: uclinux-dist-devel@blackfin.uclinux.org Cc: David Howells <dhowells@redhat.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: user-mode-linux-devel@lists.sourceforge.net
2011-03-22kthread: use kthread_create_on_node()Eric Dumazet
ksoftirqd, kworker, migration, and pktgend kthreads can be created with kthread_create_on_node(), to get proper NUMA affinities for their stack and task_struct. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> Reviewed-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Tejun Heo <tj@kernel.org> Cc: Tony Luck <tony.luck@intel.com> Cc: Fenghua Yu <fenghua.yu@intel.com> Cc: David Howells <dhowells@redhat.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-16Merge branch 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix build failure introduced by s/freezeable/freezable/ workqueue: add system_freezeable_wq rds/ib: use system_wq instead of rds_ib_fmr_wq net/9p: replace p9_poll_task with a work net/9p: use system_wq instead of p9_mux_wq xfs: convert to alloc_workqueue() reiserfs: make commit_wq use the default concurrency level ocfs2: use system_wq instead of ocfs2_quota_wq ext4: convert to alloc_workqueue() scsi/scsi_tgt_lib: scsi_tgtd isn't used in memory reclaim path scsi/be2iscsi,qla2xxx: convert to alloc_workqueue() misc/iwmc3200top: use system_wq instead of dedicated workqueues i2o: use alloc_workqueue() instead of create_workqueue() acpi: kacpi*_wq don't need WQ_MEM_RECLAIM fs/aio: aio_wq isn't used in memory reclaim path input/tps6507x-ts: use system_wq instead of dedicated workqueue cpufreq: use system_wq instead of dedicated workqueues wireless/ipw2x00: use system_wq instead of dedicated workqueues arm/omap: use system_wq in mailbox workqueue: use WQ_MEM_RECLAIM instead of WQ_RESCUER
2011-03-08debugobjects: Add hint for better object identificationStanislaw Gruszka
In complex subsystems like mac80211 structures can contain several timers and work structs, so identifying a specific instance from the call trace and object type output of debugobjects can be hard. Allow the subsystems which support debugobjects to provide a hint function. This function returns a pointer to a kernel address (preferrably the objects callback function) which is printed along with the debugobjects type. Add hint methods for timer_list, work_struct and hrtimer. [ tglx: Massaged changelog, made it compile ] Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> LKML-Reference: <20110307085809.GA9334@redhat.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-21workqueue: fix build failure introduced by s/freezeable/freezable/Tejun Heo
wq:fixes-2.6.38 does s/WQ_FREEZEABLE/WQ_FREEZABLE and wq:for-2.6.39 adds new usage of the flag. The combination of the two creates a build failure after merge. Fix it by renaming all freezeables to freezables. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Stephen Rothwell <sfr@canb.auug.org.au>
2011-02-21Merge branch 'master' into for-2.6.39Tejun Heo
2011-02-16workqueue: make sure MAYDAY_INITIAL_TIMEOUT is at least 2 jiffies longTejun Heo
MAYDAY_INITIAL_TIMEOUT is defined as HZ / 100 and depending on configuration may end up 0 or 1. Even when it's 1, depending on when the mayday timer is added in the current jiffy interval, it may expire way before a jiffy has passed. Make sure MAYDAY_INITIAL_TIMEOUT is at least two to guarantee that at least a full jiffy has passed before calling rescuers. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Ray Jui <rjui@broadcom.com> Cc: stable@kernel.org
2011-02-16workqueue, freezer: unify spelling of 'freeze' + 'able' to 'freezable'Tejun Heo
There are two spellings in use for 'freeze' + 'able' - 'freezable' and 'freezeable'. The former is the more prominent one. The latter is mostly used by workqueue and in a few other odd places. Unify the spelling to 'freezable'. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Alex Dubov <oakad@yahoo.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Steven Whitehouse <swhiteho@redhat.com>
2011-02-14workqueue: wake up a worker when a rescuer is leaving a gcwqTejun Heo
After executing the matching works, a rescuer leaves the gcwq whether there are more pending works or not. This may decrease the concurrency level to zero and stall execution until a new work item is queued on the gcwq. Make rescuer wake up a regular worker when it leaves a gcwq if there are more works to execute, so that execution isn't stalled. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Ray Jui <rjui@broadcom.com> Cc: stable@kernel.org
2011-02-09workqueue: add system_freezeable_wqTejun Heo
Add system wide freezeable workqueue. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
2011-01-11workqueue: note the nested NOT_RUNNING test in worker_clr_flags() isn't a noopTejun Heo
The nested NOT_RUNNING test in worker_clr_flags() is slightly misleading in that if NOT_RUNNING were a single flag the nested test would be always %true and thus noop. Add a comment noting that the test isn't a noop. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Hillf Danton <dhillf@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org>
2011-01-11workqueue: relax lockdep annotation on flush_work()Tejun Heo
Currently, the lockdep annotation in flush_work() requires exclusive access on the workqueue the target work is queued on and triggers warning if a work is trying to flush another work on the same workqueue; however, this is no longer true as workqueues can now execute multiple works concurrently. This patch adds lock_map_acquire_read() and make process_one_work() hold read access to the workqueue while executing a work and start_flush_work() check for write access if concurrnecy level is one or the workqueue has a rescuer (as only one execution resource - the rescuer - is guaranteed to be available under memory pressure), and read access if higher. This better represents what's going on and removes spurious lockdep warnings which are triggered by fake dependency chain created through flush_work(). * Peter pointed out that flushing another work from a WQ_MEM_RECLAIM wq breaks forward progress guarantee under memory pressure. Condition check accordingly updated. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: "Rafael J. Wysocki" <rjw@sisk.pl> Tested-by: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Peter Zijlstra <peterz@infradead.org> Cc: stable@kernel.org
2010-12-20workqueue: allow chained queueing during destructionTejun Heo
Currently, destroy_workqueue() makes the workqueue deny all new queueing by setting WQ_DYING and flushes the workqueue once before proceeding with destruction; however, there are cases where work items queue more related work items. Currently, such users need to explicitly flush the workqueue multiple times depending on the possible depth of such chained queueing. This patch updates the queueing path such that a work item can queue further work items on the same workqueue even when WQ_DYING is set. The flush on destruction is automatically retried until the workqueue is empty. This guarantees that the workqueue is empty on destruction while allowing chained queueing. The flush retry logic whines if it takes too many retries to drain the workqueue. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
2010-12-14workqueue: It is likely that WORKER_NOT_RUNNING is trueSteven Rostedt
Running the annotate branch profiler on three boxes, including my main box that runs firefox, evolution, xchat, and is part of the distcc farm, showed this with the likelys in the workqueue code: correct incorrect % Function File Line ------- --------- - -------- ---- ---- 96 996253 99 wq_worker_sleeping workqueue.c 703 96 996247 99 wq_worker_waking_up workqueue.c 677 The likely()s in this case were assuming that WORKER_NOT_RUNNING will most likely be false. But this is not the case. The reason is (and shown by adding trace_printks and testing it) that most of the time WORKER_PREP is set. In worker_thread() we have: worker_clr_flags(worker, WORKER_PREP); [ do work stuff ] worker_set_flags(worker, WORKER_PREP, false); (that 'false' means not to wake up an idle worker) The wq_worker_sleeping() is called from schedule when a worker thread is putting itself to sleep. Which happens most of the time outside of that [ do work stuff ]. The wq_worker_waking_up is called by the wakeup worker code, which is also callod outside that [ do work stuff ]. Thus, the likely and unlikely used by those two functions are actually backwards. Remove the annotation and let gcc figure it out. Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-11-26workqueue: check the allocation of system_unbound_wqHitoshi Mitake
I found a trivial bug on initialization of workqueue. Current init_workqueues doesn't check the result of allocation of system_unbound_wq, this should be checked like other queues. Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-10-26workqueues: s/ON_STACK/ONSTACK/Andrew Morton
Silly though it is, completions and wait_queue_heads use foo_ONSTACK (COMPLETION_INITIALIZER_ONSTACK, DECLARE_COMPLETION_ONSTACK, __WAIT_QUEUE_HEAD_INIT_ONSTACK and DECLARE_WAIT_QUEUE_HEAD_ONSTACK) so I guess workqueues should do the same thing. s/INIT_WORK_ON_STACK/INIT_WORK_ONSTACK/ s/INIT_DELAYED_WORK_ON_STACK/INIT_DELAYED_WORK_ONSTACK/ Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25MN10300: Fix the PERCPU() alignment to allow for workqueuesDavid Howells
In the MN10300 arch, we occasionally see an assertion being tripped in alloc_cwqs() at the following line: /* just in case, make sure it's actually aligned */ ---> BUG_ON(!IS_ALIGNED(wq->cpu_wq.v, align)); return wq->cpu_wq.v ? 0 : -ENOMEM; The values are: wa->cpu_wq.v => 0x902776e0 align => 0x100 and align is calculated by the following: const size_t align = max_t(size_t, 1 << WORK_STRUCT_FLAG_BITS, __alignof__(unsigned long long)); This is because the pointer in question (wq->cpu_wq.v) loses some of its lower bits to control flags, and so the object it points to must be sufficiently aligned to avoid the need to use those bits for pointing to things. Currently, 4 control bits and 4 colour bits are used in normal circumstances, plus a debugging bit if debugging is set. This requires the cpu_workqueue_struct struct to be at least 256 bytes aligned (or 512 bytes aligned with debugging). PERCPU() alignment on MN13000, however, is only 32 bytes as set in vmlinux.lds.S. So we set this to PAGE_SIZE (4096) to match most other arches and stick a comment in alloc_cwqs() for anyone else who triggers the assertion. Reported-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com> Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mark Salter <msalter@redhat.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-19workqueue: remove in_workqueue_context()Tejun Heo
Commit a25909a4 (lockdep: Add an in_workqueue_context() lockdep-based test function) added in_workqueue_context() but there hasn't been any in-kernel user and the lockdep annotation in workqueue is scheduled to change. Remove the unused function. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
2010-10-19workqueue: Clarify that schedule_on_each_cpu is synchronousTejun Heo
The documentation for schedule_on_each_cpu() states that it calls a function on each online CPU from keventd. This can easily be interpreted as an asyncronous call because the description does not mention that flush_work is called. Clarify that it is synchronous. tj: rephrased a bit Signed-off-by: Mel Gorman <mel@csn.ul.ie> Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-10-11workqueue: add and use WQ_MEM_RECLAIM flagTejun Heo
Add WQ_MEM_RECLAIM flag which currently maps to WQ_RESCUER, mark WQ_RESCUER as internal and replace all external WQ_RESCUER usages to WQ_MEM_RECLAIM. This makes the API users express the intent of the workqueue instead of indicating the internal mechanism used to guarantee forward progress. This is also to make it cleaner to add more semantics to WQ_MEM_RECLAIM. For example, if deemed necessary, memory reclaim workqueues can be made highpri. This patch doesn't introduce any functional change. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Steven Whitehouse <swhiteho@redhat.com>
2010-10-11workqueue: fix HIGHPRI handling in keep_working()Tejun Heo
The policy function keep_working() didn't check GCWQ_HIGHPRI_PENDING and could return %false with highpri work pending. This could lead to late execution of a highpri work which was delayed due to @max_active throttling if other works are actively consuming CPU cycles. For example, the following could happen. 1. Work W0 which burns CPU cycles. 2. Two works W1 and W2 are queued to a highpri wq w/ @max_active of 1. 3. W1 starts executing and W2 is put to delayed queue. W0 and W1 are both runnable. 4. W1 finishes which puts W2 to pending queue but keep_working() incorrectly returns %false and the worker goes to sleep. 5. W0 finishes and W2 starts execution. With this patch applied, W2 starts execution as soon as W1 finishes. Signed-off-by: Tejun Heo <tj@kernel.org>
2010-10-05workqueue: add queue_work and activate_work trace pointsTejun Heo
These two tracepoints allow tracking when and how a work is queued and activated. This patch is based on Frederic's patch to add queue_work trace point. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com>
2010-10-05workqueue: prepare for more tracepointsTejun Heo
Define workqueue_work event class and use it for workqueue_execute_end trace point. Also, move trace/events/workqueue.h include downwards such that all struct definitions are visible to it. This is to prepare for more tracepoints and doesn't cause any functional change. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com>
2010-09-19workqueue: implement flush[_delayed]_work_sync()Tejun Heo
Implement flush[_delayed]_work_sync(). These are flush functions which also make sure no CPU is still executing the target work from earlier queueing instances. These are similar to cancel[_delayed]_work_sync() except that the target work item is flushed instead of cancelled. Signed-off-by: Tejun Heo <tj@kernel.org>
2010-09-19workqueue: factor out start_flush_work()Tejun Heo
Factor out start_flush_work() from flush_work(). start_flush_work() has @wait_executing argument which controls whether the barrier is queued only if the work is pending or also if executing. As flush_work() needs to wait for execution too, it uses %true. This commit doesn't cause any behavior difference. start_flush_work() will be used to implement flush_work_sync(). Signed-off-by: Tejun Heo <tj@kernel.org>
2010-09-19workqueue: cleanup flush/cancel functionsTejun Heo
Make the following cleanup changes. * Relocate flush/cancel function prototypes and definitions. * Relocate wait_on_cpu_work() and wait_on_work() before try_to_grab_pending(). These will be used to implement flush_work_sync(). * Make all flush/cancel functions return bool instead of int. * Update wait_on_cpu_work() and wait_on_work() to return %true if they actually waited. * Add / update comments. This patch doesn't cause any functional changes. Signed-off-by: Tejun Heo <tj@kernel.org>
2010-09-13workqueue: add documentationTejun Heo
Update copyright notice and add Documentation/workqueue.txt. Randy Dunlap, Dave Chinner: misc fixes. Signed-off-by: Tejun Heo <tj@kernel.org> Reviewed-By: Florian Mickler <florian@mickler.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Christoph Lameter <cl@linux-foundation.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Dave Chinner <david@fromorbit.com>
2010-09-07Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: use zalloc_cpumask_var() for gcwq->mayday_mask workqueue: fix GCWQ_DISASSOCIATED initialization workqueue: Add a workqueue chapter to the tracepoint docbook workqueue: fix cwq->nr_active underflow workqueue: improve destroy_workqueue() debuggability workqueue: mark lock acquisition on worker_maybe_bind_and_lock() workqueue: annotate lock context change workqueue: free rescuer on destroy_workqueue
2010-08-31workqueue: use zalloc_cpumask_var() for gcwq->mayday_maskTejun Heo
alloc_mayday_mask() was using alloc_cpumask_var() making gcwq->mayday_mask contain garbage after initialization on CONFIG_CPUMASK_OFFSTACK=y configurations. This combined with the previously fixed GCWQ_DISASSOCIATED initialization bug could make rescuers fall into infinite loop trying to bind to an offline cpu. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: CAI Qian <caiqian@redhat.com>
2010-08-31workqueue: fix GCWQ_DISASSOCIATED initializationTejun Heo
init_workqueues() incorrectly marks workqueues for all possible CPUs associated. Combined with mayday_mask initialization bug, this can make rescuers keep trying to bind to an offline gcwq indefinitely. Fix init_workqueues() such that only online CPUs have their gcwqs have GCWQ_DISASSOCIATED cleared. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: CAI Qian <caiqian@redhat.com>
2010-08-25workqueue: fix cwq->nr_active underflowTejun Heo
cwq->nr_active is used to keep track of how many work items are active for the cpu workqueue, where 'active' is defined as either pending on global worklist or executing. This is used to implement the max_active limit and workqueue freezing. If a work item is queued after nr_active has already reached max_active, the work item doesn't increment nr_active and is put on the delayed queue and gets activated later as previous active work items retire. try_to_grab_pending() which is used in the cancellation path unconditionally decremented nr_active whether the work item being cancelled is currently active or delayed, so cancelling a delayed work item makes nr_active underflow. This breaks max_active enforcement and triggers BUG_ON() in destroy_workqueue() later on. This patch fixes this bug by adding a flag WORK_STRUCT_DELAYED, which is set while a work item in on the delayed list and making try_to_grab_pending() decrement nr_active iff the work item is currently active. The addition of the flag enlarges cwq alignment to 256 bytes which is getting a bit too large. It's scheduled to be reduced back to 128 bytes by merging WORK_STRUCT_PENDING and WORK_STRUCT_CWQ in the next devel cycle. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Johannes Berg <johannes@sipsolutions.net>
2010-08-24workqueue: improve destroy_workqueue() debuggabilityTejun Heo
Now that the worklist is global, having works pending after wq destruction can easily lead to oops and destroy_workqueue() have several BUG_ON()s to catch these cases. Unfortunately, BUG_ON() doesn't tell much about how the work became pending after the final flush_workqueue(). This patch adds WQ_DYING which is set before the final flush begins. If a work is requested to be queued on a dying workqueue, WARN_ON_ONCE() is triggered and the request is ignored. This clearly indicates which caller is trying to queue a work on a dying workqueue and keeps the system working in most cases. Locking rule comment is updated such that the 'I' rule includes modifying the field from destruction path. Signed-off-by: Tejun Heo <tj@kernel.org>
2010-08-23workqueue: mark lock acquisition on worker_maybe_bind_and_lock()Namhyung Kim
worker_maybe_bind_and_lock() actually grabs gcwq->lock but was missing proper annotation. Add it. So this patch will remove following sparse warnings: kernel/workqueue.c:1214:13: warning: context imbalance in 'worker_maybe_bind_and_lock' - wrong count at exit arch/x86/include/asm/irqflags.h:44:9: warning: context imbalance in 'worker_rebind_fn' - unexpected unlock kernel/workqueue.c:1991:17: warning: context imbalance in 'rescuer_thread' - unexpected unlock Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-08-23workqueue: annotate lock context changeNamhyung Kim
Some of internal functions called within gcwq->lock context releases and regrabs the lock but were missing proper annotations. Add it. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-08-21workqueue: Add basic tracepoints to track workqueue executionArjan van de Ven
With the introduction of the new unified work queue thread pools, we lost one feature: It's no longer possible to know which worker is causing the CPU to wake out of idle. The result is that PowerTOP now reports a lot of "kworker/a:b" instead of more readable results. This patch adds a pair of tracepoints to the new workqueue code, similar in style to the timer/hrtimer tracepoints. With this pair of tracepoints, the next PowerTOP can correctly report which work item caused the wakeup (and how long it took): Interrupt (43) i915 time 3.51ms wakeups 141 Work ieee80211_iface_work time 0.81ms wakeups 29 Work do_dbs_timer time 0.55ms wakeups 24 Process Xorg time 21.36ms wakeups 4 Timer sched_rt_period_timer time 0.01ms wakeups 1 Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-16workqueue: free rescuer on destroy_workqueueXiaotian Feng
wq->rescuer is not freed when wq is destroyed, leads a memory leak then. This patch also remove a redundant line. Signed-off-by: Xiaotian Feng <dfeng@redhat.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com>
2010-08-09workqueue: workqueue_cpu_callback() should be cpu_notifier instead of ↵Tejun Heo
hotcpu_notifier Commit 6ee0578b (workqueue: mark init_workqueues as early_initcall) made workqueue SMP initialization depend on workqueue_cpu_callback(), which however was registered as hotcpu_notifier() and didn't get called if CONFIG_HOTPLUG_CPU is not set. This made gcwqs on non-boot CPUs not create their initial workers leading to boot failures. Fix it by making it a cpu_notifier. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-and-bisected-by: walt <w41ter@gmail.com> Tested-by: Markus Trippelsdorf <markus@trippelsdorf.de>
2010-08-08workqueue: add missing __percpu markup in kernel/workqueue.cNamhyung Kim
works in schecule_on_each_cpu() is a percpu pointer but was missing __percpu markup. Add it. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-08-07Merge branch 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (55 commits) workqueue: mark init_workqueues() as early_initcall() workqueue: explain for_each_*cwq_cpu() iterators fscache: fix build on !CONFIG_SYSCTL slow-work: kill it gfs2: use workqueue instead of slow-work drm: use workqueue instead of slow-work cifs: use workqueue instead of slow-work fscache: drop references to slow-work fscache: convert operation to use workqueue instead of slow-work fscache: convert object to use workqueue instead of slow-work workqueue: fix how cpu number is stored in work->data workqueue: fix mayday_mask handling on UP workqueue: fix build problem on !CONFIG_SMP workqueue: fix locking in retry path of maybe_create_worker() async: use workqueue for worker pool workqueue: remove WQ_SINGLE_CPU and use WQ_UNBOUND instead workqueue: implement unbound workqueue workqueue: prepare for WQ_UNBOUND implementation libata: take advantage of cmwq and remove concurrency limitations workqueue: fix worker management invocation without pending works ... Fixed up conflicts in fs/cifs/* as per Tejun. Other trivial conflicts in include/linux/workqueue.h, kernel/trace/Kconfig and kernel/workqueue.c
2010-08-01workqueue: mark init_workqueues() as early_initcall()Suresh Siddha
Mark init_workqueues() as early_initcall() and thus it will be initialized before smp bringup. init_workqueues() registers for the hotcpu notifier and thus it should cope with the processors that are brought online after the workqueues are initialized. x86 smp bringup code uses workqueues and uses a workaround for the cold boot process (as the workqueues are initialized post smp_init()). Marking init_workqueues() as early_initcall() will pave the way for cleaning up this code. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org>
2010-08-01workqueue: explain for_each_*cwq_cpu() iteratorsTejun Heo
for_each_*cwq_cpu() are similar to regular CPU iterators except that it also considers the pseudo CPU number used for unbound workqueues. Explain them. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org>
2010-07-22workqueue: fix how cpu number is stored in work->dataTejun Heo
Once a work starts execution, its data contains the cpu number it was on instead of pointing to cwq. This is added by commit 7a22ad75 (workqueue: carry cpu number in work data once execution starts) to reliably determine the work was last on even if the workqueue itself was destroyed inbetween. Whether data points to a cwq or contains a cpu number was distinguished by comparing the value against PAGE_OFFSET. The assumption was that a cpu number should be below PAGE_OFFSET while a pointer to cwq should be above it. However, on architectures which use separate address spaces for user and kernel spaces, this doesn't hold as PAGE_OFFSET is zero. Fix it by using an explicit flag, WORK_STRUCT_CWQ, to mark what the data field contains. If the flag is set, it's pointing to a cwq; otherwise, it contains a cpu number. Reported on s390 and microblaze during linux-next testing. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Sachin Sant <sachinp@in.ibm.com> Reported-by: Michal Simek <michal.simek@petalogix.com> Reported-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Tested-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Tested-by: Michal Simek <monstr@monstr.eu>
2010-07-20workqueue: fix mayday_mask handling on UPTejun Heo
All cpumasks are assumed to have cpu 0 permanently set on UP, so it can't be used to signify whether there's something to be done for the CPU. workqueue was using cpumask to track which CPU requested rescuer assistance and this led rescuer thread to think there always are pending mayday requests on UP, which resulted in infinite busy loops. This patch fixes the problem by introducing mayday_mask_t and associated helpers which wrap cpumask on SMP and emulates its behavior using bitops and unsigned long on UP. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au>
2010-07-20workqueue: fix build problem on !CONFIG_SMPTejun Heo
Commit f3421797 (workqueue: implement unbound workqueue) incorrectly tested CONFIG_SMP as part of a C expression in alloc/free_cwqs(). As CONFIG_SMP is not defined in UP, this breaks build. Fix it by using Found during linux-next build test. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Stephen Rothwell <sfr@canb.auug.org.au>
2010-07-14workqueue: fix locking in retry path of maybe_create_worker()Tejun Heo
maybe_create_worker() mismanaged locking when worker creation fails and it has to retry. Fix locking and simplify lock manipulation. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Yong Zhang <yong.zhang@windriver.com>
2010-07-02workqueue: remove WQ_SINGLE_CPU and use WQ_UNBOUND insteadTejun Heo
WQ_SINGLE_CPU combined with @max_active of 1 is used to achieve full ordering among works queued to a workqueue. The same can be achieved using WQ_UNBOUND as unbound workqueues always use the gcwq for WORK_CPU_UNBOUND. As @max_active is always one and benefits from cpu locality isn't accessible anyway, serving them with unbound workqueues should be fine. Drop WQ_SINGLE_CPU support and use WQ_UNBOUND instead. Note that most single thread workqueue users will be converted to use multithread or non-reentrant instead and only the ones which require strict ordering will keep using WQ_UNBOUND + @max_active of 1. Signed-off-by: Tejun Heo <tj@kernel.org>
