active
commit 544ecf310f0e7f51fa057ac2a295fc1b3b35a9d3 upstream.
worker_enter_idle() has WARN_ON_ONCE() which triggers if nr_running
isn't zero when every worker is idle. This can trigger spuriously
while a cpu is going down due to the way trustee sets %WORKER_ROGUE
and zaps nr_running.
It first sets %WORKER_ROGUE on all workers without updating
nr_running, releases gcwq->lock, schedules, regrabs gcwq->lock and
then zaps nr_running. If the last running worker enters idle
inbetween, it would see stale nr_running which hasn't been zapped yet
and trigger the WARN_ON_ONCE().
Fix it by performing the sanity check iff the trustee is idle.
Reported-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
commit 62d3c5439c534b0e6c653fc63e6d8c67be3a57b1 upstream.
This patch (as1519) fixes a bug in the block layer's disk-events
polling. The polling is done by a work routine queued on the
system_nrt_wq workqueue. Since that workqueue isn't freezable, the
polling continues even in the middle of a system sleep transition.
Obviously, polling a suspended drive for media changes and such isn't
a good thing to do; in the case of USB mass-storage devices it can
lead to real problems requiring device resets and even re-enumeration.
The patch fixes things by creating a new system-wide, non-reentrant,
freezable workqueue and using it for disk-events polling.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
commit fa2563e41c3d6d6e8af437643981ed28ae0cb56d upstream.
Take cwq->gcwq->lock to avoid racing between drain_workqueue checking to
make sure the workqueues are empty and cwq_dec_nr_in_flight decrementing
and then incrementing nr_active when it activates a delayed work.
We discovered this when a corner case in one of our drivers resulted in
us trying to destroy a workqueue in which the remaining work would
always requeue itself again in the same workqueue. We would hit this
race condition and trip the BUG_ON on workqueue.c:3080.
Signed-off-by: Thomas Tuttle <ttuttle@chromium.org>
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu
* 'for-2.6.40' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu:
percpu: Unify input section names
percpu: Avoid extra NOP in percpu_cmpxchg16b_double
percpu: Cast away printk format warning
percpu: Always align percpu output section to PAGE_SIZE
Fix up fairly trivial conflict in arch/x86/include/asm/percpu.h as per Tejun
If a rescuer and stop_machine() bringing down a CPU race with each
other, they may deadlock on non-preemptive kernel. The CPU won't
accept a new task, so the rescuer can't migrate to the target CPU,
while stop_machine() can't proceed because the rescuer is holding one
of the CPU retrying migration. GCWQ_DISASSOCIATED is never cleared
and worker_maybe_bind_and_lock() retries indefinitely.
This problem can be reproduced semi reliably while the system is
entering suspend.
http://thread.gmane.org/gmane.linux.kernel/1122051
A lot of kudos to Thilo-Alexander for reporting this tricky issue and
painstaking testing.
stable: This affects all kernels with cmwq, so all kernels since and
including v2.6.36 need this fix.
Reported-by: Thilo-Alexander Ginkel <thilo@ginkel.com>
Tested-by: Thilo-Alexander Ginkel <thilo@ginkel.com>
Cc: stable@kernel.org
Percpu allocator honors alignment request upto PAGE_SIZE and both the
percpu addresses in the percpu address space and the translated kernel
addresses should be aligned accordingly. The calculation of the
former depends on the alignment of percpu output section in the kernel
image.
The linker script macros PERCPU_VADDR() and PERCPU() are used to
define this output section and the latter takes @align parameter.
Several architectures are using @align smaller than PAGE_SIZE breaking
percpu memory alignment.
This patch removes @align parameter from PERCPU(), renames it to
PERCPU_SECTION() and makes it always align to PAGE_SIZE. While at it,
add PCPU_SETUP_BUG_ON() checks such that alignment problems are
reliably detected and remove percpu alignment comment recently added
in workqueue.c as the condition would trigger BUG way before reaching
there.
For um, this patch raises the alignment of percpu area. As the area
is in .init, there shouldn't be any noticeable difference.
This problem was discovered by David Howells while debugging boot
failure on mn10300.
Cc: uclinux-dist-devel@blackfin.uclinux.org
Cc: Jeff Dike <jdike@addtoit.com>
Cc: user-mode-linux-devel@lists.sourceforge.net
ksoftirqd, kworker, migration, and pktgend kthreads can be created with
kthread_create_on_node(), to get proper NUMA affinities for their stack and
task_struct.
Reviewed-by: Andi Kleen <ak@linux.intel.com>
Acked-by: Rusty Russell <rusty@rustcorp.com.au>
Cc: <linux-arch@vger.kernel.org>
* 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: fix build failure introduced by s/freezeable/freezable/
workqueue: add system_freezeable_wq
rds/ib: use system_wq instead of rds_ib_fmr_wq
net/9p: replace p9_poll_task with a work
net/9p: use system_wq instead of p9_mux_wq
xfs: convert to alloc_workqueue()
reiserfs: make commit_wq use the default concurrency level
ocfs2: use system_wq instead of ocfs2_quota_wq
ext4: convert to alloc_workqueue()
scsi/scsi_tgt_lib: scsi_tgtd isn't used in memory reclaim path
scsi/be2iscsi,qla2xxx: convert to alloc_workqueue()
misc/iwmc3200top: use system_wq instead of dedicated workqueues
i2o: use alloc_workqueue() instead of create_workqueue()
acpi: kacpi*_wq don't need WQ_MEM_RECLAIM
fs/aio: aio_wq isn't used in memory reclaim path
input/tps6507x-ts: use system_wq instead of dedicated workqueue
cpufreq: use system_wq instead of dedicated workqueues
wireless/ipw2x00: use system_wq instead of dedicated workqueues
arm/omap: use system_wq in mailbox
workqueue: use WQ_MEM_RECLAIM instead of WQ_RESCUER
In complex subsystems like mac80211 structures can contain several
timers and work structs, so identifying a specific instance from the
call trace and object type output of debugobjects can be hard.
Allow the subsystems which support debugobjects to provide a hint
function. This function returns a pointer to a kernel address
(preferrably the objects callback function) which is printed along
with the debugobjects type.
Add hint methods for timer_list, work_struct and hrtimer.
[ tglx: Massaged changelog, made it compile ]
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
LKML-Reference: <20110307085809.GA9334@redhat.com>
wq:fixes-2.6.38 does s/WQ_FREEZEABLE/WQ_FREEZABLE and wq:for-2.6.39
adds new usage of the flag. The combination of the two creates a
build failure after merge. Fix it by renaming all freezeables to
freezables.
MAYDAY_INITIAL_TIMEOUT is defined as HZ / 100 and depending on
configuration may end up 0 or 1. Even when it's 1, depending on when
the mayday timer is added in the current jiffy interval, it may expire
way before a jiffy has passed.
Make sure MAYDAY_INITIAL_TIMEOUT is at least two to guarantee that at
least a full jiffy has passed before calling rescuers.
Reported-by: Ray Jui <rjui@broadcom.com>
There are two spellings in use for 'freeze' + 'able' - 'freezable' and
'freezeable'. The former is the more prominent one. The latter is
mostly used by workqueue and in a few other odd places. Unify the
spelling to 'freezable'.
Reported-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Cc: Alex Dubov <oakad@yahoo.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
After executing the matching works, a rescuer leaves the gcwq whether
there are more pending works or not. This may decrease the
concurrency level to zero and stall execution until a new work item is
queued on the gcwq.
Make rescuer wake up a regular worker when it leaves a gcwq if there
are more works to execute, so that execution isn't stalled.
Add system wide freezeable workqueue.
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
The nested NOT_RUNNING test in worker_clr_flags() is slightly
misleading in that if NOT_RUNNING were a single flag the nested test
would be always %true and thus noop. Add a comment noting that the
test isn't a noop.
Cc: Hillf Danton <dhillf@gmail.com>
Currently, the lockdep annotation in flush_work() requires exclusive
access on the workqueue the target work is queued on and triggers
warning if a work is trying to flush another work on the same
workqueue; however, this is no longer true as workqueues can now
execute multiple works concurrently.
This patch adds lock_map_acquire_read() and make process_one_work()
hold read access to the workqueue while executing a work and
start_flush_work() check for write access if concurrnecy level is one
or the workqueue has a rescuer (as only one execution resource - the
rescuer - is guaranteed to be available under memory pressure), and
read access if higher.
This better represents what's going on and removes spurious lockdep
warnings which are triggered by fake dependency chain created through
flush_work().
* Peter pointed out that flushing another work from a WQ_MEM_RECLAIM
wq breaks forward progress guarantee under memory pressure.
Condition check accordingly updated.
Reported-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Tested-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Currently, destroy_workqueue() makes the workqueue deny all new
queueing by setting WQ_DYING and flushes the workqueue once before
proceeding with destruction; however, there are cases where work items
queue more related work items. Currently, such users need to
explicitly flush the workqueue multiple times depending on the
possible depth of such chained queueing.
This patch updates the queueing path such that a work item can queue
further work items on the same workqueue even when WQ_DYING is set.
The flush on destruction is automatically retried until the workqueue
is empty. This guarantees that the workqueue is empty on destruction
while allowing chained queueing.
The flush retry logic whines if it takes too many retries to drain the
workqueue.
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Running the annotate branch profiler on three boxes, including my
main box that runs firefox, evolution, xchat, and is part of the distcc farm,
showed this with the likelys in the workqueue code:
correct incorrect % Function File Line
96 996253 99 wq_worker_sleeping workqueue.c 703
96 996247 99 wq_worker_waking_up workqueue.c 677
The likely()s in this case were assuming that WORKER_NOT_RUNNING will
most likely be false. But this is not the case. The reason is
(and shown by adding trace_printks and testing it) that most of the time
WORKER_PREP is set.
In worker_thread() we have:
worker_clr_flags(worker, WORKER_PREP);
[ do work stuff ]
worker_set_flags(worker, WORKER_PREP, false);
(that 'false' means not to wake up an idle worker)
The wq_worker_sleeping() is called from schedule when a worker thread
is putting itself to sleep. Which happens most of the time outside
of that [ do work stuff ].
The wq_worker_waking_up is called by the wakeup worker code, which
is also callod outside that [ do work stuff ].
Thus, the likely and unlikely used by those two functions are actually
backwards.
Remove the annotation and let gcc figure it out.
I found a trivial bug on initialization of workqueue.
Current init_workqueues doesn't check the result of
allocation of system_unbound_wq, this should be checked
like other queues.
Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Silly though it is, completions and wait_queue_heads use foo_ONSTACK
(COMPLETION_INITIALIZER_ONSTACK, DECLARE_COMPLETION_ONSTACK,
__WAIT_QUEUE_HEAD_INIT_ONSTACK and DECLARE_WAIT_QUEUE_HEAD_ONSTACK) so I
guess workqueues should do the same thing.
s/INIT_WORK_ON_STACK/INIT_WORK_ONSTACK/
s/INIT_DELAYED_WORK_ON_STACK/INIT_DELAYED_WORK_ONSTACK/
In the MN10300 arch, we occasionally see an assertion being tripped in
alloc_cwqs() at the following line:
/* just in case, make sure it's actually aligned */
---> BUG_ON(!IS_ALIGNED(wq->cpu_wq.v, align));
return wq->cpu_wq.v ? 0 : -ENOMEM;
The values are:
wa->cpu_wq.v => 0x902776e0
align => 0x100
and align is calculated by the following:
const size_t align = max_t(size_t, 1 << WORK_STRUCT_FLAG_BITS,
__alignof__(unsigned long long));
This is because the pointer in question (wq->cpu_wq.v) loses some of its
lower bits to control flags, and so the object it points to must be
sufficiently aligned to avoid the need to use those bits for pointing to
things.
Currently, 4 control bits and 4 colour bits are used in normal
circumstances, plus a debugging bit if debugging is set. This requires
the cpu_workqueue_struct struct to be at least 256 bytes aligned (or 512
bytes aligned with debugging).
PERCPU() alignment on MN13000, however, is only 32 bytes as set in
vmlinux.lds.S. So we set this to PAGE_SIZE (4096) to match most other
arches and stick a comment in alloc_cwqs() for anyone else who triggers
the assertion.
Reported-by: Akira Takeuchi <takeuchi.akr@jp.panasonic.com>
Acked-by: Mark Salter <msalter@redhat.com>
Cc: Tejun Heo <tj@kernel.org>
Commit a25909a4 (lockdep: Add an in_workqueue_context() lockdep-based
test function) added in_workqueue_context() but there hasn't been any
in-kernel user and the lockdep annotation in workqueue is scheduled to
change. Remove the unused function.
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
The documentation for schedule_on_each_cpu() states that it calls a
function on each online CPU from keventd. This can easily be
interpreted as an asyncronous call because the description does not
mention that flush_work is called. Clarify that it is synchronous.
tj: rephrased a bit
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Add WQ_MEM_RECLAIM flag which currently maps to WQ_RESCUER, mark
WQ_RESCUER as internal and replace all external WQ_RESCUER usages to
WQ_MEM_RECLAIM.
This makes the API users express the intent of the workqueue instead
of indicating the internal mechanism used to guarantee forward
progress. This is also to make it cleaner to add more semantics to
WQ_MEM_RECLAIM. For example, if deemed necessary, memory reclaim
workqueues can be made highpri.
This patch doesn't introduce any functional change.
Cc: Jeff Garzik <jgarzik@pobox.com>
The policy function keep_working() didn't check GCWQ_HIGHPRI_PENDING
and could return %false with highpri work pending. This could lead to
late execution of a highpri work which was delayed due to @max_active
throttling if other works are actively consuming CPU cycles.
For example, the following could happen.
1. Work W0 which burns CPU cycles.
2. Two works W1 and W2 are queued to a highpri wq w/ @max_active of 1.
3. W1 starts executing and W2 is put to delayed queue. W0 and W1 are
both runnable.
4. W1 finishes which puts W2 to pending queue but keep_working()
incorrectly returns %false and the worker goes to sleep.
5. W0 finishes and W2 starts execution.
With this patch applied, W2 starts execution as soon as W1 finishes.
These two tracepoints allow tracking when and how a work is queued and
activated. This patch is based on Frederic's patch to add queue_work
trace point.
Define workqueue_work event class and use it for workqueue_execute_end
trace point. Also, move trace/events/workqueue.h include downwards
such that all struct definitions are visible to it. This is to
prepare for more tracepoints and doesn't cause any functional change.
Implement flush[_delayed]_work_sync(). These are flush functions
which also make sure no CPU is still executing the target work from
earlier queueing instances. These are similar to
cancel[_delayed]_work_sync() except that the target work item is
flushed instead of cancelled.
Factor out start_flush_work() from flush_work(). start_flush_work()
has @wait_executing argument which controls whether the barrier is
queued only if the work is pending or also if executing. As
flush_work() needs to wait for execution too, it uses %true.
This commit doesn't cause any behavior difference. start_flush_work()
will be used to implement flush_work_sync().
Make the following cleanup changes.
* Relocate flush/cancel function prototypes and definitions.
* Relocate wait_on_cpu_work() and wait_on_work() before
try_to_grab_pending(). These will be used to implement
flush_work_sync().
* Make all flush/cancel functions return bool instead of int.
* Update wait_on_cpu_work() and wait_on_work() to return %true if they
actually waited.
* Add / update comments.
This patch doesn't cause any functional changes.
Update copyright notice and add Documentation/workqueue.txt.
Randy Dunlap, Dave Chinner: misc fixes.
Reviewed-By: Florian Mickler <florian@mickler.org>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq:
workqueue: use zalloc_cpumask_var() for gcwq->mayday_mask
workqueue: fix GCWQ_DISASSOCIATED initialization
workqueue: Add a workqueue chapter to the tracepoint docbook
workqueue: fix cwq->nr_active underflow
workqueue: improve destroy_workqueue() debuggability
workqueue: mark lock acquisition on worker_maybe_bind_and_lock()
workqueue: annotate lock context change
workqueue: free rescuer on destroy_workqueue
alloc_mayday_mask() was using alloc_cpumask_var() making
gcwq->mayday_mask contain garbage after initialization on
CONFIG_CPUMASK_OFFSTACK=y configurations. This combined with the
previously fixed GCWQ_DISASSOCIATED initialization bug could make
rescuers fall into infinite loop trying to bind to an offline cpu.
Reported-by: CAI Qian <caiqian@redhat.com>
init_workqueues() incorrectly marks workqueues for all possible CPUs
associated. Combined with mayday_mask initialization bug, this can
make rescuers keep trying to bind to an offline gcwq indefinitely.
Fix init_workqueues() such that only online CPUs have their gcwqs have
GCWQ_DISASSOCIATED cleared.
cwq->nr_active is used to keep track of how many work items are active
for the cpu workqueue, where 'active' is defined as either pending on
global worklist or executing. This is used to implement the
max_active limit and workqueue freezing. If a work item is queued
after nr_active has already reached max_active, the work item doesn't
increment nr_active and is put on the delayed queue and gets activated
later as previous active work items retire.
try_to_grab_pending() which is used in the cancellation path
unconditionally decremented nr_active whether the work item being
cancelled is currently active or delayed, so cancelling a delayed work
item makes nr_active underflow. This breaks max_active enforcement
and triggers BUG_ON() in destroy_workqueue() later on.
This patch fixes this bug by adding a flag WORK_STRUCT_DELAYED, which
is set while a work item in on the delayed list and making
try_to_grab_pending() decrement nr_active iff the work item is
currently active.
The addition of the flag enlarges cwq alignment to 256 bytes which is
getting a bit too large. It's scheduled to be reduced back to 128
bytes by merging WORK_STRUCT_PENDING and WORK_STRUCT_CWQ in the next
devel cycle.
Reported-by: Johannes Berg <johannes@sipsolutions.net>
Now that the worklist is global, having works pending after wq
destruction can easily lead to oops and destroy_workqueue() have
several BUG_ON()s to catch these cases. Unfortunately, BUG_ON()
doesn't tell much about how the work became pending after the final
flush_workqueue().
This patch adds WQ_DYING which is set before the final flush begins.
If a work is requested to be queued on a dying workqueue,
WARN_ON_ONCE() is triggered and the request is ignored. This clearly
indicates which caller is trying to queue a work on a dying workqueue
and keeps the system working in most cases.
Locking rule comment is updated such that the 'I' rule includes
modifying the field from destruction path.
worker_maybe_bind_and_lock() actually grabs gcwq->lock but was missing proper
annotation. Add it. So this patch will remove following sparse warnings:
kernel/workqueue.c:1214:13: warning: context imbalance in 'worker_maybe_bind_and_lock' - wrong count at exit
arch/x86/include/asm/irqflags.h:44:9: warning: context imbalance in 'worker_rebind_fn' - unexpected unlock
kernel/workqueue.c:1991:17: warning: context imbalance in 'rescuer_thread' - unexpected unlock
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Some of internal functions called within gcwq->lock context releases and
regrabs the lock but were missing proper annotations. Add it.
With the introduction of the new unified work queue thread pools,
we lost one feature: It's no longer possible to know which worker
is causing the CPU to wake out of idle. The result is that PowerTOP
now reports a lot of "kworker/a:b" instead of more readable results.
This patch adds a pair of tracepoints to the new workqueue code,
similar in style to the timer/hrtimer tracepoints.
With this pair of tracepoints, the next PowerTOP can correctly
report which work item caused the wakeup (and how long it took):
Interrupt (43) i915 time 3.51ms wakeups 141
Work ieee80211_iface_work time 0.81ms wakeups 29
Work do_dbs_timer time 0.55ms wakeups 24
Process Xorg time 21.36ms wakeups 4
Timer sched_rt_period_timer time 0.01ms wakeups 1
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
wq->rescuer is not freed when wq is destroyed, leads a memory leak
then. This patch also remove a redundant line.
Signed-off-by: Xiaotian Feng <dfeng@redhat.com>
hotcpu_notifier
Commit 6ee0578b (workqueue: mark init_workqueues as early_initcall)
made workqueue SMP initialization depend on workqueue_cpu_callback(),
which however was registered as hotcpu_notifier() and didn't get
called if CONFIG_HOTPLUG_CPU is not set. This made gcwqs on non-boot
CPUs not create their initial workers leading to boot failures. Fix
it by making it a cpu_notifier.
Reported-and-bisected-by: walt <w41ter@gmail.com>
Tested-by: Markus Trippelsdorf <markus@trippelsdorf.de>
works in schecule_on_each_cpu() is a percpu pointer but was missing
__percpu markup. Add it.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: (55 commits)
workqueue: mark init_workqueues() as early_initcall()
workqueue: explain for_each_*cwq_cpu() iterators
fscache: fix build on !CONFIG_SYSCTL
slow-work: kill it
gfs2: use workqueue instead of slow-work
drm: use workqueue instead of slow-work
cifs: use workqueue instead of slow-work
fscache: drop references to slow-work
fscache: convert operation to use workqueue instead of slow-work
fscache: convert object to use workqueue instead of slow-work
workqueue: fix how cpu number is stored in work->data
workqueue: fix mayday_mask handling on UP
workqueue: fix build problem on !CONFIG_SMP
workqueue: fix locking in retry path of maybe_create_worker()
async: use workqueue for worker pool
workqueue: remove WQ_SINGLE_CPU and use WQ_UNBOUND instead
workqueue: implement unbound workqueue
workqueue: prepare for WQ_UNBOUND implementation
libata: take advantage of cmwq and remove concurrency limitations
workqueue: fix worker management invocation without pending works
Fixed up conflicts in fs/cifs/* as per Tejun. Other trivial conflicts in
include/linux/workqueue.h, kernel/trace/Kconfig and kernel/workqueue.c
Mark init_workqueues() as early_initcall() and thus it will be initialized
before smp bringup. init_workqueues() registers for the hotcpu notifier
and thus it should cope with the processors that are brought online after
the workqueues are initialized.
x86 smp bringup code uses workqueues and uses a workaround for the
cold boot process (as the workqueues are initialized post smp_init()).
Marking init_workqueues() as early_initcall() will pave the way for
cleaning up this code.
Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com>
for_each_*cwq_cpu() are similar to regular CPU iterators except that
it also considers the pseudo CPU number used for unbound workqueues.
Explain them.
Once a work starts execution, its data contains the cpu number it was
on instead of pointing to cwq. This is added by commit 7a22ad75
(workqueue: carry cpu number in work data once execution starts) to
reliably determine the work was last on even if the workqueue itself
was destroyed inbetween.
Whether data points to a cwq or contains a cpu number was
distinguished by comparing the value against PAGE_OFFSET. The
assumption was that a cpu number should be below PAGE_OFFSET while a
pointer to cwq should be above it. However, on architectures which
use separate address spaces for user and kernel spaces, this doesn't
hold as PAGE_OFFSET is zero.
Fix it by using an explicit flag, WORK_STRUCT_CWQ, to mark what the
data field contains. If the flag is set, it's pointing to a cwq;
otherwise, it contains a cpu number.
Reported on s390 and microblaze during linux-next testing.
Reported-by: Sachin Sant <sachinp@in.ibm.com>
Reported-by: Michal Simek <michal.simek@petalogix.com>
Reported-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Tested-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Tested-by: Michal Simek <monstr@monstr.eu>
All cpumasks are assumed to have cpu 0 permanently set on UP, so it
can't be used to signify whether there's something to be done for the
CPU. workqueue was using cpumask to track which CPU requested rescuer
assistance and this led rescuer thread to think there always are
pending mayday requests on UP, which resulted in infinite busy loops.
This patch fixes the problem by introducing mayday_mask_t and
associated helpers which wrap cpumask on SMP and emulates its behavior
using bitops and unsigned long on UP.
Commit f3421797 (workqueue: implement unbound workqueue) incorrectly
tested CONFIG_SMP as part of a C expression in alloc/free_cwqs(). As
CONFIG_SMP is not defined in UP, this breaks build. Fix it by using
Found during linux-next build test.
maybe_create_worker() mismanaged locking when worker creation fails
and it has to retry. Fix locking and simplify lock manipulation.
Reported-by: Yong Zhang <yong.zhang@windriver.com>
