path: root/kernel
2011-03-29genirq: Remove move_*irq leftoversThomas Gleixner
All users converted to new interface. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29genirq: Remove compat codeThomas Gleixner
2011-03-29alpha: Use generic show_interrupts()Thomas Gleixner
The only subtle difference is that alpha uses ACTUAL_NR_IRQS and prints the IRQF_DISABLED flag. Change the generic implementation to deal with ACTUAL_NR_IRQS if defined. The IRQF_DISABLED printing is pointless, as we nowadays run all interrupts with irqs disabled. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-29genirq: Fix harmless typoThomas Gleixner
The late night fixup missed to convert the data type from irq_desc to irq_data, which results in a harmless but annoying warning. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-28Merge branches 'irq-cleanup-for-linus' and 'irq-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: vlynq: Convert irq functions * 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq; Fix cleanup fallout genirq: Fix typo and remove unused variable genirq: Fix new kernel-doc warnings genirq: Add setter for AFFINITY_SET in irq_data state genirq: Provide setter inline for IRQD_IRQ_INPROGRESS genirq: Remove handle_IRQ_event arm: Ns9xxx: Remove private irq flow handler powerpc: cell: Use the core flow handler genirq: Provide edge_eoi flow handler genirq: Move INPROGRESS, MASKED and DISABLED state flags to irq_data genirq: Split irq_set_affinity() so it can be called with lock held. genirq: Add chip flag for restricting cpu_on/offline calls genirq: Add chip hooks for taking CPUs on/off line. genirq: Add irq disabled flag to irq_data state genirq: Reserve the irq when calling irq_set_chip()
2011-03-29genirq; Fix cleanup falloutThomas Gleixner
I missed the CONFIG_GENERIC_PENDING_IRQ dependency in the affinity related functions and the IRQ_LEVEL propagation into irq_data state. Did not pop up on my main test platforms. :( Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Tested-by: David Daney <ddaney@caviumnetworks.com>
2011-03-28Relax si_code check in rt_sigqueueinfo and rt_tgsigqueueinfoRoland Dreier
Commit da48524eb206 ("Prevent rt_sigqueueinfo and rt_tgsigqueueinfo from spoofing the signal code") made the check on si_code too strict. There are several legitimate places where glibc wants to queue a negative si_code different from SI_QUEUE: - This was first noticed with glibc's aio implementation, which wants to queue a signal with si_code SI_ASYNCIO; the current kernel causes glibc's tst-aio4 test to fail because rt_sigqueueinfo() fails with EPERM. - Further examination of the glibc source shows that getaddrinfo_a() wants to use SI_ASYNCNL (which the kernel does not even define). The timer_create() fallback code wants to queue signals with SI_TIMER. As suggested by Oleg Nesterov <oleg@redhat.com>, loosen the check to forbid only the problematic SI_TKILL case. Reported-by: Klaus Dittrich <kladit@arcor.de> Acked-by: Julien Tinnes <jln@google.com> Cc: <stable@kernel.org> Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-28genirq: Fix typo and remove unused variableThomas Gleixner
Sigh, I'm overworked. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-28genirq: Fix new kernel-doc warningsRandy Dunlap
Fix new irq-related kernel-doc warnings in 2.6.38: Warning(kernel/irq/manage.c:149): No description found for parameter 'mask' Warning(kernel/irq/manage.c:149): Excess function parameter 'cpumask' description in 'irq_set_affinity' Warning(include/linux/irq.h:161): No description found for parameter 'state_use_accessors' Warning(include/linux/irq.h:161): Excess struct/union/enum/typedef member 'state_use_accessor' description in 'irq_data' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> LKML-Reference: <20110318093356.b939558d.randy.dunlap@oracle.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-28genirq: Remove handle_IRQ_eventThomas Gleixner
Last user gone. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-28genirq: Provide edge_eoi flow handlerThomas Gleixner
This is a replacment for the cell flow handler which is in the way of cleanups. Must be selected to avoid general bloat. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-28genirq: Move INPROGRESS, MASKED and DISABLED state flags to irq_dataThomas Gleixner
We really need these flags for some of the interrupt chips. Move it from internal state to irq_data and provide proper accessors. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: David Daney <ddaney@caviumnetworks.com>
2011-03-27genirq: Split irq_set_affinity() so it can be called with lock held.David Daney
The .irq_cpu_online() and .irq_cpu_offline() functions may need to adjust affinity, but they are called with the descriptor lock held. Create __irq_set_affinity_locked() which is called with the lock held. Make irq_set_affinity() just a wrapper that acquires the lock. [ tglx: Changed the argument to irq_data, added a !desc check and moved the !irq_set_affinity check where it belongs ] Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Cc: ralf@linux-mips.org LKML-Reference: <1301081931-11240-4-git-send-email-ddaney@caviumnetworks.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-27genirq: Add chip flag for restricting cpu_on/offline callsThomas Gleixner
Add a flag which indicates that the on/offline callback should only be called on enabled interrupts. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-27genirq: Add chip hooks for taking CPUs on/off line.David Daney
[ tglx: Removed the enabled argument as this is now available in irq_data ] Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Cc: ralf@linux-mips.org LKML-Reference: <1301081931-11240-3-git-send-email-ddaney@caviumnetworks.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-27genirq: Add irq disabled flag to irq_data stateThomas Gleixner
Some irq_chip implementation require to know the disabled state of the interrupt in certain callbacks. Add a state flag and accessor to irq_data. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-27genirq: Reserve the irq when calling irq_set_chip()David Daney
The helper macros and functions like for_each_active_irq() don't work unless the irq is in the allocated_irqs set. In the case of !CONFIG_SPARSE_IRQ, instead of forcing all users of the irq infrastructure to explicitly call irq_reserve_irq(), do it for them. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Cc: linux-mips@linux-mips.org Cc: ralf@linux-mips.org LKML-Reference: <1301081931-11240-2-git-send-email-ddaney@caviumnetworks.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-25Merge branch 'syscore' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6 * 'syscore' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/suspend-2.6: Introduce ARCH_NO_SYSDEV_OPS config option (v2) cpufreq: Use syscore_ops for boot CPU suspend/resume (v2) KVM: Use syscore_ops instead of sysdev class and sysdev PCI / Intel IOMMU: Use syscore_ops instead of sysdev class and sysdev timekeeping: Use syscore_ops instead of sysdev class and sysdev x86: Use syscore_ops instead of sysdev classes and sysdevs
2011-03-25Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jwessel/linux-2.6-kgdb: kdb: add usage string of 'per_cpu' command kgdb,x86_64: fix compile warning found with sparse kdb: code cleanup to use macro instead of value kgdboc,kgdbts: strlen() doesn't count the terminator
2011-03-25Merge branch 'irq-cleanup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-cleanup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (23 commits) genirq: Expand generic show_interrupts() gpio: Fold irq_set_chip/irq_set_handler to irq_set_chip_and_handler gpio: Cleanup genirq namespace arm: ep93xx: Add basic interrupt info arm/gpio: Remove three copies of broken and racy debug code xtensa: Use generic show_interrupts() xtensa: Convert genirq namespace xtensa: Use generic IRQ Kconfig and set GENERIC_HARDIRQS_NO_DEPRECATED xtensa: Convert s6000 gpio irq_chip to new functions xtensa: Convert main irq_chip to new functions um: Use generic show_interrupts() um: Convert genirq namespace m32r: Use generic show_interrupts() m32r: Convert genirq namespace h8300: Use generic show_interrupts() h8300: Convert genirq namespace avr32: Cleanup eic_set_irq_type() avr32: Use generic show_interrupts() avr: Cleanup genirq namespace avr32: Use generic IRQ config, enable GENERIC_HARDIRQS_NO_DEPRECATED ... Fix up trivial conflict in drivers/gpio/timbgpio.c
2011-03-25Merge branch 'sched-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'sched-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: sched, doc: Update sched-design-CFS.txt sched: Remove unused 'rq' variable and cpu_rq() call from alloc_fair_sched_group() sched.h: Fix a typo ("its") sched: Fix yield_to kernel-doc
2011-03-25Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf, x86: Complain louder about BIOSen corrupting CPU/PMU state and continue perf, x86: P4 PMU - Read proper MSR register to catch unflagged overflows perf symbols: Look at .dynsym again if .symtab not found perf build-id: Add quirk to deal with perf.data file format breakage perf session: Pass evsel in event_ops->sample() perf: Better fit max unprivileged mlock pages for tools needs perf_events: Fix stale ->cgrp pointer in update_cgrp_time_from_cpuctx() perf top: Fix uninitialized 'counter' variable tracing: Fix set_ftrace_filter probe function display perf, x86: Fix Intel fixed counters base initialization
2011-03-25Merge branch 'irq-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: genirq: Provide locked setter for chip, handler, name genirq: Provide a lockdep helper genirq; Remove the last leftovers of the old sparse irq code
2011-03-25Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: futex: Fix WARN_ON() test for UP WARN_ON_SMP(): Allow use in if() statements on UP x86, dumpstack: Use %pB format specifier for stack trace vsprintf: Introduce %pB format specifier lockdep: Remove unused 'factor' variable from lockdep_stats_show()
2011-03-25kdb: add usage string of 'per_cpu' commandNamhyung Kim
Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2011-03-25kdb: code cleanup to use macro instead of valueJovi Zhang
It's better to use macro KDB_BASE_CMD_MAX instead of 50 Signed-off-by: Jovi Zhang <bookjovi@gmail.com> Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
2011-03-25genirq: Expand generic show_interrupts()Thomas Gleixner
Some archs want to print extra information for certain irq_chips which is per irq and not per chip. Allow them to provide a chip callback to print the chip name and the extra information. PowerPC wants to print the LEVEL/EDGE type information. Make it configurable. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-03-25futex: Fix WARN_ON() test for UPSteven Rostedt
An update of the futex code had a WARN_ON(!spin_is_locked(q->lock_ptr)) But on UP, spin_is_locked() is always false, and will trigger this warning, and even worse, it will exit the function without doing the necessary work. Converting this to a WARN_ON_SMP() fixes the problem. Reported-by: Richard Weinberger <richard@nod.at> Tested-by: Richard Weinberger <richard@nod.at> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Darren Hart <dvhart@linux.intel.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> LKML-Reference: <20110317192208.682654502@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-24Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300 * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300: MN10300: gcc 4.6 vs am33 inline assembly MN10300: Deprecate gdbstub MN10300: Allow KGDB to use the MN10300 serial ports MN10300: Emulate single stepping in KGDB on MN10300 MN10300: Generalise kernel debugger kernel halt, reboot or power off hook KGDB: Notify GDB of machine halt, reboot or power off MN10300: Use KGDB MN10300: Create generic kernel debugger hooks MN10300: Create general kernel debugger cache flushing MN10300: Introduce a general config option for kernel debugger hooks MN10300: The icache invalidate functions should disable the icache first MN10300: gdbstub: Restrict single-stepping to non-preemptable non-SMP configs
2011-03-24vsprintf: Introduce %pB format specifierNamhyung Kim
The %pB format specifier is for stack backtrace. Its handler sprint_backtrace() does symbol lookup using (address-1) to ensure the address will not point outside of the function. If there is a tail-call to the function marked "noreturn", gcc optimized out the code after the call then causes saved return address points outside of the function (i.e. the start of the next function), so pollutes call trace somewhat. This patch adds the %pB printk mechanism that allows architecture call-trace printout functions to improve backtrace printouts. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-arch@vger.kernel.org LKML-Reference: <1300934550-21394-1-git-send-email-namhyung@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: deal with races in /proc/*/{syscall,stack,personality} proc: enable writing to /proc/pid/mem proc: make check_mem_permission() return an mm_struct on success proc: hold cred_guard_mutex in check_mem_permission() proc: disable mem_write after exec mm: implement access_remote_vm mm: factor out main logic of access_process_vm mm: use mm_struct to resolve gate vma's in __get_user_pages mm: arch: rename in_gate_area_no_task to in_gate_area_no_mm mm: arch: make in_gate_area take an mm_struct instead of a task_struct mm: arch: make get_gate_vma take an mm_struct instead of a task_struct x86: mark associated mm when running a task in 32 bit compatibility mode x86: add context tag to mark mm when running a task in 32-bit compatibility mode auxv: require the target to be tracable (or yourself) close race in /proc/*/environ report errors in /proc/*/*map* sanely pagemap: close races with suid execve make sessionid permissions in /proc/*/task/* match those in /proc/* fix leaks in path_lookupat() Fix up trivial conflicts in fs/proc/base.c
2011-03-23crash_dump: export is_kdump_kernel to modules, consolidate elfcorehdr_addr, ↵Olaf Hering
setup_elfcorehdr and saved_max_pfn The Xen PV drivers in a crashed HVM guest can not connect to the dom0 backend drivers because both frontend and backend drivers are still in connected state. To run the connection reset function only in case of a crashdump, the is_kdump_kernel() function needs to be available for the PV driver modules. Consolidate elfcorehdr_addr, setup_elfcorehdr and saved_max_pfn into kernel/crash_dump.c Also export elfcorehdr_addr to make is_kdump_kernel() usable for modules. Leave 'elfcorehdr' as early_param(). This changes powerpc from __setup() to early_param(). It adds an address range check from x86 also on ia64 and powerpc. [akpm@linux-foundation.org: additional #includes] [akpm@linux-foundation.org: remove elfcorehdr_addr export] [akpm@linux-foundation.org: fix for Tejun's mm/nobootmem.c changes] Signed-off-by: Olaf Hering <olaf@aepfle.de> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23taskstats: use appropriate printk priority levelMandeep Singh Baines
printk()s without a priority level default to KERN_WARNING. To reduce noise at KERN_WARNING, this patch set the priority level appriopriately for unleveled printks()s. This should be useful to folks that look at dmesg warnings closely. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23userns: user namespaces: convert several capable() callsSerge E. Hallyn
CAP_IPC_OWNER and CAP_IPC_LOCK can be checked against current_user_ns(), because the resource comes from current's own ipc namespace. setuid/setgid are to uids in own namespace, so again checks can be against current_user_ns(). Changelog: Jan 11: Use task_ns_capable() in place of sched_capable(). Jan 11: Use nsown_capable() as suggested by Bastian Blank. Jan 11: Clarify (hopefully) some logic in futex and sched.c Feb 15: use ns_capable for ipc, not nsown_capable Feb 23: let copy_ipcs handle setting ipc_ns->user_ns Feb 23: pass ns down rather than taking it from current [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23userns: add a user namespace owner of ipc nsSerge E. Hallyn
Changelog: Feb 15: Don't set new ipc->user_ns if we didn't create a new ipc_ns. Feb 23: Move extern declaration to ipc_namespace.h, and group fwd declarations at top. Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23userns: user namespaces: convert all capable checks in kernel/sys.cSerge E. Hallyn
This allows setuid/setgid in containers. It also fixes some corner cases where kernel logic foregoes capability checks when uids are equivalent. The latter will need to be done throughout the whole kernel. Changelog: Jan 11: Use nsown_capable() as suggested by Bastian Blank. Jan 11: Fix logic errors in uid checks pointed out by Bastian. Feb 15: allow prlimit to current (was regression in previous version) Feb 23: remove debugging printks, uninline set_one_prio_perm and make it bool, and document its return value. Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23userns: make has_capability* into real functionsSerge E. Hallyn
So we can let type safety keep things sane, and as a bonus we can remove the declaration of init_user_ns in capability.h. Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Cc: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23userns: allow ptrace from non-init user namespacesSerge E. Hallyn
ptrace is allowed to tasks in the same user namespace according to the usual rules (i.e. the same rules as for two tasks in the init user namespace). ptrace is also allowed to a user namespace to which the current task the has CAP_SYS_PTRACE capability. Changelog: Dec 31: Address feedback by Eric: . Correct ptrace uid check . Rename may_ptrace_ns to ptrace_capable . Also fix the cap_ptrace checks. Jan 1: Use const cred struct Jan 11: use task_ns_capable() in place of ptrace_capable(). Feb 23: same_or_ancestore_user_ns() was not an appropriate check to constrain cap_issubset. Rather, cap_issubset() only is meaningful when both capsets are in the same user_ns. Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23userns: allow killing tasks in your own or child usernsSerge E. Hallyn
Changelog: Dec 8: Fixed bug in my check_kill_permission pointed out by Eric Biederman. Dec 13: Apply Eric's suggestion to pass target task into kill_ok_by_cred() for clarity Dec 31: address comment by Eric Biederman: don't need cred/tcred in check_kill_permission. Jan 1: use const cred struct. Jan 11: Per Bastian Blank's advice, clean up kill_ok_by_cred(). Feb 16: kill_ok_by_cred: fix bad parentheses Feb 23: per akpm, let compiler inline kill_ok_by_cred Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23userns: allow sethostname in a containerSerge E. Hallyn
Changelog: Feb 23: let clone_uts_ns() handle setting uts->user_ns To do so we need to pass in the task_struct who'll get the utsname, so we can get its user_ns. Feb 23: As per Oleg's coment, just pass in tsk, instead of two of its members. Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23userns: security: make capabilities relative to the user namespaceSerge E. Hallyn
- Introduce ns_capable to test for a capability in a non-default user namespace. - Teach cap_capable to handle capabilities in a non-default user namespace. The motivation is to get to the unprivileged creation of new namespaces. It looks like this gets us 90% of the way there, with only potential uid confusion issues left. I still need to handle getting all caps after creation but otherwise I think I have a good starter patch that achieves all of your goals. Changelog: 11/05/2010: [serge] add apparmor 12/14/2010: [serge] fix capabilities to created user namespaces Without this, if user serge creates a user_ns, he won't have capabilities to the user_ns he created. THis is because we were first checking whether his effective caps had the caps he needed and returning -EPERM if not, and THEN checking whether he was the creator. Reverse those checks. 12/16/2010: [serge] security_real_capable needs ns argument in !security case 01/11/2011: [serge] add task_ns_capable helper 01/11/2011: [serge] add nsown_capable() helper per Bastian Blank suggestion 02/16/2011: [serge] fix a logic bug: the root user is always creator of init_user_ns, but should not always have capabilities to it! Fix the check in cap_capable(). 02/21/2011: Add the required user_ns parameter to security_capable, fixing a compile failure. 02/23/2011: Convert some macros to functions as per akpm comments. Some couldn't be converted because we can't easily forward-declare them (they are inline if !SECURITY, extern if SECURITY). Add a current_user_ns function so we can use it in capability.h without #including cred.h. Move all forward declarations together to the top of the #ifdef __KERNEL__ section, and use kernel-doc format. 02/23/2011: Per dhowells, clean up comment in cap_capable(). 02/23/2011: Per akpm, remove unreachable 'return -EPERM' in cap_capable. (Original written and signed off by Eric; latest, modified version acked by him) [akpm@linux-foundation.org: fix build] [akpm@linux-foundation.org: export current_user_ns() for ecryptfs] [serge.hallyn@canonical.com: remove unneeded extra argument in selinux's task_has_capability] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23userns: add a user_namespace as creator/owner of uts_namespaceSerge E. Hallyn
The expected course of development for user namespaces targeted capabilities is laid out at https://wiki.ubuntu.com/UserNamespace. Goals: - Make it safe for an unprivileged user to unshare namespaces. They will be privileged with respect to the new namespace, but this should only include resources which the unprivileged user already owns. - Provide separate limits and accounting for userids in different namespaces. Status: Currently (as of 2.6.38) you can clone with the CLONE_NEWUSER flag to get a new user namespace if you have the CAP_SYS_ADMIN, CAP_SETUID, and CAP_SETGID capabilities. What this gets you is a whole new set of userids, meaning that user 500 will have a different 'struct user' in your namespace than in other namespaces. So any accounting information stored in struct user will be unique to your namespace. However, throughout the kernel there are checks which - simply check for a capability. Since root in a child namespace has all capabilities, this means that a child namespace is not constrained. - simply compare uid1 == uid2. Since these are the integer uids, uid 500 in namespace 1 will be said to be equal to uid 500 in namespace 2. As a result, the lxc implementation at lxc.sf.net does not use user namespaces. This is actually helpful because it leaves us free to develop user namespaces in such a way that, for some time, user namespaces may be unuseful. Bugs aside, this patchset is supposed to not at all affect systems which are not actively using user namespaces, and only restrict what tasks in child user namespace can do. They begin to limit privilege to a user namespace, so that root in a container cannot kill or ptrace tasks in the parent user namespace, and can only get world access rights to files. Since all files currently belong to the initila user namespace, that means that child user namespaces can only get world access rights to *all* files. While this temporarily makes user namespaces bad for system containers, it starts to get useful for some sandboxing. I've run the 'runltplite.sh' with and without this patchset and found no difference. This patch: copy_process() handles CLONE_NEWUSER before the rest of the namespaces. So in the case of clone(CLONE_NEWUSER|CLONE_NEWUTS) the new uts namespace will have the new user namespace as its owner. That is what we want, since we want root in that new userns to be able to have privilege over it. Changelog: Feb 15: don't set uts_ns->user_ns if we didn't create a new uts_ns. Feb 23: Move extern init_user_ns declaration from init/version.c to utsname.h. Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Acked-by: "Eric W. Biederman" <ebiederm@xmission.com> Acked-by: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23pidns: call pid_ns_prepare_proc() from create_pid_namespace()Eric W. Biederman
Reorganize proc_get_sb() so it can be called before the struct pid of the first process is allocated. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23pid: remove the child_reaper special case in init/main.cEric W. Biederman
This patchset is a cleanup and a preparation to unshare the pid namespace. These prerequisites prepare for Eric's patchset to give a file descriptor to a namespace and join an existing namespace. This patch: It turns out that the existing assignment in copy_process of the child_reaper can handle the initial assignment of child_reaper we just need to generalize the test in kernel/fork.c Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Daniel Lezcano <daniel.lezcano@free.fr> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23sysctl: restrict write access to dmesg_restrictRichard Weinberger
When dmesg_restrict is set to 1 CAP_SYS_ADMIN is needed to read the kernel ring buffer. But a root user without CAP_SYS_ADMIN is able to reset dmesg_restrict to 0. This is an issue when e.g. LXC (Linux Containers) are used and complete user space is running without CAP_SYS_ADMIN. A unprivileged and jailed root user can bypass the dmesg_restrict protection. With this patch writing to dmesg_restrict is only allowed when root has CAP_SYS_ADMIN. Signed-off-by: Richard Weinberger <richard@nod.at> Acked-by: Dan Rosenberg <drosenberg@vsecurity.com> Acked-by: Serge E. Hallyn <serge@hallyn.com> Cc: Eric Paris <eparis@redhat.com> Cc: Kees Cook <kees.cook@canonical.com> Cc: James Morris <jmorris@namei.org> Cc: Eugene Teo <eugeneteo@kernel.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23sysctl: add some missing input constraint checksPetr Holasek
Add boundaries of allowed input ranges for: dirty_expire_centisecs, drop_caches, overcommit_memory, page-cluster and panic_on_oom. Signed-off-by: Petr Holasek <pholasek@redhat.com> Acked-by: Dave Young <hidave.darkstar@gmail.com> Cc: David Rientjes <rientjes@google.com> Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23sysctl_check: drop dead codeDenis Kirjanov
Drop dead code. Signed-off-by: Denis Kirjanov <dkirjanov@kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23sysctl_check: drop table->procname checksDenis Kirjanov
Since the for loop checks for the table->procname drop useless table->procname checks inside the loop body Signed-off-by: Denis Kirjanov <dkirjanov@kernel.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23cpuset: hold callback_mutex in cpuset_post_clone()Li Zefan
Chaning cpuset->mems/cpuset->cpus should be protected under callback_mutex. cpuset_clone() doesn't follow this rule. It's ok because it's called when creating and initializing a cgroup, but we'd better hold the lock to avoid subtil break in the future. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Paul Menage <menage@google.com> Acked-by: David Rientjes <rientjes@google.com> Cc: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
