path: root/kernel
2016-01-14Move x86_64 idle notifiers to genericTodd Poynor
Move the x86_64 idle notifiers originally by Andi Kleen and Venkatesh Pallipadi to generic. Change-Id: Idf29cda15be151f494ff245933c12462643388d5 Acked-by: Nicolas Pitre <nicolas.pitre@linaro.org> Signed-off-by: Todd Poynor <toddpoynor@google.com>
2015-12-14bpf, array: fix heap out-of-bounds access when updating elementsDaniel Borkmann
[ Upstream commit fbca9d2d35c6ef1b323fae75cc9545005ba25097 ] During own review but also reported by Dmitry's syzkaller [1] it has been noticed that we trigger a heap out-of-bounds access on eBPF array maps when updating elements. This happens with each map whose map->value_size (specified during map creation time) is not multiple of 8 bytes. In array_map_alloc(), elem_size is round_up(attr->value_size, 8) and used to align array map slots for faster access. However, in function array_map_update_elem(), we update the element as ... memcpy(array->value + array->elem_size * index, value, array->elem_size); ... where we access 'value' out-of-bounds, since it was allocated from map_update_elem() from syscall side as kmalloc(map->value_size, GFP_USER) and later on copied through copy_from_user(value, uvalue, map->value_size). Thus, up to 7 bytes, we can access out-of-bounds. Same could happen from within an eBPF program, where in worst case we access beyond an eBPF program's designated stack. Since 1be7f75d1668 ("bpf: enable non-root eBPF programs") didn't hit an official release yet, it only affects priviledged users. In case of array_map_lookup_elem(), the verifier prevents eBPF programs from accessing beyond map->value_size through check_map_access(). Also from syscall side map_lookup_elem() only copies map->value_size back to user, so nothing could leak. [1] http://github.com/google/syzkaller Fixes: 28fbcfa08d8e ("bpf: add array type of eBPF maps") Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Acked-by: Alexei Starovoitov <ast@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-11-09module: Fix locking in symbol_put_addr()Peter Zijlstra
commit 275d7d44d802ef271a42dc87ac091a495ba72fc5 upstream. Poma (on the way to another bug) reported an assertion triggering: [<ffffffff81150529>] module_assert_mutex_or_preempt+0x49/0x90 [<ffffffff81150822>] __module_address+0x32/0x150 [<ffffffff81150956>] __module_text_address+0x16/0x70 [<ffffffff81150f19>] symbol_put_addr+0x29/0x40 [<ffffffffa04b77ad>] dvb_frontend_detach+0x7d/0x90 [dvb_core] Laura Abbott <labbott@redhat.com> produced a patch which lead us to inspect symbol_put_addr(). This function has a comment claiming it doesn't need to disable preemption around the module lookup because it holds a reference to the module it wants to find, which therefore cannot go away. This is wrong (and a false optimization too, preempt_disable() is really rather cheap, and I doubt any of this is on uber critical paths, otherwise it would've retained a pointer to the actual module anyway and avoided the second lookup). While its true that the module cannot go away while we hold a reference on it, the data structure we do the lookup in very much _CAN_ change while we do the lookup. Therefore fix the comment and add the required preempt_disable(). Reported-by: poma <pomidorabelisima@gmail.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Fixes: a6e6abd575fc ("module: remove module_text_address()") Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-27sched/preempt: Fix cond_resched_lock() and cond_resched_softirq()Konstantin Khlebnikov
commit fe32d3cd5e8eb0f82e459763374aa80797023403 upstream. These functions check should_resched() before unlocking spinlock/bh-enable: preempt_count always non-zero => should_resched() always returns false. cond_resched_lock() worked iff spin_needbreak is set. This patch adds argument "preempt_offset" to should_resched(). preempt_count offset constants for that: PREEMPT_DISABLE_OFFSET - offset after preempt_disable() PREEMPT_LOCK_OFFSET - offset after spin_lock() SOFTIRQ_DISABLE_OFFSET - offset after local_bh_distable() SOFTIRQ_LOCK_OFFSET - offset after spin_lock_bh() Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Alexander Graf <agraf@suse.de> Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: bdb438065890 ("sched: Extract the basic add/sub preempt_count modifiers") Link: http://lkml.kernel.org/r/20150715095204.12246.98268.stgit@buzz Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-27workqueue: make sure delayed work run in local cpuShaohua Li
commit 874bbfe600a660cba9c776b3957b1ce393151b76 upstream. My system keeps crashing with below message. vmstat_update() schedules a delayed work in current cpu and expects the work runs in the cpu. schedule_delayed_work() is expected to make delayed work run in local cpu. The problem is timer can be migrated with NO_HZ. __queue_work() queues work in timer handler, which could run in a different cpu other than where the delayed work is scheduled. The end result is the delayed work runs in different cpu. The patch makes __queue_delayed_work records local cpu earlier. Where the timer runs doesn't change where the work runs with the change. [ 28.010131] ------------[ cut here ]------------ [ 28.010609] kernel BUG at ../mm/vmstat.c:1392! [ 28.011099] invalid opcode: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC KASAN [ 28.011860] Modules linked in: [ 28.012245] CPU: 0 PID: 289 Comm: kworker/0:3 Tainted: G W4.3.0-rc3+ #634 [ 28.013065] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.7.5-20140709_153802- 04/01/2014 [ 28.014160] Workqueue: events vmstat_update [ 28.014571] task: ffff880117682580 ti: ffff8800ba428000 task.ti: ffff8800ba428000 [ 28.015445] RIP: 0010:[<ffffffff8115f921>] [<ffffffff8115f921>]vmstat_update+0x31/0x80 [ 28.016282] RSP: 0018:ffff8800ba42fd80 EFLAGS: 00010297 [ 28.016812] RAX: 0000000000000000 RBX: ffff88011a858dc0 RCX:0000000000000000 [ 28.017585] RDX: ffff880117682580 RSI: ffffffff81f14d8c RDI:ffffffff81f4df8d [ 28.018366] RBP: ffff8800ba42fd90 R08: 0000000000000001 R09:0000000000000000 [ 28.019169] R10: 0000000000000000 R11: 0000000000000121 R12:ffff8800baa9f640 [ 28.019947] R13: ffff88011a81e340 R14: ffff88011a823700 R15:0000000000000000 [ 28.020071] FS: 0000000000000000(0000) GS:ffff88011a800000(0000)knlGS:0000000000000000 [ 28.020071] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [ 28.020071] CR2: 00007ff6144b01d0 CR3: 00000000b8e93000 CR4:00000000000006f0 [ 28.020071] Stack: [ 28.020071] ffff88011a858dc0 ffff8800baa9f640 ffff8800ba42fe00ffffffff8106bd88 [ 28.020071] ffffffff8106bd0b 0000000000000096 0000000000000000ffffffff82f9b1e8 [ 28.020071] ffffffff829f0b10 0000000000000000 ffffffff81f18460ffff88011a81e340 [ 28.020071] Call Trace: [ 28.020071] [<ffffffff8106bd88>] process_one_work+0x1c8/0x540 [ 28.020071] [<ffffffff8106bd0b>] ? process_one_work+0x14b/0x540 [ 28.020071] [<ffffffff8106c214>] worker_thread+0x114/0x460 [ 28.020071] [<ffffffff8106c100>] ? process_one_work+0x540/0x540 [ 28.020071] [<ffffffff81071bf8>] kthread+0xf8/0x110 [ 28.020071] [<ffffffff81071b00>] ?kthread_create_on_node+0x200/0x200 [ 28.020071] [<ffffffff81a6522f>] ret_from_fork+0x3f/0x70 [ 28.020071] [<ffffffff81071b00>] ?kthread_create_on_node+0x200/0x200 Signed-off-by: Shaohua Li <shli@fb.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22genirq: Fix race in register_irq_proc()Ben Hutchings
commit 95c2b17534654829db428f11bcf4297c059a2a7e upstream. Per-IRQ directories in procfs are created only when a handler is first added to the irqdesc, not when the irqdesc is created. In the case of a shared IRQ, multiple tasks can race to create a directory. This race condition seems to have been present forever, but is easier to hit with async probing. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Link: http://lkml.kernel.org/r/1443266636.2004.2.camel@decadent.org.uk Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22sched/fair: Prevent throttling in early pick_next_task_fair()Ben Segall
commit 54d27365cae88fbcc853b391dcd561e71acb81fa upstream. The optimized task selection logic optimistically selects a new task to run without first doing a full put_prev_task(). This is so that we can avoid a put/set on the common ancestors of the old and new task. Similarly, we should only call check_cfs_rq_runtime() to throttle eligible groups if they're part of the common ancestry, otherwise it is possible to end up with no eligible task in the simple task selection. Imagine: /root /prev /next /A /B If our optimistic selection ends up throttling /next, we goto simple and our put_prev_task() ends up throttling /prev, after which we're going to bug out in set_next_entity() because there aren't any tasks left. Avoid this scenario by only throttling common ancestors. Reported-by: Mohammed Naser <mnaser@vexxhost.com> Reported-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru> Signed-off-by: Ben Segall <bsegall@google.com> [ munged Changelog ] Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roman Gushchin <klamm@yandex-team.ru> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: pjt@google.com Fixes: 678d5718d8d0 ("sched/fair: Optimize cgroup pick_next_task_fair()") Link: http://lkml.kernel.org/r/xm26wq1oswoq.fsf@sword-of-the-dawn.mtv.corp.google.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22sched/core: Fix TASK_DEAD race in finish_task_switch()Peter Zijlstra
commit 95913d97914f44db2b81271c2e2ebd4d2ac2df83 upstream. So the problem this patch is trying to address is as follows: CPU0 CPU1 context_switch(A, B) ttwu(A) LOCK A->pi_lock A->on_cpu == 0 finish_task_switch(A) prev_state = A->state <-. WMB | A->on_cpu = 0; | UNLOCK rq0->lock | | context_switch(C, A) `-- A->state = TASK_DEAD prev_state == TASK_DEAD put_task_struct(A) context_switch(A, C) finish_task_switch(A) A->state == TASK_DEAD put_task_struct(A) The argument being that the WMB will allow the load of A->state on CPU0 to cross over and observe CPU1's store of A->state, which will then result in a double-drop and use-after-free. Now the comment states (and this was true once upon a long time ago) that we need to observe A->state while holding rq->lock because that will order us against the wakeup; however the wakeup will not in fact acquire (that) rq->lock; it takes A->pi_lock these days. We can obviously fix this by upgrading the WMB to an MB, but that is expensive, so we'd rather avoid that. The alternative this patch takes is: smp_store_release(&A->on_cpu, 0), which avoids the MB on some archs, but not important ones like ARM. Reported-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Cc: manfred@colorfullife.com Cc: will.deacon@arm.com Fixes: e4a52bcb9a18 ("sched: Remove rq->lock from the first half of ttwu()") Link: http://lkml.kernel.org/r/20150929124509.GG3816@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22sched: access local runqueue directly in single_task_runningDominik Dingel
commit 00cc1633816de8c95f337608a1ea64e228faf771 upstream. Commit 2ee507c47293 ("sched: Add function single_task_running to let a task check if it is the only task running on a cpu") referenced the current runqueue with the smp_processor_id. When CONFIG_DEBUG_PREEMPT is enabled, that is only allowed if preemption is disabled or the currrent task is bound to the local cpu (e.g. kernel worker). With commit f78195129963 ("kvm: add halt_poll_ns module parameter") KVM calls single_task_running. If CONFIG_DEBUG_PREEMPT is enabled that generates a lot of kernel messages. To avoid adding preemption in that cases, as it would limit the usefulness, we change single_task_running to access directly the cpu local runqueue. Cc: Tim Chen <tim.c.chen@linux.intel.com> Suggested-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Fixes: 2ee507c472939db4b146d545352b8a7c79ef47f8 Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com> Signed-off-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22perf: Fix AUX buffer refcountingPeter Zijlstra
commit 57ffc5ca679f499f4704fd9b6a372916f59930ee upstream. Its currently possible to drop the last refcount to the aux buffer from NMI context, which results in the expected fireworks. The refcounting needs a bigger overhaul, but to cure the immediate problem, delay the freeing by using an irq_work. Reviewed-and-tested-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Reported-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20150618103249.GK19282@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-22time: Fix timekeeping_freqadjust()'s incorrect use of abs() instead of abs64()John Stultz
commit 2619d7e9c92d524cb155ec89fd72875321512e5b upstream. The internal clocksteering done for fine-grained error correction uses a logarithmic approximation, so any time adjtimex() adjusts the clock steering, timekeeping_freqadjust() quickly approximates the correct clock frequency over a series of ticks. Unfortunately, the logic in timekeeping_freqadjust(), introduced in commit: dc491596f639 ("timekeeping: Rework frequency adjustments to work better w/ nohz") used the abs() function with a s64 error value to calculate the size of the approximated adjustment to be made. Per include/linux/kernel.h: "abs() should not be used for 64-bit types (s64, u64, long long) - use abs64()". Thus on 32-bit platforms, this resulted in the clocksteering to take a quite dampended random walk trying to converge on the proper frequency, which caused the adjustments to be made much slower then intended (most easily observed when large adjustments are made). This patch fixes the issue by using abs64() instead. Reported-by: Nuno Gonçalves <nunojpg@gmail.com> Tested-by: Nuno Goncalves <nunojpg@gmail.com> Signed-off-by: John Stultz <john.stultz@linaro.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Miroslav Lichvar <mlichvar@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Prarit Bhargava <prarit@redhat.com> Cc: Richard Cochran <richardcochran@gmail.com> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1441840051-20244-1-git-send-email-john.stultz@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-29unshare: Unsharing a thread does not require unsharing a vmEric W. Biederman
commit 12c641ab8270f787dfcce08b5f20ce8b65008096 upstream. In the logic in the initial commit of unshare made creating a new thread group for a process, contingent upon creating a new memory address space for that process. That is wrong. Two separate processes in different thread groups can share a memory address space and clone allows creation of such proceses. This is significant because it was observed that mm_users > 1 does not mean that a process is multi-threaded, as reading /proc/PID/maps temporarily increments mm_users, which allows other processes to (accidentally) interfere with unshare() calls. Correct the check in check_unshare_flags() to test for !thread_group_empty() for CLONE_THREAD, CLONE_SIGHAND, and CLONE_VM. For sighand->count > 1 for CLONE_SIGHAND and CLONE_VM. For !current_is_single_threaded instead of mm_users > 1 for CLONE_VM. By using the correct checks in unshare this removes the possibility of an accidental denial of service attack. Additionally using the correct checks in unshare ensures that only an explicit unshare(CLONE_VM) can possibly trigger the slow path of current_is_single_threaded(). As an explict unshare(CLONE_VM) is pointless it is not expected there are many applications that make that call. Fixes: b2e0d98705e60e45bbb3c0032c48824ad7ae0704 userns: Implement unshare of the user namespace Reported-by: Ricky Zhou <rickyz@chromium.org> Reported-by: Kees Cook <keescook@chromium.org> Reviewed-by: Kees Cook <keescook@chromium.org> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-21fs: create and use seq_show_option for escapingKees Cook
commit a068acf2ee77693e0bf39d6e07139ba704f461c3 upstream. Many file systems that implement the show_options hook fail to correctly escape their output which could lead to unescaped characters (e.g. new lines) leaking into /proc/mounts and /proc/[pid]/mountinfo files. This could lead to confusion, spoofed entries (resulting in things like systemd issuing false d-bus "mount" notifications), and who knows what else. This looks like it would only be the root user stepping on themselves, but it's possible weird things could happen in containers or in other situations with delegated mount privileges. Here's an example using overlay with setuid fusermount trusting the contents of /proc/mounts (via the /etc/mtab symlink). Imagine the use of "sudo" is something more sneaky: $ BASE="ovl" $ MNT="$BASE/mnt" $ LOW="$BASE/lower" $ UP="$BASE/upper" $ WORK="$BASE/work/ 0 0 none /proc fuse.pwn user_id=1000" $ mkdir -p "$LOW" "$UP" "$WORK" $ sudo mount -t overlay -o "lowerdir=$LOW,upperdir=$UP,workdir=$WORK" none /mnt $ cat /proc/mounts none /root/ovl/mnt overlay rw,relatime,lowerdir=ovl/lower,upperdir=ovl/upper,workdir=ovl/work/ 0 0 none /proc fuse.pwn user_id=1000 0 0 $ fusermount -u /proc $ cat /proc/mounts cat: /proc/mounts: No such file or directory This fixes the problem by adding new seq_show_option and seq_show_option_n helpers, and updating the vulnerable show_option handlers to use them as needed. Some, like SELinux, need to be open coded due to unusual existing escape mechanisms. [akpm@linux-foundation.org: add lost chunk, per Kees] [keescook@chromium.org: seq_show_option should be using const parameters] Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Jan Kara <jack@suse.com> Acked-by: Paul Moore <paul@paul-moore.com> Cc: J. R. Okajima <hooanon05g@gmail.com> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-21sched: Fix cpu_active_mask/cpu_online_mask raceJan H. Schönherr
commit dd9d3843755da95f63dd3a376f62b3e45c011210 upstream. There is a race condition in SMP bootup code, which may result in WARNING: CPU: 0 PID: 1 at kernel/workqueue.c:4418 workqueue_cpu_up_callback() or kernel BUG at kernel/smpboot.c:135! It can be triggered with a bit of luck in Linux guests running on busy hosts. CPU0 CPUn ==== ==== _cpu_up() __cpu_up() start_secondary() set_cpu_online() cpumask_set_cpu(cpu, to_cpumask(cpu_online_bits)); cpu_notify(CPU_ONLINE) <do stuff, see below> cpumask_set_cpu(cpu, to_cpumask(cpu_active_bits)); During the various CPU_ONLINE callbacks CPUn is online but not active. Several things can go wrong at that point, depending on the scheduling of tasks on CPU0. Variant 1: cpu_notify(CPU_ONLINE) workqueue_cpu_up_callback() rebind_workers() set_cpus_allowed_ptr() This call fails because it requires an active CPU; rebind_workers() ends with a warning: WARNING: CPU: 0 PID: 1 at kernel/workqueue.c:4418 workqueue_cpu_up_callback() Variant 2: cpu_notify(CPU_ONLINE) smpboot_thread_call() smpboot_unpark_threads() .. __kthread_unpark() __kthread_bind() wake_up_state() .. select_task_rq() select_fallback_rq() The ->wake_cpu of the unparked thread is not allowed, making a call to select_fallback_rq() necessary. Then, select_fallback_rq() cannot find an allowed, active CPU and promptly resets the allowed CPUs, so that the task in question ends up on CPU0. When those unparked tasks are eventually executed, they run immediately into a BUG: kernel BUG at kernel/smpboot.c:135! Just changing the order in which the online/active bits are set (and adding some memory barriers), would solve the two issues above. However, it would change the order of operations back to the one before commit 6acbfb96976f ("sched: Fix hotplug vs. set_cpus_allowed_ptr()"), thus, reintroducing that particular problem. Going further back into history, we have at least the following commits touching this topic: - commit 2baab4e90495 ("sched: Fix select_fallback_rq() vs cpu_active/cpu_online") - commit 5fbd036b552f ("sched: Cleanup cpu_active madness") Together, these give us the following non-working solutions: - secondary CPU sets active before online, because active is assumed to be a subset of online; - secondary CPU sets online before active, because the primary CPU assumes that an online CPU is also active; - secondary CPU sets online and waits for primary CPU to set active, because it might deadlock. Commit 875ebe940d77 ("powerpc/smp: Wait until secondaries are active & online") introduces an arch-specific solution to this arch-independent problem. Now, go for a more general solution without explicit waiting and simply set active twice: once on the secondary CPU after online was set and once on the primary CPU after online was seen. set_cpus_allowed_ptr()") Signed-off-by: Jan H. Schönherr <jschoenh@amazon.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Anton Blanchard <anton@samba.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Joerg Roedel <jroedel@suse.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Matt Wilson <msw@amazon.com> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: 6acbfb96976f ("sched: Fix hotplug vs. set_cpus_allowed_ptr()") Link: http://lkml.kernel.org/r/1439408156-18840-1-git-send-email-jschoenh@amazon.de Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-13genirq: Introduce irq_chip_set_type_parent() helperGrygorii Strashko
commit b7560de198222994374c1340a389f12d5efb244a upstream. This helper is required for irq chips which do not implement a irq_set_type callback and need to call down the irq domain hierarchy for the actual trigger type change. This helper is required to fix further wreckage caused by the conversion of TI OMAP to hierarchical irq domains and therefor tagged for stable. [ tglx: Massaged changelog ] Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Cc: Sudeep Holla <sudeep.holla@arm.com> Cc: <linux@arm.linux.org.uk> Cc: <nsekhar@ti.com> Cc: <jason@lakedaemon.net> Cc: <balbi@ti.com> Cc: <linux-arm-kernel@lists.infradead.org> Cc: <tony@atomide.com> Cc: <marc.zyngier@arm.com> Cc: stable@vger.kernel.org # 4.1 Link: http://lkml.kernel.org/r/1439554830-19502-3-git-send-email-grygorii.strashko@ti.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-13genirq: Don't return ENOSYS in irq_chip_retrigger_hierarchyGrygorii Strashko
commit 6d4affea7d5aa5ca5ff4c3e5fbf3ee16801cc527 upstream. irq_chip_retrigger_hierarchy() returns -ENOSYS if it was not able to find at least one .irq_retrigger() callback implemented in the IRQ domain hierarchy. That's wrong, because check_irq_resend() expects a 0 return value from the callback in case that the hardware assisted resend was not possible. If the return value is non zero the core code assumes hardware resend success and the software resend is not invoked. This results in lost interrupts on platforms where none of the parent irq chips in the hierarchy implements the retrigger callback. This is observable on TI OMAP, where the hierarchy is: ARM GIC <- OMAP wakeupgen <- TI Crossbar Return 0 instead so the software resend mechanism gets invoked. [ tglx: Massaged changelog ] Fixes: 85f08c17de26 ('genirq: Introduce helper functions...') Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Reviewed-by: Marc Zyngier <marc.zyngier@arm.com> Reviewed-by: Jiang Liu <jiang.liu@linux.intel.com> Cc: Sudeep Holla <sudeep.holla@arm.com> Cc: <linux@arm.linux.org.uk> Cc: <nsekhar@ti.com> Cc: <jason@lakedaemon.net> Cc: <balbi@ti.com> Cc: <linux-arm-kernel@lists.infradead.org> Cc: <tony@atomide.com> Link: http://lkml.kernel.org/r/1439554830-19502-2-git-send-email-grygorii.strashko@ti.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-13cpuset: use trialcs->mems_allowed as a temp variableAlban Crequy
commit 24ee3cf89bef04e8bc23788aca4e029a3f0f06d9 upstream. The comment says it's using trialcs->mems_allowed as a temp variable but it didn't match the code. Change the code to match the comment. This fixes an issue when writing in cpuset.mems when a sub-directory exists: we need to write several times for the information to persist: | root@alban:/sys/fs/cgroup/cpuset# mkdir footest9 | root@alban:/sys/fs/cgroup/cpuset# cd footest9 | root@alban:/sys/fs/cgroup/cpuset/footest9# mkdir aa | root@alban:/sys/fs/cgroup/cpuset/footest9# cat cpuset.mems | | root@alban:/sys/fs/cgroup/cpuset/footest9# echo 0 > cpuset.mems | root@alban:/sys/fs/cgroup/cpuset/footest9# cat cpuset.mems | | root@alban:/sys/fs/cgroup/cpuset/footest9# echo 0 > cpuset.mems | root@alban:/sys/fs/cgroup/cpuset/footest9# cat cpuset.mems | 0 | root@alban:/sys/fs/cgroup/cpuset/footest9# cat aa/cpuset.mems | | root@alban:/sys/fs/cgroup/cpuset/footest9# echo 0 > aa/cpuset.mems | root@alban:/sys/fs/cgroup/cpuset/footest9# cat aa/cpuset.mems | 0 | root@alban:/sys/fs/cgroup/cpuset/footest9# This should help to fix the following issue in Docker: https://github.com/opencontainers/runc/issues/133 In some conditions, a Docker container needs to be started twice in order to work. Signed-off-by: Alban Crequy <alban@endocode.com> Tested-by: Iago López Galeiras <iago@endocode.com> Acked-by: Li Zefan <lizefan@huawei.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-13perf: Fix PERF_EVENT_IOC_PERIOD migration racePeter Zijlstra
commit c7999c6f3fed9e383d3131474588f282ae6d56b9 upstream. I ran the perf fuzzer, which triggered some WARN()s which are due to trying to stop/restart an event on the wrong CPU. Use the normal IPI pattern to ensure we run the code on the correct CPU. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Vince Weaver <vincent.weaver@maine.edu> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: bad7192b842c ("perf: Fix PERF_EVENT_IOC_PERIOD to force-reset the period") Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-13perf: Fix double-free of the AUX bufferBen Hutchings
commit ee9397a6fb9bc4e52677f5e33eed4abee0f515e6 upstream. If rb->aux_refcount is decremented to zero before rb->refcount, __rb_free_aux() may be called twice resulting in a double free of rb->aux_pages. Fix this by adding a check to __rb_free_aux(). Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Fixes: 57ffc5ca679f ("perf: Fix AUX buffer refcounting") Link: http://lkml.kernel.org/r/1437953468.12842.17.camel@decadent.org.uk Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-13perf: Fix running time accountingPeter Zijlstra
commit 00a2916f7f82c348a2a94dbb572874173bc308a3 upstream. A recent fix to the shadow timestamp inadvertly broke the running time accounting. We must not update the running timestamp if we fail to schedule the event, the event will not have ran. This can (and did) result in negative total runtime because the stopped timestamp was before the running timestamp (we 'started' but never stopped the event -- because it never really started we didn't have to stop it either). Reported-and-Tested-by: Vince Weaver <vincent.weaver@maine.edu> Fixes: 72f669c0086f ("perf: Update shadow timestamp before add event") Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Shaohua Li <shli@fb.com> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-13perf: Fix fasync handling on inherited eventsPeter Zijlstra
commit fed66e2cdd4f127a43fd11b8d92a99bdd429528c upstream. Vince reported that the fasync signal stuff doesn't work proper for inherited events. So fix that. Installing fasync allocates memory and sets filp->f_flags |= FASYNC, which upon the demise of the file descriptor ensures the allocation is freed and state is updated. Now for perf, we can have the events stick around for a while after the original FD is dead because of references from child events. So we cannot copy the fasync pointer around. We can however consistently use the parent's fasync, as that will be updated. Reported-and-Tested-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Arnaldo Carvalho deMelo <acme@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: eranian@google.com Link: http://lkml.kernel.org/r/1434011521.1495.71.camel@twins Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-16signal: fix information leak in copy_siginfo_from_user32Amanieu d'Antras
commit 3c00cb5e68dc719f2fc73a33b1b230aadfcb1309 upstream. This function can leak kernel stack data when the user siginfo_t has a positive si_code value. The top 16 bits of si_code descibe which fields in the siginfo_t union are active, but they are treated inconsistently between copy_siginfo_from_user32, copy_siginfo_to_user32 and copy_siginfo_to_user. copy_siginfo_from_user32 is called from rt_sigqueueinfo and rt_tgsigqueueinfo in which the user has full control overthe top 16 bits of si_code. This fixes the following information leaks: x86: 8 bytes leaked when sending a signal from a 32-bit process to itself. This leak grows to 16 bytes if the process uses x32. (si_code = __SI_CHLD) x86: 100 bytes leaked when sending a signal from a 32-bit process to a 64-bit process. (si_code = -1) sparc: 4 bytes leaked when sending a signal from a 32-bit process to a 64-bit process. (si_code = any) parsic and s390 have similar bugs, but they are not vulnerable because rt_[tg]sigqueueinfo have checks that prevent sending a positive si_code to a different process. These bugs are also fixed for consistency. Signed-off-by: Amanieu d'Antras <amanieu@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Chris Metcalf <cmetcalf@ezchip.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-16signal: fix information leak in copy_siginfo_to_userAmanieu d'Antras
commit 26135022f85105ad725cda103fa069e29e83bd16 upstream. This function may copy the si_addr_lsb, si_lower and si_upper fields to user mode when they haven't been initialized, which can leak kernel stack data to user mode. Just checking the value of si_code is insufficient because the same si_code value is shared between multiple signals. This is solved by checking the value of si_signo in addition to si_code. Signed-off-by: Amanieu d'Antras <amanieu@gmail.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-10ftrace: Fix breakage of set_ftrace_pidSteven Rostedt (Red Hat)
commit e3eea1404f5ff7a2ceb7b5e7ba412a6fd94f2935 upstream. Commit 4104d326b670 ("ftrace: Remove global function list and call function directly") simplified the ftrace code by removing the global_ops list with a new design. But this cleanup also broke the filtering of PIDs that are added to the set_ftrace_pid file. Add back the proper hooks to have pid filtering working once again. Reported-by: Matt Fleming <matt@console-pimps.org> Reported-by: Richard Weinberger <richard.weinberger@gmail.com> Tested-by: Matt Fleming <matt@console-pimps.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-10genirq: Prevent resend to interrupts marked IRQ_NESTED_THREADThomas Gleixner
commit 75a06189fc508a2acf470b0b12710362ffb2c4b1 upstream. The resend mechanism happily calls the interrupt handler of interrupts which are marked IRQ_NESTED_THREAD from softirq context. This can result in crashes because the interrupt handler is not the proper way to invoke the device handlers. They must be invoked via handle_nested_irq. Prevent the resend even if the interrupt has no valid parent irq set. Its better to have a lost interrupt than a crashing machine. Reported-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-03security_syslog() should be called once onlyVasily Averin
commit d194e5d666225b04c7754471df0948f645b6ab3a upstream. The final version of commit 637241a900cb ("kmsg: honor dmesg_restrict sysctl on /dev/kmsg") lost few hooks, as result security_syslog() are processed incorrectly: - open of /dev/kmsg checks syslog access permissions by using check_syslog_permissions() where security_syslog() is not called if dmesg_restrict is set. - syslog syscall and /proc/kmsg calls do_syslog() where security_syslog can be executed twice (inside check_syslog_permissions() and then directly in do_syslog()) With this patch security_syslog() is called once only in all syslog-related operations regardless of dmesg_restrict value. Fixes: 637241a900cb ("kmsg: honor dmesg_restrict sysctl on /dev/kmsg") Signed-off-by: Vasily Averin <vvs@virtuozzo.com> Cc: Kees Cook <keescook@chromium.org> Cc: Josh Boyer <jwboyer@redhat.com> Cc: Eric Paris <eparis@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-03PM / sleep: Increase default DPM watchdog timeout to 60Takashi Iwai
commit fff3b16d2754a061a3549c4307a186423a0128fd upstream. Many harddisks (mostly WD ones) have firmware problems and take too long, more than 10 seconds, to resume from suspend. And this often exceeds the default DPM watchdog timeout (12 seconds), resulting in a kernel panic out of sudden. Since most distros just take the default as is, we should give a bit more safer value. This patch increases the default value from 12 seconds to one minute, which has been confirmed to be long enough for such problematic disks. Link: https://bugzilla.kernel.org/show_bug.cgi?id=91921 Fixes: 70fea60d888d (PM / Sleep: Detect device suspend/resume lockup and log event) Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-03tracing: Have branch tracer use recursive field of task structSteven Rostedt (Red Hat)
commit 6224beb12e190ff11f3c7d4bf50cb2922878f600 upstream. Fengguang Wu's tests triggered a bug in the branch tracer's start up test when CONFIG_DEBUG_PREEMPT set. This was because that config adds some debug logic in the per cpu field, which calls back into the branch tracer. The branch tracer has its own recursive checks, but uses a per cpu variable to implement it. If retrieving the per cpu variable calls back into the branch tracer, you can see how things will break. Instead of using a per cpu variable, use the trace_recursion field of the current task struct. Simply set a bit when entering the branch tracing and clear it when leaving. If the bit is set on entry, just don't do the tracing. There's also the case with lockdep, as the local_irq_save() called before the recursion can also trigger code that can call back into the function. Changing that to a raw_local_irq_save() will protect that as well. This prevents the recursion and the inevitable crash that follows. Link: http://lkml.kernel.org/r/20150630141803.GA28071@wfg-t540p.sh.intel.com Reported-by: Fengguang Wu <fengguang.wu@intel.com> Tested-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-03tracing: Fix typo from "static inlin" to "static inline"Steven Rostedt (Red Hat)
commit cc9e4bde03f2b4cfba52406c021364cbd2a4a0f3 upstream. The trace.h header when called without CONFIG_EVENT_TRACING enabled (seldom done), will not compile because of a typo in the protocol of trace_event_enum_update(). Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-03tracing/filter: Do not allow infix to exceed end of stringSteven Rostedt (Red Hat)
commit 6b88f44e161b9ee2a803e5b2b1fbcf4e20e8b980 upstream. While debugging a WARN_ON() for filtering, I found that it is possible for the filter string to be referenced after its end. With the filter: # echo '>' > /sys/kernel/debug/events/ext4/ext4_truncate_exit/filter The filter_parse() function can call infix_get_op() which calls infix_advance() that updates the infix filter pointers for the cnt and tail without checking if the filter is already at the end, which will put the cnt to zero and the tail beyond the end. The loop then calls infix_next() that has ps->infix.cnt--; return ps->infix.string[ps->infix.tail++]; The cnt will now be below zero, and the tail that is returned is already passed the end of the filter string. So far the allocation of the filter string usually has some buffer that is zeroed out, but if the filter string is of the exact size of the allocated buffer there's no guarantee that the charater after the nul terminating character will be zero. Luckily, only root can write to the filter. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-08-03tracing/filter: Do not WARN on operand count going below zeroSteven Rostedt (Red Hat)
commit b4875bbe7e68f139bd3383828ae8e994a0df6d28 upstream. When testing the fix for the trace filter, I could not come up with a scenario where the operand count goes below zero, so I added a WARN_ON_ONCE(cnt < 0) to the logic. But there is legitimate case that it can happen (although the filter would be wrong). # echo '>' > /sys/kernel/debug/events/ext4/ext4_truncate_exit/filter That is, a single operation without any operands will hit the path where the WARN_ON_ONCE() can trigger. Although this is harmless, and the filter is reported as a error. But instead of spitting out a warning to the kernel dmesg, just fail nicely and report it via the proper channels. Link: http://lkml.kernel.org/r/558C6082.90608@oracle.com Reported-by: Vince Weaver <vincent.weaver@maine.edu> Reported-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-07-21genirq: devres: Fix testing return value of request_any_context_irq()Axel Lin
commit 63781394c540dd9e666a6b21d70b64dd52bce76e upstream. request_any_context_irq() returns a negative value on failure. It returns either IRQC_IS_HARDIRQ or IRQC_IS_NESTED on success. So fix testing return value of request_any_context_irq(). Also fixup the return value of devm_request_any_context_irq() to make it consistent with request_any_context_irq(). Fixes: 0668d3065128 ("genirq: Add devm_request_any_context_irq()") Signed-off-by: Axel Lin <axel.lin@ingics.com> Reviewed-by: Stephen Boyd <sboyd@codeaurora.org> Link: http://lkml.kernel.org/r/1431334978.17783.4.camel@ingics.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-07-21livepatch: add module locking around kallsyms callsMiroslav Benes
commit 9a1bd63cdae4b623494c4ebaf723a91c35ec49fb upstream. The list of loaded modules is walked through in module_kallsyms_on_each_symbol (called by kallsyms_on_each_symbol). The module_mutex lock should be acquired to prevent potential corruptions in the list. This was uncovered with new lockdep asserts in module code introduced by the commit 0be964be0d45 ("module: Sanitize RCU usage and locking") in recent next- trees. Signed-off-by: Miroslav Benes <mbenes@suse.cz> Acked-by: Josh Poimboeuf <jpoimboe@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-07-21rcu: Correctly handle non-empty Tiny RCU callback list with none readyPaul E. McKenney
commit 6e91f8cb138625be96070b778d9ba71ce520ea7e upstream. If, at the time __rcu_process_callbacks() is invoked, there are callbacks in Tiny RCU's callback list, but none of them are ready to be invoked, the current list-management code will knit the non-ready callbacks out of the list. This can result in hangs and possibly worse. This commit therefore inserts a check for there being no callbacks that can be invoked immediately. This bug is unlikely to occur -- you have to get a new callback between the time rcu_sched_qs() or rcu_bh_qs() was called, but before we get to __rcu_process_callbacks(). It was detected by the addition of RCU-bh testing to rcutorture, which in turn was instigated by Iftekhar Ahmed's mutation testing. Although this bug was made much more likely by 915e8a4fe45e (rcu: Remove fastpath from __rcu_process_callbacks()), this did not cause the bug, but rather made it much more probable. That said, it takes more than 40 hours of rcutorture testing, on average, for this bug to appear, so this fix cannot be considered an emergency. Signed-off-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-07-21sysfs: Create mountpoints with sysfs_create_mount_pointEric W. Biederman
commit f9bb48825a6b5d02f4cabcc78967c75db903dcdc upstream. This allows for better documentation in the code and it allows for a simpler and fully correct version of fs_fully_visible to be written. The mount points converted and their filesystems are: /sys/hypervisor/s390/ s390_hypfs /sys/kernel/config/ configfs /sys/kernel/debug/ debugfs /sys/firmware/efi/efivars/ efivarfs /sys/fs/fuse/connections/ fusectl /sys/fs/pstore/ pstore /sys/kernel/tracing/ tracefs /sys/fs/cgroup/ cgroup /sys/kernel/security/ securityfs /sys/fs/selinux/ selinuxfs /sys/fs/smackfs/ smackfs Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-07-21sysctl: Allow creating permanently empty directories that serve as mountpoints.Eric W. Biederman
commit f9bd6733d3f11e24f3949becf277507d422ee1eb upstream. Add a magic sysctl table sysctl_mount_point that when used to create a directory forces that directory to be permanently empty. Update the code to use make_empty_dir_inode when accessing permanently empty directories. Update the code to not allow adding to permanently empty directories. Update /proc/sys/fs/binfmt_misc to be a permanently empty directory. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-29perf: Fix ring_buffer_attach() RCU sync, againOleg Nesterov
commit 2f993cf093643b98477c421fa2b9a98dcc940323 upstream. While looking for other users of get_state/cond_sync. I Found ring_buffer_attach() and it looks obviously buggy? Don't we need to ensure that we have "synchronize" _between_ list_del() and list_add() ? IOW. Suppose that ring_buffer_attach() preempts right_after get_state_synchronize_rcu() and gp completes before spin_lock(). In this case cond_synchronize_rcu() does nothing and we reuse ->rb_entry without waiting for gp in between? It also moves the ->rcu_pending check under "if (rb)", to make it more readable imo. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: dave@stgolabs.net Cc: der.herr@hofr.at Cc: josh@joshtriplett.org Cc: tj@kernel.org Fixes: b69cf53640da ("perf: Fix a race between ring_buffer_detach() and ring_buffer_attach()") Link: http://lkml.kernel.org/r/20150530200425.GA15748@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-17Merge tag 'trace-fix-filter-4.1-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing filter fix from Steven Rostedt: "Vince Weaver reported a warning when he added perf event filters into his fuzzer tests. There's a missing check of balanced operations when parenthesis are used, and this triggers a WARN_ON() and when reading the failure, the filter reports no failure occurred. The operands were not being checked if they match, this adds that" * tag 'trace-fix-filter-4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Have filter check for balanced ops
2015-06-17tracing: Have filter check for balanced opsSteven Rostedt
When the following filter is used it causes a warning to trigger: # cd /sys/kernel/debug/tracing # echo "((dev==1)blocks==2)" > events/ext4/ext4_truncate_exit/filter -bash: echo: write error: Invalid argument # cat events/ext4/ext4_truncate_exit/filter ((dev==1)blocks==2) ^ parse_error: No error ------------[ cut here ]------------ WARNING: CPU: 2 PID: 1223 at kernel/trace/trace_events_filter.c:1640 replace_preds+0x3c5/0x990() Modules linked in: bnep lockd grace bluetooth ... CPU: 3 PID: 1223 Comm: bash Tainted: G W 4.1.0-rc3-test+ #450 Hardware name: Hewlett-Packard HP Compaq Pro 6300 SFF/339A, BIOS K01 v02.05 05/07/2012 0000000000000668 ffff8800c106bc98 ffffffff816ed4f9 ffff88011ead0cf0 0000000000000000 ffff8800c106bcd8 ffffffff8107fb07 ffffffff8136b46c ffff8800c7d81d48 ffff8800d4c2bc00 ffff8800d4d4f920 00000000ffffffea Call Trace: [<ffffffff816ed4f9>] dump_stack+0x4c/0x6e [<ffffffff8107fb07>] warn_slowpath_common+0x97/0xe0 [<ffffffff8136b46c>] ? _kstrtoull+0x2c/0x80 [<ffffffff8107fb6a>] warn_slowpath_null+0x1a/0x20 [<ffffffff81159065>] replace_preds+0x3c5/0x990 [<ffffffff811596b2>] create_filter+0x82/0xb0 [<ffffffff81159944>] apply_event_filter+0xd4/0x180 [<ffffffff81152bbf>] event_filter_write+0x8f/0x120 [<ffffffff811db2a8>] __vfs_write+0x28/0xe0 [<ffffffff811dda43>] ? __sb_start_write+0x53/0xf0 [<ffffffff812e51e0>] ? security_file_permission+0x30/0xc0 [<ffffffff811dc408>] vfs_write+0xb8/0x1b0 [<ffffffff811dc72f>] SyS_write+0x4f/0xb0 [<ffffffff816f5217>] system_call_fastpath+0x12/0x6a ---[ end trace e11028bd95818dcd ]--- Worse yet, reading the error message (the filter again) it says that there was no error, when there clearly was. The issue is that the code that checks the input does not check for balanced ops. That is, having an op between a closed parenthesis and the next token. This would only cause a warning, and fail out before doing any real harm, but it should still not caues a warning, and the error reported should work: # cd /sys/kernel/debug/tracing # echo "((dev==1)blocks==2)" > events/ext4/ext4_truncate_exit/filter -bash: echo: write error: Invalid argument # cat events/ext4/ext4_truncate_exit/filter ((dev==1)blocks==2) ^ parse_error: Meaningless filter expression And give no kernel warning. Link: http://lkml.kernel.org/r/20150615175025.7e809215@gandalf.local.home Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@redhat.com> Cc: Arnaldo Carvalho de Melo <acme@kernel.org> Cc: stable@vger.kernel.org # 2.6.31+ Reported-by: Vince Weaver <vincent.weaver@maine.edu> Tested-by: Vince Weaver <vincent.weaver@maine.edu> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-06-14Merge branch 'locking-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull lockdep fix from Ingo Molnar: "A lockdep/modules unload race fix that can oops" * 'locking-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: lockdep: Fix a race between /proc/lock_stat and module unload
2015-06-11Merge tag 'trace-rb-bm-fix-4.1-rc7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull ring buffer benchmark buglet fix from Steven Rostedt: "Wang Long fixed a minor bug in the module parameter for the ring buffer benchmark, where the produce_fifo was being ignored and the producer thread's priority was being set with the consumer_fifo parameter" * tag 'trace-rb-bm-fix-4.1-rc7' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: ring-buffer-benchmark: Fix the wrong sched_priority of producer
2015-06-11ring-buffer-benchmark: Fix the wrong sched_priority of producerWang Long
The producer should be used producer_fifo as its sched_priority, so correct it. Link: http://lkml.kernel.org/r/1433923957-67842-1-git-send-email-long.wanglong@huawei.com Cc: stable@vger.kernel.org # 2.6.33+ Signed-off-by: Wang Long <long.wanglong@huawei.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2015-06-10sched, numa: do not hint for NUMA balancing on VM_MIXEDMAP mappingsMel Gorman
Jovi Zhangwei reported the following problem Below kernel vm bug can be triggered by tcpdump which mmaped a lot of pages with GFP_COMP flag. [Mon May 25 05:29:33 2015] page:ffffea0015414000 count:66 mapcount:1 mapping: (null) index:0x0 [Mon May 25 05:29:33 2015] flags: 0x20047580004000(head) [Mon May 25 05:29:33 2015] page dumped because: VM_BUG_ON_PAGE(compound_order(page) && !PageTransHuge(page)) [Mon May 25 05:29:33 2015] ------------[ cut here ]------------ [Mon May 25 05:29:33 2015] kernel BUG at mm/migrate.c:1661! [Mon May 25 05:29:33 2015] invalid opcode: 0000 [#1] SMP In this case it was triggered by running tcpdump but it's not necessary reproducible on all systems. sudo tcpdump -i bond0.100 'tcp port 4242' -c 100000000000 -w 4242.pcap Compound pages cannot be migrated and it was not expected that such pages be marked for NUMA balancing. This did not take into account that drivers such as net/packet/af_packet.c may insert compound pages into userspace with vm_insert_page. This patch tells the NUMA balancing protection scanner to skip all VM_MIXEDMAP mappings which avoids the possibility that compound pages are marked for migration. Signed-off-by: Mel Gorman <mgorman@suse.de> Reported-by: Jovi Zhangwei <jovi@cloudflare.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-07lockdep: Fix a race between /proc/lock_stat and module unloadPeter Zijlstra
The lock_class iteration of /proc/lock_stat is not serialized against the lockdep_free_key_range() call from module unload. Therefore it can happen that we find a class of which ->name/->key are no longer valid. There is a further bug in zap_class() that left ->name dangling. Cure this. Use RCU_INIT_POINTER() because NULL. Since lockdep_free_key_range() is rcu_sched serialized, we can read both ->name and ->key under rcu_read_lock_sched() (preempt-disable) and be assured that if we observe a !NULL value it stays safe to use for as long as we hold that lock. If we observe both NULL, skip the entry. Reported-by: Jerome Marchand <jmarchan@redhat.com> Tested-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20150602105013.GS3644@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-06-05Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "The biggest chunk of the changes are two regression fixes: a HT workaround fix and an event-group scheduling fix. It's been verified with 5 days of fuzzer testing. Other fixes: - eBPF fix - a BIOS breakage detection fix - PMU driver fixes" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf/x86/intel/pt: Fix a refactoring bug perf/x86: Tweak broken BIOS rules during check_hw_exists() perf/x86/intel/pt: Untangle pt_buffer_reset_markers() perf: Disallow sparse AUX allocations for non-SG PMUs in overwrite mode perf/x86: Improve HT workaround GP counter constraint perf/x86: Fix event/group validation perf: Fix race in BPF program unregister
2015-06-04compat: cleanup coding in compat_get_bitmap() and compat_put_bitmap()Helge Deller
In the functions compat_get_bitmap() and compat_put_bitmap() the variable nr_compat_longs stores how many compat_ulong_t words should be copied in a loop. The copy loop itself is this: if (nr_compat_longs-- > 0) { if (__get_user(um, umask)) return -EFAULT; } else { um = 0; } Since nr_compat_longs gets unconditionally decremented in each loop and since it's type is unsigned this could theoretically lead to out of bounds accesses to userspace if nr_compat_longs wraps around to (unsigned)(-1). Although the callers currently do not trigger out-of-bounds accesses, we should better implement the loop in a safe way to completely avoid such warp-arounds. Signed-off-by: Helge Deller <deller@gmx.de> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk>
2015-05-29Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull fixes for cpumask and modules from Rusty Russell: "** NOW WITH TESTING! ** Two fixes which got lost in my recent distraction. One is a weird cpumask function which needed to be rewritten, the other is a module bug which is cc:stable" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: cpumask_set_cpu_local_first => cpumask_local_spread, lament module: Call module notifier on failure after complete_formation()
2015-05-27perf: Disallow sparse AUX allocations for non-SG PMUs in overwrite modeAlexander Shishkin
PMUs that don't support hardware scatter tables require big contiguous chunks of memory and a PMI to switch between them. However, in overwrite using a PMI for this purpose adds extra overhead that the users would like to avoid. Thus, in overwrite mode for such PMUs we can only allow one contiguous chunk for the entire requested buffer. This patch changes the behavior accordingly, so that if the buddy allocator fails to come up with a single high-order chunk for the entire requested buffer, the allocation will fail. Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: acme@infradead.org Cc: adrian.hunter@intel.com Cc: hpa@zytor.com Link: http://lkml.kernel.org/r/1432308626-18845-2-git-send-email-alexander.shishkin@linux.intel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-27perf: Fix race in BPF program unregisterAlexei Starovoitov
there is a race between perf_event_free_bpf_prog() and free_trace_kprobe(): __free_event() event->destroy(event) tp_perf_event_destroy() perf_trace_destroy() perf_trace_event_unreg() which is dropping event->tp_event->perf_refcount and allows to proceed in: unregister_trace_kprobe() unregister_kprobe_event() trace_remove_event_call() probe_remove_event_call() free_trace_kprobe() while __free_event does: call_rcu(&event->rcu_head, free_event_rcu); free_event_rcu() perf_event_free_bpf_prog() To fix the race simply move perf_event_free_bpf_prog() before event->destroy(), since event->tp_event is still valid at that point. Note, perf_trace_destroy() is not racing with trace_remove_event_call() since they both grab event_mutex. Reported-by: Wang Nan <wangnan0@huawei.com> Signed-off-by: Alexei Starovoitov <ast@plumgrid.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: lizefan@huawei.com Cc: pi3orama@163.com Fixes: 2541517c32be ("tracing, perf: Implement BPF programs attached to kprobes") Link: http://lkml.kernel.org/r/1431717321-28772-1-git-send-email-ast@plumgrid.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-05-23Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fix from Thomas Gleixner: "One more fix from the timer departement: - Handle division of negative nanosecond values proper on 32bit. A recent cleanup wrecked the sign handling of the dividend and dropped the check for negative divisors" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: ktime: Fix ktime_divns to do signed division
