Trinity discovered that we fail to check all 64 bits of
attr.config passed by user space, resulting to out-of-bounds
access of the perf_swevent_enabled array in
sw_perf_event_destroy().
Introduced in commit b0a873ebb ("perf: Register PMU
implementations").
Signed-off-by: Tommi Rantala <tt.rantala@gmail.com>
Cc: davej@redhat.com
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/1365882554-30259-1-git-send-email-tt.rantala@gmail.com
The game will creat a lot of hr timer, and make cpu tick broadcast
bit not been clear all time. It will cause user space thread not
been scheduled.
Signed-off-by: guoyin.chen <guoyin.chen@freescale.com>
drivers/video/mxc/ldb.c
export usb_suspend, usb_resume, and pm_mutex
Signed-off-by: Peter Chen <peter.chen@freescale.com>
There are so many retries happen on the per-cpu event device
when run the command 'cat /proc/timer_list', as following:
root@~$ cat /proc/timer_list
Timer List Version: v0.6
HRTIMER_MAX_CLOCK_BASES: 3
now at 3297691988044 nsecs
Tick Device: mode: 1
Per CPU device: 0
Clock Event Device: local_timer
max_delta_ns: 8624432320
min_delta_ns: 1000
mult: 2138893713
shift: 32
mode: 3
next_event: 3297700000000 nsecs
set_next_event: twd_set_next_event
set_mode: twd_set_mode
event_handler: hrtimer_interrupt
retries: 36383
the reason is that the local timer will stop when enter C3 state,
we need switch the local timer to bc timer when enter the state
and switch back when exit from the that state.The code is like this:
void arch_idle(void)
clockevents_notify(CLOCK_EVT_NOTIFY_BROADCAST_ENTER, &cpu);
enter_the_wait_mode();
clockevents_notify(CLOCK_EVT_NOTIFY_BROADCAST_EXIT, &cpu);
when the broadcast timer interrupt arrives(this interrupt just wakeup
the ARM, and ARM has no chance to handle it since local irq is disabled.
In fact it's disabled in cpu_idle() of arch/arm/kernel/process.c)
the broadcast timer interrupt will wake up the CPU and run:
clockevents_notify(CLOCK_EVT_NOTIFY_BROADCAST_EXIT, &cpu); ->
tick_broadcast_oneshot_control(...);
tick_program_event(dev->next_event, 1);
tick_dev_program_event(dev, expires, force);
for (i = 0;;) {
int ret = clockevents_program_event(dev, expires, now);
if (!ret || !force)
return ret;
dev->retries++;
now = ktime_get();
expires = ktime_add_ns(now, dev->min_delta_ns);
delta = ktime_to_ns(ktime_sub(expires, now));
if (delta <= 0)
return -ETIME;
when the bc timer interrupt arrives, which means the last local timer
expires too. so, clockevents_program_event will return -ETIME, which will
cause the dev->retries++ when retry to program the expired timer.
Even under the worst case, after the re-program the expired timer,
then CPU enter idle quickly before the re-progam timer expired,
it will make system ping-pang forever if no interrupt happen.
We have found the ping-pang issue during the video play-back test.
system will freeze and video not playing for sometime until other interrupt
occured to break the error condition.
The detailed information, please refer to the LKML:https://lkml.org/lkml/2013/2/20/216
which posted by Jason Liu.
Signed-off-by: Jason Liu <r64343@freescale.com>
Tested-by: Jason Liu <r64343@freescale.com>
Tested-by: Santosh Shilimkar <santosh.shilimkar@ti.com>
Tested-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
arch/arm/configs/imx6_defconfig
arch/arm/configs/imx6_updater_defconfig
arch/arm/configs/imx6s_defconfig
arch/arm/include/asm/dma-mapping.h
arch/arm/kernel/smp.c
arch/arm/mach-mx6/Kconfig
arch/arm/mach-mx6/board-mx6dl_arm2.h
arch/arm/mach-mx6/board-mx6dl_sabresd.h
arch/arm/mach-mx6/board-mx6q_arm2.c
arch/arm/mach-mx6/board-mx6q_arm2.h
arch/arm/mach-mx6/board-mx6q_sabreauto.c
arch/arm/mach-mx6/board-mx6q_sabreauto.h
arch/arm/mach-mx6/board-mx6q_sabrelite.c
arch/arm/mach-mx6/board-mx6q_sabresd.c
arch/arm/mach-mx6/board-mx6q_sabresd.h
arch/arm/mach-mx6/board-mx6sl_arm2.c
arch/arm/mach-mx6/board-mx6sl_arm2.h
arch/arm/mach-mx6/board-mx6solo_sabreauto.h
arch/arm/mach-mx6/bus_freq.c
arch/arm/mach-mx6/clock.c
arch/arm/mach-mx6/clock_mx6sl.c
arch/arm/mach-mx6/cpu.c
arch/arm/mach-mx6/crm_regs.h
arch/arm/mach-mx6/devices-imx6q.h
arch/arm/mach-mx6/devices.c
arch/arm/mach-mx6/mx6_anatop_regulator.c
arch/arm/mach-mx6/pcie.c
arch/arm/mach-mx6/system.c
arch/arm/mm/dma-mapping.c
arch/arm/plat-mxc/devices/Makefile
arch/arm/plat-mxc/devices/platform-imx-dcp.c
arch/arm/plat-mxc/devices/platform-imx-ocotp.c
arch/arm/plat-mxc/devices/platform-imx-rngb.c
arch/arm/plat-mxc/devices/platform-mxc_hdmi.c
arch/arm/plat-mxc/include/mach/devices-common.h
arch/arm/plat-mxc/include/mach/esdhc.h
arch/arm/plat-mxc/include/mach/iomux-mx6dl.h
arch/arm/plat-mxc/include/mach/iomux-mx6q.h
arch/arm/plat-mxc/include/mach/memory.h
arch/arm/plat-mxc/include/mach/mx6.h
arch/arm/plat-mxc/include/mach/mxc_edid.h
arch/arm/plat-mxc/include/mach/mxc_hdmi.h
arch/arm/plat-mxc/system.c
drivers/Kconfig
drivers/char/hw_random/fsl-rngc.c
drivers/cpufreq/Makefile
drivers/cpufreq/cpufreq_interactive.c
drivers/crypto/Kconfig
drivers/crypto/caam/caamalg.c
drivers/crypto/caam/compat.h
drivers/crypto/caam/ctrl.c
drivers/crypto/caam/desc_constr.h
drivers/crypto/caam/intern.h
drivers/crypto/dcp.c
drivers/dma/pch_dma.c
drivers/input/keyboard/gpio_keys.c
drivers/input/touchscreen/egalax_ts.c
drivers/input/touchscreen/max11801_ts.c
drivers/media/video/mxc/capture/Kconfig
drivers/media/video/mxc/capture/adv7180.c
drivers/media/video/mxc/capture/ipu_csi_enc.c
drivers/media/video/mxc/capture/ipu_prp_vf_sdc.c
drivers/media/video/mxc/capture/ipu_prp_vf_sdc_bg.c
drivers/media/video/mxc/capture/mxc_v4l2_capture.c
drivers/media/video/mxc/capture/ov5640_mipi.c
drivers/media/video/mxc/output/mxc_vout.c
drivers/misc/Kconfig
drivers/misc/Makefile
drivers/mmc/card/block.c
drivers/mmc/core/mmc.c
drivers/mmc/host/mmci.c
drivers/mmc/host/sdhci-esdhc-imx.c
drivers/mmc/host/sdhci.c
drivers/mmc/host/sdhci.h
drivers/mxc/Kconfig
drivers/mxc/Makefile
drivers/mxc/asrc/mxc_asrc.c
drivers/mxc/gpu-viv/arch/XAQ2/hal/kernel/gc_hal_kernel_context.c
drivers/mxc/gpu-viv/arch/XAQ2/hal/kernel/gc_hal_kernel_hardware.c
drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel.c
drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel.h
drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel_command.c
drivers/mxc/gpu-viv/hal/kernel/gc_hal_kernel_event.c
drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal.h
drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal_base.h
drivers/mxc/gpu-viv/hal/kernel/inc/gc_hal_options.h
drivers/mxc/gpu-viv/hal/os/linux/kernel/gc_hal_kernel_os.c
drivers/mxc/ipu3/ipu_device.c
drivers/mxc/vpu/mxc_vpu.c
drivers/net/fec.c
drivers/net/wireless/Makefile
drivers/power/sabresd_battery.c
drivers/regulator/core.c
drivers/tty/serial/imx.c
drivers/usb/core/hub.c
drivers/usb/gadget/arcotg_udc.c
drivers/usb/gadget/fsl_updater.c
drivers/usb/gadget/inode.c
drivers/usb/host/ehci-hub.c
drivers/video/mxc/mipi_dsi.c
drivers/video/mxc/mxc_dispdrv.c
drivers/video/mxc/mxc_dispdrv.h
drivers/video/mxc/mxc_edid.c
drivers/video/mxc/mxc_elcdif_fb.c
drivers/video/mxc/mxc_ipuv3_fb.c
drivers/video/mxc/mxc_spdc_fb.c
drivers/video/mxc_hdmi.c
drivers/watchdog/imx2_wdt.c
fs/proc/base.c
include/linux/mmc/host.h
include/linux/mmc/sdhci.h
include/linux/mxc_v4l2.h
kernel/power/main.c
sound/soc/codecs/mxc_hdmi.c
sound/soc/codecs/mxc_spdif.c
sound/soc/codecs/wm8962.c
sound/soc/imx/Kconfig
sound/soc/imx/Makefile
sound/soc/imx/imx-cs42888.c
sound/soc/imx/imx-esai.c
sound/soc/imx/imx-wm8958.c
sound/soc/imx/imx-wm8962.c
When performing cpu hotplug tests the kernel printk log buffer gets flooded
with pointless "Switched to NOHz mode..." messages. Especially when afterwards
analyzing a dump this might have removed more interesting stuff out of the
buffer.
Assuming that switching to NOHz mode simply works just remove the printk.
Link: http://lkml.kernel.org/r/20110823112046.GB2540@osiris.boeblingen.de.ibm.com
Stepan found:
CPU0 CPUn
_cpu_up()
__cpu_up()
boostrap()
notify_cpu_starting()
set_cpu_online()
while (!cpu_active())
cpu_relax()
<PREEMPT-out>
smp_call_function(.wait=1)
/* we find cpu_online() is true */
arch_send_call_function_ipi_mask()
/* wait-forever-more */
<PREEMPT-in>
local_irq_enable()
cpu_notify(CPU_ONLINE)
sched_cpu_active()
set_cpu_active()
Now the purpose of cpu_active is mostly with bringing down a cpu, where
we mark it !active to avoid the load-balancer from moving tasks to it
while we tear down the cpu. This is required because we only update the
sched_domain tree after we brought the cpu-down. And this is needed so
that some tasks can still run while we bring it down, we just don't want
new tasks to appear.
On cpu-up however the sched_domain tree doesn't yet include the new cpu,
so its invisible to the load-balancer, regardless of the active state.
So instead of setting the active state after we boot the new cpu (and
consequently having to wait for it before enabling interrupts) set the
cpu active before we set it online and avoid the whole mess.
Reported-by: Stepan Moskovchenko <stepanm@codeaurora.org>
Link: http://lkml.kernel.org/r/1323965362.18942.71.camel@twins
No need to assign ret in each case and break. Simply return the result
of the handler function directly.
Cc: Darren Hart <dvhart@linux.intel.com>
Signed-off-by: Huang Shijie <b32955@freescale.com>
cpufreq: interactive: New 'interactive' governor
This governor is designed for latency-sensitive workloads, such as
interactive user interfaces. The interactive governor aims to be
significantly more responsive to ramp CPU quickly up when CPU-intensive
activity begins.
Existing governors sample CPU load at a particular rate, typically
every X ms. This can lead to under-powering UI threads for the period of
time during which the user begins interacting with a previously-idle system
until the next sample period happens.
The 'interactive' governor uses a different approach. Instead of sampling
the CPU at a specified rate, the governor will check whether to scale the
CPU frequency up soon after coming out of idle. When the CPU comes out of
idle, a timer is configured to fire within 1-2 ticks. If the CPU is very
busy from exiting idle to when the timer fires then we assume the CPU is
underpowered and ramp to MAX speed.
If the CPU was not sufficiently busy to immediately ramp to MAX speed, then
the governor evaluates the CPU load since the last speed adjustment,
choosing the highest value between that longer-term load or the short-term
load since idle exit to determine the CPU speed to ramp to.
A realtime thread is used for scaling up, giving the remaining tasks the
CPU performance benefit, unlike existing governors which are more likely to
schedule rampup work to occur after your performance starved tasks have
completed.
The tuneables for this governor are:
/sys/devices/system/cpu/cpufreq/interactive/min_sample_time:
The minimum amount of time to spend at the current frequency before
ramping down. This is to ensure that the governor has seen enough
historic CPU load data to determine the appropriate workload.
/sys/devices/system/cpu/cpufreq/interactive/go_maxspeed_load
The CPU load at which to ramp to max speed.
Signed-off-by: Anson Huang <b20788@freescale.com>
Change a single occurrence of "unlcoked" into "unlocked".
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
Cc: Darren Hart <dvhltc@us.ibm.com>
The variables here are really not used uninitialized.
kernel/futex.c: In function 'fixup_pi_state_owner.clone.17':
kernel/futex.c:1582:6: warning: 'curval' may be used uninitialized in this function
kernel/futex.c: In function 'handle_futex_death':
kernel/futex.c:2486:6: warning: 'nval' may be used uninitialized in this function
kernel/futex.c: In function 'do_futex':
kernel/futex.c:863:11: warning: 'curval' may be used uninitialized in this function
kernel/futex.c:828:6: note: 'curval' was declared here
kernel/futex.c:898:5: warning: 'oldval' may be used uninitialized in this function
kernel/futex.c:890:6: note: 'oldval' was declared here
Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com>
Acked-by: Darren Hart <dvhart@linux.intel.com>
This was legacy code brought over from the RT tree and
is no longer necessary.
Signed-off-by: Dima Zavin <dima@android.com>
Cc: Daniel Walker <dwalker@codeaurora.org>
Cc: Lai Jiangshan <laijs@cn.fujitsu.com>
Link: http://lkml.kernel.org/r/1310084879-10351-2-git-send-email-dima@android.com
Add work around to the reboot issue of SMP, with
SMP, all the CPUs need to do _rcu_barrier, if we
enqueue an rcu callback, we need to make sure CPU
tick to stay alive until we take care of those by
completing the appropriate grace period.
This work around only work when the reboot command
issue, so it didn't impact normal kernel feature.
There was some driver is slow on suspend/resume,
but some embeded system like eReader,Cellphone
are time sensitive,this commit will report the slow
driver on suspend/resume, the default value is 500us(0.5ms)
Also, the threshold can be change by modify
'/sys/power/device_suspend_time_threshold' to change the threshold,
it is in microsecond.
The output is like:
PM: device platform:soc-audio.2 suspend too slow, takes 606.696 msecs
PM: device platform:mxc_sdc_fb.1 suspend too slow, takes 7.708 msecs
the default state of suspend driver is default off,
if you want to debug the suspend time, echo time in
microsecond(u Second) to /sys/powe/device_suspend_time_threshold
eg: I want to know which driver suspend & resume takes
more that 0.5 ms (500 us), you can just :
ehco 500 > /sys/power/device_suspend_time_threshold
Signed-off-by: Zhang Jiejing <jiejing.zhang@freescale.com>
commit a841f8cef4bb124f0f5563314d0beaf2e1249d72 upstream.
It does not get processed because sched_domain_level_max is 0 at the
time that setup_relax_domain_level() is run.
Simply accept the value as it is, as we don't know the value of
sched_domain_level_max until sched domain construction is completed.
Fix sched_relax_domain_level in cpuset. The build_sched_domain() routine calls
the set_domain_attribute() routine prior to setting the sd->level, however,
the set_domain_attribute() routine relies on the sd->level to decide whether
idle load balancing will be off/on.
Signed-off-by: Dimitri Sivanich <sivanich@sgi.com>
Link: http://lkml.kernel.org/r/20120605184436.GA15668@sgi.com
active
commit 544ecf310f0e7f51fa057ac2a295fc1b3b35a9d3 upstream.
worker_enter_idle() has WARN_ON_ONCE() which triggers if nr_running
isn't zero when every worker is idle. This can trigger spuriously
while a cpu is going down due to the way trustee sets %WORKER_ROGUE
and zaps nr_running.
It first sets %WORKER_ROGUE on all workers without updating
nr_running, releases gcwq->lock, schedules, regrabs gcwq->lock and
then zaps nr_running. If the last running worker enters idle
inbetween, it would see stale nr_running which hasn't been zapped yet
and trigger the WARN_ON_ONCE().
Fix it by performing the sanity check iff the trustee is idle.
Reported-by: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
buffer.
The CPU hotplug notifications sent out by the _cpu_up() and _cpu_down()
functions depend on the value of the 'tasks_frozen' argument passed to them
(which indicates whether tasks have been frozen or not).
(Examples for such CPU hotplug notifications: CPU_ONLINE, CPU_ONLINE_FROZEN,
CPU_DEAD, CPU_DEAD_FROZEN).
Thus, it is essential that while the callbacks for those notifications are
running, the state of the system with respect to the tasks being frozen or
not remains unchanged, *throughout that duration*. Hence there is a need for
synchronizing the CPU hotplug code with the freezer subsystem.
Since the freezer is involved only in the Suspend/Hibernate call paths, this
patch hooks the CPU hotplug code to the suspend/hibernate notifiers
PM_[SUSPEND|HIBERNATE]_PREPARE and PM_POST_[SUSPEND|HIBERNATE] to prevent
the race between CPU hotplug and freezer, thus ensuring that CPU hotplug
notifications will always be run with the state of the system really being
what the notifications indicate, _throughout_ their execution time.
Signed-off-by: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com>
commit b7dafa0ef3145c31d7753be0a08b3cbda51f0209 upstream.
compat_sys_sigprocmask reads a smaller signal mask from userspace than
sigprogmask accepts for setting. So the high word of blocked.sig[0]
will be cleared, releasing any potentially blocked RT signal.
This was discovered via userspace code that relies on get/setcontext.
glibc's i386 versions of those functions use sigprogmask instead of
rt_sigprogmask to save/restore signal mask and caused RT signal
unblocking this way.
As suggested by Linus, this replaces the sys_sigprocmask based compat
version with one that open-codes the required logic, including the merge
of the existing blocked set with the new one provided on SIG_SETMASK.
Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com>
commit 5e2bf0142231194d36fdc9596b36a261ed2b9fe7 upstream.
Fork() failure post namespace creation for a child cloned with
CLONE_NEWPID leaks pid_namespace/mnt_cache due to proc being mounted
during creation, but not unmounted during cleanup. Call
pid_ns_release_proc() during cleanup.
Signed-off-by: Mike Galbraith <efault@gmx.de>
Acked-by: Oleg Nesterov <oleg@redhat.com>
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Louis Rilling <louis.rilling@kerlabs.com>
Stepan found:
CPU0 CPUn
_cpu_up()
__cpu_up()
boostrap()
set_cpu_online()
cpu_relax()
<PREEMPT-out>
<PREEMPT-in>
local_irq_enable()
sched_cpu_active()
set_cpu_active()
commit c308b56b5398779cd3da0f62ab26b0453494c3d4 upstream.
[ backported to 3.0 by Kerin Millar <kerframil@gmail.com>]
Various people reported nohz load tracking still being wrecked, but Doug
spotted the actual problem. We fold the nohz remainder in too soon,
causing us to loose samples and under-account.
So instead of playing catch-up up-front, always do a single load-fold
with whatever state we encounter and only then fold the nohz remainder
and play catch-up.
Reported-by: Doug Smythies <dsmythies@telus.net>
Reported-by: LesÅ=82aw Kope=C4=87 <leslaw.kopec@nasza-klasa.pl>
Reported-by: Aman Gupta <aman@tmm1.net>
Link: http://lkml.kernel.org/n/tip-4v31etnhgg9kwd6ocgx3rxl8@git.kernel.org
Cc: Kerin Millar <kerframil@gmail.com>
commit bdbb776f882f5ad431aa1e694c69c1c3d6a4a5b8 upstream.
It was possible to extract the robust list head address from a setuid
process if it had used set_robust_list(), allowing an ASLR info leak. This
changes the permission checks to be the same as those used for similar
info that comes out of /proc.
Running a setuid program that uses robust futexes would have had:
cred->euid != pcred->euid
cred->euid == pcred->uid
so the old permissions check would allow it. I'm not aware of any setuid
programs that use robust futexes, so this is just a preventative measure.
(This patch is based on changes from grsecurity.)
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: kernel-hardening@lists.openwall.com
Cc: spender@grsecurity.net
Link: http://lkml.kernel.org/r/20120319231253.GA20893@www.outflux.net
commit 6f103929f8979d2638e58d7f7fda0beefcb8ee7e upstream.
Fix tick_nohz_restart() to not use a stale ktime_t "now" value when
calling tick_do_update_jiffies64(now).
If we reach this point in the loop it means that we crossed a tick
boundary since we grabbed the "now" timestamp, so at this point "now"
refers to a time in the old jiffy, so using the old value for "now" is
incorrect, and is likely to give us a stale jiffies value.
In particular, the first time through the loop the
tick_do_update_jiffies64(now) call is always a no-op, since the
caller, tick_nohz_restart_sched_tick(), will have already called
tick_do_update_jiffies64(now) with that "now" value.
Note that tick_nohz_stop_sched_tick() already uses the correct
approach: when we notice we cross a jiffy boundary, grab a new
timestamp with ktime_get(), and *then* update jiffies.
Signed-off-by: Neal Cardwell <ncardwell@google.com>
Cc: Ben Segall <bsegall@google.com>
Link: http://lkml.kernel.org/r/1332875377-23014-1-git-send-email-ncardwell@google.com
arch/arm/kernel/traps.c
commit 79549c6dfda0603dba9a70a53467ce62d9335c33 upstream.
keyctl_session_to_parent(task) sets ->replacement_session_keyring,
it should be processed and cleared by key_replace_session_keyring().
However, this task can fork before it notices TIF_NOTIFY_RESUME and
the new child gets the bogus ->replacement_session_keyring copied by
dup_task_struct(). This is obviously wrong and, if nothing else, this
leads to put_cred(already_freed_cred).
change copy_creds() to clear this member. If copy_process() fails
before this point the wrong ->replacement_session_keyring doesn't
matter, exit_creds() won't be called.
commit 620f6e8e855d6d447688a5f67a4e176944a084e8 upstream.
Commit bfdc0b4 adds code to restrict access to dmesg_restrict,
however, it incorrectly alters kptr_restrict rather than
dmesg_restrict.
The original patch from Richard Weinberger
(https://lkml.org/lkml/2011/3/14/362) alters dmesg_restrict as
expected, and so the patch seems to have been misapplied.
This adds the CAP_SYS_ADMIN check to both dmesg_restrict and
kptr_restrict, since both are sensitive.
Reported-by: Phillip Lougher <plougher@redhat.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Acked-by: Richard Weinberger <richard@nod.at>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit 98b54aa1a2241b59372468bd1e9c2d207bdba54b upstream.
There is extra state information that needs to be exposed in the
kgdb_bpt structure for tracking how a breakpoint was installed. The
debug_core only uses the the probe_kernel_write() to install
breakpoints, but this is not enough for all the archs. Some arch such
as x86 need to use text_poke() in order to install a breakpoint into a
read only page.
Passing the kgdb_bpt structure to kgdb_arch_set_breakpoint() and
kgdb_arch_remove_breakpoint() allows other archs to set the type
variable which indicates how the breakpoint was installed.
Signed-off-by: Jason Wessel <jason.wessel@windriver.com>
commit 01de982abf8c9e10fc3089e10585cd2cc914bdab upstream.
8 hex characters tell only half the tale for 64 bit CPUs,
so use the appropriate length.
Link: http://lkml.kernel.org/r/1332411501-8059-2-git-send-email-wolfgang.mauerer@siemens.com
Signed-off-by: Wolfgang Mauerer <wolfgang.mauerer@siemens.com>
commit f5cb92ac82d06cb583c1f66666314c5c0a4d7913 upstream.
irq_move_masked_irq() checks the return code of
chip->irq_set_affinity() only for 0, but IRQ_SET_MASK_OK_NOCOPY is
also a valid return code, which is there to avoid a redundant copy of
the cpumask. But in case of IRQ_SET_MASK_OK_NOCOPY we not only avoid
the redundant copy, we also fail to adjust the thread affinity of an
eventually threaded interrupt handler.
Handle IRQ_SET_MASK_OK (==0) and IRQ_SET_MASK_OK_NOCOPY(==1) return
values correctly by checking the valid return values seperately.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Cc: Jiang Liu <liuj97@gmail.com>
Cc: Keping Chen <chenkeping@huawei.com>
Link: http://lkml.kernel.org/r/1333120296-13563-2-git-send-email-jiang.liu@huawei.com
Some of the newer futex PI opcodes do not check the cmpxchg enabled
variable and call unconditionally into the handling functions. Cover
all PI opcodes in a separate check.
Cc: stable@vger.kernel.org
commit f946eeb9313ff1470758e171a60fe7438a2ded3f upstream.
Module size was limited to 64MB, this was legacy limitation due to vmalloc()
which was removed a while ago.
Limiting module size to 64MB is both pointless and affects real world use
cases.
Cc: Tim Abbott <tim.abbott@oracle.com>
commit 05b4877f6a4f1ba4952d1222213d262bf8c132b7 upstream.
If create_basic_memory_bitmaps() fails, usermodehelpers are not re-enabled
before returning. Fix this. And while at it, reword the goto labels so that
they look more meaningful.
commit 540b60e24f3f4781d80e47122f0c4486a03375b8 upstream.
We do not want a bitwise AND between boolean operands
Signed-off-by: Alexander Gordeev <agordeev@redhat.com>
Link: http://lkml.kernel.org/r/20120309135912.GA2114@dhcp-26-207.brq.redhat.com
commit a09b659cd68c10ec6a30cb91ebd2c327fcd5bfe5 upstream.
In 2008, commit 0c5d1eb77a8be ("genirq: record trigger type") modified the
way set_irq_type() handles the 'no trigger' condition. However, this has
an adverse effect on PCMCIA support on Intel StrongARM and probably PXA
platforms.
PCMCIA has several status signals on the socket which can trigger
interrupts; some of these status signals depend on the card's mode
(whether it is configured in memory or IO mode). For example, cards have
a 'Ready/IRQ' signal: in memory mode, this provides an indication to
PCMCIA that the card has finished its power up initialization. In IO
mode, it provides the device interrupt signal. Other status signals
switch between on-board battery status and loud speaker output.
In classical PCMCIA implementations, where you have a specific socket
controller, the controller provides a method to mask interrupts from the
socket, and importantly ignore any state transitions on the pins which
correspond with interrupts once masked. This masking prevents unwanted
events caused by the removal and application of socket power being
forwarded.
However, on platforms where there is no socket controller, the PCMCIA
status and interrupt signals are routed to standard edge-triggered GPIOs.
These GPIOs can be configured to interrupt on rising edge, falling edge,
or never. This is where the problems start.
Edge triggered interrupts are required to record events while disabled via
the usual methods of {free,request,disable,enable}_irq() to prevent
problems with dropped interrupts (eg, the 8390 driver uses disable_irq()
to defer the delivery of interrupts). As a result, these interfaces can
not be used to implement the desired behaviour.
The side effect of this is that if the 'Ready/IRQ' GPIO is disabled via
disable_irq() on suspend, and enabled via enable_irq() after resume, we
will record the state transitions caused by powering events as valid
interrupts, and foward them to the card driver, which may attempt to
access a card which is not powered up.
This leads delays resume while drivers spin in their interrupt handlers,
and complaints from drivers before they realize what's happened.
Moreover, in the case of the 'Ready/IRQ' signal, this is requested and
freed by the card driver itself; the PCMCIA core has no idea whether the
interrupt is requested, and, therefore, whether a call to disable_irq()
would be valid. (We tried this around 2.4.17 / 2.5.1 kernel era, and
ended up throwing it out because of this problem.)
Therefore, it was decided back in around 2002 to disable the edge
triggering instead, resulting in all state transitions on the GPIO being
ignored. That's what we actually need the hardware to do.
The commit above changes this behaviour; it explicitly prevents the 'no
trigger' state being selected.
The reason that request_irq() does not accept the 'no trigger' state is
for compatibility with existing drivers which do not provide their desired
triggering configuration. The set_irq_type() function is 'new' and not
used by non-trigger aware drivers.
Therefore, revert this change, and restore previously working platforms
back to their former state.
Cc: linux@arm.linux.org.uk
commit a078c6d0e6288fad6d83fb6d5edd91ddb7b6ab33 upstream.
'long secs' is passed as divisor to div_s64, which accepts a 32bit
divisor. On 64bit machines that value is trimmed back from 8 bytes
back to 4, causing a divide by zero when the number is bigger than
(1 << 32) - 1 and all 32 lower bits are 0.
Use div64_long() instead.
Signed-off-by: Sasha Levin <levinsasha928@gmail.com>
Cc: johnstul@us.ibm.com
Link: http://lkml.kernel.org/r/1331829374-31543-2-git-send-email-levinsasha928@gmail.com
commit 59263b513c11398cd66a52d4c5b2b118ce1e0359 upstream.
arch/arm/mach-mx6/localtimer.c
drivers/mxc/gpu-viv/hal/os/linux/kernel/gc_hal_kernel_device.c
drivers/usb/otg/fsl_otg.c
include/linux/fsl_devices.h
sound/soc/imx/imx-hdmi-dma.c
activity begins.
completed.
commit 62d3c5439c534b0e6c653fc63e6d8c67be3a57b1 upstream.
This patch (as1519) fixes a bug in the block layer's disk-events
polling. The polling is done by a work routine queued on the
system_nrt_wq workqueue. Since that workqueue isn't freezable, the
polling continues even in the middle of a system sleep transition.
Obviously, polling a suspended drive for media changes and such isn't
a good thing to do; in the case of USB mass-storage devices it can
lead to real problems requiring device resets and even re-enumeration.
The patch fixes things by creating a new system-wide, non-reentrant,
freezable workqueue and using it for disk-events polling.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Tejun Heo <tj@kernel.org>
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
The dpm_suspend_noirq routing calls suspend_device_irqs()
first to disable all the irq no matter what flags it has.
Then it enumerates the device driver on dpm_suspend_list to
call their suspend_noirq pm callback. If any dev suspend
failed, it will call dpm_resume_noirq to re-enable all
the irq without IRQF_EARLY_RESUME, and return failed.
If dpm_suspend_noirq() return failed, then no syscore_resume()
can be called, that means the irq with flag IRQF_EARLY_RESUME,
can not be re-enabled on this case.
error = dpm_suspend_noirq(PMSG_SUSPEND);
if (error) {
goto Platform_finish;
error = syscore_suspend();
if (!error) {
syscore_resume();
dpm_resume_noirq(PMSG_RESUME);
Platform_finish:
if (suspend_ops->finish)
suspend_ops->finish();
So we must enable all the irqs no matter it's IRQF_EARLY_RESUME
or not.
Otherwise the GPIO power key who's irq has flag of IRQF_EARLY_RESUME
will be disabled forever when some device failed to suspend.
Signed-off-by: Xinyu Chen <xinyu.chen@freescale.com>
3.0.21's 603b63484725a6e88e4ae5da58716efd88154b1e directly used
the upstream patch, yet kprobes locking in 3.0.x uses spin_lock...()
rather than raw_spin_lock...().
Signed-off-by: Jan Beulich <jbeulich@suse.com>
commit 52abb700e16a9aa4cbc03f3d7f80206cbbc80680 upstream.
Xommit ac5637611(genirq: Unmask oneshot irqs when thread was not woken)
fails to unmask when a !IRQ_ONESHOT threaded handler is handled by
handle_level_irq.
This happens because thread_mask is or'ed unconditionally in
irq_wake_thread(), but for !IRQ_ONESHOT interrupts never cleared. So
the check for !desc->thread_active fails and keeps the interrupt
disabled.
Keep the thread_mask zero for !IRQ_ONESHOT interrupts.
Document the thread_mask magic while at it.
Reported-and-tested-by: Sven Joachim <svenjoac@gmx.de>
Reported-and-tested-by: Stefan Lippers-Hollmann <s.l-h@gmx.de>
Correct the license header of cpufreq earlysuspend
governor switch driver.
commit d80e731ecab420ddcb79ee9d0ac427acbc187b4b upstream.
This patch is intentionally incomplete to simplify the review.
It ignores ep_unregister_pollwait() which plays with the same wqh.
See the next change.
epoll assumes that the EPOLL_CTL_ADD'ed file controls everything
f_op->poll() needs. In particular it assumes that the wait queue
can't go away until eventpoll_release(). This is not true in case
of signalfd, the task which does EPOLL_CTL_ADD uses its ->sighand
which is not connected to the file.
This patch adds the special event, POLLFREE, currently only for
epoll. It expects that init_poll_funcptr()'ed hook should do the
necessary cleanup. Perhaps it should be defined as EPOLLFREE in
eventpoll.
__cleanup_sighand() is changed to do wake_up_poll(POLLFREE) if
->signalfd_wqh is not empty, we add the new signalfd_cleanup()
helper.
ep_poll_callback(POLLFREE) simply does list_del_init(task_list).
This make this poll entry inconsistent, but we don't care. If you
share epoll fd which contains our sigfd with another process you
should blame yourself. signalfd is "really special". I simply do
not know how we can define the "right" semantics if it used with
epoll.
The main problem is, epoll calls signalfd_poll() once to establish
the connection with the wait queue, after that signalfd_poll(NULL)
returns the different/inconsistent results depending on who does
EPOLL_CTL_MOD/signalfd_read/etc. IOW: apart from sigmask, signalfd
has nothing to do with the file, it works with the current thread.
In short: this patch is the hack which tries to fix the symptoms.
It also assumes that nobody can take tasklist_lock under epoll
locks, this seems to be true.
Note:
- we do not have wake_up_all_poll() but wake_up_poll()
is fine, poll/epoll doesn't use WQ_FLAG_EXCLUSIVE.
- signalfd_cleanup() uses POLLHUP along with POLLFREE,
we need a couple of simple changes in eventpoll.c to
make sure it can't be "lost".
Reported-by: Maxime Bizon <mbizon@freebox.fr>
commit b4bc724e82e80478cba5fe9825b62e71ddf78757 upstream.
An interrupt might be pending when irq_startup() is called, but the
startup code does not invoke the resend logic. In some cases this
prevents the device from issuing another interrupt which renders the
device non functional.
Call the resend function in irq_startup() to keep things going.
Reported-and-tested-by: Russell King <rmk+kernel@arm.linux.org.uk>
commit ac5637611150281f398bb7a47e3fcb69a09e7803 upstream.
When the primary handler of an interrupt which is marked IRQ_ONESHOT
returns IRQ_HANDLED or IRQ_NONE, then the interrupt thread is not
woken and the unmask logic of the interrupt line is never
invoked. This keeps the interrupt masked forever.
This was not noticed as most IRQ_ONESHOT users wake the thread
unconditionally (usually because they cannot access the underlying
device from hard interrupt context). Though this behaviour was nowhere
documented and not necessarily intentional. Some drivers can avoid the
thread wakeup in certain cases and run into the situation where the
interrupt line s kept masked.
Handle it gracefully.
Reported-and-tested-by: Lothar Wassmann <lw@karo-electronics.de>
